Topic: File creation error (Read 2422 times) previous topic - next topic
File creation error
I'm trying to extract a music CDR to FLAC, but it's giving me this error. My output folder is C:\EAC
here's the log:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 8. September 2016, 17:14
- / Festival da TV Tupi 1979
Used drive  : HL-DT-STBD-RE  WH14NS40   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 128 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\FLAC\flac.exe
Additional command line options : -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" -5 %source%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  2:50.71 |         0    |    12820
        2  |  2:50.71 |  3:58.70 |     12821    |    30740
        3  |  6:49.66 |  6:40.34 |     30741    |    60774
        4  | 13:30.25 |  3:24.07 |     60775    |    76081
        5  | 16:54.32 |  5:43.59 |     76082    |   101865
        6  | 22:38.16 |  4:11.00 |    101866    |   120690
        7  | 26:49.16 |  3:25.58 |    120691    |   136123
        8  | 30:14.74 |  1:16.01 |    136124    |   141824
        9  | 31:31.00 |  3:46.22 |    141825    |   158796
       10  | 35:17.22 |  4:25.30 |    158797    |   178701
       11  | 39:42.52 |  4:42.05 |    178702    |   199856
Track  1
     Filename C:\EAC\\1979 - Festival da TV Tupi 1979\01 - 1.wav
     Pre-gap length  0:00:02.00
     Copy aborted
Track  2
     Filename C:\EAC\\1979 - Festival da TV Tupi 1979\02 - 2.wav
     Copy aborted
Track  3
     Filename C:\EAC\\1979 - Festival da TV Tupi 1979\03 - 3.wav
     Copy aborted
Track  4
     Copy aborted
Track  5
     Copy aborted
Track  6
     Copy aborted
Track  7
     Copy aborted
Track  8
     Copy aborted
Track  9
     Copy aborted
Track 10
     Copy aborted
Track 11
     Copy aborted
 2 track(s) not fully ripped for AccurateRip lookup
 9 track(s) canceled
No tracks could be verified as accurate
There were errors
End of status report
what should I do?
Re: File creation error
Configure EAC so that I doesn't abort.
Rip in burst mode.
Curb your expectations.
I did abort the EAC operation, 'cause I saw that it wasn't working.
If I rip in burst mode, will I get the fidelity of the tracks?
I've tried on dbpoweramp (safe mode) and it ripped. But I feel more confident using EAC.
Thank you
If AccurateRip is enabled and your disc is the AccurateRip database, it will tell you if there's an error.    (Both applications support AccurateRip.)
:D :D That's a funny thing to say, since dBpoweramp is obviously giving you better results!     I don't use dBpoweramp (I've used EAC for a long time, and lately I'm using CueRipper) but dBpoweramp has a stellar reputation and it should be easier to configure and use.
For the file creation error, check the text in CD Artist.
The log shows:
korth
