Topic: [Not My Release] Library Tree (Read 129311 times) previous topic - next topic
Reply #100
The stack trace. That said, the associated .dmp file could say more.
Reply #102
Here I report some sorting problem with the library tree.
Actually, I report this problem in other thread 'Xchange v3' because I use 'Xchange v3' theme with my foobar.
Please refer to http://www.hydrogenaudio.org/forums/index....st&p=650267
When I use the library tree version 'v0.3.2.5b', the above strange sorting happens for some of my cue files.
So, I tried to change the library tree component with the stable version v0.3.1.1.
And, I found that the weird sorting problem disappears.
So, I guess that there is some problem with the v0.3.2.5b in the sorting function for cue files.
I hope that the developer of this nice component can fix this problem in the next update.
Reply #103
Is there any way I can get it to remeber the state in which I left it in when closing foobar? eg, not always start with every view collapised?
Reply #104
@ssenna
Is it be possible to make %<artist>% also available for $nowplaying{}. It would be much appreciated.
Reply #105
@Ssenna:
are there any plans for:
- adding option for vertical item padding
- option to hide horizontal (maybe also vertical) scroll bar
- more options for color customization: e.g. background color for selected items instead of the ugly windows thing (best would be a plain square to the whole width of the panel starting from the first letter of item)
- option to hide the expand/collapse arrow
- save state when closing foobar
in other words: options to get rid of most ugly windows things?
Reply #106
it may be possible, but might be difficult. I will add if possible
yes (if possible)
yes (if possible)
no
no
no (at least, state of whole tree)
Reply #107
Thank you ssenna.
I also just noticed a bug. %<album artist>% doesn't work correctly, if only the %artist% field is present.
Reply #108
yes (if possible)
yes (if possible)
no
no
anyway, good news! Thank you!
For the save state I can imagine it´s difficult to implement. Maybe only an option to decide, which branches of the tree should be expanded when opening foobar? (for me it´s e.g. that I only use artist extensively)
Reply #109
Nice Plugin! Just discovered it.
A few questions though:
Is it possible to:
- name a view dynamicaly after the active Playlist?
- highlight the things you select with the view in the playlist automaticly?
- play selected by double-clicking?
- remove selected from active playlist by pressing 'del'?
Thanks in advance!
Reply #110
hello, i´ve been using this string
$if(%disc%,CD %disc%)|
in album list panels and it was working ok. when album had two discs, it showed new subitem otherwise it didnt. but sadly it doesnt work here. any help please?
thank you
Reply #111
Try [\CD %disc%] -the \ creates a new level, and the [] tells it to do so only if %disc% exists.
Reply #113
Hi!
How to create one library view, provided it be possible, if files to be located on different HD or folders?
for example: to have got media library d:\usr\usr_music\general\, d:\usr\usr_music\classical\, d:\usr\usr_music\jazz\, e:\mmedia\soundtrack\ -> 1view for d:\usr\usr_music\general & e:\mmedia\soundtrack
thnx)
Reply #114
filter query format:
%path% HAS d:\usr\usr_music\general
etc. should do it
Reply #115
I've been scrolling around but i can't seem to find an answer. Is it possible to implement a filter textfield much like the default UI library tree has?
Reply #116
@Ssenna:
If the remember state option won't be implemented, could we hope for the expand on start option for the Views?
It's not that the state is important, it's the need to expand it each and every time to the most common state that is inconvenient atm.
P.S. It's a pity that other customization options (esp. the selection bg color) is not on your list.
Reply #117
is there anyone who knows the solution for the above problem?
I still have the same problem in the most recent library tree version(V0.3.2.6b).
Reply #118
Could you try to clear "Sort format when sending..."  form in a view_setting?
Reply #119
Thank you, ssena.
With your instruction, I finally solved the problem.
Moderation: Removed useless full quote of the preceding post.
Reply #120
I wanted to make something like a missing tags submenu and got stuck with this string:
$if(%tracknumber%,,Tracknumber Missing\$replace(%relative_path%,\%filename_ext%\,))
$if(%replaygain_track_gain%,,Gain Missing\$replace(%relative_path%,\%filename_ext%\,))
$if(%date%,,Date Missing\$replace(%relative_path%,\%filename_ext%\,))
$if(%album%,,Album Missing\$replace(%relative_path%,\%filename_ext%\,))
$if(%title%,,Title Missing\$replace(%relative_path%,\%filename_ext%\,))
There are two (or more) problems with it:
1. %title% displays filename when field is not present.
2. pasting the hole string into the "view format" field
executes one function after another.
How can I do this properly?
Reply #121
Could someone please point me into the right direction?
I've tried everything but still no luck.
Thx in advance
Reply #122
$meta(title)
$meta(artist)
actually checks for tags rather than using the various fallback mechanisms.
Reply #123
thx for your answer to my first problem!
works just fine...
Any ideas for the second one?
Thx again!
Reply #124
@Ssenna:
I have a few feature requests.
1. Is it possible to add an option to bold the playing playlist. Or have the playing playlist automatically highlighted when its focus changes to another.
2. Have the option to make the Playlist node auto-expand on start-up.
3. Option to sort the playlists in the Playlist node by alphabetical order.
