Topic: foo_upnp (Read 1663504 times) previous topic - next topic
Re: foo_upnp
Reply #2200
Without the source code, foo_upnp cannot be updated to include new foobar2000 features such as dark mode and x64 architecture. Unfortunately, bubbleguuum, the developer of foo_upnp, is offline on hydrogenaud since 2021. Unless someone can contact bubbleguuum on github or other channels, foo_upnp will likely never be updated.
Re: foo_upnp
Reply #2201
Hi.
How do I use "Stream Capture" to generate an "HTTP Stream" link without needing to select a renderer in the "UPnP Controller"?
This link I will add to HQPlayer Desktop.
Re: foo_upnp
Reply #2202
As Windows 11 only has an x64 version, I believe x86 will soon be eliminated (Realize that the linux distributions x86 repository is also optional).
It is a pity that this plugin (foo_upnp) does not have an x64 version and there may be no more updates.
I still haven't found a way to use foorbar(ios version) to play PC music library directly, unless you use the 32-bit version of foobar on your PC and install this plugin.
Re: foo_upnp
Reply #2203
But x64 Windows will still run 32-bit software, so what's the problem?
