Topic: Columns UI appearance (Read 1514423 times) previous topic - next topic
  • hejiamei
Reply #1900
Sure, but before that there will be some code cleanup that I will need to do.
Wow that dark theme is amazing! I really like the overall style! Please share this I want to try this NOW!
Forget the Anime Banner this is already awesome , you can't beat awesome!
Thanks that's a pretty constructive comments. I had been busy playing with my new phone recently. Will share it as soon as I could, probably due this week  Hope the final code is user-friendly enough.
Please share your work , its bravo
  • jbp
Reply #1901
My first usable config. I'm using foobar2k just for few weeks.
[URL=http://imgur.com/q8GGX]
  • macarych
Reply #1902
Neutron mod#2 b2.
  • hxkclan
Reply #1903
Just changed my layout a couple of days ago.
Pretty basic look, but quite compact. Had a bigger version (fullscreen) of this before, but got tired of it blocking my other windows when opened >_<.
Reply #1904
My simple and loved UI
  • mrmister
Reply #1905
Hi there,
I'm sharing with you, how beautiful my foobar2000 is looking
I'm creating this post with several screenshots to show how it was configured and also sharing with you some scripts for those that are using for first time foobar2000 and don't know very well how to use the script programming language, so it is just copy and paste.
SCREENSHOT
PD: FOOBAR2000 IS THE BEST PLAYER!!! THANKS FOR THIS GREAT JEWEL !!!
  • Last Edit: 08 September, 2012, 06:50:28 PM by mrmister
  • equaleek
Reply #1906
Uploaded with ImageShack.us
  • macarych
Reply #1907
  • zevral
Reply #1908
Here is my foobar
  • Last Edit: 08 October, 2012, 01:08:27 PM by zevral
  • Falstaff
Reply #1909
how can i disable the borders between columns? like the one between the lyrics and the playlist?
you have to use Panel Stack Splitter component, it allows you to place you panels without the splitter border between components (and more!)
http://wiki.hydrogenaudio.org/index.php?ti...nel_splitter%29
  • zevral
Reply #1910
hm okay, i replaced all my horizontal and vertical splitters with the panel stack splitter, but i still have some kind of borders:
  • Falstaff
Reply #1911
right click on splitter > splitter settings... with the dialog opened, place you panels or just set padding values from 5 (default value for left, top, right, bot) to 0, that should be enough to remove borders, for the rest, you'll have to search by yourself, reading the PSS topic and help files is a good start, then check some configs that use PSS and check their PSS settings if you need to learn more about it.
HTH
  • foomark
Reply #1912
Here is my foobar
i really like it, nice one!!
Once you've done with the mods on the panels ... i'll be glad if you could share the fcl!!
  • macarych
Reply #1913
F2K for car audio.
  • Last Edit: 15 October, 2012, 12:49:39 AM by macarych
  • Falstaff
Reply #1914
@macarych: nice car audio config, it looks mature now
  • macarych
Reply #1915
Now it looks like this.
  • Falstaff
Reply #1916
iTunes 11 CUI config for foobar2000 (W.I.P.)
Follow project at br3tt.deviantart.com
Reply #1917
I'm a goof so I'm having some sadly very basic trouble: For album artwork, where it's a multiple-disc release structured like so: Weezer - Weezer (1994) [FLAC] {2004 Deluxe Edition}/Disc 1/files.flac -- and where folder.jpg is placed not in the directory with the files of each disc but the one just above it... How do I get the source list to recognise that?
  • BenB
Reply #1918
I think you've posted in the wrong thread. Use the [seemingly abandonware] Columns UI, alternative user interface thread instead for questions regarding configuring Columns UI.
Regardless, this post I made shows the title formatting you can use to achieve what you're asking. There may be other title formatting that can utilized but I'm unaware of it.
  • Last Edit: 26 October, 2012, 02:32:27 PM by BenB
Reply #1919
Oops, sorry... but that did the trick so thanks all the same!
  • soKindly
Reply #1920
Damask Config WIP
Release will appear at Deviantart when it's done
Reply #1921
Do you guys know how to change the font size of Artists and Albums in Playlist view?
for example: http://postimage.org/image/beq047bkd/
  • Daeron
Reply #1922
Options/Columns UI/Colours and Fonts
  • morphguy12
Reply #1923
My WIP - Xbox Music style
  • Last Edit: 30 November, 2012, 06:04:04 PM by morphguy12
  • wasmachien
Reply #1924
This might be a basic question - but is there a way to quickly switch between different layouts?
