Topic: 0.6 public test (Read 68299 times) previous topic - next topic
0.6 public test
Reply #50
Canar, I believe that all of the meta-data should be written into the files, unless you're talking about CD replaygain data.
Not when it comes to CUE files.
0.6 public test
Reply #51
Testing with fb2k 0.6b3, but probably applicable to previous versions...
When shuffle is enabled and the current song is stopped, selecting play causes the current song to change, rather than playing the current song.
IMHO, the shuffle shouldn't occur from stop when play is selected.  Rather, the current song should be started and any subsequent plays would then trigger the shuffle.
0.6 public test
Reply #52
There wasn't
I know the option didn't exist. I'm asking: what was the default used by 0.5x?
0.6 public test
Reply #53
There wasn't
I would guess 0.0db.  And 0.0db = 89db?  Sort of confused
0.6 public test
Reply #54
That's entirely possible.
0.6 public test
Reply #55
$blend does not work (as noted before, this time in beta 3) as advertised. For example,
$blend(000000,FFFFFF,50,100)
does not return a gray color, but instead returns white. When 50 is changed to 0 (??), the function gives gray. Or am I misinterpreting the docs?
0.6 public test
Reply #56
Just DL'd Beta 3, started it, then opened up the config dialog. And, well, don't you think it's kinda, well, huge? No offence, but having a config dialog the size of your screen is a little overkill? Eh, who knows, it might just be Win98SE playing games on me again. It's done that before. Just thought you should know though.
Update:
Ahh, just found another bug, the File Info dialog seems to be re-sizable, but doesn't resize correctly. What I mean is that the Tags list gets wider, but the File info list stays the same width, so it's a little cut off. Also, the close button is cut off as well. Height resizing works though.
"It's the panties fault! The panties made me a pervert!"
0.6 public test
Reply #57
Can anyone tell me what the purpose of 'Desired volume level' inside Replay-gain is?
I've set to some value like -0.1dB and then scan my mp3. But the replay gain value has no different from that with setting of 0dB.
0.6 public test
Reply #58
Think of it as a "ReplayGain preamp" where 0.0dB = "±0.0dB (89dB)".
This is like preamp, but it only applies when ReplayGain data is present.
0.6 public test
Reply #59
Ah. So, if I'm understanding properly it does not affect the RG data as written to the file?
0.6 public test
Reply #61
if the default RG value adjusts to 89.0 db, why does the slider allow up to 12db "preamp" onto that? shouldn't it be max 11 db to level it at 100? what am i missing?
0.6 public test
Reply #62
Kernel Streaming didn't seem to work for me on 0.6b3. It gave me an error:
INFO (CORE) : opening file for playback : file://D:\mp3s\09-linkin_park_-_breaking_the_habit.mp3
ERROR (foo_out_ks) : KS output error: unsupported data format.
However, it worked fine for me in 0.586. Bug?
0.6 public test
Reply #63
you really should give us some more info than that :B
0.6 public test
Reply #64
Okay, I just tried reinstalling it and it worked.  must be something wrong I did previously. heh, anyway thanks loads.
[edited] I found out it was due to my Output Data Format settings that had the problem to arise.
0.6 public test
Reply #65
albumlist doesn't work, click refresh don't see anything!
database enabled, nothing in albumlist box
0.6 public test
Reply #66
uhm. what settings are you using? did you change anything from default? etc. etc.
0.6 public test
Reply #67
she's a virgin install, just have "d:\my music" and * in the two database boxes.
0.6 public test
Reply #68
there she goes!
just have d:\my music (no quotes) and the second box blank.
0.6 public test
Reply #69
oh snap!
how do i get this thing working with multi-cd albums! (with dirs like 'artist - album\cd1' etc)
i want albumlist to show multi-cd albums as 'artist - album - cd1'!
i tried putting %_directoryname% in both boxes but that makes a 'cd1' album in albumlist that, when clicked, playlists ALL the mp3s in my mp3 dir which are under 'cd1' (or disc1/cd2/disc2 etc) subdirs!
anyone figure out the right uhm syntax/code/whathaveyou to do this?
oh and it would be kool if albumlist loaded with foobar!
0.6 public test
Reply #70
%artist%[ - %album%][ - %disc% ]|%title%
That would work if you have all the tags correct. It shows it as "artist - album - cd1", and when expanded it shows songs.
0.6 public test
Reply #71
beta4 posted, crash when opening mp3 file with xing header not containing frame count should be fixed now
0.6 public test
Reply #72
'fraid you are! dB = decibels , they are a measure of power ratio. They are not a percentage. They involve logarithms.
dBs = 10 log (Power 1 / Power 2)
here is an ok (not great) explanation of decibels:
0.6 public test
Reply #73
Hi.
Can you change "reset all" button to "reset current page", and use shif+click this button to "reset all".
Thank you.
0.6 public test
Reply #74
About the 'show balloon tooltip on song change'. Very nice option, but;
if you change the song again within the time the balloon is visable, the new balloon isn't visable until the old one dissapears. it would be nice if the new balloon comes on top.
(i'm using win2k sp2)
edit:
I second Pack27's suggestion about the reset button!
