Topic: Title formatting: replacing illegal filename characters (Read 5900 times) previous topic - next topic
I am using foobar 1.0 and am trying to do something like $replace(%_path%,%_filename_ext%,)$ansi(%artist%).jpg
But nothing is done.
I mean artist is "*shells" and i still get "*shells" instead of "xshels".
Same issue with $ascii
I really need that feature if someone can help
[font= "Courier New"]$ansi()[/font] converts the string from the internal UTF-8 representation to the "system code page".
[font= "Courier New"]$ascii()[/font] converts the string from the internal UTF-8 representation to ISO-8859-1, i.e. plain ASCII.
Because both those character sets contain the star character '[font= "Courier New"]*[/font]', why should the functions change it?
Filesystem-derived replacing of illegal characters is not a part of title formatting.
you could take the easy way out like i do. i use $crc32(%artist%) to generate my filenames. ok, so i can't browse the files in explorer easily but foobar can read them and that's all i need.
$ansi() converts the string from the internal UTF-8 representation to the "system code page".
$ascii() converts the string from the internal UTF-8 representation to ISO-8859-1, i.e. plain ASCII.
Because both those character sets contain the star character '*', why should the functions change it?
Ok now i see
Look at the bottom of that page
http://wiki.hydrogenaudio.org/index.php?ti...File_operations
I understood that it was what the function did :s In fact it was just the renaming tool which did that.
So it would be great to have a function that does those replacements.
I know i can write the $replace() corresponding but if changes are made i would have to update. Would be great to have such a function
What do you need that for?
The album art loader and file operations already perform those replacements on their own.
i need it inside other plugins like wsh panel or panel stack splitter.
in wsh panel i can call the titleformating of foobar on a string.
And then i use that string to save files or create files.
Saying it i already know the answer. It s not a feature that foobar needs but that a plugin needs so ...
Yet i would be so great :s
just write your own replace function then. it's not like windows file naming conventions are going to change any time soon, is it?
and like i said above, you can use $crc32. that would perfectly suit your needs if you weren't so fussy. do you really need to browse your cache of files?
crc32 wouldnt work. What i do is very complicated and i need it to work perfectly.
I already have my own jscript function to do that. The problem is that i want to allow the user to use a foobar titleformat string as a property that will be used to save an image. I want him to be able to use functions like $replace and other stuffs like that. If i wanted to permit that in jscript i would have to rewrite my own fully titleformat ....
For title formatting calls that produce file paths, components are expected to pass a text filter that is part of the SDK. It properly ensures that (back)slashes are replaced when a metadata %field% is evaluated, to avoid specifying unwanted subfolders. That is why you cannot just run a replacement function over the final result. Edit: It is the same with the * character. As part of the original pattern, it denotes a placeholder, but when found in a tag, it needs to be replaced.
That is the problem with introducing another programming layer above the SDK: You keep running into issues that have already been solved, and artificially limit yourself to imperfect solutions. But I guess some things will never change.
So you are saying that if the component pass a text filter that will replace all illegal characters, it should work fine?
THat would be so great.
BTW, on this page is written "? < > get replaced by an _. " but when i replace ? with _ cover doesn't show. I need to delete ? to get it working. Intentional?
Edit: It happens when ? is on end of album name, ex. "Is This Real?".
Edit2: Nope, redundant file, it happens everywhere.
