@mmortal03
Okay, i have tested it now and i can tell you that it works perfectly, so it must be something wrong on your end i'm affraid. I ammended the ini file to setup REACT to make WavPack and MP3 track files. When the process had run through, then i had a WV and a MP3 folder in my Testing directory and in the WV folder there where the tracks of the album, four different cuesheet types and an EAC logfile. In the MP3 folder there where the tracks of the album and nothing else. I new that this would happen from reading the config file and when i changed it alittle, and did a re-run, then i had a WV folder with the tracks of the album and one non-compliant cuesheet named "%basename%.cue" and an EAC logfile. In the MP3 folder i had the tracks of the album, a non-compliant cuesheet named "%basename%.cue" and an EAC logfile. The changes i made to achive the latest result was :
Under the WV tracks section, then change :
IF EXIST "@albumfile@.[*].cue" COPY /Y "@albumfile@.[*].cue" .
To :
IF EXIST "@albumfile@.[mg].cue" COPY /Y "@albumfile@.[mg].cue" "@basename@.cue"
Under the MP3 tracks section, then change :
REM COPY /Y "@eaclog@" "EAClog.txt"
To :
And also add this line :
