Topic: foo_bubble_coverflow (Read 422112 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #300
@ kanak
Have you tried the two functions bubbleguuum mentioned in his first post:
CTRL + mousewheel: move backward / forward the camera
SHFT + mousewheel: increase/descrese the field of view (fov).
i also tried to fill the entire screen with art and it works with 20 to 30 covers and still runs smooth.
sometimes it is the best, not to say anything
Reply #301
@Proxific
thanks for hint. I didn't know there was a camera switching option. however, i'm on a laptop and do NOT have a mechanism to scroll so i can't use it. . Maybe if we could use some keyboard combination like Ctrl + or something it'd be great.
Reply #302
Thank you so much for current release!!
Problem detected (possible bug):
1. right click in coverflow window -> bind to playlist/preferences -> "All Music" playlist is active (that's ok)
2. right click in coverflow window -> bind to playlist/preferences -> right or left click somewhere in coverflow window: first playlist in this case "Podcasts" is now active
Problem is: I didn't change to first playlist, i only clicked somewhere in coverflow window!!
EDIT: Same bug with panelsUI
Reply #303
(Possible bug report)
Clicking on an album in coverflow seems to play the currently selected track in playlist (as opposed to the album clicked on).
Reply #304
Thanks bubble. I still have a problem that I really can't put my finger upon. In the past I used foobar/foo_dockable_panels/foo_bubble_coverflow without any problems. But at some point something changed. Anyway whenever I open a panel with foo_dockable_panels everything is still fine. Then I right click the panel to add the coverflow panel in there. But instead the panel opens as a separate window now. And the window doesn't even display any covers. All covers are black. Then I kill the window and then the panel and boom foobar crashes with an error message as the following.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00FE42B3h
Access violation, operation: read, address: 00000050h
Call path:
entry=>app_mainloop
Code bytes (00FE42B3h):
00FE4273h:  00 E9 6F 04 00 00 8B 5B 1C 3B DE 0F 84 64 04 00
00FE4283h:  00 53 FF 15 D8 C1 FF 00 E9 58 04 00 00 8B 45 14
00FE4293h:  89 70 18 89 70 1C E9 4A 04 00 00 8B CB E8 5B E8
00FE42A3h:  FF FF E9 3E 04 00 00 8B 4B 24 3B CE 74 07 8B 01
00FE42B3h:  8B 50 50 FF D2 8B 43 20 3B C6 89 73 1C 74 0A 50
00FE42C3h:  FF 15 44 C1 FF 00 89 73 20 8B 03 8B 50 04 8B CB
00FE42D3h:  89 5C 24 20 FF D2 8D 44 24 20 50 C7 44 24 74 01
00FE42E3h:  00 00 00 E8 A5 30 00 00 C7 44 24 70 FF FF FF FF
Stack (0013F504h):
0013F4E4h:  BC6F10A0 E3FCD620 BF83F323 BC7491B8
0013F4F4h:  00000400 00000020 E6C5A8C0 E6334868
0013F504h:  37721EAF 0013F5E4 00FE4000 00000000
0013F514h:  7C91EAE3 0013F520 00000018 0081AC88
0013F524h:  01034120 00000001 C000000F 101095E0
0013F534h:  7E3A6360 7E3694BE 7E392135 00EC081A
0013F544h:  00000281 00000001 C000000F 00000000
0013F554h:  000002AB 00000000 00000000 0013F5B8
0013F564h:  00000002 0013F5A0 0013F604 00FFB3D8
0013F574h:  FFFFFFFF 00000000 0013F5A8 7E368734
0013F584h:  00DD0B10 00000010 00000000 00000000
0013F594h:  00FE4000 DCBAABCD 00000000 0013F5E4
0013F5A4h:  00FE4000 0013F614 7E373745 00FE4000
0013F5B4h:  00DD0B10 00000010 00000000 00000000
0013F5C4h:  00000010 00DD0B10 007F91B8 00000014
0013F5D4h:  00000001 00000000 00000000 00000010
0013F5E4h:  00000000 0013F760 00000000 00000001
0013F5F4h:  00000000 00000000 0013F5C4 0013F128
0013F604h:  0013F6FC 7E390457 7E373768 00000000
0013F614h:  0013F65C 7E373591 00000000 00FE4000
Registers:
EAX: 00000000, EBX: 01034120, ECX: 00D56E00, EDX: 00000002
ESI: 00000000, EDI: 00DD0B10, EBP: 0013F57C, ESP: 0013F504
Crash location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00523000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C907000h
COMCTL32                        loaded at 773A0000h - 774A3000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE2000h
Secur32                          loaded at 77FC0000h - 77FD1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 7E360000h - 7E3F0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7E670000h - 7EE90000h
ole32                            loaded at 774B0000h - 775ED000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
guard32                          loaded at 00380000h - 003A2000h
fltLib                          loaded at 5E160000h - 5E168000h
winsta                          loaded at 76300000h - 76310000h
NETAPI32                        loaded at 597D0000h - 59824000h
uxtheme                          loaded at 5B0F0000h - 5B128000h
MSCTF                            loaded at 746A0000h - 746EB000h
GameHook                        loaded at 10D00000h - 10D0F000h
lgscroll                        loaded at 10100000h - 10111000h
MSVCR80                          loaded at 78130000h - 781CB000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
NTMARTA                          loaded at 77660000h - 77681000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
SAMLIB                          loaded at 71B70000h - 71B83000h
apphelp                          loaded at 77B10000h - 77B32000h
msctfime                        loaded at 75250000h - 7527E000h
foo_abx                          loaded at 00B10000h - 00B43000h
foo_albumlist                    loaded at 00B70000h - 00BD7000h
foo_audioscrobbler              loaded at 00C00000h - 00C31000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
foo_bubble_coverflow            loaded at 00CA0000h - 00D26000h
OPENGL32                        loaded at 5F0D0000h - 5F19C000h
GLU32                            loaded at 68FC0000h - 68FE0000h
DDRAW                            loaded at 736D0000h - 73719000h
DCIMAN32                        loaded at 73B30000h - 73B36000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
foo_cdda                        loaded at 00D60000h - 00D95000h
foo_channel_mixer                loaded at 00DC0000h - 00DFA000h
foo_converter                    loaded at 00E10000h - 00E79000h
foo_discogs                      loaded at 00EA0000h - 00F41000h
WINMM                            loaded at 76AF0000h - 76B1E000h
foo_dockable_panels              loaded at 00FE0000h - 01013000h
foo_dsp_dolbyhp                  loaded at 01040000h - 01061000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_dsp_std                      loaded at 01080000h - 010C8000h
foo_dsp_vst                      loaded at 010F0000h - 01112000h
foo_facets                      loaded at 01140000h - 011C1000h
OLEAUT32                        loaded at 770F0000h - 7717B000h
MSIMG32                          loaded at 76320000h - 76325000h
foo_fileops                      loaded at 011F0000h - 01236000h
foo_freedb2                      loaded at 01260000h - 012A1000h
foo_input_monkey                loaded at 012D0000h - 0131A000h
foo_input_std                    loaded at 01340000h - 01468000h
foo_masstag                      loaded at 01490000h - 014E0000h
foo_out_ks                      loaded at 01500000h - 0152A000h
SETUPAPI                        loaded at 778F0000h - 779E4000h
foo_rgscan                      loaded at 01550000h - 015AA000h
foo_uie_lyrics                  loaded at 015D0000h - 0162F000h
WININET                          loaded at 441E0000h - 442AF000h
Normaliz                        loaded at 01640000h - 01649000h
iertutil                        loaded at 43F60000h - 43FA5000h
foo_ui_columns                  loaded at 01870000h - 0196E000h
foo_ui_std                      loaded at 01990000h - 01A51000h
foo_unpack                      loaded at 01A80000h - 01AAD000h
VI                              loaded at 02270000h - 02464000h
WINSPOOL                        loaded at 72F70000h - 72F96000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E3000h
ieframe                          loaded at 444C0000h - 44A8D000h
PSAPI                            loaded at 76BB0000h - 76BBB000h
MpShHook                        loaded at 5F800000h - 5F816000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
urlmon                          loaded at 442C0000h - 443E7000h
dolbyhph                        loaded at 02BC0000h - 02CBC000h
nvoglnt                          loaded at 69500000h - 69BAA000h
imagehlp                        loaded at 76C50000h - 76C78000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
Stack dump analysis:
Address: 00FE4000h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 101095E0h, location: "lgscroll", loaded at 10100000h - 10111000h
Symbol: "UninstallScrollHooks" (+00000DC0h)
Address: 7E3A6360h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetRawInputDeviceInfoW" (+00000068h)
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E392135h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+00001EADh)
Address: 00EC081Ah, location: "foo_discogs", loaded at 00EA0000h - 00F41000h
Address: 00FFB3D8h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 00DD0B10h, location: "foo_channel_mixer", loaded at 00DC0000h - 00DFA000h
Address: 7E373745h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E373768h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 7E373591h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 7E37379Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E3737BCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36B42Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00FE4038h, location: "foo_dockable_panels", loaded at 00FE0000h - 01013000h
Address: 7E36BAA4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsWindow" (+00000171h)
Address: 7E36B96Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsWindow" (+00000038h)
Address: 7E36B3F9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 5B0F3C20h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "DrawThemeText" (+00000BEFh)
Address: 5B10E300h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+000004B0h)
Address: 5B0F1AC7h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Address: 7E36B3D2h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 5B0F1B3Dh, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Address: 5B10E2D5h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+00000485h)
Address: 7E36BB15h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetPropW" (+0000003Ah)
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 7E36C331h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 7E37366Bh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 5B0F2586h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeAppProperties" (+0000036Bh)
Address: 5B0F4301h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeBackgroundContentRect" (+00000362h)
Address: 77EF5A0Eh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GdiReleaseDC" (+00000018h)
Address: 7E36D4E4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SetPropW" (+000000BBh)
Address: 7E36B903h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "SendMessageW" (+00000049h)
Address: 5B11881Fh, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+0000A9CFh)
Address: 5B118777h, location: "uxtheme", loaded at 5B0F0000h - 5B128000h
Symbol: "GetThemeTextMetrics" (+0000A927h)
Address: 7E3684FCh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3685A4h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Address: 7E3689CDh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E36DAEAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 7E37D950h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 7E3689F0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E368A10h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042C283h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 10002638h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 0042CE06h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004C629Ch, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004C6280h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 012107EAh, location: "foo_fileops", loaded at 011F0000h - 01236000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D4B70h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 004A33D3h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049DA60h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004A1828h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CB9A4h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B7398h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042D04Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049EA9Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE81h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE7Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BE560h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BC3F0h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BE8Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B77C7h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049D80Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049D87Ah, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 003A0043h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00380078h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00390035h, location: "guard32", loaded at 00380000h - 003A2000h
Address: 00500069h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 00523000h
Version info:
foobar2000 v0.9.5.1
UNICODE
Windows 5.1
Additional info:
File Operations 2.1  (foo_fileops)
ReplayGain Scanner 2.0.3  (foo_rgscan)
Lyric Show Panels 0.3.2.2 [Feb 14 2008 - 13:57:22]  (foo_uie_lyrics)
Discogs Tagger 1.12  (foo_discogs)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
Facets 2008-02-25  (foo_facets)
Converter 1.1  (foo_converter)
foobar2000 core 0.9.5.1  (Core)
Standard DSP Array 1.0  (foo_dsp_std)
Default User Interface 0.9.5  (foo_ui_std)
freedb Tagger 0.5.2.1  (foo_freedb2)
ABX Comparator 1.3.1  (foo_abx)
Cover Flow 0.16  (foo_bubble_coverflow)
Masstagger 1.6  (foo_masstag)
Columns UI 0.2.1 alpha 10 v4  (foo_ui_columns)
RAR reader 1.1  (foo_unpack)
Audioscrobbler 2.3.1  (foo_audioscrobbler)
CD Audio Decoder 2.1.2  (foo_cdda)
Channel Mixer 0.9.6.3  (foo_channel_mixer)
ZIP/GZIP reader 1.0  (foo_unpack)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
VST bridge 0.60 Beta  (foo_dsp_vst)
Album List 4.2  (foo_albumlist)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Dolby Headphone Wrapper 1.1.1  (foo_dsp_dolbyhp)
Now I'm not sure if this problem is because of an incompatibility between foo_dockable_panels and foo_bubble_coverflow or because of the latest foobar version or even driver related. I just thought I'd mention it. Maybe you have a clue what it could be about.
Reply #305
Check if Playback follows curser is checked. I can never remember which way works and which way doesn't ;-)
Reply #306
Thanks for testing guys!
v 0.17 (download on the first post)
- fix: bound playlist changed if entering the config context menu and cancelling
1. (Possible bug): I right clicked on an album that didn't have any art, then left clicked in the window. The entire window went blank:
Fixed in 0.17, same bug as reported by grimes.
2. (Possible bug): Setting the value for number of albums to a sufficiently high number causes this thing to be displayed at the side. i don't know if you intended for it to happen or not.
It's not a bug: it's displayed like that if the track selected is the first track in your playlist
Could you please assign a keyboard combination to move camera and change fov? (I'm using a laptop with no mechanism to scroll)
yup!
I tried in dockable panel and had no problem..so I have no clue. Can you put back 0.15 and tell me if it works ? (you can get 0.15 on http://bubbleguuum.free.fr/foo_bubble_coverflow)
About the black window, the config may have been resetted and you have to change the path to cover art again.
You need "Playback follows cursor" enabled, until I figure a way to make it work regardless of this setting.
Reply #307
bubbleguuum, foo_bubble_coverflow is really shaping up nicely. the only bugs keeping it from perfection are the continued problems with fullscreen mode on the second display in a dual monitor setup and the fact that when scrolling through a playlist, coverflow does not scroll through the album art in sync with the scrolling playlist (although the reverse seems to work just fine). other than these two bugs, i couldn't be happier. thanks again for all your hard work!
Reply #308
Ok so I tried it with 0.16, 0.15 and 0.14. And I am 100% positive that it used to work just fine with 0.14. The question now is if it's a problem relating to Foobar 0.9.5.1 or if it's something that the nvidia drivers are causing. I would blame foobar since I don't have anything about Coverflow in the preferences except it being in the Components list.
I'll check if reinstalling 0.9.5 solves the problem X_X
Edit: Installing the old foobar version didn't help...
Reply #309
second monitor I totally forgot about, and scrolling can be notified to the coverflow only when scrolling with keyboard: there no way I can get notification if you scroll with the scrollbar as the selected item do not change.
Reply #310
i can live with the second bug, as long as you get dual monitor working  thanks again.
Reply #311
Hi, awesome plugin, I've been lurking a while waiting for updates and glad they are here.
When I try to set Maximum numbers of covers to display higher than 5 it causes Foobar (0.9.5.1) to crash. Even when I try and decrease the number. If you need anymore information ask and I'll try and get it to you.
It would also be great to have an option for send to current playlist and play. An option for showing text or not would be good as well.
Great work though, I look forward to more updates.
Reply #312
just delete the formatting string in "front cover caption" under "display" in coverflow's preferences to to disable text display.
Reply #313
0.18 is out!
- add: quick'n'dirty 2D layout mode similar to foo_graphical_browser, but less configurable
- add: mouse action mappings for right-click
- add: new mouse actions: "Display context menu", "Add to active playlist and play", "Send to active playlist and play"
- add: CTRL+UPARROW/DOWNARROW, SHIFT+UPARROW/DOWNARROW change zoom and fov
- chg: ENTER do the same action than the one bound to left click (on central cover).
- chg: if there several monitor used, fullscreen use the same monitor as the one used by foobar window (previously it always used the primary display)
- fix: could not bind a coverflow to the first playlist
To change the layout between 2D/3D use  "context menu/Layout"
Reply #314
fullscreen works perfectly in 0.18; thank you bubbleguuum! would it be possible to make minimize on fullscreen optional? i would like to have foobar running on one display while coverflow runs on the second.
Reply #315
Tried to give it a go (last version wouldn't bing for me with Facets Playlist.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00000000h
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Stack (0012F7BCh):
0012F79Ch:  00000000 A965532C 00000001 804DA3EE
0012F7ACh:  A9655364 7FFDE700 00000000 00000000
0012F7BCh:  08E220BC 0012F7DC 00000000 08E2252A
0012F7CCh:  0AFDD7B4 08E75098 00000004 015E0632
0012F7DCh:  08E3E274 00000000 00000000 00000000
0012F7ECh:  00000000 7E440457 7E4188E0 0AFDD7B8
0012F7FCh:  0012F974 08E3B0B8 00000000 08E2378B
0012F80Ch:  015E0632 0012FAA4 0012F980 08E75090
0012F81Ch:  00000293 00000183 0000032B 00000200
0012F82Ch:  00000146 00000032 0000040C 00000032
0012F83Ch:  00000004 00000000 08E3E084 08E7509C
0012F84Ch:  08E750A0 0012F81C 0012F834 08E750A8
0012F85Ch:  0012F820 0012F830 0012F820 0012F838
0012F86Ch:  0012F828 0012F830 08E3E08C 08E750A0
0012F87Ch:  08E7509C 0012F824 0012F82C 08E750A8
0012F88Ch:  0012F820 0012F830 0012F820 0012F838
0012F89Ch:  0012F828 0012F830 08E3E094 08E75094
0012F8ACh:  08E75098 0012F820 0012F838 08E750A4
0012F8BCh:  0012F81C 0012F82C 0012F81C 0012F834
0012F8CCh:  0012F824 0012F82C 08E3E098 08E75098
Registers:
EAX: 08C18F90, EBX: 0012F7DC, ECX: 08C17A68, EDX: 00000000
ESI: 08E750D4, EDI: 08E75090, EBP: 08E75090, ESP: 0012F7BC
Crash location: "foobar2000", loaded at 00400000h - 00523000h
Loaded modules:
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774E0000h - 7761D000h
COMDLG32                        loaded at 763B0000h - 763F9000h
foo_abx                          loaded at 003C0000h - 003F3000h
foo_albumlist                    loaded at 00A30000h - 00A97000h
foo_audioscrobbler              loaded at 00AC0000h - 00AF8000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_bubble_coverflow            loaded at 00B60000h - 00BE6000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_converter                    loaded at 08C20000h - 08C89000h
foo_custominfo                  loaded at 08CB0000h - 08D35000h
foo_cwbowron                    loaded at 08D60000h - 08D88000h
foo_cwb_hooks                    loaded at 08DB0000h - 08DFC000h
foo_dockable_panels              loaded at 08E20000h - 08E53000h
foo_facets                      loaded at 08E80000h - 08F00000h
OLEAUT32                        loaded at 77120000h - 771AB000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_fileops                      loaded at 08F20000h - 08F66000h
foo_info_samurize                loaded at 08F90000h - 08FB2000h
foo_input_std                    loaded at 090F0000h - 09218000h
foo_masstag                      loaded at 09240000h - 09290000h
foo_navigator                    loaded at 092B0000h - 092E1000h
foo_out_asio                    loaded at 09310000h - 0933F000h
foo_playcount                    loaded at 09360000h - 09385000h
foo_quicktag                    loaded at 093B0000h - 093EE000h
foo_rgscan                      loaded at 09410000h - 0946A000h
foo_run                          loaded at 09490000h - 094BB000h
foo_scheduler                    loaded at 094E0000h - 0954F000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
WINMM                            loaded at 76B40000h - 76B6D000h
usbnp4x4                        loaded at 6BD00000h - 6BD1A000h
foo_scrobblecharts              loaded at 095F0000h - 09623000h
WININET                          loaded at 771B0000h - 77256000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_skip                        loaded at 09650000h - 0966B000h
foo_tradersfriend                loaded at 09690000h - 096CA000h
foo_uie_lyrics                  loaded at 09700000h - 0975F000h
foo_ui_std                      loaded at 09780000h - 09841000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_utils                        loaded at 09870000h - 098E9000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
iphlpapi                        loaded at 76D60000h - 76D79000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
ig4icd32                        loaded at 0BCE0000h - 0BF29000h
ig4dev32                        loaded at 0BF30000h - 0C0A2000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
Address: 08E220BCh, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E2252Ah, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E3E274h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4188E0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000003Ah)
Address: 08E3B0B8h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E2378Bh, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E3E084h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E3E08Ch, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E3E094h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E3E098h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E246E8h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 08E24000h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 097E7024h, location: "foo_ui_std", loaded at 09780000h - 09841000h
Address: 097E1B0Ch, location: "foo_ui_std", loaded at 09780000h - 09841000h
Address: 08E3B3D8h, location: "foo_dockable_panels", loaded at 08E20000h - 08E53000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423745h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 0BEA20B4h, location: "ig4icd32", loaded at 0BCE0000h - 0BF29000h
Symbol: "DrvCreateContext" (+00001424h)
Address: 7E423768h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423591h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 0BEA1FA0h, location: "ig4icd32", loaded at 0BCE0000h - 0BF29000h
Symbol: "DrvCreateContext" (+00001310h)
Address: 7E43E274h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "VkKeyScanW" (+000000B6h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7E423512h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 7E4194BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B42Dh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E423761h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "PrivateExtractIconExW" (+000002CEh)
Address: 7E42366Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41B50Ch, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4184FCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E42379Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4185A4h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4237BCh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E42D950h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Address: 0042C161h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0041DAEAh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042CCE4h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CBDC8h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004D4B54h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004A3443h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049DAE0h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004A1898h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004CB984h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B7429h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0042CF29h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049EB1Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BF01h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BEFBh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BE55Ch, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004BC470h, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049BF0Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 004B781Bh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0049D88Fh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 0049D8FAh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 003D006Eh, location: "foo_abx", loaded at 003C0000h - 003F3000h
Address: 003D0065h, location: "foo_abx", loaded at 003C0000h - 003F3000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 00523000h
Version info:
foobar2000 v0.9.5.1 beta 2
UNICODE
Windows 5.1
Additional info:
Scheduler 3.53  (foo_scheduler)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Audioscrobbler 1.3.11  (foo_audioscrobbler)
cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]  (foo_cwb_hooks)
Facets 2007-12-16  (foo_facets)
Album Art Browser 0.0.5 [Jul 13 2007 - 10:15:45]  (foo_cwbowron)
ASIO support 1.2.5  (foo_out_asio)
foobar2000 core 0.9.5.1 beta 2  (Core)
foo_skip 0.2  (foo_skip)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]  (foo_cwb_hooks)
Cover Flow 0.18  (foo_bubble_coverflow)
Samurize Info Server (AMPI) 1.64  (foo_info_samurize)
Playback Statistics 2.0  (foo_playcount)
Quick Tagger 1.0  (foo_quicktag)
foo_custominfo 0.1.2  (foo_custominfo)
Run services 0.3.2  (foo_run)
Navigator 0.61a  (foo_navigator)
Reply #316
When did it crashed exactly ? Did the panel loaded in dockable panels ?
What version of foobar, dockable panels, column ui are you using ?
I can't reproduce it on my config
Reply #318
foo b2
dock 1.07
DUI
0.17 I could get into a panel but it would crash sporadically.
0.18 wouldn't "lock" into a panel - it would just float in it's own window.
Can't pinpoint what causes the crash, it crashed once when closing foobar, once when loading bubble_coverflow, once when clicking on a cover etc.
I believe the error log was after clicking on a cover.
Can't get much testing done due to the instability, sorry :-(
Reply #319
Feature request:
Option: coverflow window always in foreground
You can use foo_dockale_panels + columns UI (not used for eral UI but needed by dockable panels) to achieve that
Reply #320
HOLY CRAP!!!! The 2D view is seriously hot! Thank you SO MUCH for this (and for implementing the keyboard shortcut to change FOV).
YOU ROCK!
EDIT:
(Feature Request)
Would it be possible to have the panel display the first cover after displaying the last one? i.e. there wouldn't be a "last album"; the panel would have one continuous list with no end or beginning.
Reply #321
I don't want to use dockable_panels in DUI!
I use the coverflow window and the result is excellent, but when I click in DUI, coverflow is no more on top (goes in background)
Do I need dockable_panels for that? Can anyone give instructions?
nope you dont need this component for coverflow to function. it is just launched in separate window. if you want to fool yourself and anyone who may be looking over your shoulder that youre imba tweaker than you will have to use dockable panel to float above your dui config ;))
Reply #322
(Feature Request)
I support that feature request. Maybe as an option in Preferences?
And I still would like the coverflow to be bound to the music library, not one playlist.
Now, I need one playlist with all my music just for the coverflow. And an option to create an autoplaylist with the selected album when clicking on it woul be very nice (similar to facets).
Good job! Keep on the good work!
Reply #323
foo b2
dock 1.07
DUI
For the panel not in the dockable container, you didn't enable transparency in dockable panel config ? Transparency do not work with an OpenGL window.
For the random crashes, I have no idea as I'm using 0.9.5.1 final + dock 1.07b and I have no problem (but I do most of my testing using an ooold version of CUI + foobar 0.9.4.x).
Just curious, is your album art external or embedded ? hmmm and I forgot to ask your version of CUI.
Can you get the debug version of 0.18 here and send me the error log when it crashes:
http://bubbleguuum.free.fr/foo_bubble_cove...e_coverflow.dll
Reply #324
dl'ng the debug version, I'll see what i can get for you.
no transparency.
I don't use CUI.
all art is external (folder.jpg)
