Topic: AAC @ 128kbps listening test discussion (Read 86183 times) previous topic - next topic
Reply #125
WOOT! The return of fatboy  - I don't want to hear anyone complaining about how all the codecs sound transparent on that one  .
Reply #126
i also dont want that real with its .ra sh*t gets popular
RM is just another container format, playable in many players these days, but I have already mentioned that AAC wrapped in RM is just a temporary solution. Our alternative file writers were not ready in time for Beta. RealPlayer 10 Gold and RealProducer (Helix Producer) 10 Gold will write AAC to another format...
The Real (HE-)AAC encoder was licensed from Coding Technologies, is the only HE capable encoder in addition to Nero (CT did invent aacPlus/HE by the way), and their AAC base encoder probably started out from a similar codebase as the FhG AAC encoder. Personally I would be very curious how it compares to the rest of the AAC encoders out there. "Installing" Helix Producer is as simple as unzipping the files, and if included in the test, I will make sure Roberto has no trouble whatsoever with the encoding or installation (don't want to repeat trying to install RealPlayer.. ), as well as losslessly convert the .ra files to whichever format is preferred, .aac, or .m4a.
As a sidenote, I think it is a good idea to be very clear about which is the actual codec provider, for example for WinAmp, who did they license the encoder from? For Real, like I mentioned, this would be Coding Technologies.
I would *really* like to see Coding Technologies' AAC encoder in the listening test.
Either in the form of Real's implementation, or using CT's actual stand-alone encoder.
(I believe you can use Real Splitter+3ivx Muxer to convert from RM to MP4)
Reply #127
  • Nero
  • iTunes
  • Real
  • FAAC
  • Compaact
  • Anchor
I agree
Reply #128
OK, now a fucker decided to mess my poll.
My patience is growing too thin, so I'll tell you what I plan to do:
-Compaact and Real are in
-Winamp is out because it seems to be broken, so it would be unfair to test it now.
-NCTU is in as an anchor.
-The test will be encrypted and will require Java ABC-HR.
Flames? Opinions? Comments?
BTW: Everything is discusseable, except encryption. It is definitely going to happen.
Regards;
Roberto.
Looking forward to the test... sorry for not reading through all the drama before initially replying
Reply #129
Re: Anchors,
I'm actually partial to a very simple lowpass or something, ie something to just make it at least *easy* to place the last contender...
Oh, that horid crackling sound... that's the bad bad one
Reply #130
Hi Roberto,
I'd like to see featured in this test a live recording sample like this one
Vital papers will demonstrate their vitality by spontaneously moving from where you left them to where you can't find them.
Reply #131
what about including a speech sample with low volume music in the background (like a movie background)
this would satisfy the video nerds and would maybe make the comparsion between the codecs easier?
I know, that I know nothing (Socrates)
Reply #132
No problem. But please provide the sample and suggest what sample should be replaced.
@Atlantis: Please suggest what should be replaced too.
Reply #133
hm best would be a sample from a dts source (and maybe with english language  )
i can only provide a german ac3 source, if thats also ok?
what to replace? hm dunno, maybe waiting cause it was already used in the first aac test too?
Reply #134
I would personally prefer LPCM...
No, Waiting is perfect for killing samples tenderly. It must stay.
Reply #135
hm lpcm is used for dvd movie sound? i thought only ac3 and dts?
Reply #136
I don't know. But I would prefer LPCM neverthless
Of course, if it's not available, DTS would be the way to go. AC3 isn't a good idea considering it's already quite compressed.
Reply #137
It is for Music DVDs. Maybe some opera recitative?
Reply #138
but serious, anyone having a nice dts source from a movie dvd?
Reply #139
I only have from an Eagles concert. My only DVD with DTS
Reply #140
Uhm, I'm unsure about this...
Anyway, I think BigYellow could be replaced, in the 128 MP3 test all codecd were tied (except itunes implementation).
All is IMO, obviously
Reply #141
Hrm... your sample is interesting, but from hearing to it, it seems to be potentially very easy on codecs :/
Reply #142
OK, some more replacement suggestions:
- Polonaise will no longer be replaced with Fossiles, but with Guruboolez' Brahms - Danse Hongroise 6. So it gets replaced by another piano sample.
- riteofspring will be replaced with Mahler - Symphonie 3, also submitted by Guruboolez.
Any comments? Tonight I'll freeze the samples list and start encoding/packing/uploading.
Thanks to Guruboolez for providing those samples.
Regards;
Roberto.
Reply #143
I've tested this sample with 2 of the codecs that will be in the test at (- if VBR - settings aiming at) 128kbps.
There were more then one for me easily abx'able differences in both cases but nothing really obvious/noticable to me without comparing to the original. So ABC/HR ratings would have been between ~4 and ~4.5. IMO there are some sounds in this sample that might cause more problems for other contenders (I won't talk about details publicly before the test) I'm not sure if this sample will help to get significant differences between codecs.
Reply #144
Good point. Can anyone else suggest live recordings?
Edit: So here is the samples list as of now:
BigYellow
DaFunk
fatboy
gone
Hongroise
Mahler
mybloodrusts
NewYorkCity
OrdinaryWorld
Quizas
Scars
Waiting
Reply #145
I can have a look if I find something quickly...
BTW: I would test a bit before suggesting something - so can you please tell what settings will be used with comaact and nero?
Reply #146
Nero: -internet
Keep in mind the test will use a DLL that officially will only be released with next Nero version:
http://pessoal.onda.com.br/rjamorim/aacenc_v2620.zip
Compaact: VBR 5
Reply #147
I had no luck finding a hard to encode live sample. What about using Layla sample, or drop using a live sample and use this instead?
Reply #148
LPCM is definitely within DVD specs, but the only DVDs I know of that use it are music DVDs - defeating the purpose of finding a movie soundtrack sample.
I would be just as wary to use a DTS source as an AC3 source.  IMO the compression quality isn't that much different from AC3 despite the fact that DTS uses ridiculously high bitrates.
Reply #149
How about true killer sample, what Guruboolez uploaded once IIRC. biniou.flac
