Topic: foo_uie_lyrics3 (Read 895810 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #2025
Just found this and want to give it a try  , but using the following link
download v0.42: https://drive.google.com/file/d/1ayOA4Mi8S24bgOOmmcvh4AUWzDvK9pEd/view?usp=sharing , triggers an error in Malwarebytes, appreciate your assistance  Veksha, Thanks
File: 1
Malware.Heuristic.1008, C:\USERS\KEN_A\DOWNLOADS\FOO_MULTISOURCE.FB2K-COMPONENT, No Action By User, 1000001, 0, 1.0.42137, 0000000000000000000003F0, dds, 01302552, 4665375F483206D874BD4FB59A31B94C, 7C64CEA3404CAFAC0A2749F027FC0ACA41CF8925CEC97627C6CD7E5545C78A6B
Re: foo_uie_lyrics3
Reply #2026
File: 1
you are lucky. because this is not an error, it's a warning. :-) Heuristic analysis of an antivirus is known for false positives.
you can check any file on www.virustotal.com and see the score for yourself. right know i'm getting 0/61.
i'm actually surprised, because not so long ago the score was 1/61. (only malwarebytes detected my file as potentially malicious)
Re: foo_uie_lyrics3
Reply #2027
[/quote]
File: 1
Thanks  for prompt response, checked on virustotal.com and will be trying this out later , Thanks Veksha
Re: foo_uie_lyrics3
Reply #2028
@veksha : any luck at getting your plugin to work with Genius.com again?  Or have they messed things up completely?
Re: foo_uie_lyrics3
Reply #2029
@sveakul I have released a new version of foo_multisource 0.43. please try now. I think i fixed genius problem.
Spoiler (click to show/hide)
Re: foo_uie_lyrics3
Reply #2030
Thanks veksha!  The good news is it's finding lyrics constantly, but in the body of the lyrics there are "class="Lyrics__Container-sc-1ynbvzw-7 jjqBBp">" statements at the beginning and again towards the end of the text.
Attached are 3 examples.  I do have the "Insert URL into lyrics body" option active.
Re: foo_uie_lyrics3
Reply #2031
please try v0.44. thank you.
Re: foo_uie_lyrics3
Reply #2032
veksha:  just gave .44 a spin and all is working fine!  Genius is pulling them and there are no more "class=" lines in the text body.  Thank you, sir!  "Nothing can stop him"  :)
Re: foo_uie_lyrics3
Reply #2033
@veksha:  trying .45 version of MultiDB with Deezer, getting no results from Deezer even when website has them (other sources work fine).  Could your default sid have already expired?
Edit:  testing with the the 3-dll version not the 5-dll one.
Re: foo_uie_lyrics3
Reply #2034
Hi, @sveakul !
try to go to deezer.com in your browser (logged in with your own sid tied to your account) and then retry search in foobar2k. results may appear.
i must investigate more to deal with this issue.
(ps: log in with your own account tied to your sid in multisource settings)
Re: foo_uie_lyrics3
Reply #2035
@veksha:  it's working now, I think because I did a second restart of Foobar this time after adding Deezer to the search panel, instead of just after updating the plugin.  Also, I did browse to Deezer beforehand, although I do not have my own free account there (yet).  Bottom line is, MultiDB Deezer is drawing lyrics now, thanks!!
Re: foo_uie_lyrics3
Reply #2036
It will work for some period of time. then i will have to browser deezer.com again to awake it again. :) the issue remains.
Re: foo_uie_lyrics3
Reply #2037
hi, @sveakul
foo_multisource 0.47 now has experimental support for musixmatch translations. you can put "italian" (or whatever) in the corresponding field in settings and then search for Musixmatch unsynced lyric. let me know if it works or not. :)
Re: foo_uie_lyrics3
Reply #2038
veksha:  have been trying .47 with Musixmatch set to "german", and it has yet to return any results.  Perhaps the kind of music I listen to just doesn't have a large body of translations yet at that site.
Re: foo_uie_lyrics3
Reply #2039
I cannot for the life of me get this component to work. I feel like I'm doing something obviously dumb. I get nothing found for every single song, big and small artists.
Re: foo_uie_lyrics3
Reply #2040
that is why i made foo_multisource plugin for Lyric Source Panel 3
download:
Spoiler (click to show/hide)just download v0.47 and then add only MultiDB sources (except for minilyrics)
Re: foo_uie_lyrics3
Reply #2041
download:
OMG thank you, it works like a charm now :D
Re: foo_uie_lyrics3
Reply #2042
@veksha:  re the .48 MultiDB plugin with improved support for Lololyrics.  I think the main problem with people not getting hits from Lololyrics is that they simply have an extremely sparse database.  I've been doing searches on their website, and you can see a dozen tracks from an obscure artist like "C-Netnik", and yet there is only ONE track for Jefferson Airplane, ZERO for Rush, Lacuna Coil, etc.  Like 10% hit, 90% miss.  I'm a bit embarassed because I originally asked for Lololyrics to be added.  Now I've got it last on my active list.  Anyway, people with tracks from "Abyss & Judge" will find lots of hits here, others, "your mileage may vary."
Re: foo_uie_lyrics3
Reply #2043
the more sources the better. it's an opportunity for me at least to learn new programming language (Nim)  :P
the Lololyrics problem was concerning umlaut handling by my bad code in PureBasic, so in the future all of the lyric-sources will be rewritten in Nim. that way the code will be more elegant and easy for debugging for me. (deezer, musixmatch and lololyrics are already inside Nim's .dll)
Re: foo_uie_lyrics3
Reply #2044
I certainly agree!  As long as you mention it  ;) ... is there any chance of adding metal-archives.com to MultiDB?  While the foo_lrc_metalarchives plugin still does a great job there, it would be nice to see MultiDB end up as the "this is all you need" lyrics plugin for Foobar.
Re: foo_uie_lyrics3
Reply #2045
added metallum support in v0.49. please test :)
Re: foo_uie_lyrics3
Reply #2046
Hi veksha:  been testing .49 and it's just amazing--your added metallum/metal-archives is drawing lyrics just as fast as the old dedicated plugin.  IMPRESSIVE, man!  I also found songs that allowed me to cycle through the entire roster of MultiDB (minus MiniLyrics of course), and confirm that all the other sources still work fine as well and respond properly to the "Next lyrics" prompt.  This is the best version of your work yet.  THANK YOU!
Edit:  For the sake of completeness wanted to mention I did notice that metallum does not respond to the option to "Insert URL into lyric body".  Definitely no big deal, and certainly not worth a re-write.
Re: foo_uie_lyrics3
Reply #2047
it can be slower because I'm discarding strange results with only one line inside "(lyrics not available)". lyrics like this still take one http-request. if lyric has only one line then i'm just trying to read the next one. up to 10. but dedicated plugin returns all results, even strange empty ones. with my approach i'm trying to return only one best result. (full-length releases have higher priority)
thank you for pointing this out. metallum and lolo did not respond to that option. now it is fixed and uploaded, version is still .49.
Re: foo_uie_lyrics3
Reply #2048
Great work with your component, @veksha Now, I think that the only thing that it's missing (at least from my point of view) is to add NeateaseCloudMusic as lyric source.
I use this script https://github.com/elia-is-me/foobar-jscripts/blob/master/ESLyric/netease.js  for EsLyric panel to retrieve lyrics from NeateaseCloudMusic . Is it possible to add NeateaseCloudMusic? It would be great to have all lyrics sources in one component.
Re: foo_uie_lyrics3
Reply #2049
@Koshingg , please try 0.50
I've added NetEase as new lyric source.
PS: thank you for suggesting it!
