Topic: [Not My Release] Library Tree (Read 129305 times) previous topic - next topic
@Developer
I realise you are spending time on your Biography panel which I really like but could you please find some time to look at the following concerning the Library Tree;
1) Several crashes - sent report to foobar devs. None repeatable but all point to this plugin
2) Changes in preferences, even other plugins eg caption title cause this plugin to refresh it's contents
3) Change the way file are sent to playlist. Currently Elplaylist shows them as selected. See my many earlier posts describing this
4) It would be nice if we could have a context menu entry to Collapse All
5) Adding options to adjust the spacing and padding between nodes would be good
6) Sub-items counts would be useful
7) Would it be possible to have two named playlists and a set of mouse click options for each. I would like a single click to add to playlist a but a double click would send to playlist b - for example.
Thanks for your time and effort so far. I'm looking forward to seeing the next version of this plugin.
There are 20 Library Tree 0.3 crash reports in the database, from approximately 9 different machines*. These reports can be made available to the developer on request.
Call path statistics:
entry=>app_mainloop=>Delete View 1 (6 entries, 3 machines)
entry=>app_mainloop (5 entries, 2 machines)
entry=>app_mainloop=>Update View 2=>Construct Nodes (3 entries, 2 machines)
entry=>app_mainloop=>on_playlist_activate (2 entries, 2 machines)
entry=>app_mainloop=>Remove LIB (1 entries, 1 machines)
entry=>app_mainloop=>destroy panel=>destroy child panel=>destroy panel=>destroy child panel (1 entries, 1 machines)
entry=>user_interface::shutdown (1 entries, 1 machines)
entry=>user_interface::shutdown=>destroy panel=>destroy child panel (1 entries, 1 machines)
Note: machine counts are estimates based on numbers of different CPU/OS combinations.
I'm developer of this component.
Sorry for bad quality of my components.
Please send the crash reports of not only LibraryTree but also my other components  to "ssenna********.co.jp".
I'd like to fix fatal bugs at least.
Thanks in advance.
edit: to avoid spam e-mail. my adress can be confirmed at the bottom of my web page.
Welcome on H.A ssenna
very pleased to see you there, i'm a fan of your work, thanx again for your very good components !
Regards,
Regards,
You can double this
Hi ssenna
Great to finally see you on HA. I'd like to thank-you for all your plugins and especially for your time. You have really made a great contribution to the look n feel of foobar for me and many others.
Keep up the good work and don't forget about those change requests!
Reply #32
Peter, many thanks for the crash reports.
I fixed fatal bugs and updated Library Tree( http://foo2k.chottu.net/ ).
However some bugs may remain yet.
I understood the requests.
(but I can't promise to implement all of them.)
And, thanks for the welcome.
Version 0.3.1 Released
Not sure what else has changed but the problem of sending selected tracks has been fixed and now has an option to select or not - Great!
Thanks for the update.
Reply #34
thank you for this great plugin!
i have a question: can the horizontal scrollbar be disabled?
Reply #35
I've found a strange bug!
Using the library tree with the following setting;
View Format: $swapprefix(%<band>%,a,the)\['('%date%')' - ]%album%[\Disk %discnumber%[ - %disctitle%]]\%tracknumber% - %title%
Sort Format: %album%|%tracknumber% and enable sorting checked.
If I select the album and use left click context menu to open the properties dialog, on some albums I get the tracks in reverse order. All tags are correct as far as I can see.
Any ideas what's wrong?
Reply #36
edit
nevermind <stupid me>
Thanks for great plugin
Reply #37
Very nice plugin! I really like how it can replace both playlist switcher and album list.
Even better, though, if you could somehow display the number of items and length of your playlists.
Thank you very much!
Reply #38
@ssenna
Just wanted to notify you about a possible small bug in Library Tree. Link
Reply #39
how can make this uie pulgin background transparency
Reply #40
Very good work!!
Small problem:
I've running several instances of Library Tree.
Switching between this instances results, that one item (the marked one, the grey one, here: Library view) is inaktiv and according playlist isn't shown.
Reply #41
This plugin is really useful, it doing something that album list panel doesn't have.
However, I have a problem about it performance, foobar2000 stalls seconds whenever some metadata is changed. Can it be improved? (maybe a background thread to do expansive works?)
Reply #42
Hi.
I would like to have an View in the "ActivePlaylist"-Section, where all the tracks from the active playlist are shown (and maybe the now-playing-item highlighted), so that can use it as a simple playlist-view(er). (Maybe with drag&drop items from another playlist)
Would that be possible?
Reply #43
@ssenna
Library Tree is executed in single-thread.
This design is not appropriate as a library viewer and may cause these problems.
I will make Library Tree multithreaded.
Reply #45
I really like this plugin, but I have one request: couldn't you add an option like album list panel has, which shows the number of sub-items?
Thank you very much for the hard work!
Reply #47
problem: sort doesn't work at all, why ??
The sorting only applies to items when they're sent to a playlist I believe. I don't think you can change the sort order of items in the library tree. You can in Playlist Tree mod though- although playlist tree mod doesn't have nice things like autorefresh on tag or library updates. I haven't found a library viewer that does everything I want...
Reply #48
Hi! I don't know what to write in "view format" to see only the rate songs and in order... Anyone can help me?
Reply #49
Hmm, i don't think you're right, if this sort field was just for applying it when items are sent to a playlist, the checkbox the provide this 'enable sorting when sending to a playlist...' wouldn't be needed anymore ! just my mind ...
so, only Ssenna can tell us if it is a bug or not because nothing is explained in the joined txt file.
Thanx by advance
