Hey Alex,
I found out that you might download the HighRes Images from Qobuz with the extension "_max.jpg". Your Script so far only supports 600px Images
Perhaps you'll like to update the Qobuz Script.
Yours Thomian
I udated the Qobuz script by my own, based on Alex iTunes script.
It works pretty fine for me.
I have no idea how to upload the qobuz.boo file directly to this forum, so here comes the code, for those of you who like High Resolution Images from Qobuz.
Alex you can use this code for an official update of the Qobuz script.
import System
import System.Text.RegularExpressions
import AlbumArtDownloader.Scripts
import util
class Qobuz(AlbumArtDownloader.Scripts.IScript):
Name as string:
get: return "Qobuz"
Version as string:
get: return "0.11"
Author as string:
get: return "Alex Vallat, thomian"
def Search(artist as string, album as string, results as IScriptResults):
artist = StripCharacters("&.'\";:?!", artist)
album = StripCharacters("&.'\";:?!", album)
//Retrieve the search results page
searchResultsHtml as string = GetPage("http://www.qobuz.com/recherche?i=boutique&q=" + EncodeUrl(artist + " " + album))
matches = Regex("<a href=\"(?<url>[^\"]+)\"[^>]+>\\s+<img alt=\"(?<title>[^\"]+)\"[^>]*rel=\"(?<id>(?<idPrefix>[^\"]{4})[^\"]*(?<idPrefix2>[^\"]{2})(?<idPrefix1>[^\"]{2}))\"", RegexOptions.Singleline | RegexOptions.IgnoreCase).Matches(searchResultsHtml)
results.EstimatedCount = matches.Count
for match as Match in matches:
infoUrl = match.Groups["url"].Value
title = match.Groups["title"].Value
id = match.Groups["id"].Value
idPrefix = match.Groups["idPrefix"].Value
idPrefix1 = match.Groups["idPrefix1"].Value
idPrefix2 = match.Groups["idPrefix2"].Value
urlBase = "http://static.qobuz.com/images/covers/${idPrefix1}/${idPrefix2}/${id}"
// in previous script versions the image was reached using URL-Base:
// urlBase = "http://static.qobuz.com/images/jaquettes/${idPrefix}/${id}"
// this link still works, but not for max size images, only for 600px images
// See if max size jpg is available
if CheckResponse(urlBase + "_max.jpg"):
fullSizeImageUrl = urlBase + "_max.jpg"
else:
// fall back on 600x600
fullSizeImageUrl = urlBase + "_600.jpg"
results.Add(urlBase + "_100.jpg", title, "http://www.qobuz.com" + infoUrl, -1, -1, fullSizeImageUrl, CoverType.Front)
def CheckResponse(url):
checkRequest as System.Net.HttpWebRequest = System.Net.HttpWebRequest.Create(url)
checkRequest.Method = "HEAD"
checkRequest.AllowAutoRedirect = false
try:
response = checkRequest.GetResponse() as System.Net.HttpWebResponse
return response.StatusCode == System.Net.HttpStatusCode.OK
except e as System.Net.WebException:
return false;
ensure:
if response != null:
response.Close()
def RetrieveFullSizeImage(fullSizeCallbackParameter):
return fullSizeCallbackParameter
