Topic: foo_uie_lyrics3 (Read 900046 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #1625
Guys lets be honest this plugin is dead. I recommend you to start using Mini Lyrics. If you tinker with it a little you'll get amazing results. It's worth mentioning that not only it finds most of the lyrics (even non-english ones) but also they are all timestamped and whole program is compatible with foobar2k! ;) Here is sample of how it looks for me: (floating txt, but u can also make it a box to fit in ur foobar window)
download here: http://www.crintsoft.com/
Thanks for this - I like how it can autosave to ID3Tag
Re: foo_uie_lyrics3
Reply #1626
Does it save for you? I couldn't get it to work.
Re: foo_uie_lyrics3
Reply #1627
See my prefs below
Re: foo_uie_lyrics3
Reply #1628
This software your referring to has the ugliest GUI I've seen in years. It does not play well with foobar at all!
Also it didn't uninstall properly, left lots of remnants. This is not a good alternative in my opinion!
What is the opposite of music?
Re: foo_uie_lyrics3
Reply #1630
Redorb, GUI is rather unusual, but not bad at all. Try Metal skin.
It works very well, finds almost every lyrics, much more better than old Lyrics show panel. I think this is very good alternative solution. Big step ahead, give it second chance.
Re: foo_uie_lyrics3
Reply #1631
Hopefully there should be a new version of foo_uie_lyrics3 on it's way. I have had 3 tests versions from The vern over the last few weeks.
I thought I would point out this package that's been around for a while "Extend Sources For Lyrics3.fb2k-component" which contains 4 timestamp (sync) databases that are working and 1 unsync database (scroll down the web page until you see the package). Note that the "Extend sources" are installed as for any component, e.g. drag & drop on to the components page in file/preferences. The new sources should then appear as available sources within foo_uie_lyrics3 preferences/lyric searching.
Also lower down on the same web page is Custom Lyric Source 0.1 с that contains a working version of AZlyrics. Extract the zip and then install the Custom Lyric Source.fb2k-component as above. There is also a working version of Lyrics from metal-archives.com 0.2 с on the page (metal-archives seems to work only by artist searching).
Darklyrics within foo_uie_lyrics3 also continues to work.
Until the anticipated new version, these 8 functioning databases mean foo_uie_lyrics3 continues to work well, and of course these databases will also work in a new version.
Re: foo_uie_lyrics3
Reply #1632
Thanks for the update. Indeed good news! If my memory serves me correctly, The vern has been busy getting an academic degree!? Hopefully he got it.
And thanks for the link to the Russian forum.
Users downloading "Custom Lyric Source 0.1" should note (as stated on the web page) that get_lyric.exe must be copied to fb2k's root folder (in addition to installation of the plugin itself).
get_lyric.exe is a compiled Python command line utility. Executing this from a command prompt
get_lyric.exe --list
will show the seven site names that is supported in this version. (get_lyric.exe --help prints an argument list.)
A test has so far only resulted in unsynced lyrics.
Re: foo_uie_lyrics3
Reply #1633
At my first attemp I got Chinese lyrics and related only to the title but not to the artist I could see in the lyric search window: what am I doing wrong?
Re: foo_uie_lyrics3
Reply #1634
Thank you for the heads up.
Re: foo_uie_lyrics3
Reply #1635
You do nothing wrong. Lyric search world not as precise as you thought, so you may got the totally wrong lyric.
You got Chinese lyric only because you added some Chinese lyric detabase to lyric-show3 whitch provided by "Extend Sources For Lyrics3.fb2k-component".
A rose will bloom, it then will fade.
Re: foo_uie_lyrics3
Reply #1636
This sounds promising! Will keep my sharp eyes open for this development!
MiniLyrics is not an option as far as I'm concerned!
Poorly written code and an ugly GUI! Not recommended for serious users!
Re: foo_uie_lyrics3
Reply #1637
First, Thanks to WilB the others for this helpful advice.  :)
Based on this I was able to configure a working configuraton for my foobar-lyrics.  8)
Nevertheless, I'm also looking forward to a new version of foo_uie_lyrics3, where everythings works smoothly again.
Maybe it should be mentioned that for foo_lyricsource there is another website available: https://github.com/tripod31/foo_lyricsource .
I also tried the old Lyrics Grabber ( https://code.google.com/archive/p/lyricsgrabber2 ).
It works fine with the currently foo_uie_lyrics3 and is an another workaround until foo_uie_lyrics3 is "healed" again.
Re: foo_uie_lyrics3
Reply #1638
What I'd like to add:
The components pointed to by WilB all come with a cyrillic/russian UI (or something like that).
Does anyone know how to switch this to english?
Re: foo_uie_lyrics3
Reply #1639
The original one is in Chinese. I think a Russian version is more friendly...
Re: foo_uie_lyrics3
Reply #1640
Chrome decided to translate the Russian for me, here is the database list -
Russified component Extend Sources For Lyrics3 (DB Lyrics to 3)
File Name foo_lyrics3exsrc.dll
This component adds to the Online Databases 3 Lyrics:
DB Online: xiami.com (China)
DB Online: ttlrcct.qianqian.com (China)
DB Online: music.qq.com (China)
DB Online: music.douban.com (China)
DB Online: box.zhangmen.baidu.com (China)
DB Online: azlyrics.com
Not much of a help as they are (except for azlyrics) all in Chinese.
I'll just wait impatiently for the vern.
Re: foo_uie_lyrics3
Reply #1641
This one is giving me a lot of false positives, just a heads up! Seems like it will always return a result, even if it's complete nonsense. Not sure if there's a way to fix that easily or not?
Re: foo_uie_lyrics3
Reply #1642
That plugin still doesn't have possibility to disable? When i have bad internet and sometimes need to stop lyric searching is there a way except of deleting from list of component?
Re: foo_uie_lyrics3
Reply #1643
Baidu is known adware/spyware company. I wouldn't want a plugin on my system communicating with them
Re: foo_uie_lyrics3
Reply #1644
Everybody hates Baidu.
Re: foo_uie_lyrics3
Reply #1646
I cannot get Minilyrics to work.  Keeps giving me an Error 17.  And I don't see any options in the preferences to write to Vorbis Comments, just to ID3 tags.  I'll wait for the update.
Re: foo_uie_lyrics3
Reply #1647
The Error 17 is happening because the minilyrics.com DNS is not working.  So the only way I was able to get the lyric download to work was to add the following to my Hosts file (for windows users):
74.208.224.110 minilyrics.com
74.208.224.110 www.minilyrics.com
The host file is usually located at: C:\Windows\System32\drivers\etc\hosts (you need admin privileges).  You may need to reboot after editing the file.
Re: foo_uie_lyrics3
Reply #1648
Any news on the updated version?
Re: foo_uie_lyrics3
Reply #1649
Hello,
The custom source I've made one year ago for ML is still working. I just had to patch lyrics loading in a rush because of DNS who breaks about a month ago.
So if The Vern has no plan time to release an updated version in the following days, I can publish it if someone is interested. But you will have to be lenient because I am not very skilled at C++ so it must inevitably contain some memory leaks, or even worse.
