Topic: AAC @ 128kbps listening test discussion (Read 86417 times) previous topic - next topic
Reply #175
I tested 272 samples which are a mixture of completely different music styles. I have 132.5kbps average for Nero, which is actually lower than for Compaact1.2b2 VBR5 which was 1 kbps higher average.
It depends on the music style pretty much.
If Nero and Compaact were so close, maybe the fatboy sample where Compaact reached 270 kbps should be reconsidered? :B
Happiness - The agreeable sensation of contemplating the misery of others.
Reply #176
Hold a sec...
BigYellow   143   123   130   124   111
ok..> I encoded BigYellow...
Original:  4320784
MP4:  419946  - RATIO 10.288 - BIT RATE - 137.1 Kbit/s
Audio Track Only: 413488 - RATIO 10.4495 - BIT RATE - 135.02 Kbit/s
(Audio track only is the actual encoder bit rate measured in bit allocation, you could get it by extracting track)
So I think claim 143 + 5-6 kb/s is little bit out of bounds
Reply #177
Indeed, partially my fault. foobar randomized the input, and I forgot to sort it properly.
These are the bitrates foobar reports for the sample suite, encoded with the AAC plugin v. 2.6.2.0, high quality, -internet, LC:
The average is still 141kbps.
The final proof:
All 12 wav files summed: 52.895.248 bytes  divided by
All 12 aac files summed: 5.264.357 bytes  equals 10,0478
Final bitrate = 1411 (CD bitrate) / 10,0478 = 140,428
So there you have it.
Reply #178
Compaact 1.2 beta 3 has been out for almost a week I believe. Alexander informed me of it. Perhpas he forgot to updatre his beta thread with that link. I think it has various optimizations, so you might want to get a copy instead of using beta 2 for testing.
Do you really think he didn't send me an e-mail already about beta 3?
Edit: Erm? That post is directed at JohnV?
So, anyone willing to take a look at my batch script to convert it to bash-friendly?
rjamorim,
Yes that reply was directed at JohnV replying to his post mentioning beta 2 of Compaact 1.2... Sorry if you missed that.
Reply #179
Quote from: rjamorim,Feb 17 2004, 09:05 AM
Quote from: Garf,Feb 17 2004, 08:37 AM
@tigre: Thank-you very much. I'll replace Scars with it, since that seems to be another sample listeners don't like much. Also, I didn't have any funk/soul sample
nooooo! i liked scars! and i liked it even more once i found out it was from Chrono Cross
Reply #180
Nero on Internet :: Medium (High quality) is fair, over 500 full audio tracks (2G encoded mp4) it came out 2.5% above 128Kbps.
Compaact comression is running right now, in about 7 hours it will be completed and I will post the results all together.
Reply #181
well, here's a quick translation, I haven't tested it
Simply copy this into a blank file with LF for newlines, and set it to be +x
#!/bin/sh
# !!!UNTESTED!!!
# Reference decoding
flac -d -o ../Sample01/BigYellow.wav ../Sample01/BigYellow.flac
# Samples decoding
faad -o ../Sample01/BigYellow_1.wav ../Sample01/BigYellow_1.mp4
faad -o ../Sample01/BigYellow_2.wav ../Sample01/BigYellow_2.mp4
faad -o ../Sample01/BigYellow_3.wav ../Sample01/BigYellow_3.mp4
faad -o ../Sample01/BigYellow_4.wav ../Sample01/BigYellow_4.mp4
faad -o ../Sample01/BigYellow_5.wav ../Sample01/BigYellow_5.mp4
# Cleanup
rm -f ../Sample01/BigYellow.flac
rm -f ../Sample01/BigYellow_1.mp4
rm -f ../Sample01/BigYellow_2.mp4
rm -f ../Sample01/BigYellow_3.mp4
rm -f ../Sample01/BigYellow_4.mp4
rm -f ../Sample01/BigYellow_5.mp4
Reply #182
What faac setting did you use? Default seems to give considerably less than 128 on average sample.
Reply #183
-q 115. The average bitrate ended at +-132kbps
I didn't use TNS, since it is disabled by default and not recommeneded at the Audiocoding Wiki page.
Reply #184
Mammouth encoding task is over, 3 days worth - lets just say central heating was not required
Here are the raw figures for final file sizes:
500 lossless Ape files converted to Mp3 @128Kbps came to 1,980,037,004 bytes
FAAC (1.23.5) Quality 125    2,074,364,607 bytes                 5% over
FAAC (1.23.5) Quality 100    1,881,780,853 bytes      5% under
Quality 115 should be spot on
Nero Internet::Medium  high quality    2,029,931,171 bytes            2.5% over
Compaact q5    1,922,327,404 bytes      3% under
Guessing q6 would be 15% over (would have liked to try q6 compression, but we ran out of time).
Best of luck Roberto!
Reply #185
These bitrates sound fair
Reply #186
Thank-you very much for your help, Spoon
The test will start any minute now.
Reply #187
Thanx, I didn't even know it's so high.
Edit: I mean I didnt know the requred quality setting is so high.
Reply #189
I'm coming a bit late.
~250 discs are currently stored on my HDD in lossless format. Classical music only. I've loaded them with foobar2000, randomized the playlist, and converted them with VBR streaming (aacenc32 2620 HIGH). I've stoped after 40 hours of processing.
1495 files were converted. Musical length: 105 hours of music.
• 1495 files
• TOTAL DURATION (fb2k 0.77c) : 4d 9:24:44 <=> 105 hours 24 min 44 sec <=> 379484 seconds
• Total size (without tags) : 6,14 Go (6 602 644 072 octets) [Go=GB; octets=bytes] <=> 52 821 152 576 bits
• average bitrate = 52 821 152 576 / 379484 / 1024 = 135,929 kbps [136 kbps]
or
• average bitrate = 52 821 152 576 / 379484 / 1000 = 139,192 kbps [139 kbps]
< 100 kbps   =    7 tracks*         52min 38sec
100-109 kbps =    0 track
110-119 kbps =   35 tracks       2h 44min 37sec
120-129 kbps =  237 tracks      12h 44min 54sec
130-139 kbps =  643 tracks   1d 19h 22min 34sec
140-149 kbps =  487 tracks   1d 14h 52min 53sec
150-159 kbps =   79 tracks       6h 36min 40sec
> 160 kbps   =    7 tracks          14min 23sec
* On 7 tracks, 6 are mono (or close to be mono) and the last one is a Nirvana joke, with a short musical surprise occuring afer 8 minutes of complete silence.
=> Bitrate is superior to 128 kbps with classical music. But the deviation isn't too high.
Reply #190
I'm using the Internet VBR profile in the test... :/
Reply #191
Stux, you should guard these "rm -f" with a condition so that the users don't lose their samples. Something like:
[ -e ../Sample01/BigYellow.wav ] && rm -f ../Sample01/BigYellow.flac
Would be safer, Roberto will appreciate
Reply #192
Actually, I would just get rid of the rm's
Reply #193
oups... typo error.
I used VBR internet too (streaming would be clearly > 150 kbps).
Reply #194
oups... typo error.
Ah, OK.
Thank-you very much for testing bitrates.
Reply #196
Sample 7 is next up.
Most of the samples have been transparent to me.
Some very few, have been almost transparent. But since the 128 multiformat test, where everything but mp3 and ogg were transparent, I didn't expect to actually hear diferences.
Using onboard sound and walkman headphones at the job, but hey, it's the only way I can test...
Reply #197
Is this a bad time to mention my PuntAAC codec (which says it encodes at 128kbit but in fact runs losslessly while using 5000kbit) and my normalisation rule
S = F / A
where:
S = Final rating
F = Rating given by listening tests
A = Normalized bitrate quotient = b / B (where b = track bitrate and B = 128)
example
If a track with the chosen quality setting (aimed at 128kbit, obviously) turns out to sound 'transparent' (5 out of 5) to everyone, but has a bitrate of 700, then without my normalisation rule it would've won with the perfect score, while with my rule, the final score would be:
S = 5 / (700/128) = 0.9
which sounds fairer to me...
yes, yes, I know that the quality settings are chosen such that the SAMPLE SET averages near the intended bitrate, but:
- It still doesnt paint an absolutely fair picture to encoders that consistently end up slightly below the target bitrate
- It doesn't mean that nothing can be learned from the INDIVIDUAL SAMPLE statistics, especially if a sample is more representative of the type of sound you usually encode.
*ducks chairs thrown by absolutists*
Reply #198
Here I come to bitch again.
So far, I got samples from 6 (six) different listeners. And most of them didn't submit complete result sets.
Obviously, that's not enough to generate statistically valid results. Specially considering I didn't screen the results yet for ranked references.
So, I'd like to know, from the ones that tried to participate, the reason of such low response:
-Having problems with ABC/HR Java?
-The samples are too transparent?
-Getting tired of so many tests in a row?
-Another reason?
I don't plan to extend this test. If I don't get enough results by sunday night, I'll probably upload whatever results I got, and give up.
Regards;
Roberto.
PS: No troll feeding, please ^^
Reply #199
Here: I'm doing 1 or 2 samples a day. When I'm finished I'll submit the results.  Besides this, I should save my results more often - I've lost results when I've been almost finished with a test 2 times already, because my PC crashed (not related to ABC/HR)
