Topic: foo_uie_lyrics3 (Read 894885 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: foo_uie_lyrics3
Reply #1975
@Veksha (or anyone else here):
Thank you so much for your work.
Could you please tell me which address the component tries to reach when querying Musixmatch? I'm trying to whitelist it in my firewall, but so far adding: musixmatch.com, api.musixmatch.com, and some others like it, still results in a blocked request. I haven't been able to reverse DNS the blocked IPs (the last I got was 54.230.31.68, but the IP changes often).
Thank you in advance.
Re: foo_uie_lyrics3
Reply #1976
apic-desktop.musixmatch.com (foo_multisource.dll)
apic.musixmatch.com (foo_uie_lyrics3_musixmatch.dll)
i think they are one and the same. so whitelist both just to be sure.
Re: foo_uie_lyrics3
Reply #1977
That did it. I already had apic but was missing apic-desktop.musixmatch.com.
Thank you!
Re: foo_uie_lyrics3
Reply #1978
Thank you!
BTW, you can use fakenet to see where application is trying to connect.
Re: foo_uie_lyrics3
Reply #1980
@veksha:  I noticed that you have posted .42 of Multisource over at Reddit.  Can you tell us what changes were made from .41?  I have been having such problem-free results with .41 that I hesitate to update it without knowing if there are any performance improvements I might benefit from.  Thanks.
Re: foo_uie_lyrics3
Reply #1981
Hi, @sveakul . I had some very rare crashes with 0.41. @Sergey77 reported some more to private message box. So 0.42 is an attempt to fix them. (My guess is there will be less or almost no crashes on multi-core systems, but on a single-core processor it can happen more often. i'm not a huge expert in developing multi-threaded applications, so I'm learning along the way.)   :))
Re: foo_uie_lyrics3
Reply #1983
Thanks veksha on the extra info for the .42 release.  I've installed it now and all is working great.  I and many others appreciate your work on this!  I don't know how it could be improved further, even the database selection seems ideal now.
Re: foo_uie_lyrics3
Reply #1984
Guys, is anyone else having problems with "Multi DB: Minilyrics"?
It was working fine a couple of days ago (tons of results), but now it takes forever and I don't get a single result from that source. I also use: Musixmatch, QQ, AZ and Songlyrics and they seem to be working fine (but much less results than what Minilyrics used to return).
I'm using: foo_multisource 0.42 (SSE2), foo_uie_lyrics3 0.5 and Foobar v1.6.5.
EDIT: I just installed foo_uie_lyrics3_minilyrics 0.9.2 to see if it helped, but the same thing happened: no results from Minil. and the search took longer than usual.
Re: foo_uie_lyrics3
Reply #1985
I tried just now and it does seem to "hang" on the Minilyrics source and never find anything, before proceeding to the next.  And yes, a couple of days ago this did not happen.  I only search for non-synced lyrics, but even so Minilyrics would often return results.  Changes at the website?
Re: foo_uie_lyrics3
Reply #1987
does anyone know why my lyrics are in this jumbled mess? tried searching for a solution and i couldn't find anything :(
note that this also happens on Lyric Show Panel 3 too
Re: foo_uie_lyrics3
Reply #1988
please give more information. like name of a song , lyric source, etc
Re: foo_uie_lyrics3
Reply #1989
.the song is www.youtube.com/watch?v=-AuQZrUHjhg
and it seems that its getting the subtitles from the Youtube Source and only from it, not using Google Source or the multisource lyrics that include genius and azlyrics in it. [tl;dr it only found lyrics from youtube and not other sources despite lyrics of the song existing on those sites]
the search parameters for the artist are: [%artist%]
and for the title is: [%title%]
It's weird that this component also cant find lyrics for some (maybe even most) songs in sources/sites even though the sites have the lyrics :I
Re: foo_uie_lyrics3
Reply #1990
By "this component", do you mean LSP3 with the Multisource plugin?  If so, your experience is the opposite of mine--most songs I play via Internet radio streams find multiple sources for their lyrics, and display them fine.  Can you please post a screenshot of your Lyric Searching tab settings from Prefs/Tools/Lyrics Show 3?
Re: foo_uie_lyrics3
Reply #1991
and it seems that its getting the subtitles from the Youtube Source and only from it, not using Google Source or the multisource lyrics that include genius and azlyrics in it. [tl;dr it only found lyrics from youtube and not other sources despite lyrics of the song existing on those sites][/tl]
let's see the list of these songs.
Re: foo_uie_lyrics3
Reply #1992
I'm using Lyric Show Panel 3 to display lyrics. Every time the song starts, LSP3 spends a few seconds searching for lyrics. This occurs even if there's a text file containing the lyrics in the same folder as the song. Is there a way to not perform this search if a lyrics file is already present?
And some songs (like instrumental music) doesn't have lyrics files. Is there a way to tell LSP3 to not perform a lyrics search in this case?
Re: foo_uie_lyrics3
Reply #1993
What type of lyric format preference did you set in LSP3 settings? if "prefer synced" then it will continue to search until it finds synced one.
Re: foo_uie_lyrics3
Reply #1994
In addition to what veksha said, also make sure "Local file search" is at the top of the list in the search order if you store lyrics as external files (and Tag Search if you use embedded lyrics).  Use the "Properties" button to tell Local File Search where to look.
Re: foo_uie_lyrics3
Reply #1995
Thanks for the advice! I was able to get it to stop searching by changing the synced vs non-synced preference.
Is there a way to tell LSP3 to not do a search for certain tracks (like instrumental tracks)? Or will LSP3 always do a search?
Re: foo_uie_lyrics3
Reply #1996
If you will tell LSP3 how it can distinguish between instrumental and non-instrumental then it is possible.
Re: foo_uie_lyrics3
Reply #1997
So in other words, it's not possible?
Re: foo_uie_lyrics3
Reply #1998
it is possible.
look in Advanced tab of LSP3 settings. you will see there a Search Filter.
there is a hint below this field:
Return 1 to prevent a search. e.g. $if($stricmp(%genre%,instrumental),1,0)
if all your instrumental files will have their genre tag equal to "instrumental" then you can use this filter and it will work for you nicely.
this is only an example. you can compose your own filter.
Re: foo_uie_lyrics3
Reply #1999
This is great! Thanks so much!
Do you know if there's a way to prevent searches based on the folder the track is in?
I have audio files in folders titled "Songs", "Soundtracks", and "Podcasts". How do I tell LSP3 to not search for lyrics when the audio file is in "Soundtracks" and "Podcasts"?
