Depreciated, for most up-to-date version, visit here:
http://www.hydrogenaudio.org/forums/index....showtopic=76968 (http://www.hydrogenaudio.org/forums/index.php?showtopic=76968)
Original component(
*** FOR DOWNLOAD PLEASE SEE BELOW! ***) is here: http://gro.clinux.org/projects/ikiki/ (http://gro.clinux.org/projects/ikiki/) , just credit the original developer bluenet, Thank you!
I grab the source and do some modification("download lyrics" is still working)
However, maybe there are some problems in this modification.
Feedback is welcome!
screenshot:
(http://img510.imageshack.us/img510/5079/untitledlt1.th.jpg) (http://img510.imageshack.us/my.php?image=untitledlt1.jpg)
(http://img515.imageshack.us/img515/112/lyricshowum9.th.png) (http://img515.imageshack.us/my.php?image=lyricshowum9.png)
Requirementsfoobar2000 v0.9.5
Columns UI 0.3
Current version: 0.3.3.9
ChangeLog[full changelog] (http://theo.foobar2000.com.cn/projects/foo_uie_lyrics/Changelog.txt)
0.3.3.9- Fix high cpu usage while "Enable global field processing" is checked
- Minor cleanups
0.3.3.8- Major changes on main menu commands: Removing command "Search lyirc online" in "File"; Providing a new pop menu contains most useful commands in "View" => "Lyric Show"
- Minor changes and fixes
0.3.3.7- Fix a bug that cache may contain two lyric for one track
- Add context menu and a option for editing lyric file with external editor
- Move "Now playing" context menu items to a new popup menu
- Fix display setting importing/exporting and add support for interval, period, global field
0.3.3.6- Fix a bug that will crash on startup under certain circumstance
- Improved caching mechanism: file location, codepage, offset now won't lost after track change
- Combobox of codepage is now auto-sorted
0.3.3.5- Fix a bug that panel is visible on creation
- Fix a bug that won't show lyrics after changing track with lyric manually downloaded
0.3.3.4- Codepage change now take effect on embeded lyrics
- CRITICAL: Fix a bug that will mess up whole lyric file after offset adjust
- Various glitch fixed
0.3.3.3- Panel now will not get focus automatically while mouse move in
- Mouse scroll now will work with limit properly
- Fix a bug that after change offset, 'offset' tag won't close the bracket on its line
- Fix a bug that lyric won't save while choose user defined directory
- Some text change in configruation page
0.3.3.2
- Now Lyric Show is explicit a single CUI extension to prevent possible errors
- Fix lyric picking when downloading/updating lyrics automatically
- Fix timer loss while configing scroll setting
- Fix hang while using association manager
0.3.3.1
- Fix character problem when copying lyric to clipboard
- Better lyric file handling with UTF8 without BOM
- "Copy lyric without timestamp" now will be copied as that lyric displayed
- Add %lyric_currentline% filed
- Fix modal call when tidying associations which delay foobar2000 ui
- Build with latest foobar2000 SDK
0.3.3.0- Fix a possibly crash when reloading lyric
- Global titleformating filed processing now require latest foobar2000(using metadb_display_field_provider)
- %lyric_exists% and %lyric_hastimestamp% now refresh corectly
- Add support for per instance config (only display setting, that means you can use it in two or more PUI configruations or CUI layouts, without modifying display settings manually)
- Add support for import/export display setting
- Fix some other glitchs
Download here: Link (http://www.hydrogenaudio.org/forums/index.php?showtopic=55691)
It looks relly nice in my config!
wow! thanks so much
great!!!
Nice work, thanks!
Good work, thank you very much
Lovely, could you see why associations doesnt work
Did you got lyrics.xml in your foobar2000 path before?
I'll fix it soon
oh~~~thx ! thx
very nice
I'll fix it soon
Yes i did and i still have it right now but it doesnt work. thanks for answering so quickly and looking into it
I'll fix it soon
I've updated.
please check at
http://www.hydrogenaudio.org/forums/index....showtopic=55691 (http://www.hydrogenaudio.org/forums/index.php?showtopic=55691)
it should work well.
Works perfectly now for lyrics existing on the disk and not yet associed. They become associed, works like a charm. Couldnt test the rest from here at work. Thanks a lot you gave life back to this plugin
Do you think it would be possible to overlay an image on the panel ?
Using it on panels UI and trying to make a nice fade effect...
As you can see on the image below :
(http://img522.imageshack.us/img522/6335/lyricsfadetn8.th.jpg) (http://img522.imageshack.us/my.php?image=lyricsfadetn8.jpg)
Very nice work!
I'm after a semi-transparent background over a picture. I tried placing an empty title display box behind the lyrics panel, containing a $drawrect with pen and brush colours of 0-0-0 and alpha-128. It worked, except lyrics panel won't clear itself on a track change, leaving text overlaying text.
Any chance of fixing this or implementing semi-transparent backdrops in the panel itself?
[a href="http://img522.imageshack.us/my.php?image=lyricsfadetn8.jpg" target="_blank"] .
EDIT: I've just put a semi-transparent background using $drawrect and put %title% in before $panel Lyric Show Panel, it seems that everyting work well. the %title% changs as soon as track does.
Is the scroller shown when this is added as panel in PanelsUI ?
scrolling works well in PanelsUI.
scrollbar is not considered in the near future just because now I have little experience on programming.
Downloaded the new version, but didn't get the scrolling to work...
The "enable scroll" is checked.
Maybe this is the key:
there's timestamped lyric and plain-text lyric.
if you got plain-text lyric, this will happen, and you can only scroll it with Mouse Scrolling.
That's the problem:under PanelsUI the mouse scrolling doesn't work
The timestamped lyrics work fine, scrolling in the time it is supposed to, and no need for manual scrolling on them.
What I want is to be able to scroll up and down with the mouse on the plain-text lyrics, and it doesn't work....
I don't know, but I guess from my bad english that it's supposed to work what I am trying to do?
Ahh, so that's no change on that from the earlier version then... I thought that was one new function, nevermind my previous post then.
Still would be awesome if it could be implented....
Can you post your code here?
I'm sorry I cannot understand you because my english is poor enough .
Never mind. Your 'edit' comment actually sorted my problem out for me. Thanks.
Yes, I just notice it.
I'll go and fix it
Hi, I've uploaded the new version, try to see if it works.
Works just fine,thank you!
Yep, it works for me too!
Thanks Very much, really great!
T.P Wang,
thank you, that is great, autoscroll work's nice when using timestamped lyric
T.P Wang i also thanks you very much. it works for me too. even wheel scroll.
But which is difference between the two zip in download section... what is SSE2 (with this one wheel scroll doesn't work).
i m very grateful too you for the development of this component i use everyday.
Cheers
Cheers
SSE2 means Intel Streaming "Single Instruction, Multiple Data" Extensions 2
http://en.wikipedia.org/wiki/SSE2 (http://en.wikipedia.org/wiki/SSE2)
so if you haven't got CPU supports SSE2, there will be problems.
Besides, the SSE2 build with some options may be "unstable", so if you meet any problem, switch to the build without "SSE2"
Thanks for support.
Thanks you very much for adding the nice fading effect, I didn't expect it that quickly...
But I noticed a little problem with it, don't know how to explain it... I'll try. The fading efftect is nice when the line appears from the bottom. But at a certain point, it suddently becomes unfaded, while it should still be faded, because still in the fade zone...
Same thing happens at the top, the line suudently becomes faded.
Did anybody else noticed it ?
Maybe you did that on purpose ?
Just a small request as well, could you make an option to enable/disable the fading effect ?
Thanks a lot
Thanks a lot
EDIT: Yes I make the fadding effect on that purpose
However, ,I'll try to fix it ASAP.
Could anybody post their CPU usage while the text is scrolling, please?
I would like to have a panel with big letters on a black full screen but I'm afraid it could keep the usage at 40/60%.
You better test it yourself,since the CPU usage is quite different from machine to machine.As for me the CPU
is pretty high when i use this panel,even with plain text,so i returned to my own lyrics panel.
Found a small "bug" I think.
When you start a new song it seems like the Lyrics window gets focused. So you can't scroll in the playlist etc without clicking in it again. It doesn't matter if the lyric is a timestamped or not, the window always gets focused.
Ok, I'll fix it.
YAS ! you have just completed my foobar ! thank you alot flippin lot !
only one small request:
could add an option to auto-scroll non-timestamped lyrics ?
THANK YOU !
Thanks a lot
I've uploaded new Lyrics show panel ver 0.3.1.1b3
Just have a try
I just have a little test(not very strict), using Microsoft's perfmon.msc to monitor foobar2000's CPU time(%)
after played same song(APE 980kps), and under same playing condition(mostly)
I've got these result (average)
1. using Lyrics Panel
6.613%
2. no Lyrics Panel
4.820%
I'm using Althlon64 3000+, WinXP Pro Sp2. with 0.3.1.1b3 quick fix(SSE2).
thanks for the modification. I have one big request, but I don't know if it is possible at all. I would like to see this panel merged with the functionality of this version (http://www.hydrogenaudio.org/forums/index.php?showtopic=30855&hl=lyricsdb&st=274#). Also it would be nice to include LyricsDB (http://www.hydrogenaudio.org/forums/index.php?showtopic=36598) search. It uses a really big lyrics database. I think it should be possible at least to call this plugin to search for lyrics if they're not found.
Ok, there is a problem for me with the fading effect. The fadinfg effect is not at the very top and very botom, seems that it is 10 px from each border, at least for me... (using panels_ui)
(http://img524.imageshack.us/img524/9822/lyricsdm2.jpg)
I'd like to add LyricDb searching support.
But I'm wondering what kinds of foo_uie_lyrics_panel's functions do you want?
strange, I'm trying to find out.
EDIT: can you post snippet of your code which $panel the Lyrics Panel? And which font do you use?
EDIT2: I think i've found the problem, you can change your Vertical Padding and Horizontal Padding to "0", I'll fix it.
Yep, that solved my problem, now the component is perfect for me !
thanks a lot !
feel like Not compatible with foo_dockable_panels.dll
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 00F3707Ch
Call path:
entry=>app_mainloop
Code bytes (00F3707Ch):
00F3703Ch: 00 00 39 5C 24 34 89 6C 24 30 73 04 8D 44 24 20
00F3704Ch: BE 09 00 00 00 66 89 28 39 74 24 34 73 10 8B 44
00F3705Ch: 24 30 50 56 8D 4C 24 24 51 E8 86 CF FE FF 39 5C
00F3706Ch: 24 34 8B 44 24 20 73 04 8D 44 24 20 66 0F EF C0
00F3707Ch: 66 0F D6 00 66 0F D6 40 08 66 89 68 10 39 5C 24
00F3708Ch: 34 8B 44 24 20 89 74 24 30 73 04 8D 44 24 20 66
00F3709Ch: 89 68 12 39 5C 24 34 8B 44 24 20 73 04 8D 44 24
00F370ACh: 20 B9 FA 00 00 00 C7 00 00 00 00 44 C7 40 04 00
Stack (0012E998h):
0012E978h: 00000000 0012ED2C 0012ED04 00000000
0012E988h: F15BBF98 F15BBCA0 00460049 F15BBD60
0012E998h: D10C7014 00F63C40 00F63BFC 0012EA0C
0012E9A8h: 00F63BF0 000905DA 00F63BF0 00F20761
0012E9B8h: 01234BB0 0012EA04 00F63BFC 01234B98
0012E9C8h: 00000000 000000A7 D10C7024 0012EA84
0012E9D8h: 00F4E338 00000000 00F130AD 00F63BF0
0012E9E8h: 0012EB60 0012EA74 00F63BEC 004576E3
0012E9F8h: 00000000 00F63BFC 00000000 00F63C40
0012EA08h: FFFFFFFF 0012EA90 0045670D 000905DA
0012EA18h: 0012EB60 00456932 00000000 000A0000
0012EA28h: 005DA330 77F16E56 77F16E77 510A0A33
0012EA38h: 6FBD7000 6FBD71C8 6FB8A1E2 6FBDB0D0
0012EA48h: 0012EA60 77D4F8A6 006F5928 00000000
0012EA58h: 000C0000 0012EAF8 0012EAE0 00B02647
0012EA68h: 00000000 00000000 00000000 00F63BEC
0012EA78h: 0012EAE0 0012EAF8 0012EA18 0012EAEC
0012EA88h: 004A9A16 00000001 0012EAF8 00456B60
0012EA98h: 000905DA 015024D8 0012EB60 00456932
0012EAA8h: 00000000 77D54F1C 77D618FC 00000000
Registers:
EAX: 01234BB0, EBX: 00000008, ECX: D10C700C, EDX: 01230608
ESI: 00000009, EDI: 00F63C40, EBP: 00000000, ESP: 0012E998
Crash location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7E37F000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 763B0000h - 76405000h
IMM32 loaded at 76390000h - 763AD000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 6FB80000h - 6FBFD000h
prio loaded at 003F0000h - 003F5000h
uxtheme loaded at 5AD70000h - 5ADA8000h
MSCTF loaded at 74720000h - 7476C000h
YzShadow loaded at 00AE0000h - 00AEE000h
DM2 loaded at 00B00000h - 00B06000h
msctfime loaded at 755C0000h - 755EE000h
foo_converter loaded at 00B30000h - 00B99000h
foo_cwb_hooks loaded at 00BC0000h - 00C0D000h
foo_dockable_panels loaded at 00C30000h - 00C63000h
foo_infobox loaded at 00C90000h - 00CD0000h
foo_input_monkey loaded at 00CF0000h - 00D3A000h
foo_input_std loaded at 00D60000h - 00E73000h
foo_masstag loaded at 00EA0000h - 00EEF000h
foo_uie_lyrics loaded at 00F10000h - 00F6F000h
WININET loaded at 771B0000h - 7727E000h
Normaliz loaded at 00F80000h - 00F89000h
iertutil loaded at 6E850000h - 6E895000h
gdiplus loaded at 4EC50000h - 4EDF3000h
WINMM loaded at 76B40000h - 76B6D000h
foo_uie_playlists_dropdown loaded at 01240000h - 01279000h
foo_uie_single_column_playlist loaded at 012A0000h - 012EC000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_uie_tabs loaded at 01310000h - 0133A000h
foo_uie_trackinfo_mod loaded at 01360000h - 013B7000h
foo_ui_columns loaded at 013D0000h - 01473000h
foo_utils loaded at 014A0000h - 014D8000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 00F63C40h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F63BF0h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F20761h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F4E338h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F130ADh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F63BECh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004576E3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045670Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456932h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77F16E56h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+00000229h)
Address: 77F16E77h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+0000024Ah)
Address: 6FBD7000h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 6FBD71C8h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 6FB8A1E2h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Symbol: "ScriptPlace" (+000000E9h)
Address: 6FBDB0D0h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 77D4F8A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00B02647h, location: "DM2", loaded at 00B00000h - 00B06000h
Symbol: "CreateMenuFromString" (+00000D27h)
Address: 004A9A16h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456B60h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D54F1Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000002CBh)
Address: 77D618FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D9ABF4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 004AD1EEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D48744h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D54ECBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+0000027Ah)
Address: 77D7046Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D54EF0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+0000029Fh)
Address: 77D54D17h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000000C6h)
Address: 77D54F22h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D54F44h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48826h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48840h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4E0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B51Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D4B483h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D494CEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D4D4F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D4B913h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 773EAFF1h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 77407392h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001B4F2h)
Address: 77407720h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001B880h)
Address: 77D4BF88h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "RedrawWindow" (+0000000Ch)
Address: 7740885Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001C9BCh)
Address: 774096BDh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001D81Dh)
Address: 7740AF3Fh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001F09Fh)
Address: 7740A549h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001E6A9h)
Address: 77D4883Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 77D4B8CAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000000h)
Address: 77D4D8A0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDlgCtrlID" (+00000027h)
Address: 00F54738h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D56950h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendDlgItemMessageW" (+00000032h)
Address: 00456D0Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00F54728h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55324h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 004EE568h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55B68h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 004EE3F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE450h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE558h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE564h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0213h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55E8Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogIndirectParamAorW" (+00000033h)
Address: 77D5A1AFh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogParamW" (+00000049h)
Address: 00456E73h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00466549h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00F1852Ah, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004DF5FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D4F818h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 77D4F815h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 77D4F95Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 77D4F96Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 013F7415h, location: "foo_ui_columns", loaded at 013D0000h - 01473000h
Address: 77D4F829h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 00460088h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D9CB2Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "TrackPopupMenuEx" (+0000000Ch)
Address: 77D94EF9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "TrackPopupMenu" (+0000001Bh)
Address: 00F1848Eh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F50065h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F184A4h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F17499h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D488EAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00F501E1h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D4D63Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowLongW" (+00000000h)
Address: 00F223BCh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F22370h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D488E1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 00C333ABh, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 00C332F0h, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 77D5F5A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowTextA" (+0000005Bh)
Address: 77D4850Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485B4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B409h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D4B3A3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 77D4B3C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D4C341h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D54DF1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000001A0h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Columns UI 0.2.0 alpha 2 (foo_ui_columns)
Playlists Dropdown 0.6 alpha 3 (foo_uie_playlists_dropdown)
Playlist Tools 0.5.9 (foo_utils)
Track info panel mod 0.8.0 beta [Dec 6 2006 - 14:21:24] (foo_uie_trackinfo_mod)
Converter 1.0.1 (foo_converter)
WMA Decoder 1.1 (foo_input_std)
cwbowron's title format hooks 1.2.5 [Jun 8 2007 - 08:49:42] (foo_cwb_hooks)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48] (foo_dockable_panels)
Tabbed panel modified 0.2.5 (foo_uie_tabs)
Masstagger 1.6 (foo_masstag)
Monkey's Audio decoder 2.1.2 (foo_input_monkey)
Special file info box 2.0.4 (foo_infobox)
Single Column Playlist Display 0.5.4 beta [Jan 9 2007 - 15:42:59] (foo_uie_single_column_playlist)
foobar2000 core 0.9.4.3 (Core)
Standard Input Array 1.0 (foo_input_std)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00] (foo_cwb_hooks)
Lyric Show Panels 0.3.1.1b3 [Jun 23 2007 - 16:14:36] (foo_uie_lyrics)
FLAC Decoder 1.1.0 (foo_input_std)
Great work!
May i know what's the difference between ZN-CH and ZN-CH Special ? what's the special for?
@ store88
Use "codebox" instead of "quote"!
Great work!
the differences are:
in ZH-CN Special you can specify english font and chinese font.
Since I work on the component, for some reasons, I haven't build ZhCN.Special
There's only ZhCN available:
http://bbs.pcpchina.com/index.php?showtopic=126534 (http://bbs.pcpchina.com/index.php?showtopic=126534)
@store88:
use codebox please!
There's no crash on my machine.
But it's not recommended that use lyric panel with PanelsUI and dockable panels.
However, I think it's because foo_uie_tabs or foo_uie_single_column_playlist
Core (2007-04-21 03:36:34)
foo_albumlist.dll (2007-04-21 03:34:58)
Album List 3.2.0
foo_audioscrobbler.dll (2007-05-13 14:23:40)
Audioscrobbler 1.3.6
foo_cdda.dll (2007-04-21 03:34:44)
CD Audio Decoder 2.1.1
foo_converter.dll (2007-04-21 03:34:28)
Converter 1.0.1
foo_convolve.dll (2006-08-04 21:57:26)
Convolver 0.3
foo_cwb_hooks.dll (2007-06-05 10:10:00)
cwbowron's title format hooks 1.2.4 [Jun 5 2007 - 10:09:39]
Tagger Panel Window 1.0.beta3 [Jun 5 2007 - 10:09:39]
foo_dockable_panels.dll (2007-03-28 09:19:02)
foo_dsp_bs2b.dll (2006-11-14 14:42:36)
bs2b 2.1.0
foo_dsp_crossfader.dll (2007-06-13 00:02:08)
Gapless Crossfader 0.3.2.2 (Intel SSE)
foo_dsp_delta.dll (2006-03-21 18:16:22)
LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2007-01-20 07:36:56)
Standard DSP array 1.0
foo_dsp_tube.dll (2007-02-07 07:17:55)
Tube Sound 0.8
foo_freedb2.dll (2007-01-22 13:07:44)
freedb Tagger 0.5.2a
foo_input_monkey.dll (2007-04-13 18:39:54)
foo_input_std.dll (2007-04-21 03:34:22)
FLAC Decoder 1.1.0
WMA Decoder 1.1
foo_masstag.dll (2007-04-21 03:33:44)
Masstagger 1.6
foo_masstag_addons.dll (2007-05-20 08:00:08)
Masstagger Addons 0.3.4 (Intel SSE)
foo_out_ks.dll (2006-08-04 21:54:58)
Kernel Streaming Output 1.2.2
foo_playcount_mod.dll (2007-06-21 14:53:34)
Play Count Mod 1.0.2
foo_playlist_manager.dll (2006-03-13 00:25:15)
Playlist Manager 1.0
foo_rgscan.dll (2007-04-21 03:33:22)
ReplayGain Scanner 2.0.2
foo_run.dll (2006-06-15 22:08:10)
Run services 0.3.2
foo_ui_columns.dll (2007-06-08 00:22:56)
foo_ui_panels.dll (2007-06-12 12:28:20)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]
foo_ui_std.dll (2007-04-21 03:33:14)
Default User Interface 0.9acc
foo_uie_albumart.dll (2007-01-15 17:04:44)
Album Art Panel 0.2.6
foo_uie_albumlist.dll (2007-06-11 21:13:53)
Album list panel 0.2.3 beta
foo_uie_lyrics.dll (2007-06-23 15:27:53)
Lyric Show Panels 0.3.1.1b3 (SSE2) [Jun 23 2007 - 15:27:29]
foo_uie_playlists_dropdown.dll (2007-02-08 15:26:16)
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
foo_unpack.dll (2007-04-21 03:35:14)
RAR reader 1.1
ZIP/GZIP reader 1.0
Downloaded the new version, and it still steals focus for me.
I am using Panels UI, and I have a panel on the left where i can change between lyrics, art and some more things using pvars. It's just when the lyrics is "active" or how to say that it steals focus from the SCPL.
Hope you understand my bad english.
I got it.
But I think it's not bug. because i can't find a way to Handle Mouse wheel event without setting focus.
I got it.
Okok.. well it was just a small problem, I rather have it like this and being able to scroll the lyrics... Great work with this!
But I also have library filter in that panel I noticed, and in that you can scroll, but it doesn't automatically take focus when a new song is being played.... Maybe there is a way? In any way thanks for your work, this component really needed this.
I got it.
if you want to scroll with mouse wheel, just click the Library filter/SCPL and so on...
crash >_<
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 00F8707Ch
Call path:
entry=>app_mainloop
Code bytes (00F8707Ch):
00F8703Ch: 00 00 39 5C 24 34 89 6C 24 30 73 04 8D 44 24 20
00F8704Ch: BE 09 00 00 00 66 89 28 39 74 24 34 73 10 8B 44
00F8705Ch: 24 30 50 56 8D 4C 24 24 51 E8 86 CF FE FF 39 5C
00F8706Ch: 24 34 8B 44 24 20 73 04 8D 44 24 20 66 0F EF C0
00F8707Ch: 66 0F D6 00 66 0F D6 40 08 66 89 68 10 39 5C 24
00F8708Ch: 34 8B 44 24 20 89 74 24 30 73 04 8D 44 24 20 66
00F8709Ch: 89 68 12 39 5C 24 34 8B 44 24 20 73 04 8D 44 24
00F870ACh: 20 B9 FA 00 00 00 C7 00 00 00 00 44 C7 40 04 00
Stack (0012F468h):
0012F448h: 013EE530 7D5993C0 77F443DD 7D5993C0
0012F458h: 00000004 00000000 013EDA3C 00000000
0012F468h: C903D77F 00FB3C40 00FB3BFC 0012F4DC
0012F478h: 00FB3BF0 00100346 00FB3BF0 00F70761
0012F488h: 010645D0 0012F4D4 00FB3BFC 010645B8
0012F498h: 00000000 000000A7 C903D76F 0012F554
0012F4A8h: 00F9E338 00000000 00F630AD 00FB3BF0
0012F4B8h: 0012F630 0012F544 00FB3BEC 004576E3
0012F4C8h: 00000000 00FB3BFC 00000000 00FB3C40
0012F4D8h: FFFFFFFF 0012F560 0045670D 00100346
0012F4E8h: 0012F630 00456932 00000000 0000042C
0012F4F8h: 0012F604 0075B7BC 00000001 FFFFFFF4
0012F508h: 0000004E 0012F604 00100346 00502748
0012F518h: 0012F538 77D1B8F3 0075B7A8 0075E9B0
0012F528h: 0000042C 0012F604 00000000 0016FCC8
0012F538h: 0012F5D0 7719AF7B 00100346 00FB3BEC
0012F548h: 0000042C 0012F604 0012F4E8 0012F5BC
0012F558h: 004A9A16 00000001 0012F5C8 00456B60
0012F568h: 00100346 009F9E00 0012F630 00456932
0012F578h: 00000000 00000000 00000000 00000000
Registers:
EAX: 010645D0, EBX: 00000008, ECX: C903D747, EDX: 01060608
ESI: 00000009, EDI: 00FB3C40, EBP: 00000000, ESP: 0012F468
Crash location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Loaded modules:
ntdll loaded at 7C920000h - 7C9B5000h
kernel32 loaded at 7C800000h - 7C91E000h
COMCTL32 loaded at 77180000h - 77282000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E47000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32 loaded at 77D10000h - 77D9F000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7D590000h - 7EF0E000h
ole32 loaded at 76990000h - 76ACD000h
comdlg32 loaded at 76320000h - 76367000h
IMM32 loaded at 76300000h - 7631D000h
LPK loaded at 621F0000h - 621F9000h
USP10 loaded at 73FA0000h - 7400B000h
MSCTF loaded at 74680000h - 746CB000h
msctfime loaded at 73640000h - 7366E000h
foo_abx loaded at 00AB0000h - 00AE3000h
foo_albumlist loaded at 00B10000h - 00B57000h
OLEAUT32 loaded at 770F0000h - 7717C000h
foo_cdda loaded at 00B80000h - 00BB5000h
foo_converter loaded at 00BE0000h - 00C49000h
foo_dsp_std loaded at 00C70000h - 00CB1000h
foo_freedb2 loaded at 00CE0000h - 00D20000h
foo_input_std loaded at 00D40000h - 00E53000h
foo_masstag loaded at 00E80000h - 00ECF000h
foo_rgscan loaded at 00EF0000h - 00F38000h
foo_uie_lyrics loaded at 00F60000h - 00FBF000h
WININET loaded at 76680000h - 76727000h
CRYPT32 loaded at 765E0000h - 76672000h
MSASN1 loaded at 76DB0000h - 76DC2000h
gdiplus loaded at 4AEF0000h - 4B093000h
WINMM loaded at 76B10000h - 76B3A000h
foo_ui_std loaded at 01080000h - 010D7000h
foo_unpack loaded at 01100000h - 0112E000h
RBHook loaded at 014C0000h - 014CD000h
Mmm loaded at 01590000h - 015D2000h
version loaded at 77BD0000h - 77BD8000h
wsock32 loaded at 71A30000h - 71A3B000h
WS2_32 loaded at 71A10000h - 71A27000h
WS2HELP loaded at 71A00000h - 71A08000h
PSAPI loaded at 76BC0000h - 76BCB000h
imagehlp loaded at 76C60000h - 76C88000h
DBGHELP loaded at 68CC0000h - 68D61000h
Address: 00FB3C40h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 00FB3BF0h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 00F70761h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 00F9E338h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 00F630ADh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 00FB3BECh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FBF000h
Address: 77D1B8F3h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 7719AF7Bh, location: "COMCTL32", loaded at 77180000h - 77282000h
Address: 77D18724h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D24175h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D40477h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D24198h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D23FC1h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D241CAh, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D241ECh, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D18806h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D18820h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D1B88Bh, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetParent" (+0000016Ch)
Address: 77D1881Ah, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 771B6CF6h, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001AECCh)
Address: 771B7084h, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001B25Ah)
Address: 77D1BF60h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 771B81C0h, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001C396h)
Address: 771B9021h, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001D1F7h)
Address: 771B9E2Fh, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001E005h)
Address: 77D188C1h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D188CAh, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 771B9EADh, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001E083h)
Address: 771BA4E3h, location: "COMCTL32", loaded at 77180000h - 77282000h
Symbol: "Ordinal384" (+0001E6B9h)
Address: 77D189BDh, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D189E0h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D18A00h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D2E0A7h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FD96h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D1DAD2h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEB98h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FE08h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00E16F94h, location: "foo_input_std", loaded at 00D40000h - 00E53000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00D1DAD2h, location: "foo_freedb2", loaded at 00CE0000h - 00D20000h
Address: 00430967h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C930732h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C931538h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C92EE18h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "strchr" (+00000117h)
Address: 7C931596h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9306EBh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Address: 004E4198h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C93056Dh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C937BF5h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 004E3E68h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9306F0h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049812Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C92E1FEh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "ZwQueryValueKey" (+00000000h)
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C91E000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839A00h, location: "kernel32", loaded at 7C800000h - 7C91E000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C91E000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004962EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
ABX Comparator 1.3.1 (foo_abx)
Album List 3.2.0 (foo_albumlist)
ReplayGain Scanner 2.0.2 (foo_rgscan)
ZIP/GZIP reader 1.0 (foo_unpack)
Standard DSP array 1.0 (foo_dsp_std)
freedb Tagger 0.5.2a (foo_freedb2)
Default User Interface 0.9acc (foo_ui_std)
CD Audio Decoder 2.1.1 (foo_cdda)
RAR reader 1.1 (foo_unpack)
T.P. thanks for the great enhancements to this plugin!
Please consider fixing the #1 problem with it...we MUST be able to use a different lyrics database than the one it is currently using (which, everyone agrees, is terrible). Please let us edit it (either using a UI inside the panel's settings, or an external text file with one or more web addresses).
A couple of issues here:
- I'm using Panels Ui, and the scrolling doesn't work for the SCP display - if I open up the layout dialog box and click the OK button, I can scroll fine, until I select a new track, and from then on I cannot scroll at all in SCP until clicking OK again in the layout window. For some reason, scrolling works just fine in my Library filter panel.
- What I want to do is to overlay this panel over another panel and see just the text of the lyrivs over the panel beneath. When I try, it just flickers back and forth between the two panels
crash >_<
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0012F468h):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Ok, I noticed that you don't have ColumnsUI installed.
you can download it
HERE (http://yuo.be/columns.php)T.P. thanks for the great enhancements to this plugin!
Thank you.
I'm trying to Add LyricDB(and you can see it's already in the TODO List) support.
But One BIG problem is that there's many differences between one lyric server to another. Thus, I can only support several lyrics server.
A couple of issues here:- I'm using Panels Ui, and the scrolling doesn't work for the SCP display - if I open up the layout dialog box and click the OK button, I can scroll fine, until I select a new track, and from then on I cannot scroll at all in SCP until clicking OK again in the layout window. For some reason, scrolling works just fine in my Library filter panel.
1. It seems that I should remove "automatic setting focus" in Lyric Panel, which take effect on mouse wheeling with lyric without timestamp
2. Please don't try to overlay the panel over another panel. Because I made "transparent background" work by just bliting the backgournd(without lyric panel) as a Bitmap to the panel's bg. Because I can't find a way to transparent background realtime(I tried a coupe of methods before), I'm sorry I can't solve this problem
thanks T.P. Wang
but it still crash....
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0012F468h):
0012F448h: 014BE530 7D5993C0 77F443DD 7D5993C0
0012F458h: 00000004 00000000 014BDA3C 00000000
0012F468h: 6BE7395C 00FB3C40 00FB3BFC 0012F4DC
0012F478h: 00FB3BF0 0015075C 00FB3BF0 00F70761
0012F488h: 01064678 0012F4D4 00FB3BFC 01064660
0012F498h: 00000000 000000A7 6BE7394C 0012F554
0012F4D8h: FFFFFFFF 0012F560 0045670D 0015075C
0012F4F8h: 0012F604 0076B1DC 0012F518 77D1EB1E
0012F508h: 006F40A8 00030001 00000000 00000001
0012F518h: 0012F55C 74690E6C 00020121 00000000
0012F528h: 00000001 74690E71 00030001 7FFDD000
0012F538h: 00000001 00A50000 00020121 00FB3BEC
0012F548h: 0000042C 0012F5A4 0012F4E8 0012F5BC
0012F568h: 0015075C 009F89D8 0012F630 00456932
0012F578h: 00000000 77D1EA7E 00030000 00000001
Registers:
EAX: 01064678, EBX: 00000008, ECX: 6BE73964, EDX: 01060608
Loaded modules:
foo_ui_columns loaded at 01080000h - 01123000h
foo_ui_std loaded at 01150000h - 011A7000h
foo_unpack loaded at 011D0000h - 011FE000h
RBHook loaded at 01220000h - 0122D000h
Mmm loaded at 01600000h - 01642000h
Address: 77D1EB1Eh, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 74690E6Ch, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+00000A03h)
Address: 74690E71h, location: "MSCTF", loaded at 74680000h - 746CB000h
Symbol: "TF_UninitSystem" (+00000A08h)
Address: 77D1EA7Eh, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 77D1EA8Dh, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D1EA90h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D1EBD3h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 7C92EAE3h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
thanks T.P. Wang
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0012F468h):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
When and how it will happen? On startup?
try to remove foo_uie_lyrics.dll first. fire up foobar2000 and select Columns UI. then place foo_uie_lyrics.dll back and see if it works.
when i try setting lyrics show foobar will crash
or when i play a song with lyrics the lyrics show start scrolling than it will crash
sorry for my poor english , i hope you can understand what i say
crash, too
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 00CA707Ch
Call path:
entry=>app_mainloop
Code bytes (00CA707Ch):
00CA703Ch: 00 00 39 5C 24 34 89 6C 24 30 73 04 8D 44 24 20
00CA704Ch: BE 09 00 00 00 66 89 28 39 74 24 34 73 10 8B 44
00CA705Ch: 24 30 50 56 8D 4C 24 24 51 E8 86 CF FE FF 39 5C
00CA706Ch: 24 34 8B 44 24 20 73 04 8D 44 24 20 66 0F EF C0
00CA707Ch: 66 0F D6 00 66 0F D6 40 08 66 89 68 10 39 5C 24
00CA708Ch: 34 8B 44 24 20 89 74 24 30 73 04 8D 44 24 20 66
00CA709Ch: 89 68 12 39 5C 24 34 8B 44 24 20 73 04 8D 44 24
00CA70ACh: 20 B9 FA 00 00 00 C7 00 00 00 00 44 C7 40 04 00
Stack (0012F468h):
0012F448h: 0012F4CC 0012F48C 00000000 B830BDD8
0012F458h: B830B9DC B830BA94 B830BABC 804E4490
0012F468h: A5284B4A 00CD3C40 00CD3BFC 0012F4DC
0012F478h: 00CD3BF0 000C02FC 00CD3BF0 00C90761
0012F488h: 00FA51E8 0012F4D4 00CD3BFC 00FA51D0
0012F498h: 00000000 000000A7 A5284B5A 0012F554
0012F4A8h: 00CBE338 00000000 00C830AD 00CD3BF0
0012F4B8h: 0012F630 0012F544 00CD3BEC 004576E3
0012F4C8h: 00000000 00CD3BFC 00000000 00CD3C40
0012F4D8h: FFFFFFFF 0012F560 0045670D 000C02FC
0012F4E8h: 0012F630 00456932 00000000 00000060
0012F4F8h: 010F4124 0012F514 77E25A0E 12010F53
0012F508h: 010F4124 010F40D0 77CF84B2 77CF86BE
0012F518h: 12010F53 00000039 0012F5B4 010930C0
0012F528h: 00140372 12010F53 010F40D0 00140372
0012F538h: 0000000F 7717AFF1 010C02FC 00CD3BEC
0012F548h: 00000060 0012F604 0012F4E8 0012F5BC
0012F568h: 000C02FC 01759CB8 0012F630 00456932
0012F578h: 00000000 00000012 00000000 00000000
Registers:
EAX: 00FA51E8, EBX: 00000008, ECX: A5284B72, EDX: 00FA0608
ESI: 00000009, EDI: 00CD3C40, EBP: 00000000, ESP: 0012F468
Crash location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Loaded modules:
ntdll loaded at 7C930000h - 7C9CC000h
kernel32 loaded at 7C800000h - 7C92F000h
COMCTL32 loaded at 77160000h - 77263000h
msvcrt loaded at 77BC0000h - 77C18000h
ADVAPI32 loaded at 77F50000h - 77FF8000h
RPCRT4 loaded at 77D80000h - 77E11000h
GDI32 loaded at 77E20000h - 77E67000h
USER32 loaded at 77CF0000h - 77D7F000h
SHLWAPI loaded at 77E70000h - 77EEC000h
SHELL32 loaded at 7D5A0000h - 7E1D1000h
ole32 loaded at 76970000h - 76AAD000h
comdlg32 loaded at 76300000h - 76347000h
IMM32 loaded at 762E0000h - 762FD000h
LPK loaded at 62340000h - 62349000h
USP10 loaded at 73F80000h - 73FEB000h
MSCTF loaded at 74660000h - 746AB000h
msctfime loaded at 75110000h - 7513E000h
IMKR12 loaded at 3A700000h - 3A769000h
OLEAUT32 loaded at 770D0000h - 7715C000h
foo_dsp_std loaded at 00AD0000h - 00B11000h
foo_input_std loaded at 00B40000h - 00C53000h
foo_uie_lyrics loaded at 00C80000h - 00CDF000h
WININET loaded at 42E20000h - 42EED000h
Normaliz loaded at 00CF0000h - 00CF9000h
iertutil loaded at 42BA0000h - 42BE5000h
gdiplus loaded at 4B230000h - 4B3D3000h
WINMM loaded at 76AF0000h - 76B1B000h
foo_ui_columns loaded at 00FB0000h - 01053000h
DSOUND loaded at 73E50000h - 73EAC000h
VERSION loaded at 77BB0000h - 77BB8000h
WINTRUST loaded at 76BE0000h - 76C0E000h
CRYPT32 loaded at 765C0000h - 76653000h
MSASN1 loaded at 77C40000h - 77C52000h
IMAGEHLP loaded at 76C40000h - 76C68000h
wdmaud loaded at 72C70000h - 72C79000h
msacm32 loaded at 72C60000h - 72C68000h
MSACM32 loaded at 77B90000h - 77BA5000h
midimap loaded at 77B80000h - 77B87000h
KsUser loaded at 73E20000h - 73E24000h
DBGHELP loaded at 58DE0000h - 58E81000h
Address: 00CD3C40h, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 00CD3BF0h, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 00C90761h, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 00CBE338h, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 00C830ADh, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 00CD3BECh, location: "foo_uie_lyrics", loaded at 00C80000h - 00CDF000h
Address: 77E25A0Eh, location: "GDI32", loaded at 77E20000h - 77E67000h
Symbol: "GdiReleaseDC" (+00000018h)
Address: 77CF84B2h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF86BEh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Symbol: "ReleaseDC" (+00000021h)
Address: 010930C0h, location: "foo_ui_std", loaded at 01080000h - 010D7000h
Address: 7717AFF1h, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 010C02FCh, location: "foo_ui_std", loaded at 01080000h - 010D7000h
Address: 77CF85A4h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 01093312h, location: "foo_ui_std", loaded at 01080000h - 010D7000h
Address: 77CF8734h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D03745h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D20457h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D03768h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D03591h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D0379Ah, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF84FCh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D037BCh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF8816h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF8830h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CFB89Bh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CFB903h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF882Ah, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77197392h, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 77197720h, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 77CFBF78h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 7719885Ch, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 771996BDh, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 7719A4CBh, location: "COMCTL32", loaded at 77160000h - 77263000h
Symbol: "Ordinal384" (+0001E62Bh)
Address: 77CF88D1h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 7719A549h, location: "COMCTL32", loaded at 77160000h - 77263000h
Address: 77CF88DAh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 7719AB7Fh, location: "COMCTL32", loaded at 77160000h - 77263000h
Symbol: "Ordinal384" (+0001ECDFh)
Address: 74664636h, location: "MSCTF", loaded at 74660000h - 746AB000h
Symbol: "DllGetClassObject" (+000002ABh)
Address: 77CF89CDh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF89F0h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CF8A10h, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77D0D99Dh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 77CFDAEAh, location: "USER32", loaded at 77CF0000h - 77D7F000h
Address: 7C940732h, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C940738h, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C941596h, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C9406EBh, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C94056Dh, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C93EE18h, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C9406F0h, location: "ntdll", loaded at 7C930000h - 7C9CC000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C92F000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C92F000h
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C92F000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
deleted all optional components and run but still crash.
and same problem serect.
0.3.1.1b is fine. works well.
but after 0.3.1.1b1 is not working.
Getting metadb handle leak over here with the latest SSE2 version. Foobar 0.9.4.3, XPSP2 up to date.
Any other components?
eg. unofficial playcount?
well close. I don't use the unofficial playcount plugin but I use foo_misc_addons of acropolis providing the same functionality. But this hasn't happened once before I use your component. I don't use many other 3rd party plugins either.
Core (2007-04-21 02:36:34)
foo_albumlist.dll (2007-04-21 02:34:58)
Album List 3.2.0
foo_autoplaylist.dll (2006-08-04 21:56:56)
Autoplaylist Manager 1.0
foo_cdda.dll (2007-04-21 02:34:44)
foo_channel_mixer.dll (2007-02-27 18:15:50)
Channel Mixer 0.9.6.2
foo_converter.dll (2007-04-21 02:34:28)
Converter 1.0.1
foo_cwb_hooks.dll (2007-05-04 12:45:42)
cwbowron's title format hooks 1.1.1 [May 4 2007 - 12:39:47]
foo_dbsearch.dll (2007-01-25 21:58:48)
Database Search 1.4
foo_dsp_std.dll (2007-01-20 06:36:56)
foo_input_ofr.dll (2006-06-26 19:13:24)
OptimFROG Lossless/DualStream Decoder 1.21b
foo_input_std.dll (2007-04-21 02:34:22)
FLAC Decoder 1.1.0
WMA Decoder 1.1
foo_input_tak.dll (2007-05-13 18:54:34)
TAK Decoder 0.3.2
foo_input_tta.dll (2006-05-01 23:53:16)
TTA Audio Decoder (unofficial) 2.4.2
foo_masstag.dll (2007-04-21 02:33:44)
Masstagger 1.6
foo_menu_addons.dll (2007-05-21 00:00:50)
Menu Addons 0.3.9.5 (Intel SSE)
foo_misc_addons.dll (2007-05-23 13:19:48)
Misc. Addons 0.1 (Intel SSE)
foo_navigator.dll (2006-11-05 02:56:28)
Navigator 0.6
foo_playlist_manager.dll (2007-01-22 13:05:12)
Playlist Manager 1.0.2
foo_psf.dll (2007-01-24 07:01:04)
Highly Experimental 2.0.5
foo_rgscan.dll (2007-04-21 02:33:22)
foo_ui_columns.dll (2007-06-07 23:22:56)
foo_uie_lyrics.dll (2007-06-23 16:15:00)
foo_utils.dll (2007-01-22 13:05:00)
Album List 3.2.0
Converter 1.0.1
Database Search 1.4
FLAC Decoder 1.1.0
WMA Decoder 1.1
TAK Decoder 0.3.2
Masstagger 1.6
Navigator 0.6
ok, can you explain when or how it will occur? thanks.
Just try out your plugin put it in my config try the first song with timed lyric in tag and quit (during playing IIRC). My config is just the column view of ColumnUI, its Playlist switcher and your panel. If you need more info tell me.
which OS you are using now?
it seems that some of your system component doesn't work well.
EDIT@
thuan:
Now I'm looking into it.
However, I use lyric panel every day, meet no crash report or metadb leaks.
EDIT2I've just looked into foo_misc_addons, it seems use the source like foo_playcount_mod, which will also lead to metadb handle leaks, Some time ago I recompiled foo_playcount_mod with some changes, and now there's no metadb_handle leaks to me.
I've got metadb leaks too when I close foobar
I'm using Vista
components used are :
AC3 decoder 0.8
Album List 3.2.0
Decoding speed test 1.0
Audio CD Writer 2.0.1
Converter 1.0.1
foo_custominfo 0.1.2
Database Search 1.4
DTS decoder 0.1.7
Monkey's Audio decoder 2.1.1
Shorten decoder 0.4.2a
FLAC Decoder 1.1.0
WMA Decoder 1.1
Masstagger 1.6
MSN Now Playing (alt) 2.4.2
Playback Statistics 1.3.2
Playlist Loader Benchmark 0.3
Pretty Popup 1.2.3
Randomized playlist entry 1.2.3
Send to Device 1.0.5 [Nov 17 2006 - 14:16:40]
foosic music database 1.0 beta 12
Columns UI 0.2.0 alpha 1
Album list panel 0.2.1 beta 4
Peakmeter Panel 0.0.2
Quick Search Toolbar 2.8k
WSH Panel (uie) 0.7.1
RAR reader 1.1
ZIP/GZIP reader 1.0
LHA unpacker 1.0
many thx for this great plug-in
I'm using Vista
AC3 decoder 0.8
Album List 3.2.0
Converter 1.0.1
Database Search 1.4
DTS decoder 0.1.7
FLAC Decoder 1.1.0
WMA Decoder 1.1
Masstagger 1.6
Pretty Popup 1.2.3
RAR reader 1.1
ZIP/GZIP reader 1.0
LHA unpacker 1.0
Try Quick Search Toolbar 2.8l if it works
http://www.hydrogenaudio.org/forums/index....showtopic=44012 (http://www.hydrogenaudio.org/forums/index.php?showtopic=44012)
my os is windows XP SP2..
OH~~Yaaa~
I try the 0.3.1.1b4 lyrics show ,
all the problem solve....
work fine
thanks T.P Wang
ok, thx for your fast answer, I give it a try !
Since I downloaded the new versions, foobar takes up to 97 % of cpu usage while playing a song, even if I haven't "called" the lyrics panel in front. When the song is stopped it takes normal cpu usage.
I tried removing the lyrics component, and everything worked fine after that. It worked fine a couple of versions back too for me.
I downloaded the version of quicksearch you linked, and now it seems to be working!!! Thanks
edit: or maybe not.. I'm not entirely sure it is this component that messes it up though..
Thanks a million for enhancing this plugin! Had to stop using it, due to incompatibility with ms_live, but that's not a problem any more!
YAS ! you have just completed my foobar ! thank you a flippin lot !
THANK YOU !
any response to this ?
id greatly appreciate this feature.
thx in advance!
THANK YOU !
thx in advance!
Sorry I forgot to response your request.
However this feature is working in progress.
sweet!
thanks alot mate!
When i update 0.3.1.1b5 , crash again
why~~~~~~~~
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 013466B0h
Call path:
entry=>app_mainloop
Code bytes (013466B0h):
01346670h: 75 EE 66 83 3A 3B 75 21 EB 06 8D 9B 00 00 00 00
01346680h: 83 C2 02 66 83 3A 3B 74 F7 66 83 3A 20 75 0A 90
01346690h: 83 C2 02 66 83 3A 20 74 F7 66 83 3A 00 75 A7 32
013466A0h: C0 C3 B0 01 C3 CC CC CC CC CC CC CC CC CC CC CC
013466B0h: F2 0F 10 05 08 67 36 01 F2 0F 10 0D D8 66 36 01
013466C0h: 33 C0 A8 01 74 04 F2 0F 59 C8 D1 E8 74 0E 66 0F
013466D0h: 28 D0 F2 0F 59 D0 66 0F 28 C2 EB E6 66 0F 28 C1
013466E0h: F2 0F 59 44 24 04 F2 0F 58 05 E8 66 36 01 F2 0F
Stack (0012F670h):
0012F650h: 019DE1E0 7D5993C0 77F443DD 7D5993C0
0012F660h: 00000004 00000000 019DD6EC 00000000
0012F670h: 0132519A AAA21AE0 402F7F67 9A9B446C
0012F680h: 00000000 00000113 014155DC 0012F67C
0012F690h: 01D96480 00000000 DE19256B 400AB851
0012F6A0h: FFFFFFFF 7C930732 7C9306AB 7C9306EB
0012F6B0h: 0000000C 013750C0 014143B8 0000003E
0012F6C0h: 04F96404 BFD9999A 00000001 00000003
0012F6D0h: 009F0718 009F0000 01D3DFF8 0012F6CC
0012F6E0h: 7C937BF5 0012F910 7C92EE18 7C930738
0012F6F0h: 01416FE0 7C930732 FE72EB8C 3FF80015
0012F700h: 0000000C 00000000 7C9305D4 0000000F
0012F710h: 01D96480 01641910 01D96488 0000000C
0012F720h: 00000000 00000000 0012F79C 01416F10
0012F730h: 01416F18 01416F18 77D18724 001841A0
0012F740h: 0000000F 00000000 00000000 01641910
0012F750h: DCBAABCD 00000000 0012F79C 01641910
0012F760h: 0012F7C8 77D18BC9 7FFDE000 0012F7C8
0012F770h: 77D1884A 0012F788 001841C0 0000000F
0012F780h: 01641910 00000000 00000008 00000001
Registers:
EAX: 00000001, EBX: 01416FE0, ECX: 0000001F, EDX: 01416F18
ESI: 0012F728, EDI: 014143B8, EBP: 0012F858, ESP: 0012F670
Crash location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Loaded modules:
foo_cwb_hooks loaded at 00C70000h - 00CBA000h
foo_dsp_std loaded at 00CE0000h - 00D21000h
foo_freedb2 loaded at 00D50000h - 00D90000h
foo_infobox loaded at 00DB0000h - 00DF0000h
foo_input_monkey loaded at 00E10000h - 00E59000h
foo_input_std loaded at 00E80000h - 00F93000h
foo_lyricsdb loaded at 00FC0000h - 00FEF000h
foo_masstag loaded at 01010000h - 0105F000h
foo_playcount loaded at 010B0000h - 010D8000h
foo_playcount_mod loaded at 010E0000h - 010F5000h
foo_rgscan loaded at 01120000h - 01168000h
foo_run loaded at 01190000h - 011BB000h
foo_uie_albumart loaded at 011E0000h - 0121C000h
foo_uie_albumlist loaded at 01250000h - 01293000h
foo_uie_explorer loaded at 012C0000h - 012FC000h
foo_uie_lyrics loaded at 01320000h - 0137F000h
foo_uie_peakmeter loaded at 01420000h - 01446000h
foo_uie_quicksearch loaded at 01470000h - 014B6000h
foo_uie_vis_egoh loaded at 014E0000h - 014FD000h
foo_uie_wmpvis loaded at 01510000h - 0154B000h
foo_ui_columns loaded at 01560000h - 01603000h
foo_ui_panels loaded at 01630000h - 01719000h
foo_ui_std loaded at 01740000h - 01797000h
foo_unpack loaded at 017C0000h - 017EE000h
Msimg32 loaded at 762F0000h - 762F5000h
RBHook loaded at 01A60000h - 01A6D000h
DSOUND loaded at 73E70000h - 73ECC000h
VERSION loaded at 77BD0000h - 77BD8000h
WINTRUST loaded at 76C00000h - 76C2E000h
IMAGEHLP loaded at 76C60000h - 76C88000h
wdmaud loaded at 72C90000h - 72C99000h
msacm32 loaded at 72C80000h - 72C88000h
MSACM32 loaded at 77BB0000h - 77BC5000h
midimap loaded at 77BA0000h - 77BA7000h
KsUser loaded at 73E40000h - 73E44000h
Mmm loaded at 03E30000h - 03E72000h
Secur32 loaded at 77FC0000h - 77FD1000h
RASAPI32 loaded at 76EB0000h - 76EEC000h
rasman loaded at 76E60000h - 76E72000h
NETAPI32 loaded at 69A00000h - 69A55000h
TAPI32 loaded at 76E80000h - 76EAF000h
rtutils loaded at 76E50000h - 76E5E000h
adialhk loaded at 048C0000h - 048D7000h
msv1_0 loaded at 77C40000h - 77C63000h
iphlpapi loaded at 76D30000h - 76D48000h
USERENV loaded at 759D0000h - 75A7E000h
rsaenh loaded at 0FFD0000h - 0FFF8000h
urlmon loaded at 75C60000h - 75D00000h
mswsock loaded at 719B0000h - 719EE000h
DNSAPI loaded at 04940000h - 04967000h
rasadhlp loaded at 76F90000h - 76F96000h
hnetcfg loaded at 605B0000h - 60605000h
wshtcpip loaded at 719F0000h - 719F8000h
Address: 0132519Ah, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 7C9306ABh, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C930738h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Address: 7C9305D4h, location: "ntdll", loaded at 7C920000h - 7C9B5000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 01641910h, location: "foo_ui_panels", loaded at 01630000h - 01719000h
Address: 77D18BC9h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D1884Ah, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetDC" (+00000193h)
Address: 004BE0ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004038A4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00437D1Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A6DFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A6ECh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6366h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 013350DDh, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 0135DFC8h, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 01334A47h, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 77D1B745h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetParent" (+00000026h)
Address: 77D1B775h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetParent" (+00000056h)
Address: 0135ED80h, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 0040BC9Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044604Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0132707Bh, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 01332370h, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 0112F8B0h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 004DEDF8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01360531h, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 77D188D0h, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 77D1D613h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 013323BCh, location: "foo_uie_lyrics", loaded at 01320000h - 0137F000h
Address: 77D1EBE3h, location: "USER32", loaded at 77D10000h - 77D9F000h
Address: 77D31B6Ch, location: "USER32", loaded at 77D10000h - 77D9F000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
foo_lyricsdb 0.0.7 beta 5 (foo_lyricsdb)
Album Art Panel 0.2.6 (foo_uie_albumart)
Play Count Mod 1.0.2 (foo_playcount_mod)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Tagger Panel Window 1.0.beta4 [Jun 7 2007 - 10:34:42] (foo_cwb_hooks)
cwbowron's title format hooks 1.2.5 [Jun 7 2007 - 10:34:42] (foo_cwb_hooks)
Peakmeter Panel 0.0.2 (foo_uie_peakmeter)
Lyric Show Panels 0.3.1.1b5 [Jun 27 2007 - 15:35:37] (foo_uie_lyrics)
WMP Visualizations 0.1.2 (Intel SSE) (foo_uie_wmpvis)
Explorer Tree 1.04.6b (foo_uie_explorer)
Album list panel 0.2.3 beta (foo_uie_albumlist)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00] (foo_ui_panels)
Playback Statistics 1.3.2 (foo_playcount)
Egoh Spectrum analyser (uie) 1.1.2 (foo_uie_vis_egoh)
Run services 0.3.2 (foo_run)
crash, too (0.3.1.1b4 is fine)
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 040073DCh
Call path:
entry=>app_mainloop
Code bytes (040073DCh):
0400739Ch: 00 00 39 5C 24 34 89 6C 24 30 73 04 8D 44 24 20
040073ACh: BE 09 00 00 00 66 89 28 39 74 24 34 73 10 8B 44
040073BCh: 24 30 50 56 8D 4C 24 24 51 E8 66 CC FE FF 39 5C
040073CCh: 24 34 8B 44 24 20 73 04 8D 44 24 20 66 0F EF C0
040073DCh: 66 0F D6 00 66 0F D6 40 08 66 89 68 10 39 5C 24
040073ECh: 34 8B 44 24 20 89 74 24 30 73 04 8D 44 24 20 66
040073FCh: 89 68 12 39 5C 24 34 8B 44 24 20 73 04 8D 44 24
0400740Ch: 20 B9 FA 00 00 00 C7 00 00 00 00 44 C7 40 04 00
Registers:
EAX: 04055BE8, EBX: 00000008, ECX: 0B1B23C2, EDX: 04050608
ESI: 00000009, EDI: 04033C40, EBP: 00000000, ESP: 00000008
Crash location: "foo_uie_lyrics", loaded at 03FE0000h - 0403F000h
Loaded modules:
SHLWAPI loaded at 77E70000h - 77F0D000h
SHELL32 loaded at 7D5A0000h - 7E5D8000h
wbsys loaded at 66500000h - 6650A000h
wbhelp loaded at 66600000h - 66617000h
wblind loaded at 66000000h - 6607B000h
UXTHEME loaded at 5AD70000h - 5ADA8000h
msimg32 loaded at 762D0000h - 762D5000h
foo_abx loaded at 00E60000h - 00E93000h
foo_albumlist loaded at 00EC0000h - 00F07000h
foo_bitcompare loaded at 00F30000h - 00F57000h
foo_cdda loaded at 00F80000h - 00FB5000h
foo_converter loaded at 00FE0000h - 01049000h
foo_cwb_hooks loaded at 01070000h - 010BD000h
foo_dsp_std loaded at 010E0000h - 01121000h
foo_freedb2 loaded at 01150000h - 01190000h
foo_gasazip loaded at 011B0000h - 01205000h
foo_input_monkey loaded at 01230000h - 0127A000h
foo_input_std loaded at 012A0000h - 013B3000h
foo_input_tta loaded at 013E0000h - 0140D000h
foo_lyricsdb loaded at 01430000h - 0145F000h
WININET loaded at 42E20000h - 42F59000h
Normaliz loaded at 01470000h - 01479000h
foo_masstag loaded at 016A0000h - 016EF000h
foo_masstag_addons loaded at 01710000h - 0172A000h
foo_playback_custom loaded at 01740000h - 01785000h
WINSPOOL loaded at 72F50000h - 72F76000h
foo_playlist_bind loaded at 017D0000h - 017F5000h
foo_playlist_manager loaded at 01810000h - 01854000h
foo_prettypop loaded at 01880000h - 018CD000h
mscoree loaded at 79000000h - 79045000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni loaded at 790C0000h - 79BA6000h
mscorjit loaded at 79060000h - 790B3000h
foo_rgscan loaded at 03E20000h - 03E68000h
foo_run loaded at 03E70000h - 03E9B000h
foo_sendtodevice loaded at 03EA0000h - 03EDA000h
foo_uie_albumart loaded at 03F00000h - 03F3C000h
foo_uie_albumlist loaded at 03F70000h - 03FB3000h
foo_uie_lyrics loaded at 03FE0000h - 0403F000h
foo_uie_lyrics_panel loaded at 04060000h - 040C9000h
foo_uie_peakmeter loaded at 040F0000h - 04116000h
foo_uie_playlists_dropdown loaded at 04140000h - 04179000h
foo_uie_quicksearch loaded at 041A0000h - 041E6000h
foo_uie_vis_egoh loaded at 04210000h - 0422D000h
foo_uie_wmpvis loaded at 04240000h - 0427B000h
foo_ui_columns loaded at 04290000h - 04333000h
foo_ui_panels loaded at 04360000h - 04449000h
foo_ui_std loaded at 04470000h - 044C7000h
foo_unpack loaded at 044F0000h - 0451E000h
foo_utils loaded at 04540000h - 04578000h
foo_verifier loaded at 045A0000h - 045D0000h
foo_version loaded at 045F0000h - 04616000h
dbghelp loaded at 58DE0000h - 58E81000h
foo_ui_minilyrics loaded at 04840000h - 04862000h
gasazip loaded at 05B30000h - 05C06000h
URLMON loaded at 05C10000h - 05D39000h
olepro32 loaded at 5E700000h - 5E717000h
Wship6 loaded at 580D0000h - 580D7000h
WS2_32 loaded at 719E0000h - 719F7000h
WS2HELP loaded at 719D0000h - 719D8000h
CLBCATQ loaded at 76F80000h - 76FFF000h
COMRes loaded at 77000000h - 770A7000h
ieframe loaded at 43100000h - 436CB000h
PSAPI loaded at 76BA0000h - 76BAB000h
Secur32 loaded at 05EB0000h - 05EC1000h
SXS loaded at 75DE0000h - 75E8F000h
appHelp loaded at 76D90000h - 76DB2000h
mswsock loaded at 71980000h - 719BF000h
hnetcfg loaded at 65CB0000h - 65D06000h
wshtcpip loaded at 719C0000h - 719C8000h
RASAPI32 loaded at 76E90000h - 76ECC000h
rasman loaded at 76E40000h - 76E52000h
NETAPI32 loaded at 605F0000h - 60644000h
TAPI32 loaded at 76E60000h - 76E8F000h
rtutils loaded at 76E30000h - 76E3E000h
USERENV loaded at 759B0000h - 75A60000h
msv1_0 loaded at 77F10000h - 77F33000h
iphlpapi loaded at 76D10000h - 76D29000h
MiniLyrics loaded at 06870000h - 069B1000h
sensapi loaded at 72220000h - 72225000h
rasadhlp loaded at 76F70000h - 76F76000h
DNSAPI loaded at 76ED0000h - 76EF7000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC56000h
dciman32 loaded at 73B10000h - 73B16000h
mshtml loaded at 437E0000h - 43CAF000h
msls31 loaded at 746C0000h - 746E9000h
MLANG loaded at 74CD0000h - 74D61000h
Ymkh10 loaded at 09300000h - 09313000h
winrnr loaded at 76F60000h - 76F68000h
WLDAP32 loaded at 76F10000h - 76F3C000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Playlist Manager 1.0.2 (foo_playlist_manager)
Pretty Popup 1.2.3 (foo_prettypop)
Playlist Bind 3.1 (foo_playlist_bind)
Playback Statistics Custom 1.0.1 (foo_playback_custom)
Masstagger Addons 0.3.3 (Intel SSE) (foo_masstag_addons)
Components versions viewer 0.3 (foo_version)
Gasazip Lyric Plugin 3.0 (foo_gasazip)
Send to Device 1.1.0 (beta) [Dec 20 2006 - 16:40:06] (foo_sendtodevice)
TTA Audio Decoder (unofficial) 2.4.2 (foo_input_tta)
Lyrics panel 0.35 (foo_uie_lyrics_panel)
Binary Comparator 1.1 (foo_bitcompare)
File Integrity Verifier 1.0.1 (foo_verifier)
- Optimized version for SSE2 ( build against /arch:SSE2)
why~~~~~~~~
Code C000001Dh is EXCEPTION_ILLEGAL_INSTRUCTION. Probably your CPU does not support SSE2. That's not your fault though..
Can you make the lyric box scrollable with the arrow keys? I'm aware that the lyrics are scrollable via a mouse scroll wheel, but not all of us use mice! I am a Lenovo laptop user who uses the trackpoint (http://www-06.ibm.com/jp/pc/think/thinkvantagedesign/i/trackpoint_01.jpg) exclusively.
why~~~~~~~~
but i download the normal version ,not the sse2 version ><"
why~~~~~~~~
It's my fault. I'll reupload the normal version soon.
EDIT I've Uploaded, try and see if it works.
Can you make the lyric box scrollable with the arrow keys? I'm aware that the lyrics are scrollable via a mouse scroll wheel, but not all of us use mice! I am a Lenovo laptop user who uses the trackpoint exclusively.
Thanks, I'll try to solve this problem
....yeah~~
it works...
but when i try scrolling the lyrics, i click the panel ..
foobar will disappear(just like crash)..
but not any crash logs.
....yeah~~
it works...
I don't know how it'll happen, sorry.
However I'll release a new version with titleformatting function $lpsetscroll(value) and $lpsetpos({top, middle, bottom}) and some others for scrolling
I'll add this feature: scroll by mouse dragging. However, now I don't have much time because I'm reviewing my courses for the terminal examination
When i click on the lyrics show panel i too get that wierd shutdown...dunno what causes it, but i use it with columns ui
....yeah~~
it works...
I changed some code(without Clicking the panel), may solve this problem.
here: http://www.hydrogenaudio.org/forums/index....t=0#entry499817 (http://www.hydrogenaudio.org/forums/index.php?act=ST&f=42&t=55691&st=0#entry499817)
Hi, I've uploaded DEV version of Lyrics show panel
http://fb2k.theophile.googlepages.com/foo_uie_lyrics_DEV.7z (http://fb2k.theophile.googlepages.com/foo_uie_lyrics_DEV.7z)
with this build, you can scroll lyrics with arrow keys.
I have found a minor issue with linebreaking: Sometimes the last word on a line is partially hidden because it does not break to a new line...
I really appreciate your hard work with this, but it is rather inferior to "Lyric Panel". Especially the newer version that can't really be found anywhere. Here is a link to it if anyone is interested:
Lyrics Panel (http://savefile.com/files/726954)
A few things this can do that Lyric Show can't:
- has a timestamp maker built in
- more flexible with colors (6 instead of 4)
- decrease font size if the lyric line is to long (prevents word wrapping)
- has gradual (per line I think... can be user defined), and auto scroll
- line spacing
- can backup settings
- looking for lyrics is a lot more simple
- right click on the panel, and if you have lyricDB installed, you can search it (technically the playlist right click menu is just added to the panel right click menu)
- can execute commands when no lyrics are found/or when they are found
- more lyrics align options (left, center-left, center, center-right, right)
And more that I haven't mentioned, or just don't use myself. Would it be possible to make this component have a transparent background also? Thats the only thing missing I think... everything else is really great .
Thanks, but I can't get it to work!
I've tried a bunch of combinations in preferences, but with no results. I've tried using both Up/Down and Left/Right, but with no success. What do I have to do to scroll?
Also, the lyric text has ClearType disabled. How do I enable it?
I'm using Columns UI and the Lyrics Panel is in a "Tabbed panel stack mod".
wow this new database is just right !
it finds lyrics for almost every song now !
thank you alot for this !
a new small request tho:
could you change the panel so that if it only found .txt-lyrics for a song so far that he will look for .lrc-files everytime and preferably download them?
and if you then also include the autoscroll for txt lyrics the panel will be perfect!
youre doin a great job man! best regards!
Thanks, I'll fix this in next version.
- line spacing
Thank you for your advice.
I'll add some of them in the future.
If I had the source, I would add "transparent background"
So It seems that I should add some keybrd shortcuts mapping, the panel won't handle the key events well if it doesn't have focus, I'll try to fix that in the next version.
ClearType setting is depend on the configuration in your Display properties" -> "Appearance" -> "Effecrt".
I'll consider to add an opnion in the panel.
thank you!
But I'm now busying with the final exam, so it will take me to have these done.
I have ClearType enabled. I tried changing the font in the lyrics panel, and much to my surprise, ClearType is enabled in every font except for the one I prefer, Calibri. Why would that be? I have Calibri as my default sans serif font for everything, including FB2K and it works fine with ClearType. Bizarre.
As for the scrolling. I managed to get it to scroll when it was it's own panel, but not when it was a tab in a foo_uie_tabs tab aka "Tabbed panel stack mod". Would you please make it so it's scrollable in a foo_uie_tabs tab?
Or maybe I'm not giving it focus. I've tried clicking and double clicking on it? Is there anything else I should try?
PS: Here's a screenshot to give you a visualization of my problem:
(http://img243.imageshack.us/img243/8899/fb2klyricsxo1.th.png) (http://img243.imageshack.us/my.php?image=fb2klyricsxo1.png)
Now I add a new feature, so you can scroll nontimestamped lyrics with drag.
It seems that gdiplus didn't accept ClearType setting with DrawString(), so I changed it into AA.
check the new DEV version, I've uploaded the new one.
Perhaps my previous post was a bit unclear.
I've tried the latest version of the lyrics panel (0.3.1.b6), but had a few problems with it:
-ClearType/AA doesn't work with my preferred font, Calibri. It's works with every other font I've tried, but not Calibri.
-The lyrics panel is scrollable with the arrow keys except when it's tabbed using foo_uie_tabs (v. 0.2.5).
This screenshot: (http://img243.imageshack.us/img243/8899/fb2klyricsxo1.th.png) (http://img243.imageshack.us/my.php?image=fb2klyricsxo1.png) shows the problems quite clearly. Is it possible to correct them?
Thanks, and sorry for the unclear previous post.
Now I have no idea to scroll with arrow keys using foo_uie_tabs
Have you tried the newest DEV version?
I'm using the newest DEV version of your lyrics panel and the latest version of foo_uie_tabs. I can't get the panel to scroll even when it is by itself outside of foo_uie_tabs. It also won't allow ClearType on a very common font called
Calibri.
Hello,
I have 2 (or maybe 3) problems with this plugin.
1) Sometimes (not each time), when theres no lyrics available for a song, the plugin displays the lyrics of another song of the same artist. My LRC files are all in one folder, and named in the format %artist% - %title%. In the settings, thz only scheme for filenames is : $if(%artist%,%artist%' - ')$if2(%title%,%_filename%). So I don't understand why it act like this...
2) When I activate transparent Background, first the background is not transparent (it keep the color it has when trasparency is off, black in my case), second (but it's probably the same thing) the panel is not refreshed, so the line stay displyed at there first position when srolling (I don't know if I explain well, see screenshot), or when a window have been over the panel, the image remains.
(http://img412.imageshack.us/img412/3207/capturercy3.th.jpg) (http://img412.imageshack.us/my.php?image=capturercy3.jpg)
(the sreenshot displays the 2 things, lyrics from 1979 when Siva is played, and panel not refreshed)
Is there something I've forgotten to do?
I'm using the newest DEV version of your lyrics panel and the latest version of foo_uie_tabs. I can't get the panel to scroll even when it is by itself outside of foo_uie_tabs. It also won't allow ClearType on a very common font called Calibri.
1. Now I've no idea to get arrow keys scrolled in foo_uie_tabs, however, these a alternate way to scroll: Hold left mouse button and move the mouse up and down. I'm now looking into the foo_uie_tabs' source and maybe I can solve the problem.
2. It seems that I should do some more work to enable ClearType on these new fonts.
Hello,
1) It seem that your "Match error level" is too high.
2) Can you post the code where you place the panel?
1) Oh, yes, my mistake, I hadn't seen this slider
2)The code is like that :
$ifequal($getpvar(display.mode),3,
$panel(TIM-Lyrics,Track Display,0,$eval($get(offset-top)+$get(playlist-lgy)+2),$eval(%_width%-$get(playlist-lgx)),$eval(%_height%-$get(offset-top)-$get(offset-bot)-$get(lgy-botswapper)-$get(playlist-lgy)-2),)
$panel(Lyrics,Lyric Show,$eval(0+15+17),$eval($get(offset-top)+$get(playlist-lgy)+84+25+1-80-{$getpvar(fulls)*2}),$eval(%_width%-$get(playlist-lgx)-30-29-5),$eval(%_height%-$get(offset-top)-$get(offset-bot)-$get(lgy-botswapper)-$get(playlist-lgy)-87-35-1+81+{$getpvar(fulls)*2}),)
TIM-Lyrics contains the code to draw the frame, but it seems that's this line that makes problems (all works good when I comment it)
It's fixed in the latest DEV version
Now there's no problem with fading effect with latest DEV version
Add you can see if you can set focus to lyrcs show panel with double click.
Alternate way to scroll lyrics you can see my previous post.
It's not recommended to use one panel to overlay another panel.
PS: you can use "codebox" instead of "code"
for a few days now the panel doesnt seem to find anything anymore. and when i manually use the online search function it doesnt even say "nothing found" anymore. ive tried both the regular and the dev version.
has anyone else got this problem too ?
ps: i just saw that you have included the txt-scroll in the dev version ! works really well. but could you disable the manual scrolling then ? thank you already !
and btw: my lyrics db search has "network problems" too so maybe thats why my lyrics panel doesnt find anything anymore.
another edit: i take back that id like the manual scroll disabled for txt-lyrics. i really like that now cause you can correct them if they are ahead or behind the song.
so good job ! i only hope its goona find some lyrics again soon
First, i just love that new version, everything works perfectly. The new server for lyrics is great, i find almost everything.
I have a feature request : the possibility to have more than one instance of the panel. I know it s quite a lot of work but it would be awesome. I would allow me to create a popup for lyrics on my second display(video projector) with bigger font for easy reading.
Is there something that would display the current line on the bottom right edge (or somewhere else) of the screen to make a karaoke (and perhaps based on PrettyPopup (http://www.maroonspoon.com/foo_prettypop/)) ?
Also, I would like to know more about embedded lyrics : I understood that it will read first tag, then directory, etc.
What happens when no local datas are found? Where are they stored? Do not tell me it's reloaded each time, I would not believe you! Is there a way to auto embed them in file? And finally, is there a way to view them before downloading to file?
does anyone else experience the problem with this panel that it doesnt find anything and never stops searching ?
i think its connected o lyricsDB since that one is also having "some network issues" for a few days.
please let me know if you also have it or if the problem is client-sided.
also please try and help me figure out how to solve this. my firewall is not blocking foobar. ive checked this and i can also still use DBtagging.
maybe both plug ins are using the same ports or something?
thanks in advance
henning
[snip]
thanks in advance
henning
I've had this problem off and on since installing the component.
Thank you, your idea is really great, I'll set about to implement it as soon as I got back to school.(But I can't make any schedule for that )
1. Now this feature is not implemented, I'll add it later, thanks.
2. When no local datas are found(tag or association or dir), Lyrics show panel will perform a Internet search(in a new thread, only if "Internet -> Download automatically" is checked), and then prefered download .lrc files, if there's no .lrc file, choose one .txt file to download.
3. they are stored depends on your "Internet -> Save scheme" setting. default is "embed to file", but there's a problem when writing tags: It's OK when you've download 20 items (the number of lyrics in cache is set to 20), it will write the last 20 track's lyrics to there tags. However, when fb2k is shutting down, it always failed to write tags. So on a later release, I'll fix it.
If embed failes(such as the filter which matches "Setting -> skip w/r tags by filetypes", mslive:// or unpack:// protocol), Lyrics show panel will perform the action which you've set in "Internet -> if embed failes"
As of the "embed" is not stable, I recommend that use "Save lyrics to dictory", it's fast and stable.
4. Now you can't view lyrics before downloading, but I'll implement soon.
thanks.
thanks in advance
henning
Have you configure proxy setting of Internet Explorer before?
In defaults, lyricsDB use the proxy setting from Internet Explorer, Lyrics show panel always uses IE's proxy setting.
[snip]
thanks in advance
henning
It sounds like that server was busy or temporary down
haha im so stupid!
i set my IE to "work offline" some days ago....
now its working again ! thank you for the hint^^
thanks.
1./4. thank you for thinking about it
And thanks for the panel
Oh! Another Idea : that would be cool to change the display (and not only the color and global font) of the different line : the highlighted line could be in
big, while other could be in
small. Would be funner with a size gradient on the line, so that it looks like this :
BEYOND THE REALMS OF DEATH (Judas Priest, Stained class) :
in his mind and slammed the door
No matter how they triedThey couldn't understandThey washed and dressed himFed him by handCH: Yeah! I've left the world behindI'm safe here in my mind
Which lyrics database is your version using now? Cuz I want to contribute there. Thanks.
Edit: ahh, I see in source, that it is secret. I just know, that it maybe is this: u15191554.onlinehome-server.com on port 1212.
btw. I found that other lyric displaying (and editing) plugins for other audio programs have submission feature and your doesn't have.
Great job! Thank you for the hard work.
I would love to see a timestamp editor like Make_Lyric was for 0.8x.
(and I also give a +1 for the multiple instances!)
Hi guys, I would like to know how can I actually enable the plugin, I can see it on the Options, but can't see the panel or window.
Thanks for your help.
haha im so stupid!
My pleasure.
thanks.
Oh! Another Idea : that would be cool to change the display (and not only the color and global font) of the different line : the highlighted line could be in big, while other could be in small. Would be funner with a size gradient on the line, so that it looks like this :
Fed him by hand
It's cool, but I won't add it in the following 1 or 2 months due to the lack of time, sorry,
the lyrics database is viewlyrics.com
I hide it just because bluenet(orig developer) hide it.
Yes this feature will be
implemented in 1 month, I think.Hi guys, I would like to know how can I actually enable the plugin, I can see it on the Options, but can't see the panel or window.
You need insert the panel in columnsUI or panelsUI
Do you think it is good lyrics site? Many links pointing to the site itself aren't working. There are no submit lyrics function. However, I have to admit that when your plugin was using previous lyrics database I wasn't able to find timestamped lyrics for some of my favourite songs. After change, 99% of my songs have timestamped lyrics. I'm just wondering how those lyrics got there, when there's no upload page.
Has there been any progress correcting the following problems?
I encounter this problems in the latest version (0.3.1.1b6).
Here's a visualization of my problem: (http://img523.imageshack.us/img523/7237/fb2klyricsbm1.th.png) (http://img523.imageshack.us/my.php?image=fb2klyricsbm1.png)
Is there a guide to do this? I think I'm the only one who doesn't know how this plugin starts to work.
I just found few timestamped lrc db before, do you have any suggestion?
Previous db is minilyrics.com, has a bigger db in CJK, and the server is located in china I think.
I just knew that minilyrics can upload lyrics to these db.
Maybe I should make a standalone program or embe the function into the panel for uploading?
EDIT: I may prefer adding some features on scripting to provide more db than write the codes
staticly.Has there been any progress correcting the following problems?
In latest DEV version:
ClearType now is applied without fadint effect.
And now I can't figure out why the arrow keys can't work with foo_uie_tabs, so please try use trackpoint drag nontimestamped lyrics up and down for alternative.
Columns UI:
first see here please:
http://eolindel.free.fr/foobar0.9/UIcolumns.php (http://eolindel.free.fr/foobar0.9/UIcolumns.php)
in layout tab, right click on a splitter->insert panel->panels->Lyirc Show
PanelsUI:
$panel
(Name,Lyric Show,
x,y,width,height,)
I give up!
I am using the latest DEV version, but ClearType still doesn't work with the font Calibri. Trackpoint drag also doesn't work. I guess it just wasn't meant to be.
Thanks for all your help.
I give up!
I've just tried foo_uie_tabs. Here's some screenshots (I'm using 0.3.1.1 latest DEV version, now the DEV version is replaced by 0.3.1.1 b7)
ClearType (Calibri,
without fading effect)
(http://img187.imageshack.us/img187/5606/tab1lg1.png) (http://imageshack.us)
no ClearType (Calibri,
with fading effect, GDI+ DrawString seems not support cleartype on Vista fonts.)
(http://img187.imageshack.us/img187/78/tab2ff5.png) (http://imageshack.us)
So, you first should turn down the fading effect.
I also tested the drag feature, works.
if you want to use arrow keys, you can double click the lyrics show panel(set focus)
regards.
THANK YOU SO MUCH!!!
My foobar is now complete! I'M SO HAPPY!!!
The mouse drag works fine, but the arrow scroll doesn't. ClearType now works. Oh well! The mouse drag is fine for me.
THANKS AGAIN!!!
T.P. thanks again for a great update!
I am still having my old problem with finding the lyrics though: If %artist% is "Police, The" or "Apple, Fiona" it will not find the lyrics.
I try to solve this by fixing the Lyric file name for artist-title1 and artist-title2, but obviously the lyrics database search is not being done with these fixed names. Can you please provide us with a way to fix our artist and title names, instead of just sending %artist% and %title% to the lyrics database?
I also organize my music this way and encounter the same problem. I add all the music by the artist in question to the playlist then select it all, right click, properties, change the name to "Fiona Apple" for example, then get the lyrics, then change it back. It's kind of a hassle, but it works.
I'll add an option after I finish multi instances support.
thanks.
I don't understand why autoscroll fails with this :
[al:Angel of Retribution]
[ar:Judas Priest]
[ti:Angel]
[by:DAzed]
[00:00.00]Angel
[15:00.00]Judas Priest
[25:00.00][48:00.00][1:10:00.00][1:40:00.00][2:08:00.00][2:36:00.00][4:15:00.00]
[28:00.00][1:49:00.00]Angel,
[33:00.00][3:38:00.00][3:50:00.00][4:01:00.00]Put sad wings around me now
[38:00.00]Protect me from this world of sin
[42:00.00][3:42:00.00][4:05:00.00]So that we can rise again
[51:00.00]Oh angel,
[56:00.00]We can find our way somehow
[1:01:00.00]Escaping from the world we're in
[1:05:00.00]To a place where we began
[1:13:00.00]And I know we'll find
[1:19:00.00]A better place and piece of mind
[1:24:00.00]Just tell me that it's all you want
[1:29:00.00]For you and me
[1:34:00.00]Angel won't you set me free
[1:53:00.00]Remember how we chased the sun
[1:58:00.00]Then reaching for the stars at night
[2:03:00.00]As our lives had just begun
[2:10:00.00]When I close my eyes
[2:15:00.00]I hear your velvet wings and cry
[2:21:00.00]I'm waiting here with open arms
[2:27:00.00]Oh can't you see
[2:31:00.00]Angel shine your light on me
[2:59:00.00]Angel we'll meet once more I'll pray
[3:04:00.00]When all my sins are washed away
[3:10:00.00]Hold me inside your wings and stay
[3:20:00.00][3:31:00.00][3:54:00.00]Angel take me far away
[3:27:00.00]Put your sad wings around me now
I thougt first it was a bug, but this one works :
[ti:Angel]
[00:29.68]ANGEL - PUT SAD WINGS AROUND ME NOW
[00:38.99]PROTECT ME FROM THIS WORLD OF SIN
[00:43.13][03:43.26]SO THAT WE CAN RISE AGAIN
[00:51.57]OH ANGEL - WE CAN FIND OUR WAY SOMEHOW
[01:01.73]ESCAPING FROM THE WORLD WE’RE IN
[01:05.77]TO A PLACE WHERE WE BEGAN
[01:14.31]AND I KNOW WE’LL FIND
[01:18.76]A BETTER PLACE AND PEACE OF MIND
[01:24.72]JUST TELL ME THAT IT’S ALL YOU WANT - FOR YOU AND ME
[01:34.79]ANGEL WON’T YOU SET ME FREE
[01:49.34]ANGEL REMEMBER HOW WE’D CHASE THE SUN
[01:58.54]THEN REACHING FOR THE STARS AT NIGHT
[02:02.53]AS OUR LIVES HAD JUST BEGUN
[02:11.28]WHEN I CLOSE MY EYES I HEAR YOUR VELVET WINGS AND CRY
[02:21.49]I’M WAITING HERE WITH OPEN ARMS – OH CAN’T YOU SEE
[02:32.72]ANGEL SHINE YOUR LIGHT ON ME
[03:00.29]OH ANGEL WILL WE MEET ONCE MORE – I’LL PRAY
[03:05.64]WHEN ALL MY SINS ARE WASHED AWAY
[03:11.11]HOLD ME INSIDE YOUR WINGS AND STAY
[03:21.41]OH! ANGEL TAKE ME AWAY
[03:28.44][03:39.72]PUT SAD WINGS AROUND ME NOW
[03:32.88]ANGEL TAKE ME FAR AWAY
Isn't the format being standardized?
[ar:Judas Priest]
[ti:Angel]
[by:DAzed]
[00:00.00]Angel
[51:00.00]Oh angel,
[ti:Angel]
[01:01.73]ESCAPING FROM THE WORLD WE'RE IN
[01:14.31]AND I KNOW WE'LL FIND
[01:24.72]JUST TELL ME THAT IT'S ALL YOU WANT - FOR YOU AND ME
[01:34.79]ANGEL WON'T YOU SET ME FREE
[01:49.34]ANGEL REMEMBER HOW WE'D CHASE THE SUN
[02:21.49]I'M WAITING HERE WITH OPEN ARMS – OH CAN'T YOU SEE
[03:00.29]OH ANGEL WILL WE MEET ONCE MORE – I'LL PRAY
Lyrics Show Panel use Simple LRC format (http://en.wikipedia.org/wiki/LRC_%28file_format%29)
The Line Time Tags are in the format
[mm:ss.xx] where
mm is minutes,
ss is seconds and
xx is hundredths of a second. (from wikipedia)
Baldurien: just remove for example in [1:01:00.00] those two zeros after : ... result [1:01.00]
Cool mode! Bravo
Will be great to be able to swich between lyrics providers/servers.
Okay
(does it support the word by word lirics format? )
Baldurien: No, and I think T.P Wang isn't going to add support for it
Thanks for the great component!!!
I really like it!
cashed again
Maybe I use the latest foo_ui_column version
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00F44958h
Access violation, operation: read, address: 01275000h
Call path:
entry
Code bytes (00F44958h):
00F44918h: F7 8B 44 24 10 8B 4C 24 24 03 C8 3B D9 73 37 8B
00F44928h: C3 8D 57 1C 8D 70 02 90 66 8B 08 83 C0 02 66 85
00F44938h: C9 75 F5 2B C6 D1 F8 50 53 8B F2 E8 28 E8 00 00
00F44948h: 8B 7F 30 66 83 3C 7B 00 8D 1C 7B 75 09 83 C3 02
00F44958h: 66 83 3B 00 74 F7 8B 7C 24 20 8D 44 24 18 E8 35
00F44968h: D3 00 00 C6 44 24 38 00 8B 44 24 1C 33 F6 39 30
00F44978h: 75 58 50 E8 9D 7F 02 00 8B 7C 24 18 83 C4 04 83
00F44988h: 7F 34 08 72 0C 8B 57 20 52 E8 87 7F 02 00 83 C4
Stack (0012EF1Ch):
0012EEFCh: 0006ABF4 7C9C94F0 77F643DD 7C9C94F0
0012EF0Ch: 00000004 00000000 0006A100 00000000
0012EF1Ch: 8C8F2D90 0012F024 0012F048 294A41AA
0012EF2Ch: 00000202 01273E68 01273E68 01273F48
0012EF3Ch: 00F99324 01274DF8 00000202 0012F024
0012EF4Ch: 0012EFAC 00F814E0 00000001 0012EFB8
0012EF5Ch: 00F61075 0012EF84 00000206 0012F024
0012EF6Ch: 8C8F2D08 0012F0E8 00A265B8 000009F0
0012EF7Ch: 0012F048 0012F024 00F891EC 0012F048
0012EF8Ch: 00000000 00000206 C01D9769 490F6830
0012EF9Ch: 294A41AA 84A9FC32 8C8F2D08 0012EF6C
0012EFACh: 0012F080 00F80910 00000000 0012F08C
0012EFBCh: 00F6B50D 0040D1ED 0012F048 0012F024
0012EFCCh: 0012F114 00000002 00000197 0043D4CA
0012EFDCh: 00A26870 0012F094 00407E27 7C90D592
0012EFECh: 7C809B8B 000000A4 0012F094 004501E2
0012EFFCh: 004501EE 0012F114 00000001 00000197
0012F00Ch: 004C5C14 00000010 0043CFDE 20DBBD70
0012F01Ch: 41EF498B 075142B4 004BE958 00000000
0012F02Ch: 000000F8 00000000 00000000 00000000
Registers:
EAX: 01273E84, EBX: 01275000, ECX: 00000000, EDX: 00000002
ESI: 01273E84, EDI: 00000049, EBP: 0012EF58, ESP: 0012EF1C
Crash location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7E37F000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 763B0000h - 76405000h
IMM32 loaded at 76390000h - 763AD000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 6FB80000h - 6FBFD000h
prio loaded at 003F0000h - 003F5000h
uxtheme loaded at 5AD70000h - 5ADA8000h
RKLauncher loaded at 00A70000h - 00A7F000h
MSCTF loaded at 74720000h - 7476C000h
YzShadow loaded at 00B10000h - 00B1E000h
DM2 loaded at 00B30000h - 00B36000h
msctfime loaded at 755C0000h - 755EE000h
foo_converter loaded at 00B60000h - 00BC9000h
foo_cwb_hooks loaded at 00BF0000h - 00C3D000h
foo_dockable_panels loaded at 00C60000h - 00C93000h
foo_infobox loaded at 00CC0000h - 00D00000h
foo_input_monkey loaded at 00D20000h - 00D6A000h
foo_input_std loaded at 00D90000h - 00EA3000h
foo_masstag loaded at 00ED0000h - 00F1F000h
foo_uie_lyrics loaded at 00F40000h - 00FA4000h
WININET loaded at 771B0000h - 7727E000h
Normaliz loaded at 00FC0000h - 00FC9000h
iertutil loaded at 6E850000h - 6E895000h
gdiplus loaded at 4EC50000h - 4EDF3000h
WINMM loaded at 76B40000h - 76B6D000h
foo_uie_playlists_dropdown loaded at 01280000h - 012B9000h
foo_uie_single_column_playlist loaded at 012E0000h - 0132C000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_uie_trackinfo_mod loaded at 01350000h - 013A7000h
foo_ui_columns loaded at 013C0000h - 01466000h
foo_utils loaded at 01490000h - 014C8000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 00F814E0h, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00F61075h, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00F891ECh, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00F80910h, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00F6B50Dh, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 0040D1EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90D592h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtClose" (+0000000Ch)
Address: 7C809B8Bh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "CloseHandle" (+00000044h)
Address: 004501E2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004501EEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C5C14h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043CFDEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE958h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE960h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AC639h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00483A80h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00F40000h, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00F97CECh, location: "foo_uie_lyrics", loaded at 00F40000h - 00FA4000h
Address: 00475D12h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C62D4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DE484h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A65D8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040AF4Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC40Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7CE0A9A2h, location: "SHELL32", loaded at 7C9C0000h - 7E37F000h
Address: 7D00966Eh, location: "SHELL32", loaded at 7C9C0000h - 7E37F000h
Address: 7CDD0FC2h, location: "SHELL32", loaded at 7C9C0000h - 7E37F000h
Address: 77260F7Eh, location: "WININET", loaded at 771B0000h - 7727E000h
Address: 4ECCC473h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 773F01E3h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00004343h)
Address: 7D961B1Eh, location: "SHELL32", loaded at 7C9C0000h - 7E37F000h
Address: 7CC27D5Eh, location: "SHELL32", loaded at 7C9C0000h - 7E37F000h
Address: 004DE464h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE6C4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E1B54h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0140AC9Dh, location: "foo_ui_columns", loaded at 013C0000h - 01466000h
Address: 004AC6D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430793h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004E4198h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 004E3E68h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 10000000h, location: "shared", loaded at 10000000h - 10029000h
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049812Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
cashed again
Illegal operation:
Call path:
entry
Stack (0012EF1Ch):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Please Post your components info.
by "Preferences -> Components -> Copy"
I want to use this component to display a short comment about the artist on my track display when a track is played. I will probably just search google for a comment about each artist, and then copy it into a text document.
What text format does it use, and can I specify the directory where the document is returned from?
cashed again
Illegal operation:
Call path:
entry
Stack (0012EF1Ch):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Core (2007-04-21 03:36:34)
foobar2000 core 0.9.4.3
foo_converter.dll (2007-04-21 03:34:28)
Converter 1.0.1
foo_cwb_hooks.dll (2007-06-12 15:14:24)
cwbowron's title format hooks 1.2.5 [Jun 8 2007 - 08:49:42]
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]
foo_dockable_panels.dll (2007-03-28 09:19:02)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_infobox.dll (2006-10-09 21:17:12)
Special file info box 2.0.4
foo_input_monkey.dll (2007-04-13 18:39:54)
Monkey's Audio decoder 2.1.2
foo_input_std.dll (2007-04-21 03:34:22)
FLAC Decoder 1.1.0
Standard Input Array 1.0
WMA Decoder 1.1
foo_masstag.dll (2007-04-21 03:33:44)
Masstagger 1.6
foo_ui_columns.dll (2007-07-23 06:36:02)
Columns UI 0.2.0 beta 1
foo_uie_lyrics.dll (2007-03-12 21:32:45)
foo_uie_playlists_dropdown.dll (2007-02-08 22:26:16)
Playlists Dropdown 0.6 alpha 3
foo_uie_single_column_playlist.dll (2007-01-09 15:43:08)
Single Column Playlist Display 0.5.4 beta [Jan 9 2007 - 15:42:59]
foo_uie_trackinfo_mod.dll (2006-12-12 14:26:54)
Track info panel mod 0.8.0 beta [Dec 6 2006 - 14:21:24]
Playlist Tools 0.5.9
I learned how to use codebox
And I used orginal Lyrics show instead of Urs otherwise foobar would crash
Either plain-text file(.txt) or lrc formatted file(.lrc) is OK
There are some hints on how to configuration:
search path(always search %foobar_path%\lyrics\):[blockquote]Setting -> Lyric Search -> Search path
[/blockquote]
search name:[blockquote]Settig -> Lyric file name, Click "New":
[blockquote]Name: artist
Value: %artist% (or something other like %artist%)
[/blockquote][/blockquote]
cashed again
Illegal operation:
Call path:
entry
Stack (0012EF1Ch):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Converter 1.0.1
FLAC Decoder 1.1.0
WMA Decoder 1.1
Masstagger 1.6
It's strange.
Have tried clean & backup your current conf and see if it works?
[/blockquote]search name:
Thanks. So you are saying that the path has to always be %foobar_path%\lyrics\ ?
Can't I just store each comment (.txt file) in the artist directory? For example I have my music organised by artists then by albums then by track, and I want to have the comment file in the artist directory along with the album folders like so:
*Artist1
comment1.txt
-album1
-album2
-album3...
--track1
--track2....
*Artist2
comment2.txt
-album1
-album2
[etc....]
So that whenever I play an album or track from within that artist folder, it will show the corresponding comment (regardless of which particular album or track, as long as it's within that artist folder).
How can I do that?
Juast downloaded this...works fgreat BUT
Where can I find the fading effect? Is there a checkbox I've been not seeing for over 40 minutes?
It's strange.
I had cleaned and re-config it
Of course firest run with default config is ok
But when I config it for my personal use just like several days before, it crashed.
following Config whith original lyrics panel screenshot
(http://img209.imageshack.us/img209/4262/sshot1hq9.png)
*Artist1
comment1.txt
-album1
-album2
-album3...
--track1
--track2....
*Artist2
comment2.txt
-album1
-album2
[etc....]
How can I do that?
I mean that Lyric show panel always search %foobar_path%\lyrics, then search user defined path.
If you organize artist comments like that, you should add the path to the search folder(by titleformating scripts):
[blockquote]$replace($replace($replace(%path%,%filename_ext%,),\$directory(%path%),),$directory(%path%,2),)
[/blockquote]
Note: Lyric show panels can search more folders s
eparated by ";"(comma), And you should add some rule to search the commets file(dont check include subdir if you are not sure, it's recursive call so costs more memory/cpu). Juast downloaded this...works fgreat BUT
In Lyric Show Panels Setting, Display-> Display setting -> Enalbe Fading, just check/uncheck that.
It's strange.
Maybe some incompatiables with dockable panels and/or trackinfo_mod and/or single column playlist
I'll check it later.
Now it's ok now
amazing
I close the dockable panel first
And then close foobar
Cover the original lyrics panel with modified one
And then run foobar
All ok now
I like dockable panel
Maybe dockable panel must be updated too, I think.
(http://img209.imageshack.us/img209/6971/sshot1cz0.png)
Huh? I cannot find that option...
(http://xs217.xs.to/xs217/07304/huh.png)
Now it's ok now
amazing
And then run foobar
All ok now
Thanks for your reporting.
Get the latest version here, please, thanks:
Link (http://www.hydrogenaudio.org/forums/index.php?showtopic=55691)
I am having an issue with this component. I have timestamped lyrics embedded in the %lyrics% tag of my files, but when I play them, the lyrics don't scroll with the song playback. I have the Enable Scroll, and the Enable Scroll (no timestamp) options checked off too.
Timestamped lyrics don't scroll, and can't be scrolled with the mouse wheel.
NON timestamped lyrics CAN scroll and be scrolled with the wheel.
Am I doing something wrong?
Can you post one of your timestamped lyrics embedded in the LYRICS tag?
Here is an example of some timestamped lyrics that do not scroll for me:
[23:23.00]She was diagnosed on a Friday,
[27:37.00]The kids were on their way back home from school,
[29:43.00]Lying face down in the gutter,
[35:18.00]"Sorry ma'am, I really am. I had to break the news.
[37:09.00]I had to make the phone call to tell you that you're due,
[40:39.00]You know where, I'll tell you when,
[43:09.00]And I suggest you start living these next three weeks,
[45:55.00]The best way that you can."
[49:02.00][1:52:57.00]She’d roam the hallways half asleep,
[52:32.00][1:55:07.00][2:34:37.00]And as the footsteps fade away,
[58:20.00][2:39:19.00]Don't wait for me, you’ve got a lot to do, you’ve got a lot to be,
[1:30:47.00]Spent the day in bed.
[1:36:12.00]But when they turned their backs,
[1:37:07.00]The tears would flow.
[1:51:17.00]Every night for three long weeks,
[1:57:03.00][2:36:44.00]In my mind, I could swear, I could swear, I heard her say:
[2:04:54.00]And in the end maybe, I'll see you there.
[2:46:47.00]And in the end you know ill see you,
[2:48:26.00]There and in the end I’ll see you there.
When I reboot my computer
and then run foobar
it crash again, my god
[49:02.00][1:52:57.00]She'd roam the hallways half asleep,
[58:20.00][2:39:19.00]Don't wait for me, you've got a lot to do, you've got a lot to be,
[2:48:26.00]There and in the end I'll see you there.
It's
[!--sizeo:2--][span style=\"font-size:10pt;line-height:100%\"][!--/sizeo--]described [/size]here:
Link (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=55692&view=findpost&p=504732)When I reboot my computer
and then run foobar
, Now I've no idea about that, sorry.
It's described here: Link (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=55692&view=findpost&p=504732)
Ah, now I see what the problem is >.<! Would you beable to make it read the format I have if possible? Or I suppose an option to 'convert' the lyric stamps into the correct format? I have about 500-600 self stamped files all in this format and it would be a PAIN to change them all >.<!
The format I have is the format that foo_uie_lyrics_panel reads and thats what I have used for a long time. Your component seems to work smoothly now however, so I planned to convert, but this is holding me back .
Thanks for your reply, and answer to this issue by the way .
T.P Wang, thanks for the help, mac.
Now it's ok now
amazing
And then run foobar
All ok now
Works awesome now
I'll add an option to read the format and convert it in next release.
Now it works ok with no crash for tow days now
I don't know the reason
I just replace zlib1.dll file from the one in the zip pack of litestep
zlib1.dll (http://www.divshare.com/download/1393393-469)
At first, thanks for improving of such useful plugin
But I noticed, that tags in "Search path" isn't working. Lyrics is being searched in dir like "e:\music\texts\%artist%" but not in "e:\music\texts\trivium" for example. And I think, it would be better to include search path in filename presets with option "Number of subdirs to process" (see Lyrics show Panel).
Thanks for your hint.
Yes, it's a bug, I'll fix it in the next release.
Foobar crashed when I accidentally opened a lrc file encoded in unicode big edian - no idea what happened, it just hung there, the panel kept scrolling too (showing gibberish).
Hi T.P Wang,
with your really nice component, I have a small problem. If there is noch LYRICS-Tag found it automatically searches for the lyric in the internet and most of the time finds it. It however seems, that the lyric isn't saved. Neither into the tag, nor to the harddisk, if specified.
Could you please check this?
Thank you.
I've add an option like that and fix the titleformating problem in "Search path"
Try to get the latest DEV version HERE (http://www.mediafire.com/?6qjwnmxxzng)
Thanks, I've just add some code to convert BE to LE in the latest DEV version, since it's not tested enough, there may some other problems on reading Unicode BE lyric files. HERE (http://www.mediafire.com/?6qjwnmxxzng)
Hi T.P Wang,
It's because the fb2k shut down before writting LYRICS tag to files. It's fixed in the latest DEV version. HERE (http://www.mediafire.com/?6qjwnmxxzng)
EDIT: The problem still occurs, I may change some method to update files' tag
Thank you for the newest DEV version of your panel T.P Wang! It fixed my lyrics scroll problem because my timestamps were different . I am now using your component as my main lyrics display .
EDIT:
I spoke to soon lol
I am having a bit of trouble with the lyrics showing up in the incorrect order. It happens with a few of my songs, but I don't notice a pattern or anything. It's an MP3 file, correct header and everything, and the lyrics are timestammped in the file itself (under the %lyrics% tag).
The first few lines of my lyrics are:
[00:16:62]all you've been asking for has been placed in front of you.
[00:24:13]the headaches, the shaking, the boredom the boardroom brings.
[00:31:81]you're scratching at itching, brought by the spiders beneath your skin.
[00:39:64]the answer in question is over before it begins.
But the lyrics panel shows them as this:
The lyrics don't scroll for the first 1:30 or so of the song, and then when these lyrics repeat themselves, they do scroll. I can upload the single song if that would help debug this issue?
T.P Wang :In the last dev version, every time track changes the background goes back to white(no transparent background). I have to go to the settings and press ok to get it back to the correct color.
EDIT:
I spoke to soon lol
Thank you....
It's a CRITICAL bug which may corrupt lyrics files.
I've fixed that, try to get the latest DEV version, Thanks again.
And now I think it'll read the lyric panel format correctly.
Try to download the latest DEV version
Hi T.P Wang,
unfortunatelly the LYRICS-Tag still is not added in the newest dev-build.
bye
Hi T.P Wang,
bye
So, using metadb_io_v2 seems not work on initquit::on_quit()..............
I've changed to metadb_io so it works
HERE (http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=3567) is the newest dev-build
Regards.
Thanks for the last build TPWang, i dont have background color problems anymore
The link to the latest development build seems to be broken. Here the right one (http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=3567)
It does not work, because you are launching a background tag update
while the program is exiting; that implicitly aborts all background processes.
The latest DEV version broke the lyric panel format ([00:27:27]) that you added support for a little while ago. No more scrolling .
Any idea to provide a better Japanese or Chinese support???
I cannot find the lyrics of Japanese or Traditional Chinese named songs in Traditional Chinese windows directly.
It does not work, because you are launching a background tag update while the program is exiting; that implicitly aborts all background processes.
Thanks, foosion.
I'll find another way to update tags...
Hi T.P Wang,
bye
From the newest DEV build
[Aug 8 2007 - 18:28:24], I've add a menu item called "Update tags..." to update these tags manually for workaround.
I've uploaded the newest dev build that may solve your problem.
If you are still meeting this problem please post the whole lyrics, thanks
Download HERE (http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=3573)
Sorry, but I've no idea about a good online db providing Chinese and Japanese lyrics.
EDIT: Fix the link. Thanks Chaser.
http://www.hydrogenaudio.org/forums/index....ost&id=3573 (http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=3573)
This seems to be the correkt link to the dev-version.
Thanks for the bugfix, tags work fine now.
But option you added is not exactly what I asked. I meant the each "Lyric Filename" preset should include fields like that:
- Name - name of the preset
- Filename - template for the filename
- Directory - template for the directory name, option for subdirectory inclusion
- Maybe also Match Error Level
For example, you will be able to use this presets:
(Name: Filename (Error Level) : Dirname (Subdirs Inclusion))
1. IsAlbum: %track% - %title% (10%) : texts\%artist%\%date% - %album% (0)
2. IsSingle: %title% (30%) : texts\%artist% (0)
3. Other: %title% (50%) : texts (2)
So, search would be more effective.
Find a strange bug - number of subdirs to include can't be saved. It has been always replaced with "0".
NVM... what a waste of a of a first post. However, I REALLY enjoy this component!
is the source code available? if so please give me the link, thanks.
The link to the latest version doesn't seem to work.
The version I have is "Lyric Show Panels 0.3.1.1b8 DEV [Aug 8 2007 - 18:28:24]" and the timestamp scrolling is broken. The scrolling support that was added by my request doesn't seem to work anymore.
Can I scroll (with my mouse) to another part of the lyric?
The request feature will be applied and the bug will be fixed later.
I'll only update the source since I've finished some major stuff.
You can find v0.3.1.1b4 source
HERE (http://www.hydrogenaudio.org/forums/index.php?act=ST&f=42&t=55691&st=0)The link to the latest version doesn't seem to work.
Have you tried the latest
0.3.1.1b8 DEV [Aug 11 2007 - 16:49:37] ?And can you post the broken lyric text?
You can scrool with your mouse on non-timestamped lyrics only.
There are some problems with this panel. It can't auto adjust size following foobar2000's main window,especially at new song played.
I'd love to have the default network settings changed in this panel .. I screen where I can select network settings like proxy authorisation and all (like those in audioscrobbler plugin) will be great ..
http://www.51lrc.com/index.htm (http://www.51lrc.com/index.htm) <- tried that one?
Anyhow, to my question: would it be possible to save the files downloaded in UTF-8 instead of ANSI, my japanese lyrics ends up being garbled and i have to save them in utf-8 myself :\
-- im experiencing this as well. is this a confirmed bug? or is due to my settings?
The newest DEV build still lost support for the [xx:yy:zz] format of timestamps that you had made a few builds back. If this could be added back in, that would be awesome. Maybe an option to choose [xx:yy:zz] format and [xx:yy.zz] format (or whatever the current one is).
Thanks .
I'm not quite understand, could you provide me more info? (such as screenshots, OS version, fb2k version, columns ver, or/and PanelsUI ver)
Sounds reasonable, I'll add it.
51lrc.com is hard(in fact, very hard becasue of the damn Security Check Code) to read lyrics from...............
The files are stored as it's own encoding on the server.
The server contains various encoded files, such as UTF8, GB2312, UTF16, Thai or Latin-9
so it's hard to save all these files as UTF8, becasue if you want to save as UTF8, you must know the file's encoding first.
Thanks .
Oh, I've just found the problem, I'll fix it soon, please wait.
EDIT: you can try the new DEV build now.
I'm sorry but what is a non-timestamped lyric?
Means lyrics which are not in the LRC format.
See here: http://en.wikipedia.org/wiki/LRC_%28file_format%29 (http://en.wikipedia.org/wiki/LRC_%28file_format%29)
here's what happens. When you try to resize foobars windows, the lyrics panel, does not resize together with the window.
Before resize :(http://i15.tinypic.com/4tut2iu.png)
After resize :(http://i4.tinypic.com/6g8kojd.png)
More info on my systemCore (2007-08-20 23:04:00)
foobar2000 core 0.9.4.4
foo_abx.dll (2007-08-20 23:02:00)
ABX Comparator 1.3.1
foo_albumlist.dll (2007-08-20 23:02:00)
Album List 3.2.0
foo_amipwrapper.dll (2006-05-16 23:49:00)
AMIP Wrapper 0.90
foo_cdda.dll (2007-08-20 23:02:00)
CD Audio Decoder 2.1.1
foo_converter.dll (2007-08-20 23:02:00)
Converter 1.0.1
foo_dsp_std.dll (2007-01-20 07:36:00)
Standard DSP array 1.0
foo_dsp_winamp.dll (2006-07-30 13:01:00)
Winamp DSP Bridge 1.4.1
foo_freedb2.dll (2006-08-30 02:43:00)
freedb Tagger 0.5.2a
foo_input_std.dll (2007-08-20 23:01:00)
FLAC Decoder 1.1.0
WMA Decoder 1.1
foo_masstag.dll (2007-08-20 23:01:00)
Masstagger 1.6
foo_rgscan.dll (2007-08-20 23:01:00)
ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2006-11-22 20:05:24)
Columns UI 0.1.3 beta 1v7
foo_uie_albumart.dll (2007-04-14 03:45:00)
Album Art Panel 0.2.5.2
foo_uie_lyrics.dll (2007-08-11 16:51:07)
Lyric Show Panels 0.3.1.1b8 DEV [Aug 11 2007 - 16:49:37]
foo_uie_quicksearch.dll (2007-05-18 13:31:00)
NOTE : I noticed this happens ONLY when "transparent background" is DISABLED.I dont use transparent background.
P.S.
Thank you for your work.
Thank for your work.
I really like this component.
I want to add some lyrics by myself, but I have no idea which database are been supported....
So, I'd like to know which database you are using
Awesome! Thank you very much, works perfectly . I'm back to this lyric component now .
foobar2000 ver 0.9.4.4
I'v found one bug in this lyrics panel(Version: 0.3.1.1b8 DEV [Aug 31 2007 - 20:24:03])
(http://www.gongqing.gov.cn/bug.jpg)
In this window,there are two panel:lyrics panel and playlist panel. I have setted playlist panel as auto hide. When I moved mouse on playlist to let playlist show,then double click a song in this playlist,then let mouse leave out playlist,the playlist can autohide.
I think this bug is of lyrics panel, because some version of lyrics panel havn't this.
this lyrics panel is good, I like it.
One suggestion:User can change to many lyrics database by themsevles
I'm a Chinese, my English is not so good.haha
@esunxray:
So... I'm not good at English, either. You can PM me using Chinese.
The bug you mentioned has been fixed. Please try the latest DEV build.
@Susan:
I have already fixed that in the latest DEV build, Download (http://www.hydrogenaudio.org/forums/index.php?act=Attach&type=post&id=3681), Thanks for reporting.
@SCR5000:
I haven't done the upload client yet.
You can upload lyrics by using minilyrics, but one Problem is minilyrics uses two databases, one is viewlyrics.com, the other is minilyrics.com, and both are DIFFERENT.
I'm sorry, i didnt mean to grab lrc's from 51lrc, i just wanted the option to save the .lrc files in UTF-8 locally, instead of ANSI, so i dont have to change every single japanese lyric i download.
A dropdown with different encodings like notepad has would be nice, so we could set standard.
@Susan:
Thank you so much.
As I said before, to save files in Unicode(include UTF8, UTF16 and so on) encoding:
1. You must know the current encoding of the file.
2. You must have the "code page conversaion table" for the encoding installed.
Besides, "ANSI" containes a lot of different encoding (e.g. GB2312, Thai, Shift-JIS, JIS, EUC-JP, BIG5 and so on)
In fact, in many lyrics folder (and the online database), the lyrics file saved as (UTF8, UTF16BE, UTF16LE, GB2312, ISO-8859-15, Shift-JIS, Big5 and so on)
So the big problem is hwo to judge the file encoding... But there's no way to judge(even estimate) that.
One "solution" is popup a message and ask user judge the file encoding EVERY TIME ON LYRICS DOWNLOADED // but it's annoying...
Another "solution" is force the programe to set a encoding like "Shift-JIS" and save it to UTF8 // but when meet a file with different encoding like "EUC-JP", the characters will go garbled...
............headache.
However, I suggest you use Uni2Me (http://alf-li.pcdiscuss.com/e_index.html%5b/url) to convert various files encoding in one time
2 bugs of foobar2000 0.9.4.4,may is of lyrics_panel
1. double click mp3 named 14-LaurenChristy-TheColorOfTheNight will show:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00DE4508h
Access violation, operation: read, address: 01115000h
Call path:
entry
Code bytes (00DE4508h):
00DE44C8h: F7 8B 44 24 10 8B 4C 24 24 03 C8 3B D9 73 37 8B
00DE44D8h: C3 8D 57 1C 8D 70 02 90 66 8B 08 83 C0 02 66 85
00DE44E8h: C9 75 F5 2B C6 D1 F8 50 53 8B F2 E8 68 F7 00 00
00DE44F8h: 8B 7F 30 66 83 3C 7B 00 8D 1C 7B 75 09 83 C3 02
00DE4508h: 66 83 3B 00 74 F7 8B 7C 24 20 8D 44 24 18 E8 D5
00DE4518h: E3 00 00 C6 44 24 38 00 8B 44 24 1C 33 F6 39 30
00DE4528h: 75 58 50 E8 AA 88 02 00 8B 7C 24 18 83 C4 04 83
00DE4538h: 7F 34 08 72 0C 8B 57 20 52 E8 94 88 02 00 83 C4
Stack (0012EF1Ch):
0012EEFCh: 00000000 001672B0 00160168 00000000
0012EF0Ch: 00000000 001672B0 00000040 001672B8
0012EF1Ch: D22E0726 0012F024 0012F048 294A41AA
0012EF2Ch: 00000202 01113FD8 01113FD8 011140B8
0012EF3Ch: 00E36064 01114DF8 00000202 0012F024
0012EF4Ch: 0012EFAC 00E21920 00000001 0012EFB8
0012EF5Ch: 00E01E29 0012EF84 00000206 0012F024
0012EF6Ch: D22E07BE 0012F0E8 009F6800 000009CB
0012EF7Ch: 0012F048 0012F024 00E28FA4 0012F048
0012EF9Ch: 294A41AA 84A9FC32 D22E07BE 0012EF6C
0012EFACh: 0012F080 00E20D90 00000000 0012F08C
0012EFBCh: 00E0B7CD 0040D1C2 0012F048 0012F024
0012EFCCh: 0012F114 00000003 0000016B 0045CE10
0012EFDCh: 009F64C0 0012F094 0044E9CA 7C92D592
0012EFECh: 7C809B8B 00000070 0012F094 00450266
0012EFFCh: 00450272 0012F114 00000002 0000016B
0012F00Ch: 0049437D 0045CE10 00012E98 20DBBD70
0012F01Ch: 41EF498B 075142B4 004BE934 00000000
0012F02Ch: 000000C0 00000000 00000000 00000000
Registers:
EAX: 01113FF4, EBX: 01115000, ECX: 00000000, EDX: 00000002
ESI: 01113FF4, EDI: 00000049, EBP: 0012EF58, ESP: 0012EF1C
Crash location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Loaded modules:
ntdll loaded at 7C920000h - 7C9B4000h
kernel32 loaded at 7C800000h - 7C91D000h
COMCTL32 loaded at 77180000h - 77283000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E49000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32 loaded at 77D10000h - 77D9F000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7D590000h - 7DD82000h
ole32 loaded at 76990000h - 76ACD000h
comdlg32 loaded at 76320000h - 76367000h
IMM32 loaded at 76300000h - 7631D000h
LPK loaded at 62C20000h - 62C29000h
USP10 loaded at 73FA0000h - 7400B000h
MSCTF loaded at 74680000h - 746CB000h
msctfime loaded at 73640000h - 7366E000h
foo_cdda loaded at 00A60000h - 00A95000h
foo_converter loaded at 00AC0000h - 00B29000h
foo_dsp_std loaded at 00B50000h - 00B91000h
foo_input_monkey loaded at 00BC0000h - 00C0A000h
foo_input_std loaded at 00C30000h - 00D42000h
foo_rgscan loaded at 00D70000h - 00DB8000h
foo_uie_lyrics loaded at 00DE0000h - 00E41000h
gdiplus loaded at 4AE90000h - 4B033000h
WININET loaded at 41FD0000h - 4209F000h
Normaliz loaded at 00E60000h - 00E69000h
iertutil loaded at 41D50000h - 41D95000h
WINMM loaded at 76B10000h - 76B3A000h
foo_ui_columns loaded at 01120000h - 011C6000h
foo_ui_std loaded at 011F0000h - 01247000h
foo_unpack loaded at 01270000h - 0129E000h
imagehlp loaded at 76C60000h - 76C88000h
DBGHELP loaded at 68D60000h - 68E01000h
VERSION loaded at 77BD0000h - 77BD8000h
Address: 00E21920h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E01E29h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E28FA4h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E20D90h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E0B7CDh, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 0040D1C2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045CE10h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044E9CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C92D592h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C809B8Bh, location: "kernel32", loaded at 7C800000h - 7C91D000h
Address: 00450266h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00450272h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049437Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE934h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE93Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7650h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AC659h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A711h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040A71Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6392h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0048CD80h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00DE0000h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E348DCh, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00481422h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C6804h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DE494h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6508h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040AF92h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC416h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 76A6C5ACh, location: "ole32", loaded at 76990000h - 76ACD000h
Symbol: "SNB_UserFree" (+00002081h)
Address: 7DC71FACh, location: "SHELL32", loaded at 7D590000h - 7DD82000h
Address: 004DE474h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0084h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E1B74h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AC6F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004308CFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C930732h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C9306EBh, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C9305D4h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C930738h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C931538h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C931596h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 004E41B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C93056Dh, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C92EE18h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 7C9306F0h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Address: 00492BFDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4238h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447B71h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045CE23h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049976Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497440h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0508h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF584h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430CAAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E09B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049712Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00492502h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004924FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B3450h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.4
UNICODE
2. I have 1000 mp3, but I can't do this: ctrl+O,selected them all,click Open. this will do nothing.
I don't know this bug is of foobar2000 or lyrics panel?
@esunxray:
1. Please give me a screenshot of the TAG window of 14-LaurenChristy-TheColorOfTheNight.mp3
2. Are you sure it's a bug of foo_uie_lyrics? Open 1000 mp3s in one time?
Line padding can't set to 0: it's not a bug. Line Padding is an Integer between 4 - 20.
Lyrics database is hard to add because there is no law among them.(some require xml to post, some is query as HTTP post...)
Great work TP Wang ! Thanks for such a nice plugin ..
Great improvement of an already great piece of code, thank you very much! Autoscrolling works fine, I missed that feature so badly, thanx again!
GreetinX from Berlin, Germany
Anandamid
Uh oh .. It keeps forgetting the proxy settings .. If I select 'Use user defined proxy settings', As soon as I click on Save All, it goes back to default empty.
And how about setting the password field showing ****s instead of normal text ..?
Great work btw .. @!
once crash again
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 4EC97CD7h
Access violation, operation: read, address: 000A0004h
Call path:
entry=>initquit::on_init
Code bytes (4EC97CD7h):
4EC97C97h: 56 75 34 BE 00 04 00 00 56 E8 D8 5B 0A 00 85 C0
4EC97CA7h: 89 03 75 0C A1 3C 60 DD 4E 6A 03 89 03 58 EB 7E
4EC97CB7h: 33 C0 8B 0B 8B 15 40 60 DD 4E 89 14 08 83 C0 04
4EC97CC7h: 3B C6 7C EE 8B 45 08 8B 0B 57 0F B6 FC C1 E7 02
4EC97CD7h: 8B 0C 0F 3B 0D 40 60 DD 4E 89 7D FC 75 39 68 00
4EC97CE7h: 02 00 00 E8 8E 5B 0A 00 8B 0B 89 04 0F 85 C0 8B
4EC97CF7h: 03 75 0E 8B 0D 40 60 DD 4E 6A 03 89 0C 07 58 EB
4EC97D07h: 2C 8B 3C 07 8B 35 40 60 DD 4E 8B 45 08 B9 80 00
Stack (0012E9B4h):
0012E994h: 00000000 0012F7F8 0012F7D0 00000000
0012E9A4h: F103BDD8 F103BAE0 F103BB48 F103BBA0
0012E9B4h: 02EE58E4 02EE6168 00110002 02ED14F0
0012E9C4h: 0012E9E0 4ED0C395 00110002 0012E9DC
0012E9D4h: 00000A96 02EE5338 0011630C 0012EA0C
0012E9E4h: 4ED0C898 000000B4 02ED14F0 02EE637A
0012E9F4h: 00000000 02EE5200 00000005 02EE533C
0012EA04h: 00000000 00000007 0012EA48 4EC98B84
0012EA14h: 000003A8 0000106A 02ED14F0 02EE5240
0012EA24h: 02EE5208 02EE51C8 00000000 00000024
0012EA34h: 01F601D4 02EE5310 0000106A 01F78EA4
0012EA44h: 00000000 0012EA68 4ECD88EB 00000000
0012EA54h: 01EE9FC0 0012EBC0 00000001 000000EC
0012EA64h: 01ECB400 0012EBA4 4ECD8C6A 00000000
0012EA74h: 00000001 01EE9FC0 00000000 00000015
0012EA84h: 01613668 00000000 00000020 00000140
0012EA94h: 00000002 00000040 00000000 00000000
0012EAA4h: 016101A0 00000001 00000000 00000000
0012EAB4h: 01610190 00000004 0000000E 00000006
0012EAC4h: 00000000 00000000 00000000 01610238
Registers:
EAX: 00110002, EBX: 02ED1538, ECX: 000A0004, EDX: 00000011
ESI: 02EE6168, EDI: 00000000, EBP: 0012E9C4, ESP: 0012E9B4
Crash location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Loaded modules:
YzShadow loaded at 00A70000h - 00A7E000h
DM2 loaded at 00B00000h - 00B06000h
foo_converter loaded at 00B30000h - 00B99000h
foo_cwb_hooks loaded at 00BC0000h - 00C0D000h
foo_dockable_panels loaded at 00C30000h - 00C63000h
foo_infobox loaded at 00C90000h - 00CD0000h
foo_input_monkey loaded at 00CF0000h - 00D3A000h
foo_input_std loaded at 00D60000h - 00E72000h
foo_input_tta loaded at 00EA0000h - 00ECD000h
foo_masstag loaded at 00EF0000h - 00F40000h
foo_uie_lyrics loaded at 00F60000h - 00FC4000h
Normaliz loaded at 00FE0000h - 00FE9000h
foo_uie_playlists_dropdown loaded at 012A0000h - 012D9000h
foo_uie_single_column_playlist loaded at 01300000h - 0134C000h
foo_uie_trackinfo_mod loaded at 01370000h - 013C7000h
foo_ui_columns loaded at 013E0000h - 01486000h
foo_utils loaded at 014B0000h - 014E8000h
Address: 4ED0C395h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED0C898h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC98B84h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECD88EBh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECD8C6Ah, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 4ED3D893h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC97357h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC9777Fh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECC2A43h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECC2B9Fh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0046005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E004Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0045h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00450048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 4ECC2E23h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 77D4B765h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+00000026h)
Address: 77D4B795h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+00000056h)
Address: 77D7046Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B798h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+00000059h)
Address: 00B0267Ch, location: "DM2", loaded at 00B00000h - 00B06000h
Address: 00B026C1h, location: "DM2", loaded at 00B00000h - 00B06000h
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 77D4F8A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00C34000h, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 77D488E1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D488EAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0041005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00460050h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430054h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430041h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00B00000h, location: "DM2", loaded at 00B00000h - 00B06000h
Address: 7C90E0A5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtQueryKey" (+0000000Ch)
Address: 77DFC023h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "GetFileSecurityW" (+00000345h)
Address: 77DFBF28h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "GetFileSecurityW" (+0000024Ah)
Address: 77DFBFF8h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "GetFileSecurityW" (+0000031Ah)
Address: 77D9ABF4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 00B024B0h, location: "DM2", loaded at 00B00000h - 00B06000h
Symbol: "CreateMenuFromString" (+00000B90h)
Address: 00B01492h, location: "DM2", loaded at 00B00000h - 00B06000h
Symbol: "DisableFavMenu" (+000002B6h)
Address: 77D4883Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 7C9010EDh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLeaveCriticalSection" (+00000000h)
Address: 77F1B1B0h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "StretchDIBits" (+00000141h)
Address: 77F1991Bh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+00000084h)
Address: 77F198F6h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 7C90FB3Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+00000000h)
Address: 7C90FB6Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+0000002Fh)
Address: 7C90FB71h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+00000034h)
Address: 77F199E7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateFontIndirectW" (+0000004Eh)
Address: 77DFC25Ah, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "RegQueryInfoKeyA" (+000000A5h)
Address: 4ECC5AB3h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECC5C08h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECC2EFBh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC97E9Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 77F15B90h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SelectObject" (+00000000h)
Address: 77F1A61Eh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetBrushOrgEx" (+00000351h)
Address: 77F1A5D2h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "GetBrushOrgEx" (+00000305h)
Address: 77F53020h, location: "GDI32", loaded at 77F10000h - 77F57000h
Address: 77F16F43h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteDC" (+000000ABh)
Address: 4EC98489h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 7C901005h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlEnterCriticalSection" (+00000000h)
Address: 4EDD627Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC90E8Bh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Symbol: "GdipCreateFontFromLogfontW" (+0000007Fh)
Address: 00FB92A0h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00F64D8Fh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00F68070h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 77D4D611h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcA" (+00000113h)
Address: 004DEE08h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D4D650h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowLongW" (+00000015h)
Address: 00FA2F39h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 77D4D63Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowLongW" (+00000000h)
Address: 00F7395Ch, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00F73910h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 77D48744h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D55324h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 77D54EF0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+0000029Fh)
Address: 77D54D17h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000000C6h)
Address: 77D54F22h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D54F44h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48826h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 00FBB284h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 77D48840h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4E0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B51Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D4B483h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D494CEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D4D4F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D55B68h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 00FBB250h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00F60000h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00FBB26Eh, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00FBB1A0h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00FE0000h, location: "Normaliz", loaded at 00FE0000h - 00FE9000h
Address: 00FB0058h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 77D55E8Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogIndirectParamAorW" (+00000033h)
Address: 77D5A1AFh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogParamW" (+00000049h)
Address: 00F627C5h, location: "foo_uie_lyrics", loaded at 00F60000h - 00FC4000h
Address: 00C3274Fh, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 00C3BBE1h, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 00C310DDh, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Version info:
foobar2000 v0.9.4.4
UNICODE
Additional info:
Standard Input Array 1.0 (foo_input_std)
Converter 1.0.1 (foo_converter)
FLAC Decoder 1.1.0 (foo_input_std)
Lyric Show Panels 0.3.1.1b7 [Jul 13 2007 - 12:34:08] (foo_uie_lyrics)
Masstagger 1.6 (foo_masstag)
TTA Audio Decoder (unofficial) 2.4.2 (foo_input_tta)
Playlist Tools 0.5.9 (foo_utils)
foobar2000 core 0.9.4.4 (Core)
WMA Decoder 1.1 (foo_input_std)
Track info panel mod 0.8.0 beta [Dec 6 2006 - 14:21:24] (foo_uie_trackinfo_mod)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00] (foo_cwb_hooks)
Playlists Dropdown 0.6 alpha 3 (foo_uie_playlists_dropdown)
Single Column Playlist Display 0.5.4 beta [Jan 9 2007 - 15:42:59] (foo_uie_single_column_playlist)
Columns UI 0.2.0 beta 1 (foo_ui_columns)
Special file info box 2.0.4 (foo_infobox)
Monkey's Audio decoder 2.1.2 (foo_input_monkey)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48] (foo_dockable_panels)
cwbowron's title format hooks 1.2.5 [Jun 8 2007 - 08:49:42] (foo_cwb_hooks)
I think the crash related to my system
So I think must reinstall windowsXP
but in the other hand, I prefer to use original one( more stable one)
@Shahab Jafri:
I've fixed latest DEV version.
I'll release it tomorrow.
EDIT: You can get the latest DEV version now.
@store88:
You can disable fading effect(That doesn't use gdiplus). It seems that your gdiplus.dll file is corrupt.
Unlucky, disable fading not get a good result too
Right now no lyrics are retrieved. How can I verify what's wrong?
Now I've no ideas about that, sorry.
The lyrics server is temporarily offline.
Hey, Here is a new idea for you plugin : I have tracks that contains accented character (like Motörhead, which is written Motorhead too often :/). It seems the search engine of the lyrics website does not replace accents with their equivalents.
Is that possible to have such option while searching? eg: searching Motörhead and Motorhead?
Good idea.
Now I'm working on a new search engine that support multi servers and search strategy.
Hi. I have a problem with this plug-in. It only manages to download 10 lyrics, but then I have to restart foobar, in order to get it to download again. I am using the latest DEV version, but it was the same with previous. Can you help me?
Sorry I can't reproduce that. Can you post screenshots of your configuration of "Setting" and "Internet" tab?
Here:
(http://i19.tinypic.com/4tuqf69.jpg)
(http://i6.tinypic.com/6gtwpbq.jpg)
just reporting in to say that i have experienced the above issue as well. i never really counted but there were times when i wondered why it wouldnt display/download lyrics for a popular song.
restarting foobar made it download lyrics again.
this wasnt a firewall issue since i had no software/hardware firewall installed. i always thought it was coz i was on slow connection. dial up.
So, is there a way to fix it?
Hi, guys! I just found out about this component and I want to ask a few questions...
1. I've found out a strange bug - foo_uie_lyrics is chopping off the first characters of my lyrics files. Not the downloaded ones, but the ones I had before I started using foobar and lyrics show panel. It could be due to a bad formatting by my former lyrics plug-in, but I doubt that - all my lyrics are stored in .txt files, and not embedded in the mp3's. I used WinLyrics for Winamp, and it is still displaying them properly...
Here's an example:
[a href="http://img65.imageshack.us/my.php?image=lyricspanelproblempp0.jpg" target="_blank"]
@Blueinferno:
@Susan:
I attempt to reproduce the problem but after downloading over 50 lyrics and show it on the lyrics show panel so it seemed work fine.
However, there is three reasons may cause your problems:
(1). This is a bug and I'll fixed it later: If once you associate a song with one lyric file(just see your lyrics.xml file in foobar2000 directory), and then the lyric file is deleted or moved, It will show nothing on the lyrics file.
(2). In your lyrics.xml file, you can see "disabled" attrib in your each xml elems. It's always set to "false", but once the "disabled" is set to "true"(related to "Disable associations" and "Enable associations"), the panel will not show lyric.
(3). In the "setting" tab, you can see Filter setting. like this:
// Below two lines means if %title% or %_filename% contains any of Track* or CDImage.* or Unknown*, the lyric won't be downloaded nor shown.
[Column 1] [Column 2]
Track*;CDImage.*;Unknown* $if2(%title%,%_filename%)
That means if the content of [Column 1] matches [Column 2], The lyric won't be downloaded nor shown.
EDIT: If you tried set "Save scheme" another setting besides "Embed to file" but you still encountered the problem please let me know.
@halocline_
1. Can you send the lyric file to me? (Please update the lyric file in some file hosting.)
2. Currently I'm working on foo_makelyric plug-in which can cooperate with the foo_uie_lyrics plug-in, but I can't make any schedule now because I have a lot of other work to do.
@halocline_
Sure, here it is (http://files-upload.com/files/499870/02-borknagar-traveller-esc.txt)
I don't have a lyrics.xml file in my foobar directory. I'm only embedding them to a file.
Even if they matched (they don't), lyrics to the next song would be being downloaded, and they are not.
Right now nothing is being downloaded, so I can't really check it.
@halocline_:
confirmed as a bug, I'll fix it.
@Blueinferno:
I'm sorry I've no idea about that.
I don't have so much lyrics but more album reviews and biographies of artists wich are stored in simple txt-files. It would be a nice feature if each Lyric Show panel could have its own settings like Album Art panel has so that we could have several panels with different sources.
@halocline_:
New version updated(latest DEV build).
@q-stankovic:
The development of this feature had been suspended because of time, sorry.
could you add the feature to select the transparancy rather then just on or off? or is it possible using panels?
@Blueinferno:
Too bad. Maybe someone else is having the same problem and is able to help me?
Plus, in the newest DEV version, when i right click the panel, app crushes and I get this:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0112CB05h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (0112CB05h):
0112CAC5h: 89 25 00 00 00 00 83 EC 30 8B 4D 08 8B 01 53 56
0112CAD5h: 57 FF 10 8B D8 85 DB 89 5C 24 14 75 07 32 C0 E9
0112CAE5h: AF 00 00 00 33 F6 85 DB 76 54 8B 4D 08 8D 44 24
0112CAF5h: 0C 50 8B D6 E8 02 CD FF FF 83 64 24 44 00 8B 08
0112CB05h: 8B 01 FF 50 0C 8B 10 8B C8 FF 12 83 4C 24 44 FF
0112CB15h: 8B 4C 24 0C 85 C9 8B F8 74 04 8B 01 FF 10 8B C7
0112CB25h: 8D 7C 24 18 E8 62 00 01 00 68 98 3C 15 01 50 FF
0112CB35h: 15 04 12 15 01 85 C0 75 A4 46 3B F3 72 AC 33 F6
Stack (0012F170h):
0012F150h: 00000000 00000008 00020716 00000000
0012F160h: B04CDAD4 BF80EE00 BC6E4E38 00000008
0012F170h: 0429DBC8 0115EF0C 01184700 00000000
0012F180h: 00492A0D 00000001 00000008 01184740
0012F190h: 03C84B90 00014C84 00000007 01180178
0012F1A0h: 0012F2A0 0012F1E4 7C90EE18 0012F2B8
0012F1B0h: 0114EA97 00000000 0049435E 0012F2C4
0012F1C0h: 0112D06D 0429DBC8 0115EF0C 01126085
0012F1D0h: 00000000 0429DBC8 0012F274 0012F290
0012F1E0h: 0429DC28 0429DBB8 0429DBC8 01184728
0012F1F0h: 01125F25 00000000 0429DBC8 0012F274
0012F200h: 0012F290 0429DC28 00000000 004113EB
0012F210h: 0012F274 0012F290 0429DBC8 0429DC28
0012F220h: 0429DBB8 03C95A00 00000035 7C90EE18
0012F230h: 7C917BB8 01184720 01180168 00000000
0012F240h: 00000000 01184720 00000018 01184728
0012F250h: 00000000 01180178 00000018 00000000
0012F260h: 01180000 0012F05C 0429DC28 0012F36C
0012F270h: 7C90EE18 004C7650 00000000 00000000
0012F280h: 00000000 00000000 00000000 0000000C
Registers:
EAX: 0012F17C, EBX: 00000001, ECX: 00000000, EDX: 00000000
ESI: 00000000, EDI: 0429DBC8, EBP: 0012F1BC, ESP: 0012F170
Crash location: "foo_rgscan", loaded at 01120000h - 01168000h
Loaded modules:
ntdll loaded at 7C900000h - 7C9B2000h
kernel32 loaded at 7C800000h - 7C8FC000h
COMCTL32 loaded at 773C0000h - 774C3000h
msvcrt loaded at 77C00000h - 77C58000h
ADVAPI32 loaded at 77DC0000h - 77E6C000h
USER32 loaded at 7E360000h - 7E3F0000h
SHELL32 loaded at 7C9C0000h - 7D1DC000h
ole32 loaded at 774D0000h - 7760D000h
comdlg32 loaded at 76380000h - 763C9000h
uxtheme loaded at 5B1D0000h - 5B208000h
CbrHelper loaded at 00A40000h - 00A45000h
foo_albumlist loaded at 00A50000h - 00A97000h
OLEAUT32 loaded at 77110000h - 7719B000h
foo_appcommand loaded at 00AC0000h - 00AD6000h
foo_audioscrobbler loaded at 00B00000h - 00B30000h
WS2_32 loaded at 71A50000h - 71A67000h
WS2HELP loaded at 71A40000h - 71A48000h
foo_cdda loaded at 00B50000h - 00B85000h
foo_converter loaded at 00BB0000h - 00C19000h
foo_cwb_hooks loaded at 00C40000h - 00C75000h
foo_dbsearch loaded at 00CA0000h - 00D10000h
foo_dbsearch_api_demo loaded at 00D30000h - 00D51000h
foo_dop loaded at 00D80000h - 00DEF000h
SETUPAPI loaded at 77910000h - 77A06000h
gdiplus loaded at 4EBC0000h - 4ED63000h
foo_dsp_std loaded at 00E20000h - 00E61000h
foo_history loaded at 00E90000h - 00EAC000h
foo_input_std loaded at 00ED0000h - 00FE2000h
foo_lyricsdb loaded at 01010000h - 0102E000h
WININET loaded at 771A0000h - 77247000h
CRYPT32 loaded at 77A70000h - 77B05000h
MSASN1 loaded at 77B10000h - 77B22000h
foo_masstag loaded at 01050000h - 010A0000h
foo_playcount loaded at 010C0000h - 010E8000h
foo_rgscan loaded at 01120000h - 01168000h
foo_run loaded at 01190000h - 011BB000h
foo_sendtodevice loaded at 011E0000h - 0121A000h
foo_uie_albumart loaded at 01240000h - 0127C000h
foo_uie_lyrics loaded at 012A0000h - 01301000h
WINMM loaded at 76B20000h - 76B4E000h
foo_uie_queuemanager loaded at 013B0000h - 013E9000h
mscoree loaded at 79000000h - 79045000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 0FFD0000h - 0FFF8000h
System.ni loaded at 7A440000h - 7AC06000h
System.Drawing.ni loaded at 7ADE0000h - 7AF6C000h
foo_ui_columns loaded at 03B30000h - 03BD6000h
foo_ui_std loaded at 03C00000h - 03C57000h
dciman32 loaded at 73B50000h - 73B56000h
netapi32 loaded at 6FF40000h - 6FF94000h
appHelp loaded at 77B30000h - 77B52000h
CLBCATQ loaded at 76FC0000h - 7703F000h
COMRes loaded at 77040000h - 7710D000h
VERSION loaded at 77BF0000h - 77BF8000h
shdocvw loaded at 7E1E0000h - 7E34F000h
CRYPTUI loaded at 768B0000h - 76932000h
WINTRUST loaded at 76C20000h - 76C4E000h
IMAGEHLP loaded at 76C80000h - 76CA8000h
WLDAP32 loaded at 76F50000h - 76F7D000h
urlmon loaded at 7DF10000h - 7DFB0000h
Secur32 loaded at 77FE0000h - 77FF1000h
DBGHELP loaded at 59BC0000h - 59C61000h
Address: 0115EF0Ch, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00492A0Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Address: 0114EA97h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 0049435Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112D06Dh, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 01126085h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 01125F25h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 004113EBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 0113E5B7h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00410EE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045CBFDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AB9EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041185Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041191Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042B3E6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041265Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412310h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004124F1h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00410CAAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411882h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004ACF61h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411977h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412FA2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AB8EBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412B49h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112F46Ch, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00403ED7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412CDEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490199h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112F494h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00411CFFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0115EEFCh, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 004C3BE8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00403EC8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AE12Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411207h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6799h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041107Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 012A91AFh, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 012E8C0Ch, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Address: 03B36C80h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B42Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 012E31F9h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 012A7B01h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E368BD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E3C0088h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3CCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E36B3A7h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E37878Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ChildWindowFromPoint" (+000000B6h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 03B56F80h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 03B57057h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 7E37379Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3684FCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3685A4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3F9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 7E368B26h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 012B44E0h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 012E3348h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E36D62Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 012B452Ch, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E373745h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3737BCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36D17Fh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+0000021Ch)
Address: 7E36B393h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 7E36C331h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 7E37366Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 7E3689CDh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E36F95Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 7E381B3Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 7E3689F0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E368A10h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 7E37D99Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FED2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7E36DAEAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEB74h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FF44h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C04F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430AA3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07B4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7634h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "wcsncpy" (+00000AA9h)
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF978h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496804h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00DCD0B8h, location: "foo_dop", loaded at 00D80000h - 00DEF000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049686Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.4
UNICODE
Additional info:
Send to Device 1.1.0 (beta) [Dec 20 2006 - 16:40:06] (foo_sendtodevice)
Database Search 1.4 (foo_dbsearch)
Album List 3.2.0 (foo_albumlist)
CD Audio Decoder 2.1.1 (foo_cdda)
Database Search Toolbar Demo 1.0 (foo_dbsearch_api_demo)
Queue manager panel 0.2.3 (foo_uie_queuemanager)
iPod manager 0.4.5 TEST (foo_dop)
History 0.2 (foo_history)
Default User Interface 0.9acc (foo_ui_std)
Audioscrobbler 2.1 (foo_audioscrobbler)
Standard DSP array 1.0 (foo_dsp_std)
cwbowron's title format hooks 1.1.0beta [Dec 1 2006 - 13:47:34] (foo_cwb_hooks)
Album Art Panel 0.2.6 (foo_uie_albumart)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Run services 0.3.2 (foo_run)
foo_lyricsdb 0.0.7 beta 4 (foo_lyricsdb)
Playback Statistics 1.3.2 (foo_playcount)
Lyric Show Panels 0.3.1.1b8 DEV [Sep 15 2007 - 21:52:48] (foo_uie_lyrics)
APPCOMMAND multimedia key support 0.1 (foo_appcommand)
@Blueinferno:
It's a critial bug, to avoid the bug, do not right click the panel if the song isn't playing.
I'll fix it soon.
@2Pacalypse:
The "transparent" in fact, is pseudo transparent.
If you want semi-transparecy, create a semi-transparent rectange before place the lyrics show panel.
@Blueinferno:
The bug that caused foobar crash is fixed now(latest DEV version)
any idea how to show the lyrics in small letter?
Pardon? I can't quite understand.
@Blueinferno:
Ok, thanks.
Hey, I was thinking. If you don't know how to help me with this downloading-only-10-lyrics problem, maybe you can give me a site you take lyrics from, and I'll download 'em manually. That'll be, I guess, more convenient than restarting the app after every 10 lyrics are downloaded.
hmm, I just want all the lyrics (or text) to display in 'lowercase' instead of 'Sentence case' and 'UPPERCASE'. I've tried using panels ui syntax but it didn't work. is there any way to do so?
TP Wang you are making such a great work, thank you. I hope you ll have time to continue the multiple instance feature since know i depending on a pvar draw the lyrics panel in different places and it goes mad. After changing its position it keeps flicking and doesnt always redraw.
I have a strange bug also, i have empty lyrics automatically created when changing track even if the automatic download feature isnt checked. It happened on my two machines, once with txt files the other with lrc files. Happening right now.
Little feature request: could you add an entry for online search in the context menu of a track so that we can make a button for lyrics?
Thanks a lot
@Blueinferno:
Ok, thanks.
Have your tried right click on the panel - > Online search?
If you can visit http://www.viewlyrics.com:1212 (http://www.viewlyrics.com:1212), The panel should download lyrics.(you can't download the lyrics directly)
Sounds reasonable, I'll consider to add this feature.
Sorry, but I have lot of work to do now, really.
I hope there's more time for me to continue development in next month.
I can reproduce the bug, I'll fix it later, thanks.
Yes, I'll add it, int the next DEV version.
Hello T.P. Wang,
although all of us like to make feature requests there is nobody who wants a feature implementation on the next day.
Even next month is very fast!
I second that q-stankovic!
Thanks for the great plugin, T.P Wang.
Really love it.
I noticed in the latest DEV version, I am suddenly able to download chinese lyrics through the panel .
That's great .
But I do have one tiny request since it is not possible to convert:
Some .lrc files do have their encoding stated above, such as: "[encoding:gb2312]"
It would be great if the lyrics plugin could read and set the codepage accordingly .
I have. After 10 lyrics are downloaded it shows "nothing found".
EDIT: No, it shows "Searching for lyrics..." like for infinity, and it never manages to find them.
nice
It now work perfect with dockpanel
With the latest I have no problems with missing characters anymore. Thanks!
There's a bug in the latest DEV version, the plugin will create empty lrc files inside my download directory and associate them with the file despite the fact that my settings are:
- Do not download from the Internet
- When Lyric Found from directory: Do nothing.
By the way, can you make the latest DEV version's source code available?
I'm still experiencing problem with downloading lyrics. I can download only 10 lyrics and then it stops downloading. Since T.P Wang isn't able to help, maybe someone else is having the same problem, and can help me? It kinda freaks me out, when I have to restart foobar after every 10 lyrics are downloaded.
I just don't know what's wrong, T.P Wang says it's working for him perfectly. I am using Windows XP Pro, foobar2000 v0.9.4.4 and am polish, if it can help.
The proxy thing aint working .. .. Even when I try Right Click > Online search and click on Search, the message comes Search Failed ..
The same proxy settings are working fine in Audioscrobler plugin settings ..
I am having an HTTP proxy with authentication enabled .. So cant use IE Proxy settings ..
I've created LyricsCreator (http://www.hydrogenaudio.org/forums/index.php?showtopic=57752). You can use it with conjuction of Lyrics Show Panel, as there isn't feature of creating/editing lyrics.
one bug for this panel. When I double clicks a song named start to open it in foobar, this error will be showd. You can rename a song's name as 'start' to try.
file location: E:\LocalUser\Gongqing\File\Personal\课件\跨越海峡的生命桥flash8版\start.mp3
When I move the song to another folder, there isn't this error. Maybe the error is not about song's name.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00DE44C8h
Access violation, operation: read, address: 011E5000h
Call path:
entry
Code bytes (00DE44C8h):
00DE4488h: F7 8B 44 24 10 8B 4C 24 24 03 C8 3B D9 73 37 8B
00DE4498h: C3 8D 57 1C 8D 70 02 90 66 8B 08 83 C0 02 66 85
00DE44A8h: C9 75 F5 2B C6 D1 F8 50 53 8B F2 E8 88 F7 00 00
00DE44B8h: 8B 7F 30 66 83 3C 7B 00 8D 1C 7B 75 09 83 C3 02
00DE44C8h: 66 83 3B 00 74 F7 8B 7C 24 20 8D 44 24 18 E8 65
00DE44D8h: E4 00 00 C6 44 24 38 00 8B 44 24 1C 33 F6 39 30
00DE44E8h: 75 58 50 E8 7F 8A 02 00 8B 7C 24 18 83 C4 04 83
00DE44F8h: 7F 34 08 72 0C 8B 57 20 52 E8 69 8A 02 00 83 C4
Stack (0012EF1Ch):
0012EEFCh: 023EE62C 7D5993C0 77F443DD 7D5993C0
0012EF0Ch: 00000004 00000000 023EDB38 00000000
0012EF1Ch: 0E771637 0012F024 0012F048 294A41AA
0012EF2Ch: 00000202 011E3FD0 011E3FD0 011E40B0
0012EF3Ch: 00E3606C 011E4DF0 00000202 0012F024
0012EF4Ch: 0012EFAC 00E21A00 00000001 0012EFB8
0012EF5Ch: 00E04259 0012EF84 00000206 0012F024
0012EF6Ch: 0E7716AF 0012F0E8 009F67F8 000009CB
0012EF7Ch: 0012F048 0012F024 00E29428 0012F048
0012EF8Ch: 00000000 00000206 C01D9769 490F6830
0012EF9Ch: 294A41AA 84A9FC32 0E7716AF 0012EF6C
0012EFACh: 0012F080 00E20E10 00000000 0012F08C
0012EFBCh: 00E0B87D 0040D1C2 0012F048 0012F024
0012EFCCh: 0012F114 00000003 0000016B 00000000
0012EFDCh: 0049437D 0E6DD034 00000000 0012F07C
0012EFECh: 013E02F0 00000004 0012EFE0 00000004
0012EFFCh: 009F0000 00497440 0E335A20 FFFFFFFE
0012F00Ch: 0049437D 0045CE10 000102F0 00000009
0012F01Ch: 0012EF78 013E02F0 004BE934 7C92EE00
0012F02Ch: 000000C0 FFFFFFFF 7C93056D 0049435E
Registers:
EAX: 011E3FEC, EBX: 011E5000, ECX: 00000000, EDX: 00000002
ESI: 011E3FEC, EDI: 00000049, EBP: 0012EF58, ESP: 0012EF1C
[color=#FF0000]Crash location: "foo_uie_lyrics", [/color] loaded at 00DE0000h - 00E41000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
shared loaded at 10000000h - 10029000h
WININET loaded at 00E60000h - 00F2E000h
Normaliz loaded at 00F30000h - 00F39000h
iertutil loaded at 5DCA0000h - 5DCE5000h
foo_ui_columns loaded at 011F0000h - 01296000h
foo_ui_std loaded at 012C0000h - 01317000h
foo_unpack loaded at 01340000h - 0136E000h
Stack dump analysis:
Address: 00E21A00h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E04259h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E29428h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E20E10h, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 00E0B87Dh, location: "foo_uie_lyrics", loaded at 00DE0000h - 00E41000h
Address: 7C92EE00h, location: "ntdll", loaded at 7C920000h - 7C9B4000h
Symbol: "strchr" (+000000FFh)
Address: 77DD7BAEh, location: "ADVAPI32", loaded at 77DA0000h - 77E49000h
Symbol: "IsTextUnicode" (+0000A5B1h)
Address: 7DB22846h, location: "SHELL32", loaded at 7D590000h - 7DD82000h
Version info:
foobar2000 v0.9.4.4
UNICODE
How do I get it so that it will only load a .LRC or .TXT if it has the same filename as the current track, and so that it will also save the downloaded track with the same filename?
edit: Actually, thinking about it, that will stuff up all the .flac and .cue album rips. Is it possible to get it to append a track number in those cases only?
One more edit:
Doesnt seem to handle negative timestamps like you get when you have moved the offset then sync some lines at the start of the song in minilyrics...
Artist: H.I.M
Album:
Title: gone with the sin (Radio Edit)
By:
Offset: -40500
[00:-38.-21]ohh... my Baby,
[00:-34.-43]how beautiful you are
[00:-28.-76]ohh...my Darling,
[00:-23.-79]completely torn apart
[00:-19.-21]
[00:-18.-53]You're gone with the sin my Baby
[00:-13.-50]and beautiful you are
[00:-8.-17]so gone with the sin my Darling
[00:00.-95]
[00:02.39]I love your skin oh so white
[00:12.15]I love your touch cold as ice
[00:23.15]And I love every single tear you cry
[00:32.46]I just love the way you're losing your life
[00:40.48]
becomes
[ar:HIM]
[ti:gone with the sin]
[offset:-40499]
[00:40.47][01:23.95][02:05.93][02:46.43][02:52.21][02:59.09][03:07.52][04:11.39]
[00:43.73][02:07.45][03:31.36]ohh... my Baby,
[00:48.37][02:12.03][03:35.99]how beautiful you are
[00:53.87]ohh...my Darling,
[00:59.01][02:22.63][03:46.67]completely torn apart
when I copy it back out (trimmed for shortness here) and the starting lines dont show in the panel
Where does lyrics come from ? Is it possible to upload quickly modified lyrics ?
There is one more feauture, that I'm missing right now.
Imagine this situation: mp3 tagged with a non timestamped lyric
Could you add an option, so that your plugin automatically searches for a timestamped lyric and replaces the non timestamped lyric if one is found and otherwise continues to show the non timestamped one?
I hope my english is understandable.
I save lyrics in files.
When there's a bracket '(' in file name (i.e. in title tag for example), content of file is deleted !
ps: this bug occurs only when file is .txt !
Edit: in fact it seems to be only when 'download automatically' option is UNcheck...
Edit2: in fact, when 'download automatically' option is UNcheck, an empty file in .txt is created and then it's impossible to keep lyrics... Boring bug.
at first: Thanks T.P Wang for the great mod of Lyrics Show!
I don't know if the fellowing bug is ever mentioned...
If i switch from an windows which overlap the lyrics panel to foobar2000, the panel render the part of the window which have overlapped foobar. its the same with context elements...
(http://img212.imageshack.us/img212/2796/foolyricsbugax0.th.jpg) (http://img212.imageshack.us/my.php?image=foolyricsbugax0.jpg)
i've seen this with the latest DEV-version. both, in PanelsUI and ColumnsUI and there even if you switch between Tabs in your columns layout.
Display settings are: enabled Transparency, scroll, fading and scoll without timestamp
bye
Would it be possible to implement hot keys, especially for "embed lyric" and "online search"? Furthermore it would be great if the window "Online Search" could be active right after calling it, so that you can just hit the enter key to start the search. Or even better, if the search would start right after hitting a hot key. Thank you in advance for considering.
Thanx again for your great work and the improvement of the original component.
Greetings from Berlin, Germany
Feature Request:
Would it be possible to add either (or both) of the following:
1. Before the next line is highlighted in a stamped set of lyrics, would it be possible to flash the currently highlighted lyrics another color a user set time before going to the next set of lyrics?
For example:
[01:39:17]LINE 1
[01:42:12]LINE 2 <-- Currently playing line will flash GREEN 1 second before going to "LINE 3"
[01:53:67]LINE 3
[01:57:03]LINE 4
2. Having the option to ONLY flash another color if the distance between LINE 1 and LINE 2 is greater than 5 seconds (of course, having this time span definable would be nice).
I think this would be great for people who want to sing along to their songs. Especially when there are lyrics, then an instrument break, then more lyrics. Sometimes you don't quite know when the next set of lyrics are going to start until they actually do.
This is different than highlighting because highlighting lights them up AS they are playing, while this flashing will light up a user set time limit BEFORE the lyrics are sung. It will get the flash time based on the current stamp. It will subtract the user inputted time from the stamp and flash.
Hopefully this makes sense .
Fixed in the latest DEV release.
And the source is updated(and no secret in the source)
Added in the Latest release. You can find them in the Mainmenu -> File. And/Or bind hotkeys in fb2k's preferences page.
bye
I've just improved some code in the latest DEV release, you can try it and see if this occurs again, thanks.
When the problem occurs, have you tried visiting www.viewlyrics.com:1212 ?
I am now writting a standalone tool for downloading and uploading lyrics, I hope it will help after I release it.
Sorry, I'll check the code later.
Thank you for creating that.
I hope lyric show panel plugin can coorperate with your program. Any suggestion?
file location: E:\LocalUser\Gongqing\File\Personal\??\????????flash8?\start.mp3
Sorry I can't help because I cannot reproduce it.
One more edit:
Artist: H.I.M
Album:
By:
Offset: -40500
[00:-19.-21]
[00:00.-95]
[00:40.48]
becomes
[ar:HIM]
[offset:-40499]
1. Pardon? I think the Setting->Lyric file name and Online search->Save format is enough. And lyric show panel doesn't ingore the subsong index.
2. I'll fix the bug in negative number.
The same as minilyrics, I'll provide a 3rd party tool later to upload lyrics.
Nice idea, I'll add it in the next DEV release.
Try latest DEV release, I hope it works for you.
Feature Request:
For example:
[01:39:17]LINE 1
[01:53:67]LINE 3
[01:57:03]LINE 4
I have one question:
What does "flash" mean?
I think fading effect between current active line and upcoming active line will be nice?
By "flash" I mean the following:
LINE 1 is currently being sung, and it is lit up in BLUE. Before LINE 2 is highlighted, LINE 1 will turn GREEN for a set amount of time indicating that the next line is about to be highlighted. So it will kind of "flash" GREEN for a second or so, then go on to LINE 2.
And yeah fading between the lines would be pretty cool too! That might work just as well (and would probably look nicer!)
Thanks for the menu entries. Thats very nice!
I have a little bug with the last dev, the edge style doesnt work anymore. It always is "None". I see the correct edge style while resizing foobar but when i stop goes back to None.
Thanks for all your great work
Big crash when I've selected "Adjust offset" on context menu. I've chosen delay, press OK and... crash.
Latest dev version.
Hum, in fact, I have a lot of crashes (http://pirlouy42.free.fr/Foobar2000/Crashs/). I just have to change song and there's a crash. :/
Latest dev version.
I found the bug, I'll fix it soon.
First, I want to admit that it's one of the best (and extremely useful for me) plugins for Foobar. And I want to say "Thank you a lot!" to its author.
And I want to ask 2 questions which (maybe) help making it better - who knows?
1) The most preferrable text align for me is "Center Left". But in some cases when lyrics consists of LONG lines of text, the endings of each line are cut off completely and I can't see them at all. Wouldn't it be better to do some word wrap in this case? Example:
now:
| This is the 1'st extremely long lyr|
| This is the 2'nd extremely long lyr|
proposed:
| This is the 1'st extremely long |
| lyrics line. |
| This is the 2'nd extremely long |
| lyrics line. |
2) I can't understand why simple lyrics displaying "eats" such a huge amount of processor resources. If I look in Process Explorer (or Task Manager, it doesn't matter), I see that foobar2000.exe process uses about 1.96 ... 3.4 percent of CPU. If I turn Lyrics Show Panel off completely (for example, use exactly the same ColumnsUI layout, but without this panel), I can't see CPU using at all (and it's true cause foobar itself "eats" extremely low CPU rescources)!
"Fading" is turned off in settings. Is it normal that simple "show lyrics" plugin uses at least 3 times more CPU time than complete foobar player itself with some additional plugins (album art, track info etc)?
The lyrics panel is creating lots and lots of empty 0kb files for songs that I don't have a lyric for.
My settings for the panel on the internet page is all the boxes unchecked, save scheme: Save to my own directory.
Using Version:
Build on: Sep 16 2007 08:44:03
With Panel API version: 6.1
now:
proposed:
| lyrics line. |
| lyrics line. |
1. It's a bug, I'll fix it. Thanks for reporting.
2. It takes CPU time so much because the lyric show is lack of cache management, and scroll and paint lyric on the panel every 50ms. It will take even more CPU time if you enable "transparent".
Using Version:
Latest DEV release was built on Oct 14th, you can get it in the here (http://www.hydrogenaudio.org/forums/index.php?act=ST&f=42&t=55691&st=0)(I haven't update the thread content).
http://pastebin.com/m52c71416 (http://pastebin.com/m52c71416)
Latest DEV Version crashes (didn't get a chance to test if the 0kb files were still being created).
edit: Updated to latest columns UI version (0.2 final), still crashing..
@n0obie4life: You have exactly the same problem as the one I've described earlier.
@pirlouy,
Just noticed when I viewed the previous page . I removed the plugin in the meantime.
Thank you for your answer, looking forward for new test version!
And about 2'nd item: maybe it would be valuable implementing some tuned option in plugin settings where user is able to set refresh time in milliseconds (50 by default)? If it reduces CPU usage, some people would like to make their own decision (what do they want more - smoother scrolling or lower CPU usage).
It's just an idea - I like this plugin much without it even!
@pirlouy,
I've just changed some codes, I hope it will not crash again, try the new version(0.3.1.1b8 DEV [Oct 16 2007 - 12:57:44]).
Yes, I'll add a configuration page to customize.
Hello,
Its still crashing.
http://pastebin.com/m582a4c0e (http://pastebin.com/m582a4c0e)
Hello,
Its still crashing.
Can you provide more info about crash?
Such as:
Did it crash as soon as you play a song?
Which filetype of music were you listening?
Hello,
It crashed when I started foobar and when foobar starts playing a song (thats because I start with the playpause switch). I was playing a Chinese MP3 Song.
edit: My guess is that it would have been something to do with reading the lyrics file, not quite sure about that. I'm using Windows Vista too if that matters.
Seems last version (from october, 16th) has some problems with lyrics embedding. I have "Save scheme" preference set as "Embed to file (may slow)", but it doesn't save at all. Context menu "Update Tags" is always disabled and shows "(0)".
Btw, option "If embed" in settings now is always disabled too. I returned back to DEV copy created at Oct, 14th for a while, it works fine...
Hello,
I've changed some codes in the latest DEV. If you see some error dialog box, please post the error message here, and I'll try out find out where the problem is.
It's fixed in the latest DEV, thanks.
The problem plukin already reported still exists and it already existed in the original version. Lyric Show seems to have big problems with tabs. For me the following is reproducable: Put lyric show in a tabstack -> activate another tab of that stack -> restart foobar -> although lyric show is not the active tab you will see the display of it. After activating the lyric show tab the things are alittle bit better but sometimes still some problems occur: the context menu of lyric show appears in other tabs when rightclicked; when you resize the tabstack manually the display of lyricshow is visible in other tabs; foobars context menu is sometimes appearing and sometimes not in lyricshows contextmenu.
Hello,
Its still crashing .
http://pastebin.com/m5ba6fa7d (http://pastebin.com/m5ba6fa7d)
(I found out the cause of the crash, its because of panels_ui....)
It's improved in the lastest DEV release but still has that problem. If that displaying problem occurs, try to right click on the panel -> Reload lyric.
I've just fix many things related to tab stack.
Try the latest DEV release.
In fact, foobar context menu will only appear when current playing track is not stop.
Thank you for adding my feature request!
edit: Foobar is crashing for me since activating the "automatically replace nontimestamped lyrics"-option. It crashes randomly after several songs. No crashlog, but rather an Fatal exception. When is the Tag written / File saved? My experience is, that this is only done once after a bunch of played songs.
it would be nice if the user could decide whether the plugin takes the highline or the normal color for the lyrics if there is no timestamp, because i don't like to have the lyrics in the highline color although some people might like it.
I have a suspicion that in my case Lyrics Show doesn't save lyrics automatically. My settings at "Internet" tab are:
Download automatically: *checked*
ARTIST filter: *checked*
Only download *.lrc: *NON-checked*
Replace nontimestamped: *checked*
Save scheme: Embed to file (may slow)
If embed: (it doesn't matter which option is selected here, I tried every one)
So, when I start playing track which has no embedded lyrics, plugin searches text in Interned (and does it great) and displays it. Moreover, context menu "Update tags" becomes enabled and shows the real number of lyrics which had been downloaded but weren't saved yet. Excellent!
But in overwhelming majority of cases I forget to press "Update tags" before quitting Foobar and - SIC! - all my lyrics has gone! Next time I decide to play those tracks again, Lyrics Show will have to search Internet again and again...
Is it possible to have some option which, if set, forces plugin to save (actually embed) downloaded lyrics IMMEDIATELY after downloading? And (if possible, of course) another state of same option which, if set, forces Lyrics Show to save ALL downloaded lyrics (waiting as "Update tags" menu) before quitting foobar?
Maybe I simply haven't found the way to do things mentioned above in the existing version of plugin, then I will be thankful if you show me the way how to configure it right way.
EDIT: I made quick test and found that DEV version from September, 16th does save all downloaded lyrics before quitting foobar (exactly as I wrote in 2'nd option behavior). But all latest versions (Oct, 14th; Oct, 16th and Oct, 17th) seem having a "bug" and don't save lyrics until I press "Update tags" directly.
Hello T.P. Wang!
The problem with the tabstack still occurs even if transparent background is disabled. In fact it became a little bit stranger: Now it depends of wich panel is active if Lyric Show is visible or not.
I'll add an option to choose that later.
The earlier versions can do this but problematic, as described here (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=55692&view=findpost&p=508927)
Hello T.P. Wang!
You can try to put a Vertical/Horizontal Splliter into the tab stack and place lyric show panel into the vertical/horizontal splliter.
I've just fix some bugs that crashes foobar in ..0.3.1.1b8 DEV [Oct 17 2007 - 16:29:26]..
But if that problem still occurs, please post the exception information here if the expection is not related to memory access violation and no crashlog.
Hello,
(I found out the cause of the crash, its because of panels_ui, please fix this because it was working before I updated to one of your dev versions).
Hi, I think you missed my reply..
I have had this issue with last few dev builds and am wondering if it is something I can adjust in the settings (or if it is a bug that can be fixed).
When a song starts the Text starts centered in the panel, jumps to the top of the panel and then jumps back down to the center.
i.e.
(a song WITHOUT Lyrics is easier to explainn)
I get "Lyric Show" centered (top-to-bottom) in the panel.
The "Formatting string for lyrics not found" text jumps to the top of the panel and then jumps back to the center.
It's the same center-top-center jumping with songs with lyrics, it's just harder to describe.
(http://www.halfbakedschemes.com/test/2.jpg)
</br>
(http://www.halfbakedschemes.com/test/3.jpg)
I get that same jumping that nightfishing gets.
Also, I have three requests:
1. Would we be able to get some more visual options for our lyrics? Maybe glow, and blur and stuff like that? If it could even use title formatting (so we can do something like $font(#name,#size,#style [bold, underline, italic etc],#color,#options [blur, glow, alpha etc]) or something to that effect) that would be incredible. Or maybe something easier to understand such as $font(name,size), $rgb(color), $fontstyle(named above), $fonteffects(blur etc). That would be cool in my opinion. I just don't know how easy or feasible it is to do.
2. If the above doesn't pan out, having some more simple button options would be great. Currently we have:
- Font
- Normal Color
- Highline Color (and shouldn't this be highLIGHT Color)
- Background Color
I think this format would be much better (plus additons):
- Font (keep the same)
- Font Color (for NON-timestampped lyrics)
- Highlight Color (for the timestampped lines)
- Highlight Background (this one would be a color that would be in the background of the currently playing line)
- Inactive Text (when the lyrics are stamped, this would be the color of the text that ISN'T being played. That way it can be different from the regular NON-timestampped lyrics)
- Background (keep the same)
3. Would my flash (or even better your fade idea) be do able? It was a few pages back. Having the currently playing line color fade away and into the next playing line would be great.
4. When I timestamp lyrics, I don't timestamp blank lines. Example:
Line 1
Line 2
Line 3
Line 4
_______ <--- blank line thats NOT stampped.
Line 5
Line 6
Line 7
Line 8
Currently, these lines aren't displayed, but would it be possible to just show ANY lines (or at least blank ones) that don't have stamps while playing a stamped file. The scroll could just skip over them (go from line 4 to 5 ignoring the fact that the blank line is there).
Thats all I have for now .
Downloaded this and Lyrics DB
once i download the lyrics how do i use this panel?
Thanks to continue this component.
But I have a problem with all version, lyrics don’t scroll automatically. If I change focus on a different windows then go back to foobar, lyrics scroll but not in other way.
Apparently problem is known but I don’t find solution.
Foobar core : 0.9.4.5
Columns_ui : 0.2
Foo_lyricsdb : 0.0.7 beta5
Lyric_show_panel : 0.3.1.1b8 Dev
Thanks for your help about this problem.
Hello,
I'ts because of lyrics show panel, if you uncheck "automatically download".
new version which in order to fix this problem is now avaliable. (0.3.1.1b8 DEV [Oct 17 2007 - 16:29:26])
i.e.
- Font
- Normal Color
- Background Color
I can do it
It's on the scheduler, but will take some time.
Line 1
Line 2
Line 3
Line 4
Line 5
Line 6
Line 7
Line 8
Sorry, it's not possible. Because in .lrc files you can put timpstamped lines anywhere you want, and something like this [xx.xx:xx][xx.xx:xx]line
But I have a problem with all version, lyrics don't scroll automatically. If I change focus on a different windows then go back to foobar, lyrics scroll but not in other way.
Apparently problem is known but I don't find solution.
Columns_ui : 0.2
It's really strage, I'm sorry I cant help.
Columns_ui : 0.2
Isn't it a problem with timestamp encoding ?
Some exemple wich didn't work :
[ar:M]
[ti:La corde sensible]
[00:30.07][00:35.36]Impossible
[00:38.78]beaucoup
[00:40.20]trop sensible
[00:43.56]toutes ces âmes
[00:48.70]polygames
or
[ar:M]
[ti:Mon ego]
[al:Qui de nous deux]
[Encoding:iso-8859-15]
encoding: iso-8859-15
[00:00.01]Artist: Mon ego
[00:07.90]Title: M
[00:15.80]Album: Qui de nous deux
[00:31.45] Number one j’me cramponne
[00:34.77]Comme une icône à la con
[00:38.37]Avec un look en aluminium
[00:41.41]Un minimum, un minimum
Thanks for help me.
Columns_ui : 0.2
[ar:M]
[00:38.78]beaucoup
[00:48.70]polygames
or
[ar:M]
[ti:Mon ego]
[00:07.90]Title: M
[00:31.45] Number one j'me cramponne
Thanks for help me.
They work.
Just check your lyric show panel options.
And rember the order of lyrics to be loaded:
Embed -> Association -> lyrics dir -> Local search -> Online search
Hello,
I'm already running the panel with "Lyric Show Panels 0.3.1.1b8 DEV [Oct 17 2007 - 16:29:26] (foo_uie_lyrics)".
The download automatically option is already unchecked.
Hello,
Sorry, my fault,
The latest is
0.3.1.1b8 DEV [Oct 19 2007 - 19:56:27]
The bug was fixed in that build.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0077006Fh
Access violation, operation: write, address: 00E60040h
Call path:
entry=>app_mainloop=>threaded_process::run_modal=>threaded_process::run_modal
Code bytes (0077006Fh):
0077002Fh: 00 00 00 00 00 08 00 00 00 06 00 00 00 00 00 00
0077003Fh: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 25 6E
0077004Fh: BC 60 96 6F BC 00 00 00 00 00 00 00 00 00 00 00
0077005Fh: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0077006Fh: 00 0C 00 0C 00 00 01 08 00 77 0A 4E 00 01 00 00
0077007Fh: 00 00 00 00 00 08 85 28 85 78 00 6E BC 01 00 00
0077008Fh: 00 00 00 00 00 08 00 00 00 06 00 00 00 00 00 00
0077009Fh: 00 00 00 00 00 00 00 00 00 00 00 00 00 20 BC 74
Stack (0012E954h):
0012E934h: 00000000 00000000 00000000 00000000
0012E944h: 00000000 00000000 00000000 00000000
0012E954h: 0043C0A7 020C4DC8 068F52B8 068F52B8
0012E964h: 0000000A 004C2240 0012E9D0 00000000
0012E974h: 004DEB6C 020C4DC8 0000000A 0012E9F4
0012E984h: 004AF8E1 00000001 004DEB7C 01CE3488
0012E994h: 0112E950 0012E9D0 07612E18 020C4DB0
0012E9A4h: A855A7E6 020487D6 020487B0 0012EA04
0012E9B4h: 07631B00 004DEB7C FFFFFFFF 7C92056D
0012E9C4h: 01CFF2FF 01D1ABD4 07658008 01D1ADBC
0012E9D4h: 07637CB8 0000000A 00000010 01D1B608
0012E9E4h: 07655720 0000000A 00000010 0012EA2C
0012E9F4h: 0012EA2C 01D156C8 00000003 01CFF31E
0012EA04h: 0012EA5C 01CE3009 A855A45E 07643FE0
0012EA14h: 02048728 01DD5074 00000008 00000000
0012EA24h: 01D1ABD4 07631B60 0012EAA4 01D15900
0012EA34h: FFFFFFFF 01CD9854 0012EA5C 075FBFE8
0012EA44h: A855A406 0000040E 07643FE0 0012EC20
0012EA54h: 01DD5074 00000000 02048728 00000000
0012EA64h: 0000003A 0012EA84 7E36B3F9 005002EC
Registers:
EAX: 00730020, EBX: 00000000, ECX: 07612E18, EDX: 07612E18
ESI: 00000004, EDI: 0012E9E0, EBP: 0012E98C, ESP: 0012E954
Unable to identify crash location
Loaded modules:
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C907000h
COMCTL32 loaded at 773A0000h - 774A3000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4A000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7C9D0000h - 7D1EF000h
ole32 loaded at 774B0000h - 775ED000h
COMDLG32 loaded at 76350000h - 7639A000h
IMM32 loaded at 76330000h - 7634D000h
MSCTF loaded at 746A0000h - 746EC000h
lgscroll loaded at 10100000h - 1010F000h
MSVCR80 loaded at 78130000h - 781CB000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
NTMARTA loaded at 77660000h - 77681000h
WLDAP32 loaded at 76F20000h - 76F4D000h
SAMLIB loaded at 71B70000h - 71B83000h
msctfime loaded at 75250000h - 7527E000h
foo_burninate loaded at 00A40000h - 00A77000h
VERSION loaded at 77BD0000h - 77BD8000h
foo_cdda loaded at 00AA0000h - 00AD5000h
foo_channel_mixer loaded at 00B00000h - 00B3B000h
foo_common loaded at 00B50000h - 00B83000h
foo_cwb_hooks loaded at 00C40000h - 00C8D000h
foo_dbsearch loaded at 00CB0000h - 00D20000h
OLEAUT32 loaded at 770F0000h - 7717B000h
foo_DeleteCurrent loaded at 00D40000h - 00D60000h
foo_dsp_crossfader loaded at 00D70000h - 00DD0000h
libmmd loaded at 00DE0000h - 01091000h
foo_dsp_skip_silence loaded at 010B0000h - 010C3000h
foo_dsp_std loaded at 010E0000h - 01121000h
foo_freedb2 loaded at 01150000h - 01190000h
foo_input_mslive loaded at 011B0000h - 01227000h
WMVCore loaded at 15110000h - 1536A000h
WMASF loaded at 11C70000h - 11CA9000h
foo_input_std loaded at 01240000h - 01358000h
foo_input_tak loaded at 01380000h - 013C7000h
tak_deco_lib loaded at 013E0000h - 01411000h
foo_lyricsdb loaded at 01540000h - 0156F000h
WININET loaded at 441E0000h - 442AF000h
Normaliz loaded at 01580000h - 01589000h
iertutil loaded at 43F60000h - 43FA5000h
foo_masstag loaded at 017B0000h - 01800000h
foo_osd loaded at 01820000h - 01854000h
gdiplus loaded at 4EBA0000h - 4ED43000h
foo_playcount_mod loaded at 01890000h - 018A5000h
foo_playlist_tree loaded at 018C0000h - 01936000h
libmzsch360_000 loaded at 10400000h - 105D0000h
WSOCK32 loaded at 71A30000h - 71A3A000h
WS2_32 loaded at 71A10000h - 71A27000h
WS2HELP loaded at 71A00000h - 71A08000h
libmzgc360_000 loaded at 01960000h - 01A04000h
foo_popupplus loaded at 01A50000h - 01A9E000h
RICHED20 loaded at 74DB0000h - 74E1C000h
foo_pqview loaded at 01AB0000h - 01ACB000h
foo_preview loaded at 01AF0000h - 01B11000h
foo_removefromqueue loaded at 01B30000h - 01B3A000h
foo_rgscan loaded at 01B50000h - 01B98000h
foo_run loaded at 01BC0000h - 01BEB000h
foo_sendtodevice loaded at 01C10000h - 01C4D000h
foo_uie_albumart loaded at 01C70000h - 01CAC000h
foo_uie_lyrics loaded at 01CD0000h - 01D33000h
WINMM loaded at 76AF0000h - 76B1E000h
foo_ui_columns loaded at 01DE0000h - 01EA6000h
foo_ui_egoh2 loaded at 01ED0000h - 01F01000h
UxTheme loaded at 5B0F0000h - 5B128000h
foo_ui_std loaded at 01F20000h - 01F76000h
foo_utils loaded at 01FA0000h - 01FD8000h
dciman32 loaded at 73B30000h - 73B36000h
msimg32 loaded at 76320000h - 76325000h
DSOUND loaded at 73E70000h - 73ECC000h
Secur32 loaded at 77FC0000h - 77FD1000h
WINTRUST loaded at 76BF0000h - 76C1E000h
CRYPT32 loaded at 77A50000h - 77AE5000h
MSASN1 loaded at 77AF0000h - 77B02000h
IMAGEHLP loaded at 76C50000h - 76C78000h
wdmaud loaded at 72C90000h - 72C99000h
RASAPI32 loaded at 76EA0000h - 76EDC000h
rasman loaded at 76E50000h - 76E62000h
NETAPI32 loaded at 597D0000h - 59825000h
TAPI32 loaded at 76E70000h - 76E9F000h
rtutils loaded at 76E40000h - 76E4E000h
msv1_0 loaded at 77C40000h - 77C63000h
iphlpapi loaded at 76D20000h - 76D39000h
USERENV loaded at 76620000h - 766D5000h
sensapi loaded at 72240000h - 72245000h
msacm32 loaded at 72C80000h - 72C88000h
MSACM32 loaded at 77BB0000h - 77BC5000h
midimap loaded at 77BA0000h - 77BA7000h
mswsock loaded at 719B0000h - 719F0000h
rasadhlp loaded at 76F80000h - 76F86000h
KsUser loaded at 73E40000h - 73E44000h
DNSAPI loaded at 76EE0000h - 76F07000h
winrnr loaded at 76F70000h - 76F78000h
wshbth loaded at 750F0000h - 7510E000h
SETUPAPI loaded at 778F0000h - 779E4000h
urlmon loaded at 442C0000h - 443E4000h
w2pxdrv loaded at 06110000h - 0613E000h
hnetcfg loaded at 66710000h - 66769000h
wshtcpip loaded at 719F0000h - 719F8000h
jsproxy loaded at 44150000h - 4415A000h
CLBCATQ loaded at 76F90000h - 7700F000h
COMRes loaded at 77010000h - 770E3000h
jscript loaded at 63380000h - 633F8000h
xpsp2res loaded at 20000000h - 202D9000h
advancedautoaway loaded at 11BD0000h - 11BE3000h
btkeyind loaded at 01690000h - 0169F000h
DBGHELP loaded at 59DD0000h - 59E71000h
Address: 0043C0A7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2240h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DEB6Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF8E1h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DEB7Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01CE3488h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 01CFF2FFh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D1ABD4h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D1ADBCh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D1B608h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D156C8h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CFF31Eh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CE3009h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D15900h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CD9854h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D159A0h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CD8949h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01E073C0h, location: "foo_ui_columns", loaded at 01DE0000h - 01EA6000h
Address: 01E08EB0h, location: "foo_ui_columns", loaded at 01DE0000h - 01EA6000h
Address: 77F10D30h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "DdEntry19" (+0000001Ah)
Address: 77EF9180h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "SetDIBitsToDevice" (+00000174h)
Address: 01ED5B33h, location: "foo_ui_egoh2", loaded at 01ED0000h - 01F01000h
Address: 7E38E175h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 7E38E152h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 01CE5F40h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Symbol: "GetWindowLongW" (+0000002Bh)
Symbol: "GetWindowLongW" (+00000034h)
Address: 01D15A33h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Symbol: "SetWindowLongW" (+00000000h)
Address: 01CE5F8Ch, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E373512h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 7E3693E9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PeekMessageW" (+0000014Eh)
Address: 7E3693A8h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PeekMessageW" (+0000010Dh)
Address: 7E369402h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PeekMessageW" (+00000167h)
Address: 7E37DAAFh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallMsgFilterW" (+00000103h)
Address: 7E37593Fh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DrawStateW" (+000001F2h)
Address: 7E375981h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DialogBoxIndirectParamAorW" (+00000036h)
Address: 004F061Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00486640h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7E37559Eh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DialogBoxParamW" (+0000003Fh)
Address: 00486618h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045DD6Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF588h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C4418h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE940h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0424h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BFB44h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A0001h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01000000h, location: "libmmd", loaded at 00DE0000h - 01091000h
Symbol: "_csqrtq_f90" (+0021D6C4h)
Address: 00470E00h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D201h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C4440h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AC796h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004796F7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BCC68h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6598h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043BF8Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF431h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043C03Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00438A70h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2AC4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01CD8AE0h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 7E36F808h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 7E36F94Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 746B1031h, location: "MSCTF", loaded at 746A0000h - 746EC000h
Symbol: "TF_UninitSystem" (+00000970h)
Address: 7E36F819h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 7E3688E0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 7E373794h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+00000301h)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7E36F805h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 01EEFBF8h, location: "foo_ui_egoh2", loaded at 01ED0000h - 01F01000h
Address: 10107B16h, location: "lgscroll", loaded at 10100000h - 1010F000h
Symbol: "UninstallScrollHooks" (+000011F6h)
Address: 77EF5A0Eh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GdiReleaseDC" (+00000018h)
Address: 7E3684B2h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3686BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ReleaseDC" (+00000021h)
Address: 01ED6943h, location: "foo_ui_egoh2", loaded at 01ED0000h - 01F01000h
Version info:
foobar2000 v0.9.4.5
UNICODE
Windows 5.1
Additional info:
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00] (foo_cwb_hooks)
Columns UI 0.2 (foo_ui_columns)
FooBar2000 Delete Current Track 1.0.0.0 (foo_DeleteCurrent)
Preview 1.2 (foo_preview)
FLAC Decoder 1.1.0 (foo_input_std)
Playlist Tree Panel 3.0.4 [Aug 2 2007 - 10:16:21] (foo_playlist_tree)
Playlist Tools 0.5.9 (foo_utils)
Skip silence 0.1 (Intel SSE) (foo_dsp_skip_silence)
Converter 1.0.1 (foo_converter)
Standard Input Array 1.0 (foo_input_std)
Channel Mixer 0.9.6.2 (foo_channel_mixer)
Send to Device 1.1.1 [Sep 7 2007 - 10:34:03] (foo_sendtodevice)
Masstagger 1.6 (foo_masstag)
PopUp Plus 20070903 (foo_popupplus)
Play Count Mod 1.0.2 (foo_playcount_mod)
WMA Decoder 1.1 (foo_input_std)
Lyric Show Panels 0.3.1.1b8 DEV [Oct 19 2007 - 19:56:27] (foo_uie_lyrics)
mslive 0.3.9 (Intel SSE) (foo_input_mslive)
freedb Tagger 0.5.2a (foo_freedb2)
foo_lyricsdb 0.0.7 beta 5 (foo_lyricsdb)
Remove from Queue 1 (foo_removefromqueue)
Audio CD Writer 2.0.1 (foo_burninate)
foobar2000 core 0.9.4.5 (Core)
TAK Decoder 0.3.2 (foo_input_tak)
Gapless Crossfader 0.3.3.3 (Intel SSE) (foo_dsp_crossfader)
egoh user interface 2.0.0 (foo_ui_egoh2)
Common services 0.1 (foo_common)
On-Screen Display GDI+ 1.52 (foo_osd)
cwbowron's title format hooks 1.2.5 [Jun 8 2007 - 08:49:42] (foo_cwb_hooks)
While running foo_preview in order to get timestamped lyrics.
edit: some more:
[codebox]Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C9211DEh
Access violation, operation: read, address: 00000002h
Call path:
Code bytes (7C9211DEh):
7C92119Eh: 97 00 00 00 C1 E9 10 81 E1 FF 00 00 00 0F 84 05
7C9211AEh: FB FF FF 0F BE 81 58 10 92 7C 83 C0 10 8D 04 C2
7C9211BEh: 89 45 D8 8B 70 04 83 EE 08 89 75 C8 8D 4E 08 8B
7C9211CEh: 39 89 BD 0C FF FF FF 8B 46 0C 89 85 68 FF FF FF
7C9211DEh: 8B 10 3B 57 04 0F 85 8C 31 02 00 3B D1 0F 85 84
7C9211EEh: 31 02 00 89 38 89 47 04 3B F8 0F 85 48 02 00 00
7C9211FEh: 0F B7 0E 8B C1 C1 E8 03 89 85 28 FF FF FF 83 E1
7C92120Eh: 07 33 D2 42 D3 E2 89 95 04 FF FF FF 8D 84 18 58
Stack (0012ECFCh):
0012ECDCh: 00000000 00000000 00000000 00000000
0012ECECh: 00000000 00000000 00000000 00000000
0012ECFCh: 00000007 00000000 7C9205D4 7C91EE18
0012ED0Ch: 7C91FB78 FFFFFFFF 7C927BF5 01DD0608
0012ED1Ch: 7C927BB0 00000002 00000002 01DD0228
0012ED2Ch: 7FFDF000 033CED08 003C0000 00000000
0012ED3Ch: 003C0000 01DD0190 00000000 0012EE14
0012ED4Ch: 7C920E91 003C0608 7C92056D 01DD0228
0012ED5Ch: 00000000 033CECF8 00000000 01DD0190
0012ED6Ch: 00000000 003C0178 01DD0188 00000000
0012ED7Ch: 00000000 003C0190 003C0000 00000000
0012ED8Ch: 03357F48 0518BF58 05181FD0 00000000
0012ED9Ch: 00000000 0518BFF0 0000000C 00000000
0012EDACh: 7C91DA54 05181560 0516ADC0 0012EE24
0012EDBCh: 0012EE28 00000000 00000014 0000000B
0012EDCCh: 035F5030 00000000 0000000C 7FFDF000
0012EDDCh: 00000004 01DD0228 01DD0288 0516ADC8
0012EDECh: 035F5030 00000002 01DD0220 01DD0228
0012EDFCh: 00000002 00000004 01DD0240 01DD0178
0012EE0Ch: 0516ADB0 0517F7A8 00000003 01DD0370
Registers:
EAX: 00000002, EBX: 01DD0000, ECX: 0516ADC8, EDX: 01DD0178
ESI: 0516ADC0, EDI: 01DD0228, EBP: 0012EF1C, ESP: 0012ECFC
Crash location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+0000074Fh)
Loaded modules:
w2pxdrv loaded at 05F00000h - 05F2E000h
btkeyind loaded at 04F80000h - 04F8F000h
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C91FB78h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlNtStatusToDosError" (+0000003Bh)
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C920E91h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000402h)
Address: 7C91DA54h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "NtFreeVirtualMemory" (+0000000Ch)
Address: 7C920D5Ch, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+000002CDh)
Address: 0116ADB0h, location: "foo_freedb2", loaded at 01150000h - 01190000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 01CFEB88h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CD117Dh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF81CEh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CE8BBEh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF803Fh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CE660Fh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF7BEBh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF7B1Eh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF6848h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 0043C09Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00C7036Ah, location: "foo_cwb_hooks", loaded at 00C40000h - 00C8D000h
Address: 004E40C0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C929079h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlpUnWaitCriticalSection" (+00000022h)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01CF7D40h
Access violation, operation: write, address: 31203244h
Call path:
Code bytes (01CF7D40h):
01CF7D00h: 89 7D 04 EB 08 89 7D 04 E8 F3 E8 FE FF 85 DB 8B
01CF7D10h: 45 00 76 19 8B 7C 24 2C 2B F8 8B F3 8D 64 24 00
01CF7D20h: 8A 0C 07 88 08 83 C0 01 83 EE 01 75 F3 8B 44 24
01CF7D30h: 18 8B 55 00 83 44 24 1C 0C 83 C0 01 3B 44 24 14
01CF7D40h: C6 04 13 00 89 44 24 18 0F 82 62 FF FF FF 8B 6C
01CF7D50h: 24 10 B8 28 00 00 00 01 44 24 20 01 44 24 24 83
01CF7D60h: C5 01 3B 6C 24 30 89 6C 24 10 0F 82 21 FE FF FF
01CF7D70h: 5F 5E 5D 5B 83 C4 24 C2 08 00 CC CC CC CC CC CC
Stack (0012EFA8h):
0012EF88h: 00000000 0012E14C 7C91EB94 BADB0D00
0012EF98h: 0020027F 077C0000 01ED58CD 7E3694AA
0012EFA8h: 0260C668 05764F68 0012F044 00000000
0012EFB8h: 00000005 00000001 00000000 0000000C
0012EFC8h: 05765034 FFFFFF38 05765040 03559C05
0012EFD8h: 0000000C 01CF7B1E 05764F6C 0260C668
0012EFE8h: 01CF6848 0260C668 00000000 0012F098
0012EFF8h: 00000005 00000005 004E2AC4 0012F038
0012F008h: 0043C09C 0043C0A7 0260C668 01DD68C8
0012F018h: 01DD68C8 0000000A 004C2240 0012F088
0012F028h: 00000000 004DEB6C 0260C668 0000000A
0012F038h: 0012F0AC 004AF8E1 00000001 004DEB7C
0012F048h: 01CE3488 0112F008 0012F088 05764F68
0012F058h: 0260C650 95325E92 0260D6BD 0260D698
0012F068h: 0012F0BC 05777800 004DEB7C FFFFFFFF
0012F078h: 7C92056D 01CFF2FF 01D1ABD4 05780FE0
0012F088h: 01D1ADBC 057796D0 0000000A 00000010
0012F098h: 01D1B608 05779718 0000000A 00000010
0012F0A8h: 0012F0E4 0012F0E4 01D156C8 00000003
0012F0B8h: 01CFF31E 0012F114 01CE3009 95325E3A
Registers:
EAX: 00000001, EBX: 00000013, ECX: 7C920634, EDX: 31203231
ESI: 00000000, EDI: FDDF4BCD, EBP: 05765040, ESP: 0012EFA8
Crash location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Loaded modules:
USER32 loaded at 7E360000h - 7E3F0000h
foo_converter loaded at 00BB0000h - 00C19000h
w2pxdrv loaded at 05E10000h - 05E3E000h
Address: 012D02F6h, location: "foo_input_std", loaded at 01240000h - 01358000h
Address: 7E36F84Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+000000C3h)
Address: 7E36F7F6h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 7E373761h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002CEh)
Address: 004DE9D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004324CDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7E3691BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetProcessWindowStation" (+00000029h)
Address: 7E3691F1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetMessageW" (+0000002Bh)
Address: 0042FFB0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002F72h, location: "shared", loaded at 10000000h - 10029000h
Address: 004C0580h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B21h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00EB037Ch, location: "libmmd", loaded at 00DE0000h - 01091000h
Symbol: "_csqrtq_f90" (+000CDA40h)
Address: 004C71D4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 004E41B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 100033F1h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uGetCallStackPath" (+00000451h)
Address: 004E3E88h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004927EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4238h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00428F90h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447DC0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049935Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497030h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0590h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002F27h, location: "shared", loaded at 10000000h - 10029000h
Address: 004AF124h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430D28h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E09B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496D1Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004920D2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004920CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B3000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF518h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004963F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.5
UNICODE
Windows 5.1
Additional info:
Code: C0000005h, flags: 00000000h, address: 7C927A8Ch
Access violation, operation: read, address: 00030035h
Call path:
entry=>app_mainloop
Code bytes (7C927A8Ch):
7C927A4Ch: 0F 85 E8 4B 03 00 8B 45 14 3D FF FF FF 7F 0F 87
7C927A5Ch: F6 4B 03 00 85 C0 0F 84 4F 4C 03 00 8B 4F 48 03
7C927A6Ch: C8 23 4F 4C 89 4D DC F7 C3 00 01 00 3C 0F 85 C8
7C927A7Ch: BD FF FF 83 BF 74 01 00 00 00 0F 85 BB BD FF FF
7C927A8Ch: F6 46 FD 02 0F 85 B1 BD FF FF 83 65 FC 00 F6 C3
7C927A9Ch: 01 75 15 FF B7 78 05 00 00 E8 5B 95 FE FF C6 45
7C927AACh: DB 01 83 F3 01 89 5D 0C C7 45 FC 01 00 00 00 83
7C927ABCh: C6 F8 89 B5 04 FF FF FF 8A 46 05 A8 01 0F 84 EE
Stack (0012F410h):
0012F3F0h: 00000000 00000000 00000000 00000000
0012F400h: 00000000 00000000 00000000 00000000
0012F410h: 00000006 00000006 00030038 00000042
0012F420h: 0347DDF0 003C0000 00000000 00000000
0012F430h: 01DD0190 7C920D5C 003C0000 7C920E91
0012F440h: 003C0608 7C92056D 00000000 00000000
0012F450h: 0347DDE8 00000000 00000004 00000000
0012F460h: 7C92056D 01DD0188 00000000 03392BB0
0012F470h: 0347DDE8 003C0000 00000000 0348C268
0012F480h: 0012F54C 00000000 00000000 00000000
0012F490h: 00000042 0000000C 03327AB8 0000023B
0012F4A0h: 00000000 0554CC58 003C0000 03327AB8
0012F4B0h: 00000000 00000014 0554BF28 03260000
0012F4C0h: 00000000 0000000C 0554CC40 0000023B
0012F4D0h: 01DD0338 01DD0178 0554CC60 05554B40
0012F4E0h: 00000007 01DD0258 01DD0338 0554BF30
0012F4F0h: 03260000 01DD0350 0000000C 0554CC48
0012F500h: 00000020 00000007 01DD0320 01DD0350
0012F510h: 00000020 00000007 00000001 01DD0360
0012F520h: 00000010 00000006 01DD0370 00000010
Registers:
EAX: 00000006, EBX: 00000000, ECX: 00000010, EDX: 0048C260
ESI: 00030038, EDI: 01DD0000, EBP: 0012F5E0, ESP: 0012F410
Symbol: "RtlReAllocateHeap" (+0000008Fh)
Loaded modules:
w2pxdrv loaded at 05F10000h - 05F3E000h
Address: 004A8CE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004ACB98h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047FC99h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C927BB8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 01CFED8Ch, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF92DDh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01D02740h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CD11E9h, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 01CF7D0Dh, location: "foo_uie_lyrics", loaded at 01CD0000h - 01D33000h
Address: 7E368B26h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E373745h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E36D62Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 00ED037Ch, location: "libmmd", loaded at 00DE0000h - 01091000h
Symbol: "_csqrtq_f90" (+000EDA40h)
Address: 7C816FF7h, location: "kernel32", loaded at 7C800000h - 7C907000h
Address: 7C839A30h, location: "kernel32", loaded at 7C800000h - 7C907000h
Address: 7C817000h, location: "kernel32", loaded at 7C800000h - 7C907000h
Address: 0049645Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01C780D6h, location: "foo_uie_albumart", loaded at 01C70000h - 01CAC000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.5
UNICODE
Windows 5.1
Additional info:
[/code
Hello,
Sorry, my fault,
The latest is 0.3.1.1b8 DEV [Oct 19 2007 - 19:56:27]
Yes! It works now .
Thank you so much! ?????
@Chaser:
Did it crash when you uncheck "Download automatically"?
@ T.P Wang:
Thank you very much for implementing my requests, your support is incredible! The "Search Online" hot key works fine, but "embed" in the main "file" menu is greyed out, so no hot key can be assigned. Nevertheless, from the context menu within the lyrics window it works. Would you be so kind and check on that?
Thanx again for your great work.
Have a nice week,
Greetinx from Berlin, Germany
Anandamid
Hello T.P. Wang!
Now it works without any problem!
I have a question that many devs will hear in next time: Do you plan to create an UI-element for the new DefaultUI when it is possible?
+1 ^^ .. This is one of the components that I miss in the new UI. So pleaaaaaaaaase modify it to support the setup.
Haven't checked your proposal. But what I'm quite sure about is, that it crashes, as soon as it has 10 new lyrics cached and starts to tag the corresponding files.
That's why my guess is, it stops crashing, if I stop downloading lyrics.
For those who miss panel components not yet ported to the default ui, foo_dockable_panels (http://www.bazquux.com/wiki/Foobar2000%3a%44ock) might be a good temporary workaround.
(http://www.halfbakedschemes.com/test/lyrics2.jpg) (http://www.halfbakedschemes.com/test/lyrics.jpg)
One click and the lyrics collapses and I have my facets view back.
Is there anyway that you can recode the internet search to work on LyricWiki (lyricwiki.org, general page format is [[artist:song]])? Because I can't find any of my songs on whatever database this plugin is using right now.
great
love this component
but to me it doesn't embed to file
i select
save scheme 1) embed to file
2) if embed fails save ....
why does the component to me never embed lyrics to files?
is there some option to enable?
franesco:
It saves the tags to file after 10 new lyrics. Make a rightclick on the lyrics-viewer.
For me it however still randomly crashes (I think it is this component). You may take a look at the picutre: (http://img215.imageshack.us/img215/3799/zwischenablage1ll2.th.jpg) (http://img215.imageshack.us/my.php?image=zwischenablage1ll2.jpg)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01BE685Ch
Access violation, operation: read, address: 0000000Ah
Call path:
entry=>app_mainloop
Code bytes (01BE685Ch):
01BE681Ch: 5E 5D 5B 59 C2 08 00 CC CC CC CC CC CC CC CC CC
01BE682Ch: CC CC CC CC 83 EC 10 56 57 8B 7C 24 1C 8B F1 3B
01BE683Ch: FE 74 43 8B 06 8B 50 58 53 57 FF D2 8B 06 8B 50
01BE684Ch: 5C 57 8B CE FF D2 8B 07 8B 10 8B 1E 8B CF FF D2
01BE685Ch: 8B 43 04 83 EC 08 8B CE DD 1C 24 FF D0 8B 17 8B
01BE686Ch: 52 0C 8B 1E 8D 44 24 0C 50 8B CF FF D2 50 8B 43
01BE687Ch: 08 8B CE FF D0 5B 5F 5E 83 C4 10 C2 04 00 CC CC
01BE688Ch: CC CC CC CC 8B 06 8B 40 50 51 52 8B CE FF D0 83
Stack (0012F6CCh):
0012F6ACh: 00000000 00000000 00000000 00000000
0012F6BCh: 00000000 00000000 00000000 00000000
0012F6CCh: 00000000 0012F778 00000006 00000006
0012F6DCh: 004F0FA0 0012F718 0043A4AA 0043A4B5
0012F6ECh: 003CF818 05008438 05008438 0000000A
0012F6FCh: 004CC338 0012F768 004ED8CC 003CF818
0012F70Ch: 01EE7E98 003CF800 004ED8DC 0012F78C
0012F71Ch: 004B7902 00000001 004ED8DC 01BD3488
0012F72Ch: 0112F6E4 0012F768 00000000 0000000A
0012F73Ch: D531E71F 021B2B25 021B2AD8 0012F79C
0012F74Ch: 01EE8D00 004ED8DC FFFFFFFF 7C92056D
0012F75Ch: 01BEF2FF 01C0ABD4 0501ABC0 01C0ADBC
0012F76Ch: 0501A428 0000000A 00000010 01C0B608
0012F77Ch: 0501A3E0 0000000A 00000010 0012F7C4
0012F78Ch: 0012F7C4 01C056C8 00000003 01BEF31E
0012F79Ch: 0012F7F4 01BD3009 D531E7F7 04FF6BA8
0012F7ACh: 021B2A40 01EE4FA4 00000008 00000000
0012F7BCh: 01C0ABD4 01EE8DB8 0012F83C 01C05900
0012F7CCh: FFFFFFFF 01BC9854 0012F7F4 05009908
0012F7DCh: D531E7BF 0000040E 04FF6BA8 0012F9BC
Registers:
EAX: 004CBF98, EBX: 00000006, ECX: 003CF818, EDX: 00437FFE
ESI: 01EE7E98, EDI: 003CF818, EBP: 0012F724, ESP: 0012F6CC
Crash location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Loaded modules:
foobar2000 loaded at 00400000h - 0050A000h
shared loaded at 10000000h - 1002D000h
foo_albumlist loaded at 00A50000h - 00AA5000h
foo_burninate loaded at 00AD0000h - 00B07000h
foo_cdda loaded at 00B30000h - 00B63000h
foo_channel_mixer loaded at 00B90000h - 00BCB000h
foo_converter loaded at 00BE0000h - 00C51000h
foo_dbsearch loaded at 00C80000h - 00CF0000h
foo_DeleteCurrent loaded at 00D10000h - 00D30000h
foo_dsp_crossfader loaded at 00D40000h - 00D9E000h
libmmd loaded at 00DB0000h - 01061000h
foo_dsp_std loaded at 01080000h - 010C7000h
foo_fileops loaded at 010F0000h - 01137000h
foo_freedb2 loaded at 01160000h - 011A1000h
foo_input_mslive loaded at 011D0000h - 01253000h
foo_input_std loaded at 01270000h - 01393000h
foo_input_tak loaded at 013C0000h - 01407000h
tak_deco_lib loaded at 01420000h - 01451000h
foo_masstag loaded at 01580000h - 015D0000h
foo_osd loaded at 015F0000h - 01624000h
foo_playcount_mod loaded at 01660000h - 01675000h
foo_playlist_tree loaded at 01690000h - 01706000h
libmzgc360_000 loaded at 01730000h - 017D4000h
foo_popupplus loaded at 01820000h - 018B7000h
foo_pqview loaded at 018E0000h - 01908000h
foo_preview loaded at 01930000h - 01951000h
foo_quicktag loaded at 01970000h - 019AE000h
foo_rgscan loaded at 019D0000h - 01A16000h
foo_run loaded at 01A40000h - 01A6B000h
foo_sendtodevice loaded at 01A90000h - 01ACD000h
foo_uie_albumart loaded at 01AF0000h - 01B2D000h
foo_uie_albumlist loaded at 01B50000h - 01B93000h
foo_uie_lyrics loaded at 01BC0000h - 01C23000h
Normaliz loaded at 01C40000h - 01C49000h
foo_uie_typefind loaded at 01EF0000h - 01F20000h
foo_ui_columns loaded at 01F40000h - 02024000h
foo_ui_egoh2 loaded at 02050000h - 02081000h
foo_ui_std loaded at 020A0000h - 02156000h
MSIMG32 loaded at 76320000h - 76325000h
SXS loaded at 76970000h - 76A21000h
DWSPY32 loaded at 42000000h - 42027000h
MFC40 loaded at 61ED0000h - 61FB7000h
MSVCRT40 loaded at 78080000h - 78091000h
MFC40LOC loaded at 61EC0000h - 61ECE000h
btkeyind loaded at 04FE0000h - 04FEF000h
w2pxdrv loaded at 05BC0000h - 05BEE000h
Address: 004F0FA0h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0043A4AAh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0043A4B5h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004CC338h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004ED8CCh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004ED8DCh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B7902h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 01BD3488h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 01BEF2FFh, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C0ABD4h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C0ADBCh, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C0B608h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C056C8h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01BEF31Eh, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01BD3009h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C05900h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01BC9854h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Symbol: "strchr" (+00000117h)
Address: 01C059A0h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01BC8949h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 7E36F95Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 02056943h, location: "foo_ui_egoh2", loaded at 02050000h - 02081000h
Address: 01BD5F40h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01C05A33h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 01BD5F8Ch, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C23000h
Address: 0042FB9Eh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004ED740h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7E36DAEAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042D50Eh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004CA5E4h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0042E117h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C91EE00h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 004C4D7Ch, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004C4D60h, location: "foobar2000", loaded at 00400000h - 0050A000h
Symbol: "wcsncpy" (+00000AA9h)
Symbol: "wcsncpy" (+00000B07h)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D31D4h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 7C862CF5h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "SetThreadContext" (+00000044h)
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 0049BA76h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004A2A44h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 01000000h, location: "libmmd", loaded at 00DB0000h - 01061000h
Symbol: "_csqrtq_f90" (+0024D6C4h)
Address: 0049D160h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004A0F30h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004CA608h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 10002F27h, location: "shared", loaded at 10000000h - 1002D000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004B6DEAh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0042E350h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0049D5B0h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004EF4A0h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0049E946h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 00499AA9h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 00499AA3h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004BD0A0h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004BB7C0h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D3228h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B7287h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 0049CF16h, location: "foobar2000", loaded at 00400000h - 0050A000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Symbol: "ValidateLocale" (+000002B0h)
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049CF7Fh, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 0050A000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 0050A000h
Version info:
foobar2000 v0.9.5 beta 2
UNICODE
Windows 5.1
Additional info:
Database Search 1.4 (foo_dbsearch)
Default User Interface 0.9.5 (foo_ui_std)
PopUp Plus 20071025 (foo_popupplus)
Standard DSP Array 1.0 (foo_dsp_std)
Quick Tagger 1.0 (foo_quicktag)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Album Art Panel 0.2.7 (foo_uie_albumart)
foobar2000 core 0.9.5 beta 2 (Core)
mslive 0.4.1 (Intel SSE) (foo_input_mslive)
Gapless Crossfader 0.3.3.4 (Intel SSE) (foo_dsp_crossfader)
Columns UI 0.2.1 alpha 3 (foo_ui_columns)
Typefind 0.2 beta 2 (foo_uie_typefind)
Run services 0.3.2 (foo_run)
File Operations 2.0 (foo_fileops)
freedb Tagger 0.5.2.1 (foo_freedb2)
CD Audio Decoder 2.1.2 (foo_cdda)
Album list panel 0.2.3 beta (foo_uie_albumlist)
Album List 4.1 (foo_albumlist)
Happened while playing files with foo_preview with the newest beta of foobar.
great
love this component
i select
I've changed the tag updating strategy, now it will writting tag(s) as soon as the downloading process is done.
I hope it will solve your problem.
TO ALL:
I'll discontinue developing this component for some time becasue I need to focus on my courses and many things really important for me.
Thank you to all !
bye.
Thank you for all the effort you put into this component. I hope that you successfully make your courses.
Good luck! hope to see you back soon :-)
The component is working great now, when in normal use. During a foo_preview-session I ran into this error:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01BC338Bh
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (01BC338Bh):
01BC334Bh: CC CC CC CC CC 6A FF 68 18 1B C0 01 64 A1 00 00
01BC335Bh: 00 00 50 56 57 A1 60 2A C1 01 33 C4 50 8D 44 24
01BC336Bh: 0C 64 A3 00 00 00 00 68 8C 4F C1 01 C7 44 24 18
01BC337Bh: 00 00 00 00 FF 15 0C 41 C0 01 8B 7C 24 1C 8B 0F
01BC338Bh: 8B 01 8B 50 04 FF D2 8D 44 24 1C BE A4 4F C1 01
01BC339Bh: E8 B0 0E 01 00 68 8C 4F C1 01 FF 15 E4 40 C0 01
01BC33ABh: 83 7F 30 01 75 1B 8B F7 E8 38 2A 01 00 8B 4C 24
01BC33BBh: 0C 64 89 0D 00 00 00 00 59 5F 5E 83 C4 0C C2 04
Stack (0012F79Ch):
0012F77Ch: E3589008 B89B9000 B89B8D64 00000000
0012F78Ch: B89B8B89 86B3C4B0 86FC5218 B89B8B48
0012F79Ch: 56C63F75 01ED4F64 09335B30 0012F83C
0012F7ACh: 01C01B18 00000000 01BC98FD 09335B30
0012F7BCh: 56C63F15 0000040E 0935FD18 0012F9BC
0012F7CCh: 01ED4F64 00000008 09335B30 0012F7B8
0012F7DCh: 0012F828 7C91D592 00000028 00001174
0012F7ECh: 0012F834 02CFED30 003C0000 7C920732
0012F7FCh: 00000002 003C06E8 003C0000 0288FAD0
0012F80Ch: 0012F7FC 00000001 0012FA40 7C91EE18
0012F81Ch: 7C920738 FFFFFFFF 7C920732 7C9206AB
0012F82Ch: 7C9206EB 00000004 00000000 56C63F05
0012F83Ch: 0012F9AC 01C02748 0000000C 01BC87D8
0012F84Ch: 00000004 0935FD18 56C6308D 0935FD18
0012F85Ch: 01ED4F64 00030924 7C9205C8 00000000
0012F86Ch: 0012F938 7C920551 003C06E8 7C92056D
0012F87Ch: 00000000 0288FAD0 00000000 0044900C
0012F88Ch: 0290C798 00000000 00448673 00446C9F
0012F89Ch: 02F6272C 0219A6F8 004CCD78 0012F96C
0012F8ACh: 0219A6FC 02F62728 0044622C 00446266
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 01C14F8C
ESI: 09335B30, EDI: 09335B30, EBP: 00000004, ESP: 0012F79C
Crash location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Loaded modules:
foobar2000 loaded at 00400000h - 00509000h
foo_uie_lyrics loaded at 01BC0000h - 01C20000h
Normaliz loaded at 01C30000h - 01C39000h
foo_uie_typefind loaded at 01EE0000h - 01F10000h
foo_ui_columns loaded at 01F30000h - 0201A000h
foo_ui_egoh2 loaded at 02040000h - 02071000h
foo_ui_std loaded at 02090000h - 02146000h
w2pxdrv loaded at 05DF0000h - 05E1E000h
btkeyind loaded at 022C0000h - 022CF000h
Stack dump analysis:
Address: 01C01B18h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 01BC98FDh, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 7C91D592h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "NtClose" (+0000000Ch)
Address: 01C02748h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 01BC87D8h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 0044900Ch, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00448673h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00446C9Fh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004CCD78h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0044622Ch, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00446266h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0044912Dh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0044666Ah, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004F085Ch, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004369A0h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049A026h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049A045h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 01BD57A0h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 01C027D3h, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 01BD57ECh, location: "foo_uie_lyrics", loaded at 01BC0000h - 01C20000h
Address: 004300EAh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004ED740h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0042D92Dh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004CA570h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0042E536h, location: "foobar2000", loaded at 00400000h - 00509000h
Symbol: "strchr" (+000000FFh)
Address: 004CA9E0h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004D2EACh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004D2E90h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049C136h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004A3104h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049D820h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004A15F0h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004CA594h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004B74CCh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0042E76Fh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049DC70h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004EF4A0h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049F006h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049A169h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049A163h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004BD0B0h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004BBEF1h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004D2F00h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004B7987h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049D5D6h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0049D63Fh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 00509000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 00509000h
Version info:
foobar2000 v0.9.5 beta 3
UNICODE
Windows 5.1
Additional info:
Lyric Show Panels 0.3.1.2 Alpha 1 [Nov 2 2007 - 20:09:01] (foo_uie_lyrics)
foobar2000 core 0.9.5 beta 3 (Core)
Columns UI 0.2.1 alpha 4 v2 (foo_ui_columns)
I'm using beta 3 of foobar.
Good components.But I'm confuse who is this components's author.In chinese they say are major and ikiki.But it seems like you are the ture author and they are fake?
Thank you!
I think it's not because of foo_preview, I use foo_preview too.
Here's components I'm using now:
Core (2007-11-04 05:59:36)
foo_albumlist.dll (2007-11-02 08:05:02)
Album List 4.1
foo_audioscrobbler.dll (2007-11-10 21:43:42)
Audioscrobbler 1.3.11
foo_cdda.dll (2007-10-24 05:36:06)
foo_converter.dll (2007-11-02 08:04:44)
Converter 1.0.1
foo_convolve.dll (2006-08-04 21:57:26)
Convolver 0.3
foo_cwb_hooks.dll (2007-06-12 15:14:24)
foo_discogs.dll (2007-10-06 23:42:24)
Discogs Tagger 1.12
foo_dsp_bs2b.dll (2006-11-14 14:42:36)
bs2b 2.1.0
foo_dsp_delta.dll (2006-03-21 18:16:22)
LPCM <--> delta-PCM converter 0.1.1
foo_dsp_src9.dll (2006-06-05 20:48:38)
Resampler (Secret Rabbit Code) 1.03
foo_dsp_std.dll (2007-11-02 08:05:20)
foo_dsp_vlevel.dll (2007-09-05 16:04:48)
VLevel 20060324.0
foo_dsp_winamp.dll (2006-07-30 13:01:18)
Winamp DSP Bridge 1.4.1
foo_facets.dll (2007-11-11 10:43:25)
Facets 2007-11-10
foo_fileops.dll (2007-11-02 08:05:36)
File Operations 2.0
foo_freedb2.dll (2007-08-16 23:27:44)
foo_input_monkey.dll (2007-04-13 18:39:54)
Monkey's Audio decoder 2.1.2
foo_input_std.dll (2007-10-26 05:56:28)
foo_input_tta.dll (2006-05-01 11:53:16)
TTA Audio Decoder (unofficial) 2.4.2
foo_input_wma.dll (2007-10-18 03:18:46)
Acro WMA decoder 0.1.7.1 (Intel SSE)
foo_masstag.dll (2007-10-13 22:17:26)
Masstagger 1.6
foo_masstag_addons.dll (2007-05-20 08:00:08)
Masstagger Addons 0.3.4 (Intel SSE)
foo_playcount.dll (2007-10-16 02:08:06)
Playback Statistics 2.0
foo_playlist_manager.dll (2006-03-13 00:25:15)
Playlist Manager 1.0
foo_playlist_tree.dll (2007-08-02 10:16:46)
foo_preview.dll (2006-07-24 23:19:51)
Preview 1.2
foo_quicktag.dll (2007-10-16 17:46:18)
Quick Tagger 1.0
foo_rg_trn.dll (2007-02-10 17:56:08)
ReplayGain override 0.1.1
foo_rgscan.dll (2007-11-02 08:04:04)
foo_run.dll (2006-06-15 22:08:10)
Run services 0.3.2
foo_scheduler.dll (2007-01-09 22:33:46)
Scheduler 3.53
foo_sendtodevice.dll (2007-09-07 10:34:18)
foo_ui_columns.dll (2007-11-08 08:00:37)
Columns UI 0.2.1 alpha 6
foo_ui_panels.dll (2007-07-18 13:42:00)
Panels UI 0.14.12 beta [Jul 18 2007 - 13:39:30]
foo_ui_std.dll (2007-11-04 01:37:38)
foo_uie_albumart.dll (2007-10-23 22:39:18)
foo_uie_albumlist.dll (2007-06-11 21:13:53)
foo_uie_lyrics.dll (2007-10-31 23:43:17)
Lyric Show Panels 0.3.1.1b8 DEV [Oct 31 2007 - 23:42:52]
foo_uie_playlists_dropdown.dll (2007-09-29 03:03:32)
Playlists Dropdown 0.6 alpha 4
foo_uie_powerpanels.dll (2007-08-05 13:32:38)
Seek Panel 0.1
Volume Panel 0.1
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
foo_uie_vis_channel_spectrum.dll (2007-08-29 22:55:54)
Channel Spectrum panel 0.07
foo_unpack.dll (2006-11-04 21:17:06)
RAR reader 1.1
ZIP/GZIP reader 1.0
Please give me some more information:
- Have you enabled foo_deletecurrent?
- Were you playing audio files which were mslive streams, or tak files?
- Which DSPs you were using?
- Did you enabled foo_playcount_mod AND embed lyrics to file?
thanks.
bye
No, ikiki aka bluenet is the developer.
I just made a branch of the original one, and I dont know if bluenet will continue her work.
I have some spare time today so I've just released 0.3.1.2 Alpha 2
ChangeLog:
* Change Lyric Show Panels default setting in order to no to update tags automatically
* Add %lyric_exists% field to check if lyric exists(in Misc page)
* Add an option to change lyrics updating interval(in Misc page)
* Add an option to switch non timestamped lyrics font color(highline color or not)
* Some preferences page changes.
bye
As always: Thank you!
A small feature request:
could you add an option to automatically add to associations the downloaded lyrics?
Is there any way to change the lyric search order? I would like the component to first check local lyrics directory and only after that for embedded lyrics.
The lyric display interval option is awesome!
This finally allows reducing CPU usage down to 0-1%.
T.P Wang, Thank you very much!
very nice update! thank you!
First off, I must say I love this component
The improvements you've made are wonderful,
But alas I find I pine for the former (not to mention non-transparent) version due to one small functionality. The lyric associations, associate lyric in the right click menu, it no longer contains "..." at the end.
This option used to open a window allowing me to choose the file to be associated. I use EvilLyrics to get and edit lyrics this component may not find(rare). And due to a difference in file saving methods, I find this functionality very useful and well necessary.
What happened? Was this a small oversight perhaps, or was it intentional? I am torn, for how I love seeing my unstamped lyrics scroll and then fade away...
Overall, None of the lyric associations context menu options seem to work for me like they use to. I click and nothing happens.
On a side note, the ability to save to an alphabetized file structure like EvilLyrics would be great. I find this, regardless of program used, a more efficient system of storage. Then again I may be the only one that spends that much time playing with my lyric files. I tried using title formatting to get this to work, but the string isn't allowed/recognized and a new main file is created to save all files. Maybe implementing this ability is the work around to this?
Thanks again,
Peace
I have the same problem. This is what the console says when I try it:
foo_uie_lyrics: ERROR: I/O error (win32 #123) <2597, .\main.cpp>
Lyrics Show Panels will add downloaded lyrics to associations automatically.
And check your option -> Setting -> When found lyric from directory: ,set it to "Add to association"
Currently (and maybe for a long time, until I've completed rewriten the codes) no. Sorry
Thanks again,
Peace
I've uploaded 0.3.1.2 Alpha 2 [Nov 26 2007 - 23:27:49] to Boxstr, which meets your request
Changes:
Association now works
You can specify a dir containes titleformating scripts to hold your lyrics
such as:
E:\Music\Lyrics\$left(%artist%,1)\%artist%\%album%\
Here comes the link:
foo_uie_lyrics.7z (http://boxstr.com/files/180791_6qfei/foo_uie_lyrics.7z)
I'll delete the link and release it as (or not) Alpha 3 soon
I think I found a bug:
When I use the code $if(%lyric_exists%,yes,no), it always returns "no" even if the file has lyrics. I embed all my lyrics into my files if that matters. Am I missing something here?
Also a request:
Would you be able to create a tag such as %lyric_stamped% that would return whither or not the lyrics are timestamped or not? That would be great as right now I am using some shotty code to search for any instance of "[" in my lyrics and if it finds one, it will return that they are stamped (which isn't ALWAYS true).
Keep up the great work TP ^___^!
Also a request:
OK, I forgot to say:
%lyric_exists% return 0 if lyric doesn't exists, 1 otherwise.
I'll add some %lyric_*% fields later.
When just using %lyric_exists% by itself, it returns a "?". No 0, and no 1. It doesn't matter if the lyrics are there or not, I always get a "?". Again, all my lyrics are embedded into the file itself.
I am testing this in a track info panel if that matters at all.
You should have enabled "Enable field/function processing in titleformating scripts" in Misc of conf page.
This is what I do now, but it doesn't always work as I think that it should. For example: sometimes the automatically downloaded lyrics are wrong or have errors, so I choose to manually download another file. Anyway, the association for the song is kept to the first lyrics file, while I think that it should automatically switch to the second lyrics file instead. To switch the association, I have to remove the old association from the lyrics association manager and then I have to choose "lyrics associations"->"associate lyric" from the right click menu while the new lyrics are still shown. Imho it's a bit counterintuitive...
Oh! That solved the problem . Thanks again .
(sorry for the noobishness haha >.<)
Yeah, this update should be awesome (thanks to the Author again!) but - how did you do it? I set "Interval for lyric" to 500 (tried to 1000 even), but foobar.exe process still "eats" about 3-6% of CPU recources. I have two layouts of UI columns which are almost exactly the same, but one has Lyrics Show Panel included and other hasn't. If I switch to the layout without lyrics, foobar.exe takes 0-1% of CPU, but in case of layout wit lyrics - 3-6% in common (with rare peaks of 18-22%).
It doesn't hurt me much, but still - is there a way for me to reduce this CPU usage? (I'm using foobar 0.9.5 beta 5 under Windows 2003 server.)
There's a few factors settings affect CPU usage(on my CPU, A64 3000+ Venice, oc to 1.94Ghz):
- Transparent Background (on track change, on window move...)
- Fading(require GDI+, GDI+ is slower and take more CPU usage than GDI)
- Interval
- scroll
- font size
- panel's size
- "field/function processing in titleformatting scripts"
- On track change(related to lyric downloading, parsing lyrics, and so on)
- Cleartype
P.S: If you change Interval's value, You should click "save all" to take effect.
EDIT:However, mainly, Lyrics Show Panel take a high CPU usage because it's lack of caching system and no hardware acceleration.
I plan for rewriting the codes in order to make use of GPU. (It will take long time..., because I'll add much features.)
We will wait with patience when you have enough free time and implement all things above. This panel is excellent - let's make it BRILLIANT!
EDIT: Btw, what is strange for me - it still takes CPU time I mentioned in previous post even if there's no lyrics to display. I set formatting string for lyric not found to "no lyrics found", update period to 59 seconds - and have 3-6% of CPU usage. Transparency is turned off, fading too, both "enable scroll" boxes are checked...
I've fixed these problems in Alpha 3 (with limited tests, backup old version first). Just have a try
bye
thanks for including my request into the latest version
you're doing a really good job with this plugin, keep up the good work
just one little problem: i have the lyrics panel over the reflection of the album art and whenever the album art changes (for example when a new album starts) and this track has no lyrics the background doesn't update and i still see the old cover.
perhaps you could include in one of the future versions that the background is updated at the beginning of a track even if there are no lyrics for this song.
Hi everybody,
I hope this is the best thread for posting my question. I'm looking for an automated way of searching / downloading / storing / displaying timestamped lyrics for all my music library, all with a single click :
- automatic scan of all my "Music" directory,
- multiple online searches according to the tag fields (%album artist%, %album%, %title%),
- download of (1) preferably time-stamped lyrics, or (2) plain text lyrics only if timestamped lyrics are not available,
- storage either within the files (I have FLAC files >=v1.1.3 so the LYRICS field is enabled) or in a local database that could be accessed by a foobar component like the one we're speaking of in this topic.
- detailed log of all found timestamped lyrics / all found plain text lyrics / all lyrics that were not found.
The utility should ideally have some customizability : e.g. I have live albums where all songs are named "song title (Live)". The online search should eventually be able to skip the " (Live)" part of the %title% tag in order to retrieve the lyrics (except if the online lyrics do have the " (Live)" part of the name - I'm not sure about that).
The utility can be either a foobar component or a standalone app, I don't care... as long as the lyrics remain accessible by a foobar component of course (I want to read them within foobar, not outside of it ).
Can somebody please advise me ? Can foo_uie_lyrics do all that ? Are there things that it can't do ? Or should I simply post my request elsewhere ?
Thanks in advance !
EDIT : I've installed foo_uie_lyrics. The prefs look quite complex to me. Is there some manual / tutorial ?
Just tried, it works!
Changes:
such as:
Seems I'm not set to receive response updates, or I'd have posted sooner to tell you...
YOU FREAKIN RULE!! This component is now perfect in my opinion, and can only get better
Look forward to seeing where you'll amaze me next
Peace
Edit: Forgot to say ... Thank You!
Edit2: My lyric file is finally all cleaned up, the string i wrote a while back works perfectly
So utterly jazzed by this
I thought I'd share how to achieve the file saving system I described previously
Change save scheme settings to
Save to my directoryInsert the following...
C:\Program Files\foobar2000\lyrics\$cut(%artist%,1)
Amend to the proper destination, and all files will be now be saved alphabetically
To take a step further, add
\%artist% to the end.
Be sure to enable the search of sub directories on the settings tab!!Hope this helps someone as much as it helped me, Enjoy!
Speaking of forgetting things, has anybody seen my post up here ? I'd really appreciate an answer folks... thanks.
Hi everybody,
Thanks in advance !
I use EvilLyrics in conjunction with foobar2000 to achieve a majority of what you described.
As far as your first five points I achieve all of them sans the full library scan
With the app (EL) running it yields results for the song playing, searches multiple sites according to tags, removes anything in "()", saves to file, and works perfect with this component (especially with the recent update )
EvilLyrics has a lot of other capability's, I think it might be just what your looking for.
Feel free to P.M. me with any questions about either.
Peace
Yes! It worked. Set update time to 500ms - and now foobar takes less then 1% of CPU time with Alpha 3 version.
Great job!
Glad to see you have time to work on this great component.
I have a problem with the new v0.3.1.2 Alpha 3 and album images with embedded cuesheets. Lyrics is not changed when a new song in the same file is played. This happens even if the Lyrics association manager shows different lyrics files for the different song indexes. If I split to separate files the lyrics is downloaded as expected.
I don't experience this problem in 0.3.1.1b8 DEV.
To all Lyrics Show Panel users :
With the notable exception of ExtensionArt, nobody yet has answered my previous questions , and this one in particular : "the prefs look quite complex to me. Is there some manual / tutorial ?". There are still many things I don't understand (e.g. what exactly are associations, how do they work, what are filters, etc.). Maybe these things look trivial to you, but believe me, they aren't for a new user. Thank you.
BTW, I've decided to open a separate topic to discuss of various lyrics download / store / display solutions. You can find it here : http://www.hydrogenaudio.org/forums/index....showtopic=59361 (http://www.hydrogenaudio.org/forums/index.php?showtopic=59361)
THANKS IN ADVANCE FOR YOUR HELP, AND MOST OF ALL FOR YOUR VALUABLE COMMENTS.
EDIT : I have a first request for the developer : in the prefs > Internet > Download options > My directory, if I type "I:\Temp lyrics\%artist%\%album%", it works (the lyrics are downloaded to the expected directory). But if I type "I:\Temp lyrics\%artist%\(%date%) %album%", it doesn't (the lyrics are downloaded/cached, but nothing is written on my hard disk : the path is probably not well understood). Maybe there's the same problem with the prefs > Setting > Lyric search > Search path. Is there something you can do about this two paths ? Thank you.
EDIT2 : another little bug report :
- in the prefs > Setting > Lyric file name, when you edit a file name by double-clicking on it, the "name" field is not editable at all.
- there's a visualization bug when there are several Lyric file names and you edit one of them and validate (but if you close/reopen the prefs all becomes normal again).
- the prefs > Setting > Depth case should be a little larger to show the number in it.
1. The titleformatting script you should use is I:\Temp lyrics\%artist%\[%date% ]%album% (if you mean here, but if you want a quote, you should use '(' and ')'), be careful.
2. If you want to change the name, you must delete it, and create a new one again.
3. Confirmed as a bug, thanks.
4. Yes.
Thanks for your reply.
4. Yes.
1. Thanks, I've managed to make it work with this one : I:\Temp lyrics\%artist%\'('%date%')' %album%
That makes, e.g. : I:\Temp Lyrics\Britney Spears\(2007) Blackout
However, I have a problem with the
file names. I have defined a unique "artist-track-title" field that looks like this :
$if(%artist%,'['%artist%'] - ')$if(%track%,%track%' - ')$if2(%title%,%_filename_ext%) .
The preview looks OK (e.g. : [A-ha] - 06 - The sun always shines on tv), but the file names in my hard disk keep looking only as "Artist - Title" ! I don't understand, my music library is quite correctly tagged, so all the needed information is present.
EDIT : I've also tried with $if(%artist%,'['%artist%'] - ')$if(%tracknumber%,%tracknumber%' - ')$if2(%title%,%_filename_ext%), it doesn't work either.
2. I know I must delete it (so that looks like a bug to me, don't you think ? I can't believe that it's intended... anyway, that's no big deal )
@Jose Hidalgo:
You should do it in online search->save format
@AndersHu:
Confirmed as a bug, I'll fix it later
@radecke:
I'll check it, thanks for reporting.
Thank you very much, works great now (maybe it would be easier if the "Online search > Save format" preference was put in the "Preferences > Internet" tab, where it would be easier to find IMHO. Just my two cents).
Some settings I still don't understand :
1/ Settings > Filter : what's this for ?
2/ Settings > Internet > ARTIST filter when download automatically : what's this for ?
3/ Settings > Internet > Titleformatting for search : is is possible to configure this to look sequentially for SEVERAL title formats ?
e.g. : let's assume that a music file is correctly tagged with %artist%, %album artist% and %title% fields.
- we want to search FIRST for Artist = $if2(%artist%,) and Title = $if2(%title%,%_filename_ext%)
- but IF there's no match, then we want to search alternatively for Artist = $if2(%album artist%,) and Title = $if2(%title%,%_filename_ext%)
Is this possible ?
I have thought of writing something like $or($if2(%artist%,),$if2(%album artist%,)) but I don't think it would work. Any ideas ?
@Jose Hidalgo:
1.
When you create a new filter like this:
Value: $if2(%title%,%_filename%)
That means you want to filter %title% or %filename% which
matches Track* or CDImage.*; or Unknown*
Filter ("Value" matches "Name")
You can create many filters, the download thread will not start unless each filter fails.
2.
That means if you want to enable the filter or not(no ARTIST, it's a glitch)
3.
No, it's not possible, and there's no plan for supporting that in this modded lyrics show panel, I've planed to support that in a totally rewritten lyrics panel.
Will this plugin read the lyrics from my tags? If not, is there one that works with the default UI?
@dypsis : if your lyrics are properly encoded with the right tag name, then yes, it should read them. Try it.
@T.P. Wang : I'm not sure I have understood.
1. I suppose what you mean is that if I create a filter like this :
CDImage.*: $if2(%title%,%_filename%)
New Age;Blues;Classical: $if2(%genre%)
... then all files whose title or file name matches "CDImage.*" AND all files whose genre matches New Age, Blues or Classical will NOT be taken into account for downloading lyrics. Is that right ?
2. So this is the ON/OFF toggle for the filter, right ? OK, but it's kinda weird to see it on another tab (it would be better in the same tab IMHO : "Filter ON/OFF" checkbox or something like that).
I have since tried it, and it appears that you need Columns UI. And even when using Columns UI, I could not see how to get the lyrics to display.
Of course it needs Columns UI. It's clearly written in the first post of this topic.
I hope someone will port it to the default ui once the SDK for 0.9.5 is out.
I think that most of us hope that all Columns UI components (Lyrics Show Panel, Peakmeter,etc.) are ported to the new Default UI.
Well, as long a that means they will still be available and developed for ColumnsUI.
I've found another bug by the way. It occurs when it tries to open the plain text files created by Evil Lyrics:
Could not load info (Unsupported file format) from:
"D:\Muziek\Lyrics\W\Wagon Christ - Ring Piece.txt"
@Jose Hidalgo
1. yes.
2. I can't put the checkbox in that tab just because there's no room now.
@MC Escher
Please give a link to the lyric file(upload your file directly, no copy&paste please)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01C1341Bh
Call path:
entry=>app_mainloop
Code bytes (01C1341Bh):
01C133DBh: CC CC CC CC CC 6A FF 68 48 31 C5 01 64 A1 00 00
01C133EBh: 00 00 50 56 57 A1 70 48 C6 01 33 C4 50 8D 44 24
01C133FBh: 0C 64 A3 00 00 00 00 68 68 6F C6 01 C7 44 24 18
01C1340Bh: 00 00 00 00 FF 15 E0 60 C5 01 8B 7C 24 1C 8B 0F
01C1341Bh: 8B 01 8B 50 04 FF D2 8D 44 24 1C BE 80 6F C6 01
01C1342Bh: E8 30 20 01 00 68 68 6F C6 01 FF 15 C8 60 C5 01
01C1343Bh: 83 7F 30 01 75 1B 8B F7 E8 78 3B 01 00 8B 4C 24
01C1344Bh: 0C 64 89 0D 00 00 00 00 59 5F 5E 83 C4 0C C2 04
Stack (0012F9ACh):
0012F98Ch: BC682630 B4039000 B4038D64 00000000
0012F99Ch: 0012FEAC 7FFDF000 B4038DD8 B4038B48
0012F9ACh: 27086EF2 01F34EEC 046D0808 0012FA4C
0012F9BCh: 01C53148 00000000 01C1DA9D 046D0808
0012F9CCh: 27086E92 0000040E 046C6638 0012FBCC
0012F9DCh: 01F34EEC 00000000 046D0808 0012F9C8
0012F9ECh: 00000000 004EFD18 00000048 0041583D
0012F9FCh: 0012FA44 028AC9F0 003C0000 7C920732
0012FA0Ch: 00000002 003C06E8 003C0000 0325EA38
0012FA1Ch: 0012FA0C 000300F1 0012FC50 7C91EE18
0012FA2Ch: 7C920738 FFFFFFFF 7C920732 7C9206AB
0012FA3Ch: 7C9206EB 7C9205D4 00000004 27086EA2
0012FA4Ch: 0012FBBC 01C540C8 0000000C 01C1CA49
0012FA5Ch: 00000004 046C6638 27086D2A 046C6638
0012FA6Ch: 01F34EEC 015E059A 7FFDF000 00000000
0012FA7Ch: 7E36F7F6 00030000 00000001 0012FAF8
0012FA8Ch: 7E36F805 00030000 7FFDF000 00000000
0012FA9Ch: 0012FA90 7E390457 0012FBA0 7E390457
0012FAACh: 7E36F808 FFFFFFFF 7E36F805 7E36F94B
0012FABCh: 0012FAE8 0012FAF8 7E36F95B 00000000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 01C66F68
ESI: 046D0808, EDI: 046D0808, EBP: 00000004, ESP: 0012F9AC
Crash location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Loaded modules:
foobar2000 loaded at 00400000h - 00520000h
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C907000h
COMCTL32 loaded at 773A0000h - 774A3000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4A000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7C9D0000h - 7D1EF000h
ole32 loaded at 774B0000h - 775ED000h
shared loaded at 10000000h - 10032000h
COMDLG32 loaded at 76350000h - 7639A000h
IMM32 loaded at 76330000h - 7634D000h
MSCTF loaded at 746A0000h - 746EC000h
lgscroll loaded at 10100000h - 1010F000h
MSVCR80 loaded at 78130000h - 781CB000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
NTMARTA loaded at 77660000h - 77681000h
WLDAP32 loaded at 76F20000h - 76F4D000h
SAMLIB loaded at 71B70000h - 71B83000h
msctfime loaded at 75250000h - 7527E000h
foo_albumlist loaded at 00A60000h - 00AC6000h
foo_burninate loaded at 00AF0000h - 00B27000h
VERSION loaded at 77BD0000h - 77BD8000h
foo_cdda loaded at 00B50000h - 00B85000h
foo_channel_mixer loaded at 00BB0000h - 00BEB000h
foo_converter loaded at 00C00000h - 00C8E000h
foo_dbsearch loaded at 00CB0000h - 00D20000h
OLEAUT32 loaded at 770F0000h - 7717B000h
foo_DeleteCurrent loaded at 00D40000h - 00D60000h
foo_dsp_crossfader loaded at 00D70000h - 00DCE000h
libmmd loaded at 00DE0000h - 01091000h
foo_dsp_std loaded at 010B0000h - 010F7000h
foo_fileops loaded at 01120000h - 01167000h
foo_freedb2 loaded at 01190000h - 011D1000h
foo_input_mslive loaded at 01200000h - 01283000h
WMVCore loaded at 15110000h - 1536A000h
WMASF loaded at 11C70000h - 11CA9000h
foo_input_std loaded at 012A0000h - 013E4000h
foo_input_tak loaded at 01410000h - 01457000h
tak_deco_lib loaded at 01470000h - 014A1000h
foo_masstag loaded at 015D0000h - 01620000h
foo_osd loaded at 01640000h - 01674000h
gdiplus loaded at 4EBA0000h - 4ED43000h
foo_playcount_mod loaded at 016B0000h - 016C5000h
foo_playlist_tree loaded at 016E0000h - 01756000h
libmzsch360_000 loaded at 10400000h - 105D0000h
WSOCK32 loaded at 71A30000h - 71A3A000h
WS2_32 loaded at 71A10000h - 71A27000h
WS2HELP loaded at 71A00000h - 71A08000h
libmzgc360_000 loaded at 01780000h - 01824000h
foo_popupplus loaded at 01870000h - 01907000h
RICHED20 loaded at 74DB0000h - 74E1C000h
foo_pqview loaded at 01930000h - 01958000h
foo_preview loaded at 01980000h - 019A1000h
foo_quicktag loaded at 019C0000h - 019FE000h
foo_rgscan loaded at 01A20000h - 01A70000h
foo_run loaded at 01A90000h - 01ABB000h
foo_sendtodevice loaded at 01AE0000h - 01B1D000h
foo_uie_albumart loaded at 01B40000h - 01B7D000h
foo_uie_albumlist loaded at 01BA0000h - 01BE3000h
foo_uie_lyrics loaded at 01C10000h - 01C72000h
WINMM loaded at 76AF0000h - 76B1E000h
WININET loaded at 441E0000h - 442AF000h
Normaliz loaded at 01C90000h - 01C99000h
iertutil loaded at 43F60000h - 43FA5000h
foo_uie_typefind loaded at 01F40000h - 01F70000h
foo_ui_columns loaded at 01F90000h - 0208D000h
UxTheme loaded at 5B0F0000h - 5B128000h
foo_ui_egoh2 loaded at 020B0000h - 020E1000h
foo_ui_std loaded at 02100000h - 021B5000h
Secur32 loaded at 77FC0000h - 77FD1000h
DSOUND loaded at 73E70000h - 73ECC000h
WINTRUST loaded at 76BF0000h - 76C1E000h
CRYPT32 loaded at 77A50000h - 77AE5000h
MSASN1 loaded at 77AF0000h - 77B02000h
IMAGEHLP loaded at 76C50000h - 76C78000h
wdmaud loaded at 72C90000h - 72C99000h
RASAPI32 loaded at 76EA0000h - 76EDC000h
rasman loaded at 76E50000h - 76E62000h
NETAPI32 loaded at 597D0000h - 59825000h
TAPI32 loaded at 76E70000h - 76E9F000h
rtutils loaded at 76E40000h - 76E4E000h
USERENV loaded at 76620000h - 766D5000h
msv1_0 loaded at 77C40000h - 77C63000h
iphlpapi loaded at 76D20000h - 76D39000h
sensapi loaded at 72240000h - 72245000h
mswsock loaded at 719B0000h - 719F0000h
msacm32 loaded at 72C80000h - 72C88000h
MSACM32 loaded at 77BB0000h - 77BC5000h
midimap loaded at 77BA0000h - 77BA7000h
KsUser loaded at 73E40000h - 73E44000h
rasadhlp loaded at 76F80000h - 76F86000h
DNSAPI loaded at 76EE0000h - 76F07000h
winrnr loaded at 76F70000h - 76F78000h
wshbth loaded at 750F0000h - 7510E000h
SETUPAPI loaded at 778F0000h - 779E4000h
urlmon loaded at 442C0000h - 443E4000h
hnetcfg loaded at 66710000h - 66769000h
wshtcpip loaded at 719F0000h - 719F8000h
jsproxy loaded at 44150000h - 4415A000h
CLBCATQ loaded at 76F90000h - 7700F000h
COMRes loaded at 77010000h - 770E3000h
jscript loaded at 63380000h - 633F8000h
xpsp2res loaded at 20000000h - 202D9000h
dciman32 loaded at 73B30000h - 73B36000h
advancedautoaway loaded at 11BD0000h - 11BE3000h
btkeyind loaded at 02780000h - 0278F000h
DBGHELP loaded at 59DD0000h - 59E71000h
Address: 01C53148h, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Address: 01C1DA9Dh, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Address: 004EFD18h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0041583Dh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 01C540C8h, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Address: 01C1CA49h, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Address: 015E059Ah, location: "foo_masstag", loaded at 015D0000h - 01620000h
Address: 7E36F805h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 7E36F808h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 7E36F94Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 746B1031h, location: "MSCTF", loaded at 746A0000h - 746EC000h
Symbol: "TF_UninitSystem" (+00000970h)
Address: 7E36F819h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 7E38E175h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 7E38E152h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 10107B16h, location: "lgscroll", loaded at 10100000h - 1010F000h
Symbol: "UninstallScrollHooks" (+000011F6h)
Address: 01C26970h, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Symbol: "GetWindowLongW" (+0000002Bh)
Symbol: "GetWindowLongW" (+00000034h)
Address: 01C54153h, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Address: 7E3688E0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000003Ah)
Symbol: "SetWindowLongW" (+00000000h)
Address: 01C269BCh, location: "foo_uie_lyrics", loaded at 01C10000h - 01C72000h
Symbol: "GetDC" (+0000006Dh)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 0042EC8Ah, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004EC5B0h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E373512h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 0042C4B4h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042D0A2h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004D2C44h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004C6FA8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004D2C28h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0049F193h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00499830h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0049D5E9h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 1001D07Bh, location: "shared", loaded at 10000000h - 10032000h
Symbol: "uCallStackTracker::~uCallStackTracker" (+000000CBh)
Address: 004CA100h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004B6190h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042D2DEh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0049A86Eh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C51h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C4Bh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004BCF9Ch, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004BB270h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C5Fh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004B6667h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004995DFh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004A10E6h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0049964Ah, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 00520000h
Version info:
foobar2000 v0.9.5 beta 6
UNICODE
Windows 5.1
Additional info:
Converter 1.0.2 (foo_converter)
Send to Device 1.1.1 [Sep 7 2007 - 10:34:03] (foo_sendtodevice)
FooBar2000 Delete Current Track 1.0.0.0 (foo_DeleteCurrent)
Audio CD Writer 2.0.1 (foo_burninate)
Masstagger 1.6 (foo_masstag)
Play Count Mod 1.0.2 (foo_playcount_mod)
Playlist Tree Panel 3.0.4 [Aug 2 2007 - 10:16:21] (foo_playlist_tree)
On-Screen Display GDI+ 1.52 (foo_osd)
Preview 1.2 (foo_preview)
Channel Mixer 0.9.6.2 (foo_channel_mixer)
foobar2000 core 0.9.5 beta 6 (Core)
TAK Decoder 0.3.2 (foo_input_tak)
egoh user interface 2.0.0 (foo_ui_egoh2)
Standard Input Array 1.0 (foo_input_std)
Lyric Show Panels 0.3.1.2 Alpha 3 [Nov 29 2007 - 00:19:03] (foo_uie_lyrics)
Columns UI 0.2.1 alpha 9 (foo_ui_columns)
Happended while playing around with ng-playlist-feature of columns_ui.
I'm certainly looking forward to a port to default UI, however in the meantime i've been able to use Lyrics Show in the default UI using the Dockable Panels (http://www.hydrogenaudio.org/forums/index.php?showtopic=49263) plugin (foo_dockable_panels).
it's not a perfect solution, but it sure is a good way to bring some Lyrics Show goodness at least half way into default UI ;-)
Of course, I am using the same solution. But of course the integration is not perfect (e.g. you can't associate the lyrics panel or the peakmeter with tabs to view either one or the other).
@MC Escher
Please ignore that bug report. It seems to be related to the newly resurrected foo_dirwatch. I'm sorry to have wasted your time like that.
Thanks. I will try that. I see that the Dockable Panels plugin was developed for Columns UI, but I guess it must work for the Default UI. I much prefer the Default UI over Columns UI.
You need to install both (Columns UI and Dockable Panels). Then you can use the component over the Default UI. It's transparent. Installing Columns UI doesn't mean havint to use it.
Columns UI is NOT needed to run Dockable panels.
works fine with DUI.
I'm sorry but I didn't mean to say that. What I indended to say is simply that you need Columns UI to run foo_uie_lyrics (at least that's what's written on the first post of this thread : "Columns UI 0.1.3 beta1v7 or later"). And since dypsis was intending to use Dockable Panels anyway to run foo_uie_lyrics without Columns UI, then I meant to tell him that Columns UI was still needed anyway, because you can install Dockable Panels if you want (or not), but if you don't install the Columns UI dll then you won't be able to use foo_uie_lyrics . Am I wrong with this ? If I'm wrong, if you can really run foo_uie_lyrics with Dockable Panels and without Columns UI, then the first post should be modified IMHO. So where's the truth ?
Columns UI is not necessary to run Lyrics Show Panel (Modified version) *IF* you use Dockable Panels.
If you do not, then you need CUI.
I have tried using Dockable Panels to display my lyrics with the Lyric Show Panel, but it only displays the Artist, Title & Album.
I have tried adding Columns UI, but it doesn't make any difference.
Also, I cannot change font colour or background colour etc.
Have you considered checking the Lyrics Show Panel prefs > Internet > Download automatically checkbox ? You might want to check that out.
If you already have the lyrics files, have you considered filling the Search path at Lyrics Show Panel prefs > Setting ?
ok problem solved
the solution is very easy: you just need to hide the panel if there are no lyrics
@radecke
I've fixed that and something else since Alpha 3, however, I haven't released it yet, for I think it's not good to release it now.
@Chaser
Thanks for reporting.
I've reproduced that crash today, however, I can't reproduced it again >_<
I thought this plugin would read the lyrics from my tags.
It can read lyrics from tags. In the box called "read lyric from TAG:" just put in your tag name. For example, mine is LYRICS. So I type in LYRICS. Thats all I had to do; simple.
OK. I didn't realise that tags had different tag names. I always thought it was simply called "Lyrics". I will check it out. I still need to find out why I cannot change background and font colour. It is presently lime green font with a white background which is very hard to read.
Also. Is there a way to get Dockable Panels to remember the Lyrics Show Panel so I don't have to set it up every time I open foobar2000?
Dockable Panels should not disappear between sessions.
Right Click on the Lyric Panel and select settings and you should be able to change bg/font.
If these settings aren't sticking it soulds like you have a profile issue (both should work this way with default settings.)
Question for T. P. Wang (unless someone else cares to answer) :
Could you please try to answer questions 2/ and 3/ from the first post ? (assuming we're using foo_uie_lyrics of course).
Thanks for your help.
Yeah, they have been disappearing.
Also, as I have said, I am unable to change font or background colour.
I still cannot get it to read lyrics. I have encoded my MP3s with LAME and have tagged using Tag&Rename.
What am I doing wrong?
I also cannot get it to change background colour of font colour.
1. You should check your "LYRICS" tag first, ensure it exists. ("LYRICS" tag is
NOT "Unsynced lyric/text" or "Synced lyric/text", which can be read in wmp, some portable mp3 players,
NOT supported by Lyric Show)
2. Make sure content in "LYRICS" tag is valid.
3. You can change font color. If there's no lyric displayed, Lyric Show will display formated content in "Formating String", which you can edit color and font in a tab called
"Formating String".
4. If you have "Transprant background" enabled, you cannot change background color.
5. You cannot change background color of a font, there is not a setting about that.
1. You should check your "LYRICS" tag first, ensure it exists. ("LYRICS" tag is NOT "Unsynced lyric/text" or "Synced lyric/text", which can be read in wmp, some portable mp3 players, NOT supported by Lyric Show)
3. You can change font color. If there's no lyric displayed, Lyric Show will display formated content in "Formating String", which you can edit color and font in a tab called "Formating String".
OK. I have fixed the background. It was set to transparent.
How do I make sure my LYRICS tag is valid? It works in many other players. As I said, I used Tag&Rename for my tags.
Also. If I close Lyric Show, it needs to be reset next time. I don't need it all the time, so I like to be able to close it. But if I do that, then I have to get a New panel next time.
@dypsis
I think you didn't read carefully about this:
What I want to say is that "lyrics" in Tag&Rename is not the one in
TAG, instead, it's a
build-in frame(you can refer to the ID3 doc).
The one in
TAG I mean is a
custom frame which name is "LYRICS", which can be read/edited in fb2k and mp3tag.
P.S: I think you should set TAG to "UNSYNCED LYRICS" in Lyric Show Panel setting.
@dypsis
What I want to say is that "lyrics" in Tag&Rename is not the one in TAG, instead, it's a build-in frame(you can refer to the ID3 doc).
The one in TAG I mean is a custom frame which name is "LYRICS", which can be read/edited in fb2k and mp3tag.
OK. UNSYNCED LYRICS works. I always managed to change the font colour.
Now. There is a large space above the first line and below the last line in the lyrics. Is there a way to remove this?
@dypsis: would you please stop systematically quoting the post previous to yours ? This is very annoying. Thank you.
@T. P. Wang : thanks for your answer in the other topic.
I am so sorry for systematically annoying you.
I hope you are not annoyed that easily by other minor things in your life. You may find that you are never happy.
@dypsis
I am annoyed too seeing such quotes!
No need for such an sarcastic attack against Jose Hidalgo.
@dypsis
Would you like me to point you to all the other current threads with such quotes? Including this very thread by others who have been here for a lot longer time than me. You better go and attack them.
I am waiting to see you do it?
Here is one for you to start attacking:
http://www.hydrogenaudio.org/forums/index....647&st=3925 (http://www.hydrogenaudio.org/forums/index.php?showtopic=28647&st=3925)
dypsis, please calm down! Try to understand that making such quotes makes the readability very bad.
I am quite calm as I always am in everyday life. Maybe I should be telling you this. After all, you are the one who is annoyed.
I just find it amazing that someone can actually get annoyed at something so trivial. Can you imagine how a person like this might react if something serious happens in life? It is not a good way to live. I am very sincere when I say this.
If someone is genuinly offended or annoyed at what I posted, they should have had the manners to PM me and explain that they are finding the post difficult to read. They should also have posted the same to other bigger and longer serving offenders than me.
And what is even more amazing is that the quoting is done by numerous people in numerous threads who have been here for a lot longer than me and have quite high post counts. Yet, someone decides to single me out who has only joined this forum a few days ago. Is this the way to treat a newcomer to the forum?
Sincere regards,
dypsis
PS: My previous posts were NOT sarcastic. I have a genuine concern for people who I feel overreact to trivial matters.
PS Addendum: I actually find quoting beneficial. Especially when you only wish to reply to excerpts of a particular post. It makes it clear and concise as to what you are responding to.
"+1" to Jose Hidalgo and q-stankovic. The only correct answer to Jose's first remark is something like: "Ough, sorry, guys, I didn't think I made it wrong. It won't happen again, cause I want to be read and get answers to my posts in future." All other answers including "Everybody around does the same bad things so do I!" are wrong.
Nothing personal.
Um...Yeah
So how about that L.S.P. mod...?
Quite something isn't it
Really loving the scrolling of the non-timestamped lyrics...
Anyhoo,
All of my fellow lyric loving audiophiles should definitely take a moment to have a gander at the compelling poll/thread (http://www.hydrogenaudio.org/forums/index.php?showtopic=59361&pid=533830&st=0&#entry533830) started by our very own Jose Hidalgo. Please take a moment to share your ideas, thoughts or comments. I think we could possibly change the way lyrics (online DB's and personal libraries) are handled with this one!
Peace
Now playing: Ginuwine - What's So Different (http://www.foxytunes.com/artist/ginuwine/track/what's+so+different)
via FoxyTunes (http://www.foxytunes.com/signatunes/)
No, because this component is not a plain text show control, it's a auto-scroll lyrics displaying component.
to all:
I've updated 0.3.2.0 Alpha 1.
For changelog please see my first post
bye
i have another request:
it would be really nice if the settings of the lyric show panel would be saved in the panels ui config (*.pui file) so that users who download a theme don't have to make the settings manually.
Wow ! The "Rate lyrics in context menu" option is great ! I hope lots of people are going to use it, so that we can get reliable ratings soon. People, please take a bit of your time and give ratings to your favorite song lyrics !!! Thank you.
Of course, it would be awesome if LSP would optionally replace an already stored lyric with no rating (or with a low rating) with a lyric with a higher rating. Will this be implemented ?
Example to make this clear :
- Let's assume we have a given lyric stored, either within the music file, or in a separate .lrc or .txt file. This lyric has been downloaded before the rating system. So it has no rating at all, but we can assume chances are big that it's not perfect.
- Next time the music file is played, LSP looks online for lyrics, finds a lyric with a good rating (4 or 5), and optionally replaces the existing lyric.
- If the rating is not high enough (< 4), LSP does nothing.
Jose Hidalgo - great idea!
It seems that last version (maybe not the only last, I've just noticed it) has a bug? I set plugin's save scheme like "Embed to file", and I have "Replace nontimestamped lyrics automatically" checked. Now I see that if file has embedded nontimestamped txt-lyrics inside and plugin is able to load .LRC equivalent from Internet (I verified it), nothing happens and nontimestamped lyrics left in place. It's sad...
EDIT: Yes, I had a little test and found - "0.3.1.2 Alpha 3" worked ok, seems something was broken a bit while recompiling to "0.3.2.0 Alpha 1".
Hi:
I'm using this plugin to show exclusively embedded lyrics.
It always draws them starting from the middle of the panel, the upper 50% of the panel is empty.
I've tried all the display settings without success.
My mp3's are properly tagged without any white space at the start of lyrics, so... I have no clue.
Anyone has any idea about what could cause this behaviour?
The older versions of the same panel (from some months ago) did behave well in this respect.
Is there a way to stop Lyrics Show from displaying lyrics for internet streams (i.e. XM Radio stations?)
hey, just tried this component, its great. i only have one request. give the lyric show panel a class name so i can use girder to detect its presence.
edit:
actually now that i play with it more i found a way for girder to detect it. it would be nice to be able to scroll hte lyrics with the up/down keyboard keys though.
So.. I have a quite old version of the plugin and came here to see if the thing that bugs me the most was... corrected. I'm gessing not.
So.. you think eventually we will be able to get lyrics vertically aligned in the middle by default eventually? Everytime the lyrics loads, the first line starts at 50% vertically so I have to drag it up everytime so I can see the whole thing.
Looks like i'm not the only one who would like to see this.. fixed. Thanks alot for the nice component by the way.
i think whats it tries to do is keep the currently playing line in the middle of the screen. i like it this way.
Hi all, I'm going busy now, so I apologize for not replying your posts.
I've just uploaded 0.3.2.0 Alpha 2 with a few bug fixes, and some performance tweak.
I may provide Changelog later.
bye.
Thanks a lot for the fix!
My problem with the 50% upper part of the panel is gone!!!!
THANK YOU VERY MUCH !!!
bye.
great man, my cpu usage was at ~23% when the lyrics panel was not displayed and 40-60% when it was active. now its back down to 0-2% and 15-20% when the panel is shown.
i think "some performance tweak" is an understatement
I use Columns UI and have a tab stack with the Album Art Panel, Playlist Switcher and Lyrics Show Panel. If I select the Album Art Panel and after the restart of foobar the Lyrics Show Panel is in the foreground, although the Album Art Panel is still selected.
(http://home.arcor.de/derschwabe/lyrics01.png)
After I have switched between Album Art and Lyrics Panel and back, it shows the album cover.
(http://home.arcor.de/derschwabe/lyrics02.png)
The same with the playlist switcher panel.
@radecke:
Sorry, I was intended to do but it requires totally rewriting the codes. Though I'm working on a fully rewritten lyrics component, it'll be far to complete.
@Jose Hidalgo:
Yes, since I've embed a db engine....
@nightfishing:
I dont know about foo_xm plugin, but if xm radio can provide titleforamting info such as %title% I think lyric show panel will display lyric.
@MasterT:
See my first post, "Workaround" section.
PS: If you are using tab please *uncheck* "transparent background"
Hi:
I do have the same problem even with the new 0.3.2.0 alpha 2...
...solution anyone?
@cristox:
So you should *uncheck* "Enable scroll(nontimestamped)"
@nightfishing:
T.P
The XM plugin retrieves song titles and artists (they show up correctly in Playlist View), but the title formatting is odd; other components show the channel name as %title%
i.e. when I open the "80's" channel, Lyric Show pulls up a Robby Williams song titled "80's"
While I would love to get them to work together, I would settle for being able to disable associations for the streams.
As always, thanks for your time.
@MasterT:
Perfect, now it works.
If I disable "Enable Scroll (Non Timestamped)", my lyrics are cut off at the top.
I am using v0.3.2.0 Alpha 2.
@dypsis:
not a bug.
You can't have your cake and eat it too.
I believe it will be annoying if you enable scroll and it's scrolling so fast that you will miss some text lines.
So it's better to leave such a blank on top.
@T.P Wang
No. There is no blank on top. The lyrics are cut off. The top portion is missing.
The first few lines are missing.
@dypsis:
If your first few lines are valid characters I think you should check your vertical padding.
I just messed around with the vertical padding, but it doesn't make any difference.
By the way. The previous version v0.3.2.0 Alpha 1 doesn't have this problem.
@dypsis:
Sorry I can't reproduce it, and I have some questions:
1. Does it happen to EVERY plain text lyric?
2. Which UI are you using, Dockable Panels, Columns UI or Panels UI?
@cristox:
sorry to say but that did not work.
The texts first line starts at the middle of the panel and the text then scrolls up, keeping the momentary lyrics in the middel of the panel.
edit:
The text should be shown initially with its first line at the top of the panel.
Then the indicator highline should scroll down on the text line by line until it is in the middle (or option to let it scroll down selected number of lines) of the panel.
Then the text should scroll up under the indicator highline
Maybe you could make non timestamped lyrics align vertically in the middle of panel, if they are short enough to not need scrolling? It looks bad imo when they are at the top.
If I enable scroll it looks better but do such sort lyrics need scrolling? No.
@dypsis:
1. Yes, it happens with every lyric.
2. I am using the Default UI, but I am using Dockable Panels to display Lyrics Show.
@cristox:
The lyric display behavior current used is inherited from the original version of Lyric Show Panel, and thus I won't change the behavior since this is just a mod of Lyric Show Panel.
If you want to make your own behavior, you can grab the source I provided, and do some changes.
@orchid:
Maybe
@dypsis:
I'm sorry I can't reproduce that in Defaut UI and using Dockable Panels.
Please give me a screenshot about that.
I have been having an issue with lyrics placement, and finally figured out why it looked strange to me!
Oh, for a fix, basically, the lines with brackets need to be moved over to the left a little bit. I don't know how easy that is to do however.
Hi, I've been having some bad luck with the new versions of Lyric Show, all three versions in the download thread you linked to in the OP. Foobar crashes whenever I click on the button which shows my lyrics panel using Panels UI 14.9. I realise this is a beta of Panels UI, so the problem could lie there, but I though I'd put the crash logs here. I know you're not developing it anymore either according to the OP, so maybe there's no point posting these, but just in case you do need them:
Lyrics 0.3.2.0 Alpha 2:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04B92C5Fh
Call path:
entry=>app_mainloop=>titleformat_object::run
Code bytes (04B92C5Fh):
04B92C1Fh: 50 FF 15 4C E2 BD 04 8B 44 24 0C 8B 0D FC FB BE
04B92C2Fh: 04 50 51 FF 15 C0 E2 BD 04 8B 44 24 14 8B 50 0C
04B92C3Fh: 8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC FB
04B92C4Fh: BE 04 52 50 6A 00 51 FF 15 50 E2 BD 04 8B 4E 68
04B92C5Fh: 8B 11 A1 FC FB BE 04 8B 52 30 50 FF D2 8B 4E 68
04B92C6Fh: 85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
04B92C7Fh: 00 EB 22 8B 4C 24 0C 8B 15 D0 FB BE 04 8D 46 04
04B92C8Fh: 50 68 50 85 BA 04 51 6A 65 52 FF 15 44 E2 BD 04
Stack (0012E384h):
0012E364h: BF89EE05 BC67EC18 BC67EC38 00000007
0012E374h: 00060000 00000000 0ED234B0 7E431891
0012E384h: 0CF78818 0D6116B0 0CEAEDC2 0008080A
0012E394h: 0012E3C8 0CF46370 DA14A456 0D6116B0
0012E3A4h: 0CF73E30 04C155A8 0012E401 0CF78818
0012E3B4h: 0012E438 0CF1F4F6 00000005 0CEAF390
0012E3C4h: 0D6116B0 0CF78818 0008080A 04C155A8
0012E3D4h: DA14A42E 00000004 100065C5 0012E558
0012E3E4h: 000001CB 04C155A8 0012E3D0 0D6116B0
0012E3F4h: 00000013 003C8D10 0CF73E18 0CF2803C
0012E404h: 0D6254D8 0000001B 0000001B 0000000A
0012E414h: 0000000F 0D614D38 2D207363 0D610020
0012E424h: 0012E44C 00000013 0000001F DA14A41E
0012E434h: 0D611748 0012E54C 0CF2086C 00000007
0012E444h: 0CEAE33A 0CF73E18 0CE96584 6972796C
0012E454h: 00007363 00000004 100065C5 00000006
0012E464h: 0000000F 00000005 6972794C 68532063
0012E474h: 1000776F 0D4BDCD0 0000000A 0000000F
0012E484h: DA14A37E 0012E617 0D614CE0 0012E5D0
0012E494h: 00000181 0000004D 0D4BDA58 0012E6D4
Registers:
EAX: 00000001, EBX: 00000000, ECX: 00000000, EDX: 7C90EB94
ESI: 04C155A8, EDI: 0CF78818, EBP: 0D6116C4, ESP: 0012E384
Crash location: "foo_uie_lyrics", loaded at 04B90000h - 04BFB000h
Loaded modules:
foobar2000 loaded at 00400000h - 0051E000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 7E410000h - 7E4A0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D6000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 1002A000h
COMDLG32 loaded at 763B0000h - 763F9000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
uxtheme loaded at 5AD70000h - 5ADA8000h
RocketDock loaded at 003D0000h - 003E2000h
PSAPI loaded at 76BF0000h - 76BFB000h
MSCTF loaded at 74720000h - 7476B000h
SynTPFcs loaded at 63000000h - 63013000h
VERSION loaded at 77C00000h - 77C08000h
foo_managedWrapper loaded at 00AE0000h - 00BAA000h
mscoree loaded at 79000000h - 79045000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 0FFD0000h - 0FFF8000h
System.ni loaded at 7A440000h - 7AC06000h
System.Drawing.ni loaded at 7ADE0000h - 7AF6C000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC54000h
xpsp2res loaded at 20000000h - 202C5000h
dotnet_title loaded at 11000000h - 1101C000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_abx loaded at 036A0000h - 036D3000h
foo_albumlist loaded at 03700000h - 03765000h
foo_appcommand loaded at 03790000h - 037A6000h
foo_audioscrobbler loaded at 037D0000h - 03800000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_autoplaylist loaded at 03820000h - 03850000h
foo_browser loaded at 03870000h - 038A9000h
foo_burninate loaded at 038D0000h - 03907000h
foo_cdda loaded at 03930000h - 03965000h
foo_comserver2 loaded at 03990000h - 039E6000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_converter loaded at 03A10000h - 03A75000h
foo_custominfo loaded at 03AA0000h - 03B25000h
foo_cwb_hooks loaded at 03B50000h - 03B9D000h
foo_discogs loaded at 03BC0000h - 03C3D000h
WINMM loaded at 76B40000h - 76B6D000h
foo_dockable_panels loaded at 03CD0000h - 03D03000h
foo_dsp_std loaded at 03D30000h - 03D77000h
foo_fileops loaded at 03DA0000h - 03DE7000h
foo_freedb2 loaded at 03E10000h - 03E51000h
foo_highlightplaying loaded at 03E80000h - 03EA1000h
foo_input_mslive loaded at 03ED0000h - 03F53000h
WMASF loaded at 11C70000h - 11CAA000h
libmmd loaded at 03F70000h - 04221000h
foo_input_std loaded at 04240000h - 04362000h
foo_lyricsdb loaded at 04390000h - 043BF000h
WININET loaded at 771B0000h - 77267000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
Normaliz loaded at 71660000h - 71669000h
foo_masstag loaded at 045F0000h - 04640000h
foo_msnalt_stream loaded at 04660000h - 04684000h
foo_navigator loaded at 046B0000h - 046E4000h
foo_osd loaded at 04710000h - 04742000h
foo_playcount loaded at 04770000h - 04798000h
foo_playlist_tree loaded at 047C0000h - 04836000h
WSOCK32 loaded at 71AD0000h - 71AD9000h
libmzgc360_000 loaded at 04860000h - 04904000h
foo_rgscan loaded at 04950000h - 049A0000h
foo_run loaded at 049C0000h - 049EB000h
foo_scheduler loaded at 04A10000h - 04A7F000h
POWRPROF loaded at 74AD0000h - 74AD8000h
foo_uie_albumart loaded at 04AA0000h - 04ADD000h
foo_uie_albumart_msn loaded at 04B00000h - 04B1C000h
foo_uie_albumlist loaded at 04B30000h - 04B6D000h
foo_uie_lyrics loaded at 04B90000h - 04BFB000h
foo_uie_powerpanels loaded at 04C20000h - 04C43000h
foo_uie_quicksearch loaded at 04C70000h - 04CB6000h
foo_uie_tabs loaded at 04CE0000h - 04D0A000h
foo_uie_vis_projectm loaded at 04D30000h - 04D7A000h
OPENGL32 loaded at 5ED00000h - 5EDCC000h
GLU32 loaded at 68B20000h - 68B40000h
DDRAW loaded at 73760000h - 737A9000h
DCIMAN32 loaded at 73BC0000h - 73BC6000h
foo_ui_columns loaded at 0CD70000h - 0CE6E000h
foo_ui_panels loaded at 0CE90000h - 0CF56000h
IMM32 loaded at 76390000h - 763AD000h
foo_ui_std loaded at 0CF80000h - 0D033000h
MSIMG32 loaded at 76380000h - 76385000h
foo_unpack loaded at 0D060000h - 0D08D000h
foo_write_http loaded at 0D0B0000h - 0D0EB000h
foo_input_validator loaded at 0D110000h - 0D13E000h
foo_tutorial1_step1 loaded at 0D160000h - 0D17A000h
foo_tutorial1_step2 loaded at 0D1A0000h - 0D1C0000h
foo_tutorial1_step3 loaded at 0D1E0000h - 0D201000h
foo_tutorial1_step4 loaded at 0D230000h - 0D252000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
SXS loaded at 75E90000h - 75F40000h
msi loaded at 7D1E0000h - 7D49E000h
System.Xml.ni loaded at 637A0000h - 63D02000h
Accessibility.ni loaded at 60000000h - 60014000h
diasymreader loaded at 5E380000h - 5E409000h
netapi32 loaded at 5B860000h - 5B8B4000h
appHelp loaded at 77B40000h - 77B62000h
ieframe loaded at 46FE0000h - 47605000h
OLEACC loaded at 74C80000h - 74CAC000h
MSVCP60 loaded at 76080000h - 760E5000h
ADVPACK loaded at 65000000h - 6502B000h
SETUPAPI loaded at 77920000h - 77A13000h
CRYPTUI loaded at 754D0000h - 75550000h
WINTRUST loaded at 76C30000h - 76C5E000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
WLDAP32 loaded at 76F60000h - 76F8C000h
MSHTML loaded at 7D4A0000h - 7D7C5000h
iertutil loaded at 5DCA0000h - 5DCAD000h
urlmon loaded at 61410000h - 614E9000h
msls31 loaded at 746C0000h - 746E9000h
MSRATING loaded at 63400000h - 63436000h
sfc loaded at 76BB0000h - 76BB5000h
sfc_os loaded at 76C60000h - 76C8A000h
IEUI loaded at 5DFF0000h - 5E020000h
shellexecutehook loaded at 0EBD0000h - 0EBE3000h
MOUDL32A loaded at 0ED20000h - 0ED33000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 0CEAEDC2h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF1F4F6h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEAF390h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 100065C5h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "stricmp_utf8_ex" (+00000000h)
Address: 0CF2803Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF2086Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEAE33Ah, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CE96584h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 1000776Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetLongPathName" (+00000044h)
Address: 0045D8D6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042E7B3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004056B6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004056D0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004055CEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF20920h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CED75E2h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+000038C2h)
Address: 0CED760Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+000038EFh)
Address: 00463C69h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CCC80h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CCC60h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF08h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4476h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045FFB7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004AD08Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004603EFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00463DA2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0046531Dh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00464964h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ACAF1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CEA781Bh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF29858h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 773E207Bh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "DefSubclassProc" (+00000055h)
Address: 0CF29754h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF2989Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004EA884h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF28154h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF409E4h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CE9C22Dh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 77F17012h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "BitBlt" (+00000089h)
Address: 77F16FFAh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "BitBlt" (+00000071h)
Address: 0CEA386Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF21990h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA389Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004300E2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E470088h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3CCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E41B3A7h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3B0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 0CEA32F3h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 74DA49F4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+00000036h)
Address: 74DA4A1Ah, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+0000005Ch)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 629C3004h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkInitialize" (+0000013Ch)
Address: 629C6080h, location: "LPK", loaded at 629C0000h - 629C9000h
Address: 629C31F7h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkInitialize" (+0000032Fh)
Address: 629C322Ch, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkExtTextOut" (+00000029h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 1000B5C1h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000B5E0h, location: "shared", loaded at 10000000h - 1002A000h
Address: 77F15B80h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SelectObject" (+00000000h)
Address: 1000E080h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10002A25h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+00000384h)
Address: 1000275Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+000000B9h)
Address: 10007137h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uExtTextOut" (+00000061h)
Address: 0CE110BEh, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CD7E353h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE11316h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE37078h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE1CF4Fh, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE114A2h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7E41B3F9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 0CD97A10h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 7E41B473h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77F1DBA7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "InvertRgn" (+00000060h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0CF21E3Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 0CEA1E31h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA1E4Eh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 03CD48C0h, location: "foo_dockable_panels", loaded at 03CD0000h - 03D03000h
Address: 03CD48FAh, location: "foo_dockable_panels", loaded at 03CD0000h - 03D03000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000193h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000163h)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E41C63Fh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 7E41C665h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 773E1B57h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal11" (+00000328h)
Address: 773E1E65h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "RemoveWindowSubclass" (+00000139h)
Address: 773E1ECFh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "RemoveWindowSubclass" (+000001A3h)
Version info:
foobar2000 v0.9.5 beta 8
UNICODE
Windows 5.1
Additional info:
File Operations 2.0 (foo_fileops)
Audioscrobbler 2.2 (foo_audioscrobbler)
cwbowron's title format hooks 1.2.5 [Jun 8 2007 - 08:49:42] (foo_cwb_hooks)
Scheduler 3.53 (foo_scheduler)
RAR reader 1.1 (foo_unpack)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Component Tutorial (Step 4) 0.3.2 (foo_tutorial1_step4)
Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55] (foo_ui_panels)
Seek Panel 0.1 (foo_uie_powerpanels)
Tabbed panel modified 0.2.5 (foo_uie_tabs)
Default User Interface 0.9.5 (foo_ui_std)
foo_custominfo 0.1.2 (foo_custominfo)
Album Art Panel 0.2.7.1 (foo_uie_albumart)
Playback Statistics 1.3.2 (foo_playcount)
Columns UI 0.2.1 alpha 9 v3 (foo_ui_columns)
projectM visualization (Panel) 0.4 (foo_uie_vis_projectm)
Album list panel 0.2.2 (foo_uie_albumlist)
Discogs Tagger 1.0 (foo_discogs)
Album List 4.1 (foo_albumlist)
freedb Tagger 0.5.2.1 (foo_freedb2)
MSN Now Playing (alt) with stream radio support 2.5 (foo_msnalt_stream)
foobar2000 core 0.9.5 beta 8 (Core)
Navigator 0.63 (foo_navigator)
Component Tutorial (Step 2) 0.3.2 (foo_tutorial1_step2)
foo_lyricsdb 0.0.7 beta 5 (foo_lyricsdb)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56] (foo_browser)
Standard DSP Array 1.0 (foo_dsp_std)
Run services 0.3.2 (foo_run)
HTTP Writer 1.1 (foo_write_http)
ZIP/GZIP reader 1.0 (foo_unpack)
ABX Comparator 1.3.1 (foo_abx)
CD Audio Decoder 2.1.2 (foo_cdda)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48] (foo_dockable_panels)
APPCOMMAND multimedia key support 0.1 (foo_appcommand)
Highlight playing 0.1.0 (foo_highlightplaying)
COM Automation server 0.7 alpha 6 (foo_comserver2)
Decoder Validator 1.0 (foo_input_validator)
On-Screen Display 1.52 (foo_osd)
Album Art Panel Mod (MSN) 0.2.1_8 (foo_uie_albumart_msn)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Volume Panel 0.1 (foo_uie_powerpanels)
foo_managedWrapper 0.4 (foo_managedWrapper)
Component Tutorial (Step 1) 0.3.2 (foo_tutorial1_step1)
Lyric Show Panels 0.3.2.0 Alpha 2 [Dec 18 2007 - 15:28:24] (foo_uie_lyrics)
mslive 0.4.1 (Intel SSE) (foo_input_mslive)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00] (foo_cwb_hooks)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Component Tutorial (Step 3) 0.3.2 (foo_tutorial1_step3)
Lyrics 0.3.2.0 Alpha 1:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04B92B0Fh
Access violation, operation: read, address: 00000000h
Call path:
Code bytes (04B92B0Fh):
04B92ACFh: 50 FF 15 50 D2 BD 04 8B 44 24 0C 8B 0D FC EB BE
04B92ADFh: 04 50 51 FF 15 C4 D2 BD 04 8B 44 24 14 8B 50 0C
04B92AEFh: 8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC EB
04B92AFFh: BE 04 52 50 6A 00 51 FF 15 54 D2 BD 04 8B 4E 68
04B92B0Fh: 8B 11 A1 FC EB BE 04 8B 52 30 50 FF D2 8B 4E 68
04B92B1Fh: 85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
04B92B2Fh: 00 EB 22 8B 4C 24 0C 8B 15 D0 EB BE 04 8D 46 04
04B92B3Fh: 50 68 50 7F BA 04 51 6A 65 52 FF 15 48 D2 BD 04
Stack (0012E384h):
0012E374h: 00060000 00000000 0EDD34B0 7E431891
0012E384h: 0CF78818 0D623390 0CEAEDC2 000C0802
0012E394h: 0012E3C8 0CF46370 04984122 0D623390
0012E3A4h: 0CF73E30 04C15618 0012E401 0CF78818
0012E3C4h: 0D623390 0CF78818 000C0802 04C15618
0012E3D4h: 0498415A 00000004 100065C5 0012E558
0012E3E4h: 000001CB 04C15618 0012E3D0 0D623390
0012E3F4h: 0000000F 003C8D10 0CF73E18 0CF2803C
0012E404h: 0D623060 0000001B 0000001B 0000000A
0012E414h: 0000000F 0D624388 2D207363 0CF70020
0012E424h: 0012E44C 00000013 0000001F 0498416A
0012E434h: 0CF7A430 0012E54C 0CF2086C 00000007
0012E474h: 1000776F 0D50A0C0 0000000A 0000000F
0012E484h: 0498460A 0012E617 0D623020 0012E5D0
0012E494h: 00000181 0000004D 0D50A7B8 0012E6D4
Registers:
ESI: 04C15618, EDI: 0CF78818, EBP: 0D6233A4, ESP: 0012E384
Crash location: "foo_uie_lyrics", loaded at 04B90000h - 04BFA000h
Loaded modules:
foo_uie_lyrics loaded at 04B90000h - 04BFA000h
shellexecutehook loaded at 0EC80000h - 0EC93000h
MOUDL32A loaded at 0EDD0000h - 0EDE3000h
Address: 04984122h, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498415Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498416Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498460Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 04984AEEh, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 04984A02h, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 004700CBh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 77F1939Dh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateDIBSection" (+00000184h)
Address: 77F192ECh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateDIBSection" (+000000D3h)
Address: 4ECD9033h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECD903Eh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 4ED55B38h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4AFC0h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4B4DBh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4AF5Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECA6FFFh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED43545h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 77F1E611h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DdEntry53" (+0000000Ch)
Address: 77F1E5FCh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DdEntry39" (+00000028h)
Address: 73BC143Eh, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000048h)
Address: 73BC144Eh, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000058h)
Address: 4ED436E4h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 73BC17E4h, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCICreatePrimary" (+0000024Bh)
Address: 73BC1458h, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000062h)
Address: 4ED43700h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4390Bh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED43AA5h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECA4A8Fh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4EADDh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAD00Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAD362h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAE873h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAEB31h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED502C0h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4397Bh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC51580h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC99249h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECDE0B9h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Version info:
UNICODE
Windows 5.1
Additional info:
Lyric Show Panels 0.3.2.0 Alpha 1 [Dec 9 2007 - 14:55:15] (foo_uie_lyrics)
There's another one but I think I've reached the post limit and there seems to be something stopping me double posting. I'll finish my post tomorrow.
@Keikonium:
It's because of GDI+.
GDI+'s text rendering is not good I think, so I may remove GDI+ text rendering in the future(there's some other ways to implement fading effect)
@TomBarlow:
You should make sure there's no more instance of Lyric Show Panel GREATER than 1.
I checked and it's still not working. Yesterday when I first installed the new version I got a message saying there were multiple instances found, which was because the old version was installed at components\en-US\ which I hadn't noticed, I deleted that folder and that's when I got those crashes. I tried installing the new version to components\en-US\ just now in case foobar was looking for it there, but I'm getting the same thing. I've double checked my Panels code, my settings for the lyrics, but it still happens. Here's the latest crash log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 036A2C5Fh
Call path:
Code bytes (036A2C5Fh):
036A2C1Fh: 50 FF 15 4C E2 6E 03 8B 44 24 0C 8B 0D FC FB 6F
036A2C2Fh: 03 50 51 FF 15 C0 E2 6E 03 8B 44 24 14 8B 50 0C
036A2C3Fh: 8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC FB
036A2C4Fh: 6F 03 52 50 6A 00 51 FF 15 50 E2 6E 03 8B 4E 68
036A2C5Fh: 8B 11 A1 FC FB 6F 03 8B 52 30 50 FF D2 8B 4E 68
036A2C6Fh: 85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
036A2C7Fh: 00 EB 22 8B 4C 24 0C 8B 15 D0 FB 6F 03 8D 46 04
036A2C8Fh: 50 68 50 85 6B 03 51 6A 65 52 FF 15 44 E2 6E 03
Stack (0012E19Ch):
0012E17Ch: BF89EE05 BC678DB0 BC678DD0 00000007
0012E18Ch: 00060000 00000000 0EFD34B0 7E431891
0012E19Ch: 0CF78818 0D3AD710 0CEAEDC2 000E0614
0012E1ACh: 0012E1E0 0CF46370 CE073C16 0D3AD710
0012E1BCh: 0D391348 039B7AF8 0012E201 0CF78818
0012E1CCh: 0012E250 0CF1F4F6 00000005 0CEAF390
0012E1DCh: 0D3AD710 0CF78818 000E0614 039B7AF8
0012E1ECh: CE073C5E 00000004 100065C5 0012E374
0012E1FCh: 000001DA 039B7AF8 0012E1E8 0D3AD710
0012E20Ch: 00000008 003C8DA8 0D391330 0CF2803C
0012E21Ch: 0D3CD8E0 0000001B 0000001B 0000000A
0012E22Ch: 0000000F 0D3A16A0 70207363 6C656E61
0012E23Ch: 00202D20 00000019 0000001F CE073FAE
0012E24Ch: 0D38D398 0012E364 0CF2086C 00000007
0012E25Ch: 0CEAE33A 0D391330 0CE96584 6972796C
0012E26Ch: 70207363 6C656E61 10006500 0000000C
0012E27Ch: 0000000F 00000005 6972794C 68532063
0012E28Ch: 1000776F 0D75DE80 0000000A 0000000F
0012E29Ch: CE073F0E 0012E4AB 0D3836A8 0012E464
0012E2ACh: 0000016D 0000004D 0D77D110 0012E6D4
Registers:
ESI: 039B7AF8, EDI: 0CF78818, EBP: 0D3AD724, ESP: 0012E19C
Crash location: "foo_uie_lyrics", loaded at 036A0000h - 0370B000h
Loaded modules:
foo_uie_lyrics loaded at 036A0000h - 0370B000h
foo_abx loaded at 039C0000h - 039F3000h
foo_albumlist loaded at 03A20000h - 03A85000h
foo_appcommand loaded at 03AB0000h - 03AC6000h
foo_audioscrobbler loaded at 03AF0000h - 03B20000h
foo_autoplaylist loaded at 03B40000h - 03B70000h
foo_browser loaded at 03B90000h - 03BC9000h
foo_burninate loaded at 03BF0000h - 03C27000h
foo_cdda loaded at 03C50000h - 03C85000h
foo_comserver2 loaded at 03CB0000h - 03D06000h
foo_converter loaded at 03D30000h - 03D95000h
foo_custominfo loaded at 03DC0000h - 03E45000h
foo_cwb_hooks loaded at 03E70000h - 03EBD000h
foo_discogs loaded at 03EE0000h - 03F5D000h
foo_dockable_panels loaded at 03F70000h - 03FA3000h
foo_dsp_std loaded at 03FD0000h - 04017000h
foo_fileops loaded at 04040000h - 04087000h
foo_freedb2 loaded at 040B0000h - 040F1000h
foo_highlightplaying loaded at 04120000h - 04141000h
foo_input_mslive loaded at 04170000h - 041F3000h
libmmd loaded at 04210000h - 044C1000h
foo_input_std loaded at 044E0000h - 04602000h
foo_lyricsdb loaded at 04630000h - 0465F000h
foo_masstag loaded at 04680000h - 046D0000h
foo_msnalt_stream loaded at 046F0000h - 04714000h
foo_navigator loaded at 04740000h - 04774000h
foo_osd loaded at 047A0000h - 047D2000h
foo_playcount loaded at 04800000h - 04828000h
foo_playlist_tree loaded at 04850000h - 048C6000h
libmzgc360_000 loaded at 048F0000h - 04994000h
foo_rgscan loaded at 049E0000h - 04A30000h
foo_run loaded at 04A50000h - 04A7B000h
foo_scheduler loaded at 04AA0000h - 04B0F000h
foo_uie_albumart loaded at 04B30000h - 04B6D000h
foo_uie_albumart_msn loaded at 04B90000h - 04BAC000h
foo_uie_albumlist loaded at 04BC0000h - 04BFD000h
shellexecutehook loaded at 0E7A0000h - 0E7B3000h
MOUDL32A loaded at 0EFD0000h - 0EFE3000h
DSOUND loaded at 73F10000h - 73F6C000h
wdmaud loaded at 72D20000h - 72D29000h
mswsock loaded at 71A50000h - 71A8F000h
DNSAPI loaded at 76F20000h - 76F47000h
winrnr loaded at 76FB0000h - 76FB8000h
rasadhlp loaded at 76FC0000h - 76FC6000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
msacm32 loaded at 72D10000h - 72D18000h
MSACM32 loaded at 77BE0000h - 77BF5000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 73EE0000h - 73EE4000h
Address: 10006500h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uReplaceCharAdd" (+0000003Eh)
Address: 0CED7593h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+00003873h)
Address: 0489DE78h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 048866EBh, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 004053B7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F8E4h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F8C0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F7D3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0D70h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EDE90h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF28h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C9CD8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ACEF5h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043589Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C9CB4h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF40AE0h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 048B36D4h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 048B36A0h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 004AD218h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00435926h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EDCE0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B0298h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0044243Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CAA44h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CE9FBB1h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF1C520h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA7800h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004600D0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF28104h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 03E09418h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 03E093E1h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 00494469h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C910000h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+00000477h)
Address: 03E00001h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E0CAE0h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E08D65h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E08D46h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 0CE1F8D8h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 00464903h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045FE4Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C2E80h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00466449h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 03EA1360h, location: "foo_cwb_hooks", loaded at 03E70000h - 03EBD000h
Address: 00466BBDh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0046048Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
UNICODE
Windows 5.1
Additional info:
@TomBarlow:
Multi instance I meant is put more than one panel at the same time.
You should check your code, prevent something like this:
$panel(lyric1,Lyric Show,...)
$panel(lyric2,Lyric Show,...)
one Lyric Show in PUI code and another in Dockable Panels
et hoc genus omne.
FYI, I have a glance at your components, foo_audioscrobbler is listed as its "Repeated crash reports.".
However, that's fixed(but still doesn't support multi instances), I'll release it some days later.
Anybody have problems with lyrcis download? The last version 0.3.2.0 Alpha 2?
@TomBarlow:
et hoc genus omne.
Thanks, it's working now, I had a lyrics panel in a dockable panel that I wasn't using any more, I didn't realise it was still stored away.
I've uploaded 0.3.2.0 Alpha 3 with some minor changes
for major changes see ChangeLog
this build is for stability only
bye
Happy New Year!
It's beta time
0.3.2.1 beta 1 released
bye
Nice plugin with transparent feature.
But is it possible to add on setting for encoding inside foobar's preferences so that we can choose the default encoding for all the lyrics? I dont know why but all my lyrics for chinese and japanese will show some weird character until i change the encoding. Quite troublesome to change everytime..
@teNtiOn:
I've just considered to add it in the next release.
thanks.
I don't know why but when I scroll through the lyrics (in case it's a .txt file) the playlist scrolls as well. It's a bit annoying . Not a major issue though.
@T.P Wang: Nice man, looking forward for it.
Is there a plan to make this plugin work under default 0.95 GUI?
I guess first the DefaultUI SDK should be made available... the developer of foo_uie_peakmeter is waiting for it.
Hi there. I've ran into so crashes that seem to be incurred by foo_uie_lyrics 0.3.2.1 Beta 1 [Jan 2 2008 - 20:43:21] (see codebox). I wasn't doing anything particular at the time.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04173500h
Call path:
entry=>app_mainloop
Code bytes (04173500h):
041734C0h: ED 74 08 3B 2D 68 8F 1C 04 74 05 E8 90 BB 02 00
041734D0h: 3B FE 74 75 85 ED 75 63 E8 83 BB 02 00 33 C0 3B
041734E0h: 78 10 72 05 E8 77 BB 02 00 8B 07 8B 08 8B 01 8B
041734F0h: 50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8B 4C 24 24
04173500h: 8B 11 8B F0 8B 42 0C FF D0 8B 10 8B C8 8B 02 FF
04173510h: D0 56 50 FF D3 85 C0 74 2C 85 ED 75 23 E8 3E BB
04173520h: 02 00 33 C0 3B 78 10 72 05 E8 32 BB 02 00 A1 78
04173530h: 8F 1C 04 83 C7 04 E9 75 FF FF FF 8B 45 00 EB 9F
Stack (0013F8C0h):
0013F8A0h: EB495000 EB495000 EB494D64 00000000
0013F8B0h: 0013FEAC 7FFDF000 EB494DD8 EB494B48
0013F8C0h: 04415334 0013F934 09EB11C0 00000000
0013F8D0h: 00000000 0013F954 041B33D8 00000000
0013F8E0h: 0417DF9F 00000000 00000000 0000040E
0013F8F0h: 0013FAC8 04415334 0013F94C 7FFDFBF8
0013F900h: 00000000 0013F92C 7C90F0AA 7FFDFC00
0013F910h: 0000000A 0013F938 6606A92C 00000005
0013F920h: 7FFDFBF8 00030700 00000000 7C90D9C1
0013F930h: 7C830C6F 7FFDFC00 09EB0000 7C830C88
0013F940h: 00030700 6606A92C 00000000 00000007
0013F950h: 00030700 0013FABC 041B4DB9 FFFFFFFF
0013F960h: 0417CF82 0013F8E4 00000003 09EB11C0
0013F970h: 09EB11C0 04415334 000106C0 0013F9B0
0013F980h: 00000000 7E41C493 00030700 7E41C465
0013F990h: 7E430002 00000001 0013F988 0013FCC4
0013F9A0h: 0013FCC4 7E440457 7E41C498 FFFFFFFF
0013F9B0h: 7E41C493 6601CA4E 0002062C 0013FCA8
0013F9C0h: 6601BF1F 00000000 0002062C 0000007F
0013F9D0h: 00000001 00000000 00000000 0000029E
Registers:
EAX: 06797268, EBX: 10006293, ECX: 00000000, EDX: 004C9D38
ESI: 09EB6828, EDI: 09EB67B8, EBP: 044143C8, ESP: 0013F8C0
Crash location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Loaded modules:
RPCRT4 loaded at 77E70000h - 77F01000h
SHELL32 loaded at 7C9C0000h - 7D1D7000h
wbsys loaded at 66500000h - 6650A000h
guard32 loaded at 003A0000h - 003C2000h
fltLib loaded at 4FFE0000h - 4FFE8000h
winsta loaded at 76360000h - 76370000h
NETAPI32 loaded at 5B860000h - 5B8B4000h
wblind loaded at 66000000h - 66083000h
UXTHEME loaded at 5AD70000h - 5ADA8000h
msimg32 loaded at 76380000h - 76385000h
wbhelp loaded at 66600000h - 66617000h
apphelp loaded at 77B40000h - 77B62000h
msctfime loaded at 755C0000h - 755EE000h
foo_abx loaded at 00F50000h - 00F83000h
foo_albumlist loaded at 00FB0000h - 01015000h
foo_audioscrobbler loaded at 01040000h - 01070000h
foo_cdda loaded at 01090000h - 010C5000h
foo_converter loaded at 010F0000h - 01155000h
foo_cwb_hooks loaded at 01180000h - 011B6000h
foo_dirwatch loaded at 011E0000h - 0120E000h
foo_dsp_skip_silence loaded at 01230000h - 01243000h
libmmd loaded at 01260000h - 01511000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_dsp_std loaded at 01540000h - 01587000h
foo_fileops loaded at 015B0000h - 015F7000h
foo_infobox loaded at 01620000h - 01660000h
foo_input_monkey loaded at 01680000h - 016CA000h
foo_input_std loaded at 016F0000h - 01815000h
foo_masstag loaded at 01840000h - 0188F000h
foo_midi loaded at 018B0000h - 0195A000h
foo_playcount_mod loaded at 01980000h - 01995000h
foo_pqview loaded at 019B0000h - 019CC000h
foo_prettypop loaded at 019F0000h - 01A3D000h
mscoree loaded at 79000000h - 79046000h
mscorwks loaded at 79E70000h - 7A3FF000h
mscorlib.ni loaded at 790C0000h - 79BF6000h
mscorjit loaded at 79060000h - 790B6000h
foo_preview loaded at 03ED0000h - 03EF1000h
foo_rgscan loaded at 03F90000h - 03FE0000h
foo_scheduler loaded at 04000000h - 0406F000h
foo_uie_albumart loaded at 04090000h - 040CD000h
foo_uie_albumlist loaded at 04100000h - 04143000h
foo_uie_lyrics loaded at 04170000h - 041D4000h
WININET loaded at 42C10000h - 42CDF000h
Normaliz loaded at 041F0000h - 041F9000h
iertutil loaded at 42990000h - 429D5000h
foo_uie_playlists_dropdown loaded at 04420000h - 04459000h
foo_uie_queuemanager loaded at 04480000h - 044B9000h
System.ni loaded at 7A440000h - 7AC2A000h
System.Drawing.ni loaded at 7ADE0000h - 7AF7C000h
foo_uie_quicksearch loaded at 047A0000h - 047E6000h
foo_uie_tabs loaded at 04800000h - 0482A000h
foo_uie_trackinfo_mod loaded at 04850000h - 048A6000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
foo_uie_typefind loaded at 048C0000h - 048F0000h
foo_ui_columns loaded at 04910000h - 04A0D000h
foo_ui_std loaded at 04A30000h - 04AE3000h
foo_winamp_spam loaded at 04B10000h - 04B40000h
dciman32 loaded at 73BC0000h - 73BC6000h
ieframe loaded at 42EF0000h - 434BD000h
urlmon loaded at 42CF0000h - 42E17000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC6C000h
wshbth loaded at 751D0000h - 751EE000h
mdnsNSP loaded at 099B0000h - 099C9000h
Iphlpapi loaded at 76D60000h - 76D79000h
RASAPI32 loaded at 76EE0000h - 76F1C000h
rasman loaded at 76E90000h - 76EA2000h
TAPI32 loaded at 76EB0000h - 76EDF000h
rtutils loaded at 76E80000h - 76E8E000h
msv1_0 loaded at 77C70000h - 77C93000h
USERENV loaded at 769C0000h - 76A73000h
sensapi loaded at 722B0000h - 722B5000h
MPRAPI loaded at 76D40000h - 76D58000h
ACTIVEDS loaded at 77CC0000h - 77CF2000h
adsldpc loaded at 76E10000h - 76E35000h
ATL loaded at 76B20000h - 76B31000h
SAMLIB loaded at 71BF0000h - 71C03000h
cscui loaded at 77A20000h - 77A74000h
CSCDLL loaded at 76600000h - 7661D000h
browseui loaded at 75F80000h - 7607D000h
ntshrui loaded at 76990000h - 769B5000h
shdocvw loaded at 77760000h - 778D0000h
LINKINFO loaded at 76980000h - 76988000h
fsshext.8.0.0792.00 loaded at 5A500000h - 5A52F000h
MPR loaded at 71B20000h - 71B32000h
drprov loaded at 75F60000h - 75F67000h
ntlanman loaded at 71C10000h - 71C1E000h
NETUI0 loaded at 71CD0000h - 71CE7000h
NETUI1 loaded at 71C90000h - 71CD0000h
NETRAP loaded at 71C80000h - 71C87000h
davclnt loaded at 75F70000h - 75F79000h
wpdshext loaded at 0B1E0000h - 0B45E000h
PortableDeviceApi loaded at 0A880000h - 0A8C9000h
shgina loaded at 73D70000h - 73D83000h
MSGINA loaded at 75970000h - 75A67000h
ODBC32 loaded at 74320000h - 7435D000h
odbcint loaded at 20000000h - 20017000h
Audiodev loaded at 0B660000h - 0B6A6000h
WMVCore loaded at 0B6B0000h - 0B90A000h
WMASF loaded at 0B520000h - 0B55A000h
xpsp2res loaded at 0B910000h - 0BBD5000h
PDFShell loaded at 0BC40000h - 0BC8C000h
Address: 041B33D8h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 0417DF9Fh, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 7C90F0AAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAnsiStringToUnicodeString" (+0000005Eh)
Address: 6606A92Ch, location: "wblind", loaded at 66000000h - 66083000h
Address: 7C90D9C1h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwFindAtom" (+0000000Ch)
Address: 7C830C6Fh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GlobalDeleteAtom" (+000000B4h)
Address: 7C830C88h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GlobalDeleteAtom" (+000000CDh)
Address: 041B4DB9h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 0417CF82h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 7E41C493h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+0000002Eh)
Address: 7E41C465h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+00000000h)
Address: 7E430002h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetPropA" (+00000000h)
Address: 7E41C498h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+00000033h)
Address: 6601CA4Eh, location: "wblind", loaded at 66000000h - 66083000h
Symbol: "GetWindowsDirectoryA" (+00019B64h)
Address: 6601BF1Fh, location: "wblind", loaded at 66000000h - 66083000h
Symbol: "GetWindowsDirectoryA" (+00019035h)
Address: 004EDCF8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043AAE2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Symbol: "RtlAllocateHeap" (+00000164h)
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 04187960h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Symbol: "GetWindowLongW" (+0000002Bh)
Symbol: "GetWindowLongW" (+00000034h)
Address: 00444ED6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 041B4E52h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 66603EA3h, location: "wbhelp", loaded at 66600000h - 66617000h
Symbol: "SetAddr" (+00000229h)
Address: 041879ACh, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E41B4D0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E4191BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetProcessWindowStation" (+00000029h)
Address: 7E4191F1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetMessageW" (+0000002Bh)
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042C11Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 1000263Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000CAh)
Address: 00FC7814h, location: "foo_albumlist", loaded at 00FB0000h - 01015000h
Address: 0041DAEAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CD0Dh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F50h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F34h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004A08F3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AF90h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049ED48h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C8258h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4775h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CF49h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049BFCEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993B1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993ABh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004BAF9Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B9600h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993BFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4B5Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AD3Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049ADAAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 003A0043h, location: "guard32", loaded at 003A0000h - 003C2000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
Special file info box 2.0.4 (foo_infobox)
Queue manager panel 0.2.3 (foo_uie_queuemanager)
Columns UI 0.2.1 alpha 9 (foo_ui_columns)
foobar2000 core 0.9.5 (Core)
cwbowron's title format hooks 1.1.1 [May 4 2007 - 12:39:47] (foo_cwb_hooks)
Album list panel 0.2.3 beta (foo_uie_albumlist)
Standard Input Array 1.0 (foo_input_std)
Winamp API Emulator 0.96 (foo_winamp_spam)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
Playlists Dropdown 0.6 alpha 3 (foo_uie_playlists_dropdown)
Converter 1.0.2 (foo_converter)
Skip silence 0.1 (Intel SSE) (foo_dsp_skip_silence)
Monkey's Audio decoder 2.1.2 (foo_input_monkey)
Preview 1.2 (foo_preview)
Directory watcher 0.2 beta 3 (foo_dirwatch)
MIDI synthesizer host 1.7 (foo_midi)
Typefind 0.2 beta 2 (foo_uie_typefind)
Masstagger 1.6 (foo_masstag)
Quick Search Toolbar 2.8k (foo_uie_quicksearch)
Pretty Popup 1.2.3 (foo_prettypop)
Lyric Show Panels 0.3.2.1 Beta 1 [Jan 2 2008 - 20:43:21] (foo_uie_lyrics)
Audioscrobbler 2.1 (foo_audioscrobbler)
Play Count Mod 1.0.2 (foo_playcount_mod)
0.3.2.1 Beta 2 has been released.
@MC Escher:
Ooops, I've just returned to home for vocation but I haven't brought the symbol files. So if that problem occurs in beta 2, please let me know, thanks.
I'm afraid beta 2 still crashes:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 041234C0h
Call path:
entry=>app_mainloop
Code bytes (041234C0h):
04123480h: ED 74 08 3B 2D 10 50 17 04 74 05 E8 60 93 02 00
04123490h: 3B FE 74 75 85 ED 75 63 E8 53 93 02 00 33 C0 3B
041234A0h: 78 10 72 05 E8 47 93 02 00 8B 07 8B 08 8B 01 8B
041234B0h: 50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8B 4C 24 24
041234C0h: 8B 11 8B F0 8B 42 0C FF D0 8B 10 8B C8 8B 02 FF
041234D0h: D0 56 50 FF D3 85 C0 74 2C 85 ED 75 23 E8 0E 93
041234E0h: 02 00 33 C0 3B 78 10 72 05 E8 02 93 02 00 A1 20
041234F0h: 50 17 04 83 C7 04 E9 75 FF FF FF 8B 45 00 EB 9F
Stack (0013F8C0h):
0013F8A0h: EC036000 EC036000 EC035D64 00000000
0013F8B0h: 0013FEAC 7FFDE000 EC035DD8 EC035B48
0013F8C0h: 043B577C 0013F934 0B1B30D0 00000000
0013F8D0h: 00000000 0013F954 041609A8 00000000
0013F8E0h: 0412DE4F 00000000 00000000 0000040E
0013F8F0h: 0013FAC8 043B577C 0013F94C 7FFDEBF8
0013F900h: 00000000 0013F92C 7C90F0AA 7FFDEC00
0013F920h: 7FFDEBF8 00160978 00000000 7C90D9C1
0013F930h: 7C830C6F 7FFDEC00 0B1C0000 7C830C88
0013F940h: 00160978 6606A92C 00000000 00000007
0013F950h: 00160978 0013FABC 041622E9 FFFFFFFF
0013F960h: 0412CE2C 0013F8E4 00000003 0B1B30D0
0013F970h: 0B1B30D0 043B577C 0004042A 0013F9B0
0013F980h: 00000000 7E41C493 00160978 7E41C465
0013F9B0h: 7E41C493 6601CA4E 000903E0 0013FCA8
0013F9C0h: 6601BF1F 00000000 77F16E2D 77F16F1A
0013F9D0h: DC011406 0006040E 049C7064 00000000
Registers:
EAX: 07C0C410, EBX: 10006293, ECX: 00000000, EDX: 004C9D38
ESI: 0BBB41C4, EDI: 0BBB40E8, EBP: 043B4AF8, ESP: 0013F8C0
Crash location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Loaded modules:
foo_dsp_skip_silence loaded at 011E0000h - 011F3000h
libmmd loaded at 01210000h - 014C1000h
foo_dsp_std loaded at 014F0000h - 01537000h
foo_fileops loaded at 01560000h - 015A7000h
foo_infobox loaded at 015D0000h - 01610000h
foo_input_monkey loaded at 01630000h - 0167A000h
foo_input_std loaded at 016A0000h - 017C5000h
foo_masstag loaded at 017F0000h - 0183F000h
foo_midi loaded at 01860000h - 0190A000h
foo_playcount_mod loaded at 01930000h - 01945000h
foo_pqview loaded at 01960000h - 0197C000h
foo_prettypop loaded at 019A0000h - 019ED000h
foo_preview loaded at 03E80000h - 03EA1000h
foo_rgscan loaded at 03F40000h - 03F90000h
foo_scheduler loaded at 03FB0000h - 0401F000h
foo_uie_albumart loaded at 04040000h - 0407D000h
foo_uie_albumlist loaded at 040B0000h - 040F3000h
foo_uie_lyrics loaded at 04120000h - 04180000h
Normaliz loaded at 04190000h - 04199000h
foo_uie_playlists_dropdown loaded at 043C0000h - 043F9000h
foo_uie_queuemanager loaded at 04420000h - 04459000h
foo_uie_quicksearch loaded at 04740000h - 04786000h
foo_uie_tabs loaded at 047A0000h - 047CA000h
foo_uie_trackinfo_mod loaded at 047F0000h - 04846000h
foo_uie_typefind loaded at 04860000h - 04890000h
foo_ui_columns loaded at 048B0000h - 049AD000h
foo_ui_std loaded at 049D0000h - 04A83000h
foo_winamp_spam loaded at 04AB0000h - 04AE0000h
mdnsNSP loaded at 0A850000h - 0A869000h
mlang loaded at 75CF0000h - 75D81000h
msdmo loaded at 736B0000h - 736B7000h
wmadmod loaded at 0A480000h - 0A53C000h
mfplat loaded at 0A540000h - 0A577000h
Address: 041609A8h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 0412DE4Fh, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 041622E9h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 0412CE2Ch, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 77F16E2Dh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+00000223h)
Address: 77F16F1Ah, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteDC" (+000000ABh)
Address: 77F16E81h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteDC" (+00000012h)
Address: 7E41B629h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EndPaint" (+0000000Ch)
Address: 0494CA5Ch, location: "foo_ui_columns", loaded at 048B0000h - 049AD000h
Address: 773EEFB3h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00003113h)
Address: 04137A70h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 04162382h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 04137ABCh, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 7E41F94Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7E41F95Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 00FCE0ECh, location: "foo_albumlist", loaded at 00FB0000h - 01015000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
Lyric Show Panels 0.3.2.1 Beta 2 [Jan 15 2008 - 20:42:40] (foo_uie_lyrics)
@MC Escher:
It's really strange that it crashes that location(when do update nontimestamped lyric), Could you provide some more info about that? such as:
Do you have emebed lyric to file enabled, or it crashed when playing files with lyric embed?
Did it crash before you start to use 0.3.2.1 Beta 1, and which version you were using before 0.3.2.1 Beta 1?
Yes I save the lyrics to the tags, but only if they're timestamped. Because the crashes are so random, I don't know if the track already has embedded lyrics when it crashes. I do believe the crashes started with beta 1, yes.
@MC Escher:
So I think you'd better uncheck "Replace nontimestamped lyric" in Setting -> Internet for now.
I may fixed it later.
Hey, um, the plugin stops automatically downloading lyrics, even though they are available, and I have the the Download automatically option checked.
Um, I'm not sure what information I could give to help you find out what the problem is, I'm afraid. But does anyone have any idea how to fix this? I have the latest version of the plugin installed. (0.3.2.1 Beta 2.)
Same problem.
@Feldon:
@STEELBAS:
Yes, in these days I've found some anonying bugs so I'll fix them later, Thanks.
Thats really a nice plugin!
But I've a question using it. I would like to get the automatic downloaded files saved directly into the directory of the song. So i.e. if the song name is "Yeah Yeah Yeahs - 03 - Isis.mp3", the lyric should be named "Yeah Yeah Yeahs - 03 - Isis.lrc". So in the panels prefernces --> Setting --> Lyric file name my only entry is aritst-tracknumber-title: %artist%' - '%tracknumber%' - '%title%. Hopefully that's right for my intension.
But now the question. Is it possible, that the Lyric Show Panel is only looking for that lyric filename in the song's directory without using Associationes? I would like the panel while playing "Yeah Yeah Yeahs - 03 - Isis.mp3" look into the song's directory for "Yeah Yeah Yeahs - 03 - Isis.lrc", if not found download it and save it under that name and if not found it in the internet do nothing.
Sorry for my bad english!
great plugin...is it possible to make it a UI Element for the new default user interface?
Hi
0.3.2.1 Beta 3 is out.
Sorry for my late fix, I've fix some anonying problems.
@whatswrong:
Sorry, now it's not possible, I may add some option to close association in the future.
@u11n:
Now it's not possible, and even the new SDK is out, I won't simply migrate it to the DUI because quality of this panel is not good as a Defaut UI Element.
Hello. I am a bit silly and I don't understand how to modify/alter the way this component parses the titlename etc. It works very nice for most of my music, but I would love if it could work for internet radio.
To be more precise, this one:
http://scfire-nyk-aa04.stream.aol.com/stream/1040 (http://scfire-nyk-aa04.stream.aol.com/stream/1040)
When I listen to it, foobar's titlebar says the artist and the song perfectly but component only "recognizes" the artist, the title is .977 The 80s Channel, which is name of the radiostation.
I guess I should make a filter or something, but as I could not find any manual or explanations, I ask for help .
For those who are having problem with (automatic) scrolling, stop your Radmin Server.
I'm completely confused with this. I have download automatically checked but no lyrics show up, and when I click online search I get "Search Failed" every time. Is there a FAQ or manual for this? I have no idea what's wrong
EDIT
Now it's flickering like crazy, still no lyrics, and my browser opened up with this: Foobar2000redirect:F1C74C0B-2D99-4B6D-9338-4889E9047D68
What is going on?
@ahri:
It's not possible to support dymanic info like stream now, because its design is limited(from original source). I will not change that because I have to pay attention to my study. Sorry.
@r4b:
You should check your console, every useful infomation is labeled by "foo_uie_lyrics:"
If you have problem downloading, check these below:
Check your Internet Explorer, make sure it's not work in "offline"
Check your proxy setting
Ping 82.165.178.113
Make sure port 1212 is open.
0.3.2.1 is finally released
For changelog check my first post
I think it's time to release 0.3.2.1 before Spring Festival Eve in Chinese lunisolar calendar
Cheers.
Thanks, and Happy New Year. We celebrate it over here, too.
Thank you T.P Wang! Have a great holiday .
*goes to try it out*
Despite the latest version, I still get the crashes:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 041C3448h
Call path:
entry=>app_mainloop
Code bytes (041C3448h):
041C3408h: 04 74 05 E8 FD 83 02 00 3B FE 0F 84 C8 00 00 00
041C3418h: 85 ED 0F 85 AC 00 00 00 E8 E8 83 02 00 33 C0 3B
041C3428h: 78 10 72 05 E8 DC 83 02 00 8B 07 8B 08 8B 01 8B
041C3438h: 50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8B 4C 24 20
041C3448h: 8B 11 8B F0 8B 42 0C FF D0 8B 10 8B C8 8B 02 FF
041C3458h: D0 56 50 E8 EA 7C 03 00 83 C4 08 85 C0 75 43 8B
041C3468h: 4C 24 20 8B 11 8B 42 0C FF D0 8B 10 8B C8 8B 42
041C3478h: 08 FF D0 8B F0 85 ED 75 53 E8 87 83 02 00 33 C0
Stack (0013F8C4h):
0013F8A4h: F6E38000 F6E38000 F6E37D64 00000000
0013F8B4h: 0013FEAC 7FFDF000 F6E37DD8 F6E37B48
0013F8C4h: 0445555C 0013F934 0B0B5CD8 00000000
0013F8D4h: 0013F954 041FFAA8 00000000 041CCF3F
0013F8E4h: 00000000 0000040E 00000000 0013FAC8
0013F8F4h: 0445555C 7C910732 00000002 00B106E8
0013F904h: 00B10000 08403DE8 0013F8FC FFFFFFFF
0013F914h: 0013FB40 7C90EE18 7C910738 FFFFFFFF
0013F924h: 7C910732 7C9106AB 7C9106EB 7C9105D4
0013F934h: 00000004 0AB00000 7C91056D 00498CE9
0013F944h: 00B10000 00000000 00000007 679B1663
0013F954h: 0013FABC 04201319 FFFFFFFF 041CBF24
0013F964h: 0013F8E4 00000003 0B0B5CD8 0B0B5CD8
0013F974h: 0445555C 00020486 00000000 00000000
0013F984h: 085513C8 0013FA54 7C910551 00B10718
0013F994h: 7C91056D 00000000 085513D0 085513D0
0013F9A4h: 004032C9 00000000 004C5BCC 0045E29F
0013F9B4h: 00000000 06787040 06787040 06967930
0013F9C4h: 00410650 06967934 004D0B2C 0042D8FC
0013F9D4h: 004ED3C0 0042D903 004ED3A8 00000003
Registers:
EAX: 069592A8, EBX: 00000000, ECX: 00000000, EDX: 004C9D38
ESI: 0AAA2EFC, EDI: 0AAA2EA0, EBP: 04454AF8, ESP: 0013F8C4
Crash location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Loaded modules:
foo_amipwrapper loaded at 01040000h - 0106C000h
foo_audioscrobbler loaded at 01090000h - 010C0000h
foo_cdda loaded at 010E0000h - 01115000h
foo_converter loaded at 01140000h - 011A5000h
foo_cwb_hooks loaded at 011D0000h - 01206000h
foo_dirwatch loaded at 01230000h - 0125E000h
foo_dsp_skip_silence loaded at 01280000h - 01293000h
libmmd loaded at 012B0000h - 01561000h
foo_dsp_std loaded at 01590000h - 015D7000h
foo_fileops loaded at 01600000h - 01647000h
foo_infobox loaded at 01670000h - 016B0000h
foo_input_monkey loaded at 016D0000h - 0171A000h
foo_input_std loaded at 01740000h - 01865000h
foo_masstag loaded at 01890000h - 018DF000h
foo_midi loaded at 01900000h - 019AA000h
foo_playcount_mod loaded at 019D0000h - 019E5000h
foo_pqview loaded at 01A00000h - 01A1C000h
foo_prettypop loaded at 01A40000h - 01A8D000h
foo_preview loaded at 03F20000h - 03F41000h
foo_rgscan loaded at 03FE0000h - 04030000h
foo_scheduler loaded at 04050000h - 040BF000h
foo_uie_albumart loaded at 040E0000h - 0411D000h
foo_uie_albumlist loaded at 04150000h - 04193000h
foo_uie_lyrics loaded at 041C0000h - 0421F000h
Normaliz loaded at 04230000h - 04239000h
foo_uie_playlists_dropdown loaded at 04460000h - 04499000h
foo_uie_queuemanager loaded at 044C0000h - 044F9000h
foo_uie_quicksearch loaded at 047E0000h - 04826000h
foo_uie_tabs loaded at 04840000h - 0486A000h
foo_uie_trackinfo_mod loaded at 04890000h - 048E6000h
foo_uie_typefind loaded at 04900000h - 04930000h
foo_ui_columns loaded at 04950000h - 04A4D000h
foo_ui_std loaded at 04A70000h - 04B23000h
foo_winamp_spam loaded at 04B50000h - 04B80000h
amip loaded at 071C0000h - 07336000h
mdnsNSP loaded at 09BF0000h - 09C09000h
Address: 041FFAA8h, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 041CCF3Fh, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 00498CE9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 04201319h, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 041CBF24h, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 004032C9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C5BCCh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045E29Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00410650h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0B2Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042D8FCh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ED3C0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042D903h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ED3A8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043529Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 041D6BD0h, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 042013B2h, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 041D6C1Ch, location: "foo_uie_lyrics", loaded at 041C0000h - 0421F000h
Address: 071D7CB6h, location: "amip", loaded at 071C0000h - 07336000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
AMIP Wrapper 0.90 (foo_amipwrapper)
Lyric Show Panels 0.3.2.1 [Feb 5 2008 - 19:18:13] (foo_uie_lyrics)
simple question:
Whats files support this component? What formating??
I have an *.txt file:
NAME OF THE SONG
lyrics lyrics lyrics lyrics lyrics
lyrics lyrics lyrics lyrics lyrics lyrics
OTHER SONG
lyrics lyrics
This works????
How then??
Thanks in advance.
@bertox:
support .txt and .lrc
lrc like these types are supported
[mm:ss:ms]
or
[mm:ss.ms]
or another Lrc format used by Lyrics Panel is supported.
[mm:ss:ms]
or
[mm:ss.ms]
I don't understand really. My question is very simple.
How can i write a lyrics file??? An example please.........
@bertox:
A lyric file can be a plain text file. You can get it from many lyrics websites, such as http://lyricwiki.org (http://lyricwiki.org), or google "lyrics" for more
if you want to make synchronized lyric,
LRC format is decribed here:
http://en.wikipedia.org/wiki/LRC_(file_format) (http://en.wikipedia.org/wiki/LRC_(file_format))
in "Simple LRC fomrat" section
To make LRC, an easy way is to use minilyrics.
or use LyricsCreator (http://www.hydrogenaudio.org/forums/index.php?showtopic=57752) (requires COM Automation Server component for fb2k)
or another external program including tutor:
LRC Editor (http://www.mycnknow.com/download/TUTORIAL/tutor.htm)
P.S: I know a lot of good lyrics editor/creator and LRC online databases but they are in Chinese.
ok. Thank you..
Illegal operation:
Call path:
entry=>app_mainloop
Stack (0013F8C4h):
Registers:
Loaded modules:
foobar2000 loaded at 00400000h - 0051E000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 7E410000h - 7E4A0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 1002A000h
COMDLG32 loaded at 763B0000h - 763F9000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
WINMM loaded at 76B40000h - 76B6D000h
MSCTF loaded at 74720000h - 7476B000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
OLEAUT32 loaded at 77120000h - 771AB000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
rsaenh loaded at 0FFD0000h - 0FFF8000h
gdiplus loaded at 4EC50000h - 4EDF3000h
VERSION loaded at 77C00000h - 77C08000h
PSAPI loaded at 76BF0000h - 76BFB000h
Secur32 loaded at 77FE0000h - 77FF1000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
xpsp2res loaded at 20000000h - 202C5000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
The same thing happened to me with the latest version and the strange thing is that it was working fine until one time I opened foobar and it would crash instantly.
Great plugin! Thanks so much
Franchesco
0.3.2.2 released
@Efron
@MC Escher
I think I've fixed it in 0.3.2.2, If it still crash, please let me know.
Thank you, will do!
Crashing for me too
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 03CC8E75h
Access violation, operation: read, address: 03D35000h
Call path:
entry
Code bytes (03CC8E75h):
03CC8E35h: 54 24 28 03 D1 3B FA 73 3C 8B C7 8D 73 1C 8D 50
03CC8E45h: 02 66 8B 08 83 C0 02 66 85 C9 75 F5 2B C2 D1 F8
03CC8E55h: 50 8B C7 E8 63 D2 00 00 8B 5B 30 8D 3C 5F 33 C0
03CC8E65h: 66 3B 07 75 10 8D 9B 00 00 00 00 83 C7 02 33 C9
03CC8E75h: 66 3B 0F 74 F6 8B 54 24 14 8B 4A 0C 85 C9 75 04
03CC8E85h: 33 C0 EB 08 8B 42 14 2B C1 C1 F8 03 8B 5A 10 8B
03CC8E95h: D3 2B D1 C1 FA 03 3B D0 73 2E C6 44 24 1C 00 8B
03CC8EA5h: 44 24 1C 8B 4C 24 1C 50 51 8D 74 24 28 BA 01 00
Stack (0012F178h):
0012F158h: 00F7DB9C 7C9D94F8 77F443DD 7C9D94F8
0012F168h: 00000004 00000000 00F7D0A8 00000000
0012F178h: 0012F2E0 0012F2F8 6920FEAD 0012F2F8
0012F188h: 000000F2 03D13E48 03D34690 0012F200
0012F198h: 03D34690 03D34750 03D34F08 000000F2
0012F1A8h: 00488E45 0012F200 00000004 0012F208
0012F1B8h: 03D000E0 00000001 0012F2E0 0012F214
0012F1C8h: 03CE0AB9 0012F1F4 000000F6 0012F2E0
0012F1D8h: 0012F334 003C70D8 000008D1 AA81D745
0012F1E8h: 43A64C62 6920FEAD 39481087 03D07CFC
0012F1F8h: 0012F2F8 00000000 000000F6 0012F1D8
0012F208h: 0012F2D4 03CFFA30 00000000 0012F2E0
0012F218h: 03CEA3DF 0012F2F8 0012F2E0 00414BA7
0012F228h: 0012F2F8 0012F2E0 0012FD64 004D0178
0012F238h: 0000022F FFFFFFFF 04300000 04300000
0012F248h: 00000008 0012F1A8 0428DBA2 00000000
0012F258h: 00010000 00000009 0012F1BC 0012F1C0
0012F268h: 0012F2A8 7C91EE18 7C920570 FFFFFFFF
0012F278h: 7C92056D 0428DB83 04300000 00000000
0012F288h: 0428DBA2 8856196E 00000000 0012F2F4
Registers:
EAX: 00000000, EBX: 0000000E, ECX: 00000000, EDX: 00000000
ESI: 03D346AC, EDI: 03D35000, EBP: 0012F1C4, ESP: 0012F178
Crash location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Loaded modules:
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C905000h
COMCTL32 loaded at 77390000h - 77493000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4C000h
RPCRT4 loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32 loaded at 7E390000h - 7E420000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7C9D0000h - 7D1F5000h
ole32 loaded at 774A0000h - 775DD000h
COMDLG32 loaded at 76340000h - 7638A000h
IMM32 loaded at 76320000h - 7633D000h
LPK loaded at 62DC0000h - 62DC9000h
USP10 loaded at 753C0000h - 7542B000h
uxtheme loaded at 5B090000h - 5B0C8000h
TaskbarExHelper loaded at 003D0000h - 003DD000h
SynTPFcs loaded at 63000000h - 63013000h
VERSION loaded at 77BD0000h - 77BD8000h
MSCTF loaded at 74690000h - 746DB000h
msctfime loaded at 75140000h - 7516E000h
Secur32 loaded at 77FC0000h - 77FD1000h
CLBCATQ loaded at 76F80000h - 76FFF000h
COMRes loaded at 77000000h - 770D4000h
OLEAUT32 loaded at 770E0000h - 7716B000h
foo_abx loaded at 00AD0000h - 00B03000h
foo_albumlist loaded at 00B30000h - 00B95000h
foo_amipwrapper loaded at 00BC0000h - 00BEC000h
foo_audioscrobbler loaded at 00C10000h - 00C47000h
WS2_32 loaded at 719F0000h - 71A07000h
WS2HELP loaded at 719E0000h - 719E8000h
foo_browser loaded at 00C70000h - 00CA9000h
foo_cdda loaded at 00CD0000h - 00D05000h
foo_converter loaded at 00D30000h - 00D95000h
foo_cwb_hooks loaded at 00DC0000h - 00E0D000h
foo_discogs loaded at 00E30000h - 00ED1000h
gdiplus loaded at 4EB80000h - 4ED23000h
WINMM loaded at 76AE0000h - 76B0F000h
foo_dsp_std loaded at 00F80000h - 00FC7000h
foo_dsp_tube loaded at 00FF0000h - 01016000h
foo_freedb2 loaded at 01030000h - 01071000h
foo_input_std loaded at 010A0000h - 011C5000h
foo_lyricsdb loaded at 011F0000h - 0121F000h
WININET loaded at 44080000h - 4414F000h
Normaliz loaded at 01230000h - 01239000h
iertutil loaded at 43E00000h - 43E45000h
foo_masstag loaded at 01460000h - 014B0000h
foo_playback_custom loaded at 014D0000h - 01515000h
WINSPOOL loaded at 72F50000h - 72F76000h
foo_playcount_mod loaded at 01560000h - 01575000h
foo_playlist_bind loaded at 015A0000h - 015C5000h
foo_prettypop loaded at 015E0000h - 0162D000h
foo_rgscan loaded at 03B70000h - 03BC0000h
foo_run loaded at 03BC0000h - 03BEB000h
foo_uie_albumlist loaded at 03C00000h - 03C3D000h
foo_uie_explorer loaded at 03C60000h - 03C9D000h
foo_uie_lyrics loaded at 03CC0000h - 03D1F000h
foo_uie_peakmeter loaded at 03D40000h - 03D66000h
foo_uie_playlists_dropdown loaded at 03D90000h - 03DCA000h
foo_uie_powerpanels loaded at 03DF0000h - 03E13000h
foo_uie_quicksearch loaded at 03E40000h - 03E86000h
foo_uie_vis_channel_spectrum loaded at 03EB0000h - 03ED8000h
MSIMG32 loaded at 76310000h - 76315000h
foo_uie_wsh_panel loaded at 03F00000h - 03F36000h
foo_ui_columns loaded at 04080000h - 04117000h
foo_ui_panels loaded at 04140000h - 04207000h
foo_ui_std loaded at 04230000h - 042E3000h
foo_unpack loaded at 04310000h - 0433D000h
imagehlp loaded at 76C40000h - 76C68000h
DBGHELP loaded at 5D3F0000h - 5D491000h
Stack dump analysis:
Address: 03D13E48h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 00488E45h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 03D000E0h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 03CE0AB9h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 03D07CFCh, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 03CFFA30h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 03CEA3DFh, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 00414BA7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0178h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0428DBA2h, location: "foo_ui_std", loaded at 04230000h - 042E3000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 0428DB83h, location: "foo_ui_std", loaded at 04230000h - 042E3000h
Address: 004D0F78h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B2506h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C59A0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00434200h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00411E00h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C59A8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048C5DAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 03CC0000h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 03D12CC0h, location: "foo_uie_lyrics", loaded at 03CC0000h - 03D1F000h
Address: 004ABE25h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00412898h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C2C47h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 79103AB5h, location: "mscorlib.ni", loaded at 790C0000h - 79BF6000h
Address: 00CEF055h, location: "foo_cdda", loaded at 00CD0000h - 00D05000h
Address: 7CC874A5h, location: "SHELL32", loaded at 7C9D0000h - 7D1F5000h
Address: 7C925A51h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+000002AEh)
Address: 76FA65C1h, location: "CLBCATQ", loaded at 76F80000h - 76FFF000h
Symbol: "DestroyStgDatabase" (+0001CB2Fh)
Address: 03BD0C1Ah, location: "foo_run", loaded at 03BC0000h - 03BEB000h
Address: 0149514Ah, location: "foo_masstag", loaded at 01460000h - 014B0000h
Address: 4EC4731Ah, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 7754557Ah, location: "ole32", loaded at 774A0000h - 775DD000h
Symbol: "CoDisableCallCancellation" (+00000372h)
Address: 7702253Ah, location: "COMRes", loaded at 77000000h - 770D4000h
Address: 7752191Dh, location: "ole32", loaded at 774A0000h - 775DD000h
Symbol: "CoWaitForMultipleHandles" (+0000A7DCh)
Address: 004EA198h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 774BF05Bh, location: "ole32", loaded at 774A0000h - 775DD000h
Symbol: "CoInitializeEx" (+000000F0h)
Address: 004C7D6Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 01000002h, location: "foo_dsp_tube", loaded at 00FF0000h - 01016000h
Address: 004EA1B8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B161Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CAC7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Symbol: "strchr" (+00000117h)
Address: 004A0923h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AFC0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049ED78h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C8224h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4766h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CEB6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049BFFEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993E1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993DBh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B9620h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993EFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4B73h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AD6Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C905000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C905000h
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C905000h
Address: 0049ADDAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
@zouhair
Please use "codebox" instead of "code"
If it's Upgraded from Lyric Show Panels 0.3.1.1 or previous versions
You should clear Lyric Show Panels configruation first before you start to use this modded version.
One way to delete configruation is delete foo_uie_lyrics.dll -> start fb2k -> not keep setting -> close fb2k
no matter whether it helps, please let me know.
I did the same but actually kept the settings so I'm stuck
@zouhair
@zouhair:
That crash had reported serveral times and I'm confused by that.
Someone use ObjectDock, then result in crash. However, without ObjectDock, it's OK.
Someone cleard all configration...
I have some questions:
1) Which version of ColumnsUI component are you using?
2) After remove foo_uie_lyrics component, then start fb2k, then also remove all references(eg. in ColumnsUI), close fb2k -> place foo_uie_lyrics component ->start fb2k, would it crash?
3) Then add one reference of foo_uie_lyrics (eg. Insert "Lyric Show" Panel in ColumnsUI), would it crash?
Thanks in advance.
Any way, I think I must double check the code now
zouhair should do that:
1. unistall foobar2k
2. reintsll boobar2k
3. copy columnUI
4. copy boo_uie_lyrics
5. start foobar2k
keep the envirement clean first.
@zouhair:
Thanks in advance.
2. reintsll foobar2k
3. copy columnUI
5. start foobar2k
@zouhair:
Thanks in advance.
How do you add lyrics that weren't found thru the 'Online Search' function? I tried "associate lyric" and it didn't work.
edit: my bad, seems a restart of Foobar does the trick
Right Click on Lyrics Panel after associating the lyric file and then click on Reload Lyrics will do.
Hi I'm new to this forum, this is my first reply.
First of all I'm sorry that I am not patient enough to go through all the 19 pages of this thread, so I may miss the solutions to my problem.
I just want to add my own lyric to the song that has been associated or embed with lyric that had been automatically downloaded. I don't know how to dissociate the unwanted lyric.
What should I do?
0.3.2.3 released:
* Fix a bug that can not specify the background color when transparent is disabled
* Fix a bug that it wouldn't refresh when resizing window
* Change lyric file cap from 10K -> 32K, which help loading larger lyric file
* Add options for fading and shadow offset.
* Fix something on lyric search & download
@Hizack:
You can have a try: Right Click on Lyric Show Panel -> Lyric Associations -> Diable associations
nice new options in the new version.
but would it be possible to also add options to set the radius and the opacity of the shadow?
Thanks for new version!
I discovered a bug: if "Adjust fading height manually" is checked and I exit the preferences window then come back, it gets unchecked.
Also, can you add a scrollbar in the future?
@radecke:
I'll add an option for soft-shadow later. Thanks.
@Totyo:
Yes, it's a bug, it also occurs in misc->output verbose debugging information..
I'll fix it later.
Though scrollbar is good for scrolling lyric quickly, it is not easy for customizing, besides, Lyric Show Panels prefered synced-lyric rather than plain-text, so I won't consider it for now.
I have a feature request.
For now, we have two choices: automatically downloading lyrics (no click but connexion for each song is not a way to do) OR using an extra window (several clicks + lost time to wait for choices).
Could we have an option in contextual menu which allows to download automatically please ?
Thank you for your help, T.P Wang
But after I dissociate the unwanted lyric and associate a lyric I want, the lyric associated becomes the original unwanted one again.
How could I really remove the original lyric and associate or embed my own lyrics?
Hey! i'm using the lyrics show panel for song info when there aren't any lyric-tags in the file. So i made show me all kinds of file specific info like rg gain and bitrate and stuff like that. Now, i have two slight problems that i can't seem to fix:
1. how can i make it so that comments are always centered, even when they have manual breaks in them (mean: not line break but when i wrote the break into the comment - i.e. lyrics, diff. segments of songs). Because i can set a tag to be displayed centered but when there's a (manual) break within the comment tag "$char(1)C" applies only for the first line of the comment text..
2. most plugins and foobar itself (afaik) look for an entire tag family instead of only one specific tag within a file. For example: %artist% - not only "artist% is been returned, but also "album artist%, %composer%, %band% and so on. Only Problem is, when i set %comments% to be displayed it also returns %COMMENT ITUNNORM% which is itunes' version of ReplayGain and not a comment.. Is there anyway to exclude this particular tag from being displayed?? It really sucks to have a bunch of ugly numbers being displayed that i don't wanna see..
Thanks alot in advance for any answer!
Hello.
0.3.3.0 is released now. Please note the changlog
Regards.
Hello.
Regards.
Thanks for this great component. As it is built with the latest SDK, the requirements for your component in the first topic should be adjusted to foobar2000 0.9.5.
@fbuser:
No, current now I've only used only one new servie introduced in new SDK:
"Enable field processing in titleformating scripts" now use metadb_display_field_provider service instead of deprecated&removed metadb_display_hook
From the changelog of the new SDK:
Added access to new features introduced in foobar2000 versions 0.9.5, 0.9.5.1 and 0.9.5.2. Version 0.9.5 or newer is now required to load components made with this SDK.
I'm not able to test it at the moment, but if you are using a new service from the new SDK, I wonder how old foobar2000 versions can load lyrics panel. I don't need a deeper technical description here, if it works, it's ok for me.
@fbuser:
Yes, you are right, I've changed that.
Hi. Thanks for this great component.
Feature request: Is possible to improve the online search function? Eg. when searching artist with trailing "The" to search without "the", too? I mean if I have a song from "The Beatles" there aren't any results for "Beatles" and vice verse. Also if there is a trailing space, the component won't find any results.
Hi ,very good pugins,but I have a problem,when it auto download from internet and output the *.lyr to my hard drive, the *.lyr 's name is different from the *.mp3.for example the song's name is (01. Candy Shop.mp3) but the lyr's name is (Madonna - Candy Shop.lrc) ,it's different .If I put these together to my MP3 player, it can't play the lyr. thanks.
Hi. I have a question. Does this plugin supports word synchronised lyrics?
There are several formats I think
Minilyrics use the following format:
[00:32.83]<00:32.83>I <00:33.25>reach <00:33.67>for <00:33.95>you ... etc
I tried that and it disn't recognise the words.
Any possibility of implementing such a feature with the highlights through word synchronisation?
Thanks very much!
Good plugins.
thanks for that.
just wondering where does the plugin download from?
Nice plugin. It would be cool though if you could have the lyrics in a separate window that show/hide depending on if lyrics are found.
You can do it with fb2k v0.9.5.3 (with $stripprefix(X) and $swapprefix(X)), and in configruation window of Lyric Show -> Internet, you can find setting for "Titleformatting for search".
No, at least not now, this component now is hard to read and render that format.
You can do it with dockable panels and the %lyric_exists% field.
would you be able to make lyrics fade in/out like in MiniLyrics?
also is there a plan to make a lyrics editor that can be used in conjunction with lyrics show panel?
Yea a .lrc editor that could be used in conjunction with lyrics show panel would be good. Like you have it in the Lyrics Show Panel context menu. And it should be able to take time stamps from foobar so that you can enter the lyrics of the song and then whenever a line starts you hit a button and it automatically adds the correct time stamp.
Although I guess this would belong in a separate thread to request such a component.
A component like this already exists. It is another lyric display. It can be found on this site at the bottom: http://foo2k.chottu.net/ (http://foo2k.chottu.net/)
The only reason I still use this component is because of the editor, so if an editor like this were included in Lyrics Show Panel, that'd be amazing .
Sorry my Chinese really isn't that strong.
Even if you were Chinese native speaker, it wouldn't help you. It's Japanese. Seriously, altough the side is in Japanese the component itself is in English.
Fine then it's Japanese. Doesn't really make a difference since I can't tell which component is able to do what.
Maybe the online translation (http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Ffoobar2000.xrea.jp%2Findex.php%3FLyrics%2520Panel%2520%25E8%25A7%25A3%25E8%25AA%25AC&lp=ja_en&btnTrUrl=Translate) of the Japanese Wiki can help you. It is sometimes very hard to understand, especially when English is not your first language, but it helped me for the other components on that site.
You don't need to understand the website (which is Japanese) since this component is in English anyways. Also, if you can't figure out WHICH component to download, it's the one at the VERY bottom of the page. Here is a direct link: http://foo2k.chottu.net/foo_uie_lyrics_panel.zip (http://foo2k.chottu.net/foo_uie_lyrics_panel.zip). I will link you to the thread about this specific component so the talk can continue on there since this thread is about T.P. Wang's lyric component. Here is the other topic:
http://www.hydrogenaudio.org/forums/index....showtopic=62476 (http://www.hydrogenaudio.org/forums/index.php?showtopic=62476)
great component!..
feature request: being able to display the active lyric line in the foobar window caption, or maybe the possibility to export it somehow.
I cannot get it to display lyrics with my FLAC files. MP3s work, but not FLAC. I have used the same tagger for both FLAC and MP3.
I have a suggestion to improve that great plugin:
I like a band with a special character in the bandname called "Therapy?". My files of that band are tagged in the same way with a questionmark at the end. Although I know that for the most songs are .lrc files on the server, this panel unfortunately didn't find anything. If I search for "Therapy" without that questionmark the songs are found. What's the point? Minilyrics itself find the songs, never mind if there's a questionmark or not. (On the lyrics - server the bandname is called "Therapy" without special character)
So wouldn't it be possible to improve the search function to simply not read special characters from the file tags?
Hi there...
There's a problem with saving Files to directory...
At the "normal" options page under Preferences -> Tools -> Lyric Show Panels is no option where you can configure how the lyrics are safed as file (*).
You have to right-click on the lyrics panel choosing "Online Search" and under save options there is the field "Safe format"...
So... what you define at the "Safe format" field is what your global safe format is about. This is not very intuitive...
By the way... all my lyrics are stored into .txt-files... but i want to have .lrc-files...
And... I don't wanna use that association manager... it's a good idea... but not everyone wanna use that... why is there no option disabling the assoc-manager?
I have to say... configure this plugin confuses me all the time. There is no consistency... I think a fully rebuild of the option page would solve that problem...
(*) What is the "Lyric file name" field for...? I cannot see any effect by changing values in it... I only got
"Filename : %_filename%.lrc"
in it... but it reads my %_filename%.txt files as well...
Thx,
eNc7
I have a request. Currently when I use Copy Lyrics (without Timestamp) the lyrics are just copied as they are in the .txt or .lrc files. I would like them to copied the way they are displayed in the Panel. So the chorus wouldn't just appear once but would be put wherever it comes.
That would make sharing lyrics online much easier since it's just a c&p job. Right now I have to go to lyrics sites and c&p it from there so that the format is correct.
Currently I won't add any effects on vision, just bug fix and minor updates, sorry.
Yes, I've started it a few months ago but it's far from use.
I don't know what has happed, because Lyric Show Panel use titleformatting to determine which lyric to display, I think it won't have problem if your tag and lyric file is right. I also have a couple of FLAC files, they work good.
I may add something like %lyric_currentline% field to do that.
Planned, thanks for your advice.
@eNc7:
I think you refer to "Save format", it means
file name(exclude ext.) when the lyric is saved, unless you've chosen "embed to file".
All lyrics will be stored as it be (so when you download a .txt lyric file, it won't be saved as .lrc)
If you ask why, I don't know, because it exists for a long time before I made improvements to this component, I think set lyrics.xml readonly will do that trick though....
I'll say that too, it something like junk, however, refactor require a lot of work(in fact, not the UI is bad design, also source code...), I've e're tried to refactor this component, but failed...
I think you shouldn't append ext. to filename. Lyric show will read filename as lrc first, if failed, then read as .txt.
Very strange. My FLAC files conform to standard with only FLAC tags. I do not have any ID3 tags in my FLAC files. This is the recommended way.
I can view lyrics in other players.
0.3.3.1 released. This is not a major releaseVery strange. My FLAC files conform to standard with only FLAC tags. I do not have any ID3 tags in my FLAC files. This is the recommended way.
Can you provide more information?
Are these lyric files stored on hdd, or embeded to FLAC file?
If they are embeded to Flac file, can foobar2000 access them through file Properties window?
The lyrics are embedded in FLAC tags. Yes, foobar can access them through the properties window.
@dypsis:
Strage, I've tested my FLAC(only FLAC tags) files with "LYRICS" and "UNSYNCED LYRICS", doesn't see any problem. Are you using different frame to store LYRIC? And did add "FLAC" to your "skip read / write tag files by filetype" setting? And check your filenames, do they match the critera in "Filter" of Lyric Show configruation (by deafault, you see, skip files which matched Track*;CDImage.*;Unknown*)?
No FLAC in skip read / write tag files by filetype".
Filter is how you posted above.
As for the tags. I just used Tag&Rename. Mp3tag also sees the lyrics.
@dypsis:
So, if your filename are:
Track*.flac
CDImage.flac
Unknow*.flac
Lyirc Show will not load lyric from these files.
You can remove that filter if you want.
@ T.P Wang:
I do not have any FLAC in the filter.
Thanks. The new version is very much appreciated by me .
Hey, I've got question. How do I edit lyrics? When I'm editing file in C:\Program Files\foobar2000\lyrics\ nothing happens... Is there any trick to edit lyrics?
Stupid question, but have you tried to reload the lyrics in foobar after editing the file? Right-click on the lyrics panel and choose "reload lyrics".
Yup, I tried it... I even deleted *.lrc file, then reloaded, but lyrics didn't disappear ;o
Well, if you are sure that the .lrc file is deleted and you still see the lyrics - I would guess that the lyrics may be in multiple locations. Confirm that there is not a track.txt file around that might be getting picked up by foobar as the lyric file or you might want to check the properties of the track in question and see if you have a "lyrics" field with data.
terry
Lyrics are turned on, but after delete .lrc file I can't click option "open directory", which means there's no file xDD I also scanned whole disk for copy of file, but there's no results ;o
Crash log with version 0.3.3.1 (latest):
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 02825966h
Access violation, operation: read, address: 2AB91000h
Call path not available.
Code bytes (02825966h):
02825926h: 54 24 10 8B 35 14 33 86 02 52 FF D6 8B 44 24 14
02825936h: 50 FF D6 8B 4C 24 18 51 FF D6 8B 75 08 83 C6 04
02825946h: 83 C8 FF 33 DB E8 10 BC FF FF 85 FF 75 06 89 7C
02825956h: 24 18 EB 16 33 C0 38 07 74 0C 83 F8 FF 73 07 40
02825966h: 80 3C 38 00 75 F4 89 44 24 18 8B 44 24 18 8B 5E
02825976h: 14 6A 00 40 8B FE E8 CF 09 01 00 83 7E 18 08 72
02825986h: 05 8B 46 04 EB 03 8D 46 04 8B 7C 24 2C 8D 0C 58
02825996h: 8B 44 24 18 8B D7 E8 8F DB 01 00 03 D8 83 C8 FF
Stack (2514FD68h):
2514FD48h: 7C919B3F 7C97C0D8 7C919AEB 028637AC
2514FD58h: 038F9B08 0000FFFF 7FFDE000 00267598
2514FD68h: 038C3438 0289473C 2514FE08 005BAE56
2514FD78h: 00CC000C 00CC0008 00CC0004 00000000
2514FD88h: 00000000 00000B0F 00000B0F 2AB904D8
2514FD98h: 00000B11 028665DC 00000000 028664C4
2514FDA8h: 038DEB00 038F96E6 0000002E 028664C4
2514FDB8h: 00000063 0000012F 0289473C 2514FF34
2514FDC8h: 0285FEC0 00000001 028664C4 02894738
2514FDD8h: 02828855 02894738 05C83A80 02894738
2514FDE8h: 2514FF70 00000000 02890000 00000000
2514FDF8h: 0284B529 05C83A80 00000000 2514FE94
2514FE08h: 00640041 00670061 006F0069 00000000
2514FE18h: 00000006 00000007 415BAE56 038C3438
2514FE28h: 0284B529 02828704 02892758 00000008
2514FE38h: 0000000F 028285A7 05C83A80 02894738
2514FE48h: 2514FF70 00000000 004A0519 00000038
2514FE58h: 0000003B 00000098 038F0000 05DF4728
2514FE68h: 05D6F698 00000000 00000000 00000007
2514FE78h: 00000034 02894888 02867984 00000000
Registers:
EAX: 00000B28, EBX: 00000000, ECX: 00000000, EDX: 038F9628
ESI: 0289473C, EDI: 2AB904D8, EBP: 2514FDD4, ESP: 2514FD68
Crash location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Loaded modules:
foobar2000 loaded at 00400000h - 00527000h
COMDLG32 loaded at 763B0000h - 76405000h
IMM32 loaded at 76390000h - 763AD000h
uxtheme loaded at 5AD70000h - 5ADA8000h
foo_abx loaded at 00AA0000h - 00AD1000h
foo_albumlist loaded at 00B00000h - 00B66000h
foo_audioscrobbler loaded at 00B90000h - 00BC0000h
foo_bubble_coverflow loaded at 00C20000h - 00CA9000h
OPENGL32 loaded at 5ED00000h - 5EDCC000h
GLU32 loaded at 68B20000h - 68B40000h
DDRAW loaded at 73760000h - 737A9000h
DCIMAN32 loaded at 73BC0000h - 73BC6000h
foo_cdartdisplay loaded at 016E0000h - 01711000h
foo_cdda loaded at 01740000h - 01778000h
foo_channel_mixer loaded at 017A0000h - 017DA000h
foo_chronflow loaded at 017F0000h - 01851000h
foo_converter loaded at 01A00000h - 01A66000h
foo_dbsearch loaded at 01A90000h - 01AEC000h
foo_discogs loaded at 01B10000h - 01BA4000h
foo_dsp_delta loaded at 01BC0000h - 01BDE000h
foo_dsp_std loaded at 01C00000h - 01C46000h
foo_dumb loaded at 01C70000h - 01CF9000h
foo_fileops loaded at 01D20000h - 01D66000h
foo_freedb2 loaded at 01D90000h - 01DD0000h
foo_input_monkey loaded at 01DF0000h - 01E33000h
foo_input_shorten loaded at 01E60000h - 01E8D000h
foo_input_std loaded at 01EB0000h - 01FD7000h
foo_input_tak loaded at 02000000h - 02047000h
tak_deco_lib loaded at 02060000h - 02091000h
foo_lnk loaded at 021C0000h - 021D9000h
foo_masstag loaded at 02200000h - 02250000h
foo_osd loaded at 02270000h - 022A6000h
foo_out_asio loaded at 022D0000h - 022FE000h
foo_out_ks loaded at 02320000h - 0234A000h
SETUPAPI loaded at 77920000h - 77A7D000h
foo_playcount loaded at 02370000h - 02399000h
foo_playlist_manager loaded at 023C0000h - 02406000h
foo_pqview loaded at 02430000h - 0244C000h
foo_random loaded at 02470000h - 024AF000h
foo_rgscan loaded at 024D0000h - 0252B000h
foo_run loaded at 02550000h - 0257B000h
foo_sendtodevice loaded at 025A0000h - 025DD000h
foo_tradersfriend loaded at 02600000h - 0263D000h
foo_uie_albumart loaded at 02660000h - 0269D000h
foo_uie_albumlist loaded at 026C0000h - 02703000h
foo_uie_console loaded at 02730000h - 0274C000h
foo_uie_graphical_browser loaded at 02770000h - 02804000h
MSIMG32 loaded at 76380000h - 76385000h
foo_uie_lyrics loaded at 02820000h - 0287C000h
WININET loaded at 771B0000h - 7725A000h
foo_uie_playlists_dropdown loaded at 028A0000h - 028DA000h
foo_uie_quicksearch loaded at 02950000h - 02996000h
foo_uie_vis_channel_spectrum loaded at 029A0000h - 029C8000h
foo_uie_vis_projectm loaded at 029D0000h - 02A1A000h
foo_ui_columns loaded at 02A40000h - 02B69000h
foo_ui_ipanels loaded at 02B90000h - 02C69000h
ILU loaded at 02C80000h - 02C93000h
DevIL loaded at 02CA0000h - 02E2A000h
d3dx9_37 loaded at 02E30000h - 031E7000h
d3d9 loaded at 4FDD0000h - 4FF76000h
d3d8thk loaded at 6D990000h - 6D996000h
foo_ui_std loaded at 03300000h - 033D3000h
foo_utils loaded at 03400000h - 03439000h
foo_vis_shpeck loaded at 03460000h - 03496000h
atioglx2 loaded at 69010000h - 69AEB000h
mswsock loaded at 71A50000h - 71A8F000h
DNSAPI loaded at 76F20000h - 76F47000h
rasadhlp loaded at 76FC0000h - 76FC6000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
WINTRUST loaded at 76C30000h - 76C5E000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
ksuser loaded at 73EE0000h - 73EE4000h
mslbui loaded at 605D0000h - 605D9000h
wsock32 loaded at 71AD0000h - 71AD9000h
NETAPI32 loaded at 5B860000h - 5B8B4000h
iphlpapi loaded at 76D60000h - 76D79000h
urlmon loaded at 7E1E0000h - 7E282000h
Hook loaded at 0F350000h - 0F35E000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77118000h
shdocvw loaded at 7E290000h - 7E401000h
CRYPTUI loaded at 754D0000h - 7555D000h
WLDAP32 loaded at 76F60000h - 76F8C000h
xpsp2res loaded at 20000000h - 202F9000h
DBGHELP loaded at 59A60000h - 59B01000h
Address: 028665DCh, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 028664C4h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0285FEC0h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 02828855h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0284B529h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 02828704h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 028285A7h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 004A0519h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 02867984h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 004F5EE8h, location: "foobar2000", loaded at 00400000h - 00527000h
Address: 02860075h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 02827F09h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 7C91A5AFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeSid" (+000000F2h)
Address: 0284FB01h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0284FCDBh, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 02860548h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0284B7A1h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0284F850h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 0284B849h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 0284B7C7h, location: "foo_uie_lyrics", loaded at 02820000h - 0287C000h
Version info:
foobar2000 v0.9.5.3
UNICODE
Windows 5.1
Additional info:
Columns UI 0.3 beta 2 preview 11d (foo_ui_columns)
DUMB module decoder 0.9.8.4 (foo_dumb)
CD Audio Decoder 2.1.2 (foo_cdda)
Lyric Show Panels 0.3.3.1 [Jun 22 2008 - 23:58:43] (foo_uie_lyrics)
Kernel Streaming Output 1.2.2 (foo_out_ks)
iPanels 0.0.3 (foo_ui_ipanels)
TAK Decoder 0.3.2 (foo_input_tak)
Default User Interface 0.9.5 (foo_ui_std)
Database search 1.3.1 beta 11 (foo_dbsearch)
foobar2000 core 0.9.5.3 (Core)
Live show tagger 0.6.1 (foo_tradersfriend)
File Operations 2.1 (foo_fileops)
Monkey's Audio decoder 2.0 (foo_input_monkey)
Audioscrobbler 1.3.16 (foo_audioscrobbler)
Cover Flow 0.19 (foo_bubble_coverflow)
Playback Statistics 2.1.4 (foo_playcount)
Discogs Tagger 1.13 (foo_discogs)
Randomized playlist entry 1.2.3 (foo_random)
Shorten decoder 0.4.2a (foo_input_shorten)
Standard DSP Array 1.0 (foo_dsp_std)
Playlist tools 0.5.7 (foo_utils)
Converter 1.1.1 (foo_converter)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
Album Art Panel 0.2.7.1 (foo_uie_albumart)
Album List 4.2.2 (foo_albumlist)
ABX Comparator 1.3.3 (foo_abx)
Playlists Dropdown 0.5.7.5 (foo_uie_playlists_dropdown)
Playlist Manager 1.0 (foo_playlist_manager)
Chronial's Coverflow 0.3.0 (foo_chronflow)
CD Art Display Interface 2.0 beta 134 (foo_cdartdisplay)
Graphical Browser rev015 (foo_uie_graphical_browser)
freedb Tagger 0.6 (foo_freedb2)
Run services 0.3.2 (foo_run)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Shell link resolver 1.1 (foo_lnk)
Shpeck - Winamp vis plug-ins wrapper 0.0.7 (foo_vis_shpeck)
On-Screen Display GDI+ 1.52 (foo_osd)
ReplayGain Scanner 2.0.6 (foo_rgscan)
Console panel 0.2 (foo_uie_console)
Channel Mixer 0.9.4 (foo_channel_mixer)
Send to Device 1.1.1 [Sep 7 2007 - 10:34:03] (foo_sendtodevice)
Channel Spectrum panel 0.07 (foo_uie_vis_channel_spectrum)
projectM visualization (Panel) 0.4 (foo_uie_vis_projectm)
It crashed a couple of times with the previous version I had installed, too (don't remember which, but it must have been more or less recent).
And did you select the song > Right click > Properties ; to check to see if you have embedded the lyrics into a <lyrics> field?
terry
@Sasori:
Check your tag field such as UNSYNCED LYRICS and LYRICS, depend on your setting in Lyric show, and also check if you turned on "automatically search" in Internet Tab.
@Hakubo:
I'll check it later.
Can I use this component with default UI?
Thank you!
For some reason, this component messes with apostrophes. It puts them at the bottom where periods usually are. Does anyone else have this issue?
Thank you!
Yes and No.
No for this is not UI element for DUI.
Yes for here's a component called docakable panels, which can hold CUI extension in an sperate window
Can you give me some examples?
Yeah here are some screen shots:
(http://img.photobucket.com/albums/v326/keikonium/apos1.jpg)
(http://img.photobucket.com/albums/v326/keikonium/apos2.jpg)
Oddly enough, some apostrophes show up fine, but others don't. I haven't figured out why o.O. Here is a written example for testing if you want:
I found a way
Over the fear and through the flames
I'm diving in don't follow me
Stay right here I’ll be back for you someday
I found a way
It'd be best if you just stayed
It's not safe don't follow me
I found a way
I found a way
I found a way
I found a way
I found a way
I found a way
The one's that are not working [I'll] are not apostrophes [']. Don't know what keyboard character it is, but if you erase and replace all is well
terry
Really o.O?? This lyric example is one that I had written out myself with my keyboard. I had used the character that is right beside the Enter button for BOTH entries, and only one of them had messed up. I didn't realize they were different characters haha. Doesn't make sense, but it'll be a pain in the butt to fix all my lyrics that have this problem.
Can these "unknown" characters be fixed tho TP?
Those are accents not apostrophes.
@Keikonium:
I don't know why, beacuse they work well on my machine.
But I can see one thing that "’" is in "SBC case"(takes two bytes), that means if you don't have mapped your font to a eastern font, I think it's not possible to display these characters except use a unicode / eastern font.
Thanks! I found them. They're embedded in file, but only in foobar. When I check Properties of file, (not in foobar, in windows) "Lyrics" field is empty. Is there any way to embed lyrics in file automatically?
@Keikonium:
Hmm, I don't think I have changed anything related to character sets. Here are my settings:
http://keikoniumboards.ke.funpic.org/files...icsettings.lspd (http://keikoniumboards.ke.funpic.org/files/lyricsettings.lspd)
By defaults, Lyric Show will not embed file automatically. However, you can check setting in
#'Setting' -> 'When found lyric from directory'
#'Internet' -> 'Save scheme'
I see you're using "
@Arial Unicode MS", I think you should use "Arial Unicode MS" instead(Yes, I meet your problem when using any font with name start with
I see you're using "@Arial Unicode MS", I think you should use "Arial Unicode MS" instead(Yes, I meet your problem when using any font with name start with '@').
Good man! That fixed me right up. No idea why those stupid @ fonts are there... they screwed with my Panels layout a while back too. But anyways, thanks TP .
I want to right click on an mp3 and find lyrics, which I want to see and not save anywhere (file or tag). Is it possible with this component? How?
If not which component should I use?
Thank you!
Yeah, but it embed lyric to file in foobar, but when I click "Properties" on file on Windows, there's a blank place in "Lyrics"...
I have a problem with the autoscroll. it doesn't work. It does scroll when I open the preferences window window, well at least for one moment. I could go and open the preference window a million times evertime I want the lyrics to scroll, but that's not exactly nice.
The zh-CH_special version of foo_uie_lyrics.dll 3.1.1 seems to work fine...but I can't find an english working version...
edit: even that strange language (which only gives blocks on my PC) doesn't seem to work now and i'm using the latest version of columns plugin.
edit: it seems like it's just not refreshing the lyrics panel. Might be some setting...anybody has a clue which one?
edit2:strangely enough when i locked and unlocked the panel, it seems to work again...
can u add support for "layout editing mode" in the default ui?
There is already Text Display (foo_textdisplay) which supports lyrics, comments etc. and works well for the default UI.
dypsis: but doesn't support scrolling, LRC lyrics I just want to new SDK be out, so this kind of components (Lyrics Show Panel) will be as UI Elements…
can you add a float window like lyricist do? or just add a option to scroll the lyrics vertically but not horizontally?
Lyrics not scrolling
Hi all - posted this in the general 3rd party forum last week, but I guess I should have put it here.
Just installed lyric show. Am using default ui and dockable panels for the lyrics.
At first install lyrics scrolled. Then I changed the align from center to left, changed some font and background colors and no more scroll. Changed back to center, back to default fonts, still no scroll. Maybe I changed some other settings, not sure. What are the defaults, so I can go back to where it was at the start? Or should I uninstall and reinstall? Does this mean just removing the dll, running foobar, and then reinstalling the dll? Thanks
PS - scrolling is enabled.
Thanks for the help.
0.3.3.2 update with minor fixes.
@arnstein:
Can you try 0.3.3.2 and enable "Output verbose debugging information" in the configruation and post log in your console? (All related information is started with "foo_uie_lyrics:")
Installed new version and scrolling's back, thanks.
I have a request, I don't know how feasable it is, but it doesn't hurt to ask.
I am in the process of making a website with lyrics to ALOT of songs. Right now I have to manually copy the lyrics, paste them into a file, add a header and footer to that file, and upload it to my website.
So my request is if you could add a feature where we can export lyrics to a file (text file is fine) and append a predetermined header and a footer to the file that we set in preferences or something. This would make my work all that much easier.
Also, for some reason, I can't use the mouse wheel to scroll non timestamped lyrics anymore o.O. I am using the latest version.
Forgive me for asking, but aren't you going to use a db as back-end of your web site?
Alessandro
Alessandro
Nope, the main purpose for my site is I have hand written quite a bit of the lyrics myself because I have tons of demos / live / acoustic / alternate versions / remixes etc of songs. Each song has the exact words spoken in that specific file, and sometimes things are added / removed / changed around etc depending on the song versions.
Stuff like that isn't easy to come across on the net cause many people don't bother doing it because it takes to long. This is gonna be a fan site (not a general purpose lyrics site for thousands of bands) but it's still around 1000 songs+ at the moment.
I was thinking of using Text Tools to do this since it was header / body / footer fields, but it doesn't export to a file, which would be really helpful for me.
One other thing that bothers me is the inaccuracy of some lyrics floating around. no proper capitalization, punctuation, and misspellings.
A function to edit lyrics right out of the panel would be nice. Just open the txt or lrc file in a text editor
not sure if this has been mentioned, but when adding an offset, the embedded tag doesn't close the bracket on its line.
Is it possible to show lyrics panel only if lyrics are available?
You mean only export tags? That won't require too much work to implement. Contact me with PM, I may have more separate time since Sep, 15th.
Just since use latest version? or not? I do not touch these code, I think...
Confirmed, will be fixed in the next build. Thanks for reporting.
Thank you for your replies, I will contact you via PM about the first request.
As for the scrolling, I am not 100% sure what's going on, but when I hover over the lyrics panel, and use the scroll wheel nothing happens. It used to scroll if the lyrics were not time stampped. This has happened since I updated foobar to version 0.9.5.2 beta 2 and uninstalled SetPoint (it was causing crashes in another program I use). Scrolling worked fine with every recent lyrics show version, and foobar beta 1, so maybe it's beta 2 or something causing the issue . I also use the Panel in Panels UI, but the scrolling doesn't work in CUI either.
I will reinstall SetPoint and see if that was the culprit, and I shall report back if it changes.
My thanks to the creator of this pgrm!! Works great.
I don't know if this has been answered yet, but is there a function on this pgrm to auto time stamp musics? And can it be used for text in Unicode?
I'm sorry if this has been answered but 22 pages is alot to scroll through....
No this lyrics component cannot time stamp lyrics, but there is another lyric component that can. It can be found here: http://foo2k.chottu.net/ (http://foo2k.chottu.net/) (bottom of the page). I am pretty sure it is no longer being developed however.
On a related note, T.P Wang, do you think you could get in contact with the creator of the lyrics component in question, and implement a time stamper in your lyrics component also? The only reason I still use the other one is for the time stamping abilities. Or if you can't get help from him, maybe implement your own version that is similar?
It's very useful I think, and would be appreciated by many who like to display lyrics.
Alright thanks and yea an option to timestamp on this plug-in would b nice. Thank for the plug in! I don't think I'll switch to the one with timestamp since this one is nice.
Heh, I didn't try this plugin because I usually stay away from "modified versions" (often made by someone less skilled than the original developper who just adds a bunch of useless features), but since the original while is not updated anymore I thought I'd give this one a try.
And I must say it's really good ! I especially love the ability to update lyrics if it finds timestamped ones.
btw, where does it get the lyrics from ?
edit : two small bugs though :
-When you scroll with the mousewheel there's no limit : you can scroll higher or lower than the lyrics :-/
-When your cursor is over the lyrics panel it's as if the window loses focus : the highlighted elements in the playlist get unfocused.
ok I skipped reading the topic from the beginning after all these "works like charm" "it's great" "nice" replies.
So my question is: why can't you have 2 lyrics panels at the same time?
This is a really nice plugin. One thing I've found though, is that the left and right arrow keys don't skip to next or previous track when the lyrics panel has focus, which is kind of annoying. I don't know if this is intended, if they have another function on the lyric panel or what...
Fixed in 0.3.3.3
It's by designed, it will return focus while you move mouse out. though, I remove them now, it's of use if you use a notebook and without mouse(use key up/down, and in 0.3.3.3, you can use page up/down, only if Lyric Show Panel get focused)
It
beyonds me
A wild guess is that the implementer stores data that should be per-instance globally or statically, and thus clobbers himself hard.
0.3.3.3 seems to have weird problems. Lyrics that are downloaded seem odd. Not sure if it's the fault of the files that were downloaded or the component. Then if I try to manually download lyrics it doesn't seem to work or it's so slow that I can't be bothered to wait that long.
Edit: Hum reverting to the last version didn't change anything...
Same here, now i can't even download lyrics 99% of the time because it says it's either searching or downloading but it never completes it's task. I noticed this started happening like 2-3 days ago. Weird, probably something wrong with the server the lyrics are downloaded from.
It's just extremely slow at searching. You can force a quick dl by double clicking the lyrics.
Yeah, I've noticed it being really slow lately as well. This a new occurrence since it used to be nearly instantaneous. I think it must be a server issue (and hopefully it will be fixed soon).
why this lyric db is so incomplete?
It sucks!
Can I use another db to do the search online?
It sucks!
+1 Oh, and besides that i could not get this thing working thru proxy (CCProxy).
It sucks!
Lyrics grabber works well, although it's not time-encoded:
http://www.hydrogenaudio.org/forums/index....showtopic=62821 (http://www.hydrogenaudio.org/forums/index.php?showtopic=62821)
I personally try to get the time-encoded one first, and then if it's not accurate or it doesn't exist then I just use another one.
Can I request a feature?
After I choose one codepage for a lyric, the next time the component can remember codepage so I won't have to choose the codepage again?
I hope this can be considered.
@Shoujo Pi:
It has already been done (since 0.3.1.1b8 DEV)
Eh? I'm using 0.3.3.3 Sep 23 2008 14:15:11 and it doesn't remember the codepage.
It should be.
However, you should check if your association file (lyrics.xml) is not read only.
If you change code page, they should apear in the xml file like this:
<Association src="***********\Lichtgestalt\02. Kelch Der Liebe.mp3" index="0" disabled="false" codepage="28599">C:\Users\*******\AppData\Roaming\lyrics\Lacrimosa - Kelch Der Liebe.lrc</Association>
Where do I find the association file? I embed all my lyrics.
I haven't add support to to embeded lyrics just because I think all lyrics embed should be already in Unicode(UCS-2 in ID3v2.3, UTF8 in ID3v2.4).
I may add it in the next release.
Most lyrics I download from the db is not in unicode. Some of them already is, but most still not in unicode.
Thank you.
This is an idea. But maybe you can make the component convert non-unicode lyric download to unicode? That way it doesn't need to remember the codepage, as the lyrics will automatically be stored in unicode. Is this possible though?
0.3.3.4 released.
codepage changes now take effect on emebed lyrics
offset adust now work correctly(and will save as UTF8 if saving lyric file)
0.3.3.4 released.
thanks for keeping it up to date
Thank you for the update
Just one small problem, when I am using it for streaming LastFM songs, the lyrics jerk as they scroll up, but they are perfectly smooth when I play songs from my database, any idea what would cause this?
Thank you!
hi guys, i got a problem when use this pluging.
the settings of this pluging is default.
I use online search to search a lyric and download it sucessfully, it be stored in configuration folder (by default setting), and the lyric shows up normally. but when I playback this song again, the lyric doesn't shows up !
Only If i restart foobar then playback this song again, the lyric can be found and shows up normally.
Is it normal or is it the problem of settings?
i have a strange problem with this plugin (using foobar 0.9.6. beta 3, foo_ui_columns 0.3.5.4, foo_uie_lyrics 0.3.3.4)
i have set the lyrics folder to be inside foobar's directory (c:\media\foobar2000\lyrics)
i have also set the lyric filename to be %artist% - %title%
i've also set skip access from files *.wav *.mp3 *.mp4 *.aac, because i don't want lyrics in my tags.
internet settings: download automatically and filter artist when download checked
and set the save scheme to save to folder (no update to tags)
when i play some of my songs, they don't show up, but when i manually go to the online search, they get found. i don't understand why do i have to manually search for them?
when i manually add .lrc or .txt file to c:\media\foobar2000\lyrics, they don't show in panel.
i don't understand why it doesn't work when i manually add lyrics files to this folder.
so this panel only shows lyrics if they are found automatically (which not always works) or if i manually do an online search. is that an expected behaviour?
basically, what i'd like to know, why some of lyrics aren't found automatically, but when i go to online search i can find them?
@jeremija:
I don't know, but I'll recommed you to enable "Output verbose debugging information" in Misc tab
and play a track as you like:
1. Check autodownload funtionallity:
# If nothing shows up in console like "foo_uie_lyrics: SearchThreadProc", that means your filter setting is not correct.
# If there's such information like that but followed with some Win32 I/O error, please let me know.
@jeremija:
Thank you for such a fast reply!
First i deleted all downloaded lyrics, then removed all associations and enabled the debug mode. Then restarted foobar. All my songs have all tags (title, artist, album, date, genre).
The log is a bit strange, first i played Albert Collins - Honey Hush, and there was nothing about the search in the log. Then i played Albert Collins - Cold Cold Feeling, and there was nothing again. Later i tried to search for these lyrics manually and i got no results.
Then i played America - A Horse With No Name, the lyrics were found this time, but no file saved, and nothing in the log.
Bad Company - Can't Get Enough, lyrcs were shown and saved, log entry also exists.
Then i tried a song for which i thought there will be no result, but they were, and also, lyrics were found, displayed and saved to file.
Lastly i played Me and My Bobby Mcgee, a song for which i knew i will get no lyrics displayed, even though the manual search finds the lyrics. Again, nothing in the log.
Note that during this log i did not try manual search.
edit: now it seems that more lyrics are downloaded than before, but still no autodownload for me and my bobby mcgee and albert collins songs from ice picking album, normal search has results...
i just don't understand why are there no queries for some songs...
edit2: hmmm, i copied Albert Collins Honey Hush track to another folder, still no lyrics, but then i removed all tags in the properties window and added Albert Collins to artist and Honey Hush to track tab and now it works :/ :/
don't get it, i mean, foobar sees those tags fine, why doesn't it work with this plugin?
edit3: i think i finally solved it, really don't understand why were Blues and New Wave in the default filter list. I just realized that both Janis Joplin and Albert Collins and Eric Clapton and many others had the genre tag Blues. Removed them from the filter and it seems to work now. Will report if anything seems wrong!
Watching: C:\Users\Jere\Music
Columns UI/Tab stack: Warning: Lyric Show panel was visible on creation! This usually indicates a bug in this panel.
tree generated in : 0:00.150098
Startup time : 0:00.805652
Opening track for playback: "C:\Users\Jere\Music\Albert Collins\1978 Ice pickin'\01 - Honey Hush!.mp3"
Handshake successful.
Opening track for playback: "C:\Users\Jere\Music\Albert Collins\1978 Ice pickin'\04 - Cold Cold Feeling.mp3"
Opening track for playback: "C:\Users\Jere\Music\America\2001 The Complete Greatest Hits\01 - A Horse With No Name.mp3"
Opening track for playback: "C:\Users\Jere\Music\Bad Company\1974 Bad Company\01 - Can't Get Enough.mp3"
foo_uie_lyrics: SearchThreadProc: started.
foo_uie_lyrics: SearchThreadProc: for file://C:\Users\Jere\Music\Bad Company\1974 Bad Company\01 - Can't Get Enough.mp3 /index: 0.
foo_uie_lyrics: SearchThreadProc: search retry: 0
foo_uie_lyrics: SearchThreadProc: return [true].
foo_uie_lyrics: DownloadThreadProc: started.
foo_uie_lyrics: DownloadThreadProc: for file://C:\Users\Jere\Music\Bad Company\1974 Bad Company\01 - Can't Get Enough.mp3 /index: 0.
foo_uie_lyrics: DownloadThreadProc: search retry: 0
foo_uie_lyrics: DownloadThreadProc: downloading lyric from: http://www.viewlyrics.com/up/upe/0903/Bad%20Company%20-%20Can't%20Get%20Enough.lrc
foo_uie_lyrics: DownloadThreadProc: return [true].
Opening track for playback: "C:\Users\Jere\Music\Azra\1982 Filigranski Plo?nici\CD1\Azra - Iran.mp3"
foo_uie_lyrics: SearchThreadProc: for file://C:\Users\Jere\Music\Azra\1982 Filigranski Plo?nici\CD1\Azra - Iran.mp3 /index: 0.
foo_uie_lyrics: DownloadThreadProc: for file://C:\Users\Jere\Music\Azra\1982 Filigranski Plo?nici\CD1\Azra - Iran.mp3 /index: 0.
foo_uie_lyrics: DownloadThreadProc: downloading lyric from: http://www.viewlyrics.com/up4/080702/Azra%20-%20Iran.txt
Opening track for playback: "C:\Users\Jere\Music\Janis Joplin\1970 Pearl\07 - Me And Bobby Mcgee.mp3"
Is there a basic guide to using this, I haven't figured it out.
I believe you need to "associate" the said lyric file. Explore the context menu a little bit.
I have a question about embedded lyrics. What is the standard id3v2.4 tag for that? LYRICS? Anyway, I am also using minilyrics as my lyrics editor, it seems to have it own system of embedding lyrics that only works with Windows Media Player. Is there a good lyrics editor somewhere?
I have a strange problem while using this plugin.
I'v set the download path to the same directory with music file. When I download the lyric, it displayed correctly. But When I reopen the song, the lyric can't be found any more.
I've also tried to set the search path to $directory_path(%path%), but it doesn't worked for me.
So, what should I do next?
Hi T.P. Wang,
On start-up the console displays the following message:
If indeed it is a bug is it possible for you to fix this? Thanks for all your work on this component.
Restart foobar2000.
Seriously, there is only one problem with this component and it's that the lyrics will display once downloaded but on a second play without restart, the panel shows blank. You guys should have figured to restart foobar2000 anyway, because other than that, this plugin is essentially perfect.
@wangyi6854:
You can give me your screenshot of the configruation of Lyric Show, just via PM, you can also decribe it in chinese via PM, but not here.
@aphasia:
Yes, It's a bug, I think it exists for a long time before I start to mod this component. I'll post a quick fix soon.
0.3.3.5 Released, with two bug fix(see changlog for details)
works fine.
Thanks very much!
Um, this happened just after I updated to 0.3.3.5. Before I updated, foobar2000 works just fine. But after I updated to 0.3.3.5, this always shows up when I try to start foobar2000.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 020B33FCh
Access violation, operation: read, address: 00000000h
Call path:
entry=>user_interface::init=>Create splitter host=>Create splitter host
Code bytes (020B33FCh):
020B33BCh: 04 75 17 8B 48 08 3B 4E 08 75 0F 8B 50 0C 3B 56
020B33CCh: 0C 75 07 5F 32 C0 5E C2 04 00 5F B0 01 5E C2 04
020B33DCh: 00 CC CC CC A1 C4 11 10 02 56 57 8B F1 85 C0 74
020B33ECh: 64 8B 4C 24 0C 51 50 FF 15 84 32 0F 02 8B 4E 64
020B33FCh: 8B 11 A1 C4 11 10 02 8B 52 30 50 FF D2 8B 44 24
020B340Ch: 10 8B 38 85 FF 74 09 8B 17 8B 42 04 8B CF FF D0
020B341Ch: 8B 4E 64 85 C9 74 06 8B 11 8B 02 FF D0 8B 44 24
020B342Ch: 14 6A 04 89 7E 64 8B 48 0C 8B 50 08 51 8B 48 04
Stack (0034E24Ch):
0034E22Ch: 00000000 00000000 00000000 00000000
0034E23Ch: 00000000 00000000 00000000 00000000
0034E24Ch: 018CC0D8 018CE8A0 01A20FA2 00060B24
0034E25Ch: 0034E274 01A3F61C 428B0A77 018CE8A0
0034E26Ch: 0034E2AC 00000000 018CE8A0 0034E2C8
0034E27Ch: 01A2EDB7 00000000 01A22FE4 018C26B8
0034E28Ch: 018CE758 00000000 01A33A68 00000014
0034E29Ch: 018C26B8 0034E2DC 100025D2 01A33A68
0034E2ACh: 0034E328 01A20CD5 00310A0A 428B0AA3
0034E2BCh: 018CC1B0 018C26B8 00000000 0034E2F8
0034E2CCh: 01A2ED71 00000000 01A20FA2 00310A0A
0034E2DCh: 00000031 01A3F61C 428B0AF7 018C26B8
0034E2ECh: 0034E328 00000019 018C26B8 0034E344
0034E2FCh: 01A2EDB7 00000000 01A22FE4 02F2EFD0
0034E30Ch: 018C0E98 02F2EF90 00000014 02F2EFD0
0034E31Ch: 0034E358 100025D2 01A33A68 0034E434
0034E32Ch: 01A20CD5 00100A3A 428B0B27 00000000
0034E33Ch: 018C0E98 02F2EF90 0034E428 01A2ED71
0034E34Ch: 00000000 02DDEBC0 00100A3A 0000001B
0034E35Ch: 02E98F54 4380920F 00000001 02F2EF90
Registers:
EAX: 00310A0A, EBX: 00000000, ECX: 00000000, EDX: 77D60F34
ESI: 024A7E28, EDI: 018CC0D8, EBP: 0034E2AC, ESP: 0034E24C
Crash location: "foo_uie_lyrics", loaded at 020B0000h - 0210C000h
Loaded modules:
foobar2000 loaded at 000E0000h - 00219000h
ntdll loaded at 77D00000h - 77E1E000h
kernel32 loaded at 77E60000h - 77F38000h
COMCTL32 loaded at 75600000h - 75794000h
msvcrt loaded at 768C0000h - 7696A000h
ADVAPI32 loaded at 77760000h - 7781F000h
RPCRT4 loaded at 77BE0000h - 77CA3000h
GDI32 loaded at 767E0000h - 7682B000h
USER32 loaded at 76710000h - 767AE000h
SHLWAPI loaded at 77A50000h - 77AA5000h
SHELL32 loaded at 76C90000h - 7775E000h
ole32 loaded at 765C0000h - 76704000h
shared loaded at 10000000h - 1002A000h
UxTheme loaded at 74EF0000h - 74F2F000h
COMDLG32 loaded at 769F0000h - 76A64000h
IMM32 loaded at 77E40000h - 77E5E000h
MSCTF loaded at 77980000h - 77A47000h
LPK loaded at 77E20000h - 77E29000h
USP10 loaded at 76970000h - 769ED000h
guard32 loaded at 00090000h - 000B3000h
fltlib loaded at 76440000h - 76447000h
winsta loaded at 76410000h - 76434000h
TFWAH loaded at 01190000h - 011D1000h
OLEAUT32 loaded at 76830000h - 768BC000h
RocketDock loaded at 00350000h - 00362000h
PSAPI loaded at 76520000h - 76527000h
lgscroll loaded at 10100000h - 1010E000h
MSVCR80 loaded at 758A0000h - 7593B000h
NTMARTA loaded at 753B0000h - 753D1000h
WLDAP32 loaded at 76C40000h - 76C89000h
WS2_32 loaded at 767B0000h - 767DD000h
NSI loaded at 76C30000h - 76C36000h
SAMLIB loaded at 76040000h - 76051000h
foo_uie_wsh_panel loaded at 011F0000h - 01224000h
gdiplus loaded at 75450000h - 755FA000h
foo_input_std loaded at 01730000h - 0186C000h
foo_cdda loaded at 015E0000h - 01621000h
foo_uie_quicksearch loaded at 01630000h - 01676000h
foo_dsp_std loaded at 01690000h - 016D8000h
foo_abx loaded at 01870000h - 018A1000h
foo_uie_panel_splitter loaded at 01A00000h - 01A48000h
foo_uie_trackinfo_mod loaded at 01A80000h - 01AD6000h
MSVCP80 loaded at 71E30000h - 71EB7000h
foo_uie_playlists_dropdown loaded at 01F40000h - 01F79000h
foo_uie_elplaylist loaded at 01F80000h - 01FE7000h
foo_rgscan loaded at 02050000h - 020AB000h
foo_audioscrobbler loaded at 01FF0000h - 02020000h
foo_uie_lyrics loaded at 020B0000h - 0210C000h
WINMM loaded at 757E0000h - 75813000h
OLEACC loaded at 757A0000h - 757D8000h
WININET loaded at 77820000h - 778F0000h
Normaliz loaded at 77E30000h - 77E33000h
iertutil loaded at 77CB0000h - 77CF5000h
foo_input_monkey loaded at 02280000h - 022C5000h
foo_dsp_soundtouch loaded at 02140000h - 02166000h
foo_fileops loaded at 02410000h - 02456000h
foo_albumlist loaded at 025B0000h - 0261B000h
foo_uie_vis_channel_spectrum loaded at 02460000h - 0249D000h
MSIMG32 loaded at 75C80000h - 75C85000h
foo_lyricsgrabber loaded at 74620000h - 74674000h
foo_unpack loaded at 02650000h - 0267D000h
foo_chronflow loaded at 02680000h - 026E1000h
OPENGL32 loaded at 744E0000h - 745AB000h
GLU32 loaded at 74790000h - 747B3000h
DDRAW loaded at 6F350000h - 6F436000h
DCIMAN32 loaded at 6FEA0000h - 6FEA6000h
SETUPAPI loaded at 76A70000h - 76BF9000h
dwmapi loaded at 73BF0000h - 73BFC000h
foo_ui_columns loaded at 02D90000h - 02EBD000h
foo_freedb2 loaded at 02750000h - 02790000h
foo_uie_graphical_browser loaded at 6EDA0000h - 6EE34000h
foo_playcount loaded at 02790000h - 027BA000h
foo_converter loaded at 029A0000h - 02A0C000h
foo_ui_std loaded at 03180000h - 03254000h
foo_uie_albumlist loaded at 028F0000h - 0292C000h
mscms loaded at 747C0000h - 74822000h
WINSPOOL loaded at 73320000h - 73361000h
USERENV loaded at 76470000h - 7648E000h
Secur32 loaded at 76450000h - 76464000h
icm32 loaded at 745B0000h - 745E8000h
nvoglv32 loaded at 69500000h - 69A7D000h
SXS loaded at 762F0000h - 7634F000h
CLBCatQ loaded at 778F0000h - 77974000h
jscript loaded at 6D8B0000h - 6D928000h
rsaenh loaded at 75990000h - 759C8000h
imagehlp loaded at 76C00000h - 76C29000h
dbghelp loaded at 70CC0000h - 70D9C000h
Address: 01A20FA2h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+0000DDA2h)
Address: 01A2EDB7h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+0001BBB7h)
Address: 01A22FE4h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+0000FDE4h)
Address: 01A33A68h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+00020868h)
Address: 100025D2h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uCallStackTracker::uCallStackTracker" (+0000002Fh)
Address: 01A20CD5h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+0000DAD5h)
Address: 01A2ED71h, location: "foo_uie_panel_splitter", loaded at 01A00000h - 01A48000h
Symbol: "foobar2000_get_interface" (+0001BB71h)
Address: 00100A3Ah, location: "foobar2000", loaded at 000E0000h - 00219000h
Address: 02DDEBC0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02E750CCh, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000437ECh)
Address: 02E76E60h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00045580h)
Address: 02E7367Ch, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00041D9Ch)
Address: 02E631CEh, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000318EEh)
Address: 02DDFE0Ah, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 000A0A18h, location: "guard32", loaded at 00090000h - 000B3000h
Address: 767324AFh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "SetWindowLongW" (+00000065h)
Address: 76732539h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 76732545h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 767776CCh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "AlignRects" (+00001926h)
Address: 02E30146h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 76731A10h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 76733123h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetWindow" (+0000010Fh)
Address: 02E2FFB0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 76731A91h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+000000EFh)
Address: 76731C03h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+00000261h)
Address: 76728562h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetThreadDesktop" (+000008C8h)
Address: 767624BAh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetRawInputDeviceInfoW" (+00000070h)
Address: 77D60E6Eh, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77D60E20h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 02D90000h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02E76ED0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000455F0h)
Address: 76731BB8h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+00000216h)
Address: 767283B4h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetThreadDesktop" (+0000071Ah)
Address: 76728348h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetThreadDesktop" (+000006AEh)
Address: 02D90108h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 76728166h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetThreadDesktop" (+000004CCh)
Address: 7672622Ch, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetAppCompatFlags2" (+0000022Fh)
Address: 7677B024h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "AlignRects" (+0000527Eh)
Address: 00200000h, location: "foobar2000", loaded at 000E0000h - 00219000h
Address: 77D62054h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlTryEnterCriticalSection" (+0000076Eh)
Address: 77D62033h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlTryEnterCriticalSection" (+0000074Dh)
Address: 77D6240Bh, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B25h)
Address: 77D62447h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B61h)
Address: 77D61843h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 77D688D8h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlImageNtHeaderEx" (+0000009Dh)
Address: 77D08BF2h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 77D461E5h, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000125Fh)
Address: 77D688FBh, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlImageNtHeader" (+0000001Bh)
Address: 7672848Bh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetThreadDesktop" (+000007F1h)
Address: 02E96BB4h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000652D4h)
Address: 77D6162Dh, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 02E38E24h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00007544h)
Address: 7672862Bh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 02E2FE31h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02D9C524h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02E981D0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000668F0h)
Address: 02E981B8h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000668D8h)
Address: 02DF24D2h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02E959CCh, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000640ECh)
Address: 02E62EB0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+000315D0h)
Address: 02DF3FD0h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 001D09F6h, location: "foobar2000", loaded at 000E0000h - 00219000h
Address: 02E78380h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00046AA0h)
Address: 00360038h, location: "RocketDock", loaded at 00350000h - 00362000h
Symbol: "WindowProc" (+0000E5A8h)
Address: 02E66870h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00034F90h)
Address: 7677AB20h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "AlignRects" (+00004D7Ah)
Address: 76731B41h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+0000019Fh)
Address: 76731AFFh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetMessageW" (+0000015Dh)
Address: 02E96C54h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Symbol: "foobar2000_get_interface" (+00065374h)
Address: 77D616DCh, location: "ntdll", loaded at 77D00000h - 77E1E000h
Symbol: "RtlAllocateHeap" (+000000AFh)
Address: 76731933h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetWindowRect" (+00000036h)
Address: 02DE8305h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 02DE9C30h, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 76731E2Ch, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "DefWindowProcW" (+0000009Ch)
Address: 76731DFBh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 02DEAC9Dh, location: "foo_ui_columns", loaded at 02D90000h - 02EBD000h
Address: 767E6A53h, location: "GDI32", loaded at 767E0000h - 7682B000h
Symbol: "DeleteDC" (+000000AEh)
Address: 767E69B7h, location: "GDI32", loaded at 767E0000h - 7682B000h
Symbol: "DeleteDC" (+00000012h)
Address: 76726A60h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "GetAppCompatFlags2" (+00000A63h)
Address: 0185000Fh, location: "foo_input_std", loaded at 01730000h - 0186C000h
Symbol: "foobar2000_get_interface" (+000A1FDFh)
Address: 76732937h, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "IsWindow" (+0000003Dh)
Address: 767328FAh, location: "USER32", loaded at 76710000h - 767AE000h
Symbol: "IsWindow" (+00000000h)
Address: 74EF891Bh, location: "UxTheme", loaded at 74EF0000h - 74F2F000h
Symbol: "IsThemeBackgroundPartiallyTransparent" (+0000087Eh)
Address: 74F287C8h, location: "UxTheme", loaded at 74EF0000h - 74F2F000h
Symbol: "Ordinal74" (+000070BCh)
Address: 74EF87C5h, location: "UxTheme", loaded at 74EF0000h - 74F2F000h
Symbol: "IsThemeBackgroundPartiallyTransparent" (+00000728h)
Version info:
foobar2000 v0.9.6
UNICODE
Windows 6.0
Additional info:
SoundTouch DSP 0.1 (SSE) (foo_dsp_soundtouch)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
Columns UI 0.3.4.2 (foo_ui_columns)
Lyrics Grabber 0.2.5 Beta (foo_lyricsgrabber)
Album List 4.3 (foo_albumlist)
Converter 1.2 (foo_converter)
Standard Input Array 1.0 (foo_input_std)
RAR reader 1.1 (foo_unpack)
ELPlaylist 0.6.2.7(beta) (foo_uie_elplaylist)
ZIP/GZIP reader 1.0 (foo_unpack)
Playlists Dropdown 0.6 alpha 4 (foo_uie_playlists_dropdown)
Playback Statistics 2.1.6 (foo_playcount)
Panel Stack Splitter 0.3.4(alpha) (foo_uie_panel_splitter)
Album list panel 0.3.2 (foo_uie_albumlist)
foobar2000 core 0.9.6 (Core)
Monkey's Audio Decoder 2.1.3 (foo_input_monkey)
ReplayGain Scanner 2.0.8 (foo_rgscan)
File Operations 2.1.1 (foo_fileops)
Channel Spectrum panel 0.17.2 (foo_uie_vis_channel_spectrum)
WSH Panel (uie) 0.7.2 (foo_uie_wsh_panel)
CD Audio Decoder 2.1.3 (foo_cdda)
Lyric Show Panel 0.3.3.5 [Dec 9 2008 - 13:53:04] (foo_uie_lyrics)
BTW, I am now reverting back to 0.3.3.4 and now foobar2000 starts working correctly again. So I am pretty certain the problem is within the new 0.3.3.5.
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]
Moderation: [codebox]your crashlog here[/codebox][/size]
@Shoujo Pi:
I've release 0.3.3.6, I hope it fix that problem
PS: Please use codebox
0.3.3.7
* Fix a bug that cache may contain two lyric for one track
* Add context menu and a option for editing lyric file with external editor
* Move "Now playing" context menu items to a new popup menu
* Fix display setting importing/exporting and add support for interval, period, global field
0.3.3.7
Awesome updates, thanks alot!
There is one problem though in the Formatting String "when lyrics not found". The color you assign there seems to be ignored and actually the info gets deleted after closing the preferences.
Another problem is the editing of lyrics when they are embedded. Could you please provide some possibility to edit them, too? When I use external program I see an empty document. Would be so cool to for example double click the lyrics in the panel and have some inline editing But maybe at least the use of the internal tagger only on the lyrics tag would be easy to implement?
Big thanks.
The color in that textbos is indicator which used in titleformatting string, like this:
C0C0C0This line is grey'
000000This line is black'
One internal editor is easy but I will consider to implemet it to fit most conditions, becasue there exist various way of storing lyrics...
0.3.3.8 just released, with minor bug fixes and a big change in main menu commands, for details, check changelog.
The last two versions produce a 100% CPU load with timed lyrics.
@elenhil:
Maybe caused by interval setting reset to zero after updating, You may check that in Formatting string->period and Misc -> interval.
@elenhil:
Actually I have the same CPU problem with timestamped lyrics, although I have checked that the two options you mentioned are not set to zero... Well, this leads me to a small feature request again Do you think it's possible to implement a menu to just delete the time stamps in the lyrics? You already offer copying without stamps so I guess it's easy Deleting the timestamps but keeping the lyrics is important for remixes or live tracks.. Would be cool!
As I'm hungry... another idea would be to implement some sort of rectangle-drawing or implementing image-positioning to make lyrics look even cooler (and especially the infos when there are no lyrics available). I mean some function like in trackinfo_mod, graphicalbrowser or whatever...
Thanks again for your great work so far.
... As I'm hungry... another idea would be to implement some sort of rectangle-drawing or implementing image-positioning to make lyrics look even cooler (and especially the infos when there are no lyrics available). I mean some function like in trackinfo_mod, graphicalbrowser or whatever....
Well... did you notice that this component can have transparent background? You can easily achieve the same by putting this on panel_stack_splitter.
Cheers!
I think I find the problem, that's because "Enable gobal field processing", I'll fix that in the next version, for now, please uncheck that option.
0.3.3.9 Released, I hope that High CPU usage is gone now
I tried to find an explanation but I still don't understand what this "Enable global field processing" means.
Cheers!
Okay, while lyrics are showing that's true.. what I was looking for is a way to have some nice track info when there are no lyrics available. Of course it would be possible to just switch the panel in panel stack splitter to trackinfo_mod. The easier way though would be to use some nice drawing stuff in the lyrics panel But I guess this is beyond the scope of the plugin, so I'm gonna stick to the other approach.
Seconded. What IS global field processing? (New context menu is quite concise and to the point, not used to it being so short yet but definitely something that should have been done)
First off- great plugin! works great, easy to set up etc etc
Just a quick question... can you change the tag which lyrics show panel saves to after downloading?
I use foo_dop to manage music with my ipod, which requires lyrics to be stored in %LYRICS% for m4a and %UNSYNCED LYRICS% for mp3. As ipod's don't support synchronized lyrics, I end with a whole heap of lyrics showing up with the lrc-style time tags (the [00:00.00] before the line).
I'd like to change the tag (i.e. to %SYNCED LYRICS% for example). Is this possible?
from which database does this plugin get its lyrics?
Hi.
I download automatically and embed the lyrics to file and I alway get this message if there were no lyrics before.
(http://img520.imageshack.us/img520/7681/76341692kf6.th.jpg) (http://img520.imageshack.us/my.php?image=76341692kf6.jpg)
Any advice?
Nobody any idea?
Hmm... dunno, I'm thinking maybe because foobar's playing that file at the same time, it's locking it (so other apps can't delete it/mess around with it while it's being accessed). Don't know why it's doing it with this plugin though...
It's not a bug I guess, but if we fail to find lyrics the panel shows only song title/artist and it does't use font from panel setup.
Could you fix?
You can set the font for that in the Formatting String tab of the panels settings.
Great mod. But I have a question and request:
1 - can you make it so we can try multiple searches for the song with different string? I remove any "The" from the beginning of band names. So hence it will search for "Frames" when looking for lyrics and most likely not find them, yet "The Frames" returns lyrics as expected. It'd be nice to somehow allow different searches or maybe regex style where we can customize what matches (e.g. $["The "]{0,1}%artist%^) Any ideas/features for how to make it find "The" bands are appreciated.
2 - what lyric database does this use? I've recently switched to foobar from winamp and the lyrics I used on winamp allowed you to edit the lyrics in the actual database online itself. It'd be nice to have a button to quickly do a google search for the lyrics and upload them to the online database for download and association
Cheers!
Thanks! Missed this setting.
It's nice, but I think it's not that convenient if you'd like to work on other things while at the same time taking a glimpse at the lyrics. The major problem is that when minimize the main window, the lyrics is gone too.
To get behavior you want:
1) make foobar2000 always on top
2) go to File-Preferences-Display-Dockable Panels-Minimize panels when minimizing main window (uncheck).
You can also put hot keys on show and hide dockable panel - it's a pity but you can't switch its state by one key and should have two separate keys.
It works, thanks
I'm not sure if this is the right place to ask or not, but I'm having problems with the LYRICS tag in my FLAC files.... I'm trying to add a timing tag, which works fine in mp3 files, but not in FLAC files:
[ti:Title]
[00:42.50]blah blah blah lyrics
When using this scheme, the lyrics panel displays the following with an mp3 file:
Title
But with my FLAC files, the formatting is still there and does not seem to recognize the timestamps:
[ti:Title]
Any ideas? Does FLAC format or the lyrics panel not recognize timestamps in FLAC files?
Thank you for your help.
I store my lyrics in /mp3/_lyrics_/%artist% but I have a problem showing lyrics from a particular album.
2 similar albums: Stevie Ray Vaughan and Double Trouble - Live at Montreux 1982 & 1985 and Stevie Ray Vaughan and Double Trouble - The Essential, the lyrics are stored in the same folder, the lyrics from the Montreux album show just fine, but I can't get to show the lyrics from the Essential album.
When I download the lyrics via the plugin, the lyrics are downloaded, saved and shown normally, but as soon as I restart foobar, it seems that it can't find the lyrics and are also not downloaded automatically anymore. I tried about everything I can think of, renaming, retagging, etc. but still no go. Anyone able to help me?
Well after de- and reinstalling the plugin it works now, still a strange error.
[ti:Title]
Title
[ti:Title]
No answers on this? Any help is appreciated!
T.P Wang, thanks for plugin. Could you add some menu item for automatic lyric download?
Guys,
I just installed this component today, and I am amazed. It just works, it's brilliant...
There is just one thing: it fails to find lyrics for about 40% of the songs I tried, especially newer (2008-2009) songs. I just think this is an incredible waste, since I can find 100% of the lyrics to the tracks I tried on Lyrics Show Panel with a quick Google search or by using, say, the amazing http://www.songmeanings.net (http://www.songmeanings.net).
My question is: is there any way to make this component perfect by allowing it to broaden its search capabilities?
Hey, really sweet lyrics plugin. Thanks, for your efforts.
There's only one thing, that i don't get managed.
In Preferences i try to change the TAG to be read from. As my Mp3s have the lyrics embedded in UNSYNCED LYRICS i tried to change that but somehow it doesn't recognize the lyrics from there.
In the Settings i tried under 'Read lyric from TAG' to fill in UNSYNCED LYRICS; and UNSYNCED LYRICS;LYRIC and
UNSYNCED LYRICS;LYRICS;LYRIC
But it doesn't read the lyrics (i can see they are there in file info)
Where is the flaw?
Hi. I just switched to this component from the original one, because I was having a problem... and I still have it with this version
Some of my lyrics are not displayed let's say around 5% of them
I don't use lyrics tags, only txt and lrc files stored all in the same folder (specified in the path), and always with the EXACT file name as the song file name.
So after testing and testing and to make it all clear, I deleted all the entries in the "lyric file name" box, and left only one: %filename%
But sometimes it doesn't work, and I can't figure out why. For some songs in an album it finds the lyrics just fine, and for others in the same album, with the exact lyric file name as the song file name, without any weird character,etc, it doesn't work...
Does this happen to anyone else?
Any hints?
Guys,
This plugin would be perfect if it could search a series of places. First check its current one, then lyricsplugin, then lyricswiki, etc, etc as there are many databases out there.
(Also I'd love if it could search for an optional The in front of artist name as mentioned in a previous post)
Is the dev around, I haven't seen him post in awhile?
I'm curious, where does it get the lyrics from?
Can I upload lrc files to the server?
Any hints?
Yes the plugin has a weird behavior now and then (see my post above), it also sometimes displays the wrong lyrics, even if the correct lyrics are present.
AFAIK http://viewlyrics.com/ (http://viewlyrics.com/)
Hello,
I'm using foo_uie_lyrics v3.3.9 (good component, BTW) and I see a typo in the preferences of this component.
Preferences -> Tools -> Lyrics Show Panel -> Internet tab
the option Save scheme: Save the *configruation* folder
and
the option Fail to embed: Save the *configruation* folder
A.
is there something like this, but without the Panels UI required?
This is not a panels component. It works with CUI.
It will also work with DUI with the addition of using it with Dockable Panels.
terry
Just FYI, there is no dedicated threads here that concern themselves with components that work only with Panels UI.
oh pardon me, i meant the columns UI, not the panels ui
edit: nevermind, it's ok now, i found the text display plugin for this
Would it be possible to make the tag the lyrics get written to to be customizable under settings (and utilizing foobar scripting)? And be able to set timestamped lyrics to be written to a different tag?
Also, when the lyrics aren't long enough to take up all the space in the panel, when you try to scroll it just acts really glitchy. I also find the change to scrolling distance to being locked to between the first line of lyrics at the top and last line at the bottom, since I then can't scroll and have the current line centered. :/
Option Request.
Much of what I listen to are live tracks. The length of any one song title can vary considerably across versions.
That is one of the reasons that I prefer .txt files for lyrics.
Having auto download set is very nice and I would like to maintain that option.
When a .lrc file is found, I can oftentimes override by doing a manual search and select a .txt.
However, upon a foobar restart, the .lyc file always has precedence. Either it will be loaded from my drive [if both files exist] or reloaded from net [and .txt file ignored].
Could there be an option added that would allow user to determine preference of lyric type.
thanks
terry
@ developer:
I´m using the panel with transparency. I experience a little bug. It seems that the transparency is only applied after the first track change event and not from the beginning. The background is black, drop shadow and fading effects are applied although unchecked and the formatting string for lyrics not found shows up twice. This happens e.g. when a song is playing and the panel is shown first time (by some PSS button e.g.) or when a song is stopped and you turn on the lyrics panel.
Could you have a look at this issue, please?
Apart from that I really love this component, keep up the great work!
@vogliadicane:
In fact, the pseudo transparent will update on new track, stop, pause, and WM_PAINT message. I've added a lot of hacks for PSS already, I don't know why because brett's kameleon seems to be OK, you should ask someone else who is experienced in PSS, for help(I don't use PSS, sorry).
And thanks for your support.
PS: I decide to write a new lyric component, because this component is now hard to maintain, I'll start it in late June or early July.
@vogliadicane
Transparency works here too...
Do you have placed the Lyrics Show Panel in Tabs?
That is the only situation your described "bugs" with transparency happened to me too.
@ T.P Wang: these are good news, though I think it´s really fine now, only the transparency thing. Well and maybe some option to chose several lyrics sources would be nice. Anyway I´m shure it´s gonna be a great component again.
@tedgo: no, no tabs, just a panel which is hidden at startup and turned on by a PSS button. I´ll try what happens, if I don´t hide it at startup...
edit: same result...
Hey, the lyric panel is working all fine, except most of the time, the lyric server is offline. Is it just me or is it offline most of the time? At the moment it is offline for me. Also a quick question, lyric association just finds lrc or txt files in the specfied directory, what happens if you don't use lyric association, will it continue to just download lyrics off the lyric server or will it find the lrc and txt files in the lyric folder? If someone could explain what happens i would be thankful.
I'm glad to hear this news. I had some plans similar to this, but I never started.
I have some suggestions (which is my original proposal), you may or may not think it is useful.
1. The lyrics downloaders should implemented as services (extends service_base class), so it is easy to support multiple sites and can be extended by other components.
2. It should handle charsets better, many .lrc has [encoding: ****] tag, just use that. (should check UTF Byte-Order-Mark first, of course)
3. The window class to display lyrics shouldn't direct derive from the CUI's class. The DUI's SDK may be released some day, we can support it from that point soon.
4. Optional, implement more parts of this components as services, we have *too* *many* lyrics components for foobar2000 but none of them works everywhere. By this design, we don't need the redundant works anymore.
@JackieKu:
1. I've already made lyrics as service, though it should be improved, see here: http://lyricsgrabber.googlecode.com/ (http://lyricsgrabber.googlecode.com/)
2. Yes.
3. Thanks for your advice, I'll made it wrapped into a container window.
4. Well, first the lyric parser should made as service....
@vogliadicane
Try moving the panel with $movepanel_c(Lyrics,x,y,w,h), that solved my problems with Lyrics panel transparency.
@vogliadicane
Thanks that helped!
Seems it has to be triggered once somehow... (and Panelshow alone isn´t enough)
Wang, you just made me happy
For some reason the original plugin just didn't seem to find any timestamped lyrics from the internet, so i removed it.
Today i downloaded your modification and, surprisingly it all works perfectly now.
Great work! Really!
May i ask you (or the rest of the users here) which databases this plugin searchs for timestamped lyrics?
It's just because i thought about writing some myself for songs which can't be found yet and upload them.
How do i do that?
Thanks for your answeres
It uses the minilyrics database. You can edit and upload lyrics with said program.
For some reason, some of my lyrics appear really wrong. For example, a lyric to track 1 will appear on track 4 or so, however on the rest of the tracks, even track 1, it will appear correctly. There is no <LYRIC> tag on the file properties or the album folder as well, so I have no idea why it's doing this. Is it an error on the lyrics server for some particular songs? Or am I doing something wrong?
Here is a screenshot of one of these songs:
http://img40.picoodle.com/img/img40/2/6/4/...edm_18879ca.jpg (http://img40.picoodle.com/img/img40/2/6/4/crazyneo/f_Untitledm_18879ca.jpg)
Sometimes things go wrong. When it has occurred to me, I have;
Right click [in lyric panel] > File association > Disable association
Then re-download.
This has worked for me and my config....YMMV
terry
I love this plugin, i wonder if the author could add more internet sources to grab lyrics..
T.P.Wang,
I was changing something in Lyrics Show panel preferences, and noticed this:
Funny
I have a feature request: Image Limits greater than 5 from last.fm would be very nice. I'd like to set it to 50 or even more.
Wrong thread ( http://www.hydrogenaudio.org/forums/index....showtopic=70955 (http://www.hydrogenaudio.org/forums/index.php?showtopic=70955) ), or am I missing something?
Is it possible to have this component read from files first, and then from tags (%lyrics%,%unsynched lyrics%) if no lyrics are found? iirc telling the component to read from a tag field would make it override text files, which is not ideal in my case since my files are timed and my lyrics field is just plain text.
This also relates to a request I have, that it be possible to scroll the "Formatting string (if no lyrics are found)" with the arrow keys just like untimed lyrics (because I tried putting %lyrics% into the Formatting string box but it's not possible to scroll it to see the whole thing)
Feature request : FORMATTING STRING FOR FOUND LYRICS
Just as there is a script box to enter a formatting string for lyrics not found, could we have the same for lyrics that are actually found ?
This way we could enter some titleformat header that would be previous to the found lyrics. For example :
%artist%$crlf()
%title%$crlf()
$crlf()
... just as we would do with the Text Display DUI component. Do you get the idea ?
...or with Item Details in CUI
I think it is nice idea, and would also like to suggest some simple editor for time-stamping lyrics
This one (http://foo2k.chottu.net/) can do that, but it doesn't support gap offsets and does mm:ss
:ms instead of mm:ss
.ms.
Yes, I know, thanks
Only that the component was last active in 2007, but maybe it's finished project for it's author ssenna, although the editor is in alpha stage
And replacing ":" to "." or deleting ":ms" is funny, as it limitation for updating the lyrics tag
An editor for lyrics that meets today's standards would be very nice. I second that request. Would be cool if you could first write the lyrics in some kind of a text window, then start foobar2000's playback and just click once for every new line of song text to set the time markers. You shouldn't have to hover the mouse cursor over specific lines during that but just single-click somewhere in the window (or maybe use a keyboard key like Space).
I'am using SingedIT
very small program but complete
(http://img266.imageshack.us/img266/9264/image0055.th.png) (http://img266.imageshack.us/i/image0055.png/)
An integrated component would be obviously better, if it exists.
I hope T.P is still alive, I haven't seen him in quite a long time...
http://www.hydrogenaudio.org/forums/index....st&p=642265 (http://www.hydrogenaudio.org/forums/index.php?showtopic=55692&view=findpost&p=642265)
would it be possible to add the ability for changing the port (that it uses for online services) with a little field in the options??
As far as i was able to have a quick overlook to the codefiles, the port is fixed on port 1212 (download.h) file. I really would appreciate that little update, cause im not able to connect due the fact that only little ports are opened in my network =(
Or maybe there is already a workaround? (i have to say that i didnt read all 26pages of topic here )
This question is probably really easy for someone to answer but anyway.
I'm trying to get it to save the lyrics to the folder the song is in a folder named _LYRICS, so i tried to %path%/_LYRICS but didn't work.
So does anyone know how to do this? And also so it searches that folder for them as well.
Thanks beforehand
Thanks beforehand
%path% includes filename.ext . You shoul use $directory_path(%path%) instead.
Hi, need a little help.
I have foobar2000 0.9.6.8, Columns UI 0.3.7.8 and Lyrics Show Panel 0.3.3.9.
The problem is the Lyrics aren't displayed anywhere and I don't think they're being downloaded either (although I've checked "Download automatically" in the Internet tab).
Also View -> Lyric Show is greyed out.
Maybe I'm forgetting something basic here I can't find any documentation of the plugin, so I'm hoping you guys can help.
i had the same problem, and activation "ouput verbose debugging information" (Settings-> Lyrics Show Panel -> misc tab) showed me the following information when clicking for a online search of the lyrics [viewing the console: foobar menu->view->console]
foo_uie_lyrics: SearchThreadProc: HttpSendRequest failed.
i had the problem caused due the closed port (described 2 posts above)
May these little information is helping you =) *Sometimes* these verbose text are understandable for humans ^^
No errors there.
The lyrics window isn't displayed anywhere, so I guess that's the main problem.
EDIT: Fixed!
I knew it was something simple. Had to add a Lyric Show panel in Columns UI config.
I'm sure it's pretty obvious for you guys, I just wish the information that it needs to be done would be given somewhere - for people not familiar with Columns UI/foobar.
Im using Coulums UI with Tabbed Panel Stack Mod.. Is it normal for the lyrics not to scroll when i turn on Transparency?
They work fine when its turned off, So i figure its just a bug?
When transparency is turned on it doesnt scroll unless i scroll over the tabs....
[a href="http://img268.imageshack.us/i/lyricsy.jpg/" target="_blank"]
EDIT: Well i fixed the problem..Changed the Tabbed Panel Stack Mod to Tab Stack and its working now.. I would like to use the other addon because you can choose if you want it on TOP or BOTTOM of the playlist, I dont think you can do that with Tab Stack addon...
I really don't know why you can't guys use my lyrics editor. Pretty much, what you could want (down arrow records time offset, but I can change it or make it changable).
Link to this editor? I don't remember if I've seen it before or not...
http://www.hydrogenaudio.org/forums/index....showtopic=57752 (http://www.hydrogenaudio.org/forums/index.php?showtopic=57752)
But I'll rewrite it in a week or so, because I no longer have source codes to it.
I suspect there is more need for an extremely simple "timestamper" than there is for yet another "Professional Lyrics Editor". And by simple I mean a lyrics show panel with single button for inserting a timestamp on the spot. The only other feature would be jumping to the corresponding time by clicking on a timestamped line (for mistake correction primarily).
im wondering if someone could save me from tearing my hair out
im currently working on a config with this component as a panel set to Transparent
now, whenever i restart foobar the panel isnt transparent until i start a track.
iv gone over settings dozens of times in this & the panel stack splitter it is contained in & im really baffled as to why this behaviour happens
as i said, it only happens on start up then it goes transparent when a track is started.
any help is greatly appreciated
^^ you can solve this by adding a 'movepanel' command in the PSS script with the normal positions of lyrics panel you used before.
afair you have to set the values in PSS panellist each to 0.
thank you very much for the advice, i will give it a try later
i am also getting the 10 lyrics download issue that was brought up earlier, any suggestions on a fix? I have lyrics set to auto.
After autograbbing 10 lyrics, this happens: I play a song and the lyrics do not show up automatically, so I try online search - and that does not even work.
For example:
Opening track for playback: "V:\Music\Third Eye Blind - Blue\04 Never Let You Go.mp3"
foo_uie_lyrics: ReadLyric: Skipped reading from cache.
foo_uie_lyrics: ReadLyric: ReadLyricFromTag failed.
foo_uie_lyrics: ReadLyricProc: ReadLyricFromAssociation failed.
foo_uie_lyrics: ReadLyricProc: ReadLyricFromFile failed.
foo_uie_lyrics: SearchThreadProc: for file://V:\Music\Third Eye Blind - Blue\04 Never Let You Go.mp3 /index: 0.
foo_uie_lyrics: SearchThreadProc: search retry: 1
But when I restart:
foo_uie_lyrics: DownloadThreadProc: for file://V:\Music\Third Eye Blind - Blue\04 Never Let You Go.mp3 /index: 0.
foo_uie_lyrics: DownloadThreadProc: downloading lyric from: http://www.viewlyrics.com/lrc/English/third%20eye%20blind%20-%20never%20let%20you%20go.lrc
Works fine! :s
Search also works as normal..
foo_uie_lyrics: SearchThreadProc: for file://V:\Torrents\Third Eye Blind - Blue\04 Never Let You Go.mp3 /index: 0.
But after 10 songs it stops working, and I have to restart..
thanks for any help.. this is a great plugin.
Please-please-please help me ^^
I've been using foobar for a long time, but today i decided to add some features, you know ) Everything went great, even with UI Colomns, but then i decided to add this Lyrics Panel. I've placed the .dll file into the "components" folder, it appeared in Tools, but i can't see it anywhere in foobar =(( Sorry for stupid questions, but i really can't get the idea of how it should work
oh, i've managed to make it work ))) the only thing is that it sometimes downloads/displays lyrics really slowly (((
@vogliadicane
thank you very much for the tip, the $movepanel_c setting worked a treat
I have "Replace unsynced lyrics automatically" set and "Save scheme" is "Save to directory".
When I have embedded unsynchronized lyrics, and LSP finds synchronized ones, it tends to replace embedded lyrics rather than saving .lrc.
So, even if I turn any automatically embedding OFF, it still happens.
wanted to ask you that is it possible in any way to get this plugin to show lyrics in the newest foobar2000, without columns ui? I've been trying to work around to make a small space for lyrics, but can't manage to do it. Anyone care to help?
No, this is for ColumnsUI only.
I am afraid it does not work any longer. I have tested two different builds of foobar2000 but the result is the same. When trying to Online search --> Search there is 'Search failed' error and there is not even an attempt of establishing a network connection. Has anyone have such problem? :-)
I did it a few days ago with no problem. Maybe it's just a temporary server-problem.
@Author: Usually automatic downloading works like a charm, but sometimes it get's lyrics for a different version or just misaligned. I think it would be great if you could add commands to foobar2000 that will automatically try to download the next lyric with default search-options.
I found out that the plug-in uses _http://viewlyrics.com/ , but it works.
I wonder how harken93 made such logs? =) The default console output is not so detailed.
And one more thing: sometimes the plug-in uses wrong lyric files. When playing one song, it can take lyric from another file (but usually the same album), even if there is the necessary file. I tried to make some changes to the variables and other setting but with no effect at all. There is no difference where to store lyric files.
You may have a config issue. Has this worked for you before or are you
setting it up for the first time.
Just tried it and worked fine.
terry
RazorSharp
Please, take a deep breath
Check your config. There is an option to log more details.
It stores the lyric files correctly based on your settings. [edit] It helps to view the main settings page
and clearly view the progression order the plugin uses to search for the correct lyric. [/edit]
It will sometimes - very rare in my case - associate a wrong lyric file.
Disable the association and all is well.
terry
Ok, I've caught the problem (the second one) and took a screenshot:
[a href="http://img168.imageshack.us/i/21016808.jpg/" target="_blank"] Thanks for help guys!
Misc
output verbose debug.......
terry
Or maybe there is already a workaround? (i have to say that i didnt read all 26pages of topic here :rolleyes: )
I am also suffering with the inability to use port 1212. Has there been any consideration of allowing the port to be selected or set to something like 80?
It goes without saying, with or without the port fix, this is a kick ass plug-in!!
Hi T.P Wang, could you please remove the text "Lyric show" when there's no lyrics being displayed? For aesthetic reasons I'd like to have a black background with no text if no lyrics are found on the internet.
^^ you can edit the text in preferences/formatting string
I'm not sure. I mean this green text:
(http://img406.imageshack.us/img406/9020/screenshotzx.png)
yes, right click panel: settings/formatting string...
Not an exhaustive study, but the only time I see 'lyric show' as a text displayed is when a track is stopped via stop.
At all other times it defaults to found lyrics or the configured settings as mentioned by vogliadicane.
If this is the issue, then I do not believe there are any settings to remove without developer assistance.
terry
Another idea is that it would be awesome if we could use multiple Lyric Show Panels. For example, one could use one small lyric panel for the main music library screen and another big one for a tab dedicated for displaying lyrics in big full screen size (if you have party guests so everyone could see the lyrics).
But they would have the same settings
You can try with Lyrics panel (http://foo2k.chottu.net/#lp), and although you can add multiple instances of this lyrics panel, the settings are same for all instances
A feature request:
- Adding a button for searching another/next lyric-file, and buttons for adjusting lyric by 250/500ms increments (or custom defined)
Reason: Often it downloads an improper lyric for various reasons, and it would be nice if you could easily switch to another lyric. I.e. a button could search using the already predefined pattern and choose the next (lrc) lyric in the list. Also a button for removing the timesync would be nice. Could be useful for alternative performances of a song that would not match the sync anyway.
A feature request:
where do you want these buttons, in the panel itself?
I am very happy that there´s nothing except of the thing it was made for - the lyrics!
But I think the ideas as options are good (e.g. remove timesync), maybe just add them to the context menu, or better the main menu (view/lyric show/...)? ...then one can make custom buttons with panel stack splitter.
Very good feature request: Would be cool if Lyric Show Panel would be also be refreshed if the song is paused but the user uses the seekbar. Then users could use the seekbar to directly navigate to a specific part of the lyrics, not having to resume playback first.
Another idea: Please add option to use color gradients for background color. It would look awesome if theres not just a single-colored background but a smooth color transition.
When using Cyrillic encoded text or just Cyrillic chars in UTF-8 encoding, Lyrics Show wraps text on any character, not on word:
(http://img30.imageshack.us/img30/1324/clipboard03kh.png)
So I tried with "Assume charset" in Misc options, but whenever I change something it's reseted to 9494 - Korean
Can anyone tell me how this thing works?
you install it and then what, do you have to add something , some url or a thing like that?
cause i installed it but i can only download lyrics , and after i downloaded them i can play them?
also can i add this thing in the default user interface and how?
No, this is a ColumnsUI extension. You can add it as a panel (hence the title) in ColumnsUI.
What do you mean by play it? It works right out of the box. You play a track and it will display any lyrics it can find (if any) in the panel.
A search using your question: lyrics show panel default
Brings up plenty of info for you to consider.
This component's implementation within the Default user interface is via a floating panel which will not 'attach' to the DUI but works well for me.
http://www.google.com/custom?domains=hydro...RID:1&hl=en (http://www.google.com/custom?domains=hydrogenaudio.org&q=lyrics+show+panel+default&sa=Google+Search&sitesearch=hydrogenaudio.org&client=pub-4544327213918729&forid=1&channel=7051718642&ie=ISO-8859-1&oe=ISO-8859-1&flav=0000&sig=6_g3ghDcS6bRpfcd&cof=GALT:%23008000;GL:1;DIV:%23336699;VLC:663399;AH:center;BGC:FFFFFF;LBGC:FFFFFF;ALC:0000FF;LC:0000FF;T:000000;GFNT:0000FF;GIMP:0000FF;LH:50;LW:262;L:http://www.hydrogenaudio.org/forums/logo50.png;S:http://www.hydrogenaudio.org;FORID:1&hl=en)
terry
is anyone experiencing low cpu usage while using this component in Windows 7?
usually, my foobar2000 rarely has cpu usage (almost always on 0%), but when i use this component, cpu usage almost always varies between 2-5%.
has anyone else noticed that?
on xp everything works fine...
I defined a search path as follows
D:\Media\Lyrics\%artist%\
and that's where I want to store my lyric files. Ok, everything works fine so far - the download options are set correctly.
But thing is, it stores my files as:
D:\Media\Lyrics\%artist%\%artist% - %title%.lrc
But I want to have the following kind of save format:
D:\Media\Lyrics\%artist%\%title%.lrc
Another thing is, the only lyric file name I defined under the "setting tab" is by %title%. There is no search for "%artist% - %title%" but it finds files formatted like this.
It seems to me being a standard/default configuration and to me it is very annoying.
So all I want to say is I just want to store the lyric files the way I prefer, not your plugin does. ;)
Thanks for hearing me out, great Plugin! :)
Hello, i have a problem on the lyrics automatic search.
I found that most of the results are inaccurate however if i use Online Search, it displays the correct lyrics on the results.
Any idea what's wrong here?
In my experience it always worked like this. It sometimes loads the lyrics for the wrong song. My guess is that its buggy.
I think that your problem has to do with the component's "cache."
Once I deleted all the files there (%FOOBAR CONFIG%\Lyrics) it worked correctly.
I don't think so. Sometimes the lyrics for a song I never listened ot is shown, but when I search I only get results for the song that is playing.
