Topic: foo_uie_vis_projectm - a quick port to 0.9 (Read 144168 times) previous topic - next topic
Reply #50
Fantastic!  Thanks so much Acropolis!
Reply #51
I've been monitoring the memory usage after installing this plugin and it shows that every time
i switch to next song\album it takes additional RAM till it finally reached 60M! Is there any way to cause it to
free some memory every time it starts working again?
Favourite artist:CD-R
Favourite album:700MB
Reply #52
Awesome, no need for Geforce port anymore, this is a great panel version !
Reply #53
Bug: When I try to lock a preset, it locks it to Aderrasi - Alligator instead of the one I'm on.
Is over the of = % over 100
Reply #54
If I right-click on the panel, the context menu opens up on the wrong display.  Foobar is running on my second monitor, and the menu opened up on the first monitor.
I have no idea, I'm running dual monitors, but have no problem.
Hmm, well, I have my second monitor to the left of the main one.  Which, I guess is non-standard.  One of the pitfalls of multi-monitor support, I guess.
After some more testing, the right click dialog does appear in the proper position if foobar is on the second display in a 1, 2 (from left to right) monitor configuration.  But, it appears on the right side of monitor 1 if foobar is on the second monitor in a 2, 1 configuration.
Just from the fact that the dialog shows up on the right side of the first monitor, I would guess that it's assuming that it's trying to display on the second monitor, but assumes it's on the other side.
Fullscreen mode will also not load on the same monitor for my AIW9600.
Otherwise, great plugin.  I'd just like to see it work perfectly for everyone. =]
Reply #55
I removed window blinds and still am getting a crash when using project m with windows 2000.  I also updated to 9.2 beta 3.  Also, I am pretty sure it project m becaue when I remove it from my lqyout the crash goes away with and without window blinds.  It must be a windows 2000 issue.  Here is my crash log.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 080ABF92h
Access violation, operation: write, address: FFFFBF00h
Call path:
entry=>user_interface::shutdown
Code bytes (080ABF92h):
080ABF52h:  0A 08 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88
080ABF62h:  E2 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88 E2
080ABF72h:  96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88 00 00
080ABF82h:  00 00 00 00 00 00 02 00 08 00 01 01 0C 00 98 D6
080ABF92h:  3E 08 00 BC 3B 08 03 00 02 00 01 01 08 00 88 EF
080ABFA2h:  38 08 72 65 73 73 5F 6C EF 6E 67 74 68 00 02 00
080ABFB2h:  03 00 01 01 0C 00 18 BC 3B 08 50 EE 38 08 03 00
080ABFC2h:  02 00 01 00 3B 08 08 BC 0A 08 98 B2 0A 08 A0 BC
Stack (0012E458h):
0012E438h:  00000001 A0005C09 00000172 00000002
0012E448h:  A03824A8 00000172 00000018 005651C0
0012E458h:  03E42D58 800BCF3F 006F0172 0F21B838
0012E468h:  03E76A30 0012E5A8 03E5E836 00000000
0012E478h:  03E2D486 0F21B838 03E76A30 00000000
0012E488h:  03E76A30 03E2DC71 006F0172 03E76A30
0012E498h:  00000000 00000000 006F0172 0012E494
0012E4A8h:  006F0172 0012E5A8 77E437BD 00000002
0012E4B8h:  03E46E99 006F0172 00000002 00000000
0012E4C8h:  00000000 03E76A38 03E76A30 0012E50C
0012E4D8h:  08920BD0 0012E518 03E76A38 03E76A30
0012E4E8h:  08920BD0 7FFDE000 77E4158F 006F0172
0012E4F8h:  00000002 00000000 00000000 03E76A30
0012E508h:  DCBAABCD 0012E528 77E3C19D 03E46D20
0012E518h:  006F0172 00000002 00000000 00000000
0012E528h:  0000E550 77E3C1CA 005651C0 00000002
0012E538h:  00000000 00000000 03E46D20 00000000
0012E548h:  00000000 00000000 0012E5B4 77F91BAF
0012E558h:  0012E560 00000018 005651C0 00000002
0012E568h:  00000000 00000000 03E46D20 77E3C168
Registers:
EAX: FFFFBF00, EBX: 00000000, ECX: 00896308, EDX: 080ABF50
ESI: 0F21B838, EDI: 0F229998, EBP: 0012E4B5, ESP: 0012E458
Unable to identify crash location
Loaded modules:
foobar2000                      loaded at 00400000h - 004E0000h
ntdll                            loaded at 77F80000h - 77FFC000h
COMCTL32                        loaded at 71710000h - 71794000h
GDI32                            loaded at 77F40000h - 77F7C000h
KERNEL32                        loaded at 7C570000h - 7C623000h
USER32                          loaded at 77E10000h - 77E79000h
ADVAPI32                        loaded at 7C2D0000h - 7C335000h
RPCRT4                          loaded at 77D30000h - 77DA8000h
SHLWAPI                          loaded at 70A70000h - 70AD6000h
msvcrt                          loaded at 78000000h - 78045000h
SHELL32                          loaded at 7CF30000h - 7D175000h
ole32                            loaded at 7CE20000h - 7CF0F000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 76B30000h - 76B6E000h
foo_abx                          loaded at 008A0000h - 008D4000h
foo_albumlist                    loaded at 008F0000h - 00931000h
foo_autoplaylist                loaded at 00950000h - 00982000h
foo_browser                      loaded at 009A0000h - 009D4000h
foo_burninate                    loaded at 009F0000h - 00A26000h
VERSION                          loaded at 77820000h - 77827000h
LZ32                            loaded at 759B0000h - 759B6000h
foo_cdda                        loaded at 00A40000h - 00A6C000h
foo_common                      loaded at 00A80000h - 00ABA000h
foo_converter                    loaded at 00AD0000h - 00B32000h
foo_dbsearch                    loaded at 00B50000h - 00BAC000h
foo_dsp_continuator              loaded at 00BC0000h - 00BF2000h
OLEAUT32                        loaded at 779B0000h - 77A4B000h
foo_dsp_delta                    loaded at 01020000h - 0103E000h
foo_dsp_std                      loaded at 01050000h - 01092000h
foo_freedb2                      loaded at 010B0000h - 010F0000h
foo_fullscreen                  loaded at 01100000h - 0111B000h
foo_infobox                      loaded at 01130000h - 0116F000h
foo_input_shorten                loaded at 01180000h - 011AE000h
foo_input_std                    loaded at 011C0000h - 012B3000h
foo_lnk                          loaded at 012D0000h - 012E9000h
foo_lock                        loaded at 01300000h - 01319000h
foo_locktest                    loaded at 01330000h - 01348000h
foo_masstag                      loaded at 01360000h - 013B0000h
foo_out_asio                    loaded at 013C0000h - 013EE000h
foo_out_ks                      loaded at 01400000h - 0142B000h
SETUPAPI                        loaded at 77880000h - 7790E000h
USERENV                          loaded at 7C0F0000h - 7C154000h
foo_playcount                    loaded at 01440000h - 01468000h
foo_playlist_manager            loaded at 01480000h - 014C6000h
foo_playlist_tree                loaded at 014E0000h - 01543000h
foo_pqview                      loaded at 01560000h - 0157C000h
foo_prettypop                    loaded at 01590000h - 015DE000h
MSVCR80                          loaded at 78130000h - 781CB000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscoree                          loaded at 79000000h - 79045000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 7CA00000h - 7CA23000h
CRYPT32                          loaded at 7C740000h - 7C7CC000h
MSASN1                          loaded at 77430000h - 77441000h
foo_random                      loaded at 03BC0000h - 03BFF000h
foo_rgscan                      loaded at 03C10000h - 03C55000h
foo_tradersfriend                loaded at 03C70000h - 03CAD000h
foo_uie_albumart                loaded at 03CC0000h - 03CF0000h
gdiplus                          loaded at 70D00000h - 70E91000h
foo_uie_albumlist                loaded at 03D10000h - 03D4F000h
foo_uie_console                  loaded at 03D60000h - 03D7C000h
foo_uie_playlists_dropdown      loaded at 03D90000h - 03DC9000h
foo_uie_trackinfo                loaded at 03DE0000h - 03E10000h
foo_uie_vis_projectm            loaded at 03E20000h - 03E94000h
OPENGL32                        loaded at 69510000h - 695D7000h
GLU32                            loaded at 6FAC0000h - 6FADF000h
DDRAW                            loaded at 51000000h - 51049000h
DCIMAN32                        loaded at 728A0000h - 728A6000h
foo_ui_columns                  loaded at 07E80000h - 07F1B000h
foo_ui_std                      loaded at 07F30000h - 07F87000h
foo_unpack                      loaded at 07FA0000h - 07FCE000h
foo_utils                        loaded at 07FE0000h - 08019000h
foo_ui_minilyrics                loaded at 08030000h - 08053000h
nvoglnt                          loaded at 08D00000h - 090C1000h
MiniLyrics                      loaded at 0FA10000h - 0FB03000h
WS2_32                          loaded at 75030000h - 75044000h
WS2HELP                          loaded at 75020000h - 75028000h
RICHED32                        loaded at 76B20000h - 76B25000h
RICHED20                        loaded at 772B0000h - 7731C000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
Gdiplus                          loaded at 10050000h - 101E1000h
ksuser                          loaded at 5EF80000h - 5EF84000h
imagehlp                        loaded at 77920000h - 77943000h
DBGHELP                          loaded at 72A00000h - 72A2D000h
Stack dump analysis:
Address: 03E42D58h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 03E76A30h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 03E5E836h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 03E2D486h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 03E2DC71h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 77E437BDh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 03E46E99h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 03E76A38h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 77E4158Fh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3C19Dh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 03E46D20h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 77E3C1CAh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77F91BAFh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77E3C168h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 03E2DE31h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 07EA2C0Eh, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EE1BCFh, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EA4796h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 77E417A7h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 07E87398h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07E87220h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07E8720Dh, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07E93BD8h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 00440256h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 07F03C14h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EACD43h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 00400276h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 07F03C0Ch, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EF62D0h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EEB298h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07F03C28h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EE2627h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EADFB4h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EAA726h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 004C7C18h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 07E9F762h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 77E3C133h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3AFA1h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3AFC7h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3C159h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 7A4A7DA1h, location: "System.ni", loaded at 7A440000h - 7ABFE000h
Address: 07EE1844h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 77E417D6h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 07EE24D0h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 77E2137Fh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 08E82A5Bh, location: "nvoglnt", loaded at 08D00000h - 090C1000h
Address: 009D027Fh, location: "foo_browser", loaded at 009A0000h - 009D4000h
Address: 77E1F417h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 07EAA561h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EA6FC0h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 0045EA5Dh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00499F96h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042B0FFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00494167h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7B70h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004935F3h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049FA4Bh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00488720h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004940BDh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0048D2B4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77FBB272h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FBB2ADh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FACDAAh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 0049FA8Bh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7F28h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7EE8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00AD027Ah, location: "foo_converter", loaded at 00AD0000h - 00B32000h
Address: 07EA4C76h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 0048D265h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77E3C1DAh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3B6D5h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 0047022Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 07EA64D8h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EA65AFh, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 07EE1E71h, location: "foo_ui_columns", loaded at 07E80000h - 07F1B000h
Address: 00493AF2h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 03E72750h, location: "foo_uie_vis_projectm", loaded at 03E20000h - 03E94000h
Address: 00493B2Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00493BB1h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00493F44h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7F50h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00494129h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77FBB286h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FACC28h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 0049FC6Dh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77F91BC6h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 7C59BC3Fh, location: "KERNEL32", loaded at 7C570000h - 7C623000h
Address: 00467594h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004D01F4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 08E828A0h, location: "nvoglnt", loaded at 08D00000h - 090C1000h
Address: 0120027Fh, location: "foo_input_std", loaded at 011C0000h - 012B3000h
Address: 011C0000h, location: "foo_input_std", loaded at 011C0000h - 012B3000h
Version info:
foobar2000 v0.9.2 beta 3
UNICODE
Additional info:
Playlist Lock Test 1.0  (foo_locktest)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Playlist tools 0.5.6  (foo_utils)
RAR reader 1.1  (foo_unpack)
Default User Interface 0.9acc  (foo_ui_std)
CD Audio decoder 2.0  (foo_cdda)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Shell link resolver 1.1  (foo_lnk)
Play Count 1.9.2  (foo_playcount)
Masstagger 1.5  (foo_masstag)
Playlist Tree Panel 2.0.7 [May  5 2006 - 13:10:05]  (foo_playlist_tree)
Database search 1.3.1 beta 11  (foo_dbsearch)
Console panel 0.2  (foo_uie_console)
Playlists Dropdown 0.5.6  (foo_uie_playlists_dropdown)
ABX comparator 1.3  (foo_abx)
Album List 3.2.0  (foo_albumlist)
Playlist Manager 1.0  (foo_playlist_manager)
Common services 0.1  (foo_common)
freedb tagger v0.5.1  (foo_freedb2)
Kernel Streaming Output 1.2.1  (foo_out_ks)
Pause on Lock 0.4  (foo_lock)
Live show tagger 0.6.1  (foo_tradersfriend)
Standard DSP array 1.0  (foo_dsp_std)
Track info panel 0.7  (foo_uie_trackinfo)
Fullscreen 0.3.1  (foo_fullscreen)
Standard input array 1.0  (foo_input_std)
projectM visualization (Panel) 0.4  (foo_uie_vis_projectm)
Continuator 0.4.0  (foo_dsp_continuator)
Special file info box v2.0.1  (foo_infobox)
Audio CD Writer 2.0  (foo_burninate)
ReplayGain Scanner 2.0  (foo_rgscan)
Converter 1.0  (foo_converter)
Music Browser 1.1.5 [Apr 28 2006 - 10:44:17]  (foo_browser)
FLAC decoder 1.1.0  (foo_input_std)
ZIP/GZIP reader 1.0  (foo_unpack)
Pretty Popup 1.2.2  (foo_prettypop)
Randomized playlist entry 1.2.3  (foo_random)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Album Art Panel 0.164a  (foo_uie_albumart)
Shorten decoder 0.4.2a  (foo_input_shorten)
Reply #56
are u sure it's because of this vis? it use quite a lot, but definitely not 100%.
I guess you are using foo_uie_trackinfo, if so, in its setting , change the scroll steps = 1. this vis will become not useless.
its been set to 1 for a long time. Its 80-90 and sometimes 100. In pause mode it still takes the same amount of CPU.
Reply #57
Feature Request: Can you add a Delete function in the Preset submenu, because I have 5000+ presets and I don't like a lot of them, but I don't want to go through all to delete the garbage ones. A feature like that will help see the bad presets and delete them easily.
Reply #58
Crash happened while having a wavpack (with embedded cue) converting to mp3 (single file) and fb2k minimized...
it worked fine so far... it crashed about 10 minutes after having some "new" milkdrop presets... so maybe it's their fault... I'll keep them in use for a while and see if this happens again...
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 018E5BF3h
Access violation, operation: read, address: 00000C9Ah
Call path:
Code bytes (018E5BF3h):
018E5BB3h:  24 1C 52 6A 02 88 5C 24 23 89 44 24 24 89 4C 24
018E5BC3h:  28 FF 15 00 21 90 01 85 C0 0F 85 1D 01 00 00 80
018E5BD3h:  3E 00 0F 84 50 01 00 00 80 7E 01 00 74 0F 8B 46
018E5BE3h:  50 50 FF 15 08 21 90 01 E9 E6 00 00 00 8B 4E 48
018E5BF3h:  8B 11 8B 52 0C 8D 44 24 1C 50 FF D2 84 C0 74 6C
018E5C03h:  8B 4E 48 DD 44 24 1C F2 0F 2A 46 14 F2 0F 10 0D
018E5C13h:  30 60 90 01 8B 01 8B 40 10 83 EC 10 F2 0F 5E C8
018E5C23h:  F2 0F 11 4C 24 08 DD 1C 24 8D 54 24 38 52 FF D0
Stack (0CC6FEFCh):
0CC6FEDCh:  05E7BBB8 5F140000 69311E3B 00000000
0CC6FEECh:  7FFDF000 69306C47 69306C4C 000F0000
0CC6FEFCh:  CCAED580 2D010CC9 00010000 08FFCCE0
0CC6FF0Ch:  00704427 00000438 00000190 4C0D986F
0CC6FF1Ch:  408067AE 85413078 01905DBC 08A7F018
0CC6FF2Ch:  00000498 0000AC44 00000002 00000003
0CC6FF3Ch:  0000024C 85413078 7FF49000 A7720C88
0CC6FF4Ch:  804FBB9C 00000000 00000005 00000000
0CC6FF5Ch:  00000000 00000000 804F43C4 A7720C60
0CC6FF6Ch:  854130AC 804DD3C7 0CC6FFDC 01900D88
0CC6FF7Ch:  00000000 00000000 85413160 00000001
0CC6FF8Ch:  00000000 85104380 804FBB7C 00000000
0CC6FF9Ch:  00000000 00000000 804FBB84 A7720CA0
0CC6FFACh:  80704EF2 0CC6FFEC 018E5D99 7C80B50B
0CC6FFBCh:  08FFCCE0 2D010CC9 00010000 08FFCCE0
0CC6FFCCh:  7FF49000 C0000005 0CC6FFC0 0CC6FB20
0CC6FFDCh:  FFFFFFFF 7C8399F3 7C80B518 00000000
0CC6FFECh:  00000000 00000000 018E5D90 08FFCCE0
0CC6FFFCh:  00000000 00000000 00010000 00001000
0CC7000Ch:  00000000 001505C8 20042000 00003000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000C9A, EDX: 7C91EB94
ESI: 08FFCCE0, EDI: 00008000, EBP: 0CC6FFB0, ESP: 0CC6FEFC
Crash location: "foo_uie_vis_projectm", loaded at 018C0000h - 01936000h
Loaded modules:
ntdll loaded at 7C910000h - 7C9C6000h
kernel32 loaded at 7C800000h - 7C8FF000h
COMCTL32 loaded at 773A0000h - 774A2000h
msvcrt   loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77F40000h - 77FEB000h
RPCRT4   loaded at 77DA0000h - 77E31000h
GDI32 loaded at 77E40000h - 77E86000h
USER32   loaded at 77D10000h - 77DA0000h
SHLWAPI   loaded at 77E90000h - 77F06000h
SHELL32   loaded at 7C9D0000h - 7D1EB000h
ole32 loaded at 774B0000h - 775EC000h
comdlg32 loaded at 76360000h - 763AA000h
IMM32 loaded at 76340000h - 7635D000h
LPK   loaded at 62E40000h - 62E49000h
USP10 loaded at 74D20000h - 74D8B000h
uxtheme   loaded at 5B180000h - 5B1B8000h
MSCTF loaded at 746B0000h - 746FB000h
msctfime loaded at 752E0000h - 7530E000h
foo_ac3   loaded at 00A50000h - 00A7C000h
foo_adpcm loaded at 00A90000h - 00AE1000h
foo_albumlist loaded at 00B10000h - 00B51000h
foo_amipwrapper   loaded at 00B80000h - 00BA6000h
foo_audioscrobbler   loaded at 00BD0000h - 00C00000h
WS2_32   loaded at 71A30000h - 71A47000h
WS2HELP   loaded at 71A20000h - 71A28000h
foo_bitcompare   loaded at 00C60000h - 00C86000h
foo_browser   loaded at 00CB0000h - 00CE8000h
foo_cdda loaded at 00D10000h - 00D3C000h
foo_common   loaded at 00D60000h - 00D9A000h
foo_converter loaded at 00DC0000h - 00E22000h
foo_dbsearch loaded at 00E50000h - 00EAC000h
foo_dsp_crossfeed loaded at 00ED0000h - 00EF4000h
foo_dsp_std   loaded at 00F20000h - 00F62000h
foo_dumb loaded at 00F90000h - 00FEF000h
foo_freedb2   loaded at 01010000h - 01050000h
foo_infobox   loaded at 01070000h - 010AE000h
foo_input_matroska   loaded at 010D0000h - 01156000h
foo_input_monkey loaded at 01180000h - 011C3000h
foo_input_shorten loaded at 011F0000h - 0121E000h
foo_input_std loaded at 01240000h - 01333000h
foo_lnk   loaded at 01360000h - 01379000h
foo_masstag   loaded at 013A0000h - 013F0000h
foo_midi loaded at 01410000h - 014B8000h
foo_osd   loaded at 014E0000h - 01516000h
gdiplus   loaded at 4EBD0000h - 4ED73000h
foo_playcount loaded at 01550000h - 01578000h
foo_playlist_manager loaded at 015A0000h - 015E6000h
foo_pqview   loaded at 01610000h - 0162C000h
foo_random   loaded at 01650000h - 0168F000h
foo_rgscan   loaded at 016B0000h - 016F5000h
foo_tradersfriend loaded at 01720000h - 0175D000h
foo_uie_albumart loaded at 01780000h - 017B0000h
foo_uie_albumlist loaded at 017D0000h - 0180F000h
foo_uie_console   loaded at 01830000h - 0184C000h
foo_uie_trackinfo loaded at 01870000h - 0189E000h
foo_uie_vis_projectm loaded at 018C0000h - 01936000h
OPENGL32 loaded at 5F140000h - 5F20C000h
GLU32 loaded at 5C8A0000h - 5C8C1000h
DDRAW loaded at 736D0000h - 73719000h
DCIMAN32 loaded at 73B30000h - 73B36000h
foo_ui_columns   loaded at 02360000h - 023FB000h
foo_ui_std   loaded at 02420000h - 02477000h
foo_unpack   loaded at 024A0000h - 024CE000h
foo_utils loaded at 024F0000h - 02529000h
foo_vis_projectM loaded at 02550000h - 025C1000h
atioglxx loaded at 69000000h - 694FF000h
amip loaded at 09F60000h - 0A10C000h
newdotnet6_38 loaded at 0A520000h - 0A55C000h
OLEAUT32 loaded at 770F0000h - 7717C000h
urlmon   loaded at 77230000h - 772CD000h
VERSION   loaded at 77BD0000h - 77BD8000h
WININET   loaded at 77180000h - 77227000h
CRYPT32   loaded at 77A50000h - 77AE5000h
MSASN1   loaded at 77AF0000h - 77B02000h
SETUPAPI loaded at 778F0000h - 779E7000h
MPR   loaded at 71AA0000h - 71AB2000h
WINTRUST loaded at 76BF0000h - 76C1E000h
IMAGEHLP loaded at 76C50000h - 76C78000h
mswsock   loaded at 719D0000h - 71A10000h
hnetcfg   loaded at 66750000h - 667A8000h
wshtcpip loaded at 71A10000h - 71A18000h
netapi32 loaded at 5BC70000h - 5BCC4000h
CLBCATQ   loaded at 76F90000h - 7700F000h
COMRes   loaded at 77010000h - 770E2000h
Secur32   loaded at 77F10000h - 77F21000h
SSSensor loaded at 0AA20000h - 0AA35000h
DSOUND   loaded at 73E80000h - 73EDC000h
WINMM loaded at 76B00000h - 76B2E000h
wdmaud   loaded at 72C90000h - 72C99000h
msacm32   loaded at 72C80000h - 72C88000h
MSACM32   loaded at 77BB0000h - 77BC5000h
DNSAPI   loaded at 76EE0000h - 76F07000h
winrnr   loaded at 76F70000h - 76F78000h
WLDAP32   loaded at 76F20000h - 76F4D000h
rasadhlp loaded at 76F80000h - 76F86000h
midimap   loaded at 77BA0000h - 77BA7000h
KsUser   loaded at 73E50000h - 73E54000h
appHelp   loaded at 77B10000h - 77B32000h
shdocvw   loaded at 77730000h - 7789C000h
CRYPTUI   loaded at 76890000h - 76913000h
xpsp2res loaded at 0F070000h - 0F345000h
cscui loaded at 779F0000h - 77A45000h
CSCDLL   loaded at 765B0000h - 765CD000h
browseui loaded at 75F30000h - 7602C000h
ntshrui   loaded at 76950000h - 76976000h
ATL   loaded at 76AE0000h - 76AF1000h
USERENV   loaded at 76980000h - 76A34000h
LINKINFO loaded at 76940000h - 76948000h
fsshext   loaded at 5A500000h - 5A52D000h
MSVCR71   loaded at 7C340000h - 7C396000h
drprov   loaded at 75F10000h - 75F17000h
ntlanman loaded at 71BA0000h - 71BAE000h
NETUI0   loaded at 71C60000h - 71C77000h
NETUI1   loaded at 71C20000h - 71C60000h
NETRAP   loaded at 71C10000h - 71C17000h
SAMLIB   loaded at 71B80000h - 71B93000h
davclnt   loaded at 75F20000h - 75F29000h
shgina   loaded at 73CE0000h - 73CF3000h
MSGINA   loaded at 75920000h - 75A18000h
WINSTA   loaded at 76310000h - 76320000h
ODBC32   loaded at 745E0000h - 7461D000h
odbcint   loaded at 0FF70000h - 0FF88000h
NETSHELL loaded at 763B0000h - 76559000h
rtutils   loaded at 76E40000h - 76E4E000h
credui   loaded at 76BC0000h - 76BEE000h
iphlpapi loaded at 76D20000h - 76D39000h
KBAbsent loaded at 0CC80000h - 0CC86000h
DBGHELP   loaded at 59E60000h - 59F01000h
Address: 01905DBCh, location: "foo_uie_vis_projectm", loaded at 018C0000h - 01936000h
Address: 01900D88h, location: "foo_uie_vis_projectm", loaded at 018C0000h - 01936000h
Address: 018E5D99h, location: "foo_uie_vis_projectm", loaded at 018C0000h - 01936000h
Address: 7C80B50Bh, location: "kernel32", loaded at 7C800000h - 7C8FF000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8FF000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C80B518h, location: "kernel32", loaded at 7C800000h - 7C8FF000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 018E5D90h, location: "foo_uie_vis_projectm", loaded at 018C0000h - 01936000h
Version info:
UNICODE
Additional info:
MIDI synthesizer host 1.6  (foo_midi)
AMIP Wrapper 0.90  (foo_amipwrapper)
Special file info box v2.0.0  (foo_infobox)
Playback statistics 1.0  (foo_playcount)
RAC decoder 1.0  (foo_adpcm)
Crossfeed 0.70  (foo_dsp_crossfeed)
ADX decoder 1.0  (foo_adpcm)
OKI-ADPCM decoder 0.14  (foo_adpcm)
projectM visualization 1.97.6.2  (foo_vis_projectM)
GCN DSP decoder 1.2  (foo_adpcm)
Music Browser 1.1.2 [Apr  3 2006 - 16:51:34]  (foo_browser)
kode's ADPCM decoders 1.2  (foo_adpcm)
DUMB module decoder 0.9.7  (foo_dumb)
Binary comparator 1.0  (foo_bitcompare)
BRR decoder and converter 0.7  (foo_adpcm)
AC3 decoder 0.7  (foo_ac3)
Monkey's Audio decoder 2.0  (foo_input_monkey)
Track info panel 0.8  (foo_uie_trackinfo)
projectM visualization (Panel) 0.4 (SSE2)  (foo_uie_vis_projectm)
Matroska Plugin 0.9.0.7  (foo_input_matroska)
Interplay ACM decoder 1.0  (foo_adpcm)
Audioscrobbler 2.0  (foo_audioscrobbler)
XA ADPCM decoder 1.1  (foo_adpcm)
On-Screen Display GDI+ 1.52  (foo_osd)
anyway thank you for your great work  keep it on!
Reply #59
did u try the non panel one? because the bug may be from the original one, I need to know first.
Reply #60
tell you what... I'm 99% sure it's a "preset-related" crash, 'cause it's impossible for me to reproduce again the crash... what about putting a "last_used_preset.log"? Just a suggestion, I can live without this one, but it might be helpful somehow...
cheers!
Reply #63
hi, could be i'm stupid, but I allways get this error:
Startup time : 0:01.374998
ERROR : Couldn't initialise projectM: Couldn't get wgl render context from window DC.
whats wrong? am I missing something?
Reply #64
seems like you have some problem about the OpenGL.
Reply #67
* NEWS *
New version in progress, using the projectM 0.98 core.
screenshot
Nice1! Good job! Icons seem to be a little bit too big though. I guess those could be adjusted?
nono, those icons are not part of the plugin, they are just my playback buttons
LOL! What the heck did I think...
Reply #68
hello,
I'am using this panel and he is working very well,except,as some users said, a little excess in cpu charge
with the panel 17-25 without 5-8.But there is no option to stop the engine! or if there is,I did'nt found it!
This is not important if your player is in focus and you watch visualizations and listen to music
but if you want to work and still listen to music,then you don't need the visualization,so to regain full cpu
capacity one should be able to pause or stop the engine ?
As you are working on a new version,maybe you could add this option in the right-click menu ?
thank you
Ps:If I'm all wrong,and this option actually exist,then please accept my apologies and just be kind enought
to point it out to me
Reply #69
hello,
thank you
because the current version is just a quick wrapper which use the existing code of the non panel version, so I didn't really change a lot of things, so it may have problems.
that's why I'm writing a new version using the new core, which can use TTF and write completely new code. hopefully I can release it around the end of june. but I still think it could use a lot of cpu.
at the time I need to prepare for my exams, so I can't write anything.
Reply #70
Of course,your exams are far more important (good luck)
I just wanted to point the fact that the only way to stop the visualizations
but still listening music ,is to take the panel out of the layout.
Hope you will implement a disable possibility in your next release
thank you
Reply #71
look here if u wanna find out better to use sse2-version or non-sse2-version --> http://en.wikipedia.org/wiki/SSE2
there's a cpu-list :-)
what should be in the fonts-directory to see the song-title?
edit:
now i have the arial1.glf from winamp-port of projectm, but i dont found any other glf-font file
how can i increase font-size for panel version? i cant read anything
Reply #72
there's not many glf fonts you can download, I think, and even if you have a lot, only arial1.glf and time_new1.glf will be used (it's hardcoded).
you can't change the font size, but will be implemented in the new version.
Reply #73
Please consider compiling a SSE (1) version for all the CPU users that have SSE but not SSE2. This includes Pentium 3, Athlon XP, and some other CPUs.
Reply #74
maybe u have too much time and would make an sse3-version for those wo have newer penti-4, newer athlon64, newer opteron, newer sempron, all athlon64x2, all turion, all celeron d and my core duo and ...
what about sse4 or mmx or 3Dnow! versions?
i think the two versions are enough.
