Topic: Columns UI appearance (Read 3306244 times) previous topic - next topic
Reply #1875
Here's my first attempt a a skin.
Code mostly borrowed from the ZiX skin.
Not the prettiest but works the way I like it.
Reply #1876
I really like your config would it be possible to share it?
Reply #1877
I have uploaded it to: http://www.mediafire.com/?2824eoqn5g55h62
put the skins folder in the foobar directory then import the fcl file into columns UI.
All the components needed should be in the components folder if you need them. The code is a bit messy as it was mostly trial and error.
Reply #1878
Awesome thanks for your time
Reply #1879
Few days ago stumbled across lastFoodly by kabuki here and I'm very impressed with the overall design. It really changes the way I browse my music library and playlist. The code is simply brilliant and I never thought that EL Playlist grouping format can be so advanced. Took me some time to understand the code but thanks to the modularity I managed to pick up fast. Here's the final result of the mod to suit my browsing and listening experience:
Changes:
- Dark theme. I like dark, it's easy to the eyes and save energy (I think I read about this somewhere).
- Slightly larger font size. I hate having to squint my eyes.
- Right panel menu.
- Additional playlist view, NG Playlist.
- Album info dual panel.
- More information in Albums Flow (look nice when displayed in large screen)
- Additional grouping format in EL Playlist for Group (useful for browsing anime and game by their represented title).
- Lyrics indicator checks both %LYRIC% tag and external file path for .lrc and .txt.
- Dual language support in LCD. (useful for displaying foreign artist and title, which I have a lot)
- Full integration with customdb (e.g. play_count)
- Additional buttons menu here and there.
Images:
[a href="http://s179.photobucket.com/albums/w306/DeoxySynchro89/foobar/?action=view&current=11Jun211521.jpg" target="_blank"]
Reply #1881
Few days ago stumbled across lastFoodly by kabuki here and I'm very impressed with the overall design. […] Took me some time to understand the code but thanks to the modularity I managed to pick up fast. Here's the final result of the mod to suit my browsing and listening experience:
Changes:
i been using the original version and i always wanted a black version of it
Would you mind share it ? please?
Reply #1882
Sure, but before that there will be some code cleanup that I will need to do.
Reply #1883
Few days ago stumbled across lastFoodly by kabuki […] Here's the final result of the mod to suit my browsing and listening experience:
Changes:
Images:
Simply magnifient ! I was addicted to lastFoodly configuration and I'll try to add some changes but I'm not skilled enough for that job. Last time I had to install my PC, I lost this configuration and it's quite hard to install Kakubi's configuration in a non portable version.
Can I ask you to share this version ? I wish I can test it and install it. Thx a lot in advance !
Reply #1884
Here's my second confiq which is just an improvement to my first. Biggest changes are using of space, and playlist view.
I think that I've brought this appearance so far that I start making whole new config to myself after I'm bored to this. Dunno what kind of though, so I'll be lurking this thread more or less to get innovations.
Reply #1885
I wanted something that
a) had flexibility
b) was really quick (some skins are pretty but painfully slow with large collections, a big no no)
c) looked decent with default aero-theme
In the end, this is what I came up with:
The three panels are all the same mod, a modified version of marc2003's last.fm-info wsh panel. I use the meta data to create auto playlists of my own library. Really good for finding those fantastic songs you've downloaded but never bothered to listen to!
The two arrows in the top left corner changes between playlists, something that I found really useful but, sadly, hard to find in other designs.
Reply #1886
spyboda, can you post your modified wsh panel script for the autoplaylists generated from your library?
Reply #1887
Sure, here you go:
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common4.js"
// @name "Last.fm"
// @author "marc2003 (modified by kimgronqvist)"
// @feature "v1.4"
// @feature "watch-metadb"
// ==/PREPROCESSOR==
var script_name = "Last.fm";
var username_file = settings_path + "username";
var username = read(username_file);
var api_key_file = settings_path + "api_key";
var api_key = read(api_key_file);
var lfm_img = gdi.Image(images_path + "lastfm_red_small.gif");
var spotify_img = gdi.Image(images_path + "spotify.png");
var lastfm_play_img = gdi.Image(images_path + "lastfm_play.png");
var auto_img = gdi.Image(images_path + "search_small.png");
var up_img = gdi.Image(images_path + "up.png");
var down_img = gdi.Image(images_path + "down.png");
var text_x = 6;
var but_x = 0;
var offset = 0;
var rows = 0;
var items = 0;
var artist = "";
var folder = "";
var g_text = "";
var names = [];
var names_c = [];
var names_widths = [];
var all_width;
var urls = [];
var methods = ["artist.getSimilar", "artist.getTopTags", "artist.getTopFans", "artist.getTopAlbums", "artist.getTopTracks"];
var nice_lastfm_types = ["similar artists", "top tags", "top fans", "top albums", "top tracks"];
var g_tooltip = window.CreateTooltip();
var link = window.GetProperty("link", "spotify");
var lastfm_type = window.GetProperty("lastfm_type", 0);
var lastfm_artist = window.GetProperty("lastfm_artist", "%artist%");
var pause = window.GetProperty("pause", true);
on_item_focus_change();
function on_notify_data(name, data) {
if (name == "lastfm_update" && data == 1) {
artist = Date();
function on_size() {
ww = window.Width;
wh = window.Height;
but_x = Math.round((ww - 15) / 2);
offset = 0;
rows = Math.floor((wh - 58) / 20);
up_btn = new sb(but_x, 32, 15, 15, up_img, "offset > 0", function() { on_mouse_wheel(1); });
down_btn = new sb(but_x, wh - 15, 15, 15, down_img, "offset < items - rows", function() { on_mouse_wheel(-1); });
function on_paint(gr) {
gr.FillSolidRect(0, 0, ww, wh, g_backcolor);
switch(true) {
case username.length == 0:
case api_key.length != 32:
gr.GdiDrawText("Please use the context menu to set your Last.fm username and API KEY.", normal_font, g_textcolor, 10, 0, ww - 20, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
case !g_metadb:
gr.GdiDrawText("[no selection]", normal_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
break;
default:
gr.GdiDrawText(nice_lastfm_types[lastfm_type], title_font, g_textcolor_hl, 6, 6, ww - 77, 24, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
//gr.DrawImage(lfm_img, ww - 60, 8, 50, 18, 0, 0, 50, 18);
gr.DrawLine(5, 29, ww - 10, 29, 1, g_textcolor_hl);
if (items == 0) {
gr.GdiDrawText("[no data]", normal_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
} else {
gr.GdiDrawText("[ALL]", list_font, g_textcolor, text_x, 32, ww - 36, 18, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
for (i = 0; i < Math.min(rows, items); i++) {
//if (lastfm_type == 0) gr.DrawImage(link == "spotify" ? spotify_img : link == "lastfm" ? lastfm_play_img : auto_img, 6, 45 + (i * 20), 20, 20, 0, 0, 20, 20);
gr.GdiDrawText(names[i + offset], list_font, g_textcolor, text_x, 52 + (i * 20), ww - 36, 18, DT_VCENTER | DT_END_ELLIPSIS | DT_CALCRECT | DT_NOPREFIX);
up_btn.draw(gr);
down_btn.draw(gr);
function on_playback_dynamic_info_track() {
function on_playback_stop() {
if (!g_metadb) return;
my_metadb_changed(lastfm_artist, function() { load(); });
function load() {
names = [];
names_widths = [];
urls = [];
data = [];
offset = 0;
items = 0;
text_x = 6;
if (!fso.FolderExists(folder)) fso.CreateFolder(folder);
filename = folder + "\\" + methods[lastfm_type] + ".json";
if (fso.fileExists(filename)) {
file = fso.Getfile(filename);
ts = fso.OpenTextFile(filename, 1, false, -1);
g_text = ts.ReadAll();
ts.close();
parsed_data = JSON.parse(g_text);
switch(true) {
case parsed_data.error > 0:
fb.trace(script_name + ": " + g_text);
break;
case lastfm_type == 0 && typeof parsed_data.similarartists.artist == "object":
//text_x = 30;
data = parsed_data.similarartists.artist;
break;
case lastfm_type == 1 && typeof parsed_data.toptags.tag == "object":
data = parsed_data.toptags.tag;
break;
case lastfm_type == 2 && typeof parsed_data.topfans.user == "object":
data = parsed_data.topfans.user;
break;
case lastfm_type == 3 && typeof parsed_data.topalbums.album == "object":
data = parsed_data.topalbums.album;
break;
case lastfm_type == 4 && typeof parsed_data.toptracks.track == "object":
data = parsed_data.toptracks.track;
break;
items = data.length;
var temp_bmp = gdi.CreateImage(1, 1);
var temp_gr = temp_bmp.GetGraphics();
for (i = 0; i < items; i++) {
names[i] = data[i].name;
urls[i] = data[i].url;
names_widths[i] = temp_gr.CalcTextWidth(names[i], list_font);
all_width = temp_gr.CalcTextWidth("[ALL]", list_font);
temp_bmp.ReleaseGraphics(temp_gr);
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
if (Date.parse(Date()) - Date.parse(file.DateLastModified) > 86400000) get();
} else {
get();
window.Repaint();
function get() {
var fn = filename;
lastfm("&method=" + methods[lastfm_type] + "&artist=" + encodeURIComponent(artist), "foo_wsh_lastfm_similar", function() { save(xmlhttp.responsetext, fn); load(); });
function on_mouse_wheel(delta) {
if (items < rows) return;
offset -= delta * 3;
if (offset < 0) offset = 0;
if (rows + offset > items) offset = items - rows;
window.Repaint();
index = Math.floor((y - 45 ) / 20) + offset;
in_range = index >= offset && index < Math.min(offset + rows, items);
switch(true) {
case !g_metadb:
return;
//case lastfm_type == 0 && link == "spotify" && in_range && x > 6 && x < 26:
// tt('spotify:search:"' + names[index].replace(/\s+/g,"+") + '"');
// window.SetCursor(IDC_HAND);
// break;
// case lastfm_type == 0 && link == "lastfm" && in_range && x > 6 && x < 26:
// tt("Last.fm radio: " + names[index]);
// break;
// case lastfm_type == 0 && link == "auto" && in_range && x > 6 && x < 26:
// tt("Autoplaylist: " + names[index]);
// break;
//text_x, 32, ww - 36, 18,
case y > 32 && y < 50 && x > text_x && x < text_x + all_width:
//tt(urls[index]);
tt("Autoplaylist: Everything");
break;
case in_range && x > text_x && x < text_x + names_widths[index]:
//tt(urls[index]);
break;
case up_btn.trace(x, y):
case down_btn.trace(x, y):
break;
default:
window.SetCursor(IDC_ARROW);
g_tooltip.Text = "";
g_tooltip.Deactivate();
break;
switch(true) {
case !g_metadb:
return;
// case lastfm_type == 0 && link == "spotify" && in_range && x > 6 && x < 26:
// try {
// WshShell.run('spotify:search:"' + names[index].replace(/\s+/g,"+") + '"');
// if (fb.IsPlaying && !fb.IsPaused && pause) fb.Pause();
// } catch(e) {
// MsgBox("Unable to launch Spotify.", 0, script_name);
// break;
// if (!utils.CheckComponent("foo_lastfm_radio", true)) return(MsgBox("foo_lastfm_radio is not installed.", 0, script_name));
// try { WshShell.run("lastfm://artist/" + names[index].replace(/\s+/g,"+") + "/similarartists"); } catch(e) { MsgBox('Unable to launch last.fm radio. Check foobar is set as the default handler for the lastfm:// protocol. Use the "Manage file type associations" tool found under File>Preferences>Shell Integration.', 0, script_name); }
// break;
// fb.CreateAutoPlaylist(fb.PlaylistCount, names[index], "artist HAS " + names[index]);
// fb.ActivePlaylist = fb.PlaylistCount - 1;
// break;
playlist_name = "#Search";
            i = 0;
            while(i < fb.PlaylistCount) {
                if (fb.GetPlaylistName(i) == playlist_name) fb.RemovePlaylist(i);
                else i++;
switch(true) {
case lastfm_type == 0:
var auto_search = "artist IS " + names[0];
for (i = 1; i < items; i++) {
auto_search += " OR artist IS " + names[i];
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, auto_search);
break;
case lastfm_type == 1:
var auto_search = "genre IS " + names[0] + " OR style IS " + names[0];
auto_search += " OR genre IS " + names[i] + " OR style IS " + names[i];
break;
case lastfm_type ==  2:
try { WshShell.run(urls[0]); } catch(e) { MsgBox("Unable to launch your default browser.", 0, script_name); }
break;
case lastfm_type == 3:
var auto_search = "(album IS " + names[0];
auto_search += " OR album IS " + names[i];
auto_search += ") AND artist IS " + artist;
break;
case lastfm_type == 4:
var auto_search = "(title IS " + names[0];
auto_search += " OR title IS " + names[i];
break;
break;
//try { WshShell.run(urls[index]); } catch(e) { MsgBox("Unable to launch your default browser.", 0, script_name); }
//break;
            i = 0;
                else i++;
switch(true) {
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, "artist HAS " + names[index]);
break;
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, "genre HAS " + names[index] + " OR style HAS " + names[index]);
break;
break;
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, "album HAS " + names[index] + " AND artist IS " + artist);
break;
fb.CreateAutoPlaylist(fb.PlaylistCount, playlist_name, "title HAS " + names[index] + " AND artist IS " + artist);
break;
            break;
up_btn.click(x, y);
break;
down_btn.click(x, y);
break;
function on_mouse_rbtn_up(x, y) {
var _menu = window.CreatePopupMenu();
var _links = window.CreatePopupMenu();
var _selection = window.CreatePopupMenu();
var _panel = window.CreatePopupMenu();
var idx;
_menu.AppendMenuItem(username.length > 0 && api_key.length == 32 && g_metadb ? MF_STRING : MF_GRAYED, 1, "Update");
_menu.AppendMenuSeparator();
_menu.AppendMenuItem(MF_STRING, 8, "Artist field remapping...");
for (i = 0; i < nice_lastfm_types.length; i++) {
_panel.AppendMenuItem(MF_STRING, 30 + i, nice_lastfm_types[i]);
_panel.CheckMenuRadioItem(30, 34, lastfm_type + 30);
_panel.AppendTo(_menu, MF_STRING, "Panel");
if(lastfm_type == 0) {
_menu.AppendMenuItem(link == "spotify" ? MF_STRING : MF_GRAYED, 7, "Pause playback when launching Spotify");
_menu.CheckMenuItem(7, pause);
_links.AppendMenuItem(MF_STRING, 4, "Spotify");
_links.AppendMenuItem(MF_STRING, 5, "Last.fm radio");
_links.AppendMenuItem(MF_STRING, 6, "Autoplaylist");
_links.CheckMenuRadioItem(4, 6, link == "spotify" ? 4 : link == "lastfm" ? 5 : 6);
_links.AppendTo(_menu, MF_STRING, "Buttons");
_selection.AppendMenuItem(MF_STRING, 900, "Use display preferences");
_selection.AppendMenuItem(MF_STRING, 901, "Prefer now playing");
_selection.AppendMenuItem(MF_STRING, 902, "Follow selected track");
_selection.CheckMenuRadioItem(900, 903, selection_mode + 900);
_selection.AppendTo(_menu, MF_STRING, "Selection mode");
_menu.AppendMenuItem(MF_STRING, 2, "Set your Last.fm username...");
_menu.AppendMenuItem(MF_STRING, 3, "Set your API KEY...");
if (utils.IsKeyPressed(0x10)) _menu.AppendMenuItem(MF_STRING, 9, "Properties");
_menu.AppendMenuItem(MF_STRING, 10, "Configure...");
idx = _menu.TrackPopupMenu(x, y);
switch(idx) {
case 1:
get();
break;
case 2:
set_username();
artist = Date();
break;
case 3:
set_api_key();
artist = Date();
break;
case 4:
case 5:
case 6:
link = idx == 4 ? "spotify" : idx == 5 ? "lastfm" : "auto";
window.SetProperty("link", link);
window.Repaint();
break;
case 8:
lastfm_artist = InputBox("Enter a tag that should be used to query Last.fm. The default is %artist%\n\nYou can use full foobar title formatting syntax to make it conditional.", script_name, lastfm_artist);
if (lastfm_artist == "") lastfm_artist = "%artist%";
window.SetProperty("lastfm_artist", lastfm_artist);
break;
case 7:
pause = !pause;
window.SetProperty("pause", pause);
break;
case 9:
window.ShowProperties();
break;
case 10:
window.ShowConfigure();
break;
case 30:
case 31:
case 32:
case 33:
case 34:
lastfm_type = idx - 30;
window.SetProperty("lastfm_type", lastfm_type);
artist = Date();
break;
case 900:
case 901:
case 902:
selection_mode = idx - 900;
window.SetProperty("selection_mode", selection_mode);
break;
_panel.Dispose();
_selection.Dispose();
_menu.Dispose();
_links.Dispose();
return true;
Reply #1888
spyboda - That's pretty ingenious!  I've already put this to great use!
Reply #1889
Does anyone know how to overlay an image on top of a panel in columnsUI? I can't stand the ugly grey playlist tabs but I don't want to give up their functionality. Is there anyway to do this in WSH panel mod? Or is there anyway to change the color/colour?
If I could overlay a grey image it would look like this, much better.
Reply #1890
Wow that dark theme is amazing! I really like the overall style! Please share this I want to try this NOW!
Forget the Anime Banner this is already awesome , you can't beat awesome!
Reply #1891
foonate skin
Reply #1892
Not been here for a while so I thought I'd show you what I'm using. It's a mashup of mnlt2 and Br3tts latest configs. So props go to the original creators.
out of topic but what visual style is that?
Reply #1894
Under construction.
mad messy misanthropist morbid mused
Reply #1896
Thanks that's a pretty constructive comments. I had been busy playing with my new phone recently. Will share it as soon as I could, probably due this week  Hope the final code is user-friendly enough.
Reply #1898
not finished yet
I love this theme. Would you mind posting it for download, would love to try it out.
Reply #1899
Simple theme with large fonts meant for HTPC screens (55" TV) and DPI scaling.
