Topic: foo_uie_single_column_playlist (Read 743579 times) previous topic - next topic
Reply #1025
Found some new bugs.
1) Deleting some files from the playlist and then doing 'undo' (ctrl+z) makes scrollbar disappear. To make it reappear, you have to either resize the window or repeat the "delete-restore" action again.
2) As a continuation, if you do this "delete-restore" routine two or more times, without resizing the window, this will have the following effects: i) bug 1 won't reappear until resizing the window again, ii) the scroll box on that scrollbar won't be able to reach the bottom, even if you drag it with the mouse, iii) the size of the scroll box becomes fixed, and  this behavior persists between all the playlists. All of those disappear when you resize the window.
3) Deleting, then doing 'Undo', and 'Redo' after that leads to the bug 2.
4) An empty playlist doesn't have any scrollbar. It also doesn't get any when you add some files to it (while you don't - right - resize the window).
If you then switch between playlists, the scrollbar won't be in any of them, too.
Can be partially healed with switching playlists to the one with lots of tracks and resizing the window in it. Partially means they (all except the one with a few tracks) will become subject to some 'independent' version of bug 2 (with the difference of having scroll boxes of different sizes).
Full healing can be reached with adding enough files to that almost-empty playlist so that they fill up the window in height, and scrollbar appears. Or you can just delete that playlist and resize the window.
5) Deleting enough files in a playlist leads to the bug 4.
Edit: A bit of specifics.
Reply #1026
I'm also getting a lot of scrollbar bugs when it comes to measuring the panel's height and if it's even necessary to be shown.
Reply #1027
Is there a way to lock this plugin to show always a chosen playlist?
(Of course every instance should have its target.)
Reply #1028
I too like the idea to be able to collapse groups that fofr and mazy introduced, but since I have experienced the scrollbar bug I have started to think that it would also be nice to be able to completely disable the scrollbar. I personally don't have playlists so large that I would need to use the scrollbar to get to the end of playlist. I really like the way my foobar looks without the scrollbar and this options would be nice, if it is possible to implement.
Reply #1029
Hi guys,
I just started installing the newest foobar version and trying to get a nice config with this plugin. but it doesn't work for me.
I have all my covers in the folder of the depending album and they are all named "00. Front.jpg".
So for AlbumArt I use this code:
But for the SingleColumnPlaylist this code doesn't work. And I can't find a code that seems to fit my needs.
Hopefully someone can help me.
Thanx
Great Jay
Reply #1030
Hi guys,
Thanx
Great Jay
if you re - name your cover to  folder.jpg  it'll show up in your single_column_playlist .
Reply #1031
why that? It could be named as mymommyisthebest.jpg and would show up...
@great jay. did u put u're code in an $imageabs() function?? like $imageabs(10,10,$replace(%path%,%filename_ext%,)00. Front.jpg,)
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Reply #1032
thanx...it worked out for me now
I tried to put the code in the group panel but I had to edit something in the item panel as well..
thx
gReat jay
Reply #1033
another quick update to (hopefully) fix the scroll bar issues.
Reply #1034
Works all right here.
Reply #1035
A small fix request:when in the "grey" window mode,there's a hole at the bottom of the playlist thet cannot
be fixed by changing window's size.
Favourite artist:CD-R
Favourite album:700MB
Reply #1036
Short report. Tab and Space keyboard shortcuts (e.g. Ctrl+Tab to switch playlist tabs or Space to pause/play) don't work when the playlist is in focus.
Same trouble here, even with the last update (2006.11.24).
Reply #1037
small bug: when starting up foobar there's always a horizontal scrollbar visible even if the playlist isn't long enough. when switching playlists it disappear eventually if not needed.
Reply #1038
Thanks, so much Terrestrial! This latest version is amazing, the optimizations rock (it no longer refreshes more times then needed) and the drag and drop is exactly what I always wanted. Not to mention you have solved all the active / playing issues I need to have multiple views synchronized and still have a coherent, intuitive player interface.
Thanks! Thanks! Thanks!
Reply #1039
I don't mean to just show up in here and start demanding stuff, but i have a request, if somebody else hasn't brought it up already: Is it possible to make the keyboard shortcut for 'select all' (Ctrl+A here, dunno if it's different in other languages) work in the edit boxes? I instinctively hit those keys to copy text from a box like that, and it just keeps beeping at me every time. :/
(edit: I had a question here earlier, but i figured it out on my own, so i removed it. Great plug-in by the way.)
Reply #1040
Hi, I really like your plugin.
But I have a question: If I have different playlists, is there a possibility to format them differently?
I tried simply making different tabs with that, and i can format that differently. But then i noticed that it showed the same playlist at both tabs - and i want it so that it stays with the selected playlist.
I hope that anyone understands what i mean...
mausemecker
Reply #1041
Could someone remind me of the function that is similar to $_itemcount(), expect that it returns the item number?
Reply #1045
what is the syntax for the fileexists()?
Reply #1046
space selects/deselects items in the playlist, so you can't use it in a shortcut.
Reply #1047
I too would love to know the syntax - I am trying to take advantage of the new features terrestrial has added but not having much luck.
Here is my example
$if($fileexists(%path%,Folder.*),
$imageabs2(%_height%,%_height%,,,,,0,0,$replace(%path%,%filename_ext%,Folder.*),NOKEEPASPECT),
$imageabs2(%_height%,%_height%,,,,,0,0,C:\Documents and Settings\xxxxx\Application Data\foobar2000\data\misc images\nocover.png,NOKEEPASPECT))
If my code doesnt make sense then my thoughts are that $fileexists is a test for a file existing, in this case if there is a file called Folder.* in the %path% location then this should turn true/1 thus in my if statement the first result should be 1 and the 2nd should be 0
Currently only my nocover image is showing... when I know there is a file.* there.. so what am I doing wrong...
Reply #1048
First of all, change
to
$fileexists($replace(%path%,%filename_ext%,Folder.*))
The %path% contains the filename too, not just the name of the containing folder.
Reply #1049
fantastic Hakubo thanks heaps!!! working like a charm
