Topic: foo_uie_lyrics3 (Read 900656 times) previous topic - next topic
foo_uie_lyrics3
Reply #375
Would it be possible to set shadow colour as back or enable customisation of the colour?
foo_uie_lyrics3
Reply #376
Version 0.2.1 uploaded.
http://www.foobar2000.org/components/view/foo_uie_lyrics3
Changelog:
- Solved background issue (where artwork was not displayed after track change etc).
- Now supports timestamps with .xxx as well as .xx.
- Improved fading the highline colour at low scrolling speeds.
- Fixed the global variables getting stuck.
- Fixed the editor - it doesn't drop text any more.
- Added a lyric synchroniser.
- Added the ability to open a browser to a predefined webpage (which you can define) - in the lyric search dialogue.
- Fixed saving with radiostreams.
- Behind the scenes changes to the lyrics searching (your lyrics search order will be reset).
- Sorted the availability of the 'Associate lyrics' options. Also added 'Associate current lyrics' which link the playing track and the currently displayed lyric.
- Added two new timestamped databases.
- Added a Minilyrics output plugin (it gets the lyrics Minilyrics finds). Please note: Minilyrics must be installed and activated for foobar2000 for this to work. To install the plugin, go to the Minilyrics search properties (in preferences) and click 'Download and install'. If you want to remove the taskbar entry of Minilyrics you can do so in the advanced section of Minilyrics' preferences. I would also recommend configuring Minilyrics  to only download synchronised lyrics, as Minilyrics will guess the timestamps for unsynchronised lyrics (which I find annoying).
- Fixed the line spacing of the wiki lyrics database.
- Fixed removing of links and other garbage from wiki lyrics.
- Darklyrics should find more specific lyrics now.
- It will now sort lyrics according to your search order more robustly.
- Fixed a repaint issue where it took a while to update the currently displaying lyric.
- A potential crash fix.
To-Do:[/u]
- Lyric uploading to lyrics.mirkforce.net
- Improvements to the associations.
Thanks to you all for your feedback!
foo_uie_lyrics3
Reply #377
Can we access to the internal editor by using main menu?
foo_uie_lyrics3
Reply #378
Thanks for fixing the background, seems to work fine.
foo_uie_lyrics3
Reply #380
Thanks for the new version.
Some little issues:
1. The bug when the Panel displayed commented lines (reported here) has not been fixed.
2. The Panel does not clear the contents of the fallback text after stop playback (introduced in v.0.2.1).
foo_uie_lyrics3
Reply #382
Changelog:
Fricking awesome! This is what I have been wanting but not bothering to ask for and you have added it anyway. You must be psychic!
Thanks for this.
foo_uie_lyrics3
Reply #384
Thanks for the update!
I think i found some regressions. My settings:
I deleted for testing some of the lyrics i received with previous versions. Now there won't be displayed the lyrics which are available online. Also i cannot load them by the lyrics search dialogue. (There is a glitch with the custom search button too).
Here a video for demonstration: http://www.youtube.com/watch?v=MVp1TmYJwDE...eature=youtu.be
foo_uie_lyrics3
Reply #386
To my posted problem (two posts before): it was somehow related to the minilyrics plugin - after removing it, all works like expected. It seems that mini lyrics integration was and still is not clear to me.
foo_uie_lyrics3
Reply #387
@The vern
Great update, the fading bug fixed and the reload function is back.
Thanks very much!
Another bug report:
As you can see in the image above, the local file lyrics search is not so accurate as it should be.
foo_uie_lyrics3
Reply #388
I can't load them neither, I get "load failed". This happens with wikia.lyrics and this didn't happen in the previous version.
foo_uie_lyrics3
Reply #389
Version 0.2.2 Uploaded.
http://www.foobar2000.org/components/view/foo_uie_lyrics3 (should auto update).
Changelog:
- Fixed refresh on playback stop.
- Commenting out in the fallback text now works.
- Changed the naming of some of the menu entries.
- Fixed problem with the message 'Load failed'.
- Fixed the resizing of the lyric search dialogue.
- Fixed a problem where the custom colours wouldn't update if a synced lyric was displayed.
- Fixed the issue with the preference page window being the wrong size (e.g. when using large fonts) - please confirm this is fixed.
- Crash fixes.
@holyrevenger:
You can fix that problem by using the associations: shift + Right click on the panel -> Associations -> Associate other lyrics -> choose your lyric. Then make sure Associations search is enabled. (I have plans to make this process a lot easier/automated)
foo_uie_lyrics3
Reply #390
@The vern, with both 0.2.1 and 0 2.2, I'm getting a large number of searchs that return results from the wrong artist, wrong song name, or both.  It's happening with most of my results and is not something I've seen before.  The artist and title information for the search is correct, but the results displayed are mostly for the wrong artist or title.
example: http://img820.imageshack.us/img820/2598/capturerww.jpg
I don't think any of my settings have anything to do with this, but I've selected all the online dbs, query all and pick the best result, and prefer synced.  Glad to provide more info.
foo_uie_lyrics3
Reply #392
It's working here. Your comments must be at the start of a line.
@godrick:
Does it happen with a particular database? (i.e. lyrdb.com)
foo_uie_lyrics3
Reply #393
It appears to be lyrdb returning all the garbage.  I'll continue to test and get back here if I find any other dbs acting the same way.
Update:  only results from lyrdb are bad so far.  Out of about 50 search results from lyrdb, only two were accurate.  Other dbs are producing accurate results.  I also tried Lyricsgrabber and was able to get accurate search results from lyrdb for the same songs that were getting bad results with 0.2.1 and 0.2.2.
foo_uie_lyrics3
Reply #394
Hello,
my first post here.
So first of all: Thank you for this great plugin!!! I like it and have fun with it.
For me there is only one wish: Could you make the option to save synced AND unsynced Lyrics in MP3-Tag.
On my PC I like synced lyrics, but my smartpone only displays the unsynced lyrics - so I would like to have both automatically, if they are available.
Thank you!
Greets Martin
foo_uie_lyrics3
Reply #395
Yes, it's woking.
The problem was that my multi-line config is showed up unexpectedely as a single line in v.0.2.2.
Now it's all ok.
Thank you.
foo_uie_lyrics3
Reply #396
Seems to be working better now  It's still not respecting the source priority order, though.
foo_uie_lyrics3
Reply #397
@The vern
@holyrevenger:
Thanks for your advice, but, it would be better to make it automated, cause no one has patient to manually associate every specific lyrics with songs of similar title.
foo_uie_lyrics3
Reply #398
hi, the vern! thanks for this amazing plugin. i am a newbie with foobar so i need your help to make this plugin work as it should. i was using the "classic" foo_uie_lyrics.dll and i want to transfer to your foo_uie_lyrics3.dll. and now to the problem. as i dowloaded foobar, i automatically downloaded a skin called FooNight. there is lyrics show panel with foo_uie_lyrics.dll. so my question is, how can i change it, so it will use foo_uie_lyrics3.dll instead? i tried to find the settings or tried to modify the skin, but no luck so far. i will appreciate if someone could help me with it, just tell me what info do you need or something. you can also PM ME if necessary. many thanks
edit: the script looks like this
$imagebutton(15,5,40,19,$get_ps_global(image.path)'/bt/blank_off2.png',$get_ps_global(image.path)'/bt/blank_on2.png',COMMAND:View/Lyric Show/Online search,,)
$movepanel_c(Lyric Show,5,35,$sub(%_width%,10),$sub(%_height%,40))
tried renaming to "lyrics show 3/lyric search" and "lyrics show 3", but it's not working. i guess i need to change the panel to the new one somewhere? i'm completely lost
foo_uie_lyrics3
Reply #399
The name of the panel have to be the same in the script and in the panel stack splitter. In other words, if you have"$movepanel_c(Lyric Show" then it has to be called the same in the panel stack splitter. If it's different in the panel stack splitter, change it in the script.
Hope it helps.
