Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 367247 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #1075
Here's a quick and dirty hack for autoplaylists that will sort by name if you middle click. Right click>Configure and add this...
function on_mouse_mbtn_up() {
    if (list.data.length < 2) return;
    list.data = _.orderBy(list.data, 'name');
    list.save();
    list.offset = 0;
    window.Repaint();
You can also click entries and move up/down but that's a bit cumbersome.
Reply #1076
TheQwertiest, v.1.6.0., my script "clock and timer" works well.
But i have a new problem.
I use pseodo-transparence.
After start Foobar i have black background now (pseodo-transparence does not work). If i go to "Show configure" - "Appearence" and press "OK" pseodo-transparence turns on.
Or I make mistake and must use version 1.5.2.
UR5EQF. Ukraine
Reply #1077
    list.save();
    list.offset = 0;
    window.Repaint();
Reply #1078
Download link is missing at
https://www.foobar2000.org/components/view/foo_spider_monkey_panel
Reply #1079
@kgena_ua , thanks, I'll take a look.
@regor , that's intentional: I want my download count and fb2k component section does not provide it (I need to feed my sense of importance after all :D)
Reply #1080
@kgena_ua, wait, is this on 1.6.0 or on the dev build? If it's 1.6.0 can you try the dev build and see if this bug is present there?
Reply #1082
See the first post in this thread, there is a link called "Dev Build". This link always points to the latest dev build.
Reply #1083
Everything seems to work.
UR5EQF. Ukraine
Reply #1084
For example, I made a simple script. Sometimes I get an error.
const objShellApp = new ActiveXObject("Shell.Application");
function get_folder() {
    var prompt = "\nSelect folder ...";
    var folder = objShellApp.BrowseForFolder(0, prompt, 512, 17);
    if (folder != null) {
        /// do ...
MF_ENABLED = 0x00000000;
MF_SEPARATOR = 0x00000800;
function on_mouse_rbtn_up(x, y){
    const _menu = window.CreatePopupMenu();
    _menu.AppendMenuItem( MF_ENABLED, 100, "Getfolder");
    _menu.AppendMenuItem( MF_SEPARATOR, 0, 0);
    _menu.AppendMenuItem( MF_ENABLED, 230, "Edit Script");
    ret = _menu.TrackPopupMenu(x, y);
    switch (ret) {
    case 100:
        get_folder();
        break;
    case 230:
        window.EditScript();
        break;
    return true;
This also happens with:
utils.InputBox();
WshShell.Popup();
Select a menu item and wait.
Sometimes the error occurs immediately.
UR5EQF. Ukraine
Reply #1085
        /// do ...
    switch (ret) {
    case 100:
        get_folder();
        break;
    case 230:
        break;
    return true;
utils.InputBox();
WshShell.Popup();
Does it happen with the dev build as well?
Reply #1087
Not sure if it has been already changed, but on v1.5.2-dev+28cbd05e I have just seen a BSOD and all packages being used have been corrupted, those panel reset and all properties lost.  ::)  Having a backup of the json files as fallback would come handy if that single file can break everything.
@TheQwertiest.
Happened before And now with the dev build.
Can also confirm that behavior when opening popups in any way.
Reply #1088
Happened before on this example. I had to abandon such a code.
var limit = 0;
    _menu.AppendMenuItem( MF_ENABLED, 100, "Set limit");
    switch (ret) {
    case 100:
        download_limit(x, y);
        break;
    case 230:
        break;
    return true;
function download_limit(x, y){
    _menu.AppendMenuItem(MF_ENABLED, 1, "Increase");
    _menu.AppendMenuItem(MF_ENABLED, 2, "Limit : "  + limit + "     Return to main menu");
    _menu.AppendMenuItem(MF_ENABLED, 3, "Decrease");
    switch (ret) {
    case 1:
        limit = limit + 1;
        // do
        break;
    case 2:
        on_mouse_rbtn_up (x, y);
        break;
    case 3:
        limit = limit <= 1 ? 1 : limit - 1;
        // do
        break;
UR5EQF. Ukraine
Reply #1089
var limit = 0;
    switch (ret) {
    case 100:
        break;
    case 230:
        break;
    return true;
    switch (ret) {
    case 1:
        limit = limit + 1;
        // do
        break;
    case 2:
        break;
    case 3:
        // do
        break;
It happens on every instance where the code is waiting for user input to continue execution. Menus, input boxes, etc. Obviously there is not a reason to open a menu and wait... but if you do, you get a warning about script taking too much time. You could bypass it using promises though... but agree a workaround on the base code would be better.
Reply #1090
Trying to switch Darkone theme to SMP and I was having great success until the Display. I get this...
Failed to create GdiPlus object (0x2): InvalidParameter
File: Display.js
Line: 162, Column: 18
Stack trace:
on_paint@Display.js:16218
Line 162 is: d_font = gdi.Font("Arial Black", f_size);
It happens on bootup. Reloading works fine.
I have made no changes to the code other than taking out Dispose. In fact, anything that has a line like this in it, whether it's Darkone or not, crashes . I can reload but it will crash on bootup.
EDIT: Ok, never mind. It stopped doing this after I "fixed" the Visual switch in the Panel Stack Splitter.  But the switch worked fine with JScript.
Reply #1091
Just guessing but I suspect the issue is related to the variable f_size being dependent on panel width/height which could be 0 on startup - this would explain why it works after reloading later. Ideally, it should be initialised with a sensible minimum value for a font and only grow if the panel gets bigger.
edit: with regard to JSP behaving differently, SMP is doing it better by throwing more errors. While it might seem like an inconvenience, it actually forces the creation of better scripts.
Reply #1092
Thanks for the reply. I'm back to that error again. I thought I had it licked. I actually have two displays on my Darkone. (I'm talking about the display with the Elapsed/Remaining time). It's fine with one display but when I add an additional one, it throws the error on bootup.
Only one display is visible at a time.
It used to throw the error when I cycled the displays with the Visual switch but I tweaked the "Switch code" a bit and now it errors only on bootup.
So how would I go about initializing the width/height?
Thanks, again!
Reply #1093
Ok, I think I REALLY fixed it this time. :) I believe it had to do with the panel stack settings (as stated above), specifically the Panel List settings (Left, Top, Width, Height). I had duplicate values in both the splitter's $movepanel entries AND the Panel List.  Once I deleted the panel list entries the errors stopped.
Anyway, thanks for your time.
Reply #1094
I think I've found a bug with SMP 1.6.0. Perhaps it's already been reported. When I use 1.6.0 with Tedgo's Darkone, every SMP panel flickers on and off when I resize the window. What I mean is when I minimize and then grab a corner and stretch it in and out. The buttons also dance around more than they should.
Replacing the 1.6.0 dll with 1.5.8 fixes it.
It took me awhile to trouble shoot it. I killed every panel except one SMP and then I inserted a Jscript panel. The SMP (1.6.0) flickered but the Jscript did not.
Reply #1096
Would it be possible to retrieve some kind of uuid for playlists?
That would make a lot easier to track a playlist no matter its position or if there are other playlists with same name. Just asking to get that info, nothing more. Traversing them can be done by idx fine.
Reply #1097
No can do: fb2k does not provide any such information. It's probably stored as a plain array internally.
Reply #1098
Other question, could ${current_script_path} be exposed as variable?
https://theqwertiest.github.io/foo_spider_monkey_panel/assets/generated_files/docs/html/global.html#include
Reply #1099
@TheQwertiest.
Just got a Foobar crash and again all panels with packages got reset and all properties were lost due to json files being corrupted. Packages are becoming an annoyance more than helping... :(
