Topic: Lyrics Show Panel (Modified version) (Read 489796 times) previous topic - next topic
Reply #450
@zouhair:
That crash had reported serveral times and I'm confused by that.
Someone use ObjectDock, then result in crash. However, without ObjectDock, it's OK.
Someone cleard all configration...
I have some questions:
1) Which version of ColumnsUI component are you using?
2) After remove foo_uie_lyrics component, then start fb2k, then also remove all references(eg. in ColumnsUI), close fb2k -> place foo_uie_lyrics component ->start fb2k, would it crash?
3) Then add one reference of foo_uie_lyrics (eg. Insert "Lyric Show" Panel in ColumnsUI), would it crash?
Thanks in advance.
Any way, I think I must double check the code now
Reply #451
zouhair  should do that:
1.  unistall  foobar2k
2.  reintsll  boobar2k
3.  copy  columnUI
4.  copy  boo_uie_lyrics
5.  start foobar2k
keep the envirement clean first.
@zouhair:
Thanks in advance.
2.  reintsll  foobar2k
3.  copy  columnUI
5.  start foobar2k
@zouhair:
Thanks in advance.
Reply #452
How do you add lyrics that weren't found thru the 'Online Search' function? I tried "associate lyric" and it didn't work.
edit: my bad, seems a restart of Foobar does the trick
Reply #453
Right Click on Lyrics Panel after associating the lyric file and then click on Reload Lyrics will do.
Reply #454
Hi I'm new to this forum, this is my first reply.
First of all I'm sorry that I am not patient enough to go through all the 19 pages of this thread, so I may miss the solutions to my problem.
I just want to add my own lyric to the song that has been associated or embed with lyric that had been automatically downloaded. I don't know how to dissociate the unwanted lyric.
What should I do?
Reply #455
0.3.2.3 released:
    * Fix a bug that can not specify the background color when transparent is disabled
    * Fix a bug that it wouldn't refresh when resizing window
    * Change lyric file cap from 10K -> 32K, which help loading larger lyric file
    * Add options for fading and shadow offset.
    * Fix something on lyric search & download
@Hizack:
You can have a try: Right Click on Lyric Show Panel -> Lyric Associations -> Diable associations
Reply #456
nice new options in the new version.
but would it be possible to also add options to set the radius and the opacity of the shadow?
Reply #457
Thanks for new version!
I discovered a bug: if "Adjust fading height manually" is checked and I exit the preferences window then come back, it gets unchecked.
Also, can you add a scrollbar in the future?
Reply #458
@radecke:
I'll add an option for soft-shadow later. Thanks.
@Totyo:
Yes, it's a bug, it also occurs in misc->output verbose debugging information..
I'll fix it later.
Though scrollbar is good for scrolling lyric quickly, it is not easy for customizing, besides, Lyric Show Panels prefered synced-lyric rather than plain-text, so I won't consider it for now.
Reply #459
I have a feature request.
For now, we have two choices: automatically downloading lyrics (no click but connexion for each song is not a way to do) OR using an extra window (several clicks + lost time to wait for choices).
Could we have an option in contextual menu which allows to download automatically please ?
Reply #460
Thank you for your help, T.P Wang
But after I dissociate the unwanted lyric and associate a lyric I want, the lyric associated becomes the original unwanted one again.
How could I really remove the original lyric and associate or embed my own lyrics?
Reply #461
Hey! i'm using the lyrics show panel for song info when there aren't any lyric-tags in the file. So i made show me all kinds of file specific info like rg gain and bitrate and stuff like that. Now, i have two slight problems that i can't seem to fix:
1. how can i make it so that comments are always centered, even when they have manual breaks in them (mean: not line break but when i wrote the break into the comment - i.e. lyrics, diff. segments of songs). Because i can set a tag to be displayed centered but when there's a (manual) break within the comment tag "$char(1)C" applies only for the first line of the comment text..
2. most plugins and foobar itself (afaik) look for an entire tag family instead of only one specific tag within a file. For example: %artist% - not only "artist% is been returned, but also "album artist%, %composer%, %band% and so on. Only Problem is, when i set %comments% to be displayed it also returns %COMMENT ITUNNORM% which is itunes' version of ReplayGain and not a comment.. Is there anyway to exclude this particular tag from being displayed?? It really sucks to have a bunch of ugly numbers being displayed that i don't wanna see..
Thanks alot in advance for any answer!
Reply #462
Hello.
0.3.3.0 is released now. Please note the changlog
Regards.
Reply #463
Hello.
Regards.
Thanks for this great component. As it is built with the latest SDK, the requirements for your component in the first topic should be adjusted to foobar2000 0.9.5.
Reply #464
@fbuser:
No, current now I've only used only one new servie introduced in new SDK:
"Enable field processing in titleformating scripts" now use metadb_display_field_provider service instead of deprecated&removed metadb_display_hook
Reply #465
From the changelog of the new SDK:
Added access to new features introduced in foobar2000 versions 0.9.5, 0.9.5.1 and 0.9.5.2. Version 0.9.5 or newer is now required to load components made with this SDK.
I'm not able to test it at the moment, but if you are using a new service from the new SDK, I wonder how old foobar2000 versions can load lyrics panel. I don't need a deeper technical description here, if it works, it's ok for me.
Reply #466
@fbuser:
Yes, you are right, I've changed that.
Reply #467
Hi. Thanks for this great component.
Feature request: Is possible to improve the online search function? Eg. when searching artist with trailing "The" to search without "the", too? I mean if I have a song from "The Beatles" there aren't any results for "Beatles" and vice verse. Also if there is a trailing space, the component won't find any results.
Reply #468
Hi ,very good pugins,but I have a problem,when it auto download from internet and output the *.lyr to my hard drive, the *.lyr 's name is different from the *.mp3.for example the song's name is (01. Candy Shop.mp3) but the lyr's name is (Madonna - Candy Shop.lrc) ,it's different .If I put these together to my MP3 player, it can't play the lyr. thanks.
Reply #469
Hi. I have a question. Does this plugin supports word synchronised lyrics?
There are several formats I think
Minilyrics use the following format:
[00:32.83]<00:32.83>I <00:33.25>reach <00:33.67>for <00:33.95>you ... etc
I tried that and it disn't recognise the words.
Any possibility of implementing such a feature with the highlights through word synchronisation?
Thanks very much!
Reply #470
Good plugins.
thanks for that.
just wondering where does the plugin download from?
Reply #471
Nice plugin. It would be cool though if you could have the lyrics in a separate window that show/hide depending on if lyrics are found.
Reply #472
You can do it with fb2k v0.9.5.3 (with $stripprefix(X) and $swapprefix(X)), and in configruation window of Lyric Show -> Internet, you can find setting for "Titleformatting for search".
No, at least not now, this component now is hard to read and render that format.
You can do it with dockable panels and the %lyric_exists% field.
Reply #473
would you be able to make lyrics fade in/out like in MiniLyrics?
also is there a plan to make a lyrics editor that can be used in conjunction with lyrics show panel?
Reply #474
Yea a .lrc editor that could be used in conjunction with lyrics show panel would be good. Like you have it in the Lyrics Show Panel context menu. And it should be able to take time stamps from foobar so that you can enter the lyrics of the song and then whenever a line starts you hit a button and it automatically adds the correct time stamp.
Although I guess this would belong in a separate thread to request such a component.
