Topic: Menu layout changes in v1.0 (Read 73568 times) previous topic - next topic
Seriously, it doesnt matter.
Wrong, it does... Don't know bout you, but I don't like context menu barely fitting on my 24" display...
File operations category is for foo_fileops commands only.
And Tagging is only for foo_freedb? oh, wait... there is a foo_masstagger too, what we shall do?! (cynicism intended...)
"Open containing folder" is available even without File Operations, and is on its place to mimic Windows' "Open file location" in shell context menu.
What to do?
How about understanding that you have already clearly stated your point.
You are on the side of having the context menu be more flexible.
Maybe a few more examples from you are in order
terry
1. Wait for legacy components to be updated.
2. Start figuring out what can be hidden, given your usage patterns.
At first the new context menu might seem bewildering and/or limiting, but after a few months of use you definitely don't want to go back.
The old menu was a support burden and a major annoyance for new users.
Good riddance!
elevatorladylevitateme
I've never customized the context menu much -- except, I think, move the Properties to the bottom, for consistency with almost every other application. But that's a long time ago, and I might be mistaken.
I've alredy done *2*, just the two quirks I've mention left for the menu to be more-or-less like my old one
As for the *1* -- not counting on this happening soon, given that with time they tend to rather be dropped that updated...
Re-organization of a menu breaks no-one's needs. If a context menu is not fast enough, nothing's stopping you from mapping it to a hotkey or a toolbar button (current bugs excepted).
Yes, we get it, you're all butt-hurt about how the new context menu changes break your customization. It's not changing. Get used to it. If you want to contribute meaningfully, give ways in which the default layout can be improved, but please don't be surprised when we shoot them down. It's nothing personal. Things are how they are for reasons, not to irritate the customizers among us.
Reply #32
I like the new context (and main!) menu, esp. shift-click for "hidden" options. Would it be possible to add another way for showing those hidden menu items - ie. without having to use keyboard. Eg. they could appear after holding right (or left for main menu) mouse button for certain amount of time (say 0.5sec) instead of "clicking". Or there could be "Show more options" item at the bottom (or small button in the corner of the context menu).
Will those suggestions for "mouse-only" people be taken into consideration?
IIRC, I believe that shift-click was chosen because that combo modifies menus in Windows (especially 7).
Reply #34
http://www.infoplease.com/dictionary/brewers/high-words.html
OK, I understand that. Nevertheless, I think there is no reason not to extend existing Windows "standard". I still hope that your answer does not mean definitive 'no' to my suggestion.
And I believe this small enhancement would not complicate the application very much, and even better - it would increase its simplicity (© Canar) (you know, using only one device - mouse, instead of two - mouse + keyboard ) It's all these small details that we love foobar2000 for, isn't it?
Reply #35
@Developers
I'm sure foobar is better internally for all your hard word - for this I thank-you.
However why have you decided to reduce the customisation of the context menu. I want the ability to group commands and simplay move command up\down. This really is a backward step.
Reply #36
and there goes my sorted by usage frequency context menu.
No, seriously, 1.0 is a solid improvement. But putting properties and replaygain - the most frequently used items - to the bottom... It is disappointing.
Reply #37
> properties [...] to the bottom
Note on interfaces: The first and last item of a context menu are the fastest items, because the user does not have to read the item to identify them. Reading is a slow operation for the brain. (tangent: it's the same reason why icons are good and why I still hate that Firefox has no icons in its context menu, despite the large set of too-similar items in the middle)
What, exactly is the current context menu layout? I don't wish to install just yet; I tend to wait for stable releases, and the Screenshots page on fb2k.org hasn't been updated yet (assumedly because of V1's beta stage).
By the way, is there an immediate indication for the state of stop-after-current yet? Just about my only FB pet peeve.
Reply #38
With shift:
Reply #39
Good riddance!
It was also a annoaynce for old users (like me): I was used f.e. to restructure the commands of foo_utils into new and renamed groups and for each command i had to open again and again  the pop-up window with the list of commands. I can remember when 0.9 was released i was horrified but it didn't took much time to get used and to be eased to see that new fixed main menu was nicer than my custom one in 0.8
Ok, here a suggestion for improvement!
One improvement of the new context menu not mentioned so far: you can't change anymore the path of a command (means: placing one command from origin group into another custom group). That caused the irritating inconsistency that in some parts of the program (f.e. hotkey editor) the origin path was continued to be displayed. That can't happen anymore.
That is a solid base to repeat an old request i made 1-2 years ago:
The more buttons you have the more context menu items you can hide to keep overview in contextmenu. In that context wouldn't it be useful to add groups as button (you even wouldn't have to change button dialogue)? I mean following: i select in the the tree the group "Quick Tagger" and am able to add this as button - clicking this button then opens the submenu.
Reply #41
I honestly didn't know it was a support burden, and i don't understand why also ... i also know that if i HAVE to, i would probably get used to not being able to reorder, but i also believe it is a STEP BACKWARD, and i would surely miss my customize menu:
Reply #42
@kwanbis
Your screenshot shows strange things: Commands that should be displayed in the "tagging" or "utils" menu are shown in root of context menu. That doesn't happen for me. Try removing foo_menu_addons to see if it helps.
Good advice! There are commands we use never, in rare cases or often. So here one constructive idea more: a third state for the menu items - show hidden, show always and show never. So you would rather hide some items that you otherwise would show always and you can keep context menu with hidden items also cleaner.
Reply #43
All you have to do is follow the link I already provided labeled "support burden", and click on and read some of those  threads.
Feigning ignorance isn't a great way to help yourself.
That really causes one of the same problems as the old menu: People who need something that they've removed (old) or "hidden always" have to go into the preferences to add it back.
Also, user might need that thing that they've hidden always sometime in the future and come to the forums making a "feature request' to do something that is already possible. (great example)
Reply #44
I am not sure, if you understood me correctly. With "show never" i don't mean to remove the item from the tree but to have a special symbol in the checkbox.
Example: not checked means show never, checked means show always and (after clicking a checked checkbox) the special symbol  means show hidden.
"Ok, I understand now."
Reply #45
Would it be possible (or, more accurately, does it have a prayer of actually happening) to at least add some kind of indicator to the 'legacy commands' menu operator of what component those commands belong to?
Reply #46
I must admit that I'm slowly getting used to the new context menu, but I want to support mixcherry's proposal about using the hidden entries without having to use keyboard.
Reply #47
Ok, i tested the new beta with all my components - and what a suprise: It is not the mess i expected.
However, here two minor suggestions to improve the out-of-the-box layout:
  • 1. The "tagging" submenu is the only one that appears messy. It would make sense to seperate this submenu into two subgroups diveded by a seperator: one for tagging operations and one for commands/groups that retrieves data from the internet
  • 2. All third party components which add their menus to the root have own subgroup: it is just one seperator that makes overview a little bit friendlier
Reply #48
+1
I'd prefere that plugins add their menu entries into more logical categories their funcionality fits (i.e. discogs fits perfectly into tagging)
Reply #49
Components are free to do either, just as before.
