Topic: foo_uie_single_column_playlist (Read 741283 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #1000
the problem is with the win32 list control, as terrestrial would probably have to do more things like position / scrollbar stuff by himself. if he couldn't implement arbitrary collapse / expand feature, i would like "collapse / expand everything" command at least (for quick overview of the playlist's groups).
Reply #1001
Not sure if its possible, but maybe he could base the component around a treeview control instead of a list control. Then collapsing could be implemented easily. This would also allow a lot more customization like multiple levels of groups.
Reply #1002
terrestrial, i would like to request one (or two) features
please, add the command (assignable to a keyboard shortcut) to toggle "collapse" of all groups just to group headers. it would auto-expand on doubleclick on any group (and start playback on its first item). you could also add features like auto-exapnd on hover (after given time) etc.
similar feature would be to auto-expand playing group and collapse everything else.
also, it would be nice to have those group-related summary infos and info whether given group has item that is playing or not.
thank you
if a group was collapsed would songs inside be played? or would the playlist skip over it?
I think that should be an option. It would actually be pretty cool feature in making playlists if you could selectively expand albums
I like the idea of the now playing album being expanded too.
I think all of this would have to be optional though.
It would also have to save what is expanded/not on close/open.
It would also be kinda nice if text rendering was crisper and more like cleartype. :]
hi
Reply #1003
Is there a chance to get to know what features tererestrial is programming?
Reply #1004
Small annoyance. When I add tracks to the queue, SCP blanks for a moment. I've also noticed that F2K seems to save changes to tracks played minutes prior and also at shudown.  Perhaps it's normal behaviour I just hadn't noticed prior to using SCP.
Reply #1005
I think It might work best if you could independently set the number of rows for a group.
Imagine:
$if(%isplaying%,$grouprows(10),$grouprows(5))
or (what Ive been wanting to do):
$ifgreater(%discnumber%,1,$grouprows(1),)
The current set number of group rows could then become the default.
elevatorladylevitateme
Reply #1006
This seems like a very promising plugin. I have a few suggestions, which most likely already been suggested...
1. Increase the size of the boxes the code is in. I hate how I'm trying to make a working config, and all I have is one tiny little 6 line box to edit the code. I'd like that bot to be much bigger, or better yet, re-sizable. Also, the ability to interact with the playlist while that box is up would be nice too.
2. Allow for a way for the user to assign a command for a double click on empty space in the playlist. Columns_UI had an option to do this. I got accustomed to double clicking empty space to clear the playlist. I'd like to still be able to do that.
Reply #1007
I second that and would also like to be able to select all and clear all text. Dragging to select is a pain in this tiny window (ditto for TIM).
Reply #1008
Short report. Tab and Space keyboard shortcuts (e.g. Ctrl+Tab to switch playlist tabs or Space to pause/play) don't work when the playlist is in focus.
f to c to f to c
Reply #1009
I think I found a bug:
This bit of code:
$imageabs2(104,104,,,,,5,3,'X:\Covers\'%artist%' - '%Album%'.jpg',)
works fine, that is until a file with a special character comes along. For instance the file:
X:\Covers\Godspeed You Black Emperor - F#A# (Infinity).jpg
will not get displayed unless I take out the #'s and rename the ID3 tags. The same goes for any file with a '&' in the title.
Reply #1010
This bit of code:
Try this code:
$imageabs2(104,104,,,,,5,3,$replace('X:\Covers\'%artist%' - '%Album%'.jpg',#),)
Reply #1011
Try this code:
doesn't the replace function take three parameters?
Anyways, I'm not wanting to replace the #'s because the #'s are in the filename. #'s are not illegal characters in windows systems.
edit: here is the code I'm using:
$imageabs2(104,104,,,,,5,3,'X:\Covers\'$replace(%album artist%' - '%Album%,'/',,'\',,:,,|,,?,,'"',>,,<,)'.jpg',)
$imageabs2(104,104,,,,,5,3,'X:\Covers\'$replace(%album artist%' - '%Album%,'/',,'\',,:,,|,,?,,'"',>,,<,)'.png',)
$imageabs2(104,104,,,,,5,3,'X:\Covers\'$replace(%album artist%' - '%Album%,'/',,'\',,:,,|,,?,,'"',>,,<,)'.gif',)
which works for every single album in my collection except for the GYBE album. What the heck... The album art plugin displays the gybe cover fine. (which used the exact same code, except it used wildcards instead of the three different lines for each format).
Reply #1012
new version. mostly internal changes / some optimizations.
Reply #1015
ok, I uploaded a new version with support for the mouse wheel.
Reply #1016
It works.
Thanks for this and the new version - according to my task manager, the cpu usage has changed a bit for the better overall.
I see the topic of rearranging the tracks in the playlist has already been brought up here, but no resolution was given. Here are a few thoughts and ideas on that subject, hope you find them of any value.
1) Not only there is no dragging, we also can't cut and/or copy the tracks from the playlist. Inserting them from the album list works all right, so I guess the other ones can be implemented too.
2) The drag and drop rearranging doesn't really have to be identical to the one in the columns playlist. With real-time position updating, retaining the distances between selected tracks and whatnot. While it certainly would be nice, I can't envision that in the context of scpl - especially the first one.
Do something simpler, maybe? Like Windows' native drag and drop. We select the tracks, then hold down left muse button again, the cursor changes its shape to the familiar arrow with a dotted frame under it. While dragging, the tracks stay on their positions until we release the mouse button. And then they are automatically cut from their places, sticked together (keeping the order though) and pasted/inserted into the new position, right after the track above which we released the button (if the mouse button is released above the group header, tracks will be pasted before the group). And that's that.
Or you can add some inner indicator of where the dragged tracks will be going, too.
The simpler way is just draw a line of some (hardcoded or customizable) color there where the tracks will be inserted if we release the button right now.
A more advanced one would require introducing an additional variable - %_dragmarker% or something, which we will use to detect if the currently rendered track is the one after which the tracks will be pasted, to change its view accordingly.
What do you think?
Reply #1017
Changing playlist from the context menu doesn't work anymore.
Reply #1018
^^ fixed.
to rearrange tracks hold down the alt + mouse or alt + up/down. moving isn't optimized, so the whole playlist has to be reindexed.
Reply #1019
great plugin so far...
but I have one issue/question. I just updated after long time and found something I don't like ^^
Before I had the version from september 24.
after I installed the version from today the font size increased strangly, but just from the first row of the item display!
as you can see here:
thx
callisto
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #1020
Yay! Thanks.
Since now it's like this, an option to not break groups while moving would be great too. At least for the case when the tracks have been selected with ctrl-clicking on the groups' headers (only).
Also, two small issues here:
1. When you select multiple tracks and then right-click on the header of a group not holding down ctrl or shift, selection completely switches to this group. Even if this group is completely included in the selection.
2. If I right-click anywhere in the playlist (to call the context menu) and then click on any header (discarding the menu), only the first track in this header's group would be selected.
Reply #1021
right clicking while a few tracks are selected loses the selection. Now, The only way to access the context menu for a group of selected tracks is via the keyboard. Is this bug still present, And can it be fixed?
Thanks in advance for all the hard work you've put into your plugins, terrestrial.
Reply #1022
Well, with the latest update this bug is gone
Reply #1023
Works for me. With the version dated as Nov 22 2006 - 23:21:26.
Reply #1024
Yeah, I posted before checking the very latest. Works here aswell. Kudos to terrestrial on his skills.
