Topic: Lyrics Show Panel (Modified version) (Read 490097 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
Reply #400
Maybe you could make non timestamped lyrics align vertically in the middle of panel, if they are short enough to not need scrolling? It looks bad imo when they are at the top.
If I enable scroll it looks better but do such sort lyrics need scrolling? No.
Reply #401
@dypsis:
1. Does it happen to EVERY plain text lyric?
2. Which UI are you using, Dockable Panels, Columns UI or Panels UI?
1. Yes, it happens with every lyric.
2. I am using the Default UI, but I am using Dockable Panels to display Lyrics Show.
Reply #402
@cristox:
The text should be shown initially with its first line at the top of the panel.
Then the indicator highline should scroll down on the text line by line until it is in the middle (or option to let it scroll down selected number of lines) of the panel.
Then the text should scroll up under the indicator highline
The lyric display behavior current used is inherited from the original version of Lyric Show Panel, and thus I won't change the behavior since this is just a mod of Lyric Show Panel.
If you want to make your own behavior, you can grab the source I provided, and do some changes.
@orchid:
Maybe
@dypsis:
I'm sorry I can't reproduce that in Defaut UI and using Dockable Panels.
Please give me a screenshot about that.
Reply #403
I have been having an issue with lyrics placement, and finally figured out why it looked strange to me!
Oh, for a fix, basically, the lines with brackets need to be moved over to the left a little bit. I don't know how easy that is to do however.
Reply #404
Hi, I've been having some bad luck with the new versions of Lyric Show, all three versions in the download thread you linked to in the OP. Foobar crashes whenever I click on the button which shows my lyrics panel using Panels UI 14.9. I realise this is a beta of Panels UI, so the problem could lie there, but I though I'd put the crash logs here. I know you're not developing it anymore either according to the OP, so maybe there's no point posting these, but just in case you do need them:
Lyrics 0.3.2.0 Alpha 2:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04B92C5Fh
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop=>titleformat_object::run
Code bytes (04B92C5Fh):
04B92C1Fh:  50 FF 15 4C E2 BD 04 8B 44 24 0C 8B 0D FC FB BE
04B92C2Fh:  04 50 51 FF 15 C0 E2 BD 04 8B 44 24 14 8B 50 0C
04B92C3Fh:  8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC FB
04B92C4Fh:  BE 04 52 50 6A 00 51 FF 15 50 E2 BD 04 8B 4E 68
04B92C5Fh:  8B 11 A1 FC FB BE 04 8B 52 30 50 FF D2 8B 4E 68
04B92C6Fh:  85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
04B92C7Fh:  00 EB 22 8B 4C 24 0C 8B 15 D0 FB BE 04 8D 46 04
04B92C8Fh:  50 68 50 85 BA 04 51 6A 65 52 FF 15 44 E2 BD 04
Stack (0012E384h):
0012E364h:  BF89EE05 BC67EC18 BC67EC38 00000007
0012E374h:  00060000 00000000 0ED234B0 7E431891
0012E384h:  0CF78818 0D6116B0 0CEAEDC2 0008080A
0012E394h:  0012E3C8 0CF46370 DA14A456 0D6116B0
0012E3A4h:  0CF73E30 04C155A8 0012E401 0CF78818
0012E3B4h:  0012E438 0CF1F4F6 00000005 0CEAF390
0012E3C4h:  0D6116B0 0CF78818 0008080A 04C155A8
0012E3D4h:  DA14A42E 00000004 100065C5 0012E558
0012E3E4h:  000001CB 04C155A8 0012E3D0 0D6116B0
0012E3F4h:  00000013 003C8D10 0CF73E18 0CF2803C
0012E404h:  0D6254D8 0000001B 0000001B 0000000A
0012E414h:  0000000F 0D614D38 2D207363 0D610020
0012E424h:  0012E44C 00000013 0000001F DA14A41E
0012E434h:  0D611748 0012E54C 0CF2086C 00000007
0012E444h:  0CEAE33A 0CF73E18 0CE96584 6972796C
0012E454h:  00007363 00000004 100065C5 00000006
0012E464h:  0000000F 00000005 6972794C 68532063
0012E474h:  1000776F 0D4BDCD0 0000000A 0000000F
0012E484h:  DA14A37E 0012E617 0D614CE0 0012E5D0
0012E494h:  00000181 0000004D 0D4BDA58 0012E6D4
Registers:
EAX: 00000001, EBX: 00000000, ECX: 00000000, EDX: 7C90EB94
ESI: 04C155A8, EDI: 0CF78818, EBP: 0D6116C4, ESP: 0012E384
Crash location: "foo_uie_lyrics", loaded at 04B90000h - 04BFB000h
Loaded modules:
foobar2000                      loaded at 00400000h - 0051E000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
RocketDock                      loaded at 003D0000h - 003E2000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
MSCTF                            loaded at 74720000h - 7476B000h
SynTPFcs                        loaded at 63000000h - 63013000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_managedWrapper              loaded at 00AE0000h - 00BAA000h
mscoree                          loaded at 79000000h - 79045000h
MSVCR80                          loaded at 78130000h - 781CB000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D6000h
mscorlib.ni                      loaded at 790C0000h - 79B90000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7AC06000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF6C000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC54000h
xpsp2res                        loaded at 20000000h - 202C5000h
dotnet_title                    loaded at 11000000h - 1101C000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_abx                          loaded at 036A0000h - 036D3000h
foo_albumlist                    loaded at 03700000h - 03765000h
foo_appcommand                  loaded at 03790000h - 037A6000h
foo_audioscrobbler              loaded at 037D0000h - 03800000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 03820000h - 03850000h
foo_browser                      loaded at 03870000h - 038A9000h
foo_burninate                    loaded at 038D0000h - 03907000h
foo_cdda                        loaded at 03930000h - 03965000h
foo_comserver2                  loaded at 03990000h - 039E6000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_converter                    loaded at 03A10000h - 03A75000h
foo_custominfo                  loaded at 03AA0000h - 03B25000h
foo_cwb_hooks                    loaded at 03B50000h - 03B9D000h
foo_discogs                      loaded at 03BC0000h - 03C3D000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dockable_panels              loaded at 03CD0000h - 03D03000h
foo_dsp_std                      loaded at 03D30000h - 03D77000h
foo_fileops                      loaded at 03DA0000h - 03DE7000h
foo_freedb2                      loaded at 03E10000h - 03E51000h
foo_highlightplaying            loaded at 03E80000h - 03EA1000h
foo_input_mslive                loaded at 03ED0000h - 03F53000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CAA000h
libmmd                          loaded at 03F70000h - 04221000h
foo_input_std                    loaded at 04240000h - 04362000h
foo_lyricsdb                    loaded at 04390000h - 043BF000h
WININET                          loaded at 771B0000h - 77267000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
Normaliz                        loaded at 71660000h - 71669000h
foo_masstag                      loaded at 045F0000h - 04640000h
foo_msnalt_stream                loaded at 04660000h - 04684000h
foo_navigator                    loaded at 046B0000h - 046E4000h
foo_osd                          loaded at 04710000h - 04742000h
foo_playcount                    loaded at 04770000h - 04798000h
foo_playlist_tree                loaded at 047C0000h - 04836000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 04860000h - 04904000h
foo_rgscan                      loaded at 04950000h - 049A0000h
foo_run                          loaded at 049C0000h - 049EB000h
foo_scheduler                    loaded at 04A10000h - 04A7F000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
foo_uie_albumart                loaded at 04AA0000h - 04ADD000h
foo_uie_albumart_msn            loaded at 04B00000h - 04B1C000h
foo_uie_albumlist                loaded at 04B30000h - 04B6D000h
foo_uie_lyrics                  loaded at 04B90000h - 04BFB000h
foo_uie_powerpanels              loaded at 04C20000h - 04C43000h
foo_uie_quicksearch              loaded at 04C70000h - 04CB6000h
foo_uie_tabs                    loaded at 04CE0000h - 04D0A000h
foo_uie_vis_projectm            loaded at 04D30000h - 04D7A000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_ui_columns                  loaded at 0CD70000h - 0CE6E000h
foo_ui_panels                    loaded at 0CE90000h - 0CF56000h
IMM32                            loaded at 76390000h - 763AD000h
foo_ui_std                      loaded at 0CF80000h - 0D033000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_unpack                      loaded at 0D060000h - 0D08D000h
foo_write_http                  loaded at 0D0B0000h - 0D0EB000h
foo_input_validator              loaded at 0D110000h - 0D13E000h
foo_tutorial1_step1              loaded at 0D160000h - 0D17A000h
foo_tutorial1_step2              loaded at 0D1A0000h - 0D1C0000h
foo_tutorial1_step3              loaded at 0D1E0000h - 0D201000h
foo_tutorial1_step4              loaded at 0D230000h - 0D252000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
SXS                              loaded at 75E90000h - 75F40000h
msi                              loaded at 7D1E0000h - 7D49E000h
System.Xml.ni                    loaded at 637A0000h - 63D02000h
Accessibility.ni                loaded at 60000000h - 60014000h
diasymreader                    loaded at 5E380000h - 5E409000h
netapi32                        loaded at 5B860000h - 5B8B4000h
appHelp                          loaded at 77B40000h - 77B62000h
ieframe                          loaded at 46FE0000h - 47605000h
OLEACC                          loaded at 74C80000h - 74CAC000h
MSVCP60                          loaded at 76080000h - 760E5000h
ADVPACK                          loaded at 65000000h - 6502B000h
SETUPAPI                        loaded at 77920000h - 77A13000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
MSHTML                          loaded at 7D4A0000h - 7D7C5000h
iertutil                        loaded at 5DCA0000h - 5DCAD000h
urlmon                          loaded at 61410000h - 614E9000h
msls31                          loaded at 746C0000h - 746E9000h
MSRATING                        loaded at 63400000h - 63436000h
sfc                              loaded at 76BB0000h - 76BB5000h
sfc_os                          loaded at 76C60000h - 76C8A000h
IEUI                            loaded at 5DFF0000h - 5E020000h
shellexecutehook                loaded at 0EBD0000h - 0EBE3000h
MOUDL32A                        loaded at 0ED20000h - 0ED33000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 0CEAEDC2h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF1F4F6h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEAF390h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 100065C5h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "stricmp_utf8_ex" (+00000000h)
Address: 0CF2803Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF2086Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEAE33Ah, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CE96584h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 1000776Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetLongPathName" (+00000044h)
Address: 0045D8D6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042E7B3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004056B6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004056D0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004055CEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF20920h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CED75E2h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+000038C2h)
Address: 0CED760Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+000038EFh)
Address: 00463C69h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CCC80h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CCC60h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF08h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4476h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045FFB7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004AD08Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004603EFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00463DA2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0046531Dh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00464964h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ACAF1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CEA781Bh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF29858h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 773E207Bh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "DefSubclassProc" (+00000055h)
Address: 0CF29754h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF2989Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004EA884h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF28154h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF409E4h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CE9C22Dh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 77F17012h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "BitBlt" (+00000089h)
Address: 77F16FFAh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "BitBlt" (+00000071h)
Address: 0CEA386Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF21990h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA389Ch, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004300E2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E470088h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3CCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 7E41B3A7h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B3B0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 0CEA32F3h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 74DA49F4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+00000036h)
Address: 74DA4A1Ah, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptIsComplex" (+0000005Ch)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 629C3004h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkInitialize" (+0000013Ch)
Address: 629C6080h, location: "LPK", loaded at 629C0000h - 629C9000h
Address: 629C31F7h, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkInitialize" (+0000032Fh)
Address: 629C322Ch, location: "LPK", loaded at 629C0000h - 629C9000h
Symbol: "LpkExtTextOut" (+00000029h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 1000B5C1h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000B5E0h, location: "shared", loaded at 10000000h - 1002A000h
Address: 77F15B80h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "SelectObject" (+00000000h)
Address: 1000E080h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10002A25h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+00000384h)
Address: 1000275Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+000000B9h)
Address: 10007137h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uExtTextOut" (+00000061h)
Address: 0CE110BEh, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CD7E353h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE11316h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE37078h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE1CF4Fh, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 0CE114A2h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7E41B3F9h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 0CD97A10h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 7E41B473h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77F1DBA7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "InvertRgn" (+00000060h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0CF21E3Fh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0CEA1E31h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA1E4Eh, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 03CD48C0h, location: "foo_dockable_panels", loaded at 03CD0000h - 03D03000h
Address: 03CD48FAh, location: "foo_dockable_panels", loaded at 03CD0000h - 03D03000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000193h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000163h)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E41C63Fh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 7E41C665h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 773E1B57h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal11" (+00000328h)
Address: 773E1E65h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "RemoveWindowSubclass" (+00000139h)
Address: 773E1ECFh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "RemoveWindowSubclass" (+000001A3h)
Version info:
foobar2000 v0.9.5 beta 8
UNICODE
Windows 5.1
Additional info:
File Operations 2.0  (foo_fileops)
Audioscrobbler 2.2  (foo_audioscrobbler)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Scheduler 3.53  (foo_scheduler)
RAR reader 1.1  (foo_unpack)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Component Tutorial (Step 4) 0.3.2  (foo_tutorial1_step4)
Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55]  (foo_ui_panels)
Seek Panel 0.1  (foo_uie_powerpanels)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Default User Interface 0.9.5  (foo_ui_std)
Audio CD Writer 2.0.1  (foo_burninate)
foo_custominfo 0.1.2  (foo_custominfo)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
Playback Statistics 1.3.2  (foo_playcount)
Columns UI 0.2.1 alpha 9 v3  (foo_ui_columns)
projectM visualization (Panel) 0.4  (foo_uie_vis_projectm)
Album list panel 0.2.2  (foo_uie_albumlist)
Discogs Tagger 1.0  (foo_discogs)
Album List 4.1  (foo_albumlist)
freedb Tagger 0.5.2.1  (foo_freedb2)
MSN Now Playing (alt) with stream radio support 2.5  (foo_msnalt_stream)
foobar2000 core 0.9.5 beta 8  (Core)
Navigator 0.63  (foo_navigator)
Component Tutorial (Step 2) 0.3.2  (foo_tutorial1_step2)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Converter 1.0.2  (foo_converter)
Standard DSP Array 1.0  (foo_dsp_std)
Run services 0.3.2  (foo_run)
HTTP Writer 1.1  (foo_write_http)
ZIP/GZIP reader 1.0  (foo_unpack)
ABX Comparator 1.3.1  (foo_abx)
CD Audio Decoder 2.1.2  (foo_cdda)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
APPCOMMAND multimedia key support 0.1  (foo_appcommand)
Masstagger 1.6  (foo_masstag)
Highlight playing 0.1.0  (foo_highlightplaying)
COM Automation server 0.7 alpha 6  (foo_comserver2)
Decoder Validator 1.0  (foo_input_validator)
On-Screen Display 1.52  (foo_osd)
Album Art Panel Mod (MSN) 0.2.1_8  (foo_uie_albumart_msn)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Volume Panel 0.1  (foo_uie_powerpanels)
foo_managedWrapper 0.4  (foo_managedWrapper)
Component Tutorial (Step 1) 0.3.2  (foo_tutorial1_step1)
Lyric Show Panels 0.3.2.0 Alpha 2 [Dec 18 2007 - 15:28:24]  (foo_uie_lyrics)
mslive 0.4.1 (Intel SSE)  (foo_input_mslive)
Playlist Tree Panel 3.0.4 [Aug  2 2007 - 10:16:21]  (foo_playlist_tree)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Component Tutorial (Step 3) 0.3.2  (foo_tutorial1_step3)
Lyrics 0.3.2.0 Alpha 1:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04B92B0Fh
Call path:
Code bytes (04B92B0Fh):
04B92ACFh:  50 FF 15 50 D2 BD 04 8B 44 24 0C 8B 0D FC EB BE
04B92ADFh:  04 50 51 FF 15 C4 D2 BD 04 8B 44 24 14 8B 50 0C
04B92AEFh:  8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC EB
04B92AFFh:  BE 04 52 50 6A 00 51 FF 15 54 D2 BD 04 8B 4E 68
04B92B0Fh:  8B 11 A1 FC EB BE 04 8B 52 30 50 FF D2 8B 4E 68
04B92B1Fh:  85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
04B92B2Fh:  00 EB 22 8B 4C 24 0C 8B 15 D0 EB BE 04 8D 46 04
04B92B3Fh:  50 68 50 7F BA 04 51 6A 65 52 FF 15 48 D2 BD 04
Stack (0012E384h):
0012E374h:  00060000 00000000 0EDD34B0 7E431891
0012E384h:  0CF78818 0D623390 0CEAEDC2 000C0802
0012E394h:  0012E3C8 0CF46370 04984122 0D623390
0012E3A4h:  0CF73E30 04C15618 0012E401 0CF78818
0012E3C4h:  0D623390 0CF78818 000C0802 04C15618
0012E3D4h:  0498415A 00000004 100065C5 0012E558
0012E3E4h:  000001CB 04C15618 0012E3D0 0D623390
0012E3F4h:  0000000F 003C8D10 0CF73E18 0CF2803C
0012E404h:  0D623060 0000001B 0000001B 0000000A
0012E414h:  0000000F 0D624388 2D207363 0CF70020
0012E424h:  0012E44C 00000013 0000001F 0498416A
0012E434h:  0CF7A430 0012E54C 0CF2086C 00000007
0012E474h:  1000776F 0D50A0C0 0000000A 0000000F
0012E484h:  0498460A 0012E617 0D623020 0012E5D0
0012E494h:  00000181 0000004D 0D50A7B8 0012E6D4
Registers:
ESI: 04C15618, EDI: 0CF78818, EBP: 0D6233A4, ESP: 0012E384
Crash location: "foo_uie_lyrics", loaded at 04B90000h - 04BFA000h
Loaded modules:
foo_uie_lyrics                  loaded at 04B90000h - 04BFA000h
shellexecutehook                loaded at 0EC80000h - 0EC93000h
MOUDL32A                        loaded at 0EDD0000h - 0EDE3000h
Address: 04984122h, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498415Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498416Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 0498460Ah, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 04984AEEh, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 04984A02h, location: "foo_rgscan", loaded at 04950000h - 049A0000h
Address: 004700CBh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 77F1939Dh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateDIBSection" (+00000184h)
Address: 77F192ECh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "CreateDIBSection" (+000000D3h)
Address: 4ECD9033h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECD903Eh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 4ED55B38h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4AFC0h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4B4DBh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4AF5Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECA6FFFh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED43545h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 77F1E611h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DdEntry53" (+0000000Ch)
Address: 77F1E5FCh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DdEntry39" (+00000028h)
Address: 73BC143Eh, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000048h)
Address: 73BC144Eh, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000058h)
Address: 4ED436E4h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 73BC17E4h, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCICreatePrimary" (+0000024Bh)
Address: 73BC1458h, location: "DCIMAN32", loaded at 73BC0000h - 73BC6000h
Symbol: "DCIEndAccess" (+00000062h)
Address: 4ED43700h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4390Bh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED43AA5h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECA4A8Fh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4EADDh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAD00Ch, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAD362h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAE873h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECAEB31h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED502C0h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ED4397Bh, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC51580h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4EC99249h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Address: 4ECDE0B9h, location: "gdiplus", loaded at 4EC50000h - 4EDF3000h
Version info:
UNICODE
Windows 5.1
Additional info:
Lyric Show Panels 0.3.2.0 Alpha 1 [Dec  9 2007 - 14:55:15]  (foo_uie_lyrics)
There's another one but I think I've reached the post limit and there seems to be something stopping me double posting. I'll finish my post tomorrow.
Reply #405
@Keikonium:
It's because of GDI+.
GDI+'s text rendering is not good I think, so I may remove GDI+ text rendering  in the future(there's some other ways to implement fading effect)
@TomBarlow:
You should make sure there's no more instance of Lyric Show Panel GREATER than 1.
Reply #406
I checked and it's still not working. Yesterday when I first installed the new version I got a message saying there were multiple instances found, which was because the old version was installed at components\en-US\ which I hadn't noticed, I deleted that folder and that's when I got those crashes. I tried installing the new version to components\en-US\ just now in case foobar was looking for it there, but I'm getting the same thing. I've double checked my Panels code, my settings for the lyrics, but it still happens. Here's the latest crash log:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 036A2C5Fh
Call path:
Code bytes (036A2C5Fh):
036A2C1Fh:  50 FF 15 4C E2 6E 03 8B 44 24 0C 8B 0D FC FB 6F
036A2C2Fh:  03 50 51 FF 15 C0 E2 6E 03 8B 44 24 14 8B 50 0C
036A2C3Fh:  8B 48 08 6A 04 52 8B 50 04 8B 00 51 8B 0D FC FB
036A2C4Fh:  6F 03 52 50 6A 00 51 FF 15 50 E2 6E 03 8B 4E 68
036A2C5Fh:  8B 11 A1 FC FB 6F 03 8B 52 30 50 FF D2 8B 4E 68
036A2C6Fh:  85 C9 74 06 8B 01 8B 10 FF D2 C7 46 68 00 00 00
036A2C7Fh:  00 EB 22 8B 4C 24 0C 8B 15 D0 FB 6F 03 8D 46 04
036A2C8Fh:  50 68 50 85 6B 03 51 6A 65 52 FF 15 44 E2 6E 03
Stack (0012E19Ch):
0012E17Ch:  BF89EE05 BC678DB0 BC678DD0 00000007
0012E18Ch:  00060000 00000000 0EFD34B0 7E431891
0012E19Ch:  0CF78818 0D3AD710 0CEAEDC2 000E0614
0012E1ACh:  0012E1E0 0CF46370 CE073C16 0D3AD710
0012E1BCh:  0D391348 039B7AF8 0012E201 0CF78818
0012E1CCh:  0012E250 0CF1F4F6 00000005 0CEAF390
0012E1DCh:  0D3AD710 0CF78818 000E0614 039B7AF8
0012E1ECh:  CE073C5E 00000004 100065C5 0012E374
0012E1FCh:  000001DA 039B7AF8 0012E1E8 0D3AD710
0012E20Ch:  00000008 003C8DA8 0D391330 0CF2803C
0012E21Ch:  0D3CD8E0 0000001B 0000001B 0000000A
0012E22Ch:  0000000F 0D3A16A0 70207363 6C656E61
0012E23Ch:  00202D20 00000019 0000001F CE073FAE
0012E24Ch:  0D38D398 0012E364 0CF2086C 00000007
0012E25Ch:  0CEAE33A 0D391330 0CE96584 6972796C
0012E26Ch:  70207363 6C656E61 10006500 0000000C
0012E27Ch:  0000000F 00000005 6972794C 68532063
0012E28Ch:  1000776F 0D75DE80 0000000A 0000000F
0012E29Ch:  CE073F0E 0012E4AB 0D3836A8 0012E464
0012E2ACh:  0000016D 0000004D 0D77D110 0012E6D4
Registers:
ESI: 039B7AF8, EDI: 0CF78818, EBP: 0D3AD724, ESP: 0012E19C
Crash location: "foo_uie_lyrics", loaded at 036A0000h - 0370B000h
Loaded modules:
foo_uie_lyrics                  loaded at 036A0000h - 0370B000h
foo_abx                          loaded at 039C0000h - 039F3000h
foo_albumlist                    loaded at 03A20000h - 03A85000h
foo_appcommand                  loaded at 03AB0000h - 03AC6000h
foo_audioscrobbler              loaded at 03AF0000h - 03B20000h
foo_autoplaylist                loaded at 03B40000h - 03B70000h
foo_browser                      loaded at 03B90000h - 03BC9000h
foo_burninate                    loaded at 03BF0000h - 03C27000h
foo_cdda                        loaded at 03C50000h - 03C85000h
foo_comserver2                  loaded at 03CB0000h - 03D06000h
foo_converter                    loaded at 03D30000h - 03D95000h
foo_custominfo                  loaded at 03DC0000h - 03E45000h
foo_cwb_hooks                    loaded at 03E70000h - 03EBD000h
foo_discogs                      loaded at 03EE0000h - 03F5D000h
foo_dockable_panels              loaded at 03F70000h - 03FA3000h
foo_dsp_std                      loaded at 03FD0000h - 04017000h
foo_fileops                      loaded at 04040000h - 04087000h
foo_freedb2                      loaded at 040B0000h - 040F1000h
foo_highlightplaying            loaded at 04120000h - 04141000h
foo_input_mslive                loaded at 04170000h - 041F3000h
libmmd                          loaded at 04210000h - 044C1000h
foo_input_std                    loaded at 044E0000h - 04602000h
foo_lyricsdb                    loaded at 04630000h - 0465F000h
foo_masstag                      loaded at 04680000h - 046D0000h
foo_msnalt_stream                loaded at 046F0000h - 04714000h
foo_navigator                    loaded at 04740000h - 04774000h
foo_osd                          loaded at 047A0000h - 047D2000h
foo_playcount                    loaded at 04800000h - 04828000h
foo_playlist_tree                loaded at 04850000h - 048C6000h
libmzgc360_000                  loaded at 048F0000h - 04994000h
foo_rgscan                      loaded at 049E0000h - 04A30000h
foo_run                          loaded at 04A50000h - 04A7B000h
foo_scheduler                    loaded at 04AA0000h - 04B0F000h
foo_uie_albumart                loaded at 04B30000h - 04B6D000h
foo_uie_albumart_msn            loaded at 04B90000h - 04BAC000h
foo_uie_albumlist                loaded at 04BC0000h - 04BFD000h
shellexecutehook                loaded at 0E7A0000h - 0E7B3000h
MOUDL32A                        loaded at 0EFD0000h - 0EFE3000h
DSOUND                          loaded at 73F10000h - 73F6C000h
wdmaud                          loaded at 72D20000h - 72D29000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
Address: 10006500h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uReplaceCharAdd" (+0000003Eh)
Address: 0CED7593h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Symbol: "foobar2000_get_interface" (+00003873h)
Address: 0489DE78h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 048866EBh, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 004053B7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F8E4h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F8C0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048F7D3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0D70h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EDE90h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EAF28h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C9CD8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ACEF5h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043589Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C9CB4h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF40AE0h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 048B36D4h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 048B36A0h, location: "foo_playlist_tree", loaded at 04850000h - 048C6000h
Address: 004AD218h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00435926h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004EDCE0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B0298h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0044243Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004CAA44h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CE9FBB1h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CF1C520h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 0CEA7800h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 004600D0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0CF28104h, location: "foo_ui_panels", loaded at 0CE90000h - 0CF56000h
Address: 03E09418h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 03E093E1h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 00494469h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C910000h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosErrorNoTeb" (+00000477h)
Address: 03E00001h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E0CAE0h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E08D65h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 03E08D46h, location: "foo_custominfo", loaded at 03DC0000h - 03E45000h
Address: 0CE1F8D8h, location: "foo_ui_columns", loaded at 0CD70000h - 0CE6E000h
Address: 00464903h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0045FE4Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C2E80h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00466449h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 03EA1360h, location: "foo_cwb_hooks", loaded at 03E70000h - 03EBD000h
Address: 00466BBDh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0046048Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
UNICODE
Windows 5.1
Additional info:
Reply #407
@TomBarlow:
Multi instance I meant is put more than one panel at the same time.
You should check your code, prevent something like this:
$panel(lyric1,Lyric Show,...)
$panel(lyric2,Lyric Show,...)
one Lyric Show in PUI code and another in Dockable Panels
et hoc genus omne.
FYI, I have a glance at your components, foo_audioscrobbler is listed as its "Repeated crash reports.".
However, that's fixed(but still doesn't support multi instances), I'll release it some days later.
Reply #408
Anybody have problems with lyrcis download? The last version 0.3.2.0 Alpha 2?
Reply #409
@TomBarlow:
et hoc genus omne.
Thanks, it's working now, I had a lyrics panel in a dockable panel that I wasn't using any more, I didn't realise it was still stored away.
Reply #410
I've uploaded 0.3.2.0 Alpha 3 with some minor changes
for major changes see ChangeLog
this build is for stability only
bye
Reply #411
Happy New Year!
It's beta time
0.3.2.1 beta 1 released
bye
Reply #412
Nice plugin with transparent feature.
But is it possible to add on setting for encoding inside foobar's preferences so that we can choose the default encoding for all the lyrics? I dont know why but all my lyrics for chinese and japanese will show some weird character until i change the encoding. Quite troublesome to change everytime..
Reply #413
@teNtiOn:
I've just considered to add it in the next release.
thanks.
Reply #414
I don't know why but when I scroll through the lyrics (in case it's a .txt file) the playlist scrolls as well. It's a bit annoying . Not a major issue though.
Reply #415
@T.P Wang: Nice man, looking forward for it.
Reply #416
Is there a plan to make this plugin work under default 0.95 GUI?
Reply #417
I guess first the DefaultUI SDK should be made available... the developer of foo_uie_peakmeter is waiting for it.
Reply #418
Hi there. I've ran into so crashes that seem to be incurred by foo_uie_lyrics 0.3.2.1 Beta 1 [Jan  2 2008 - 20:43:21] (see codebox). I wasn't doing anything particular at the time.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04173500h
Call path:
entry=>app_mainloop
Code bytes (04173500h):
041734C0h:  ED 74 08 3B 2D 68 8F 1C 04 74 05 E8 90 BB 02 00
041734D0h:  3B FE 74 75 85 ED 75 63 E8 83 BB 02 00 33 C0 3B
041734E0h:  78 10 72 05 E8 77 BB 02 00 8B 07 8B 08 8B 01 8B
041734F0h:  50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8B 4C 24 24
04173500h:  8B 11 8B F0 8B 42 0C FF D0 8B 10 8B C8 8B 02 FF
04173510h:  D0 56 50 FF D3 85 C0 74 2C 85 ED 75 23 E8 3E BB
04173520h:  02 00 33 C0 3B 78 10 72 05 E8 32 BB 02 00 A1 78
04173530h:  8F 1C 04 83 C7 04 E9 75 FF FF FF 8B 45 00 EB 9F
Stack (0013F8C0h):
0013F8A0h:  EB495000 EB495000 EB494D64 00000000
0013F8B0h:  0013FEAC 7FFDF000 EB494DD8 EB494B48
0013F8C0h:  04415334 0013F934 09EB11C0 00000000
0013F8D0h:  00000000 0013F954 041B33D8 00000000
0013F8E0h:  0417DF9F 00000000 00000000 0000040E
0013F8F0h:  0013FAC8 04415334 0013F94C 7FFDFBF8
0013F900h:  00000000 0013F92C 7C90F0AA 7FFDFC00
0013F910h:  0000000A 0013F938 6606A92C 00000005
0013F920h:  7FFDFBF8 00030700 00000000 7C90D9C1
0013F930h:  7C830C6F 7FFDFC00 09EB0000 7C830C88
0013F940h:  00030700 6606A92C 00000000 00000007
0013F950h:  00030700 0013FABC 041B4DB9 FFFFFFFF
0013F960h:  0417CF82 0013F8E4 00000003 09EB11C0
0013F970h:  09EB11C0 04415334 000106C0 0013F9B0
0013F980h:  00000000 7E41C493 00030700 7E41C465
0013F990h:  7E430002 00000001 0013F988 0013FCC4
0013F9A0h:  0013FCC4 7E440457 7E41C498 FFFFFFFF
0013F9B0h:  7E41C493 6601CA4E 0002062C 0013FCA8
0013F9C0h:  6601BF1F 00000000 0002062C 0000007F
0013F9D0h:  00000001 00000000 00000000 0000029E
Registers:
EAX: 06797268, EBX: 10006293, ECX: 00000000, EDX: 004C9D38
ESI: 09EB6828, EDI: 09EB67B8, EBP: 044143C8, ESP: 0013F8C0
Crash location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Loaded modules:
RPCRT4                          loaded at 77E70000h - 77F01000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
wbsys                            loaded at 66500000h - 6650A000h
guard32                          loaded at 003A0000h - 003C2000h
fltLib                          loaded at 4FFE0000h - 4FFE8000h
winsta                          loaded at 76360000h - 76370000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
wblind                          loaded at 66000000h - 66083000h
UXTHEME                          loaded at 5AD70000h - 5ADA8000h
msimg32                          loaded at 76380000h - 76385000h
wbhelp                          loaded at 66600000h - 66617000h
apphelp                          loaded at 77B40000h - 77B62000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00F50000h - 00F83000h
foo_albumlist                    loaded at 00FB0000h - 01015000h
foo_audioscrobbler              loaded at 01040000h - 01070000h
foo_cdda                        loaded at 01090000h - 010C5000h
foo_converter                    loaded at 010F0000h - 01155000h
foo_cwb_hooks                    loaded at 01180000h - 011B6000h
foo_dirwatch                    loaded at 011E0000h - 0120E000h
foo_dsp_skip_silence            loaded at 01230000h - 01243000h
libmmd                          loaded at 01260000h - 01511000h
foo_dsp_std                      loaded at 01540000h - 01587000h
foo_fileops                      loaded at 015B0000h - 015F7000h
foo_infobox                      loaded at 01620000h - 01660000h
foo_input_monkey                loaded at 01680000h - 016CA000h
foo_input_std                    loaded at 016F0000h - 01815000h
foo_masstag                      loaded at 01840000h - 0188F000h
foo_midi                        loaded at 018B0000h - 0195A000h
foo_playcount_mod                loaded at 01980000h - 01995000h
foo_pqview                      loaded at 019B0000h - 019CC000h
foo_prettypop                    loaded at 019F0000h - 01A3D000h
mscoree                          loaded at 79000000h - 79046000h
mscorwks                        loaded at 79E70000h - 7A3FF000h
mscorlib.ni                      loaded at 790C0000h - 79BF6000h
mscorjit                        loaded at 79060000h - 790B6000h
foo_preview                      loaded at 03ED0000h - 03EF1000h
foo_rgscan                      loaded at 03F90000h - 03FE0000h
foo_scheduler                    loaded at 04000000h - 0406F000h
foo_uie_albumart                loaded at 04090000h - 040CD000h
foo_uie_albumlist                loaded at 04100000h - 04143000h
foo_uie_lyrics                  loaded at 04170000h - 041D4000h
WININET                          loaded at 42C10000h - 42CDF000h
Normaliz                        loaded at 041F0000h - 041F9000h
iertutil                        loaded at 42990000h - 429D5000h
foo_uie_playlists_dropdown      loaded at 04420000h - 04459000h
foo_uie_queuemanager            loaded at 04480000h - 044B9000h
System.ni                        loaded at 7A440000h - 7AC2A000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF7C000h
foo_uie_quicksearch              loaded at 047A0000h - 047E6000h
foo_uie_tabs                    loaded at 04800000h - 0482A000h
foo_uie_trackinfo_mod            loaded at 04850000h - 048A6000h
foo_uie_typefind                loaded at 048C0000h - 048F0000h
foo_ui_columns                  loaded at 04910000h - 04A0D000h
foo_ui_std                      loaded at 04A30000h - 04AE3000h
foo_winamp_spam                  loaded at 04B10000h - 04B40000h
dciman32                        loaded at 73BC0000h - 73BC6000h
ieframe                          loaded at 42EF0000h - 434BD000h
urlmon                          loaded at 42CF0000h - 42E17000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC6C000h
wshbth                          loaded at 751D0000h - 751EE000h
mdnsNSP                          loaded at 099B0000h - 099C9000h
Iphlpapi                        loaded at 76D60000h - 76D79000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
rtutils                          loaded at 76E80000h - 76E8E000h
msv1_0                          loaded at 77C70000h - 77C93000h
USERENV                          loaded at 769C0000h - 76A73000h
sensapi                          loaded at 722B0000h - 722B5000h
MPRAPI                          loaded at 76D40000h - 76D58000h
ACTIVEDS                        loaded at 77CC0000h - 77CF2000h
adsldpc                          loaded at 76E10000h - 76E35000h
ATL                              loaded at 76B20000h - 76B31000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607D000h
ntshrui                          loaded at 76990000h - 769B5000h
shdocvw                          loaded at 77760000h - 778D0000h
LINKINFO                        loaded at 76980000h - 76988000h
fsshext.8.0.0792.00              loaded at 5A500000h - 5A52F000h
MPR                              loaded at 71B20000h - 71B32000h
drprov                          loaded at 75F60000h - 75F67000h
ntlanman                        loaded at 71C10000h - 71C1E000h
NETUI0                          loaded at 71CD0000h - 71CE7000h
NETUI1                          loaded at 71C90000h - 71CD0000h
NETRAP                          loaded at 71C80000h - 71C87000h
davclnt                          loaded at 75F70000h - 75F79000h
wpdshext                        loaded at 0B1E0000h - 0B45E000h
PortableDeviceApi                loaded at 0A880000h - 0A8C9000h
shgina                          loaded at 73D70000h - 73D83000h
MSGINA                          loaded at 75970000h - 75A67000h
ODBC32                          loaded at 74320000h - 7435D000h
odbcint                          loaded at 20000000h - 20017000h
Audiodev                        loaded at 0B660000h - 0B6A6000h
WMVCore                          loaded at 0B6B0000h - 0B90A000h
WMASF                            loaded at 0B520000h - 0B55A000h
xpsp2res                        loaded at 0B910000h - 0BBD5000h
PDFShell                        loaded at 0BC40000h - 0BC8C000h
Address: 041B33D8h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 0417DF9Fh, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 7C90F0AAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAnsiStringToUnicodeString" (+0000005Eh)
Address: 6606A92Ch, location: "wblind", loaded at 66000000h - 66083000h
Address: 7C90D9C1h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwFindAtom" (+0000000Ch)
Address: 7C830C6Fh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GlobalDeleteAtom" (+000000B4h)
Address: 7C830C88h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GlobalDeleteAtom" (+000000CDh)
Address: 041B4DB9h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 0417CF82h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 7E41C493h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+0000002Eh)
Address: 7E41C465h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+00000000h)
Address: 7E430002h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetPropA" (+00000000h)
Address: 7E41C498h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "IsWindowVisible" (+00000033h)
Address: 6601CA4Eh, location: "wblind", loaded at 66000000h - 66083000h
Symbol: "GetWindowsDirectoryA" (+00019B64h)
Address: 6601BF1Fh, location: "wblind", loaded at 66000000h - 66083000h
Symbol: "GetWindowsDirectoryA" (+00019035h)
Address: 004EDCF8h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043AAE2h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 04187960h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 00444ED6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 041B4E52h, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 66603EA3h, location: "wbhelp", loaded at 66600000h - 66617000h
Symbol: "SetAddr" (+00000229h)
Address: 041879ACh, location: "foo_uie_lyrics", loaded at 04170000h - 041D4000h
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E41B4D0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E4191BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetProcessWindowStation" (+00000029h)
Address: 7E4191F1h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetMessageW" (+0000002Bh)
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042C11Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 1000263Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000CAh)
Address: 00FC7814h, location: "foo_albumlist", loaded at 00FB0000h - 01015000h
Address: 0041DAEAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CD0Dh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F50h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F34h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D0F18h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004A08F3h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AF90h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049ED48h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004C8258h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4775h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CF49h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049BFCEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993B1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993ABh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004BAF9Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B9600h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993BFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4B5Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AD3Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049ADAAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 003A0043h, location: "guard32", loaded at 003A0000h - 003C2000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
Special file info box 2.0.4  (foo_infobox)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Columns UI 0.2.1 alpha 9  (foo_ui_columns)
foobar2000 core 0.9.5  (Core)
cwbowron's title format hooks 1.1.1 [May  4 2007 - 12:39:47]  (foo_cwb_hooks)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Winamp API Emulator 0.96  (foo_winamp_spam)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Skip silence 0.1 (Intel SSE)  (foo_dsp_skip_silence)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Preview 1.2  (foo_preview)
Directory watcher 0.2 beta 3  (foo_dirwatch)
MIDI synthesizer host 1.7  (foo_midi)
Typefind 0.2 beta 2  (foo_uie_typefind)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Pretty Popup 1.2.3  (foo_prettypop)
Lyric Show Panels 0.3.2.1 Beta 1 [Jan  2 2008 - 20:43:21]  (foo_uie_lyrics)
Audioscrobbler 2.1  (foo_audioscrobbler)
Play Count Mod 1.0.2  (foo_playcount_mod)
Reply #419
0.3.2.1 Beta 2 has been released.
@MC Escher:
Ooops, I've just returned to home for vocation but I haven't brought the symbol files. So if that problem occurs in beta 2, please let me know, thanks.
Reply #420
I'm afraid beta 2 still crashes:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 041234C0h
Call path:
entry=>app_mainloop
Code bytes (041234C0h):
04123480h:  ED 74 08 3B 2D 10 50 17 04 74 05 E8 60 93 02 00
04123490h:  3B FE 74 75 85 ED 75 63 E8 53 93 02 00 33 C0 3B
041234A0h:  78 10 72 05 E8 47 93 02 00 8B 07 8B 08 8B 01 8B
041234B0h:  50 0C FF D2 8B 10 8B C8 8B 02 FF D0 8B 4C 24 24
041234C0h:  8B 11 8B F0 8B 42 0C FF D0 8B 10 8B C8 8B 02 FF
041234D0h:  D0 56 50 FF D3 85 C0 74 2C 85 ED 75 23 E8 0E 93
041234E0h:  02 00 33 C0 3B 78 10 72 05 E8 02 93 02 00 A1 20
041234F0h:  50 17 04 83 C7 04 E9 75 FF FF FF 8B 45 00 EB 9F
Stack (0013F8C0h):
0013F8A0h:  EC036000 EC036000 EC035D64 00000000
0013F8B0h:  0013FEAC 7FFDE000 EC035DD8 EC035B48
0013F8C0h:  043B577C 0013F934 0B1B30D0 00000000
0013F8D0h:  00000000 0013F954 041609A8 00000000
0013F8E0h:  0412DE4F 00000000 00000000 0000040E
0013F8F0h:  0013FAC8 043B577C 0013F94C 7FFDEBF8
0013F900h:  00000000 0013F92C 7C90F0AA 7FFDEC00
0013F920h:  7FFDEBF8 00160978 00000000 7C90D9C1
0013F930h:  7C830C6F 7FFDEC00 0B1C0000 7C830C88
0013F940h:  00160978 6606A92C 00000000 00000007
0013F950h:  00160978 0013FABC 041622E9 FFFFFFFF
0013F960h:  0412CE2C 0013F8E4 00000003 0B1B30D0
0013F970h:  0B1B30D0 043B577C 0004042A 0013F9B0
0013F980h:  00000000 7E41C493 00160978 7E41C465
0013F9B0h:  7E41C493 6601CA4E 000903E0 0013FCA8
0013F9C0h:  6601BF1F 00000000 77F16E2D 77F16F1A
0013F9D0h:  DC011406 0006040E 049C7064 00000000
Registers:
EAX: 07C0C410, EBX: 10006293, ECX: 00000000, EDX: 004C9D38
ESI: 0BBB41C4, EDI: 0BBB40E8, EBP: 043B4AF8, ESP: 0013F8C0
Crash location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Loaded modules:
foo_dsp_skip_silence            loaded at 011E0000h - 011F3000h
libmmd                          loaded at 01210000h - 014C1000h
foo_dsp_std                      loaded at 014F0000h - 01537000h
foo_fileops                      loaded at 01560000h - 015A7000h
foo_infobox                      loaded at 015D0000h - 01610000h
foo_input_monkey                loaded at 01630000h - 0167A000h
foo_input_std                    loaded at 016A0000h - 017C5000h
foo_masstag                      loaded at 017F0000h - 0183F000h
foo_midi                        loaded at 01860000h - 0190A000h
foo_playcount_mod                loaded at 01930000h - 01945000h
foo_pqview                      loaded at 01960000h - 0197C000h
foo_prettypop                    loaded at 019A0000h - 019ED000h
foo_preview                      loaded at 03E80000h - 03EA1000h
foo_rgscan                      loaded at 03F40000h - 03F90000h
foo_scheduler                    loaded at 03FB0000h - 0401F000h
foo_uie_albumart                loaded at 04040000h - 0407D000h
foo_uie_albumlist                loaded at 040B0000h - 040F3000h
foo_uie_lyrics                  loaded at 04120000h - 04180000h
Normaliz                        loaded at 04190000h - 04199000h
foo_uie_playlists_dropdown      loaded at 043C0000h - 043F9000h
foo_uie_queuemanager            loaded at 04420000h - 04459000h
foo_uie_quicksearch              loaded at 04740000h - 04786000h
foo_uie_tabs                    loaded at 047A0000h - 047CA000h
foo_uie_trackinfo_mod            loaded at 047F0000h - 04846000h
foo_uie_typefind                loaded at 04860000h - 04890000h
foo_ui_columns                  loaded at 048B0000h - 049AD000h
foo_ui_std                      loaded at 049D0000h - 04A83000h
foo_winamp_spam                  loaded at 04AB0000h - 04AE0000h
mdnsNSP                          loaded at 0A850000h - 0A869000h
mlang                            loaded at 75CF0000h - 75D81000h
msdmo                            loaded at 736B0000h - 736B7000h
wmadmod                          loaded at 0A480000h - 0A53C000h
mfplat                          loaded at 0A540000h - 0A577000h
Address: 041609A8h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 0412DE4Fh, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 041622E9h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 0412CE2Ch, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 77F16E2Dh, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+00000223h)
Address: 77F16F1Ah, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteDC" (+000000ABh)
Address: 77F16E81h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteDC" (+00000012h)
Address: 7E41B629h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EndPaint" (+0000000Ch)
Address: 0494CA5Ch, location: "foo_ui_columns", loaded at 048B0000h - 049AD000h
Address: 773EEFB3h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00003113h)
Address: 04137A70h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 04162382h, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 04137ABCh, location: "foo_uie_lyrics", loaded at 04120000h - 04180000h
Address: 7E41F94Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7E41F95Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 00FCE0ECh, location: "foo_albumlist", loaded at 00FB0000h - 01015000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
Additional info:
Lyric Show Panels 0.3.2.1 Beta 2 [Jan 15 2008 - 20:42:40]  (foo_uie_lyrics)
Reply #421
@MC Escher:
It's really strange that it crashes that location(when do update nontimestamped lyric), Could you provide some more info about that? such as:
Do you have emebed lyric to file enabled, or it crashed when playing files with lyric embed?
Did it crash before you start to use 0.3.2.1 Beta 1, and which version you were using before 0.3.2.1 Beta 1?
Reply #422
Yes I save the lyrics to the tags, but only if they're timestamped. Because the crashes are so random, I don't know if the track already has embedded lyrics when it crashes. I do believe the crashes started with beta 1, yes.
Reply #423
@MC Escher:
So I think you'd better uncheck "Replace nontimestamped lyric" in Setting -> Internet for now.
I may fixed it later.
Reply #424
Hey, um, the plugin stops automatically downloading lyrics, even though they are available, and I have the the Download automatically option checked.
Um, I'm not sure what information I could give to help you find out what the problem is, I'm afraid. But does anyone have any idea how to fix this? I have the latest version of the plugin installed. (0.3.2.1 Beta 2.)
