Topic: foo_upnp (Read 1658960 times) previous topic - next topic
koupa, JakubL and 5 Guests are viewing this topic.
foo_upnp
Reply #525
new: server: option in streaming profile to apply RG only to files that would be transcoded to mp3 or decoded to PCM according to the rules.
Thank you for implementing this feature, but unfortunately I can't find it.
The option is not in the UI, you have to edit foo_upnp.xml and restart the server. look for the "decoded_and_transcoded_only" attribute in the file and set it to "yes" in the relevant profile.
foo_upnp
Reply #526
Request: Not sure if this is possible, but an option to scrobble tracks to last.fm (via foo_audioscrobbler - similar to how foo_dop does it) when they are streamed to another device. Eg., if I use foo_upnp to play a track on my Xbox360, the track would also get scrobbled.
"Lifting Shadows Off a Dream"
foo_upnp
Reply #527
This is probably the single best plugin (IMHO) for foobar. Keep up the great work!
Were you the same person who had done some of the work years(s) ago on Java integration? If so I'm very interested in helping / forking if you'd be willing to share source.
On to the meat of the post...
Suggestion/Request:
Is it possible to add some working/progress indicitators to both the tree and the search request? There are many times when clicking on the tree that it's not immediately obvious that something is happening. I understand that things ARE happening but the immediate user feedback will make the UI "feel" better, specifically in the case of searching. Something as simple as a rotating icon, "Working...", indeterminate progress bar, etc. I've dealt with very similar issues with my users (at work) and often times feedback goes a long way.
See http://www.extjs.com/deploy/dev/examples/d...direct-tree.php. In particular look at the animated dots/circle when expanding a node, not the animated node expansion itself.
Hopefully that makes sense, if not I can dig up more example videos / screenshots
foo_upnp
Reply #528
If foo_audioscrobbler offers an API (likely if foo_dop uses it), I'll look into it
True, I did an experimental Java plugin loader some time ago. Its source is available here. I never devellopped it
further because mapping the SDK to Java classes is a huge and non trivial task.
I agree some visual feedback is really needed. I'll do something about it.
foo_upnp
Reply #529
Nice to see such a useful plugin is kept up to date. Bubbleguuum, you're work is really appreciated.
But I have a issue I couldn't find in the previous thread pages. Using foobar 1.0 and your last beta 0.99.17.
I work with FLACs with embedded cuesheets. Foo_upnp seems to work really nice when it streams un-transcoded music, which gets to the client in the form of 1411 kbps PCM. But since this format is quite inapplicable over the internet, I prefer to have mp3 streamed to the client. When I switch to 'always' transcoding to MP3 the client can't get a correct tracklists of FLAC albums: the tracklists it receives are made of the same (the last) track over and over. Albums that were already coded in MP3 are no issue.
It does seem something which can be easily handled, I think.
Thank you very much.
foo_upnp
Reply #530
@mccarver: streaming url is missing the subsong index. This will be fixed in the next release
foo_upnp
Reply #531
0.99.18 (first post to download)
- browser: new: added visual indication of browsing and searching actions
- server: new: send fodlerPath MS specific property for WMP to be able to browse by folder path. Return MS specific rating property if present (%rating% between 0 and 5)
- server: fix: transcoding to mp3 items with subsong would not work
- server: chg: removed childCount property of returned containers, was slowing down browsing too much in some cases (most noticeably, when browsing the Media Library node).
- controller: mute toggle button reflects renderer mute state
foo_upnp
Reply #532
Last rel works flawlessy, my bug is definitely fixed.
I just have a question: what kind of album arts are currently supported? My 'folder.jpg' are not streamed. Just a minor inconvenience I guess..
Thank you
EDIT: Going to next track after previous is finished is slooow and in the meantime produces unwanted sound stuttering..
foo_upnp
Reply #533
Hi, thanks bubbleguuum for this update.
Bug report starring foo_upnp server with wmp client:
- the MS properties won't always work for me, by default foo_playcount does not store the rating in file tag. Could you check the %rating% titleformatting field instead of the rating tag.
- the path is not right for some albums that would end up in the generic <current folder>. This is because the original path has an ampersand and it has been escaped. From a conversation we had earlier  I quoted a microsoft document:
In Windows Vista, WMP Sharing double-escapes the XML tags inside the descriptor () element.
..that is the xml tags only should be double escaped, not the path inside the escaped tag! It might  be my fault because I spoke about 'inner text'.
The test build worked fine though because the desc tag content was not double escaped at all and wmp 12 can handle this.
- I'd rather see the paths exposed be constrained to the foobar media library if that's possible.
- not new but still valid, the default wmp profile decode to wav but then for each files, wmp 12 shows a blue exclamation mark along with a warning This file is of an unrecognized type ... Selecting the lpcm format fix this.
By the way, why is there a wav format in the first place? This container is never mentioned as a valid format in the dlna specs I could read (draft only as i don't have 300€ to spend on the final document).
foo_upnp
Reply #534
The server recognize album art configured as Front Cover in Preferences / Display / Album Art.
"Allow allbum art streaming" must  be enabled in Server / Advanced setting pref page (it is enabled by default)
For the UPnP Browser to load  album art in an Album Art Viewer UI Element (under DUI), "Fetch album art" must be enabled (on by default)
inthe Browser pref page.
Note that under CUI, album art cannot display yet. It needs to use the newer album art loader introduced in fb 1.0.0.
Can you be more precise about the exact settings this happens ? transcoding enabled ? over internet ? how much bandwidth ? which file type ? etc...
foo_upnp
Reply #535
This is probably why I can't see album arts..
It seems to only happen with trascoding enabled. As a matter of fact streaming is almost gapless in PCM.
Transcoding options are set to VBR MP3. It seems I can't set ABR/CBR back.
Experiments are done in local network.
foo_upnp
Reply #536
This is great software, thanks!
However, let me report 2 problems I encountered:
- The Wi-Fi connection must be established before the moment foobar2000 is started.  Otherwise, if foobar2000 is started before I establish the connection, my device would not see the foobar server.  It would only see the computer, which is a different server.  This is not the case with Windows Media Player 12, to I can connect even if it was running before I established the Wi-Fi connection.  Why is it necessary to establish the Wi-Fi connection prior to starting the foobar UPnP server?
- If I start a audio file in a playlist from the external device, it would play, but it also sets the option Stop after current (available in the Playback main menu).  I would rather prefer it to let the audio continue with the next files in the playlist instead.
I'm running v. 0.99.16.1 on the latest foobar2000 0.9.6.9 and I'm connecting with a Nokia N95.
foo_upnp
Reply #537
I can't seem to reproduce the problem. Both VBR and CBR works without glitch here. Note that there is a confusing visual bug on the
ABR and VBR/CBR radio button, where both buttons can be selected at the same time, but it does not affect operation.
Because I'm not detecting new network interfaces after starting.
I've just implemented it in the upcoming version (not too far off) so it should work as you expected in this case.
I suppose you mean you are remote controlling a foobar2000 Media Renderer instance, and on that instance "Stop After Current" remains enabled.
During the time of being remotely controlled, the Renderer enables "Stop After Current" because it needs it for proper operation. It just does a poor job at restoring the initial
"Stop After Current"  state when not being controlled anymore.
foo_upnp
Reply #538
I guess we can say it this way, too.
Do you mean it's a bug that could be fixed sometime?
This behaviour is a bit confusing, since you can easily forget about "Stop after current" when you use foobar as a basic audio player again.
foo_upnp
Reply #539
New version, with finally the much requested ability to browse the ML by folders. For the new "Folders" node to show up,
you'll have to either remove  foo_upnp_ml_tree.xml or add
<SubTree label="Folders" type="filesystem"/>
The server now loads the content of the browse tree when starting, so browsing on the client should be much faster, especially with large libraries.
0.99.19 (first post to download)
- server: support for browsing the Media Library by folders (requires prior removal of foo_upnp_ml_tree.xml or adding the node manually)
- server: on start, preload the whole Media Library browse tree in background, to speed up client browsing
- browser/controller: detect new network interfaces at runtime and UPnP devices on those interfaces
- server: in returned items, when browsed from WMP, returned rating property was off by one star. Also, use %rating% instead of the RATING tag for both WMP and fb2k returned ratings.
- server: in returned items, when browsed from WMP, set folderPath property value to the item's Media Library relative path (allow browsing by folders on WMP).
- server: when streaming profile specify LPCM, take into account LPCM limitations (bitdepth = 16, max samplerate = 48Khz).
- server: WMP profile defaults to LPCM (if no foo_upnp.xml exists).
- server: do not force conversion to stereo anymore when streaming LPCM to a fb2k instance
- renderer: restore correctly user state of "Stop After Current" when a track stops.
- controller: when selecting a Linn Source in the combo box, the Source was not enabled on the Ds, only the first time.
@Speech: Stop After Current should be fixed in the new version.
foo_upnp
Reply #540
With .99.19, foobar2000 crashes a few seconds after startup for me if I have 'Split tree nodes by first letter if more than x items' enabled.  I'd guess it's related to the changes you made in the startup code to load the media library in the background.  If you want I could supply you with a crash log but I'd guess replicating this on your end probably shouldn't be overly difficult to do, at least as your media library is bigger than a trivial / token size.
foo_upnp
Reply #541
Thanks for reporting, fixed in 0.99.19.1 (first post to download)
foo_upnp
Reply #542
Thanks it works fine now, you're awesome!  Browsing the ML by folders appears to work very well to me in my quick testing as well.
foo_upnp
Reply #543
One question. Is it possible to stop the automatic recode from FLAC to WAV?
I am using the foobar2000 server with a Linn DS player. The Linn supports 24 bit flac files (i.e. DVD audio). As well the Linn device accepts flac files over upnp.
If I now try to stream 24bit flac files only one song is played and then it stops. As well the decode automatically decodes it to 16bit wav file so i loose audio quality. Then it takes processor time from the server for recoding it to WAV.
More and more devices are supporting direct playback of FLAC. Can we add a switch to disable the recode?
foo_upnp
Reply #544
OK when using foobar for playback it is working and flac is used. It is only recoding when using kinsky desktop as controller.
But when using the foobar the display on the Linn device does not show artist and track info. Is there any setting for that?
And one more question. Is there alreay columnsUI supporting the upnp artwork display??
Moderation: Removed useless full quote of the preceding post.
foo_upnp
Reply #545
I posted this in the "Support" forum by mistake... my bad. I'll repost here with a description of the problem I am hoping to get help with...quoting from my previous post:
I was delighted to find that the beta version of Foobar2000, when combined with the UPnP component, allowed my to send song files to my Linn DS player. That delight was short lived when I found that every 3-4 minutes playback came to a sudden halt, with a "Buffering..." message displayed in the UPnP controller window. And the music does not restart until I exit Foobar and then start all over again.
BTW I am using a QNAP server with Twonky software, which I really do not like, and bypass whenever possible. I have about 4.5 Terrabytes of music in Flac file format stored on this server and I like the fact that I can play songs directly from the server, allowing Foobar to act as the media server, but the stopping bug is bothersome and potentially renders Foobar ineffective for UPnP playback. And I hope there is a remediable problem here, as I'm gaining a real appreciation for Foobar, the more I use it.
I look forward to your suggestions.
Doug Coleman
For the music stopping problem, in the UPnP Controller combo box, are you using your DS unit as a traditional UPnP AV Media Renderer (MediaRenderer appended to the name) or are you using the Playlist source (Playlist appended to the name) ? Do you have the same problem (getting stuck on Buffering....) if you use Twonky as the Media Server instead of the plugin ? Anyway ,what you can do is enable  the debug logs in Advanced Settings. Enable "Log to file" with INFO log level. Then restart foobar and operates the plugin until the problem occur. Close foobar and send me the file foo_upnp.log (either in your foobar install directory or c:\Document And Settings\<your login>\Application Data\foobar2000) to bubbleguuum@free.fr
foo_upnp
Reply #546
Kinsky Desktop is using the "Default" streaming profile which stream as WAV for non-standard codecs (ie other than mp3, aac, wma), as it is the most compatible.
If you copy the "Linn Ds" profile settings to the "Default" profile then it should work as you expect (streaming 24 bits FLAC instead of WAV).
I thought it worked but as my DS do not have any display (it is a Sekrit DS-I), I could not check. So from what I understand if you send
an item from foobar your DS do not display metadata while it does if you use KinskyDesktop (with foobar as the media server) ?
Not yet. ColumnsUI needs to be recompiled with the (unreleased) foobar 1.0 SDK.
foo_upnp
Reply #547
Doug Coleman
I am sending it to Living Room: Akurate DS (Playlist) and I do not have the same problem when using the Twonky software - which I seem to have an aversion to ++ but I'm not sure why. It just annoys me, and I prefer the Foobar interface. I will enable logging and send you the log file following the next buffering stall. And thank you for your promt reply.
And BTW, it seems to be happening less, the more I use it.
D.C.
foo_upnp
Reply #548
This did the trick. Thanks for the feedback!
Correct (using foobar as media server). If I use kinksydesktop then the Meta data is displayed on the Linn. When I use foobar to sent to the Linn then the metadata is not displayed.
foo_upnp
Reply #549
Ok, I'll look into it.
The latest version of columnsUI (0.3.8.2) supports upnp album art.
