Topic: foo_uie_lyrics3 (Read 895179 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #2100
@Fladder72
I use Gerhard's  mod also , on the latest beta 3 ,   can't say I noticed artwork not displaying tho i was runing in ADMIN purely to run the search to trap the bug  will have to check  later
Re: foo_uie_lyrics3
Reply #2102
@Fladder72 I use Mod-UI DarkOne4Mod, with v0.55, and minilyric works fine!
Re: foo_uie_lyrics3
Reply #2104
@Fladder72
I've got it. The Problem was, my Music Source is on a Network Drive. But for the Admin Account I've never mapped this Network Drive
Re: foo_uie_lyrics3
Reply #2105
I've noticed that foo_uie_lyrics3 sometimes uses the wrong lyrics files for a song. Instead of using a lyrics file in the same folder, foo_uie_lyrics3 will sometimes use a (seemingly random) lyrics file in a different folder.
Any ideas on what causes this?
If I manually do a lyrics search, then the random lyrics file doesn't show up, and I can choose the correct lyrics file. I haven't tested this long term, so I don't know if my choice will be retained.
Has anyone else experienced foo_uie_lyrics3 using the wrong lyrics? What solutions worked for you?
Re: foo_uie_lyrics3
Reply #2106
@tigershark
- Is your setting of the folder in Preferences>Tools>Lyrics3>Lyrics Saving correct ?
- When you load a new Lyric manually and you want to keep it, you have to manually save the lyric, because if there is a previously existing lyric, the new one won't save automatically
- Depending on your settings, if the new lyrics is not synced, then even if you save it, a synced lyrics will load instead. This behavior can be changed in the preferences. So maybe your problem is that you are saving a non-synced lyric, and when you play the file again, Lyrics3 will attempt to download a new Lyric because it will look for a synced Lyric, and is set to prefer synced Lyrics.
Re: foo_uie_lyrics3
Reply #2107
@veksha
how to save to the lyrics folder, in the same folder with the tracks "Lyrics\[%artist% - ][%title%]" does not work
Re: foo_uie_lyrics3
Reply #2108
Mrakobes:  check out veksha's post on page 82 of this thread, Reply #2025 (for some reason posting a link to the post took me somewhere else).
Re: foo_uie_lyrics3
Reply #2110
I have read all the posts from page 80, there is no way to save them to a specific folder. Post 2025 is generally about viruses
Re: foo_uie_lyrics3
Reply #2113
There is a desire for the author to pull the lyrics from
https://www.metal-archives.com/
https://bandcamp.com/
The latest foo_multisource (.55) already has metal-archives (metallum) as one of its sources.  The separate plugin linked by Porcus also works well, as long you have the .3 version.  FYI, the author of foo_multisource has indicated that this source is blocked in some areas (https://www.reddit.com/r/foobar2000/comments/o7ua73/lyric_show_panel_3_lyrics_from_genius_musixmatch/).
Re: foo_uie_lyrics3
Reply #2117
I go in through the mirror https://www.dev.metal-archives.com and let Putin with his gang of corrupt officials who enslaved my country...it's probably impossible to swear
Re: foo_uie_lyrics3
Reply #2120
Bro, we will be banned for politics))) we live here as in an occupied colony, Putin does not allow competitors to pass, fakes the votes of voters, the land of our ancestors has been seized
Re: foo_uie_lyrics3
Reply #2121
Sorry to confirm what i supposed. Be strong mate.
Re: foo_uie_lyrics3
Reply #2122
Haha, so only "www."metal-archives is blocked?
Then I assume that the April-joke-became-permanent works too: https://cats.metal-archives.com/
Now ... is it possible for the lyrics components to be easily tweaked to retrieve from here too? (Unless they are already doing so?)
Re: foo_uie_lyrics3
Reply #2124
hi @veksha
may i ask you a question ?
in the past i have installed foo_darklyricsscore , foo_geniuslyricsscore , foo_musicxmatchlyricsscore and so on
are all of them replaced by foo_multisource.fb2k-component?
thanks Veksha
