i do not get a crash log but just a fatal exception error in an error box. The steps generally vary, but always involve clicking on an item.
I don't know then, I code it under XP with using version 0.9.2 beta 3 without this problem.
My crash log using windows 2000 and .91 with updated components. Runs for a while and then crashes usually upon clicking an item. There is definitely a bug at least under windows 2000. Foobar never crashed before I installed plugin and after removing it I get no more crashes. The crash happens frequently and cannot run foobar with project m for more than a 1/2 hour before crash occurs.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 089F8028h
Access violation, operation: write, address: FFFFFFA2h
Call path:
entry=>user_interface::shutdown
Code bytes (089F8028h):
089F7FE8h: 28 80 9F 08 96 88 E2 96 88 E2 96 88 E2 96 88 E2
089F7FF8h: 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96
089F8008h: 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88
089F8018h: 00 8E F1 BD 13 2E 2B BD 08 00 08 00 02 01 0E 00
089F8028h: D0 5B A2 08 96 88 E2 96 88 E2 96 88 E2 96 88 E2
089F8038h: 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96 88 E2 96
089F8048h: 88 00 96 88 00 96 88 00 96 88 00 96 88 00 96 88
089F8058h: 00 F8 01 3D 1A 11 8E 3C 0A 00 08 00 02 01 0C 00
Stack (0012E1F0h):
0012E1D0h: 00000001 A0005C09 000002A2 00000002
0012E1E0h: A0325328 000002A2 00000018 00565FC8
0012E1F0h: 04472CD8 883B227F 002202A2 0F626BD8
0012E200h: 084A3C88 0012E340 0448E316 00000000
0012E210h: 04471106 0F626BD8 084A3C88 00000000
0012E220h: 084A3C88 04471895 002202A2 084A3C88
0012E230h: 00000000 00000002 660153E5 002202A2
0012E240h: FFFFFFEB 002202A2 084A3C88 00000002
0012E250h: 044769E9 002202A2 00000002 00000000
0012E260h: 00000000 084A3C90 084A3C88 0012E2A4
0012E270h: 08F50D60 0012E2B0 084A3C90 084A3C88
0012E280h: 08F50D60 7FFDE000 77E4158F 002202A2
0012E290h: 00000002 00000000 00000000 084A3C88
0012E2A0h: DCBAABCD 0012E2C0 77E3C19D 04476870
0012E2B0h: 002202A2 00000002 00000000 00000000
0012E2C0h: 0012E2E8 77E3C1CA 00565FC8 00000002
0012E2D0h: 00000000 00000000 04476870 00000000
0012E2E0h: 00000000 00000000 0012E34C 77F91BAF
0012E2F0h: 0012E2F8 00000018 00565FC8 00000002
0012E300h: 00000000 00000000 04476870 77E3C168
Registers:
EAX: 089F8028, EBX: 00000000, ECX: 08948CC8, EDX: 089F7FE8
ESI: 0F626BD8, EDI: 0F66F478, EBP: 0012E24C, ESP: 0012E1F0
Unable to identify crash location
Loaded modules:
foobar2000 loaded at 00400000h - 004E0000h
ntdll loaded at 77F80000h - 77FFC000h
COMCTL32 loaded at 71710000h - 71794000h
GDI32 loaded at 77F40000h - 77F7C000h
KERNEL32 loaded at 7C570000h - 7C623000h
USER32 loaded at 77E10000h - 77E79000h
ADVAPI32 loaded at 7C2D0000h - 7C335000h
RPCRT4 loaded at 77D30000h - 77DA8000h
SHLWAPI loaded at 70A70000h - 70AD6000h
msvcrt loaded at 78000000h - 78045000h
SHELL32 loaded at 7CF30000h - 7D175000h
ole32 loaded at 7CE20000h - 7CF0F000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 76B30000h - 76B6E000h
WBlind loaded at 66000000h - 660CF000h
msimg32 loaded at 6B2C0000h - 6B2C5000h
wbhelp loaded at 66600000h - 66617000h
foo_abx loaded at 00EC0000h - 00EF4000h
foo_albumlist loaded at 00F10000h - 00F51000h
foo_autoplaylist loaded at 00F70000h - 00FA2000h
foo_browser loaded at 00FC0000h - 00FF4000h
foo_burninate loaded at 01010000h - 01046000h
VERSION loaded at 77820000h - 77827000h
LZ32 loaded at 759B0000h - 759B6000h
foo_cdda loaded at 01060000h - 0108D000h
foo_common loaded at 010A0000h - 010DA000h
foo_converter loaded at 010F0000h - 01151000h
foo_dbsearch loaded at 01170000h - 011CC000h
foo_dsp_continuator loaded at 011E0000h - 01212000h
OLEAUT32 loaded at 779B0000h - 77A4B000h
foo_dsp_delta loaded at 01640000h - 0165E000h
foo_dsp_std loaded at 01670000h - 016AF000h
foo_freedb2 loaded at 016C0000h - 01700000h
foo_fullscreen loaded at 01710000h - 0172B000h
foo_infobox loaded at 01740000h - 0177F000h
foo_input_shorten loaded at 01790000h - 017BE000h
foo_input_std loaded at 017D0000h - 018E3000h
foo_lnk loaded at 01900000h - 01919000h
foo_lock loaded at 01930000h - 01949000h
foo_locktest loaded at 01960000h - 01978000h
foo_masstag loaded at 01990000h - 019E0000h
foo_out_asio loaded at 019F0000h - 01A1E000h
foo_out_ks loaded at 01A30000h - 01A5B000h
SETUPAPI loaded at 77880000h - 7790E000h
USERENV loaded at 7C0F0000h - 7C154000h
foo_playcount loaded at 01A70000h - 01A98000h
foo_playlist_manager loaded at 01AB0000h - 01AF6000h
foo_playlist_tree loaded at 01B10000h - 01B73000h
foo_pqview loaded at 01B90000h - 01BAC000h
foo_prettypop loaded at 01BC0000h - 01C0E000h
MSVCR80 loaded at 78130000h - 781CB000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscoree loaded at 79000000h - 79045000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni loaded at 790C0000h - 79BA8000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 7CA00000h - 7CA23000h
CRYPT32 loaded at 7C740000h - 7C7CC000h
MSASN1 loaded at 77430000h - 77441000h
foo_random loaded at 041F0000h - 0422F000h
foo_rgscan loaded at 04240000h - 04284000h
foo_tradersfriend loaded at 042A0000h - 042DD000h
foo_uie_albumart loaded at 042F0000h - 04320000h
gdiplus loaded at 70D00000h - 70E91000h
foo_uie_albumlist loaded at 04340000h - 0437F000h
foo_uie_console loaded at 04390000h - 043AC000h
foo_uie_playlists_dropdown loaded at 043C0000h - 043F9000h
foo_uie_trackinfo loaded at 04410000h - 04440000h
foo_uie_vis_projectm loaded at 04450000h - 044C4000h
OPENGL32 loaded at 69510000h - 695D7000h
GLU32 loaded at 6FAC0000h - 6FADF000h
DDRAW loaded at 51000000h - 51049000h
DCIMAN32 loaded at 728A0000h - 728A6000h
foo_ui_columns loaded at 084B0000h - 0854B000h
foo_ui_std loaded at 08560000h - 085B7000h
foo_unpack loaded at 085D0000h - 085FE000h
foo_utils loaded at 08610000h - 08649000h
foo_ui_minilyrics loaded at 08660000h - 08683000h
nvoglnt loaded at 09330000h - 096F1000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC56000h
Gdiplus loaded at 10050000h - 101E1000h
MiniLyrics loaded at 10430000h - 10523000h
WS2_32 loaded at 75030000h - 75044000h
WS2HELP loaded at 75020000h - 75028000h
RICHED32 loaded at 76B20000h - 76B25000h
RICHED20 loaded at 772B0000h - 7731C000h
ksuser loaded at 5EF80000h - 5EF84000h
imagehlp loaded at 77920000h - 77943000h
DBGHELP loaded at 72A00000h - 72A2D000h
Stack dump analysis:
Address: 04472CD8h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 0448E316h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 04471106h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 04471895h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 660153E5h, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 044769E9h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 77E4158Fh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3C19Dh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 04476870h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 77E3C1CAh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77F91BAFh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77E3C168h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 04471A51h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 084D2C0Eh, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 08511BCFh, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084D4796h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 77E437BDh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E417C0h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 084B7398h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084B7220h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084B720Dh, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084C3BD8h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 08533C14h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084DCD43h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 08533C0Ch, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 085262D0h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 0851B298h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 08533C28h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 08512627h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084DDFB4h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084DA726h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 004C74B0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 084CF762h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 77E1F417h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E54447h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 6600E2F0h, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 77E3C1DAh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E543F8h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 085124D0h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 094B2A5Bh, location: "nvoglnt", loaded at 09330000h - 096F1000h
Address: 084DA561h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 084D6FC0h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 0045FB02h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004976BFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042B82Ch, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00494167h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7408h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004935F3h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049F7BBh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00488720h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004940BDh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0048D2B4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77FBB272h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FBB2ADh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FACDAAh, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 0049F7FBh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C77F0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C77B0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 6600EE24h, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 77E33A0Bh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3B811h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 084B7313h, location: "foo_ui_columns", loaded at 084B0000h - 0854B000h
Address: 0048D265h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77E4001Bh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3AFA1h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E27E2Dh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 6603CB75h, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 66014C09h, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 6600AD5Dh, location: "WBlind", loaded at 66000000h - 660CF000h
Address: 77E37045h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E3265Eh, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77E27419h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 00493AF2h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 044A2548h, location: "foo_uie_vis_projectm", loaded at 04450000h - 044C4000h
Address: 00493B2Eh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00493BB1h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00493F44h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004C7818h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77E3B377h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 00494129h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77FBB286h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 77FACC28h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 0049F9EFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77E417D6h, location: "USER32", loaded at 77E10000h - 77E79000h
Address: 77F91BC6h, location: "ntdll", loaded at 77F80000h - 77FFC000h
Address: 7C59BC3Fh, location: "KERNEL32", loaded at 7C570000h - 7C623000h
Address: 00445ECAh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 094B28A0h, location: "nvoglnt", loaded at 09330000h - 096F1000h
Address: 0120027Fh, location: "foo_dsp_continuator", loaded at 011E0000h - 01212000h
Address: 011C0000h, location: "foo_dbsearch", loaded at 01170000h - 011CC000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
Playlist Lock Test 1.0 (foo_locktest)
Randomized playlist entry 1.2.3 (foo_random)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Pause on Lock 0.4 (foo_lock)
Audio CD Writer 2.0 (foo_burninate)
Live show tagger 0.6.1 (foo_tradersfriend)
MPEG-4 AAC decoder 2.1 (foo_input_std)
Standard DSP array 1.0 (foo_dsp_std)
Converter 1.0 (foo_converter)
Playlists Dropdown 0.5.6 (foo_uie_playlists_dropdown)
Database search 1.3.1 beta 11 (foo_dbsearch)
Track info panel 0.7 (foo_uie_trackinfo)
Album Art Panel 0.164a (foo_uie_albumart)
Playlist tools 0.5.6 (foo_utils)
Play Count 1.9.2 (foo_playcount)
Pretty Popup 1.2.2 (foo_prettypop)
Masstagger 1.5 (foo_masstag)
ABX comparator 1.3 (foo_abx)
Shorten decoder 0.4.2a (foo_input_shorten)
Default User Interface 0.9acc (foo_ui_std)
Special file info box v2.0.1 (foo_infobox)
FLAC decoder 1.1.0 (foo_input_std)
Continuator 0.4.0 (foo_dsp_continuator)
Shell link resolver 1.1 (foo_lnk)
CD Audio decoder 2.0 (foo_cdda)
Playlist Tree Panel 2.0.7 [May 5 2006 - 13:10:05] (foo_playlist_tree)
ZIP/GZIP reader 1.0 (foo_unpack)
Kernel Streaming Output 1.2.1 (foo_out_ks)
Standard input array 1.0 (foo_input_std)
Fullscreen 0.3.1 (foo_fullscreen)
Common services 0.1 (foo_common)
RAR reader 1.1 (foo_unpack)
ReplayGain Scanner 2.0 (foo_rgscan)
ProjectM (Panel) 0.3.1 (foo_uie_vis_projectm)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
Playlist Manager 1.0 (foo_playlist_manager)
Album List 3.2.0 (foo_albumlist)
Album list panel 0.2.1 beta 4 (foo_uie_albumlist)
Console panel 0.2 (foo_uie_console)
freedb tagger v0.5.1 (foo_freedb2)
Music Browser 1.1.5 [Apr 28 2006 - 10:44:17] (foo_browser)
Also, foobar usually crashes without a text file created crash log. I just get a pop up box that states "unhandled exception: <unknown exception>."
