Topic: Recommended Encoder Versions and Settings (Read 572257 times) previous topic - next topic
Reply #200
Could someone please fix the links in the first post?
oggenc28: it's no longer in dancer, and beta 4.51 is no longer in RareWares. You can either link here (generic), here (P3) and here (P4) for the r1 build, or here if you decide to go ahead with b5.
Same thing about OggDrop, either link here or use the new dancer tags:
http://www.rarewares.org/dancer/dancer.php...gdrop-aoTuV-gen
http://www.rarewares.org/dancer/dancer.php...ggdrop-aoTuV-P3
http://www.rarewares.org/dancer/dancer.php...ggdrop-aoTuV-P4
Reply #201
IMO all links should just be removed.
I never understand the logic of having to maintain a forum post (that can only be edited by mods or the original poster) and a wiki page.  WTF?  Way to make life twice as hard, and confuse the user (wiki and post are rarely synchronised)!  I fought to stop the MP3 settings sticky being maintained, to no avail.
Anyway (), 4.51 links updated, until a decision is made on the HA recommended version.
I'm on a horse.
Reply #204
I was searching for the optimal command line options for ripping with EAC v0.99pb3 (ExactAudioCopy) but didn't found something useful. So I examined some nice things out by my own.
It's optimized for using with the recommended oggenc2.exe (oggenc2.84-aoTuVb5-generic.zip) at the moment.
-q2,22 -a "%a" -t "%t" -l "%g" -d "%y" -N "%n" -G "%m" %s -o %d
Explanation:
-q  Quality between -2 (low) and 10 (high)
-a  Name of artist
-t  Title for this track
-l  Name of album
-d  Date for track (usually date of performance)
-N  Track number for this track
-G  Genre of track
%s  Input file
-o  Write file to fn (only valid in single-file mode)
%d  Output file
Reply #205
Does anyone have changelog for libvorbis with list of changes in latest version 1.2.3??
🇺🇦 Glory to Ukraine!
Reply #206
From "CHANGES" file.
libvorbis 1.2.3 (2009-07-09) -- "Xiph.Org libVorbis I 20090709"
* correct a vorbisfile bug that prevented proper playback of
  Vorbis files where all audio in a logical stream is in a
  single page
* Additional decode setup hardening against malicious streams
* Add 'OV_EXCLUDE_STATIC_CALLBACKS' define for developers who
  wish to avoid avoid unused symbol warnings from the static
  callbacks defined in vorbisfile.h
Reply #207
Does update contains fixes only?
I'm waiting for improving of encoding quality...
