Fancy surge protectors and power conditioners.. Gimmicks?
Reply #66 – 2006-12-17 15:37:24
I recently had a direct lighting strike hit a tree 40 feet from my couch. I was home at the time, and on the phone (bad idea). I had several pieces of expensive audio/video/networking equipment get fried. ALL of it was plugged into APC power strips, and some were plugged into an APC UPS unit. In some equipment, the surge blew out the power supply section. In most, it entered via the CAT5 networking interface, and fried the network ports. I had many long runs of unshielded CAT5 cable, which apparently, absorbed a lot of energy, a delivered it very efficiently to my Slimserver Squeezebox (which they repaired at no cost), my Netgear wireless router, a Netgear switch, and more than one PCI network card. The moral of the story is that power conditioning alone will not protect your equipment. At least, not in the typical home. No, that's not the moral of the story at all. You are generalizing from your unique experience of a direct lightning strike. If you want to generalize, you could say that home-use power strips and UPS units are not sufficient protection against a direct lightning strike - something no honest manufacturer will tout them to be, anyway. Direct being 40 feet OUTSIDE the house, and the fact that it was the ethernet ports that blew out. Not all that uncommon. My experience is not unique. Lighting damage can also occur via the phone line/modem entry path, and often does. As internal modems become more rare, so does that particular problem. This is not an argument or debate. It happens. I think it's important to realize that the powerline is not the only thing that needs to be protected if you are that serious about it. Edit: Now, if this thread is not to include any discussion of protecting against lighting damage, then my post is offtopic, and I apologize.
