Topic: [Not My Release] Library Tree (Read 129870 times) previous topic - next topic
Reply #76
Request by @qwertz: Is it possible to add an option to auto expand certain trees? Particular with the playlist tree it's annoying, to have to expand it after every foobar restart. Alternatively, maybe the panel could remember the position of the trees after a restart?
I'd like to get that too, just to make it perfect. For example:
Instead of:
  • Library
  • Playlist
    Maybe that way: (Very much easier for faster opening)
    [-] Library
    ___ [-] Folder  (This folder should be open at start)
    _______
  • Bues
    _______
  • Classic
    _______
  • Jazz
    _______
  • Pop
    _______
  • Rock
    _______
    ___
  • Artist
    ___
  • Album
    ___
    [-] Playlist  (Playlist should be open at start too)
    ______ Default
    ______ Album Library Playlist
    ______ Filter Results
    ______ ...
    BTW, is there a way to change or to add points to the mouse-menue:
    "Send to Active Playlist, Send to Autosend Playlist, Add to ..."?
    Thanks ssenna, really good work!
Reply #77
v0.3.2.2 released => it fixes some rare crash bugs (translated from Ssenna homepage)
thanx Ssenna
Reply #78
Thanks for this component Ssenna, it's probably the best library viewer around. I have a couple of things I'd like to request, if it's not too much trouble I'd be really grateful if you could think about them. The first is the sunken/grey border option I mentioned- really important for me, all my other panels are sunken! I'd also like to be able to customize colours for the selected item and inactive selected item. It would be really great if it could use the CUI colours and fonts panel, so that I could just set it to global mode.
Thanks for all your work so far.
Reply #79
At leaset, Edge Style will be added in the next release.
Reply #80
@ssenna
i like to navigate the library viewer with the arrow keys.  it makes moving into and out of groups much faster.  doing this, i've found some peculiar behavior:
when i move up and down with the arrow keys under the "playlist" header, the active playlist is updated to whichever one i have selected.
when i move up and down with the arrow keys under the "library" header, the active playlist is NOT updated to whichever one i have selected.  i have to actually click the artist, album, etc. for the playlist to be active.  it would be nice for the library header to work just like the playlist header does (recognize using the arrow keys as a single *click*).
Reply #81
Ssenna website info : "v0.3.2.2 will cause crash. so I removed the downloadlink. Please use v0.3.1."
i hope the $nodisplay function will be back soon in a stable version
Reply #82
0.3.1.1 released today :
crash bug fixed and $nodisplay added (like done before in 0.3.2.2 but as said above, 0.3.2.2 cause crashes and the last stable version recommended by Ssenna is 0.3.1.1)
enjoy  and thanx to the developer
Reply #83
To the developer of this plugin,
I have a few feature requests/suggestions for this neat component:
  • Similar to iTunes give the user the ability to create playlist folders within the Playlist node and Autoplaylist node. This would make organization so much easier for those of us with many playlists.
  • Drag 'n drop and reordering of playlists: If the ability to create playlist folders is added, let users drag and drop playlists into folders. Also allow reordering of playlists by dragging playlists into desired location.
  • Reduce the indentation length of the leaf nodes in the playlist navigation pane. Or give the user the option to specify the length of the leaf node indentation in the Panel Preference window. I think this is a pretty good length for indentation...
  • Would it be possible to merge the Playlist and Autoplaylist nodes into one node called "Playlists"?
I think all these suggestions would give this component the same basic functionality that the iTunes playlist navigation pane and the Playlist Tree navigation pane have.
Edit: Fixed typo.
Reply #84
Thanks for the latest version.  It works OK for me, I'll let you know if I have any problems.
Reply #85
0.3.2.3b is fine too here after 2 hours of non-stop music and use
(running under Seven)
Reply #86
a crash on closing foobar due to Library tree  ==> first time it happens since the 2009-06-20
foo_uie_library_tree.dll (2009-06-20 12:43:54)
Library Tree 0.3.2.3b
here is the dump, i hope that's help you Ssenna :
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 03763CC3h
Access violation, operation: read, address: 00004048h
Call path:
thread_task = 3,0=>Modify Library=>Add Library=>Construct Nodes
Code bytes (03763CC3h):
03763C83h:  44 24 14 8B 48 30 8B 54 24 10 8B 0C 91 80 79 04
03763C93h:  00 74 43 85 F6 75 0C 8B 45 0C 50 57 E8 2C FD FF
03763CA3h:  FF EB 33 8B 55 0C 52 51 8B CE 8B D7 E8 8C 00 00
03763CB3h:  00 8B 45 0C 8B 4C 24 14 8B 51 30 50 8B 44 24 14
03763CC3h:  8B 0C 82 57 E8 64 FF FF FF 56 6A 01 68 0A 11 00
03763CD3h:  00 57 FF D3 8B F0 8B 4C 24 14 8B 51 2C 8B 02 83
03763CE3h:  44 24 10 01 83 C1 2C FF D0 39 44 24 10 72 90 85
03763CF3h:  F6 74 3A 56 6A 01 68 0A 11 00 00 57 89 74 24 24
Stack (12B7FB84h):
12B7FB64h:  00200008 00008003 FFFFFD34 000002E4
12B7FB74h:  FFFFFD34 000002CC 00000018 00000000
12B7FB84h:  00000000 00060306 0B6C6008 760855FC
12B7FB94h:  03BBBA90 00001012 03BBBA90 12B7FBC8
12B7FBA4h:  03763CCC 00060306 00000000 00000005
12B7FBB4h:  03B60D30 00000000 00000005 00000001
12B7FBC4h:  03B60BD8 03B60BD8 0376B282 00060306
12B7FBD4h:  00000000 29FB4397 0E6B7F84 12B7FC78
12B7FBE4h:  00000021 12B7FC0C 0379A912 00000001
12B7FBF4h:  0376B481 0000002E 29FB444B 00000000
12B7FC04h:  12B7FC48 0E6B7F70 12B7FC6C 0379AF39
12B7FC14h:  00000000 03768F81 00000011 29FB4433
12B7FC24h:  00000000 00000000 03B85AD8 00000001
12B7FC34h:  03B85AD0 12B7FC50 76E03CF8 03B85AD8
12B7FC44h:  037A132C 00000000 00000000 00000000
12B7FC54h:  00000011 0E6B7F68 0E6B7F70 00000000
12B7FC64h:  03B60D30 12B7FC20 12B7FC94 0379AFF1
12B7FC74h:  00000005 12B7FCA0 037628E7 29FB44EB
12B7FC84h:  00000000 00000000 03B85AD8 12B7FC80
12B7FC94h:  12B7FCCC 037986E0 00000000 12B7FCDC
Registers:
EAX: 00001012, EBX: 760855FC, ECX: 03BBBA90, EDX: 00000000
ESI: 0E35BBA8, EDI: 00060306, EBP: 12B7FBA0, ESP: 12B7FB84
Crash location:
Module: foo_uie_library_tree
Offset: 3CC3h
Loaded modules:
foobar2000                      loaded at 01060000h - 011F9000h
ntdll                            loaded at 76DB0000h - 76EEC000h
kernel32                        loaded at 76340000h - 76414000h
KERNELBASE                      loaded at 751B0000h - 751F8000h
COMCTL32                        loaded at 73E50000h - 73FEC000h
msvcrt                          loaded at 75FC0000h - 7606C000h
GDI32                            loaded at 76B80000h - 76BCE000h
USER32                          loaded at 76070000h - 76139000h
LPK                              loaded at 76F00000h - 76F0A000h
USP10                            loaded at 76140000h - 761DD000h
SHLWAPI                          loaded at 76B20000h - 76B77000h
DSOUND                          loaded at 6B770000h - 6B7E2000h
ADVAPI32                        loaded at 76720000h - 767C0000h
sechost                          loaded at 76F20000h - 76F39000h
RPCRT4                          loaded at 76670000h - 76712000h
ole32                            loaded at 761E0000h - 7633B000h
WINMM                            loaded at 73350000h - 73382000h
POWRPROF                        loaded at 73CE0000h - 73D05000h
SETUPAPI                        loaded at 767F0000h - 7698D000h
CFGMGR32                        loaded at 74FA0000h - 74FC7000h
OLEAUT32                        loaded at 76C50000h - 76CDF000h
DEVOBJ                          loaded at 74F80000h - 74F92000h
SHELL32                          loaded at 75370000h - 75FB6000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 767C0000h - 767EA000h
UxTheme                          loaded at 73CA0000h - 73CE0000h
dbghelp                          loaded at 6EB70000h - 6EC5C000h
COMDLG32                        loaded at 76BD0000h - 76C4B000h
IMM32                            loaded at 75340000h - 7535F000h
MSCTF                            loaded at 76CE0000h - 76DAC000h
CRYPTBASE                        loaded at 74E80000h - 74E8C000h
CLBCatQ                          loaded at 76990000h - 76A13000h
MMDevApi                        loaded at 73930000h - 73969000h
PROPSYS                          loaded at 73D10000h - 73E05000h
dwmapi                          loaded at 738B0000h - 738C3000h
foo_input_std                    loaded at 00EC0000h - 01000000h
foo_uie_biography                loaded at 00980000h - 009CA000h
gdiplus                          loaded at 73B10000h - 73CA0000h
foo_exvar                        loaded at 009D0000h - 009F8000h
foo_masstag                      loaded at 00DA0000h - 00DF0000h
foo_abx                          loaded at 00E00000h - 00E32000h
foo_uie_panel_splitter          loaded at 01000000h - 01058000h
foo_uie_vis_channel_spectrum    loaded at 029D0000h - 02A0D000h
MSIMG32                          loaded at 73450000h - 73455000h
foo_covers                      loaded at 6B580000h - 6B5A7000h
foo_uie_quicksearch              loaded at 02A10000h - 02A56000h
foo_uie_wsh_panel_mod            loaded at 6B4F0000h - 6B578000h
foo_unpack                      loaded at 02BE0000h - 02C0E000h
foo_uie_elplaylist              loaded at 02C10000h - 02C7E000h
foo_rgscan                      loaded at 02DB0000h - 02DFE000h
foo_chronflow                    loaded at 02E00000h - 02E61000h
OPENGL32                        loaded at 6B6A0000h - 6B768000h
GLU32                            loaded at 6B800000h - 6B822000h
DDRAW                            loaded at 603D0000h - 604B7000h
DCIMAN32                        loaded at 6B4B0000h - 6B4B6000h
foo_albumlist                    loaded at 031F0000h - 0324B000h
foo_uie_graphical_browser        loaded at 6B5B0000h - 6B644000h
foo_cdda                        loaded at 03250000h - 03291000h
foo_playcount                    loaded at 03310000h - 03340000h
foo_uie_lyrics                  loaded at 035D0000h - 0362D000h
WININET                          loaded at 76A20000h - 76B12000h
Normaliz                        loaded at 76F10000h - 76F13000h
urlmon                          loaded at 75200000h - 75335000h
CRYPT32                          loaded at 74FD0000h - 750EC000h
MSASN1                          loaded at 74F70000h - 74F7C000h
iertutil                        loaded at 76420000h - 76618000h
foo_uie_library_tree            loaded at 03760000h - 037B6000h
foo_playback_custom              loaded at 03350000h - 03397000h
WINSPOOL                        loaded at 6F0D0000h - 6F121000h
foo_freedb2                      loaded at 037C0000h - 03801000h
foo_utils                        loaded at 6B650000h - 6B694000h
foo_ui_std                      loaded at 041D0000h - 042DE000h
foo_fileops                      loaded at 03900000h - 03946000h
foo_vis_shpeck                  loaded at 6B830000h - 6B86F000h
foo_converter                    loaded at 03950000h - 039BD000h
foo_ui_columns                  loaded at 04720000h - 04889000h
foo_dsp_std                      loaded at 039E0000h - 03A29000h
mscms                            loaded at 60630000h - 606A9000h
USERENV                          loaded at 74560000h - 74577000h
profapi                          loaded at 74F00000h - 74F0B000h
icm32                            loaded at 70250000h - 70288000h
SXS                              loaded at 74E90000h - 74EEF000h
jscript                          loaded at 72AF0000h - 72BA1000h
VERSION                          loaded at 74400000h - 74409000h
CRYPTSP                          loaded at 749B0000h - 749C6000h
rsaenh                          loaded at 74750000h - 7478B000h
RpcRtRemote                      loaded at 74EF0000h - 74EFE000h
WindowsCodecs                    loaded at 73760000h - 73859000h
wshom                            loaded at 702F0000h - 70311000h
MPR                              loaded at 6CC50000h - 6CC62000h
ScrRun                          loaded at 60EF0000h - 60F1A000h
nvoglv32                        loaded at 69500000h - 69EFC000h
explorerframe                    loaded at 61C20000h - 61D8E000h
DUser                            loaded at 742C0000h - 742EF000h
DUI70                            loaded at 739F0000h - 73AA1000h
AUDIOSES                        loaded at 73050000h - 73086000h
SspiCli                          loaded at 74E10000h - 74E2A000h
ws2_32                          loaded at 76FA0000h - 76FD5000h
NSI                              loaded at 75360000h - 75366000h
dnsapi                          loaded at 74830000h - 74874000h
iphlpapi                        loaded at 72FB0000h - 72FCC000h
WINNSI                          loaded at 72FA0000h - 72FA7000h
RASAPI32                        loaded at 73560000h - 735B2000h
rasman                          loaded at 73540000h - 73555000h
rtutils                          loaded at 73530000h - 7353D000h
sensapi                          loaded at 73B00000h - 73B06000h
NLAapi                          loaded at 73230000h - 73240000h
rasadhlp                        loaded at 72E50000h - 72E56000h
ntmarta                          loaded at 73420000h - 73441000h
WLDAP32                          loaded at 76620000h - 76665000h
mswsock                          loaded at 74970000h - 749AC000h
wshtcpip                        loaded at 74490000h - 74495000h
wship6                          loaded at 74960000h - 74966000h
mdnsNSP                          loaded at 16080000h - 160A5000h
winrnr                          loaded at 700A0000h - 700A8000h
napinsp                          loaded at 70090000h - 700A0000h
pnrpnsp                          loaded at 70070000h - 70082000h
fwpuclnt                        loaded at 717F0000h - 71828000h
peerdist                        loaded at 73280000h - 732A5000h
AUTHZ                            loaded at 74B20000h - 74B3B000h
d3d9                            loaded at 71D00000h - 71EC3000h
d3d8thk                          loaded at 71CF0000h - 71CF6000h
Stack dump analysis:
Address: 760855FCh (USER32+155FCh), symbol: "SendMessageW" (+0h)
Address: 03763CCCh (foo_uie_library_tree+3CCCh)
Address: 0376B282h (foo_uie_library_tree+B282h)
Address: 0379A912h (foo_uie_library_tree+3A912h), symbol: "foobar2000_get_interface" (+216D2h)
Address: 0376B481h (foo_uie_library_tree+B481h)
Address: 0379AF39h (foo_uie_library_tree+3AF39h), symbol: "foobar2000_get_interface" (+21CF9h)
Address: 03768F81h (foo_uie_library_tree+8F81h)
Address: 76E03CF8h (ntdll+53CF8h), symbol: "RtlFreeHeap" (+7Eh)
Address: 037A132Ch (foo_uie_library_tree+4132Ch), symbol: "foobar2000_get_interface" (+280ECh)
Address: 0379AFF1h (foo_uie_library_tree+3AFF1h), symbol: "foobar2000_get_interface" (+21DB1h)
Address: 037628E7h (foo_uie_library_tree+28E7h)
Address: 037986E0h (foo_uie_library_tree+386E0h), symbol: "foobar2000_get_interface" (+1F4A0h)
Address: 037628A9h (foo_uie_library_tree+28A9h)
Address: 03779D20h (foo_uie_library_tree+19D20h), symbol: "foobar2000_get_interface" (+AE0h)
Address: 0377CE90h (foo_uie_library_tree+1CE90h), symbol: "foobar2000_get_interface" (+3C50h)
Address: 03779DC5h (foo_uie_library_tree+19DC5h), symbol: "foobar2000_get_interface" (+B85h)
Address: 763910DCh (kernel32+510DCh), symbol: "BaseThreadInitThunk" (+12h)
Address: 76E11E9Eh (ntdll+61E9Eh), symbol: "RtlProcessFlsData" (+D3h)
Address: 763A2AA5h (kernel32+62AA5h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 76DCF1A5h (ntdll+1F1A5h), symbol: "DbgPrint" (+408h)
Address: 76E11E71h (ntdll+61E71h), symbol: "RtlProcessFlsData" (+A6h)
Address: 03779D46h (foo_uie_library_tree+19D46h), symbol: "foobar2000_get_interface" (+B06h)
Address: 010113DEh (foo_uie_panel_splitter+113DEh)
Environment:
App: foobar2000 v0.9.6.8
OS: Windows 6.1.7100 x86
CPU: Intel® Core™2 Duo CPU    E6850  @ 3.00GHz, features: MMX SSE SSE2 SSE3
Audio: Haut-parleurs (Périphérique High Definition Audio); Audio numérique (SPDIF) (Périphérique High Definition Audio)
UI: Columns UI 0.3.7.1
Components:
Core (2009-06-07 14:28:34)
    foobar2000 core 0.9.6.8
foo_abx.dll (2009-05-21 16:57:38)
    ABX Comparator 1.3.4
foo_albumlist.dll (2009-05-21 16:59:10)
    Album List 4.3.1
foo_cdda.dll (2009-05-21 16:58:54)
    CD Audio Decoder 2.1.4
foo_chronflow.dll (2008-04-14 00:16:00)
    Chronial's Coverflow 0.3.0
foo_converter.dll (2009-05-21 16:58:58)
    Converter 1.2.1
foo_covers.dll (2009-04-27 14:19:56)
    Locate Covers 0.03
foo_dsp_std.dll (2009-05-21 16:59:10)
    Standard DSP Array 1.0
foo_exvar.dll (2008-06-14 00:42:56)
    Extended Variables 0.3.1
foo_fileops.dll (2009-05-21 16:57:42)
    File Operations 2.1.2
foo_freedb2.dll (2009-05-21 16:58:00)
    freedb Tagger 0.6.1
foo_input_std.dll (2009-05-21 16:58:46)
    Standard Input Array 1.0
foo_masstag.dll (2007-10-13 16:17:26)
    Masstagger 1.6
foo_playback_custom.dll (2009-04-27 18:35:24)
    Playback Statistics Custom 1.5.1
foo_playcount.dll (2009-04-29 20:09:32)
    Playback Statistics 2.1.9
foo_rgscan.dll (2009-05-21 16:58:30)
    ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2009-05-10 23:28:46)
    Columns UI 0.3.7.1
foo_ui_std.dll (2009-05-21 16:59:16)
    Default User Interface 0.9.5
foo_uie_biography.dll (2009-06-24 23:06:56)
    Biography View 0.3.0.0
foo_uie_elplaylist.dll (2009-06-05 22:01:32)
    ELPlaylist 0.6.5.3.3(beta)
foo_uie_graphical_browser.dll (2008-04-19 21:37:54)
    Graphical Browser rev015
foo_uie_lyrics.dll (2008-12-12 11:39:22)
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_panel_splitter.dll (2009-06-07 22:36:54)
    Panel Stack Splitter 0.3.8(alpha)
foo_uie_quicksearch.dll (2007-05-18 14:31:10)
    Quick Search Toolbar 2.8l
foo_uie_vis_channel_spectrum.dll (2008-05-18 04:02:12)
    Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2009-06-01 18:04:42)
    WSH Panel Mod 1.1.8
foo_unpack.dll (2009-05-21 16:57:34)
    RAR reader 1.2
    ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
    Playlist Tools 0.6.2 beta 6
foo_vis_shpeck.dll (2009-05-21 00:18:26)
    Shpeck - Winamp vis plugins wrapper 0.3.5
Recent events:
itm focus changed
Reply #88
@ssenna
Latest version of this panel. Many many crash reports submitted over the past few days. Most of them seem to happen when I am changing configuration and Library Tree is still updating the tree.
Hope the reports help you in sorting the problem. It's still a greal plugin.
Thanks for all your hard work.
Reply #89
Hi!
Thanx for this PLugin! In my mind its the best Library Viewer at all. Now i have a Follower for my good old "Playist Tree Panel".
But i have a wish  Is it possible to keep the extensions after a restart of Foobar? At the moment its collapsed as soon as i restart Foobar.
Reply #90
@ssenna
Just found a bug with the playlist switcher. When I switch playlists via another panel, quicksearch for example, the last active playlist stays highlighted and I can't switch directly back to that playlist. I first have to activate a different playlist and then switch back.
Seconded, that really is my one big pet peeve with Library Tree, otherwise it's almost perfect.
Reply #91
closing...  thanks.
@ssenna
thanks. I'd like to confirm one question.
Which does changing "configuration" mean Library Tree Page in foobar2000 Preferences or Add/Edit View via contextmenu or Panel Preference via contextmenu?
maybe it's hard.
thanks.
Reply #92
@ssenna
All of the crashes have been via preferences entry and only when Apply\Close is used. Most of my changes have been changing various horizontal and vertical splitters to your pss plugin.
I hope this helps. Please let me know if you want me to try anything for you.
Reply #93
@ssenna
similar ways here ...HTH
Reply #94
Hi Ssenna,
just  to tell you that crash are always present even with the last version 0.3.2.4b
it happens 7 times on 2 days, and each time, the crash report says : "Unable to identify crash location!"
crash happens suddenly, when a track is playing or on track change, or when i edit layout in CUI settings ... etc many ways ... weird.
back to the stable version this morning and no more crash at all after intensive use and coding (PSS/WSH script ... etc)
so it seems that this component is really the cause of the crash encoutered.
I hope you'll find the bug asap
keep the good work and thanx again for your efforts
Reply #95
hum ... always some annoying crash when editing scripts (wsh or pss or preferences when music is playing and track changing) even with 0.3.1.1 (stable version), library view is maybe not the problem, i've to make other tests.
Regards
Reply #96
hum ... always some annoying crash when editing scripts (wsh or pss or preferences when music is playing and track changing) even with 0.3.1.1 (stable version)...
well... Could you post the crash report ?
Reply #97
here is the last one
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0000C385h
Access violation, operation: write, address: 0000C385h
Call path:
entry=>app_mainloop
Stack (001CEE50h):
001CEE30h:  FFFFFFFF 8BC3D5E6 FFFFFD34 000002E4
001CEE40h:  FFFFFD34 000002CC 00000018 00000000
001CEE50h:  763600BE 046E96C0 001CEF0C 0CB54E0C
001CEE60h:  00000000 1494EE98 00000000 76353AC8
001CEE70h:  00000009 00000000 001CEF20 76353F57
001CEE80h:  1494EE98 75960009 049C0002 001CEF0C
001CEE90h:  00000000 0CB54DE4 00000000 00000002
001CEEA0h:  00000000 03C2D974 001CF0DC 001CEF98
001CEEB0h:  03C2D98C 0000000B 049C0002 001CEF68
001CEEC0h:  02520017 001CF0EC 001CEFA4 FFFFFFFF
001CEED0h:  00000000 00334290 0000000B 0000000B
001CEEE0h:  00000001 001CF0DC 03C2D9C0 00000000
001CEEF0h:  FFFFFFFF 0000000A 00000000 00000000
001CEF00h:  00000000 75960009 0CB54DE4 7EFBD443
001CEF10h:  4CB24F6F 2B88EE9E F6CB199B DCB4D34B
001CEF20h:  001CEFB4 76353727 03C2D974 00333CA8
001CEF30h:  00000001 001CF0DC 001CEF98 001CEF68
001CEF40h:  001CEFA4 001CF0EC 00000000 001CF00C
001CEF50h:  00000000 046E7748 00000000 00000000
001CEF60h:  01B54B80 01A60048 01A601B0 1494EDF8
Registers:
EAX: 046E96C0, EBX: 1494EE98, ECX: 678C0065, EDX: 0CB54E0C
ESI: 0CB54E04, EDI: 0CB54DE4, EBP: 001CEE78, ESP: 001CEE50
Loaded modules:
foobar2000                      loaded at 013A0000h - 01539000h
ntdll                            loaded at 772F0000h - 7742C000h
kernel32                        loaded at 75920000h - 759F4000h
KERNELBASE                      loaded at 756A0000h - 756E8000h
COMCTL32                        loaded at 743C0000h - 7455C000h
msvcrt                          loaded at 761C0000h - 7626C000h
GDI32                            loaded at 75CB0000h - 75CFE000h
USER32                          loaded at 75750000h - 75819000h
LPK                              loaded at 75740000h - 7574A000h
USP10                            loaded at 763D0000h - 7646D000h
SHLWAPI                          loaded at 77430000h - 77487000h
DSOUND                          loaded at 68C90000h - 68D02000h
ADVAPI32                        loaded at 75D00000h - 75DA0000h
sechost                          loaded at 774C0000h - 774D9000h
RPCRT4                          loaded at 75DA0000h - 75E42000h
ole32                            loaded at 76060000h - 761BB000h
WINMM                            loaded at 738F0000h - 73922000h
POWRPROF                        loaded at 73DD0000h - 73DF5000h
SETUPAPI                        loaded at 76470000h - 7660D000h
CFGMGR32                        loaded at 754C0000h - 754E7000h
OLEAUT32                        loaded at 76340000h - 763CF000h
DEVOBJ                          loaded at 75720000h - 75732000h
SHELL32                          loaded at 766A0000h - 772E6000h
imagehlp                        loaded at 774E0000h - 7750A000h
UxTheme                          loaded at 74240000h - 74280000h
dbghelp                          loaded at 696C0000h - 697AC000h
COMDLG32                        loaded at 75A00000h - 75A7B000h
IMM32                            loaded at 77490000h - 774AF000h
MSCTF                            loaded at 76270000h - 7633C000h
CRYPTBASE                        loaded at 753C0000h - 753CC000h
CLBCatQ                          loaded at 76610000h - 76693000h
MMDevApi                        loaded at 73F30000h - 73F69000h
PROPSYS                          loaded at 74280000h - 74375000h
dwmapi                          loaded at 73F10000h - 73F23000h
foo_uie_vis_channel_spectrum    loaded at 00270000h - 002AD000h
MSIMG32                          loaded at 73990000h - 73995000h
foo_cdda                        loaded at 011C0000h - 01201000h
foo_freedb2                      loaded at 012A0000h - 012E1000h
foo_exvar                        loaded at 012F0000h - 01318000h
foo_playcount                    loaded at 01D80000h - 01DB0000h
foo_uie_lyrics                  loaded at 01DF0000h - 01E4D000h
WININET                          loaded at 75820000h - 75912000h
Normaliz                        loaded at 77510000h - 77513000h
urlmon                          loaded at 75B70000h - 75CA5000h
CRYPT32                          loaded at 75580000h - 7569C000h
MSASN1                          loaded at 754B0000h - 754BC000h
iertutil                        loaded at 75E60000h - 76058000h
foo_masstag                      loaded at 02BE0000h - 02C34000h
foo_abx                          loaded at 02A30000h - 02A62000h
foo_burninate                    loaded at 02B80000h - 02BC0000h
foo_ui_columns                  loaded at 02F60000h - 030CE000h
gdiplus                          loaded at 740B0000h - 74240000h
foo_uie_graphical_browser        loaded at 68DC0000h - 68E54000h
foo_dsp_std                      loaded at 02D60000h - 02DA9000h
foo_fileops                      loaded at 02DF0000h - 02E36000h
foo_uie_panel_splitter          loaded at 02E40000h - 02E98000h
foo_audioscrobbler              loaded at 02DB0000h - 02DE0000h
WS2_32                          loaded at 75A80000h - 75AB5000h
NSI                              loaded at 774B0000h - 774B6000h
foo_covers                      loaded at 734A0000h - 734C7000h
foo_albumlist                    loaded at 032D0000h - 0332B000h
foo_utils                        loaded at 690A0000h - 690E4000h
foo_convolve                    loaded at 037D0000h - 03821000h
foo_menu_addons                  loaded at 03330000h - 0336C000h
foo_vis_shpeck                  loaded at 73460000h - 7349F000h
foo_input_std                    loaded at 03A80000h - 03BC0000h
foo_chronflow                    loaded at 03830000h - 03891000h
OPENGL32                        loaded at 66CC0000h - 66D88000h
GLU32                            loaded at 73510000h - 73532000h
DDRAW                            loaded at 6C830000h - 6C917000h
DCIMAN32                        loaded at 6D250000h - 6D256000h
foo_playback_custom              loaded at 03600000h - 03647000h
WINSPOOL                        loaded at 6F5D0000h - 6F621000h
foo_ui_std                      loaded at 041B0000h - 042BE000h
foo_unpack                      loaded at 03660000h - 0368E000h
foo_uie_library_tree            loaded at 03BC0000h - 03C13000h
foo_uie_elplaylist              loaded at 03C50000h - 03CBE000h
foo_uie_quicksearch              loaded at 03F10000h - 03F56000h
foo_uie_wsh_panel_mod            loaded at 67860000h - 678EE000h
foo_converter                    loaded at 04110000h - 0417D000h
foo_uie_biography                loaded at 04410000h - 04461000h
foo_rgscan                      loaded at 04580000h - 045CE000h
mscms                            loaded at 6C920000h - 6C999000h
USERENV                          loaded at 74AA0000h - 74AB7000h
profapi                          loaded at 75440000h - 7544B000h
icm32                            loaded at 684F0000h - 68528000h
SXS                              loaded at 753D0000h - 7542F000h
jscript                          loaded at 6C770000h - 6C821000h
VERSION                          loaded at 74940000h - 74949000h
CRYPTSP                          loaded at 74EF0000h - 74F06000h
rsaenh                          loaded at 74C90000h - 74CCB000h
RpcRtRemote                      loaded at 75430000h - 7543E000h
WindowsCodecs                    loaded at 73CC0000h - 73DB9000h
wshom                            loaded at 6BE00000h - 6BE21000h
MPR                              loaded at 6F5B0000h - 6F5C2000h
ScrRun                          loaded at 6C5C0000h - 6C5EA000h
nvoglv32                        loaded at 0A7E0000h - 0B1DC000h
mswsock                          loaded at 74EB0000h - 74EEC000h
DNSAPI                          loaded at 74D70000h - 74DB4000h
Iphlpapi                        loaded at 73250000h - 7326C000h
WINNSI                          loaded at 73240000h - 73247000h
fwpuclnt                        loaded at 71D00000h - 71D38000h
rasadhlp                        loaded at 730E0000h - 730E6000h
wship6                          loaded at 74EA0000h - 74EA6000h
wshtcpip                        loaded at 749D0000h - 749D5000h
explorerframe                    loaded at 6F170000h - 6F2DE000h
DUser                            loaded at 73FC0000h - 73FEF000h
DUI70                            loaded at 73FF0000h - 740A1000h
vis_milk2                        loaded at 08C30000h - 0914F000h
d3d9                            loaded at 6B020000h - 6B1E3000h
d3d8thk                          loaded at 739A0000h - 739A6000h
nvd3dum                          loaded at 6BE60000h - 6C5BC000h
AUDIOSES                        loaded at 736D0000h - 73706000h
SspiCli                          loaded at 75340000h - 7535A000h
RASAPI32                        loaded at 73AA0000h - 73AF2000h
rasman                          loaded at 73A80000h - 73A95000h
rtutils                          loaded at 73A70000h - 73A7D000h
sensapi                          loaded at 6C6F0000h - 6C6F6000h
NLAapi                          loaded at 73750000h - 73760000h
ntmarta                          loaded at 73960000h - 73981000h
WLDAP32                          loaded at 75B20000h - 75B65000h
winrnr                          loaded at 70580000h - 70588000h
napinsp                          loaded at 70570000h - 70580000h
pnrpnsp                          loaded at 70550000h - 70562000h
tiptsf                          loaded at 6E6B0000h - 6E708000h
apphelp                          loaded at 75370000h - 753BB000h
EhStorShell                      loaded at 6ED70000h - 6EDA1000h
cscui                            loaded at 6ED00000h - 6ED6A000h
CSCDLL                          loaded at 6ECF0000h - 6ECF9000h
CSCAPI                          loaded at 6ECE0000h - 6ECEB000h
ntshrui                          loaded at 6EC50000h - 6ECBF000h
srvcli                          loaded at 75090000h - 750A9000h
slc                              loaded at 73630000h - 7363A000h
msls31                          loaded at 6E710000h - 6E739000h
xmllite                          loaded at 73EE0000h - 73F0F000h
shdocvw                          loaded at 6EB30000h - 6EB5D000h
StructuredQuery                  loaded at 707F0000h - 7084C000h
Secur32                          loaded at 75170000h - 75178000h
actxprxy                        loaded at 708B0000h - 708FF000h
ieproxy                          loaded at 6A140000h - 6A16B000h
thumbcache                      loaded at 6EE50000h - 6EE66000h
PSAPI                            loaded at 75E50000h - 75E55000h
ieframe                          loaded at 6DC30000h - 6E6AC000h
OLEACC                          loaded at 73A30000h - 73A6C000h
SearchFolder                    loaded at 691F0000h - 6928E000h
samcli                          loaded at 73BA0000h - 73BAF000h
SAMLIB                          loaded at 74380000h - 74392000h
netutils                        loaded at 73E80000h - 73E89000h
NaturalLanguage6                loaded at 68FD0000h - 69096000h
NLSData000c                      loaded at 68150000h - 683DF000h
NLSLexicons000c                  loaded at 67B50000h - 68144000h
LINKINFO                        loaded at 6EB20000h - 6EB29000h
NetworkExplorer                  loaded at 6D3F0000h - 6D588000h
drprov                          loaded at 69A40000h - 69A48000h
WINSTA                          loaded at 74B60000h - 74B89000h
ntlanman                        loaded at 69A20000h - 69A33000h
davclnt                          loaded at 69A00000h - 69A16000h
DAVHLPR                          loaded at 699F0000h - 699F8000h
wkscli                          loaded at 73BB0000h - 73BBF000h
PortableDeviceApi                loaded at 70740000h - 707C9000h
WINTRUST                        loaded at 756F0000h - 7571D000h
PortableDeviceTypes              loaded at 70180000h - 701AB000h
EhStorAPI                        loaded at 6EA50000h - 6EA72000h
MediaLibraryNSE                  loaded at 15170000h - 151C9000h
MSVCR71                          loaded at 7C340000h - 7C396000h
MFC71U                          loaded at 17600000h - 17702000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
peerdist                        loaded at 73710000h - 73735000h
AUTHZ                            loaded at 75060000h - 7507B000h
avrt                            loaded at 73DC0000h - 73DC7000h
Address: 763600BEh (OLEAUT32+200BEh), symbol: "VarBstrFromUI4" (+A2h)
Address: 76353AC8h (OLEAUT32+13AC8h), symbol: "DispCallFunc" (+263h)
Address: 76353F57h (OLEAUT32+13F57h), symbol: "DispCallFunc" (+6F2h)
Address: 75960009h (kernel32+40009h), symbol: "SetFileInformationByHandle" (+16F4h)
Address: 76353727h (OLEAUT32+13727h), symbol: "LoadRegTypeLib" (+76A7h)
Address: 7730F1A5h (ntdll+1F1A5h), symbol: "DbgPrint" (+408h)
Address: 77343FF7h (ntdll+53FF7h), symbol: "RtlAllocateHeap" (+211h)
Address: 77343E92h (ntdll+53E92h), symbol: "RtlAllocateHeap" (+ACh)
Address: 6786AA5Ch (foo_uie_wsh_panel_mod+AA5Ch)
Address: 6C794F86h (jscript+24F86h), symbol: "DllGetClassObject" (+D02Fh)
Address: 6C792190h (jscript+22190h), symbol: "DllGetClassObject" (+A239h)
Address: 6C794EDAh (jscript+24EDAh), symbol: "DllGetClassObject" (+CF83h)
Address: 6C794E4Dh (jscript+24E4Dh), symbol: "DllGetClassObject" (+CEF6h)
Address: 76355973h (OLEAUT32+15973h), symbol: "LHashValOfNameSysA" (+35Eh)
Address: 0308031Fh (foo_ui_columns+12031Fh), symbol: "foobar2000_get_interface" (+709BFh)
Address: 6C79223Eh (jscript+2223Eh), symbol: "DllGetClassObject" (+A2E7h)
Address: 6C795900h (jscript+25900h), symbol: "DllGetClassObject" (+D9A9h)
Address: 6C792489h (jscript+22489h), symbol: "DllGetClassObject" (+A532h)
Address: 6C7944CFh (jscript+244CFh), symbol: "DllGetClassObject" (+C578h)
Address: 6C770001h (jscript+1h)
Address: 6C794DA3h (jscript+24DA3h), symbol: "DllGetClassObject" (+CE4Ch)
Address: 6C795942h (jscript+25942h), symbol: "DllGetClassObject" (+D9EBh)
Address: 741774DEh (gdiplus+C74DEh), symbol: "GdipCreateSolidFill" (+804CAh)
Address: 7410AA01h (gdiplus+5AA01h), symbol: "GdipCreateSolidFill" (+139EDh)
Address: 74223480h (gdiplus+173480h), symbol: "GdipCreateSolidFill" (+12C46Ch)
Address: 7410B661h (gdiplus+5B661h), symbol: "GdipCreateSolidFill" (+1464Dh)
Address: 75CB6AC3h (GDI32+6AC3h), symbol: "DeleteObject" (+1FDh)
Address: 75CF9100h (GDI32+49100h), symbol: "DdQueryVisRgnUniqueness" (+1D51h)
Address: 75CB698Ch (GDI32+698Ch), symbol: "DeleteObject" (+C6h)
Address: 75CB6A4Fh (GDI32+6A4Fh), symbol: "DeleteObject" (+189h)
Address: 7414A0AAh (gdiplus+9A0AAh), symbol: "GdipCreateSolidFill" (+53096h)
Address: 6C780001h (jscript+10001h)
Address: 6C7857C3h (jscript+157C3h)
Address: 6C8068E4h (jscript+968E4h), symbol: "DllRegisterServer" (+1A223h)
Address: 6C79441Eh (jscript+2441Eh), symbol: "DllGetClassObject" (+C4C7h)
Address: 6C784D16h (jscript+14D16h)
Address: 760A5641h (ole32+45641h), symbol: "CoSetState" (+904h)
Address: 6C79437Ch (jscript+2437Ch), symbol: "DllGetClassObject" (+C425h)
Address: 760B3749h (ole32+53749h), symbol: "CoRevokeInitializeSpy" (+80D0h)
Address: 760A5669h (ole32+45669h), symbol: "CoSetState" (+92Ch)
Address: 6C78643Bh (jscript+1643Bh)
Address: 6C7971CCh (jscript+271CCh), symbol: "DllGetClassObject" (+F275h)
Address: 6C783CF8h (jscript+13CF8h)
Address: 7410AA9Ch (gdiplus+5AA9Ch), symbol: "GdipCreateSolidFill" (+13A88h)
Address: 7412596Eh (gdiplus+7596Eh), symbol: "GdipCreateSolidFill" (+2E95Ah)
Address: 741259E2h (gdiplus+759E2h), symbol: "GdipCreateSolidFill" (+2E9CEh)
Address: 6C795B4Dh (jscript+25B4Dh), symbol: "DllGetClassObject" (+DBF6h)
Address: 6C783B65h (jscript+13B65h)
Address: 6C77F9FFh (jscript+F9FFh)
Address: 6C77F94Ah (jscript+F94Ah)
Address: 6C783F55h (jscript+13F55h)
Address: 7601118Eh (iertutil+1B118Eh), symbol: "Ordinal57" (+3BBD4h)
Address: 6C78417Bh (jscript+1417Bh)
Address: 6C77D5E6h (jscript+D5E6h)
Address: 67868ED8h (foo_uie_wsh_panel_mod+8ED8h)
Address: 678C788Ch (foo_uie_wsh_panel_mod+6788Ch), symbol: "foobar2000_get_interface" (+428BCh)
Address: 6786A3B5h (foo_uie_wsh_panel_mod+A3B5h)
Address: 678CA7FCh (foo_uie_wsh_panel_mod+6A7FCh), symbol: "foobar2000_get_interface" (+4582Ch)
Address: 678C3868h (foo_uie_wsh_panel_mod+63868h), symbol: "foobar2000_get_interface" (+3E898h)
Address: 678695B5h (foo_uie_wsh_panel_mod+95B5h)
Address: 757651FBh (USER32+151FBh), symbol: "IsDialogMessageW" (+30Ch)
Address: 7576CE73h (USER32+1CE73h), symbol: "OffsetRect" (+62h)
Address: 757B98D8h (USER32+698D8h), symbol: "gSharedInfo" (+498h)
Address: 7576526Fh (USER32+1526Fh), symbol: "DefWindowProcW" (+6Bh)
Address: 757B62DDh (USER32+662DDh), symbol: "IsWow64Message" (+49h)
Address: 678693D9h (foo_uie_wsh_panel_mod+93D9h)
Address: 757642F0h (USER32+142F0h), symbol: "wsprintfA" (+306h)
Address: 7576630Ch (USER32+1630Ch), symbol: "GetWindowLongW" (+2Bh)
Address: 75766318h (USER32+16318h), symbol: "GetWindowLongW" (+37h)
Address: 678C4DC3h (foo_uie_wsh_panel_mod+64DC3h), symbol: "foobar2000_get_interface" (+3FDF3h)
Address: 678AC325h (foo_uie_wsh_panel_mod+4C325h), symbol: "foobar2000_get_interface" (+27355h)
Address: 7576C6C2h (USER32+1C6C2h), symbol: "gapfnScSendMessage" (+1FAh)
Address: 75766101h (USER32+16101h), symbol: "SetPropW" (+DBh)
Address: 678AC190h (foo_uie_wsh_panel_mod+4C190h), symbol: "foobar2000_get_interface" (+271C0h)
Address: 7576C743h (USER32+1C743h), symbol: "gapfnScSendMessage" (+27Bh)
Address: 7576502Ch (USER32+1502Ch), symbol: "IsDialogMessageW" (+13Dh)
Address: 7575DFB3h (USER32+DFB3h), symbol: "SystemParametersInfoW" (+11Eh)
Address: 75765089h (USER32+15089h), symbol: "IsDialogMessageW" (+19Ah)
Address: 7733817Eh (ntdll+4817Eh), symbol: "KiUserCallbackDispatcher" (+2Eh)
Address: 77338130h (ntdll+48130h), symbol: "KiUserApcDispatcher" (+48h)
Address: 75764FE1h (USER32+14FE1h), symbol: "IsDialogMessageW" (+F2h)
Address: 75765FA2h (USER32+15FA2h), symbol: "FillRect" (+67h)
Address: 75765FB5h (USER32+15FB5h), symbol: "FillRect" (+7Ah)
Address: 7576CF98h (USER32+1CF98h), symbol: "GetMessageW" (+0h)
Address: 7596F0DDh (kernel32+4F0DDh), symbol: "SetLastError" (+0h)
Address: 7576CE9Dh (USER32+1CE9Dh), symbol: "DispatchMessageW" (+Fh)
Address: 757666F9h (USER32+166F9h), symbol: "PeekMessageW" (+0h)
Address: 013FCBBDh (foobar2000+5CBBDh)
Address: 10002657h (shared+2657h), symbol: "uPrintCrashInfo_OnEvent" (+B0h)
Address: 014D7620h (foobar2000+137620h)
Address: 013FD959h (foobar2000+5D959h)
Address: 76840DA0h (SHELL32+1A0DA0h), symbol: "SHGetFileInfo" (+9D57h)
Address: 77343DE6h (ntdll+53DE6h), symbol: "RtlAllocateHeap" (+0h)
Address: 014D0604h (foobar2000+130604h)
Address: 014E139Ch (foobar2000+14139Ch)
Address: 013A0000h (foobar2000+0h)
Address: 014E1380h (foobar2000+141380h)
Address: 01502CA0h (foobar2000+162CA0h)
Address: 014A1BABh (foobar2000+101BABh)
Address: 014A8E64h (foobar2000+108E64h)
Address: 014A4E00h (foobar2000+104E00h)
Address: 014A735Ch (foobar2000+10735Ch)
Address: 03000300h (foo_ui_columns+A0300h)
Address: 014A2298h (foobar2000+102298h)
Address: 014D7644h (foobar2000+137644h)
Address: 014C07B2h (foobar2000+1207B2h)
Address: 1000269Ah (shared+269Ah), symbol: "uCallStackTracker::uCallStackTracker" (+2Fh)
Address: 013FDB9Eh (foobar2000+5DB9Eh)
Address: 014C8000h (foobar2000+128000h)
Address: 013B0136h (foobar2000+10136h)
Address: 014A20F6h (foobar2000+1020F6h)
Address: 014A210Ah (foobar2000+10210Ah)
Address: 014C0A35h (foobar2000+120A35h)
Address: 014A2C5Ch (foobar2000+102C5Ch)
Address: 014AA527h (foobar2000+10A527h)
Address: 759710DCh (kernel32+510DCh), symbol: "BaseThreadInitThunk" (+12h)
Address: 77351E9Eh (ntdll+61E9Eh), symbol: "RtlProcessFlsData" (+D3h)
Address: 76840F78h (SHELL32+1A0F78h), symbol: "SHGetFileInfo" (+9F2Fh)
Environment:
UI: Columns UI 0.3.7.8
Components:
    Album List 4.3.1
foo_audioscrobbler.dll (2008-03-09 20:08:02)
    Audioscrobbler 1.3.16
foo_burninate.dll (2009-06-21 23:17:14)
    Audio CD Writer 3.0
    Converter 1.2.1
foo_convolve.dll (2006-08-04 21:57:26)
    Convolver 0.3
    Locate Covers 0.03
    freedb Tagger 0.6.1
foo_masstag.dll (2009-06-21 23:04:00)
    Masstagger 1.8.2
foo_menu_addons.dll (2009-01-05 21:44:56)
    Menu Addons 0.4.1 (SSE)
foo_ui_columns.dll (2009-06-15 00:18:06)
    Columns UI 0.3.7.8
foo_uie_biography.dll (2009-07-18 19:42:50)
    Biography View 0.3.2.1
foo_uie_library_tree.dll (2009-06-11 00:08:06)
    Library Tree 0.3.1.1
foo_uie_wsh_panel_mod.dll (2009-07-12 05:44:54)
    WSH Panel Mod 1.1.9
    RAR reader 1.2
    ZIP/GZIP reader 1.0
Recent events:
itm focus changed
itm focus changed
itm focus changed
itm focus changed
Opening track for playback: "Z:\MP3\P\Paco De Lucia\Discographie\35 Paco De Lucia Al Di Meola & MCLaughlin  - 1996 - The Guitar Trio -\Paco De Lucia & Al Di Meola & Mclaughlin - 01 - La Estiba.mp3"
itm focus changed
itm focus changed
itm focus changed
itm focus changed
Reopening played file after update: "Z:\MP3\P\Paco De Lucia\Discographie\35 Paco De Lucia Al Di Meola & MCLaughlin  - 1996 - The Guitar Trio -\Paco De Lucia & Al Di Meola & Mclaughlin - 01 - La Estiba.mp3"
Reply #98
Thank you.
humm...
sorry, I can't identify where the crash occurred, too.
(the crash of this report might have been caused by foo_uie_wsh_panel_mod or jscript... I'm not sure)
Reply #99
"the crash of this report might have been caused by foo_uie_wsh_panel_mod or jscript... I'm not sure"
What makes you say that?
