Topic: Columns UI appearance (Read 1508575 times) previous topic - next topic
  • derty2
Reply #1825
If you are having problems sorting the items in the playlist, read this post ---> here <---
Reply #1826
Reply #1827
Hi guys, this is my current config:
But I need some help: how can I change the window colors?
I know I can make a buttons panel with WSH (in fact the volume control is WSH), but I want to paint blue the scroll bars, columns headers, dropdown boxes, and the line between panels...
Is this possible?
  • derty2
Reply #1828
Those elements are dependent on your operating system theme; therefore, under normal circumstances, you can't change those things.
However, if you run your foobar2000 installation contained in a portable sandbox and configure the sandbox to be fully isolated from your real system
then you can possibly change these things without touching your real system.
Do a Google search for a free software named JauntePE and see what it can do for you...
  • Corey
Reply #1829
How did you split window like that? I want to do the same, so I can have space for album artwork, lyrics, bio etc... This is stupid question, I'm a beginner at this, so basic help you be nice.
Or how can I make tabbed columns?
Example
http://fc07.deviantart.net/fs47/f/2009/236...amofsandman.png
Bottom right, are small button that have tabbing ability, in one tab is Playlists, other libary, third lyrics, 4th bio etc... how can I make it? And what's the plugin for making playlist organized like this by albums?
I know, so many questions.... : (
  • Last Edit: 12 April, 2012, 09:57:17 AM by Corey
Reply #1830
I'm using ColumnsUI, if you go to Preferences -> Display -> Columns UI -> [TAB] Layout you will see a tree structure where you can group different splitters.
My config is:
Horizontal splitter
---Vertical splitter
------Horizontal splitter
---------Buttons
---------Playback order
---------WSH Panel Mod (for volume)
------EsPlaylist
------Waveform seekbar
---------Vertical splitter
------------Biography (for album art)
------------Biography (for artist info)
---------Lyric Show 3
------Channel spectrum panel
------Spectrum analizer
Also I use [a banned component] to [circumvent compliance with the Windows UI]
  • Last Edit: 12 April, 2012, 10:21:19 AM by db1989
  • Corey
Reply #1831
What are differences between deffault splitters and Panel Stack Splitters? And what's the component for artist biography, I can't seem to find it.
Reply #1832
@db1989: banned component? that means it can be harmful? should I delete it?
@corey: not sure about panel stack, but I think it's like a tab panel...
and about biography, is this one:
foo_uie_biography
Biography View 0.4.0.3
This is an experimental plugin, use at your own risk
  • Last Edit: 13 April, 2012, 11:34:15 AM by patanpatan
  • Corey
Reply #1833
Hm, I think it's not, maybe someone else can explain better.
Reply #1834
hi
Uploaded with ImageShack.us
  • acrox999
Reply #1835
  • Last Edit: 23 April, 2012, 07:16:03 AM by acrox999
Reply #1836
Cool, I borrowed the coverflow and the playlist.
  • Last Edit: 26 April, 2012, 03:54:18 AM by db1989
  • LSton
Reply #1837
hi
I love your setup! I know this is probably a stupid question but how do you get the underline across the bottom of the grouping titles?
  • MacStew
Reply #1838
New version of fooxgen3 released
  • Falstaff
Reply #1839
nice config MacStew, ...but imho track line is maybe too cluttered around the ...rating info
  • MacStew
Reply #1840
Thanks, I will fix it.
  • Brazil2
Reply #1841
I'd wish to make tabs for the artwork view for Front, Back, Media covers as seen in the pic from this post:
http://www.hydrogenaudio.org/forums/index....st&p=793905
But it's done with the default UI, so is it possible to do the same with Columns UI ? And if so, how to do it ? I'm quite new to foobar and not good at customization, I've searched but I didn't find out how to do it. Thanks
  • marc2003
Reply #1842
assuming you have an artwork panel already in your layout, goto file>preferences>display>columns UI>layout tab. using the right click menu, remove the artwork panel. now right click the splitter it was sitting in and add a tab stack. add to that as many artwork panels as you need. use the use custom title option on each panel and that will become the title of the tab. make sure you untick show caption for each panel as well.
  • Last Edit: 29 April, 2012, 04:02:38 AM by marc2003
  • Brazil2
Reply #1843
Thanks a lot, with your great help I managed to do it
There is one annoyance though: each time I click on a tab (Front, Back, etc) the title on the playlist becomes unselected-out of focus thus the artwork view appears empty and I have to click on the title again for making the covers to show up.
Is there any workaround for this so I can switch between tabs without the need the click back on the title each time ?
  • marc2003
Reply #1844
right click the panel>displayed track and try the options there.
  • Brazil2
Reply #1845
The 'Playlist selection' option did it.
Again, thanks a lot for your help
  • Frankie
Reply #1846
hello all -
  well, here's the new and improved (much) lljkturntable config.  it looks about
the same...
  thanks to tom barlow and tedgo for their help with the wsh panel, and to br3tt
for his (unwitting) help with the buttons scripting!  thanks also to everyone else
i've shamelessy but not thanklessly "borrowed" scripting ideas from....
here's the link:  stick this in yer foobar and smoke it...
rock
j
Unfortunatly the link in this post doesn't work anymore. Can anybody please repost this or tell me if I can find this skin (or another nice turntable skin) elswhere?
Reply #1847
hi
[a href="http://imageshack.us/photo/my-images/18/2000ra.jpg/" target="_blank"]
Reply #1848
Interesting, but I cannot get it to work.
After it loads I get a "Aw, crashed " message below the album art, and I can't see the playlist or the tabs.
Console says:
Error: WSH Panel Mod ({05B803E5-E660-4D82-9F7F-4635DEA32226}): Microsoft JScript runtime error:
Invalid procedure call or argument
File: <main>
Ln: 28, Col: 1
Do you know what am I missing?
  • MacStew
Reply #1849
Console says:
File: <main>
Ln: 28, Col: 1
A picture can be helpful ^^.
If you have like the picture and only a crash, click on the big down arrow button: add an album and restart foobar.
http://imageshack.us/photo/my-images/10/untitm.jpg/
Otherwise the installation is not good
  • Last Edit: 02 May, 2012, 08:36:49 PM by MacStew
