Topic: Menu layout changes in v1.0 (Read 73562 times) previous topic - next topic
By way of trying to help in another thread, I noticed Context Menu preferences have made quite a leap forward in UI.
thanks
terry
context menu is reseted and can't be rearranged: I got used to my context menu, can option for rearranging it be added?
No.
can option for rearranging it [the context menu] be added?
No.
I'm quite sure this decision had good reasons - I am thinking of easier support because of known, standardised menu structure. However, I also got used to be able to group the context menu by use of separators and custom groups for nesting rarely used commands together. Could you at least explain why you decided to remove this possibility?
Ease-of-use. Context menu customizability added needless complexity and provided little-to-no benefit.
It broke my right click menu inside foobar : / iPod Manager & Discogs stuff went to a sub-category called Legacy Commands : / now they are all messed up.
yeap! mine is broke too...
And how I can organize that menu ?
Regarding the "Legacy commands" group: You need to contact the developers to update their component with the new SDK as soon as it will be released.
With the change to the context menu structure, some components' menus are moved to Legacy section until the plugins are updated.
bubbleguuum will soon update foo_discogs, I believe.
stimulating the audio nerve directly
It puts a lot of stuff under legacy. But as I can see, this doesn't happen to all components. Do the components that get an item under legacy in context need an update from the developer to reclaim an own subgroup in context menu?
That is a strange release in a positive sense: unexpected number and unexpected changes like restructure of edit menu. Thanks!
Yes and No. Indeed: it was horrible to work with the old context menu editor and the new one is much friendlier. However: the benefit increased with every new component. A first look into the new context menu (i am not at home, so i use a clean install) shows a new arrangement of items and it even looks better. But i am really afraid to see mess with all installed components. A chance to have opportunity just to rearrange the order of the items of the first level and to set seperators (means: no rearrangment of commands from one folder into other folder)?
Nice to see that you now can set playing file as source for selection viewing. On the other side (though i see advantages of central settings in many cases) i think it would have been better to select the source in each ui element seperately as you would like to mix the sources in one layout (small album cover that shows playing songs cover and big album cover) or you have different layouts where in one you like playing file as source and in another you want selection as source.  Why not?
Edit:
Not sure how the new edit menu works? If you select items in library search or playlist search then you see info in selection viewer but the commands of edit menu are not related to current selection.
@2E7AH: vertical and how do I re-organize the context menu ? like move things up and down etc.
It should at least be possible to rearrange context menu items provided by third party components. My context menu is quite a mess.
It's not possible anymore, as explained earlier.
- bollocks about no-customizable context menu (reeeaaally!). Tho -- can at least "(unsorted)" be stripped from legacy item?
- like the new, separated configuration;
Cosmetic change request (hoping it's right topic):
- Move (context-menu-wise) "Convert" from separate "Convert" category to "File Operations" category (converting a file is a "file operation", therefore fits there better and will decrease clutter in the context menu
Also, I would consider 'Open Containing Folder' a File Operation, too.
Nonsense. Replaygain would also be a "file operation" by your logic. Same goes for "Open containing folder". "File Operations" contains options that move, copy, rename and delete files without parsing them. Open containing folder launches explorer. "Convert" transcodes.
And there goes another -- ReplayGain, either under Tagging or File Operations (tho I would lean more towards the former)
EDIT: (one minute of difference  ):
As stated before, I consider it that way (and it was the way I built my context menu -- it was intuitive and compact!).
I stand that Convert does the same kind of file operations that moving/copying/deleting (one might say that it in a way comprise all of the above  )
Its more like folder operation...
Seriously, it doesnt matter. File operations category is for foo_fileops commands only. You could consider "file operation" almost every context action.
EDIT: Canar's speed...
