Topic: foo_upnp (Read 1663274 times) previous topic - next topic
dinodisc and 1 Guest are viewing this topic.
foo_upnp
Reply #1325
Hi bubbleguuum,
I am a foo_upnp user using with foobar + foo_sacd . First thank you to add the 176.4 khz to the spec in future, I am waiting for this feature.
I have some problem on the latest version 0.99.35, when I using it with android app bubbleupnp (paid license), it always render the songs to 48khz (old version do not have this problem). Even I switch a rendering device to Linn Sneaky DS or foobar rendering with 24/192 sound card support wasapi / asio. The problem can be fix after I restored the previous version. Does something wrong on me or some issues on the latest version?
I just discovered the problem may caused by foobar2000 portable installation. The sampling problem will not occur when I use the standand installation (i.e. installed in program files).
Make sure you modify the BubbleUPnP streaming profile (if you cannot see it, remove foo_upnp.xml in you foobar2000 profile dir) to match the foobar2000 profile.
foo_upnp
Reply #1326
Hi Bubbleguuum,
Thank you for your reply and I had discovered this issue on yesterday night. Now I know that even I choose the rendering device for linn ds, then rendering setting may follow the profile (previous verison do not have bubbleupnp profile so will follow the default setting).
Hope the new release of the foo_upnp with 176.4 support will coming out soon, insteand I need to hack the dll.....
foo_upnp
Reply #1327
Hi. Is it possible to/how can I go from this..
to this?
In other words, get the remote library into columns ui so I can use the filters etc. and use it almost like on the server/native side.
foo_upnp
Reply #1328
I was thinking about the same idea (DUI in my case). Something like a virtual folder to be monitored.
foo_upnp
Reply #1329
to this?
The best you can do is to integrate the UPnP Browser into your CUI layout as a CUI panel.
foo_upnp
Reply #1330
I've got a HTPC at home setup with foobar and using UPnP to stream the Playback Stream Capture to my foobar here at work. I'm controlling it from work using foo_httpcontrol and just letting the stream play continuously (i.e. I never stop or pause the stream on my work fb2k instance). It works great (WAY better than foo_vorbisstream which I tried first) but there's almost exactly 10 seconds of buffer between when I hit pause and when the audio stops (obviously the same for any other of the controls). The playback stream is being encoded to mp3 v0 because I obviously don't have the bandwidth to do PCM and it's the best trade off between audio quality while transcoding file size.
Is there something I can change on the source or listener side to lessen the buffer amount? I don't mind some buffering, but 10 seconds seems pretty excessive when I've got plenty of bandwidth available to me.
So am I out of luck?
foo_upnp
Reply #1331
Don't use Playback Stream Capture for this. Instead connect at work to your home foobar2000 with "View > Add remote foobar2000 server...". The remote server will appear in the UPnP Browser that you can use as if the server was on the LAN.
foo_upnp
Reply #1332
Correct me if I'm wrong, but I think I want to use the Playback Stream Capture (in conjunction with httpcontrol) for the following reasons:
1) I want to scrobble everything I listen to. When using the UPnP browser I get an "Audioscrobbler: Skipping track due to missing artist or title info." message.
2) I'd like my playcounts on my home server to be incremented, because I use a couple of auto-playlists which key off whether a track has been listened to before (this ensures I listen to everything at least once)
3) One of my playlists is extremely large (i.e. 5 weeks worth of music) and it takes forever to load in the UPnP browser
4) I can see my folder.jpg album art when using httpcontrol, but not with UPnP.
The long buffer isn't a deal breaker, but I'd love it if I could cut it down slightly. Even 5 seconds would be world's better.
foo_upnp
Reply #1333
I don't have such an entry in the foobar2000 menu, not even with Shift-View. What's going on?
foo_upnp
Reply #1334
1. Ok. Still scrobbling is overrated...
2. The upnp server update playback statistics although it might be less accurate than regular playback
3. million tracks playlists with a life long worth of of music is indeed a local foobar2000 concept.
4. it is supported and you should see it provded it is not disabled at either end
For the delay,  streaming is done by the regular foobar2000 http decoder so it starts to play when it decides to (provided the server feeds it audio fast enough which I can't see a reason it wouldn't).
foo_upnp
Reply #1335
You must have the UPnP Browser launched (either as a standalone window or as an UI Element or a CUI panel)
foo_upnp
Reply #1336
I realize that scrobbling isn't your fault. Wish Florian had added that before he went AWOL. You're right, it does update playback statistics, sometimes. In my initial test it didn't work apparently. No idea why my album artwork isn't working; I have it enabled on both ends.
foo_upnp
Reply #1337
The plugin depends on UDP but what about TCP?
Also from the current docummentation "Apply the "sort incoming files by" filter when sending new items to playlist: is now renamed to "Sort items sent to playlist by" and the sort order does not depend of "Shell Integration->Sort incoming files by" but the texbox beneath the checkbox - am i right?
foo_upnp
Reply #1338
UDP is used for SSDP discovery. TCP for everything else (HTTP)
You are right. It allows you to override the order the remote server sends items.
foo_upnp
Reply #1339
hi bubbleguuum,
I want to modify foo_upnp library tree format but don't know how!
For example I have 3 songs, and one of the song is sung by both artists. In mp3tag artist field I input:
song1 artist: abc
song2 artist: def
song3 artist: abc\\def
In foobar2000 internal Media Library tree view under Artists, it shows 2 artists:
abc
def
Select either artist will bring up the 2 songs with the selected artist.
But when browsing through foo_upnp, it will show a 3 artists entry:
abc
def
abc, def
I WANT the way foobar2000 internal Media Library tree view showing. How can I modify foo_upnp_ml_tree.xml so that it lists like foobar internal library tree? I check the xml file and it seems very very simple:
   <SubTree label="Artists">
      <spec type="object.container.person.musicArtist">%artist%</spec>
      <spec type="object.container.album.musicAlbum">%album%</spec>
   </SubTree>
How to modify? Thanks in advance!!!
foo_upnp
Reply #1340
Hello all,
I need help on my system, I tried to find a solution reading part of the thread but it is too long and my english is not good  enough to make useful research.
However, I have a mini-itx server running Foobar2000 1.1.9 on WXP, with column_UI and foo_upnp running and correctly configured.
The server hosts a backup of all of my CDs, and is connected to my Hi-Fi amplifier.
I can control foobar2000 from my main P (the one I'm using now) using KinskyDesktop (playing Nirvana right now) and from my wife's smartphone (Android) using BubbleUPNP application through a WiFi connection (Is BubbleUPNP yours, bubbleguuum?).
Up to this point, everything works really fine.
I really miss, however, an important feature (at least, for me):
when I set up a playlist, both into KinskyDesktop or BubbleUPNP, the playlist is local to the UPNP control point, so if I close the control point, the playlist is lost and the playback is stopped.
Moreover, I cannot create a playlist on my PC and then control it from the smartphone (or viceversa), cause the playlist is local to the device which created it.
Again, I can create a playlist into my PC and a different one on the smartphone, causing a big mess.
Last issue, I cannot switch off the control point until the playlist is playing; this is not a big problem with my PC, but it is a bigger problem with the smartphone (battery dies fast).
Any idea how to address this issue? Any way to create the playlist onto server (foobar2000) side?
Thank you very much in advance.
Best regards,
Giovanni Albergoni
foo_upnp
Reply #1341
I'm having trouble controlling my Sony BDV-L600 with foo_upnp, it shows up and I can queue up music, but as soon as I press play, foobar locks up
If you need any more info, please let me know
The same happens with BubbleUPnP too
foo_upnp
Reply #1342
Hey everyone,
Having a bit of a problem getting this to run on Windows 7 (64bit).  I have a full 1.1.9 Foobar installed, opened necessary ports, started upnp service, etc.  Can't connect - ran wireshark to see if the necessary ports were doing well . . . anything - and they aren't.
Here's a log (set to fine incase)
[code]0.001: foo_upnp::on_init(136)/6848: INFO: foo_upnp: version 0.99.34
0.004: PLT_UPnP::Start(211)/6848: INFO: Starting UPnP...
0.005: media_tree_root_node_t::load_ml_filters_from_file(200)/6848: INFO: file C:\Users\Shike\AppData\Roaming\foobar2000\foo_upnp_ml_tree.xml do not exists
0.005: standard_media_tree_root_node_t::load_ml_filters(558)/6848: INFO: loaded default Media Library filters
0.008: PLT_UPnP::AddDevice(343)/6848: INFO: Starting Device...
0.009: PLT_HttpServer::Start(109)/6848: INFO: HttpServer listening on 0.0.0.0:56293
0.010: PLT_UPnP::AddDevice(343)/6848: INFO: Starting Device...
0.011: PLT_HttpServer::Start(109)/6848: INFO: HttpServer listening on 0.0.0.0:54213
initialized in 0.012s
0.110: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.110: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.110: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
Host: 239.255.255.250:1900
NTS: ssdp:byebye
USN: uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
NT: upnp:rootdevice
created 7798 path registry entries in 0.105s
0.114: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.114: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.114: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
NT: upnp:rootdevice
0.133: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
0.133: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
NT: urn:schemas-upnp-org:device:MediaServer:1
0.136: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
0.136: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
NT: urn:schemas-upnp-org:device:MediaRenderer:1
0.152: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
0.152: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
NT: urn:schemas-upnp-org:service:ContentDirectory:1
0.155: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
0.155: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
NT: urn:schemas-upnp-org:service:AVTransport:1
0.171: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
0.171: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
NT: urn:schemas-upnp-org:service:ConnectionManager:1
0.174: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.174: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.190: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.190: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
NT: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.193: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
0.193: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
USN: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
NT: urn:schemas-upnp-org:service:RenderingControl:1
0.209: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.209: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.212: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.212: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.228: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.228: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.228: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.231: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.231: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.231: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.247: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
0.247: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.250: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
0.250: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.266: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
0.266: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.269: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
0.269: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.285: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
0.285: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.288: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.288: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.304: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.304: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.307: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
0.307: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.323: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.323: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.326: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.326: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.342: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.342: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.342: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.345: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.345: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.345: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.361: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
0.361: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.364: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
0.364: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.380: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
0.380: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.383: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
0.383: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.399: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
0.399: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.402: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.402: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.418: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.418: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.421: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
0.421: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.437: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.437: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.440: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.440: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.456: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.456: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.456: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.459: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:byebye) Request to http://239.255.255.250:1900* with location:
0.459: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.459: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
NT: upnp:rootdevice
0.475: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
0.475: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.478: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
0.478: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.494: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
0.494: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.497: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
0.497: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.513: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
0.513: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.516: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.516: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.532: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.532: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.535: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
0.535: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.551: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.551: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.554: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.554: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:byebye
0.870: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://192.168.1.254:56293/DeviceDescription.xml
0.870: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.870: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
LOCATION: http://192.168.1.254:56293/DeviceDescription.xml
NTS: ssdp:alive
CACHE-CONTROL: max-age=1800
Server: UPnP/1.0, DLNADOC/1.50, Platinum/0.5.4.0 / foobar2000
NT: upnp:rootdevice
0.873: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://192.168.1.254:54213/
0.873: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.873: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
0.889: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
0.889: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
loaded Media Library tree in 0.880s
0.892: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
0.892: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.908: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
0.908: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.911: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
0.911: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.927: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
0.927: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.930: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
0.930: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.946: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
0.946: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.949: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
0.949: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.965: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
0.965: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.968: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
0.968: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
0.984: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://192.168.1.254:56293/DeviceDescription.xml
0.984: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
0.984: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
0.987: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://192.168.1.254:54213/
0.987: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
0.987: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
1.003: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
1.003: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.006: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
1.006: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.022: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
1.022: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.025: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
1.025: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.041: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
1.041: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.044: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
1.044: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.060: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
1.060: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.063: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
1.063: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.079: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
1.079: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.082: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
1.082: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.098: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://127.0.0.1:56293/DeviceDescription.xml
1.098: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
1.098: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
1.101: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://127.0.0.1:54213/
1.101: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
1.101: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
1.117: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
1.117: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.120: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
1.120: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.136: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
1.136: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.139: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
1.139: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.155: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
1.155: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.158: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
1.158: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.174: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
1.174: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.177: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
1.177: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.193: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
1.193: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.196: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
1.196: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.212: PLT_DeviceHost::Announce(293)/7500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://127.0.0.1:56293/DeviceDescription.xml
1.212: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::upnp:rootdevice
1.212: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
1.215: PLT_DeviceHost::Announce(293)/4500: FINE: Sending SSDP NOTIFY (ssdp:alive) Request to http://239.255.255.250:1900* with location:http://127.0.0.1:54213/
1.215: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::upnp:rootdevice
1.215: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: upnp:rootdevice
1.231: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:device:MediaServer:1
1.231: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.234: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:device:MediaRenderer:1
1.234: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.250: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ContentDirectory:1
1.250: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.253: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:AVTransport:1
1.253: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.269: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:schemas-upnp-org:service:ConnectionManager:1
1.269: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.272: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:ConnectionManager:1
1.272: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.288: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
1.288: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.291: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411::urn:schemas-upnp-org:service:RenderingControl:1
1.291: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.307: PLT_SsdpSender::SendSsdp(72)/7500: FINE: Sending SSDP NOTIFY for uuid:aba1bac7-d093-4161-54e0-1bcf44203177
1.307: PLT_HttpHelper::ToLog(441)/7500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.310: PLT_SsdpSender::SendSsdp(72)/4500: FINE: Sending SSDP NOTIFY for uuid:ab435182-b5dd-fc7a-b16f-f7320f5a5411
1.310: PLT_HttpHelper::ToLog(441)/4500: FINE:
NOTIFY * HTTP/1.1
NTS: ssdp:alive
1.604: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.605: PLT_HttpServer::ProcessHttpRequest(142)/7708: FINE: Received GET Request from 127.0.0.1 for /DeviceDescription.xml
1.605: FbMediaServer::ProcessHttpRequest(330)/7708: INFO: received LAN request: http://127.0.0.1:56293/DeviceDescription.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.605: FbMediaServer::ProcessGetDescription(414)/7708: INFO: ProcessGetDescription: user-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024)
1.613: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.613: PLT_HttpServer::ProcessHttpRequest(142)/8188: FINE: Received GET Request from 127.0.0.1 for /ContentDirectory/aba1bac7-d093-4161-54e0-1bcf44203177/scpd.xml
1.616: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.616: PLT_HttpServer::ProcessHttpRequest(142)/7660: FINE: Received SUBSCRIBE Request from 127.0.0.1 for /ContentDirectory/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml
1.616: FbMediaServer::ProcessHttpRequest(330)/7660: INFO: received LAN request: http://127.0.0.1:56293/ContentDirectory/ab...03177/event.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0)
1.616: PLT_Service::ProcessNewSubscription(506)/7660: FINE: New subscription for ContentDirectory/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml
1.616: PLT_Service::ProcessNewSubscription(534)/7660: INFO: New subscription for ContentDirectory/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml, sid=uuid:a507f1d0-0aea-3c2e-c1a3-8a3db013dbd5
1.617: PLT_EventSubscriber::PLT_EventSubscriber(60)/7660: FINE: Creating new subscriber (uuid:a507f1d0-0aea-3c2e-c1a3-8a3db013dbd5)
1.617: PLT_EventSubscriber::SetTimeout(141)/7660: FINE: subscriber (uuid:a507f1d0-0aea-3c2e-c1a3-8a3db013dbd5) expiring in 1800 seconds
1.617: PLT_EventSubscriber::AddCallbackURL(176)/7660: FINE: Adding callback "http://127.0.0.1:2869/upnp/eventing/pafvtspujz" to subscriber uuid:a507f1d0-0aea-3c2e-c1a3-8a3db013dbd5
1.619: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.620: PLT_HttpServer::ProcessHttpRequest(142)/7124: FINE: Received GET Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/scpd.xml
1.621: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.621: PLT_HttpServer::ProcessHttpRequest(142)/7852: FINE: Received SUBSCRIBE Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml
1.621: FbMediaServer::ProcessHttpRequest(330)/7852: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...03177/event.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0)
1.621: PLT_Service::ProcessNewSubscription(506)/7852: FINE: New subscription for X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml
1.621: PLT_Service::ProcessNewSubscription(534)/7852: INFO: New subscription for X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/event.xml, sid=uuid:544b3508-80b1-d072-2e1e-7d9cf5122e40
1.621: PLT_EventSubscriber::PLT_EventSubscriber(60)/7852: FINE: Creating new subscriber (uuid:544b3508-80b1-d072-2e1e-7d9cf5122e40)
1.621: PLT_EventSubscriber::SetTimeout(141)/7852: FINE: subscriber (uuid:544b3508-80b1-d072-2e1e-7d9cf5122e40) expiring in 1800 seconds
1.621: PLT_EventSubscriber::AddCallbackURL(176)/7852: FINE: Adding callback "http://127.0.0.1:2869/upnp/eventing/amhphckuof" to subscriber uuid:544b3508-80b1-d072-2e1e-7d9cf5122e40
1.623: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.623: PLT_HttpServer::ProcessHttpRequest(142)/6876: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.623: FbMediaServer::ProcessHttpRequest(330)/6876: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.623: PLT_DeviceHost::ProcessHttpPostRequest(555)/6876: FINE: Received IsAuthorized action from 127.0.0.1
1.623: FbMediaServer::OnAction(261)/6876: INFO: received action 'IsAuthorized', args = { DeviceID= }
1.624: FbMediaServer::OnAction(284)/6876: INFO: action 'IsAuthorized' response: args = { DeviceID=,  }
1.624: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.625: PLT_HttpServer::ProcessHttpRequest(142)/7968: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.625: FbMediaServer::ProcessHttpRequest(330)/7968: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.625: PLT_DeviceHost::ProcessHttpPostRequest(555)/7968: FINE: Received IsAuthorized action from 127.0.0.1
1.625: FbMediaServer::OnAction(261)/7968: INFO: received action 'IsAuthorized', args = { DeviceID= }
1.625: FbMediaServer::OnAction(284)/7968: INFO: action 'IsAuthorized' response: args = { DeviceID=,  }
1.917: NPT_HttpClient::SendRequestOnce(1032)/7784: FINE: requesting URL http://127.0.0.1:2869/upnp/eventing/pafvtspujz
1.921: NPT_HttpClient::SendRequestOnce(1032)/8092: FINE: requesting URL http://127.0.0.1:2869/upnp/eventing/amhphckuof
1.936: PLT_HttpClientSocketTask::ProcessResponse(289)/7784: FINE: PLT_HttpClientSocketTask::ProcessResponse (result=0)
1.936: PLT_HttpClientSocketTask::ProcessResponse(289)/8092: FINE: PLT_HttpClientSocketTask::ProcessResponse (result=0)
1.942: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.943: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 3
1.943: PLT_HttpServer::ProcessHttpRequest(142)/7576: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.943: FbMediaServer::ProcessHttpRequest(330)/7576: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.943: PLT_DeviceHost::ProcessHttpPostRequest(555)/7576: FINE: Received IsAuthorized action from 127.0.0.1
1.944: FbMediaServer::OnAction(261)/7576: INFO: received action 'IsAuthorized', args = { DeviceID= }
1.944: FbMediaServer::OnAction(284)/7576: INFO: action 'IsAuthorized' response: args = { DeviceID=,  }
1.944: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 4
1.944: PLT_HttpServer::ProcessHttpRequest(142)/3900: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.944: FbMediaServer::ProcessHttpRequest(330)/3900: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.944: PLT_DeviceHost::ProcessHttpPostRequest(555)/3900: FINE: Received IsAuthorized action from 127.0.0.1
1.944: FbMediaServer::OnAction(261)/3900: INFO: received action 'IsAuthorized', args = { DeviceID= }
1.944: FbMediaServer::OnAction(284)/3900: INFO: action 'IsAuthorized' response: args = { DeviceID=,  }
1.945: PLT_HttpServer::ProcessHttpRequest(142)/4328: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.945: FbMediaServer::ProcessHttpRequest(330)/4328: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.945: PLT_DeviceHost::ProcessHttpPostRequest(555)/4328: FINE: Received IsValidated action from 127.0.0.1
1.945: FbMediaServer::OnAction(261)/4328: INFO: received action 'IsValidated', args = { DeviceID= }
1.945: FbMediaServer::OnAction(284)/4328: INFO: action 'IsValidated' response: args = { DeviceID=,  }
1.946: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/7668: FINE: current http task count = 2
1.946: PLT_HttpServer::ProcessHttpRequest(142)/6672: FINE: Received POST Request from 127.0.0.1 for /X_MS_MediaReceiverRegistrar/aba1bac7-d093-4161-54e0-1bcf44203177/control.xml
1.946: FbMediaServer::ProcessHttpRequest(330)/6672: INFO: received LAN request: http://127.0.0.1:56293/X_MS_MediaReceiverR...177/control.xml (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024))
1.946: PLT_DeviceHost::ProcessHttpPostRequest(555)/6672: FINE: Received IsValidated actio
foo_upnp
Reply #1343
   </SubTree>
modify the line to read:
<spec type="object.container.person.musicArtist">%&lt;artist&gt;%</spec>
This will split %artist% by individual artists. Untested but should work.
foo_upnp
Reply #1344
Not possible. Playlist is local to the Control Point, whatever the Control Point is, unless you have a Linn DS.
foo_upnp
Reply #1345
With lockup do you mean total freeze of the app ?
DLNA TVs can be really annoying  and are not totally supported so I'm not surprised...
foo_upnp
Reply #1346
Hey everyone,
Connecting to what, from where etc, what network configuration...?
foo_upnp
Reply #1347
duplicate post
foo_upnp
Reply #1348
Hey everyone,
I'm using a computer at work with foobar portable, trying to connect to the foobar as server at home.  The home computer is the Win7 64 box.  I've forwarded all necessary router ports, disabled all firewalls, checked ports at work which are fully open . . . but can't connect to the FB2K server at home.
Testing the portable install as a server at work verifies that ports should be showing in wireshark from what I can tell, but at home it's like there's no attempt to use the ports at all.
EDIT:
To clarify I'm specifically talking about the UPNP ports.  For example, if I had the server port set to 5678 I ran a filter "tcp.port eq 5678" in wireshark and it worked on the work machine when the server service was enabled (ports showed as being used in wireshark by FB2K w/UPNP).  Doing the same on the home machine showed zero attempts at the ports for the server service being used.  The work machine is 32bit with portable install and the home machine is 64bit with full install.
foo_upnp
Reply #1349
hi bubbleguuum,
Thanks! That works! I need to study those CODE! Is there any guide for dummy?
Btw, is there is way to remove the current topmost level, so that a upnp controller/browser will directly show album/artist/genre/... as the topmost level? Since I don't use foobar local playback, nor the "playback stream capture", now my topmost level has only the "Media Library". It seems kind of silly with only 1 item at the top level...
