Topic: Lyrics Show Panel (Modified version) (Read 490114 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
Reply #200
Hey, Here is a new idea for you plugin : I have tracks that contains accented character (like Motörhead, which is written Motorhead too often :/). It seems the search engine of the lyrics website does not replace accents with their equivalents.
Is that possible to have such option while searching? eg: searching Motörhead and Motorhead?
Good idea.
Now I'm working on a new search engine that support multi servers and search strategy.
Reply #201
Hi. I have a problem with this plug-in. It only manages to download 10 lyrics, but then I have to restart foobar, in order to get it to download again. I am using the latest DEV version, but it was the same with previous. Can you help me?
Reply #202
Sorry I can't reproduce that. Can you post screenshots of your configuration of "Setting" and "Internet" tab?
Reply #203
Here:
Reply #204
just reporting in to say that i have experienced the above issue as well. i never really counted but there were times when i wondered why it wouldnt display/download lyrics for a popular song.
restarting foobar made it download lyrics again.
this wasnt a firewall issue since i had no software/hardware firewall installed. i always thought it was coz i was on slow connection. dial up.
Reply #205
So, is there a way to fix it?
Reply #206
Hi, guys! I just found out about this component and I want to ask a few questions...
1. I've found out a strange bug - foo_uie_lyrics is chopping off the first characters of my lyrics files. Not the downloaded ones, but the ones I had before I started using foobar and lyrics show panel. It could be due to a bad formatting by my former lyrics plug-in, but I doubt that - all my lyrics are stored in .txt files, and not embedded in the mp3's. I used WinLyrics for Winamp, and it is still displaying them properly...
Here's an example:
[a href="http://img65.imageshack.us/my.php?image=lyricspanelproblempp0.jpg" target="_blank"]
Reply #207
@Blueinferno:
@Susan:
I attempt to reproduce the problem but after downloading over 50 lyrics and show it on the lyrics show panel so it seemed work fine.
However, there is three reasons may cause your problems:
(1). This is a bug and I'll fixed it later: If once you associate a song with one lyric file(just see your lyrics.xml file in foobar2000 directory), and then the lyric file is deleted or moved, It will show nothing on the lyrics file.
(2). In your lyrics.xml file, you can see "disabled" attrib in your each xml elems. It's always set to "false", but once the "disabled" is set to "true"(related to "Disable associations" and "Enable associations"), the  panel will not show lyric.
(3). In the "setting" tab, you can see Filter setting. like this:
// Below two lines means if %title% or %_filename% contains any of Track* or CDImage.* or Unknown*, the lyric won't be downloaded nor shown.
[Column 1]                                                [Column 2]
Track*;CDImage.*;Unknown*        $if2(%title%,%_filename%)
That means if the content of [Column 1] matches [Column 2], The lyric won't be downloaded nor shown.
EDIT: If you tried set "Save scheme" another setting besides "Embed to file" but you still encountered the problem please let me know.
@halocline_
1. Can you send the lyric file to me? (Please update the lyric file in some file hosting.)
2. Currently I'm working on foo_makelyric plug-in which can cooperate with the foo_uie_lyrics plug-in, but I can't make any schedule now because I have a lot of other work to do.
Reply #208
@halocline_
Sure, here it is
Reply #209
I don't have a lyrics.xml file in my foobar directory. I'm only embedding them to a file.
Even if they matched (they don't), lyrics to the next song would be being downloaded, and they are not.
Right now nothing is being downloaded, so I can't really check it.
Reply #210
@halocline_:
confirmed as a bug, I'll fix it.
@Blueinferno:
I'm sorry I've no idea about that.
Reply #211
I don't have so much lyrics but more album reviews and biographies of artists wich are stored in simple txt-files. It would be a nice feature if each Lyric Show panel could have its own settings like Album Art panel has so that we could have several panels with different sources.
Reply #212
@halocline_:
New version updated(latest DEV build).
@q-stankovic:
The development of this feature had been suspended because of time, sorry.
Reply #213
could you add the feature to select the transparancy rather then just on or off? or is it possible using panels?
Reply #214
@Blueinferno:
Too bad. Maybe someone else is having the same problem and is able to help me?
Plus, in the newest DEV version, when i right click the panel, app crushes and I get this:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0112CB05h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (0112CB05h):
0112CAC5h:  89 25 00 00 00 00 83 EC 30 8B 4D 08 8B 01 53 56
0112CAD5h:  57 FF 10 8B D8 85 DB 89 5C 24 14 75 07 32 C0 E9
0112CAE5h:  AF 00 00 00 33 F6 85 DB 76 54 8B 4D 08 8D 44 24
0112CAF5h:  0C 50 8B D6 E8 02 CD FF FF 83 64 24 44 00 8B 08
0112CB05h:  8B 01 FF 50 0C 8B 10 8B C8 FF 12 83 4C 24 44 FF
0112CB15h:  8B 4C 24 0C 85 C9 8B F8 74 04 8B 01 FF 10 8B C7
0112CB25h:  8D 7C 24 18 E8 62 00 01 00 68 98 3C 15 01 50 FF
0112CB35h:  15 04 12 15 01 85 C0 75 A4 46 3B F3 72 AC 33 F6
Stack (0012F170h):
0012F150h:  00000000 00000008 00020716 00000000
0012F160h:  B04CDAD4 BF80EE00 BC6E4E38 00000008
0012F170h:  0429DBC8 0115EF0C 01184700 00000000
0012F180h:  00492A0D 00000001 00000008 01184740
0012F190h:  03C84B90 00014C84 00000007 01180178
0012F1A0h:  0012F2A0 0012F1E4 7C90EE18 0012F2B8
0012F1B0h:  0114EA97 00000000 0049435E 0012F2C4
0012F1C0h:  0112D06D 0429DBC8 0115EF0C 01126085
0012F1D0h:  00000000 0429DBC8 0012F274 0012F290
0012F1E0h:  0429DC28 0429DBB8 0429DBC8 01184728
0012F1F0h:  01125F25 00000000 0429DBC8 0012F274
0012F200h:  0012F290 0429DC28 00000000 004113EB
0012F210h:  0012F274 0012F290 0429DBC8 0429DC28
0012F220h:  0429DBB8 03C95A00 00000035 7C90EE18
0012F230h:  7C917BB8 01184720 01180168 00000000
0012F240h:  00000000 01184720 00000018 01184728
0012F250h:  00000000 01180178 00000018 00000000
0012F260h:  01180000 0012F05C 0429DC28 0012F36C
0012F270h:  7C90EE18 004C7650 00000000 00000000
0012F280h:  00000000 00000000 00000000 0000000C
Registers:
EAX: 0012F17C, EBX: 00000001, ECX: 00000000, EDX: 00000000
ESI: 00000000, EDI: 0429DBC8, EBP: 0012F1BC, ESP: 0012F170
Crash location: "foo_rgscan", loaded at 01120000h - 01168000h
Loaded modules:
foobar2000   loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B2000h
kernel32 loaded at 7C800000h - 7C8FC000h
COMCTL32 loaded at 773C0000h - 774C3000h
msvcrt   loaded at 77C00000h - 77C58000h
ADVAPI32 loaded at 77DC0000h - 77E6C000h
RPCRT4   loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 7E360000h - 7E3F0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1DC000h
ole32 loaded at 774D0000h - 7760D000h
shared   loaded at 10000000h - 10029000h
comdlg32 loaded at 76380000h - 763C9000h
uxtheme   loaded at 5B1D0000h - 5B208000h
CbrHelper loaded at 00A40000h - 00A45000h
foo_albumlist loaded at 00A50000h - 00A97000h
OLEAUT32 loaded at 77110000h - 7719B000h
foo_appcommand   loaded at 00AC0000h - 00AD6000h
foo_audioscrobbler   loaded at 00B00000h - 00B30000h
WS2_32   loaded at 71A50000h - 71A67000h
WS2HELP   loaded at 71A40000h - 71A48000h
foo_cdda loaded at 00B50000h - 00B85000h
foo_converter loaded at 00BB0000h - 00C19000h
foo_cwb_hooks loaded at 00C40000h - 00C75000h
foo_dbsearch loaded at 00CA0000h - 00D10000h
foo_dbsearch_api_demo loaded at 00D30000h - 00D51000h
foo_dop   loaded at 00D80000h - 00DEF000h
SETUPAPI loaded at 77910000h - 77A06000h
gdiplus   loaded at 4EBC0000h - 4ED63000h
foo_dsp_std   loaded at 00E20000h - 00E61000h
foo_history   loaded at 00E90000h - 00EAC000h
foo_input_std loaded at 00ED0000h - 00FE2000h
foo_lyricsdb loaded at 01010000h - 0102E000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
MSVCR80   loaded at 78130000h - 781CB000h
WININET   loaded at 771A0000h - 77247000h
CRYPT32   loaded at 77A70000h - 77B05000h
MSASN1   loaded at 77B10000h - 77B22000h
foo_masstag   loaded at 01050000h - 010A0000h
foo_playcount loaded at 010C0000h - 010E8000h
foo_rgscan   loaded at 01120000h - 01168000h
foo_run   loaded at 01190000h - 011BB000h
foo_sendtodevice loaded at 011E0000h - 0121A000h
foo_uie_albumart loaded at 01240000h - 0127C000h
foo_uie_lyrics   loaded at 012A0000h - 01301000h
WINMM loaded at 76B20000h - 76B4E000h
foo_uie_queuemanager loaded at 013B0000h - 013E9000h
mscoree   loaded at 79000000h - 79045000h
msvcm80   loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni   loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh   loaded at 0FFD0000h - 0FFF8000h
System.ni loaded at 7A440000h - 7AC06000h
System.Drawing.ni loaded at 7ADE0000h - 7AF6C000h
foo_ui_columns   loaded at 03B30000h - 03BD6000h
foo_ui_std   loaded at 03C00000h - 03C57000h
dciman32 loaded at 73B50000h - 73B56000h
netapi32 loaded at 6FF40000h - 6FF94000h
appHelp   loaded at 77B30000h - 77B52000h
CLBCATQ   loaded at 76FC0000h - 7703F000h
COMRes   loaded at 77040000h - 7710D000h
VERSION   loaded at 77BF0000h - 77BF8000h
shdocvw   loaded at 7E1E0000h - 7E34F000h
CRYPTUI   loaded at 768B0000h - 76932000h
WINTRUST loaded at 76C20000h - 76C4E000h
IMAGEHLP loaded at 76C80000h - 76CA8000h
WLDAP32   loaded at 76F50000h - 76F7D000h
urlmon   loaded at 7DF10000h - 7DFB0000h
Secur32   loaded at 77FE0000h - 77FF1000h
DBGHELP   loaded at 59BC0000h - 59C61000h
Stack dump analysis:
Address: 0115EF0Ch, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00492A0Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "strchr" (+00000117h)
Address: 0114EA97h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 0049435Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112D06Dh, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 01126085h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 01125F25h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 004113EBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 004C7650h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0113E5B7h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00410EE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045CBFDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AB9EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041185Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041191Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042B3E6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041265Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412310h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004124F1h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00410CAAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411882h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004ACF61h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411977h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412FA2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC416h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AB8EBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412B49h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112F46Ch, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00403ED7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00412CDEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490199h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0112F494h, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 00411CFFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0115EEFCh, location: "foo_rgscan", loaded at 01120000h - 01168000h
Address: 004C3BE8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00403EC8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AE12Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00411207h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6799h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041107Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 012A91AFh, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 012E8C0Ch, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 03B36C80h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E36B42Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 012E31F9h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 012A7B01h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E368BD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E3C0088h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3CCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E36B3A7h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E37878Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "ChildWindowFromPoint" (+000000B6h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 03B56F80h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 03B57057h, location: "foo_ui_columns", loaded at 03B30000h - 03BD6000h
Address: 7E37379Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E3684FCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3685A4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E36B3F9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 7E368B26h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 012B44E0h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 012E3348h, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E36D62Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetWindowLongW" (+00000000h)
Address: 012B452Ch, location: "foo_uie_lyrics", loaded at 012A0000h - 01301000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E373745h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E3737BCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E36D17Fh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "EnumDisplayMonitors" (+0000021Ch)
Address: 7E36B393h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 7E36C331h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 7E37366Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 7E3689CDh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E36F95Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 7E381B3Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 7E3689F0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E368A10h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 7E37D99Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FED2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7E36DAEAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEB74h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FF44h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C04F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430AA3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07B4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7634h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Address: 004E41B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B2000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00492BFDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4238h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447B71h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045CE23h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049976Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497440h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0508h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF584h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430CAAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E09B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049712Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00492502h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004924FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B3450h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF978h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496804h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00DCD0B8h, location: "foo_dop", loaded at 00D80000h - 00DEF000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8FC000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049686Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.4
UNICODE
Additional info:
Send to Device 1.1.0 (beta) [Dec 20 2006 - 16:40:06]  (foo_sendtodevice)
Database Search 1.4  (foo_dbsearch)
Masstagger 1.6  (foo_masstag)
WMA Decoder 1.1  (foo_input_std)
Album List 3.2.0  (foo_albumlist)
CD Audio Decoder 2.1.1  (foo_cdda)
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
iPod manager 0.4.5 TEST  (foo_dop)
History 0.2  (foo_history)
Default User Interface 0.9acc  (foo_ui_std)
Audioscrobbler 2.1  (foo_audioscrobbler)
Standard DSP array 1.0  (foo_dsp_std)
foobar2000 core 0.9.4.4  (Core)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
Album Art Panel 0.2.6  (foo_uie_albumart)
Columns UI 0.2.0 beta 1  (foo_ui_columns)
ReplayGain Scanner 2.0.2  (foo_rgscan)
FLAC Decoder 1.1.0  (foo_input_std)
Converter 1.0.1  (foo_converter)
Run services 0.3.2  (foo_run)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Playback Statistics 1.3.2  (foo_playcount)
Lyric Show Panels 0.3.1.1b8 DEV [Sep 15 2007 - 21:52:48]  (foo_uie_lyrics)
APPCOMMAND multimedia key support 0.1  (foo_appcommand)
Reply #215
@Blueinferno:
It's a critial bug, to avoid the bug, do not right click the panel if the song isn't playing.
I'll fix it soon.
Reply #216
@2Pacalypse:
The "transparent" in fact, is pseudo transparent.
If you want semi-transparecy, create a semi-transparent rectange before place the lyrics show panel.
@Blueinferno:
The bug that caused foobar crash is fixed now(latest DEV version)
Reply #217
any idea how to show the lyrics in small letter?
Reply #219
@Blueinferno:
Ok, thanks.
Hey, I was thinking. If you don't know how to help me with this downloading-only-10-lyrics problem, maybe you can give me a site you take lyrics from, and I'll download 'em manually. That'll be, I guess, more convenient than restarting the app after every 10 lyrics are downloaded.
Reply #221
TP Wang you are making such a great work, thank you. I hope you ll have time to continue the multiple instance feature since know i depending on a pvar  draw the lyrics panel in different places and it goes mad. After changing its position it keeps flicking and doesnt always redraw.
I have a strange bug also, i have empty lyrics automatically created when changing track even if the automatic download feature isnt checked. It happened on my two machines, once with txt files the other with lrc files. Happening right now.
Little feature request: could you add an entry for online search in the context menu of a track so that we can make a button for lyrics?
Thanks a lot
Reply #222
@Blueinferno:
Ok, thanks.
Have your tried right click on the panel - > Online search?
If you can visit http://www.viewlyrics.com:1212, The panel should download lyrics.(you can't download the lyrics directly)
Pardon? I can't quite understand.
hmm, I just want all the lyrics (or text) to display in 'lowercase' instead of 'Sentence case' and 'UPPERCASE'. I've tried using panels ui syntax but it didn't work. is there any way to do so?
Sounds reasonable, I'll consider to add this feature.
Sorry, but I have lot of work to do now, really.
I hope there's more time for me to continue development in next month.
I can reproduce the bug, I'll fix it later, thanks.
Yes, I'll add it, int the next DEV version.
Reply #223
Hello T.P. Wang,
although all of us like to make feature requests there is nobody who wants a feature implementation on the next day.
Even next month is very fast!
Reply #224
I second that q-stankovic!
Thanks for the great plugin, T.P Wang.
Really love it.
