Thanks bubble. I still have a problem that I really can't put my finger upon. In the past I used foobar/foo_dockable_panels/foo_bubble_coverflow without any problems. But at some point something changed. Anyway whenever I open a panel with foo_dockable_panels everything is still fine. Then I right click the panel to add the coverflow panel in there. But instead the panel opens as a separate window now. And the window doesn't even display any covers. All covers are black. Then I kill the window and then the panel and boom foobar crashes with an error message as the following.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00FE42B3h
Access violation, operation: read, address: 00000050h
Call path:
entry=>app_mainloop
Code bytes (00FE42B3h):
00FE4273h: 00 E9 6F 04 00 00 8B 5B 1C 3B DE 0F 84 64 04 00
00FE4283h: 00 53 FF 15 D8 C1 FF 00 E9 58 04 00 00 8B 45 14
00FE4293h: 89 70 18 89 70 1C E9 4A 04 00 00 8B CB E8 5B E8
00FE42A3h: FF FF E9 3E 04 00 00 8B 4B 24 3B CE 74 07 8B 01
00FE42B3h: 8B 50 50 FF D2 8B 43 20 3B C6 89 73 1C 74 0A 50
00FE42C3h: FF 15 44 C1 FF 00 89 73 20 8B 03 8B 50 04 8B CB
00FE42D3h: 89 5C 24 20 FF D2 8D 44 24 20 50 C7 44 24 74 01
00FE42E3h: 00 00 00 E8 A5 30 00 00 C7 44 24 70 FF FF FF FF
Stack (0013F504h):
0013F4E4h: BC6F10A0 E3FCD620 BF83F323 BC7491B8
0013F4F4h: 00000400 00000020 E6C5A8C0 E6334868
0013F504h: 37721EAF 0013F5E4 00FE4000 00000000
0013F514h: 7C91EAE3 0013F520 00000018 0081AC88
0013F524h: 01034120 00000001 C000000F 101095E0
0013F534h: 7E3A6360 7E3694BE 7E392135 00EC081A
0013F544h: 00000281 00000001 C000000F 00000000
0013F554h: 000002AB 00000000 00000000 0013F5B8
0013F564h: 00000002 0013F5A0 0013F604 00FFB3D8
0013F574h: FFFFFFFF 00000000 0013F5A8 7E368734
0013F584h: 00DD0B10 00000010 00000000 00000000
0013F594h: 00FE4000 DCBAABCD 00000000 0013F5E4
0013F5A4h: 00FE4000 0013F614 7E373745 00FE4000
0013F5B4h: 00DD0B10 00000010 00000000 00000000
0013F5C4h: 00000010 00DD0B10 007F91B8 00000014
0013F5D4h: 00000001 00000000 00000000 00000010
0013F5E4h: 00000000 0013F760 00000000 00000001
0013F5F4h: 00000000 00000000 0013F5C4 0013F128
0013F604h: 0013F6FC 7E390457 7E373768 00000000
0013F614h: 0013F65C 7E373591 00000000 00FE4000
Registers:
EAX: 00000000, EBX: 01034120, ECX: 00D56E00, EDX: 00000002
ESI: 00000000, EDI: 00DD0B10, EBP: 0013F57C, ESP: 0013F504
Crash location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Loaded modules:
foobar2000 loaded at 00400000h - 00523000h
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C907000h
COMCTL32 loaded at 773A0000h - 774A3000h
msvcrt loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4A000h
RPCRT4 loaded at 77E50000h - 77EE2000h
Secur32 loaded at 77FC0000h - 77FD1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32 loaded at 7E360000h - 7E3F0000h
SHLWAPI loaded at 77F40000h - 77FB6000h
SHELL32 loaded at 7E670000h - 7EE90000h
ole32 loaded at 774B0000h - 775ED000h
shared loaded at 10000000h - 1002A000h
COMDLG32 loaded at 76350000h - 7639A000h
IMM32 loaded at 76330000h - 7634D000h
guard32 loaded at 00380000h - 003A2000h
fltLib loaded at 5E160000h - 5E168000h
winsta loaded at 76300000h - 76310000h
NETAPI32 loaded at 597D0000h - 59824000h
uxtheme loaded at 5B0F0000h - 5B128000h
MSCTF loaded at 746A0000h - 746EB000h
GameHook loaded at 10D00000h - 10D0F000h
lgscroll loaded at 10100000h - 10111000h
MSVCR80 loaded at 78130000h - 781CB000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
NTMARTA loaded at 77660000h - 77681000h
WLDAP32 loaded at 76F20000h - 76F4D000h
SAMLIB loaded at 71B70000h - 71B83000h
apphelp loaded at 77B10000h - 77B32000h
msctfime loaded at 75250000h - 7527E000h
foo_abx loaded at 00B10000h - 00B43000h
foo_albumlist loaded at 00B70000h - 00BD7000h
foo_audioscrobbler loaded at 00C00000h - 00C31000h
WS2_32 loaded at 71A10000h - 71A27000h
WS2HELP loaded at 71A00000h - 71A08000h
foo_bubble_coverflow loaded at 00CA0000h - 00D26000h
OPENGL32 loaded at 5F0D0000h - 5F19C000h
GLU32 loaded at 68FC0000h - 68FE0000h
DDRAW loaded at 736D0000h - 73719000h
DCIMAN32 loaded at 73B30000h - 73B36000h
gdiplus loaded at 4EBA0000h - 4ED43000h
foo_cdda loaded at 00D60000h - 00D95000h
foo_channel_mixer loaded at 00DC0000h - 00DFA000h
foo_converter loaded at 00E10000h - 00E79000h
foo_discogs loaded at 00EA0000h - 00F41000h
WINMM loaded at 76AF0000h - 76B1E000h
foo_dockable_panels loaded at 00FE0000h - 01013000h
foo_dsp_dolbyhp loaded at 01040000h - 01061000h
VERSION loaded at 77BD0000h - 77BD8000h
foo_dsp_std loaded at 01080000h - 010C8000h
foo_dsp_vst loaded at 010F0000h - 01112000h
foo_facets loaded at 01140000h - 011C1000h
OLEAUT32 loaded at 770F0000h - 7717B000h
MSIMG32 loaded at 76320000h - 76325000h
foo_fileops loaded at 011F0000h - 01236000h
foo_freedb2 loaded at 01260000h - 012A1000h
foo_input_monkey loaded at 012D0000h - 0131A000h
foo_input_std loaded at 01340000h - 01468000h
foo_masstag loaded at 01490000h - 014E0000h
foo_out_ks loaded at 01500000h - 0152A000h
SETUPAPI loaded at 778F0000h - 779E4000h
foo_rgscan loaded at 01550000h - 015AA000h
foo_uie_lyrics loaded at 015D0000h - 0162F000h
WININET loaded at 441E0000h - 442AF000h
Normaliz loaded at 01640000h - 01649000h
iertutil loaded at 43F60000h - 43FA5000h
foo_ui_columns loaded at 01870000h - 0196E000h
foo_ui_std loaded at 01990000h - 01A51000h
foo_unpack loaded at 01A80000h - 01AAD000h
VI loaded at 02270000h - 02464000h
WINSPOOL loaded at 72F70000h - 72F96000h
CLBCATQ loaded at 76F90000h - 7700F000h
COMRes loaded at 77010000h - 770E3000h
ieframe loaded at 444C0000h - 44A8D000h
PSAPI loaded at 76BB0000h - 76BBB000h
MpShHook loaded at 5F800000h - 5F816000h
rsaenh loaded at 0FFD0000h - 0FFF8000h
urlmon loaded at 442C0000h - 443E7000h
dolbyhph loaded at 02BC0000h - 02CBC000h
nvoglnt loaded at 69500000h - 69BAA000h
imagehlp loaded at 76C50000h - 76C78000h
DBGHELP loaded at 59DD0000h - 59E71000h
Stack dump analysis:
Address: 00FE4000h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 101095E0h, location: "lgscroll", loaded at 10100000h - 10111000h
Symbol: "UninstallScrollHooks" (+00000DC0h)
Address: 7E3A6360h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetRawInputDeviceInfoW" (+00000068h)
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E392135h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+00001EADh)
Address: 00EC081Ah, location: "foo_discogs", loaded at 00EA0000h - 00F41000h
Address: 00FFB3D8h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 00DD0B10h, location: "foo_channel_mixer", loaded at 00DC0000h - 00DFA000h
Address: 7E373745h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E37379Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E3737BCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36B42Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00FE4038h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7E36BAA4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsWindow" (+00000171h)
Address: 7E36B96Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsWindow" (+00000038h)
Address: 7E36B3F9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 5B0F3C20h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "DrawThemeText" (+00000BEFh)
Address: 5B10E300h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+000004B0h)
Address: 5B0F1AC7h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Address: 7E36B3D2h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 5B0F1B3Dh, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Address: 5B10E2D5h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+00000485h)
Address: 7E36BB15h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetPropW" (+0000003Ah)
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 7E36C331h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 7E37366Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 5B0F2586h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeAppProperties" (+0000036Bh)
Address: 5B0F4301h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeBackgroundContentRect" (+00000362h)
Address: 77EF5A0Eh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GdiReleaseDC" (+00000018h)
Address: 7E36D4E4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetPropW" (+000000BBh)
Address: 7E36B903h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SendMessageW" (+00000049h)
Address: 5B11881Fh, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+0000A9CFh)
Address: 5B118777h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+0000A927h)
Address: 7E3684FCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3685A4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3689CDh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E36DAEAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 7E37D950h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 7E3689F0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E368A10h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042C283h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 10002638h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 0042CE06h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004C629Ch, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004C6280h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 012107EAh, location: "foo_fileops", loaded at 011F0000h - 01236000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D4B70h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 004A33D3h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049DA60h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004A1828h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CB9A4h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B7398h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042D04Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049EA9Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE81h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE7Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BE560h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BC3F0h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE8Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B77C7h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049D80Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049D87Ah, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 003A0043h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00380078h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00390035h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 00523000h
Version info:
foobar2000 v0.9.5.1
UNICODE
Windows 5.1
Additional info:
File Operations 2.1 (foo_fileops)
ReplayGain Scanner 2.0.3 (foo_rgscan)
Lyric Show Panels 0.3.2.2 [Feb 14 2008 - 13:57:22] (foo_uie_lyrics)
Discogs Tagger 1.12 (foo_discogs)
Standard Input Array 1.0 (foo_input_std)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48] (foo_dockable_panels)
Facets 2008-02-25 (foo_facets)
Converter 1.1 (foo_converter)
foobar2000 core 0.9.5.1 (Core)
Standard DSP Array 1.0 (foo_dsp_std)
Default User Interface 0.9.5 (foo_ui_std)
freedb Tagger 0.5.2.1 (foo_freedb2)
ABX Comparator 1.3.1 (foo_abx)
Cover Flow 0.16 (foo_bubble_coverflow)
Masstagger 1.6 (foo_masstag)
Columns UI 0.2.1 alpha 10 v4 (foo_ui_columns)
RAR reader 1.1 (foo_unpack)
Audioscrobbler 2.3.1 (foo_audioscrobbler)
CD Audio Decoder 2.1.2 (foo_cdda)
Channel Mixer 0.9.6.3 (foo_channel_mixer)
ZIP/GZIP reader 1.0 (foo_unpack)
Monkey's Audio decoder 2.1.2 (foo_input_monkey)
VST bridge 0.60 Beta (foo_dsp_vst)
Album List 4.2 (foo_albumlist)
Kernel Streaming Output 1.2.2 (foo_out_ks)
Dolby Headphone Wrapper 1.1.1 (foo_dsp_dolbyhp)
Now I'm not sure if this problem is because of an incompatibility between foo_dockable_panels and foo_bubble_coverflow or because of the latest foobar version or even driver related. I just thought I'd mention it. Maybe you have a clue what it could be about.
