Topic: [Not My Release] Library Tree (Read 129854 times) previous topic - next topic
Reply #50
Hi! I don't know what to write in "view format" to see only the rate songs and in order... Anyone can help me?
i dont know if this is any use to you but this is what i have for something similar in Album List Panel, just a few things will need chaging for Library Tree (ie, the | switch, cant remember what it is in Library Tree)
$if($strcmp(%rating%,'5'),'?????',$if($strcmp(%rating%,'4'),'?????',$if($strcmp(%rating%,'3'),'?????',$if($strcmp(%rating%,'2'),'?????',$if($strcmp(%rating%,'1'),'?????',$if($strcmp(%rating%,'?'),'?????',%rating%))))))|
$if($stricmp($ext(%filename_ext%),'CUE'),'CUE',$if($stricmp($ext(%filename_ext%),'WMA'),'MP3',$if($stricmp($ext(%filename_ext%),'OGG'),'MP3',$if($stricmp($ext(%filename_ext%),'M4A'),'MP3',$if($stricmp($ext(%filename_ext%),'MP3'),'MP3',$if($stricmp($ext(%filename_ext%),'FLAC'),'FLAC lossless',$ext(%filename_ext%)))))))|
[$swapprefix($if2(%album artist%,%artist%))' - ']$if2(%album%,%title%)[' ('%discnumber%$if(%totaldiscs%,'/'%totaldiscs%)')']' '['['%date%']']|
[%tracknumber%. ][%artist% - ]%title%' '['('%length%')']' '['['%play_count%']']
this seperates by rating, then file extension, artist - album etc.
hope its off some help
Reply #51
instead of doing all the string compares on rating, I just use "$repeat($char(9733),%rating%)"
I dont know what the performance difference will be, but it works.
hope this helps.
Reply #52
When are we going to get some library viewers like this for Default UI?  Is this a future possibility?
Reply #53
@Jack Schmaltz
Or:
$repeat($char(9733),%rating%)$repeat($char(9734),$sub(5,%rating%))|$caps($info(encoding))|...
Without stars (no need for unicode charset):
%rating%|$caps($info(encoding))|...
Reply #54
Would make sense to be able to embed CUI-Panels into DUI and vice-versa, dunno if this is possible at all from coding side without enormous changes. Would at least make sense to bundle some efforts, ideas and time and to homogenize things (therefore 'vice-versa' doesn't make sense  ). BTW, dangerous half knowledge, isn't there some outstanding DUI-PlugIn-API..
Reply #55
There's an SDK for developing elements for the Default User Interface, but it's not available to the public.
Reply #56
A plugin like this one would fit my needs exactly.  I guess that I'll have to start playing around with Columns UI again, but it sure would be nice to have some more library viewer options for Default UI other than Album List and Facets.  Both of those are good, but they're not exactly what I'm looking for.
Reply #57
Request:
Is it possible to add an option to auto expand certain trees? Particular with the playlist tree it's annoying, to have to expand it after every foobar restart. Alternatively, maybe the panel could remember the position of the trees after a restart?
Reply #58
new beta out : experimental version(v0.3.2b)
@Ssenna: bugg found
when i click on a playlist to swap to activate it, the mouse cursor stay in the 'working' state even the new playlist is fully "loaded"/activated, weird
can you check/fix this point please ?
What's new in this experimental version ? multi thread ?
Reply #59
ok, i found some news ... in creating view for Library, now the sort when sending to playlist works !! thanx
always a shame that this sort is not directly applied on the view
btw, the mouse cursor always stuck to the state 'working' after editing a view too alkthough process seems over, weird !
Reply #60
@Falstaff
big news for you Falstaff
the newly added $nodisplay(str) is implemented for tree sorting !!
here's my crappy translation
v0.3.2b
・processing is now basically done by background thread
・added $nodisplay (used for sorting nodes)
peace
Reply #61
not sure to understand ??
nodisplay(str) just display nothing but leave a blank line :S
nothing to do with sort order in the lib view or am i missing something ?
Reply #62
it does what its supposed to do, but kinda like a work around
you will use it in View Format
heres an example for album sort by date added then title sort by play count
$nodisplay(%added%)%album% \ nodisplay(%playcount%)%title%
I think you can understand this without further explanation
Reply #63
ok, i got it, ty nmm
EDIT: .... but it's not really optimized if i use it in the View format, it took a long time to define the list when i use sort in view format (with $nodisplay) and filter ...
Reply #64
maybe its because it's not processed by a lowest priority thread (as stated in the changelog) ?
Reply #65
Thanks for the latest version, the ability to customize sorting in the panel is great. Could we also have the sunken/grey/none border options please?
Reply #66
actually I was meant to say NOW processed by a lowest priority thread
I miss my edit button
@Falstaff
what does the $nodisplay do in "Sort Format" ?
I think it does nothing right?
because Sort Format doesnt display anything
it just sorts the playlist
so I dont think you'll need to use it in Sort Format
correct me if I am wrong
Reply #67
v0.3.2 released, BUT BE CAREFULL, this new build broke my PSS config !!!
after installing this new dll and launching my CUI+PSS+WSH config, all panels deleted in the main PSS !!!
Ssenna, what's the pb, this new version is more than buggus, it is not compatible with PSS at all ... weird...
EDIT: importing fcl file doesn't work anymore, back to 0.3.2b needed to make import fcl working back
Reply #68
mmh had no probs :confused:
Reply #70
Same problem here (on XP).
All panels except WSH Panels and ELPlaylist are deleted...
Reply #71
Same problem (I use fooNight 1.1b)
Reply #72
Sorry, I made a mistake...
I released fixed vesrison.
Reply #73
haha, thought it was my own f'ed up
some but not all of my panels disappeared
i will make sure i backup my stuff from now on
