Topic: Lyrics Show Panel (Modified version) (Read 490014 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
Reply #100
Is there something that would display the current line on the bottom right edge (or somewhere else) of the screen to make a karaoke (and perhaps based on PrettyPopup (http://www.maroonspoon.com/foo_prettypop/)) ?
Also, I would like to know more about embedded lyrics : I understood that it will read first tag, then directory, etc.
What happens when no local datas are found? Where are they stored? Do not tell me it's reloaded each time, I would not believe you! Is there a way to auto embed them in file? And finally, is there a way to view them before downloading to file?
Reply #101
does anyone else experience the problem with this panel that it doesnt find anything and never stops searching ?
i think its connected o lyricsDB since that one is also having "some network issues" for a few days.
please let me know if you also have it or if the problem is client-sided.
also please try and help me figure out how to solve this. my firewall is not blocking foobar. ive checked this and i can also still use DBtagging.
maybe both plug ins are using the same ports or something?
thanks in advance
henning
- creative x-fi extreme music
- sennheiser 650hd
- F U B A R++
Reply #102
[snip]
thanks in advance
henning
I've had this problem off and on since installing the component.
Reply #103
First, i just love that new version, everything works perfectly. The new server for lyrics is great, i find almost everything.
I have a feature request : the possibility to have more than one instance of the panel. I know it s quite a lot of work but it would be awesome. I would allow me to create a popup for lyrics on my second display(video projector) with bigger font for easy reading.
Thank you, your idea is really great, I'll set about to implement it as soon as I got back to school.(But I can't make any schedule for that  )
1. Now this feature is not implemented, I'll add it later, thanks.
2. When no local datas are found(tag or association or dir), Lyrics show panel will perform a Internet search(in a new thread, only if "Internet -> Download automatically" is checked), and then prefered download .lrc files, if there's no .lrc file, choose one .txt file to download.
3. they are stored depends on your "Internet -> Save scheme" setting. default is "embed to file", but there's  a problem when writing tags: It's OK when you've download 20 items (the number of lyrics in cache is set to 20), it will write the last 20 track's lyrics to there tags. However, when fb2k is shutting down, it always failed to write tags. So on a later release, I'll fix it.
If embed failes(such as the filter which matches "Setting -> skip w/r tags by filetypes", mslive:// or unpack:// protocol), Lyrics show panel will perform the action which you've set in "Internet -> if embed failes"
As of the "embed" is not stable, I recommend that use "Save lyrics to dictory", it's fast and stable.
4. Now you can't view lyrics before downloading, but I'll implement soon.
thanks.
thanks in advance
henning
Have you configure proxy setting of Internet Explorer before?
In defaults, lyricsDB use the proxy setting from Internet Explorer, Lyrics show panel always uses IE's  proxy setting.
[snip]
thanks in advance
henning
It sounds like that server was busy or temporary down
Reply #104
haha im so stupid!
i set my IE to "work offline" some days ago....
now its working again ! thank you for the hint^^
- sennheiser 650hd
- F U B A R++
Reply #105
thanks.
1./4. thank you for thinking about it
And thanks for the panel
Oh! Another Idea : that would be cool to change the display (and not only the color and global font) of the different line : the highlighted line could be in big, while other could be in small. Would be funner with a size gradient on the line, so that it looks like this :
BEYOND THE REALMS OF DEATH (Judas Priest, Stained class) :
in his mind and slammed the door
No matter how they tried
They couldn't understand
They washed and dressed him
Fed him by hand
CH: Yeah! I've left the world behind
I'm safe here in my mind
Reply #106
Which lyrics database is your version using now? Cuz I want to contribute there. Thanks.
Edit: ahh, I see in source, that it is secret. I just know, that it maybe is this: u15191554.onlinehome-server.com on port 1212.
btw. I found that other lyric displaying (and editing) plugins for other audio programs have submission feature and your doesn't have.
Reply #107
Great job! Thank you for the hard work.
I would love to see a timestamp editor like Make_Lyric was for 0.8x.
(and I also give a +1 for the multiple instances!)
Reply #108
Hi guys, I would like to know how can I actually enable the plugin, I can see it on the Options, but can't see the panel or window.
Thanks for your help.
Reply #109
haha im so stupid!
My pleasure.
thanks.
Fed him by hand
It's cool, but I won't add it in the following 1 or 2 months due to the lack of time, sorry,
the lyrics database is viewlyrics.com
I hide it just because bluenet(orig developer) hide it.
Yes this feature will be implemented in 1 month, I think.
You need insert the panel in columnsUI or panelsUI
Reply #110
Do you think it is good lyrics site? Many links pointing to the site itself aren't working. There are no submit lyrics function. However, I have to admit that when your plugin was using previous lyrics database I wasn't able to find timestamped lyrics for some of my favourite songs. After change, 99% of my songs have timestamped lyrics. I'm just wondering how those lyrics got there, when there's no upload page.
Reply #111
Has there been any progress correcting the following problems?
I encounter this problems in the latest version (0.3.1.1b6).
-ClearType/AA doesn't work with my preferred font, Calibri. It's works with every other font I've tried, but not Calibri.
-The lyrics panel is scrollable with the arrow keys except when it's tabbed using foo_uie_tabs (v. 0.2.5).
Here's a visualization of my problem:
Reply #112
Is there a guide to do this? I think I'm the only one who doesn't know how this plugin starts to work.
Reply #113
I just found few timestamped lrc db before, do you have any suggestion?
Previous db is minilyrics.com, has a bigger db in CJK, and the server is located in china I think.
I just knew that minilyrics can upload lyrics to these db.
Maybe I should make a standalone program or embe the function into the panel for uploading?
EDIT: I may prefer adding some features on scripting to provide more db than write the codes staticly.
In latest DEV version:
ClearType now is applied without fadint effect.
And now I can't figure out why the arrow keys can't work with foo_uie_tabs, so please try use trackpoint drag nontimestamped lyrics up and down for alternative.
Columns UI:
first see here please:
http://eolindel.free.fr/foobar0.9/UIcolumns.php
in layout tab, right click on a splitter->insert panel->panels->Lyirc Show
PanelsUI:
$panel(Name,Lyric Show,x,y,width,height,)
Reply #114
I give up!
I am using the latest DEV version, but ClearType still doesn't work with the font Calibri. Trackpoint drag also doesn't work. I guess it just wasn't meant to be.
Thanks for all your help.
Reply #115
I give up!
I've just tried foo_uie_tabs. Here's some screenshots (I'm using 0.3.1.1 latest DEV version, now the DEV version is replaced by 0.3.1.1 b7)
ClearType (Calibri, without fading effect)
no ClearType (Calibri, with fading effect, GDI+ DrawString seems not support cleartype on Vista fonts.)
So, you first should turn down the fading effect.
I also tested the drag feature, works.
if you want to use arrow keys, you can double click the lyrics show panel(set focus)
regards.
Reply #116
THANK YOU SO MUCH!!!
My foobar is now complete! I'M SO HAPPY!!!
The mouse drag works fine, but the arrow scroll doesn't. ClearType now works. Oh well! The mouse drag is fine for me.
THANKS AGAIN!!!
Reply #117
T.P. thanks again for a great update!
I am still having my old problem with finding the lyrics though:  If %artist% is "Police, The" or "Apple, Fiona" it will not find the lyrics.
I try to solve this by fixing the Lyric file name for artist-title1 and artist-title2, but obviously the lyrics database search is not being done with these fixed names.  Can you please provide us with a way to fix our artist and title names, instead of just sending %artist% and %title% to the lyrics database?
Reply #118
I also organize my music this way and encounter the same problem. I add all the music by the artist in question to the playlist then select it all, right click, properties, change the name to "Fiona Apple" for example, then get the lyrics, then change it back. It's kind of a hassle, but it works.
Reply #119
I'll add an option after I finish multi instances support.
thanks.
Reply #120
I don't understand why autoscroll fails with this :
[al:Angel of Retribution]
[ar:Judas Priest]
[ti:Angel]
[by:DAzed]
[00:00.00]Angel
[15:00.00]Judas Priest
[25:00.00][48:00.00][1:10:00.00][1:40:00.00][2:08:00.00][2:36:00.00][4:15:00.00]
[28:00.00][1:49:00.00]Angel,
[33:00.00][3:38:00.00][3:50:00.00][4:01:00.00]Put sad wings around me now
[38:00.00]Protect me from this world of sin
[42:00.00][3:42:00.00][4:05:00.00]So that we can rise again
[51:00.00]Oh angel,
[56:00.00]We can find our way somehow
[1:01:00.00]Escaping from the world we're in
[1:05:00.00]To a place where we began
[1:13:00.00]And I know we'll find
[1:19:00.00]A better place and piece of mind
[1:24:00.00]Just tell me that it's all you want
[1:29:00.00]For you and me
[1:34:00.00]Angel won't you set me free
[1:53:00.00]Remember how we chased the sun
[1:58:00.00]Then reaching for the stars at night
[2:03:00.00]As our lives had just begun
[2:10:00.00]When I close my eyes
[2:15:00.00]I hear your velvet wings and cry
[2:21:00.00]I'm waiting here with open arms
[2:27:00.00]Oh can't you see
[2:31:00.00]Angel shine your light on me
[2:59:00.00]Angel we'll meet once more I'll pray
[3:04:00.00]When all my sins are washed away
[3:10:00.00]Hold me inside your wings and stay
[3:20:00.00][3:31:00.00][3:54:00.00]Angel take me far away
[3:27:00.00]Put your sad wings around me now
I thougt first it was a bug, but this one works :
[ti:Angel]
[00:29.68]ANGEL - PUT SAD WINGS AROUND ME NOW
[00:38.99]PROTECT ME FROM THIS WORLD OF SIN
[00:43.13][03:43.26]SO THAT WE CAN RISE AGAIN
[00:51.57]OH ANGEL - WE CAN FIND OUR WAY SOMEHOW
[01:01.73]ESCAPING FROM THE WORLD WE’RE IN
[01:05.77]TO A PLACE WHERE WE BEGAN
[01:14.31]AND I KNOW WE’LL FIND
[01:18.76]A BETTER PLACE AND PEACE OF MIND
[01:24.72]JUST TELL ME THAT IT’S ALL YOU WANT - FOR YOU AND ME
[01:34.79]ANGEL WON’T YOU SET ME FREE
[01:49.34]ANGEL REMEMBER HOW WE’D CHASE THE SUN
[01:58.54]THEN REACHING FOR THE STARS AT NIGHT
[02:02.53]AS OUR LIVES HAD JUST BEGUN
[02:11.28]WHEN I CLOSE MY EYES I HEAR YOUR VELVET WINGS AND CRY
[02:21.49]I’M WAITING HERE WITH OPEN ARMS – OH CAN’T YOU SEE
[02:32.72]ANGEL SHINE YOUR LIGHT ON ME
[03:00.29]OH ANGEL WILL WE MEET ONCE MORE – I’LL PRAY
[03:05.64]WHEN ALL MY SINS ARE WASHED AWAY
[03:11.11]HOLD ME INSIDE YOUR WINGS AND STAY
[03:21.41]OH! ANGEL TAKE ME AWAY
[03:28.44][03:39.72]PUT SAD WINGS AROUND ME NOW
[03:32.88]ANGEL TAKE ME FAR AWAY
Isn't the format being standardized?
Reply #121
[ar:Judas Priest]
[ti:Angel]
[by:DAzed]
[00:00.00]Angel
[51:00.00]Oh angel,
[ti:Angel]
[01:01.73]ESCAPING FROM THE WORLD WE'RE IN
[01:14.31]AND I KNOW WE'LL FIND
[01:24.72]JUST TELL ME THAT IT'S ALL YOU WANT - FOR YOU AND ME
[01:34.79]ANGEL WON'T YOU SET ME FREE
[01:49.34]ANGEL REMEMBER HOW WE'D CHASE THE SUN
[02:21.49]I'M WAITING HERE WITH OPEN ARMS – OH CAN'T YOU SEE
[03:00.29]OH ANGEL WILL WE MEET ONCE MORE – I'LL PRAY
Lyrics Show Panel use Simple LRC format
The Line Time Tags are in the format [mm:ss.xx] where mm is minutes, ss is seconds and xx is hundredths of a second. (from wikipedia)
Reply #122
Baldurien: just remove for example in [1:01:00.00] those two zeros after : ... result [1:01.00]
Reply #123
Cool mode! Bravo
Will be great to be able to swich between lyrics providers/servers.
Reply #124
Okay
(does it support the word by word lirics format? )
