Hydrogenaudio Forums
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: TheQwertiest on 2018-10-01 11:01:15
Title: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: TheQwertiest on 2018-10-01 11:01:15
Spider Monkey Panel     (https://img.shields.io/github/release/theqwertiest/foo_spider_monkey_panel.svg) (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/master/CHANGELOG.md) (https://ci.appveyor.com/api/projects/status/4fg787ijr73u7mxc/branch/master?svg=true) (https://ci.appveyor.com/project/TheQwertiest/foo-spider-monkey-panel/branch/master)
fb2k component that allows for creation of full-fledged CUI/DUI panels using JavaScript!
Base functionality includes:
 - Graphics functions: drawing (text, images, lines, rectangles and etc), image modification (resize, blur, inversion of colours and etc).
 - Access to font and colour settings from CUI/DUI preferences.
 - Capture of foobar2000 events with callbacks.
 - Capture of keystrokes and mouse movement/clicks.
 - Execution of main menu and context menu commands.
 - Creation of custom buttons and menus.
 - Playlist management: create, destroy, sort, change, rename and do anything that fb2k can do.
 - Media Library access with ability to sort and filter it's content.
 - File tag management.
 - Per panel settings storage.
 - Built-in web and filesystem functionality.
 - foo_acfu (https://acfu.3dyd.com) integration.
 - And more!
Getting started!
 - Use Installation Guide (https://theqwertiest.github.io/foo_spider_monkey_panel/docs/installation).
 - Check out Samples and User scripts (https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_showcase).
 - Take a look at Documentation (https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_documentation), if you are craving for more!
JScript Panel users
Spoiler (click to show/hide)
Links
 - Download link (https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/latest)
 - Homepage (https://theqwertiest.github.io/foo_spider_monkey_panel)
 - Changelog (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/master/CHANGELOG.md)
 - Detailed list of API Changes (https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_documentation/api_changes)
 - Current tasks and plans (https://github.com/TheQwertiest/foo_spider_monkey_panel/projects/1)
 - Nightly build (https://ci.appveyor.com/api/projects/theqwertiest/foo-spider-monkey-panel/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel.fb2k-component?branch=master&job=Configuration%3A%20Release)
Credits
 - marc2003 (https://github.com/marc2k3): original foo_jscript_panel (https://github.com/marc2k3/foo_jscript_panel), sample scripts (https://github.com/TheQwertiest/smp_2003) and multiple contributions to this project.
 - T.P. Wang (https://hydrogenaud.io/index.php?action=profile;u=44175): original WSH Panel Mod (https://code.google.com/archive/p/foo-wsh-panel-mod).
 - #jsapi IRC channel (https://wiki.mozilla.org/IRC): wouldn't make it through without them, love you guys!
    Especially huge thanks to sfink and jonco, who spent literally tens of hours helping me!
 - Respective authors (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/master/THIRD_PARTY_NOTICES.md) of the code being used in this project.
Title: Re: Spider Monkey Panel
Post by: TheQwertiest on 2018-10-01 11:15:34
Version: 1.0.0
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.0
Changelog (relative to the latest version of JScript Panel (https://github.com/marc2k3/foo_jscript_panel)):
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v100
Huge thanks to marc2003 (https://github.com/marc2k3) for porting samples and testing the component!
Post by: seriousstas on 2018-10-02 21:24:31
Tried to see the cover:
foobar2000 \ user-components \ foo_spider_monkey_panel \ samples \ basic \ GetAlbumArtV2.txt
Error: Spider Monkey Panel v1.0.0 (GetAlbumArtV2 by T.P Wang)
g_img.Dispose is not a function
File: <main>
Line: 35, Column: 3
Stack trace:
   on_playback_new_track @ <main>: 35: 3
How to adapt this :
https://hydrogenaud.io/index.php/topic,110938.0.html
Library tree ?
Post by: WilB on 2018-10-03 00:51:55
Library Tree is in the process of being ported.
Post by: MordredKLB on 2018-10-03 05:01:20
@TheQwertiest , I can't tell you how excited I am for this! Really want to check it out, but I need to finish my themes 1.0 release before I have to redo everything again :)
You said it's fast, but have you done performance benchmarking? What kind of speed increase are you seeing when initializing 10k files in your playlist component?
I saw this bit in the API docs:
utils.CreateHtmlWindow() method.
This method allows the creation of HTML windows rendered by IE8 engine.
utils.CreateHtmlWindow(html_code, { width: window_w, height: window_h, title: window_title, data: callback_data, fn: callback_fn }).
If that's using ActiveX to create the window, you can bump it up to IE11 using the FEATURE_BROWSER_EMULATION (https://docs.microsoft.com/en-us/previous-versions/windows/internet-explorer/ie-developer/general-info/ee330730(v=vs.85)) registry key. Not ideal for sharing themes, but probably possible nonetheless.
Post by: Black_Over_Bills_Mothers on 2018-10-03 09:32:06
@TheQwertiest , This is great work, at last an engine that has the latest ECMA support. Now I can use string.startsWith and array.findIndex. Heaven knows what I can do with those async functions!
@WilB, You just knew someone would ask 'What about porting your wonderful Biography panel'.....
Post by: TheQwertiest on 2018-10-03 09:44:54
Oops, forgot to nuke that `Dispose` call (will be fixed in v1.0.1).
For now you can just remove the following lines:
if (g_img)
    g_img.Dispose();
How to adapt this :
Library tree ?
See @WilB 's reply above: it's being ported =)
Nice! Looking forward to ;)
Post by: Black_Over_Bills_Mothers on 2018-10-03 09:56:39
@TheQwertiest
I think I've found a problem. The following line;
    fb.RunContextCommandWithMetadb("ReplayGain/Scan as albums (by folders)",plman.GetPlaylistSelectedItems(plman.ActivePlaylist));
gives this error;
'RunContextCommandWithMetadb' failed:
handle argument is invalid
Post by: TheQwertiest on 2018-10-03 09:59:12
I was too lazy to perform any proper benchmarking. AFAIK most(?) operations are faster by at least an order of magnitude. There is one regression I've encountered though (https://bugzilla.mozilla.org/show_bug.cgi?id=1474914), so `Playlist` performance might be further increased by rewriting initialization without `reverse`.
I'm in progress of total rewrite of `CreateHtmlWindow`, since current implementation has some nasty bugs (like fb2k lockup when user closes html window). As a side effect it should work properly with IE=edge and it will support loading htmls from file.
@TheQwertiest
gives this error;
See https://github.com/TheQwertiest/foo_spider_monkey_panel/issues/19
Bug will be fixed in v1.0.1
Post by: Black_Over_Bills_Mothers on 2018-10-03 10:19:35
@TheQwertiest re issue #19
I've tried 'Build: 21:06:31, Oct  2 2018' patch from github and still get the same problem
Post by: WilB on 2018-10-03 10:26:28
@Black_Over_Bills_Mothers
Yes, Biography, Library Tree & YouTube Track Manager are all in the process of being ported... Spider Monkey Panel is a really great advancement that will enable them to be used with the newer ECMA features. To implement these properly may take a little time, but hopefully they are not far away...
Post by: loz on 2018-10-03 11:07:47
I'm just going to flat out make a request even before I RTFM...
Please, for the love of all that is, add an album rating method. Something similar to jsp_rating would be nice but I'm not that picky. That is the only feature left that I want in foobar and the one thing I miss about not using custom database. (Having custom notes in custom db was nice too but I can do that with a .txt)
And if not, because marc2003 wouldn't do it either when I asked, I'm still going to use this component because it looks great. Thanks for this.
Post by: Black_Over_Bills_Mothers on 2018-10-03 12:16:03
Can we please have a better development environment. Links to an external editor such as Notepad++ or at least add text search and brace matching. I know you can export and import script but it's a pain.
Post by: fbuser on 2018-10-03 14:53:11
I'd consider this as a waste of time to implement such functionality. Just place one line like include('path/to/script.js') in the panel code area and do the code editing of this script with an editor of your choice.
Post by: Black_Over_Bills_Mothers on 2018-10-03 15:10:25
Seems interesting but could you explain a little further please.
Post by: Sergey77 on 2018-10-03 17:12:35
@WilB, great news!
looking forward to new versions of your cool scripts! (Don't forget JScript's version :) )
And I want to test Spider Monkey Panel
@TheQwertiest, thanks a lot for your great work!
Wish you creative success in the development of this project!
Post by: TheQwertiest on 2018-10-03 20:42:39
That's weird, I'll recheck later.
Haha, thanks!
Not sure what you mean. Do you want another custom metadb field? Like `smp_album_rating`?
PS: Both JSP and SMP provide a way to edit tags via `UpdateFileInfoFromJSON`.
See `docs/js_doc/Interfaces.js` and samples. This method works like `eval`, but accepts path to file and provides better error-reporting.
On another note: JSP and SMP `Configure` window uses the same editor engine as Notepad++ =)
Post by: MordredKLB on 2018-10-03 22:19:37
Maybe he wants Atom :)
Post by: TheQwertiest on 2018-10-04 00:10:53
Well, to be fair, only internal editor engines are the same, the engine wrappers are different, thus the different experience in Notepad++ compared to `Configure` window in JSP/SMP =)
Post by: loz on 2018-10-04 01:04:24
^ That exactly.  I don't want to be changing the actual tags in the files. I realize I could do this in m-TAGS but that just creates other issues for me personally atm. Custom database was also really good for such things but it just got to the point it crashed so often it was unusable.
Again, Thanks for this component. It looks great.
Post by: mjm716 on 2018-10-04 02:59:47
"wordwrap" option would be nice! ;)
great job by the way!
Post by: TheQwertiest on 2018-10-04 09:49:13
Hm... Don't really want to add random tags. I'd rather make a generic method to add custom tags (well, if it's possible), smth like
utils.CreateCustomTag('smp_new_tag', 'number') ); // CreateCustomTag(tag_name, tag_type);
metadb.SetCustomTag('smp_new_tag', 'this is my tag value'); // SetCustomTag(tag_name, tag_value);
Do you mean `linewrap` (when line is too big, part of it will move to the next line)?
If you do, then I can add in v1.0.1.
Post by: loz on 2018-10-04 10:29:35
That would be fine. Great even. I could actually do more with that.
Post by: mjm716 on 2018-10-04 11:08:00
Notepad++ actually calls it wordwrap - but yes, linewrap option would be great!
Post by: TheQwertiest on 2018-10-04 17:25:12
It seems that this is impossible... From fb2k SDK:
List of fields that you provide is expected to be fixed at run-time. The backend will enumerate your fields only once and refer to them by indexes later.
I.e. all fields must be defined when component loads and can't be added afterwards.
Another way might be to configure custom tags from the component's preferences page, but that would be possible only if component configuration is loaded before fields enumeration (which I doubt is the case).
Post by: MordredKLB on 2018-10-04 20:41:39
You could add a customProperties field to the metadb and then expose some methods to store and read arbitrary JSON from it. It's kind of ugly and hacky, but since you're abstracting it away from the end-user it'd hide the ugly implementation details and be pretty seamless.
To be clear, I'm not really advocating this approach, but it's doable.
Post by: TheQwertiest on 2018-10-05 11:48:23
Version: 1.0.1
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.1
Changelog
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v101
Post by: TheQwertiest on 2018-10-05 12:29:49
Version: 1.0.2
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.2
Changelog
Hotfix for v1.0.1 (see changelog above (https://hydrogenaud.io/index.php/topic,116669.msg963027.html#msg963027))
Post by: TheQwertiest on 2018-10-05 13:32:09
I've benchmarked playlist script a bit:
Playlist initialization speed is mostly the same. Profiling showed that bad performance of `Array.reverse()` is the main culprit. So it should greatly improve once I remove it.
But!!! I've noticed that CPU usage is halved during playlist scrolling!
- Normal scrolling: ~3.5% SMP vs ~7.5% JSP.
- Erratic scrolling in huge playlist: ~5% SMP vs ~10% JSP.
Another thing that I've noticed is that erratic scrolling in JSP has small hitches, while SMP does not suffer from it. Most likely caused by differences in GC management policy - JScript immediately destroys any resources that are no longer used, no matter how long it takes, while SpiderMonkey has a `budget` - it can spend only as much time in GC as allowed by budget.
Measured same performance increase during scrolling in @WilB 's Library Tree as well.
PS: I have a 6-core CPU and SMP/JSP are single-threaded, so to get a clearer picture results should be multiplied by six. Thus ~21% SMP vs ~45% JSP in normal scrolling and 30% SMP vs 60% JSP in erratic.
Post by: Sergey77 on 2018-10-05 17:50:36
I noticed same interrupt of Shpeck visualization for both panels jsplaylist-mod script in JSP and SMP.
Post by: TheQwertiest on 2018-10-06 12:57:54
What do you mean? Shpeck visualization is a separate component/panel and is not a part of SMP nor jsplaylist-mod :\
Post by: Sergey77 on 2018-10-06 14:09:15
Yes, but I mean these separate components (Shpeck and jsplaylist-mod) work at the same time in diferent CUI panels.
When together displaying the panel with Shpek and another panel with jsplaylist-mod, the visualization is displaying with jerks during a file playback.
This behavior of visualization when running jsplaylist-mod as in JSP or as in SMP is the same.
But when activated CUI Playlist view panel (jsplaylist-mod panel is not active), Shpeck visualization is displayed smoothly, without jerks.
Post by: TheQwertiest on 2018-10-06 16:22:17
Can't reproduce: Shpeck visualization(with MilkDrop2) is smooth with both stock CUI playlist and `jsplaylist-mod` script.
Possible cause of hitches you are experiencing: Shpeck is pretty CPU intensive, so, if your CPU is practically used up by Shpeck, then any additional CPU load might cause stuttering.
PS: I've tested `jsplaylist-mod` script a bit, and it does not seem to cause any meaningful CPU load during casual usage. And CPU load is close to nil when idle (i.e. when there is no interaction with playlist panel).
Post by: Sergey77 on 2018-10-06 17:19:53
Did you test synchronous work the panels (Shpeck and jsplaylist-mod) during music playback? (triangle cursor of jsplaylist-mod should flashing)
Shpeck (with MilkDrop2) stuttering synchronous with flashing cursor. Shpeck works stable without playback.
Maybe it really depends on my hardware speed. Let's see maybe someone else will report of similar problem.
In any case, thanks for your time!
Post by: Black_Over_Bills_Mothers on 2018-10-08 13:52:43
I have a script to automate the addition of new tracks/albums into my collection. This script calls fb.RunContextCommandWithMetadb function to remove all embedded images and then to Optimize and reduce file sizes - both core functionality. These two operations need to be performed sequentially. This has caused me two problems;
1) Firstly the call to fb.RunContextCommandWithMetadb does not block with means that the only way I can detect completeness is to catch the callback - okay but it would be better if the call could block - maybe optionally.
2) Both calls generate a popup window asking the user to click either close or OK button. Can this request be circumvented in some way?
Post by: MordredKLB on 2018-10-09 17:36:09
Those are both built in functionality of foobar. There's nothing Spidermonkey or JScript can do to control those operations once it tells foobar to start them.
Post by: TheQwertiest on 2018-10-11 10:17:01
Version: 1.0.3
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.3
Changelog
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v103
Note: v1.0.0 API changelog was missing description of on_notify_data callback behaviour change. It is rectified now: see wiki (https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v100) or callbacks doc (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/master/component/docs/Callbacks.js).
Post by: Decalicatan_Decalicatan on 2018-10-12 12:31:39
@TheQwertiest , thanks for the component
It seems there is an issue with the on_main_menu() function. As soon as I try to trigger one of the menu items, foobar2000 crashes :-(.
Post by: TheQwertiest on 2018-10-12 14:26:03
Thanks for the report!
I'll look into it (#25 (https://github.com/TheQwertiest/foo_spider_monkey_panel/issues/25)).
Post by: Decalicatan_Decalicatan on 2018-10-14 21:56:21
@TheQwertiest you're welcome ^^.
I think I may have found another bug  O:) : using Columns UI and the "MainMenuManager All-In-One", as soon as I try to change to another layout --> instant crash...
Post by: TheQwertiest on 2018-10-15 10:35:29
Could not reproduce the bug (on the latest build at least). Can you try the latest build (https://ci.appveyor.com/api/projects/theqwertiest/foo-spider-monkey-panel/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel.fb2k-component?branch=master&job=Configuration%3A%20Release)?
Post by: Decalicatan_Decalicatan on 2018-10-15 17:26:24
My bad, I tried with a new portable installation and is fine. I think I may have messed up one of the js files in the "docs".
Anyway, on_main_menu() works fine now. Thanks!
Post by: TheQwertiest on 2018-10-15 21:36:33
Bug reproduced: see #29 (https://github.com/TheQwertiest/foo_spider_monkey_panel/issues/29)
Post by: loz on 2018-10-20 18:18:33
I have the following code in ratings.txt to set ratings using keyboard shortcuts:
// RATING HOTKEYS
function on_main_menu(index) {
switch (index) {
case 1: // set rating File>Spider Monkey Panel>1 is run
panel.metadb.SetRating(panel.tf('$if2(%smp_rating%,0)') == 1 ? 0 : 1);
panel.metadb.RefreshStats();
break;
This, and every variation I have tried crashes foobar instantly. Now I'm assuming it's either something with my configuration or my code since I pretty much modified what I had in js_panel, but just in case it's something with spider monkey I thought I'd the thread aware this is happening. (Crash reports and full code attached if needed). Thanks.
Post by: TheQwertiest on 2018-10-20 22:17:13
// RATING HOTKEYS
switch (index) {
break;
This is a known bug, which will be fixed in v1.0.4, which is expected to be released before the end of the next week.
PS: You can use the `nightly build` from the link in the OP for the time being. It should be noted though, that `nightly build` might be less stable than the `release build` and might have API incompatibilities, which are not documented. So it should be used only if you want to help me by testing it (thus making `release-build` more stable), or if you want to get your bug-fixes as soon as possible by accepting the risk of potential instability.
Post by: loz on 2018-10-20 22:53:58
Ok great. Just making sure. I'll wait a few days for the stable as this is a minor issue for me and everything else seems to be working nicely.
Post by: TheQwertiest on 2018-10-24 21:40:47
Version: 1.0.4
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.4
Changelog
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v104
Note: reset SMP advanced settings for better performance - Preferences>Advanced>Tools>Right-Click on Spider Monkey Panel>Reset Branch.
Huge thanks to @WilB for all the bug reports!
Title: Re: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: loz on 2018-10-25 10:50:11
Fixed
  • Fixed crash when `on_main_menu` callback was invoked.
Can confirm my issues with this have been fixed. Thanks.
Post by: embe on 2018-10-25 14:19:51
I'm having problem with displaying buttons with 'track info + seekbar + buttons' config. All I get are these rectangles. Do I need some special font installed for it?
Post by: TheQwertiest on 2018-10-25 22:43:08
That's because nobody reads `Readme` nowadays...
Quote from: samples/readme.md
- "complete" scripts:
         Should work fine on any system.
         Most scripts require the installation of FontAwesome (https://github.com/FortAwesome/Font-Awesome/blob/fa-4/fonts/fontawesome-webfont.ttf?raw=true)."
Post by: TheQwertiest on 2018-11-05 21:04:14
Version: 1.0.5
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.0.5
Changelog:
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v105
Post by: TheQwertiest on 2018-11-19 19:08:10
Version: 1.1.0
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.0
Changelog:
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v110
Post by: TheQwertiest on 2018-11-20 11:49:00
Version: 1.1.1
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.1
Changelog
Hotfix for v1.1.0 (see changelog above (https://hydrogenaud.io/index.php/topic,116669.msg965016.html#msg965016))
Post by: AlexR on 2018-11-28 07:48:36
Do not work callback on_colours_changed()
version 1.1.1, foobar 1.4.1
Post by: AlexR on 2018-11-28 11:29:39
version 1.1.1, foobar 1.4.1, DUI
Post by: TheQwertiest on 2018-11-29 16:15:24
Yep, that's a bug, will be fixed in the next version =)
Post by: TheQwertiest on 2019-01-09 11:01:17
Version: 1.1.2
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.2
Changelog:
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v112
Post by: SUPERCOOLMAN on 2019-01-13 01:33:37
trying to re-create an ancient foo_uie_albumart behaviour where pictures/arts in all user specified sub-directories of currently playing track are collected when track playback starts, then runs slideshow cycling through all the art every X second as specified by user
the component can load jpg, pg, bmp...etc. but not webp or other newer formats. I was wondering if it's possible for SMP to handle webp. maybe through some codec installed on the system?
Post by: TheQwertiest on 2019-01-16 14:17:19
TLDR: SMP does not have functionality to load images that are not supported by fb2k.
Full answer:
SMP uses foobar2000 API to load album art and `Gdiplus::Bitmap` (https://docs.microsoft.com/en-us/windows/desktop/api/gdiplusheaders/nf-gdiplusheaders-bitmap-bitmap(inconstwchar_inbool)) to load external images. AFAIK neither fb2k nor GDI+ have the ability to work with webp files.
It's probably possible to write a fb2k component that can load webp files as images though (and maybe even work as album art source for fb2k).
Post by: TheQwertiest on 2019-01-17 10:53:43
Version: 1.1.3
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.3
Changelog:
Post by: Decalicatan_Decalicatan on 2019-01-19 18:21:25
I don't know if the issue is with the latest version (1.1.3) or if it was already there before, but I can't update ratings (foo_playcount) anymore with fb.RunContextCommandWithMetadb. For example with the rating.txt script. It does simple nothings :(
Thanks in advance. And ty for all the work you have already done with the component!
Regards
Post by: hlhp on 2019-01-20 10:47:39
I am new to Spider Monkey Panel and J script panel.
I want to embed play back statistic information into the file.
Is there a function to edit metadata? (I only found retrieve info from metadata)
Post by: Rhand on 2019-01-20 11:28:36
This command doesn't work anymore with new spider panel.
buttons.buttons.albumart = new _button(bs * 6.8, 0, bs, bs, {normal : "Albumart.png", hover: "Albumart_h.png"}, function () { fb.RunContextCommand("Run service/AlbumArt"); },"AlbumArt"); Hope you can solve this
Post by: TheQwertiest on 2019-01-20 15:11:12
Version: 1.1.4
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.4
Changelog
Hotfix for v1.1.3 (see changelog above (https://hydrogenaud.io/index.php/topic,116669.msg967258.html#msg967258))
Post by: TheQwertiest on 2019-01-20 15:12:44
@Decalicatan_Decalicatan @Rhand : the issue should be fixed in v1.1.4. Thanks for the bug report!
Post by: TheQwertiest on 2019-01-20 15:19:26
Depends on what you mean: you can't edit some most stats provided by `foo_playcount` (e.g. %play_count%), but you can write additional custom tags with `FbMetadbHandleList.UpdateFileInfoFromJSON()` (you can read more about the method and it's usage in the documentation included with component: `Configure Panel` dialog > menu > Help > View Help).
Post by: Decalicatan_Decalicatan on 2019-01-20 16:25:18
ty!
Post by: hlhp on 2019-01-21 02:36:39
Thank you, adding custom tags is the only thing I want.   ;)
Post by: TheQwertiest on 2019-01-21 14:43:01
Version: 1.1.5
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.1.5
Changelog
Hotfix II for v1.1.3 (see changelog above (https://hydrogenaud.io/index.php/topic,116669.msg967258.html#msg967258))
Post by: hlhp on 2019-01-23 03:10:19
I want to find meta value(first value) by name.
According to the documentation.
I need to...
1. Check if there are matched name in the meta. if yes, go to step 2.
2. Find out how many meta in it.
3. Loop through the meta(s) to find the idx numbers for the name
4. Use the idx to get the Value out.
Is there any better way to doing this?
Post by: TheQwertiest on 2019-01-23 09:06:46
I need to...
There is also a MetaFind method, which returns the index of the meta field (or -1 if not found) =)
Post by: hlhp on 2019-01-24 14:58:14
Thank you it works.
I thought it only return like Boolean, I should read the documentation more carefully.
Post by: davideleo on 2019-02-06 16:53:34
First of all, a big thank you to @TheQwertiest for this component. I've been away from the forum for sometime and this is really a great surprise. It's good to have a jscript component back with official support and with the developer active in the forum. I'm following the migration instructions from JScript panel 2 and so far no problem. The only issue I found which was not mentioned in the official docs, nor in the forum, is that I can no more include both JScommon and Helpers in the preprocessor because some constants and variables are declared on both scripts.
I solved the problem by copying the few functions I actually needed, from JScommon to a new script, which replaced JScommon in the preprocessors where Helpers is also included. I like it better this way, it is definitely cleaner, but I just wanted to make sure that it is an intended behavior and I did not mess anything up.
Post by: TheQwertiest on 2019-02-07 13:20:50
You are very welcome :)
Well, it was probably intended that way (that is for Br3tt's scripts to be self-sufficient).
I wouldn't know anyway, since I've never actually delved into them - it's only thanks to marc2003 that Br3tt's scripts were even included in SMP =)
Post by: anamorphic on 2019-02-08 05:00:59
I too, would like to heap many thanks upon TheQwertiest one for this component. I do believe it will be quite fun once I figure out how to write scripts. ;)
For now though I just have a minor, issue / question / request. (An issquesest?) If one (me) did not want to see the SMP Playback Statistics in track properties, how could one (I) turn display of them off? Might it please be possible? (We looked for options)
The thing is with 'Selection Properties' (DUI) element, all stats are lumped / jumbled together under 'Other' along with official Playback Statistics (foo_playcount) component. So I guess that is limitation of the element. However the original PS 'Rating' (displayed as stars) is gone altogether, replaced by SMP 'Rating' (with no stars, because not using it) - not very complementary. I'd prefer to see my original ratings.
Not sure what / if you can do anything about this, but mentioning just in case.
(Of course, one could design a far superior 'Selection Properties' element with this very fine component. :D Even so... Edit: and I just found the 'properties.txt' sample after posting, typical!)
Cheers
Post by: davideleo on 2019-02-08 10:54:29
I just noticed the stats show up twice in the properties tab. I still have JScript panel installed of course. It's not a problem, I just wonder why this happens:
Now, in the picture above you will also notice the custom database tags. I don't know how SMP statistics work, but if the values are pinned to primary tags or a combination of primary tags, like the official playback statistics component does, than this is potentially a custom database replacement. I've seen a previous request by @loz for custom tags, but I did not understand if they're planned to be implemented. Anyway I definitely second that request.
Post by: davideleo on 2019-02-08 21:02:31
Eventually I ran into a problem. I use some text files to share layout settings between jscript panels and panel stack splitter. I have a script which deletes a specific file when triggered, using the FileSystemObject DeleteFile method. It's a very simple script and it always worked with JScript Panel, but since migrating to Spider Monkey Panel the delete action is denied because the file is in use by foobar2000. I cannot even delete the file manually.
Post by: TheQwertiest on 2019-02-09 12:19:02
Not sure if I can do anything about it (apart from renaming the metatag, which I won't do :P).
@Peter : could you help us out, please? Is there a way to hide and/or reorder the priority of the metadata provided by components?
That is the intended behaviour: SMP and JSP use different (internal) tags to avoid potential compatibility issues.
This is something I'm planning to look into (that is the ability to add customs tags via SMP API), but it's rather low on my priority list.
Could you provide the script (or it's relevant parts)?
Post by: davideleo on 2019-02-09 15:46:45
Sure, as I said it's a pretty simple one. The panel is resized via PSS (panel stack splitter) and this triggers either a delete or a create file action.
function on_size(){
    switch (window.Height){
        case 0:
        if (fso.FileExists(SettingsPath + "PlaylistVisible")) fso.DeleteFile(SettingsPath + "PlaylistVisible");
        RefreshPSS();
        break;
        case 1:
        if (!fso.FileExists(SettingsPath + "PlaylistVisible")) fso.CreateTextFile(SettingsPath + "PlaylistVisible");
        RefreshPSS();
        break;
        case 2:
        RefreshPSS();
        break;
Here's also the relevant code from another script, included in the preprocessor:
var fso = new ActiveXObject("Scripting.FileSystemObject");
var SettingsPath = fb.ProfilePath + "settings\\";
function RefreshPSS() {
var Refresh_sys = window.GetProperty("Refresh_sys",true);
 if (Refresh_sys < true) {
if (fb.IsPlaying || fb.IsPaused) {
fb.RunMainMenuCommand("View/Show status bar");
} else {
} else {
fb.RunMainMenuCommand("Playback/Play or Pause");
} else {
fb.RunMainMenuCommand("Playback/Play");
fb.RunMainMenuCommand("Playback/Stop");
The script seems to work for a few times right after foobar2000 start up, but eventually something happens which blocks the file, and I can't figure out what it could even be.
Post by: davideleo on 2019-02-09 16:24:28
I see, I never noticed before that JScript panel had its own! I though it was reading Spider Monkey Panel statistics.  :))
Post by: TheQwertiest on 2019-02-09 18:15:50
TLDR: Use the following code fso.CreateTextFile(path).Close(); or let file = fso.CreateTextFile(path); file.Close();
Full story: the problem is caused by your usage of fso.CreateTextFile: CreateTextFile returns a file object, which contains an open handle to the file, which will be closed only in two cases - when object is destroyed and when it's closed manually. The lifetime of JS objects is variable, i.e. objects might not be immediately destroyed when there are no references to them, so in your case: object is alive & not closed > handle remains open > file remains locked.
PS: Plz, don't over-quote =)
Post by: davideleo on 2019-02-09 20:32:18
Thanks, that was it. So, the real question is: why did it work with JScript panel?
Post by: TheQwertiest on 2019-02-09 21:11:12
Because GC behaves differently in JScript and SMP (Microsoft's jscript is quite outdated in that way).
Post by: WebSkater on 2019-02-12 13:59:01
after installing Spider Monkey Panel in perfect working fb2k v1.3.20 on W7 x64 - and not making any use of it, i only installed it - I can't write rating tags to foo_playcount's database anymore. Modifying already existing rating tags stored in the database isn't possible either. Writing rating tags direct to files is still working. After uninstalling Spider Monkey Panel everything is working as before and writing and modifying rating tags in files or in the database is possible again without any issue !
Seems Spider Monkey Panel and the official Playback Statistics (foo_playcount) can't work together without making trouble.
Any ideas or suggestion?
Post by: TheQwertiest on 2019-02-12 14:34:41
Replied on GitHub.
PS: please, do not duplicate bug reports in the future - posting it in one place (here or on GitHub) is good enough =)
Post by: WebSkater on 2019-02-12 17:28:08
Hi TheQwertiest,
sorry for duplicate posting, but I'm not very experienced in posting + "forum behaviour". Till now reading alone helped me over the years to solve my problems with foobar.
"Replied on GitHub"
means you noticed my post and are aware of the problem, but not that you have answered to it, right ? Stupid question, I know, but after "closing Github post by accident" and reopening and not seeing an answer after that in Github I'm really unsecure about this. Or I'm making something wrong again?
Post by: michtar on 2019-02-13 13:01:46
I'm not sure if it's a system specific, user  :-[ , script or Spider Monkey Panel problem but:
- mouse-on and double click functions of "album art" sample stopped working. They used to work with SMP and work fine with JScript Panel.
- tested on clean portable install, Foobar 1.4.2, default components + Spider Monkey Panel 1.1.5, default path, Windows 7
- as far as I noticed script did not change
Post by: TheQwertiest on 2019-02-13 13:30:35
Thanks for the bug report! Will be fixed in the next version (kudos to marc2003).
In the mean time you can apply the fix manually - https://github.com/marc2k3/smp_2003/commit/c12b44f25fb5b810a7c92366e324191a2a0ce5bf
Post by: michtar on 2019-02-14 09:47:34
Works (obviously). Thanks marc2003/TheQwertiest.
Post by: dwmartin0906 on 2019-02-14 12:37:22
I was wondering if anyone else was having this problem with the SMP thumbs panel.  It works fine except when displaying the thumbs in a grid.  They display fine initially, but when clicking on a specific thumb to display it I get the following error.  Any ideas?
Error: Spider Monkey Panel v1.1.5 (Thumbs by marc2003)
_.drawOverlay is not a function
File: thumbs.js
Line: 100, Column: 5
Stack trace:
  _thumbs/this.paint@thumbs.js:100:5
  on_paint@<main>:58:2
Post by: TheQwertiest on 2019-02-15 09:09:00
File: thumbs.js
Stack trace:
Yup, that's a bug =) Will be fixed in the next version (again kudos to marc2003).
In the mean time you can apply the fix manually - https://github.com/marc2k3/smp_2003/commit/a0e578ec06211b1d4b01f529962142bf50a75da5
Post by: dwmartin0906 on 2019-02-15 10:19:33
Thank you both very much.  That fixed it.  Amazing what one little period can do, isn't it?  I was a COBOL programmer for over 35 years so I understand how much damage one little typo can do.  At least you don't have to deal with hard copies, punch cards and 4 hour compile times like I had to in the beginning.  Debugging was a total nightmare.
Post by: TheQwertiest on 2019-02-15 10:37:46
Yeah, script languages are quite convenient in that way (actually one of the reasons why WSH/JSP/SMP were developed in the first place).
Post by: AndreaT on 2019-02-15 18:27:11
Hello!
Anybody knows if somebody already did a JS better than the default Album List DUI component?
The default Album List is "too slow" for me and many time starves.
I just need something providing a consolidated by folder structure view (as does Album List DUI) and some capability for searching the dBase by usual search patterns.
If I would be capable of programming in Java I would try myself, but I am not.
Thanks and regards, Andrea
Post by: always.beta on 2019-02-16 00:31:56
https://hydrogenaud.io/index.php/topic,111060.0.html
Try it yourself
Post by: AndreaT on 2019-02-17 10:45:17
Hi Always.beta, many thanks!
Regards, Andrea
Post by: davideleo on 2019-02-22 13:31:35
From what I gather, the strict mode defined in the panel does not apply to the scripts processed with the include statement. Is this an intended behaviour?
BTW, is the strict mode kind of mandatory with SMP or is it just a scrpting suggestion by the developers? or is it merely the common practice with the latest ECMA versions?
Post by: philodoxxx on 2019-02-22 16:46:28
 I have been experiencing an error on start up in Foobar related to the JS Smooth Browser sample script  in Spider Monkey Panel v1.1.5. See below:
Error: Spider Monkey Panel v1.1.5 (JS Smooth Browser by Br3tt aka Falstaff)
Resize failed:
Failed to create GdiPlus object (0x0: No error
File: jssb.js
Line: 3500, Column: 24
Stack trace:
  get_images@jssb.js:3500:24
  oBrowser/this.update@jssb.js:1526:3
  oBrowser/this.setSize@jssb.js:1548:3
  on_size@jssb.js:3120:3
If I reload the script it work's fine. The error only occurs at startup.
Post by: davideleo on 2019-02-23 23:41:55
So far I managed to upgrade all my scripts, but I still have a very old one by marc2003 that I can't get working on Spider Monkey Panel. The script is "Last.fm Album Art Downloader" with some little modifications I made over time and it still works perfectly on JScript Panel 2.1.4.
This is the script that works in JScript Panel:
// ==PREPROCESSOR==
// @name "Last.fm Album Art Downloader"
// @author "marc2003"
// @import "%fb2k_component_path%samples\complete\js\lodash.min.js"
// @import "%fb2k_component_path%samples\complete\js\helpers.js"
// @import "%fb2k_component_path%samples\complete\js\panel.js"
// ==/PREPROCESSOR==
var library_tracks_only = false;
var folder_tf = fb.TitleFormat("$puts(folder,$trim($replace($lower($directory(%path%)),disc,,cd,)))$replace($directory_path(%path%),$ifequal($strstr($get(folder),$num($get(folder),$len($get(folder)))),1,\\%directoryname%,),)\\");
var filename_tf = fb.TitleFormat("front.jpg");
var panel = new _.panel("Last.fm Album Art Downloader", ["metadb", "custom_background"]);
var x = new ActiveXObject("Microsoft.XMLHTTP");
var ini = SettingsPath + "album-art.ini";
_.createFolder(SettingsPath);
panel.item_focus_change();
var np = fb.GetNowPlaying();
if (panel.metadb && np && np.Compare(panel.metadb) && np.RawPath.indexOf("file://") == 0 && (!library_tracks_only || fb.IsMetadbInMediaLibrary(np))) {
var ar = panel.tf("%album artist%");
var al = panel.tf("%album%");
var f = folder_tf.EvalWithMetadb(panel.metadb) + _.fbSanitise(filename_tf.EvalWithMetadb(panel.metadb));
var tmp = _.q(_.fbSanitise(ar + al));
var n = _.round(_.now() / 1000);
var t = utils.ReadINI(ini, "Timestamps", tmp, 0);
switch (true) {
case !_.tagged(ar):
case !_.tagged(al):
case _.isFile(f):
case n - t < ONE_DAY:
break;
default:
utils.WriteINI(ini, "Timestamps", tmp, n);
x.open("GET", "https://www.last.fm/music/" + encodeURIComponent(ar) + "/" + encodeURIComponent(al) + "/+images", true);
x.setRequestHeader("If-Modified-Since", "Thu, 01 Jan 1970 00:00:00 GMT");
x.send();
x.onreadystatechange = function () {
if (x.readyState == 4) {
if (x.status == 200) {
var o = _.first(_.filter(_.getElementsByTagName(x.responsetext, "img"), {"className" : "image-list-image"}));
if (o) {
var u = o.src.replace("avatar170s", "ar0");
_.runCmd("cscript //nologo " + _.q(fb.ProfilePath + "scripts\\JSP\\download.vbs") + " " + _.q(u) + " " + _.q(f), false);
window.SetTimeout(function () {
}, 3000);
} else {
console.log("HTTP error: " + x.status);
break;
RefreshPSS();
} else {
} else {
} else {
...and this is my attempt to upgrade it for Spider Monkey Panel:
'use strict';
window.DefinePanel('Last.fm Album Art Downloader', {author:'marc2003'});
include(fb.ComponentPath + 'samples\\complete\\js\\lodash.min.js');
include(fb.ComponentPath + 'samples\\complete\\js\\helpers.js')
include(fb.ComponentPath + 'samples\\complete\\js\\panel.js');
let panel = new _panel("Last.fm Album Art Downloader", ["metadb", "custom_background"]);
_createFolder(SettingsPath);
var f = folder_tf.EvalWithMetadb(panel.metadb) + _fbSanitise(filename_tf.EvalWithMetadb(panel.metadb));
var tmp = _q(_fbSanitise(ar + al));
switch (true) {
case !_tagged(ar):
case !_tagged(al):
case _isFile(f):
break;
default:
x.send();
var o = _first(_filter(_getElementsByTagName(x.responsetext, "img"), {"className" : "image-list-image"}));
if (o) {
_runCmd("cscript //nologo " + _q(fb.ProfilePath + "scripts\\SMP\\download.vbs") + " " + _q(u) + " " + _q(f), false);
}, 3000);
} else {
break;
RefreshPSS();
} else {
} else {
} else {
Unfortunately it doesn't crash, therefore I have no idea where the problem is, but it does not download the album cover (doubled checked with the JScript panel version).
Any insight will be much appreciated.
Post by: zeremy on 2019-02-24 15:31:12
@davideleo
Replace line 45 with
var o = _.first(_.filter(_getElementsByTagName(x.responseText, "img"), {"className" : "image-list-image"}));
_.first and _.filter are from lodash.js
_getElementsByTagName is from helpers.js
x.responseText is valid (not x.responsetext)
Post by: davideleo on 2019-02-24 17:14:42
Thanks so much @zeremy! I was going mad. It works now!
Why wouldn't SMP report an error, though?
Post by: zeremy on 2019-02-24 17:26:59
It is a known bug.
https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/Known-bugs
Post by: TheQwertiest on 2019-02-26 18:06:40
Not sure, gonna test it out with other JS engines to see how they handle it.
`strict mode` is not mandatory by any means, but it helps avoiding mistakes in the code (via stricter error checking) and might also increase it's performance. So, yes, it is a recommended mode of operation. You can read more about it >>here<< (https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Strict_mode)
Could you please try the Nightly build (see the link in the first post of this thread) and see if it produces a more intelligible error message?
PS: @zeremy thanks for all the answers in this thread =)
Post by: davideleo on 2019-02-27 21:30:31
Seems like I spoke too soon. The script stopped working once again, but I can't tell if I got mistaken when I tested it or if I inadvertently made some changes in foobar2000 that affect SMP's behavior. Whatever is, I fixed it, but I still can't understand why SMP and JSP behave differently.
Here's the script as I'm usinig it now. The patch is marked by a comment:
var panel = new _panel("Last.fm Album Art Downloader", ["metadb", "custom_background"]);
function on_playback_new_track(){   //edit for Spider Monkey Panel
console.log("SMP: metadb changed");
console.log("SMP: metadb_func = " + (typeof on_metadb_changed == 'function'));
console.log("SMP: if condition = " + (panel.metadb && np && np.Compare(panel.metadb) && np.RawPath.indexOf("file://") == 0 && (!library_tracks_only || fb.IsMetadbInMediaLibrary(np))));
var ar = panel.tf("$meta_sep(artist,', ',' and ')");
switch (true) {
case !_tagged(ar):
case !_tagged(al):
case _isFile(f):
break;
default:
x.send();
if (o) {
}, 3000);
} else {
break;
RefreshPSS();
} else {
} else {
} else {
From what I can understand of marc2003's original script, the code responsible for the download is all in the on_metadb_changed function, but because we want the code to be executed also when a new track is played, the on_metadb_changed function is invoked by the item_focus_change method of the panel object, on line 11. As far as I know this part of the code should be read only on panel start up, but with the console I was able to see that the item_focus_change method is executed on playback of a new track by JSP. So, is this one of those incorrect behaviors tolerated by JSP, but not by SMP? Or is the item_focus_change method triggered by some other event, I thought maybe it could be related to the built-in playcount, which is set differently by default in JSP and SMP?
Post by: zeremy on 2019-02-28 17:20:03
@davideleo
The difference is that JSP panel.js is different from SMP panel.js
Compare the two files and you will see that in JSP panel.js
is defined
In SMP panel.js  it is not defined
Your edit added the missing function.
TIL : When migrating a custom JSP script we should also check its include files.
Post by: davideleo on 2019-02-28 17:45:08
is defined
Can you please point me to the relevant code lines? I've been comparing the two panel.js versions for the last two days, but I couldn't find it. I must say the whole panel script is pretty hard for me to read, because of the many cross-references and the use of activex objects that I'm not familiar with.
Post by: zeremy on 2019-02-28 17:53:58
JSP
https://github.com/marc2k3/foo_jscript_panel/blob/master/foo_jscript_panel/samples/complete/js/panel.js#L15
SMP
https://github.com/marc2k3/smp_2003/blob/a0e578ec06211b1d4b01f529962142bf50a75da5/js/panel.js
Post by: davideleo on 2019-02-28 18:03:40
JSP
SMP
OMG! I can't believe I totally ignored those callabacks  :-[  I was concentrating on the panel object only.
Post by: philodoxxx on 2019-03-05 18:11:15
 The error is pretty much the same with the nightly build:
Error: Spider Monkey Panel v1.1.6-beta+0191969 (JS Smooth Browser by Br3tt aka Falstaff)
Resize failed:
Failed to create GdiPlus object (0X0): No error
File:
Stack trace:
  get_images@:3500:24
  oBrowser/this.update@:1526:3
  oBrowser/this.setSize@:1548:3
  on_size@:3120:3
Post by: zeremy on 2019-03-05 19:28:42
@philodoxxx
Try clearing the Panel Properties
Post by: TheQwertiest on 2019-03-06 11:13:03
Could you try again with the latest Nightly? It should produce a proper error message now.
Post by: zeremy on 2019-03-06 18:20:15
@TheQwertiest
You can reproduce @philodoxxx error if you select Display > Album Art Grid
Post by: TheQwertiest on 2019-03-06 19:00:19
@TheQwertiest
Post by: davideleo on 2019-03-09 14:41:24
I noticed on one of my scripts that the on_paint() function always increases memory usage, without releasing it, until eventually foobar2000 has no alternative, but crash. I can't tell if this was happening before switching to SMP, because I never really analysed my scripts in this connection, but the flaw is likely in something I ignore about memory allocation and garbage collection.
I'm posting here the on_paint() code, only, because the complete script is quite long, but if it helps I can post the rest of it. For reference: it's a playlist manager script.
function on_paint(gr) {
var PlaylistVisible = (fso.FileExists(SettingsPath + "PlaylistVisible"));
var MenuVisible = fso.FileExists(SettingsPath + "MenuVisible");
VisibleItemsCount = (wh / row_height);
ScrollerHeight = Math.max(wh * VisibleItemsCount / UserPlaylistsCount, 30);
    ScrollerExtension = ScrollerHeight - (wh * VisibleItemsCount / UserPlaylistsCount);
    scrollbar_w = MenuVisible?17:0;
idxStart = Math.max(idxStart, SysPlaylistsCount);
idxEnd = Math.min(TotalPlaylistsCount, idxStart + Math.ceil(VisibleItemsCount));
var x = gr.CalcTextWidth(" ", font);
    var w = ww - x - scrollbar_w;
var h = row_height;
    for (i = idxStart; i < idxEnd; i++) {
        var y = row_height*(i - idxStart);
        var MouseHover = (x <= mouse_x) && (mouse_x <= x + w) && (y <= mouse_y) && (mouse_y < y + h);
var ActiveVisible = PlaylistVisible && plman.ActivePlaylist == i;
        var icon = plman.PlayingPlaylist == i && fb.IsPlaying?String.fromCharCode(57369):String.fromCharCode(57368);
        var text = "  " + icon + (MenuVisible?"   " + plman.GetPlaylistName(i):"") + (SHOW_COUNT?" [" + plman.PlaylistItemCount(i) + "]":"");
        var textColor = ActiveVisible?colours.White:offcolour;
        var bgColor = MouseHover?setAlpha(colours.Gray, 60):setAlpha(colours.Black, 0);
        if (!dragging && !scrolling) gr.FillSolidRect(x, y, w, h, bgColor);
        if (ActiveVisible) gr.FillSolidRect(x/2, y, x/2, h, RGBA(255,255,255,255));
gr.GdiDrawText(text, font, textColor, x, y, w, h, IFormat);
        if (dragging && MouseHover) gr.FillSolidRect(x, y + drag_down*row_height, w, 1, offcolour);
    scrollbar_y = (idxStart - SysPlaylistsCount) * (wh - ScrollerExtension) / UserPlaylistsCount;
    gr.SetSmoothingMode(1);
    if (MenuVisible && (scrollbar || (SCROLLBAR_MODE == 0))) gr.FillRoundRect(ww - scrollbar_w, scrollbar_y, scrollbar_w, ScrollerHeight, 1, 1, RGBA(255,255,255,100));
    gr.SetSmoothingMode(0);
Post by: TheQwertiest on 2019-03-11 14:26:45
@philodoxxx Thanks for the bug report! It will be fixed in the next release, in the meantime you can apply the following fix manually - https://github.com/TheQwertiest/foo_spider_monkey_panel/pull/62/files
I noticed on one of my scripts that the on_paint() function always increases memory usage, without releasing it...
Doesn't look like there is anything that could cause a memory leak in your code. To diagnose the issue I need the full (i.e. working) sample. Ideally it should be stripped down as much as possible =)
Post by: TheQwertiest on 2019-03-11 14:29:34
[EDIT] Accidental double-post
Post by: davideleo on 2019-03-11 18:08:11
If you mean the whole script, here it is:
'use strict';
window.DefinePanel('YouFy Playlist Manager', {author:'davideleo'});
include(fb.ComponentPath + 'docs\\Flags.js');
include(fb.ComponentPath + 'docs\\Helpers.js');
include(fb.ProfilePath + 'scripts\\SMP\\YouFy common.js');
var i = 0;
var SysPlaylistsCount = 0;
var UserPlaylistsCount = 0;
var TotalPlaylistsCount = 0
var idxStart = 0;
var idxEnd = 0;
var idxFrom = -1;
var idxTo = -1;
var mouse_x = -1;
var mouse_y = -1;
var dragging = false;
var scrollbar = false;
var scrolling = false;
var SCROLLBAR_MODE = window.GetProperty("Scrollbar Mode", 2); //0=always, 1=never, 2=auto hide
var SHOW_COUNT = window.GetProperty("Show TrackCount", true);
var row_height = Number(ReadSettingsValue("RowHeight", 45));
var DPI = ReadSettingsValue("DPI", 96);
var iconfont = ReadSettingsValue("iconfont","youfy mdl2 assets");
var font_size = 16;
var font_height = font_size * DPI / 72;
var font = gdi.Font(iconfont, font_height, 0);
var IFormat = DT_LEFT | DT_VCENTER | DT_SINGLELINE | DT_END_ELLIPSIS | DT_NOPREFIX;
count_playlists();
function on_size() {
    ww = window.Width;
    wh = window.Height;
var h = row_height;
drag_down = y >= mouse_y;
    mouse_x = x;
    mouse_y = y;
    scrollbar = (UserPlaylistsCount > VisibleItemsCount && SCROLLBAR_MODE != 1);
    if(scrolling){
        scrollbar_y = Math.max(exScrollbar_y + y - lbtn_down_y, 0);
        if(scrollbar_y + ScrollerHeight > wh) scrollbar_y = wh - ScrollerHeight;
        idxStart = Math.floor(scrollbar_y * UserPlaylistsCount  / (wh - ScrollerExtension)) + SysPlaylistsCount;
        if(idxStart > TotalPlaylistsCount - VisibleItemsCount) idxStart = TotalPlaylistsCount - VisibleItemsCount;
window.Repaint();
function on_mouse_lbtn_down(x, y){
    if(x > ww - scrollbar_w) {
        if(y > scrollbar_y && y < scrollbar_y + ScrollerHeight) {
            exScrollbar_y = scrollbar_y;
            lbtn_down_y = y;
            scrolling = true;
        } else {
            if (y < scrollbar_y) idxStart = Math.max(idxStart - VisibleItemsCount,0);
            if (y > scrollbar_y + ScrollerHeight) idxStart = Math.min(idxStart + VisibleItemsCount, TotalPlaylistsCount - VisibleItemsCount);
    } else {
        idxFrom = GetPlaylistIdx(y);
        plman.ActivePlaylist = idxFrom;
        fso.CreateTextFile(SettingsPath + "PlaylistVisible").Close();
        if (plman.GetPlaylistName(plman.ActivePlaylist)){
            WriteSettingsValue("ActivePlaylist",plman.GetPlaylistName(plman.ActivePlaylist));
            WriteSettingsValue("PlaylistType",plman.IsAutoPlaylist(plman.ActivePlaylist)?"Autoplaylist":"Playlist");
        RefreshPSS();
        dragging = true;
mouse_y = y;
    window.Repaint();
function on_mouse_leave() {
    mouse_x = -1;
    mouse_y = -1;
    scrollbar = false;
    window.Repaint();
function on_mouse_lbtn_up(x, y){
    idxTo = GetPlaylistIdx(y);
    if (dragging) plman.MovePlaylist(idxFrom,idxTo);
    dragging = false;
    scrolling = false;
    window.Repaint();
    RefreshPSS();
function on_mouse_lbtn_dblclk(x, y){
    if(x < ww - scrollbar_w){
plman.PlayingPlaylist = GetPlaylistIdx(y);
fb.Play();
window.Repaint();
function on_mouse_rbtn_down(x, y, mask){
    var idx = GetPlaylistIdx(y);
    var ContextMenu = window.CreatePopupMenu();
    var _ScrollbarOption = window.CreatePopupMenu();
    ContextMenu.AppendMenuItem(MF_STRING, 1, "Rename...");
    ContextMenu.AppendMenuItem(MF_STRING, 2, "Remove");
    ContextMenu.AppendMenuItem(MF_STRING, 3, "Save...");
    ContextMenu.AppendMenuItem(MF_STRING, 11, "Move to top");
    ContextMenu.AppendMenuItem(MF_STRING, 12, "Move to bottom");
    ContextMenu.AppendMenuSeparator();
    if (plman.IsAutoPlaylist(idx)){
        ContextMenu.AppendMenuItem(MF_STRING, 4, "AutoPlaylist Format");
    ContextMenu.AppendMenuItem(MF_STRING, 5, "Show Track Count");
    ContextMenu.CheckMenuItem(5, SHOW_COUNT?1:0);
    _ScrollbarOption.AppendTo(ContextMenu,0, "Show Scrollbar");
    _ScrollbarOption.AppendMenuItem(MF_STRING, 6, "Always");
    _ScrollbarOption.AppendMenuItem(MF_STRING, 7, "Never");
    _ScrollbarOption.AppendMenuItem(MF_STRING, 8, "Auto Hide");
    _ScrollbarOption.CheckMenuRadioItem(6,8,SCROLLBAR_MODE + 6);
    if (mask == 6||mask == 14){
        ContextMenu.AppendMenuItem(MF_STRING, 9, "Properties");
        ContextMenu.AppendMenuItem(MF_STRING, 10, "Configure...");
    if(idx != null){
        switch(ContextMenu.TrackPopupMenu(x, y, 0)){
            case 1:
            plman.ActivePlaylist = idx;
            fb.RunMainMenuCommand("File/Rename Playlist") ;
            break;
            case 2:
            plman.RemovePlaylist(idx);
UserPlaylistsCount = TotalPlaylistsCount - SysPlaylistsCount;
            plman.ActivePlaylist = Math.min(idx, UserPlaylistsCount - 1);
            window.Repaint();
            break;
            case 3:
            fb.SavePlaylist();
            break;
            case 4:
            plman.ShowAutoPlaylistUI(idx);
            break;
            case 5:
            SHOW_COUNT = !SHOW_COUNT;
            window.SetProperty("Show TrackCount", SHOW_COUNT);
            ContextMenu.CheckMenuItem(5, SHOW_COUNT);
            window.Repaint();
            break;
            case 6:
            SCROLLBAR_MODE = 0;
            window.SetProperty("Scrollbar Mode", 0);
            _ScrollbarOption.CheckMenuRadioItem(6,8,6);
            break;
            case 7:
            SCROLLBAR_MODE = 1;
            window.SetProperty("Scrollbar Mode", 1);
            _ScrollbarOption.CheckMenuRadioItem(6,8,7);
            break;
            case 8:
            SCROLLBAR_MODE = 2;
            window.SetProperty("Scrollbar Mode", 2);
            _ScrollbarOption.CheckMenuRadioItem(6,8,8);
            break;
            case 9:
            window.ShowProperties()
            break;
            case 10:
            window.ShowConfigure();
            break;
            case 11:
            plman.MovePlaylist(idx, SysPlaylistsCount);
            window.Repaint();
            break;
            case 12:
            plman.MovePlaylist(idx, TotalPlaylistsCount - 1);
            window.Repaint();
            break;
            default:
            break;
function on_drag_over(action, x, y, mask){
    mouse_x = x;
    mouse_y = y;
window.Repaint();
function on_drag_drop(action, x, y) {
action.Playlist = idx;
action.ToSelect = false;
function on_playlists_changed() {
count_playlists();
window.Repaint();
function on_notify_data(name, info) {
    switch(name) {
        case "refresh":
        window.Repaint();
RefreshPSS();
        break;
        case "row height":
        row_height = info;
        window.Repaint();
        break;
function GetPlaylistIdx(y) {
    return Math.floor(y / row_height) + idxStart;
function count_playlists(){         //system playlists are prefixed with a "#" and must be hidden from the playlist manager.
TotalPlaylistsCount = plman.PlaylistCount;
for (i = 0; i < TotalPlaylistsCount; i++) {
if (plman.GetPlaylistName(i).search("#") == 0) {
if (i > SysPlaylistsCount) plman.MovePlaylist(i, SysPlaylistsCount);
SysPlaylistsCount = SysPlaylistsCount + 1;
If you really are willing to review my script (in which case I'd be eternally grateful), for completeness here's also the preprocessed "YouFy common" script:
// Additional functions & flags for the YouFy skin
var SkinPath = fb.ProfilePath + "skins\\YouFy\\";
var ImagesPath = fb.TitleFormat("%images_path%").Eval(true) + "\\";
var ThumbsPath = ImagesPath + "thumbs\\";
var BackgroundPath = ImagesPath + "background\\";
var offcolour = RGB(120,120,120);
function ReadSettingsValue(folder,default_value) {
   if (!fso.FolderExists(SettingsPath)) fso.CreateFolder(SettingsPath);
   var FolderPath = SettingsPath + folder +"\\";
   if(!fso.FolderExists(FolderPath)) {
      WriteSettingsValue(folder,default_value);
      return default_value;
   } else {
      var FolderObj = fso.GetFolder(FolderPath);
      var FolderEnumerator = new Enumerator(FolderObj.Files);
      if(fso.FileExists(FolderEnumerator.item(1))) {
          return FolderEnumerator.item(1).Name;
        } else {
function WriteSettingsValue(folder,value) {
   var FolderPath = SettingsPath + folder;
   if(fso.FolderExists(FolderPath)) {
       for (var i = 1; i < FolderObj.Files.Count + 1; i++) {
           fso.DeleteFile(FolderEnumerator.item(i));
   } else {
       fso.CreateFolder(FolderPath);
   fso.CreateTextFile(FolderPath + "\\" + value).Close();
} else {
} else {
} else {
function Get_taskbar_colour() {
    var Shell = new ActiveXObject("WScript.Shell");
    if (Shell.RegRead("HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Themes\\Personalize\\ColourPrevalence")) {
        if (Shell.RegRead("HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Themes\\Personalize\\EnableTransparency")) {
            return AccentPalette(7);
            } else {
            return AccentPalette(6);
        } else {
            return "0-0-0";
            } else {
            return "16-16-16";
function AccentPalette(item) {
    item = item -1;
    AccentPaletteArray = Shell.RegRead("HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Accent\\AccentPalette");
//  return AccentPaletteArray[4*item] + "-" + AccentPaletteArray[1+4*item] + "-" + AccentPaletteArray[2+4*item];
    return RGB(AccentPaletteArray[4*item], AccentPaletteArray[1+4*item], AccentPaletteArray[2+4*item]);
function Get_dpi() {
return Shell.RegRead("HKEY_CURRENT_USER\\Control Panel\\Desktop\\WindowMetrics\\AppliedDPI");
var library_items = fb.GetLibraryItems();
function list_values(tag, handle_list = library_items, query = tag + " PRESENT", split = true){
var tags = [];
var items = fb.GetQueryItems(handle_list, query)
for (var i = 0; i < items.Count; i++) {
var handle = items[i];
var meta_num = fb.TitleFormat("$meta_num(" + tag + ")").EvalWithMetadb(handle);
for (var j = 0; j < meta_num; j++) {
tags.push(fb.TitleFormat("$meta(" + tag + "," + j + ")").EvalWithMetadb(handle));
fb.ShowPopupMessage(_.uniq(tags.sort(), true).join("\n"));
All in all the script works fluently and the on_paint routine doesn't actually use much memory. What leaves me perplexed is that it is never released. Why would that even happen, unless something's not working properly with the GC?
P.S.
I also wanted to explain that I realized the issue was with the on_paint function because the on_mouse_move function always triggers a repaint. By simply moving the mouse over the panel, the memory increases. After commenting out the repaint instruction, moving the mouse over the panel doesn't increase memory usage by one byte.
Post by: davideleo on 2019-03-11 19:47:51
I uploaded a short video (https://www.dropbox.com/s/p1yrvbnytaq5b66/2019-03-11%2020-30-51.mp4?dl=0) to show what I mean (and maybe it is also of help to who is willing to take a look at my script).
Post by: philodoxxx on 2019-03-11 20:39:49
Thank you. Switching out those few lines in the script did indeed fix the issue. Regards.
Post by: TheQwertiest on 2019-03-12 10:24:50
@davideleo your script looks like this for me
And there were no apparent memory leaks :\
Post by: davideleo on 2019-03-12 13:41:22
Yes, that's because you are missing the "Youfy MDL2 assets" font, which is a collage-font I put together for this skin. Actually there are also a few variables which take their value from text files created by another script.
So, that's a clue, isn't it? Doesn't it close in on the interaction with other scripts or components? I actually already tested it without the black sheep of foobar2000's plug-ins, foo_customdb, but nothing changed.
What about the GC settings in the advanced preferences? Should I  mess around with them?
Post by: davideleo on 2019-03-12 16:02:38
I tested all of my scripts and it turned out it's a general problem. Every on_paint() function seems to increase memory and never release it. Even worse is that there is likely an on_playback_newtrack() function with the same problem, but I still didn't find out which one. That means my foobar2000 is bound to crash sooner or later at every session, even if I don't touch it.
What really put me down is that I also tested the only script I have by another author (marc2003's Last.fm Bio) and guess what? No memory leak at all. This is the proof that the problem is in my scripting.
@TheQwertiest when you write that there were no apparent memory leaks, do you mean that triggering the on_mouse_move() doesn't increase memory usage or that the memory increase is then released? BTW thanks a lot for taking a look.
Post by: juniiflow on 2019-03-13 10:14:47
Anyone knows a quick way to remove or move the now playing arrow on j smooth?
Post by: Strigoy on 2019-03-13 12:58:06
Uh, this 'Edit' menu problem drives me nuts )) I don't get it, why this happens (this only affects 'Edit' submenu, others work just fine):
(https://i.imgur.com/7NQBTxp.png)
but if I use default Menu everything works just fine =>
(https://i.imgur.com/fnDOzg7.png)
I'm using snippet from MainMenuManager All-In-One.js
Speaking of which: I got couple of questions:
1)
contextman.InitNowPlaying();
this is getting called twice for some reason
2)
Am I MisSinG SoMetHing wItH thE CasE herE?
    menuman1.Init('file');
    menuman2.Init('edit');
    menuman3.Init('View');
    menuman4.Init('playback');
    menuman5.Init('library');
    menuman6.Init('help');
Post by: Strigoy on 2019-03-13 21:54:14
Nevermind, guh... I've spent so much time trying to figure it out, but the problem was with panel settings... just unchecked 'grab focus' and it's working as intended.
My god, that's so silly...
Post by: TheQwertiest on 2019-03-14 12:25:39
Not sure what's going on here - it works fine for me (both with `Grab Focus` enabled and disabled).
1) this is getting called twice for some reason
2) Am I MisSinG SoMetHing wItH thE CasE herE?
Because reasons :D
Those are just typos.
Post by: davideleo on 2019-03-14 16:40:17
Spoiler (click to show/hide)
I tested my script on a clean installation with no other plug-in, but spider monkey panel. The memory leak was more than apparent. How did you test it?
I really need to get to the bottom of this problem, because it is making spider monkey panel unusable for me.
P.S.
BTW, on a clean installation I realized that the reason for that appearance is that the script does not find the "MenuVisible" file (without extension) in the "settings" folder inside the foobar2000 configuration folder. It is normally created by another script.
Post by: davideleo on 2019-03-14 18:12:21
P.P.S.
I tested some of the sample scripts to see if I could find at least one with a similar behaviour. Eventually I found that the "track info + seekbar + buttons" by marc2003 increases memory usage by 0,8-9 MB at every button click without releasing it, but it looks like marc2003 managed the issue, because it is released when (and apparently only if) the total memory delta is around 20MB.
EDIT
I made a mistake: it's not the button click that increases memory, but the playback state change, triggered by the button click.
Post by: davideleo on 2019-03-14 23:58:52
I made some steps forward in my inquiry on the memory-greedy script.
First of all I realized that memory usage increases only when several repaint actions are executed sequentially at close intervals, therefore I managed to lessen its impact by limiting the repaint action to when it is actually required, rather than on any on_mouse_move event.
That didn't solve the issue, though, and if I move the mouse very quickly, over the panel, I can still reproduce it, even if it takes longer to reach dangerous levels.
Anyway, I finally tested the same script on a JScript panel, on the same clean installation of the Spider Monkey panel. Here (https://www.dropbox.com/s/0yci9nfctu70cx6/2019-03-14%2023-38-45.mp4?dl=0)'s what happened (yes, I know I look like a weirdo). I moved the mouse up and down on the JScript panel for about one minute and - as you can see in the task manager - the memory level is stuck on 677,2 MB. There is only a slight increase towards the end, released right after. The same action on the Spider Monkey panel immediately starts raising the memory in use and after one minute it's well over 680 MB.
Sorry if I sound obsessed, but since I'm still learning javascript, it's very important for me to understand what I didn't get right, before I move on to more advanced scripting.
Post by: TheQwertiest on 2019-03-15 09:08:25
That's just GC kicking in - it has several triggers, one of which is the amount of allocated memory. I.e. you don't have to `Dispose` anything manually in 99.9% cases in SMP.
You should not =)
The memory increase is minuscule and it's not permanent - it's  cleaned up properly after sometime with GC (i.e. it's not a leak).
[EDIT] Can you download the debug version of SMP and enable GC zeal and check if memory is still leaking for you?
Debug version: https://ci.appveyor.com/api/buildjobs/rylakh87w1kuotm2/artifacts/_result%2FWin32_Debug%2Ffoo_spider_monkey_panel.fb2k-component_debug
GC Zeal: Preferences > Advanced > Display > Spider Monkey Panel > GC > Zeal > Enable
Post by: TheQwertiest on 2019-03-15 12:59:12
@davideleo you can also try the latest Nightly build (which is available via link in OP) - I might have fixed the leak there.
Post by: davideleo on 2019-03-15 14:11:18
With the nightly build (1.1.6-beta+80ac164) the behavior is unchanged and when I try installing the debug version I get this message:
Failed to load DLL: foo_spider_monkey_panel.dll
Post by: davideleo on 2019-03-15 15:53:14
With the nightly build (1.1.6-beta+80ac164) the behavior is unchanged...
I think it was not the latest version. Anyway I just tried  1.1.6-beta+f3d6584 and it behaves in the same way.
Post by: TheQwertiest on 2019-03-15 15:54:10
Are you sure? Note that GC does not kick in immediately, that is 10mb of allocated memory is not enough to trigger GC. Try reaching 100mb of allocations.
I will send you a PM with missing dlls later this evening or tomorrow.
Post by: davideleo on 2019-03-15 20:25:07
You are right! I gave the job to a timer, set to execute the repaint action once every millisecond. Right after startup, foobar2000 was using 677MB. After about 7 minutes the GC kicked in and memory usage dropped from 825MB to 690MB. I didn't clear the timer the first time and watched it repeat the cycle with the exact same values.
Just to make sure I tested the release version, too, and to my surprise it performed even better, dropping from 820MB to 687MB.
That's quite encouraging, even though I don't really understand why a script like mine would use so much memory for what to me looks basically like reassigning already allocated variables.
Thanks a lot, I really appreciate your attention.
Post by: TheQwertiest on 2019-03-16 12:06:53
GC is tuned for the best performance with multiple active SMP panels and heavy-allocating scripts, so it might be not aggressive enough for simple (that is light-allocating) scripts. That said, your case helped me to discover a bug, which made GC to be more lenient with memory allocation than it should've been. You can check out the fix with the latest Nightly build =)
Post by: davideleo on 2019-03-16 17:10:51
I just tested the script with beta version 2fdc8be and it behaves similarly, perhaps slightly worst: GC kicked in at 835MB (higher threshold than beta f3d6584) and dropped to 694MB (higher residual than beta f3d6584).
The fact remains that with JScript panel the same script does not raise memory usage at all. I recorded one more video (https://www.dropbox.com/s/p6fn2aj9odp7bcb/2019-03-16%2017-04-44.mp4?dl=0) which shows the task manager while two identical foobar2000 installations run the same script, one with JScript panel and one with Spider Monkey panel. The timer is set on start-up, and the two installations are launched simultaneously. Mind that no dispose() method was added in the JScript panel version.
I'm a bit puzzled now: is JScript panel better tuned for light-allocating scripts? Is it more advisable for simple ones like mine?
Post by: TheQwertiest on 2019-03-17 22:39:09
Hm... That's weird... I'm currently reworking GC a bit, so hopefully the memory usage will go down with next builds.
Because JSP does not have GC at all, which has it advantages like never using more memory than currently needed, but at the cost of the performance. See the following post for a bit more info and performance trade-off example: https://hydrogenaud.io/index.php/topic,116669.msg963036.html#msg963036
I've never said anything like that. SMP and JSP are different beasts with different memory allocation policies. SMP uses (generally) more memory than JSP, but provides enhanced performance and smoother UX instead.
What I did say, is that I tuned SMP GC policies for more heavy scripts. So, while it uses more memory with light scripts than it could've (i.e. it would accumulate more memory before purging it), it consumes CPU time drastically less with heavy scripts than it would've otherwise (which results in smoother UX and etc and etc).
Post by: davideleo on 2019-03-18 20:59:57
What I did say, is that I tuned SMP GC policies for more heavy scripts. So, while it uses more memory with light scripts than it could've (i.e. it would accumulate more memory before purging it), it costumes CPU time drastically less with heavy scripts than it would've otherwise (which results in smoother UX and etc and etc).
I see, that makes sense, thanks for the explanation. I couldn't quite relate it to what I's experiencing because other heavy-looking scripts by professional coders didn't increase memory usage as much and my fear was that I was ignoring some basic good practice in my scripts. Eventually I found at least one professional script with a much bigger impact on memory and that reassured me a bit.
Post by: TheQwertiest on 2019-03-19 15:01:43
@davideleo Please try the latest build again.
Post by: davideleo on 2019-03-20 14:34:04
I'm testing beta 6cc1cbd. The memory increases at a similar pace than the previous ones, but apparently GC comes round more often and with a smaller truck.
With foobar2000 starting up at 670-680 MB, beta 2fdc8be and the stable release both need at least 825-835 MB (but today it was 850-860 MB, just to make things more random!) before dropping to more or less 700 MB. Beta 6cc1cbd drops from 800-810 MB to 760 MB.
My two cents: by looking at the first cycle only, it would seem a lot better. I wonder, though, whether a higher garbage residual means that, on the long run, the average memory usage is bound to increase more rapidly. What is also hard to tell is how multiple panels, working together in a real usage set up, would actually perform: analytically speaking the single panel is better off with a lower peak, but a higher residual means that the overall uncollected garbage level is generally higher. So, except for the very rare case of all scripts approaching their memory cap at the same time, I can't tell really which one is more advisable.
Post by: TheQwertiest on 2019-03-20 15:53:02
Mind though, that you should differentiate between total memory usage (i.e. via task manager) and SMP memory usage (via `window.TotalMemoryUsage`).
Whatever the case it should not `leak` anymore. That is, SMP average memory usage should stay mostly the same.
Post by: davideleo on 2019-03-20 20:37:40
I monitored the memory values for over 2 hours (not literally, I recorded 2 hours of task manager and then scrolled the frames through) because I was curious of the GC behavior on the long run, so now I have a bigger picture. The new beta stabilizes already after the first GC action, whereas the previous beta and the stable release keep on raising the baseline - and to a lesser extent the peak level - for over one hour! That's a long time and if you don't know it will come to an end, it really looks like a bad memory leak. The comparison I made above did not take this into account: I compared the stabilized memory baseline of the new beta with the still growing baseline of the other two. Once the values are stable, the winner is the new beta by all means.
You shouldn't have told me. Now I know what I'll do in the next days.
Post by: davideleo on 2019-03-20 20:46:39
And now for something completely different: is it possible to read and edit the search pattern of an autoplaylist via JScript?
Post by: Ottodix on 2019-03-21 09:17:26
Yep :) plman.ShowAutoPlaylistUI(pl_idx);
Post by: davideleo on 2019-03-21 14:57:29
As far as I know that opens the autoplaylist properties dialog window. I want to read (and possibly edit) the query pattern by code.
Post by: TheQwertiest on 2019-03-21 15:26:19
fb2k does not provide such API, so neither SMP nor JSP have this feature.
Post by: TheQwertiest on 2019-04-03 17:12:29
I apologize for the lack of updates (and the promised fixes), so here is a bit info to those who care(^^):
Recently my motivation suffered a huge blow from Mozilla and it's shenanigans, which (coupled with my usual lack of free time) mostly stalled any progress on the next SMP release. Hopefully, the motivation will restore itself (at least partially) soon enough, but it may take some time...
Regardless, the current SMP version (and the nightly build as well) should be stable enough to last till the new release =)
Post by: davideleo on 2019-04-03 18:20:19
No need to apologize: as far as I remember, hardly any component has had the support you've been providing so far.
Post by: WilB on 2019-04-03 18:47:50
@TheQwertiest
That's disappointing news & hopefully not too restrictive in the future. All your excellent hard work & effort is much appreciated on this marvellous plug-in.
Post by: wcs13 on 2019-04-20 17:51:41
Hi everybody,
So this may be the successor of the excellent JScript Panel ! Great news !
Is there an updated list of the already-compatible scripts, with the corresponding codes ? That would help a lot.
I'm thinking about marc2003 scripts... Plus WilB's Biography View... etc..
Post by: TheQwertiest on 2019-04-20 22:28:38
There is no such list (yet?).
All WilB's script are SMP compatible though.
Post by: TheQwertiest on 2019-04-20 22:33:47
@davideleo , @WilB , thanks for your kind words and support, really appreciated =)
It was not anything really huge (like DMCA), but rather the state of the current and the future support of Mozilla SpiderMonkey embeddings...
Post by: TheQwertiest on 2019-04-22 17:15:22
Version: 1.2.0
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.2.0
Changelog:
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v120
Post by: kutuzof on 2019-04-23 15:03:23
https://drive.google.com/open?id=1Me4EUu65bn9vCJ4E1ZUgubPx48DaHXqK
Post by: TheQwertiest on 2019-04-23 19:16:46
@kutuzof , can you try the latest Nightly build and see if it fixes the freeze?
Post by: louiscoim on 2019-04-23 20:41:28
Hello TheQwertiest, and everybody else, off course..
I have very simple question:
Is there a way to port WSH Coverflow  to an SMP Script?
I mean, I know Chronial's Coverflow or even Bubble Coverflow are more advanced components, but my PC doesn't support them as
I get the pixelformat error because of my old Intel HD graphics chip.. I tried everything possible to fix this issue (from drivers to installing open EL/GL solutions)..
If it isn't possible, no need to tell me why, I don't know much about scripting and I must say that: I admire a lot Your work and think it's awesome!!
Anyway, Thanks in Advance.
Peace
Post by: kutuzof on 2019-04-24 07:39:49
Thanks, I tried the nightly build, while it seems to work well.
Post by: TheQwertiest on 2019-04-24 16:35:15
Version: 1.2.1
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.2.1
Changelog
Hotfix for v1.2.0 (see changelog above (https://hydrogenaud.io/index.php/topic,116669.msg970630.html#msg970630))
Post by: davideleo on 2019-04-24 17:09:04
How safe is it to add custom methods and properties to default SMP objects?
Post by: TheQwertiest on 2019-04-24 18:53:04
Never tried, but should be probably safe (if it works :D), since all SMP objects are proper JS objects. Obviously there are some limitations - e.g. you can't make a deep copy of (most) SMP objects (unless it's stated explicitly otherwise in docs).
Post by: acmodeu on 2019-04-24 21:05:30
Tried to migrate to Spider Monkey. Added volume bar from https://github.com/timonwong/foo_uie_wsh_panel_mod/blob/master/samples/Volbar%20with%20GdiDrawText.txt
Got this on gr.FillGradRect(  0, 0, pos , wh, 90, RGB(240,240,240), RGB(46,48,63));
Error: Spider Monkey Panel v1.2.1 (MyScript v1.2.3 by Me)
FillGradRect failed:
GdiPlus error: SetBlendTriangularShape failed with error (0X2): InvalidParameter
File: <main>
Line: 45, Column: 2
Stack trace:
  on_paint@<main>:45:2
Post by: davideleo on 2019-04-24 21:42:10
I think the error is generated when the width argument is equal to 0, that is when "pos" is equal to "ww". I guess you have to manage that eventuality with something like:
line 51         if (pos != ww) gr.FillGradRect(pos, 0, ww - pos, wh, 90, RGB(240, 240, 240), RGB(190, 190, 190));
P.S.
I just realized you got the error on the previous FillGradRect function, on line 50. Obviously the same applies to both:
    if (pos != 0) gr.FillGradRect(0, 0, pos, wh, 90, RGB(240, 240, 240), RGB(100, 230, 100));
Post by: TheQwertiest on 2019-04-24 22:37:02
@acmodeu, there is no need to update this sample manually - it's available as part of SMP package (samples/basic/Volbar with GdiDrawText.js).
PS: @davideleo, your reasoning is correct =)
Post by: TheQwertiest on 2019-04-24 22:43:23
You can try using the following guide: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/JScript-to-SpiderMonkey-migration-guide
Post by: acmodeu on 2019-04-25 14:59:16
@davideleo, @TheQwertiest thank you guys!
Post by: Ottodix on 2019-04-25 17:35:14
Big thanks TheQuertiest for your work on this component!
I released a theme based on this, you can get it there if you want to try it:
(https://i.ibb.co/4Tmh9TB/preview-tn.jpg)   https://github.com/Ottodix/Eole-foobar-theme
Most of this theme is made possible by SMP
Post by: TheQwertiest on 2019-04-25 17:53:56
Looks awesome! Guess it's time to make that script showcase page :D
It might be a good idea to create a separate thread for your theme though, otherwise it might get lost in this thread and not get the attention it deserves...
Post by: davideleo on 2019-05-01 18:56:47
Conceptual question: what is the use of setting to null the variable that holds the graphics object, after using the GetGraphics() and thereon the ReleaseGraphics() methods?
Post by: Ottodix on 2019-05-02 14:03:59
Making sure that the GC collect and free up the allocated memory for this graphic object, if you declared it as a global variable ? That's my guess
Post by: davideleo on 2019-05-02 14:58:03
...if you declared it as a global variable...
In the sample scripts I've seen, it is always declared locally and nevertheless set to null at closure. But isn't it redundant after the ReleaseGraphics() method, given how spider monkey GC works?
P.S.
I noticed the StackBlur (text).js sample script does not bother to set the graphics object variable to null, after running the ReleaseGraphics() method. It's the only exception, though. What is the difference, for example, with the thumbs.js sample script? Why is setting the graphics object variable to null required in the latter and not in the first?
Title: Re: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: Joulupukki on 2019-05-02 20:52:09
@TheQwertiest: many thanks for your Spider Monkey Panel!
@TheQwertiest and other other developers:
Would it be possible to have a simple code for a simple volume control with 2 images: a dot and a knob with your panel?
(I've both images)
Thanks in advance.
Post by: Joulupukki on 2019-05-04 19:00:16
Well,, I swtched to WSH panel mod and the "DarkOne Volume Knob Panel  v3.1" vworks fine now  with my Foobar v1.4.3 (DUI).  :)
Post by: davideleo on 2019-05-13 15:20:15
I'm working on a one-panel theme and so I turned some of my stand-alone scripts to objects. With stand-alone scripts, though, we are able to draw portions of graphic elements by placing the drawing coordinates virtually outside of the window, relying on the fact that only the pixels inside the window will be painted. This is especially helpful (at least it helped me) in animating a scrolling motion.
Obviously this trick is not available in a one-panel script, where coordinates outside of the target area (the area I actually want to paint) are nevertheless inside the main window, and will be painted anyway.
So, is there a general way to mask or clip the portion of a graphic element that falls outside of a given area?
Let's say I have an object with x, y, width and height properties which define a region of the window, and than a draw() method which executes a few GdiGraphics methods. I want to make sure that when the draw() method is called, only the region defined by the object x, y, width and height properties is painted. How can I achieve that?
Post by: davideleo on 2019-05-13 19:19:54
For the record, I actually managed to get the above mentioned effect, but I cannot stress enough how much I dislike my solution:
var repainting = false;
var repaint_done = false;
var myObj = new PaintRegion(700, 400, 500, 300)
function on_paint(gr){
    myObj.paint(gr);
function PaintRegion(x, y, w, h){
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
    this.paint = (gr) => {
        if (repainting) // some GdiGraphics method...
        repainting = !repainting ;
        if (!repaint_done) window.RepaintRect(this.x, this.y, this.w, this.h);
        repaint_done = true
I'm not comfortable triggering a RepaintRect method with the on_paint() callback and I have to pay attention that whenever the on_paint event is called, the repainting and repaint_done global variables are set to the proper value. If this is the right direction I can work on it to make it safe, but I reckon there must be a better way.
P.S.
After some tests with multiple objects I settled on the following version which seems to be pretty fluent:
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
    this.repainting = false;
    this.repaint_done = false;
        if (this.repainting) //draw something...;
        this.repainting = !this.repainting;
        if (!this.repaint_done) window.RepaintRect(this.x, this.y, this.w, this.h);
        this.repaint_done = !this.repaint_done
Still looking forward to insights from skilled coders.
Post by: davideleo on 2019-05-13 23:44:11
Update: the above solution is okay if the objects are separate, but it gets buggy when they overlap.
Post by: MordredKLB on 2019-05-14 18:38:02
Unless I'm missing something, RepaintRect just clips the area that is currently drawn to the screen. So if I draw a rectangle from 0,0,100,100 to the gr buffer, and I'm only painting the region from (50,50 -> 100,100), the next time a full repaint is done, the rectangle will be completely drawn from 0,0 -> 100,100.
Also, it's my understanding that RepaintRect isn't something that causes a draw to happen immediately. It just specifies the region which will be drawn to the screen and that region is the union of the outermost extants of the region on the next draw cycle. So if I do RepaintRect(10,10,20,20) and then another RepaintRect(1000,1000,20,20) before the contents are actually drawn, when the drawcycle occurs it'll actually draw (10,10) -> (1020,1020). I'm assuming the underlying gdi stuff hasn't changed for Spidermonkey.
Post by: davideleo on 2019-05-14 20:27:04
Yes, unless you do this:
var myRegion = new PaintRegion(50, 50, 100, 100)
    myRegion.paint(gr);
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
        if (this.repainting) {
            gr.FillSolidRect(0,0, window.Width, window.Height,0xFF000000);  // these are just examples,any other
            gr.DrawEllipse(80, 30, 200, 200, 2, 0xFFFFFFFF)                 // GdiGraphics method goes here.
            this.repaint_done = true;
        if (!this.repaint_done) {
            this.repainting = true;
The full paint is done only if the repainting property is true, but this is set to false by default and it is not touched when a full paint is called. It is turned to true only for the RepaintRect method to reference it, and than back to false right after its execution. The repaint_done property works the other way round, in order to prevent a RepaintRect loop.
The above code works, but in my new project I built a system of nested objects, that pass the paint action (any action actually) on to their content, and that's where it gets tricky, but it's a very specific problem for that script.
Anyway, I'd prefer, and I'm still looking for (I still did not look into the Catrox scripts!  :-[ ), an alternative method that doesn't use the on_paint() callback to trigger the RepaintRect() method, for obvious safety reasons, but also because it would probably work in my nested objects chain.
I'm not sure about that. From what I read in the docs, it behaves like the Repaint() method. Doesn't that call an immediate window repaint?
Post by: davideleo on 2019-05-14 23:10:11
Sorry, I just realized the last line of code which resets the repaint_done property to false, must not be in the conditional section, but right after:
    myRegion.paint(gr);
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
       this.repaint_done = false;  // <---------
I don't really understand why, though. It seems that the RepaintRect method aborts the execution of the previously called on_paint() function that triggered it. Is that correct?
Post by: davideleo on 2019-05-15 00:11:46
Alright, I think I understand now what @MordredKLB was telling me in his previous reply (https://hydrogenaud.io/index.php/topic,116669.msg971412.html#msg971412): the new paint event called by the RepaintRect() method is queued and executed only when the first paint event that triggered it is popped off the stack. Right?
Post by: MordredKLB on 2019-05-15 01:23:49
Not exactly. Say you have a function that calls window.RepaintRect() twice in a row so that two buttons are repainted. It's my understanding that your on_paint method will only be called once the next time a WM_PAINT message is received by the foobar window, and that the cliprect for the area drawn will be the union of the exterior bounds (although that I'm less sure on).
Basically the Javascript is single-threaded, but the operating system isn't, and it queues up the areas that will be drawn.
Post by: davideleo on 2019-05-18 16:19:43
I finally found out how @TheQwertiest managed to solve the above issue in his CatRox theme. It's pretty straightforward actually, but it took me a few days because it was buried in thousands of code lines. So, for who's interested, here is a proper and more reasonable way than the one I came up with:
var myRegion = new PaintRegion(100, 100, 200, 200)
    myRegion.paint(gr);
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
        var clipImg = gdi.CreateImage(this.w, this.h)
        var grClip = clipImg.GetGraphics();
        grClip.DrawEllipse(100, 50, 200, 200, 2, 0xFF000000)
        clipImg.ReleaseGraphics(grClip);
        gr.DrawImage(clipImg, this.x, this.y, this.w, this.h, 0, 0, this.w, this.h)
Post by: cerbaire on 2019-06-05 11:43:45
Hello,
I have a question about on_size event. It has two parameters and documentation indicates that it corresponds to panel size.
I have tested that and saw that it correspond to window size.
I did not do the test with JScript panel, but I would like to know if it the same with the JScript Panel ?
Kind regards,
Post by: TheQwertiest on 2019-06-05 13:44:42
That is impossible - SMP currently does not have a way to find the size of fb2k window. on_size arguments ARE panel width and height respectively.
You can easily verify this by creating a layout with two resizeable SMP panels (e.g. in DUI) and replacing the following line in the default script:
gr.GdiDrawText(g_text, g_font, g_hot ? g_textcolour_hl : g_textcolour, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
with
gr.GdiDrawText(`width: ${ww}, height ${wh}`, g_font, g_hot ? g_textcolour_hl : g_textcolour, 0, 0, ww, wh, DT_VCENTER | DT_CENTER | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
Each panel will display it's size, which will change when they are resized.
Post by: cerbaire on 2019-06-05 18:30:31
Thanks for you response.
I was already displaying width and height but is was the same for my for 4 panels.
After more testing, I decided to add a MinWidth and MaxWidth, idem with height. And it is not respected. I use CUI with horizontal and vertical splitter.
The thing is that a panel stretch to the size of the largest panel inside a column, even if larger than MaxWidth.
When you say 'resizeable SMP panel', do you mean that we can have them not resizeable?
Post by: TheQwertiest on 2019-06-17 11:50:40
MinWidth and MaxWidth properties (and window dimensions adjustment functionality) are not provided by SMP component, but rather by foo_ui_hacks =)
You can use the following code though from my CaTRoX theme though: https://github.com/TheQwertiest/CaTRoX_QWR/blob/61eecfa4159e3714d58f53ae942d5f1861e83fb2/theme/Scripts/Panel_Menu.js#L1018
Note, that you have to change assignments like MinWidth=True to MinWidth.Enabled=True.
I mean smth like parent vertical/horizontal splitter in DUI/CUI that allows for panel size adjustment. There are components that provide panels for CUI/DUI, which allow having other panels inside, but don't allow their resizing.
[EDIT] Disregard this, I can't read...
Post by: Ottodix on 2019-06-26 10:11:57
Does someone knows a trick to trigger a new evaluation of panel stack splitter scripts, from a SMP panel ?
There is the play/pause way, using the function below, because the PerTrack scripts of a PSS panel are evaluate on playback changes, but this creates some sound glitches, especially while playing live streams (because foobar can't buffer the stream when this is a live stream, it need to synchronize with the stream after a pause command)
fb.PlayOrPause();
fb.PlayOrPause();
else {
fb.Play();fb.Stop();
Post by: zeremy on 2019-06-26 19:38:11
fb.PlayOrPause();
fb.PlayOrPause();
else {
There is a trick you can try.
You will need to enable is the PSS panels "Evaluate scripts when track info is modified"
Change your function to
let handle_list = plman.GetPlaylistItems(plman.ActivePlaylist);
handle_list.RefreshStats();
There is a limitation:  Your handle list cannot be empty.
Post by: Ottodix on 2019-06-26 21:28:21
Ah yes, thanks! By combining both methods, you end up with something which work all the time:
function RefreshPSS() {
if (fb.IsPlaying || fb.IsPaused) {
let handle_list = new FbMetadbHandleList(fb.GetNowPlaying());
else {
Important point:
 "Evaluate scripts when track info is modified" needs to be enabled AND on the script tab of the PSS panel, "Titleformat mode on startup" needs to be on "now playing"
Post by: TheQwertiest on 2019-06-27 13:44:23
@cerbaire , I have to apologize: my last answer was answering the wrong question, since I've misread `MinWidth` (present in SMP/JSP) as `MinSize.Width` (foo_ui_hacks)... But you've probably read the (correct) answer by marc2003 by now, so I won't repeat it here... :shame_on_me:
Post by: cerbaire on 2019-06-27 19:17:17
Thanks TheQwertiest, yes I saw marc2k3 response on GitHub.
Post by: spuuunit on 2019-06-27 20:56:20
How can I use foobar2000 code with Spider Monkey Panel code?
This is what I want to do:
$if(%ispaused%,❚❚,▶)‌‌
%title%
%playback_time% / %length%
This is my Spider Monkey Panel code so far:
var font = gdi.Font("Segoe UI", 12, 0);
function Color(r, g, b) {
return 0xFF000000 | r << 16 | g << 8 | b;
    gr.FillSolidRect(0, 0, 1000, 1000, Color(240,240,240));
    gr.GdiDrawText("Playing/Paused - Track Title", font, Color(0,0,0), 5, 1, 226, 1000);
    gr.GdiDrawText("00:00 / 00:00", font, Color(0,0,0), 237, 1, 1000, 1000);
Post by: Decalicatan_Decalicatan on 2019-06-28 14:12:54
Hi everyone,
Does anyone ever hear of a SMP (or marc2003's jscript) code for an library search toolbar (like the Quicksearch toobar component for example?)
There used to be a WSH toolbar in one of Br3tt's theme (xchange I think) but it's kind of old and I'm not sure I will be able to port it to SMP.
Thanks in advance
Post by: davideleo on 2019-06-29 00:27:57
Hi everyone,
Not sure it helps, but here is an adaptation of the script I wrote for my config. It was not meant to work in a component-like fashion, so you might have to edit the code here and there (no window properties, sorry). My coding is much more naive than marc2003's or Br3tt's, but perhaps this makes it easier to grasp and modify.
For reasons I don't understand, it only works with columns ui, maybe some more advanced coder can figure out why,
I still didn't find the time to handle the typing animation when the text's length exceeds that of the width of the panel, so make sure the panel is wide enough for your average search strings.
Search results are displayed in a playlist called "Search results [your search string]", which is overwritten at every new search.
"use strict";
include(fb.ComponentPath + "docs\\flags.js");
include(fb.ComponentPath + "docs\\helpers.js");
include(fb.ComponentPath + "samples\\complete\\js\\lodash.min.js");
var font_height = 18;
var fontcolor = colours.White;
var text = "";
var cursor = 0;
var set_cursor = false;
var selection_lx = 0;
var selection_rx = 0;
var selection = "";
var mouse_lbtn_down = false;
var count = 0;
var timerID;
var timer = false;
var edit = false;
var writing = false;
var ctrla = false;
var dblclk = false;
var dblclk_lx = 0;
var dblclk_rx = 0;
var mouse_lbtn_down_x = 0;
var mouse_move_x = 0;
var obj = new ActiveXObject("htmlfile");
var autocomplete = new Array();
var history = new Array();
history.push(text);
var currentState = 0;
var ww = 0;
var wh = 0;
var text_x = 0;
function on_size(){
    ww = window.Width;
    wh = window.Height;
    var iconfont = "Segoe mdl2 assets";
    var selection_color = colours.Black;
    var icon = String.fromCharCode(57492);
    var textheigth = gr.CalcTextHeight(icon, font);
    text_x = wh + gr.CalcTextWidth(" ", font);
    dblclk_lx = Math.max(text.slice(0, getPos(mouse_lbtn_down_x, text, font, gr)).toString().lastIndexOf(" ") + 1, 0);
    dblclk_rx = getPos(mouse_lbtn_down_x, text, font, gr) + (text + " ").slice(getPos(mouse_lbtn_down_x, text, font, gr)).toString().indexOf(" ") + 1;
    selection_lx = getPos(Math.min(mouse_lbtn_down_x, mouse_move_x), text, font, gr);
    selection_rx = getPos(Math.max(mouse_lbtn_down_x, mouse_move_x), text, font, gr);
    if (dblclk) selection_lx = Math.min(selection_lx, dblclk_lx);
    if (dblclk) selection_rx = Math.max(selection_rx, dblclk_rx);
    if (ctrla) selection_lx = 0;
    if (ctrla) selection_rx = text.length;
    var selection_x = text_x + (gr.CalcTextWidth(text.slice(0, selection_lx), font));
    var selection_w = gr.CalcTextWidth(text.slice(selection_lx, selection_rx), font);
    var text1 = text.slice(0, selection_lx);
    var text2 = text.slice(selection_lx, selection_rx);
    var text3 = text.slice(selection_rx);
    if (set_cursor) {
        cursor = getPos(mouse_lbtn_down_x, text, font, gr);
        set_cursor = false;
    selection = text2;
    var cursor_x = text_x + gr.CalcTextWidth(text.slice(0, cursor), font);
    gr.DrawRect(0, 0, ww - 1, wh - 1, 1, fontcolor);
    gr.GdiDrawText(icon, font, fontcolor, 0, 0, wh, wh, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
    gr.FillSolidRect(selection_x, (wh - textheigth)/2, selection_w, textheigth, colours.Gray);
    gr.GdiDrawText(text1, font, fontcolor, text_x, 0, gr.CalcTextWidth(text1, font), wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
    gr.GdiDrawText(text2, font, selection_color, text_x + gr.CalcTextWidth(text1, font), 0, gr.CalcTextWidth(text2, font), wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
    gr.GdiDrawText(text3, font, fontcolor, text_x + gr.CalcTextWidth(text1, font) + gr.CalcTextWidth(text2, font), 0, gr.CalcTextWidth(text3, font), wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
    if (selection_w == 0 && edit && count%2 == 1) gr.DrawLine(cursor_x, (wh - textheigth)/2, cursor_x, (wh + textheigth)/2, 1, fontcolor);
    if (text == "" && !edit) gr.GdiDrawText("Search", font, fontcolor, text_x, 0, ww - text_x, wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE);
    writing = false;
function on_mouse_move(x, y){
    window.SetCursor(IDC_IBEAM);
    if (mouse_lbtn_down){
        mouse_move_x = x;
        window.Repaint();
    edit = true;
    mouse_lbtn_down = true;
    mouse_lbtn_down_x = x;
    set_cursor = true;
    unselect();
    window.Repaint();
    dblclk = true;
    window.Repaint();
function on_mouse_leave(){
    edit = writing;
function on_focus(is_focused){
    if (is_focused){
        timerID = window.SetInterval(function() {
            count++;
            window.Repaint();
            }, 500);
        timer = true
    } else {
        window.ClearInterval(timerID);
        timer = false;
        count = 0;
        window.Repaint();
function on_char(code){
    if (code > 31) {
        if (selection_lx < selection_rx){
            text = text.slice(0, selection_lx) + String.fromCharCode(code) + text.slice(selection_rx);
            cursor = selection_lx + 1;
            unselect();
        } else {
            text = text.slice(0, cursor) + String.fromCharCode(code) + text.slice(cursor);
            cursor = cursor + 1;
        newState(text);
        var autocompleteMenu = window.CreatePopupMenu();
        var filtered_list = _.uniq(autocomplete, true).filter(filterAutocomplete);
        for (var i = 0; i < filtered_list.length; i++){
            autocompleteMenu.AppendMenuItem(MF_STRING, i + 1, filtered_list[i]);
        var ret = autocompleteMenu.TrackPopupMenu(text_x, wh, 0);
        if (ret > 0){
            text = filtered_list[ret - 1];
            cursor = text.length;
        writing = true;
        window.Repaint();
function on_key_down(vkey){
    var ShiftKeyPressed = utils.IsKeyPressed(VK_SHIFT);
    var ControlKeyPressed = utils.IsKeyPressed(VK_CONTROL);
    if (!ControlKeyPressed){
        switch (vkey){
            case 8: //backspace
                text = text.slice(0, selection_lx) + text.slice(selection_rx);
                cursor = selection_lx;
                unselect();
            } else {
                text = text.slice(0, Math.max(cursor - 1, 0)) + text.slice(cursor);
                cursor = Math.max(cursor - 1, 0);
            newState(text);
            break;
            case 13: //enter
            search();
            text = "";
            cursor = 0;
            history = [];
            newState(text);
            break;
            case 37: //left arrow
            break;
            case 39: //right arrow
            cursor = Math.min(cursor + 1, text.length);
            break;
            case 46: //delete
                unselect();
            } else {
                text = text.slice(0, cursor) + text.slice(cursor).slice(1);
            newState(text);
            break;
    } else {
        switch (vkey){
            case 65: //ctrl + A
            ctrla = true;
            break;
            case 67: //ctrl + C
            obj.parentWindow.clipboardData.setData("Text", selection);
            break;
            case 86: //ctrl + V
            var clipboard = obj.parentWindow.clipboardData.getData("Text") + "";
                text = text.slice(0, selection_lx) + clipboard + text.slice(selection_rx);
            } else {
                text = text.slice(0, cursor) + clipboard + text.slice(cursor);
            cursor = selection_lx + clipboard.length;
            unselect();
            newState(text);
            break;
            case 88: //ctrl + X
            unselect();
            newState(text);
            break;
            case 89: //ctrl + Y
            currentState = Math.max(currentState - 1, 0);
            text = history[currentState];
            break;
            case 90: //ctrl + Z
            currentState = Math.min(currentState + 1, history.length - 1);
            break;
    window.Repaint();
function getPos(x, text, font, gr){
    var pos;
    for (var i = 0; i <= text.length; i++){
        if (x < text_x + gr.CalcTextWidth(text.slice(0, i + 1), font)){
            pos = i;
            i = text.length + 1;
        } else {
            pos = text.length;
    return pos;
function unselect(){
    mouse_move_x = mouse_lbtn_down_x;
    dblclk = false;
    ctrla = false;
function newState(text){
    history.slice(currentState);
    history.unshift(text);
    currentState = 0;
function search(){
    autocomplete.push(text);
    autocomplete.sort();
    var SortOrder = "%album artist%|%release date%|%album%|%discnumber%|%set subtitle%|%tracknumber%|%path%";
    try {
        var queryItems = fb.GetQueryItems(fb.GetLibraryItems(), text);
    catch(Error){
        var queryItems = fb.CreateHandleList();
    var index = -1;
    for (var i = 0; i < plman.PlaylistCount; i++) {
       if (plman.GetPlaylistName(i).indexOf("Search results [") == 0) index = i;
    if (index > -1){
        plman.RemovePlaylist(index);
    } else {
        index = plman.PlaylistCount;
    plman.CreatePlaylist(index,"Search results [" + text + "]");
    plman.InsertPlaylistItems(index, 0, queryItems);
    plman.SortByFormat(index, SortOrder);
    plman.ActivePlaylist = index;
function filterAutocomplete(value){
    return value.indexOf(text) == 0;
Post by: CrowRabbit on 2019-06-29 14:40:24
I wrote to able use Spider Monkey Panel in TypeScript.
https://github.com/FuCrowRabbit/SpiderMonkeyPanelForTypeScript
Post by: spuuunit on 2019-06-29 14:46:23
Oh god I just figured out how to write my panel! Kind of like a short status bar:
var play_pause = fb.TitleFormat('$if(%ispaused%,❚❚,▶)');
var title = fb.TitleFormat('%title%');
var time1 = fb.TitleFormat('%playback_time%');
var time2 = fb.TitleFormat('%length%');
function on_playback_pause() {  // + play
    window.Repaint();
    window.Repaint();
function on_playback_seek() {
window.Repaint();
function on_playback_time() {
window.Repaint();
    gr.GdiDrawText(play_pause.Eval() + " " + title.Eval(), font, Color(0,0,0), 5, 1, 226, 1000);
    gr.GdiDrawText(time1.Eval() + " / " + time2.Eval(), font, Color(0,0,0), 237, 1, 1000, 1000);
But does anyone know if there's a way to update just one string, and not the whole panel like window.Repaint(); does?
Post by: TheQwertiest on 2019-06-29 15:05:48
@spuuunit , you can use `RepaintRect(w,h)` instead of `Repaint()` if you want to redraw only part of the panel.
@CrowRabbit , TS typings would be nice, but I'm wary of the duplicated documentation: there is already a JSDoc version https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/master/component/docs/js/foo_spider_monkey_panel.js , and it would be a pain to have to maintain the same docs in TS typings as well... (I mean method descriptions and stuff, I'm fine with maintaining the interface itself)
Post by: spuuunit on 2019-06-29 15:34:06
Thanks! But how exactly does that look like, is it like this: window.RepaintRect(0, 1000, 0, 1000); Does that cover the whole area? Because nothing is updating for me.
And another thing: The playback time that increases every second is what I want to update. Is it worth updating just that area all the time, rather than the whole panel, to save resources? Or does panel update affect resources so little that I shouldn't bother?
EDIT: This is my panel by the way. 4 tags and a background color: https://imgur.com/Pds7rqY
Post by: TheQwertiest on 2019-06-29 16:17:26
That's cause you are using it wrong =)
The method prototype is `window.RepaintRect(x,y,w,h)` and you calling it like `window.RepaintRect(x,w,y,h)`. So, in your case, the correct call would be `window.RepaintRect(0, 0, 1000, 1000)`.
Post by: spuuunit on 2019-06-29 16:32:34
Oh shit thanks! =) But does RepaintRect require less computer power than only Repaint? If so I'll go with that.
Post by: TheQwertiest on 2019-06-29 16:37:26
RepaintRect will use less CPU only if the area it's redrawing is smaller then your whole panel. Otherwise there will be no difference.
Post by: spuuunit on 2019-06-29 16:47:28
Ok thanks!
I have 2 more questions, sorry to be a nuicense.  O:)
1. Is it possible to draw text right aligned?
2. Is it possible to draw an external image, a PNG for example.
Post by: Decalicatan_Decalicatan on 2019-06-29 18:43:04
Thank you! Very much appreciated :)
Post by: davideleo on 2019-06-30 11:45:56
Don't bother ask if you need help understanding the script or indications on which variables must be edited to change the appearance.
Post by: Decalicatan_Decalicatan on 2019-07-01 10:26:53
Thanks for the offer ^^ ....
Maybe you can help me for a more generic question then:
Where can I find character codes if I wanted to change the search icon in the line "var icon = String.fromCharCode(57492);").
(I already managed to change the font / color / other stuffs)
Thanks in advance.. and thanks once again to profide me the script,, even I you prefer not to answer, which I can undersand.
Post by: davideleo on 2019-07-01 11:33:48
Well, I guess it depends on the new font you chose. You can look it up in the windows character map application where it is shown as UTF-8 code, you than have to convert it to decimal in order to use it in the fromCharCode method (I use online converters for this purpose).
Post by: TheQwertiest on 2019-07-01 11:37:10
See documentation for `GdiDrawText` method, specifically `format` argument.
See docs for `LoadImageAsync`/`LoadImageAsyncV2`, `DrawImage`/`GdiDrawBitmap` methods and basic `LoadImageAsync.js`/`LoadImageAsyncV2.js` samples.
Post by: Decalicatan_Decalicatan on 2019-07-01 13:27:16
Thank you. The hex to decimal conversion part was what I missed. Now it's working.
Post by: spuuunit on 2019-07-01 23:17:03
God thank you! I found those documentation files, didn't even know they were there. Finally I put together my panel and it's perfect. =)
Thank you TheQwertiest for an awesome plugin and all the support! This plugin must give endless possibilities for you guys who really know how to script. Keep up the good work!
Post by: TheQwertiest on 2019-07-02 15:01:36
FYI, there is a JS version and HTML version of the docs. You want the HTML version, which is accessible via `Context Menu`>`Configure Panel`>`Help`>`View Help`.
Post by: cerbaire on 2019-07-12 14:12:14
Is it possible to load an image directly from an url ?
Post by: TheQwertiest on 2019-07-12 16:00:03
Nope, you'll have to download it manually: SMP does not provide any direct means to work with the Web, you have to use a suitable COM object via `ActiveObjectX` interface (e.g. `ActiveObjectX("MSXML2.XMLHTTP")`.
Post by: cerbaire on 2019-07-16 15:46:01
I have created a code using XMLHttpRequest that can download binary stream of file under Chrome, but it does not work inside a SMP panel (using a the ActiveX component instead of XMLHttpRequest object), and then I don't find anyway to save the stream to filesystem.
Any clue appreciated.
Post by: Ottodix on 2019-07-17 18:48:47
It's not an easy problem. You can try to look at the code of the Biography script by Wilb, there (https://hydrogenaud.io/index.php/topic,112913.msg929674.html#new), it calls a VBScript in order to download images (well his VBScript can actually download any kind of file).
Post by: whyonearth on 2019-07-22 03:20:00
Post by: TheQwertiest on 2019-07-22 11:24:06
With foobar2000 v 1.5 beta 6 and foo_spider_monkey_panel nightly build v1.2.2-beta+8a02533a I observe constant memory usage growing in following scenario
It's not really leaking: garbage collector in SMP has several triggers, two of them are `allocated memory trigger` and `allocation count trigger`. The problem is that I can't know the size of a loaded ActiveXObject, so it doesn't trigger GC as much as it should. But, if you are actively using your script (instead of just reloading it =)), it should encounter one of the GC triggers sooner or later and will free all the memory occupied by ActiveXObject's.
Regarding your suggestions: noted, but I don't think I'll work on these any times soon - I have a few major features that I really want to implement and it will take quite a lot of time... COM objects being a major PITA (and the lack of documentation) also doesn't help.
Post by: TheQwertiest on 2019-07-22 11:48:06
@Awesomeo : moved SMP specific discussion here, as to not clutter @WilB 's thread.
And vice versa, I could have any PSS element that would react to changes in a particular SMP. So maybe something like $set_smp(smp_id,property,value) and $get_smp(smp_id,property).
This is not possible - PSS does not provide any way to extend it's API. What I will (probably) do is add an additional panel option, which would allow to define panel `events` that could be used by fb2k shortcuts.
Hm, not sure if I fully understand this, because both things happen at once for me: playback pauses and the library tree search field receives a space.
Playback pause/play shortcut uses 'on_key_down' event (which is not passed to script in this case), library tree uses 'on_key_up' event (which is passed).
However I've already checked other CUI panels with typing option, like 'Typefind' or 'Youtube Source Search' and keystrokes work locally in them, they don't execute foobar's global hotkeys
Dunno about Youtube Source, but it seems that 'Typefind' uses quite a hacky method to workaround this problem. I'm not quite ready to make such hacks (might change my mind though).
Post by: whyonearth on 2019-07-22 15:31:19
OK, I think I understand this. SMP garbage collector had been tuned to kick-in based on reasonable criterias. And instantiation of ActiveX object doesn't produce any meaningful information that can contribute to this criteria, so garbage collector just have no reasons to react to growing memory usage.
Problem is, even though multiple saving/reloading is a laughable use-case (not in bad sense), I really did it on valid purpose, when I iteratively developed SMP script. Change script a little, save, try it out. Repeat.
With instantiation of AutoHotkey COM object (as I described in list item 4), memory usage grows in about 1-2 MB chunks on every save/reload event. I think, I have not so modern computer, with just 2GB RAM, and Windows 10 is memory-hungry too, so I hit OOM. I really did. Foobar2000 process just was killed. That's a bad experience.
So maybe, if tuning GC kick-in criteria now requires changes to C++ code and recompilation of SMP, the solution to my problem would be a possibility for user to contribute to criteria with JavaScript API.
Something like
window.TriggerSmpGcAsap()
Calling such function will trigger SMP garbage collector as soon as possible even though criterias defined in C++ code aren't fulfilled yet.
With this function I can do something like
const gc_memory_criteria = 20 * (1024 * 1024 * 1024); // 20 MB
function on_script_unload() {
  if (window.PanelMemoryUsage > gc_memory_criteria) {
Also, even though you don't know the size of a loaded ActiveXObject, but I (as user) can observe memory usage growing and make an assumption about this size. So maybe there could be a way to pass this information from JavaScript to component, like
const obj = newActiveXObject('Some.MemoryHungry.COM.Object')
window.AssumeObjectSizeInGcCriteria(obj, 2*1024*1024*1024 /*2 MB*/);
I totally agree about COM technology being PITA  :'(  and I didn't even interact with it in C++, so I can only imagine how it is (but I don't want to, sorry  ;D).
However, all of my suggestions for new SMP features don't directly touch COM.
I implemented Tab key focusing by setting WS_TABSTOP (https://docs.microsoft.com/en-us/windows/win32/winmsg/window-styles) window style for SMP control from AutoHotkey script. So I suggested adding of JavaScript API for enabling/disabling this style from SMP panel script.
And suggestion about extending JavaScript API for manipulating activation contexts also don't need COM programming at all. Just introducing thin wrapper for instantiating ACTCTX (https://docs.microsoft.com/en-us/windows/win32/api/winbase/ns-winbase-tagactctxa) structure and calling CreateActCtx (https://docs.microsoft.com/ru-ru/windows/win32/api/winbase/nf-winbase-createactctxa), ActivateActCtx (https://docs.microsoft.com/ru-ru/windows/win32/api/winbase/nf-winbase-activateactctx) and DeactivateActCtx (https://docs.microsoft.com/ru-ru/windows/win32/api/winbase/nf-winbase-deactivateactctx).
There are also other function in Activation Context API (https://docs.microsoft.com/en-us/windows/win32/sbscs/activation-context-reference), but they are possibly not so important for simple use-cases like mine.
But anyway, it's just a clarification. I understand that SMP development is driven by your motivation and motivation can be substantially lowered by unwanted distractions. I'm the only one who asked for this features, and I can live without them for long time or even forever, as I've found workarounds. So it's totally OK for me to know that these features wouldn't be implemented soon or wouldn't be implemented at all.
Post by: TheQwertiest on 2019-07-22 17:08:18
Something like
I will not implement such method if I can avoid. Reason is simple: users ALWAYS try to shoot themselves in the foot, e.g. call `ForceGC` in every `on_paint` event and then complain that the performance is bad.
I'll try to think of a better way to solve your problem (hoping there is one).
Same with exposing such internals. API should be kept as concise as possible (I would remove/reorganize quite a few methods from the current SMP if I could do so without breaking compatibility).
PS: `2*1024*1024*1024` is 2GB =)
These are not general-purpose methods so they would never be placed in the core namespaces, maybe they could be added as static methods of ActiveXObject... (or perhaps a candidate for a SMP plugin, once/if such plugin API is implemented).
About tabbing: I'll take a look, but no ETA =)
Post by: whyonearth on 2019-07-22 18:33:33
Yep, you are right, the code was wrong, the code comment is correct. Don't know how it happened. Thanks for noticing.
It's good to know that you've took a closer look at suggested features. I'll patiently wait.
If you don't want to give user any access to GC control knobs, it might be enough to force GC in C++ code just after invoking JS on_script_unload() callback (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/3467e78e0266a7e03c8c08a0cf1fc1acdd6305d6/foo_spider_monkey_panel/js_panel_window.cpp#L944) (maybe force conditionally, based on state of checkbox added in Panel Features menu). As far as I can deduce from looking at code, it should cover cases of saving script in panel configuration window and script reload. After all, on reload most (all?) references in unloaded script should be unreachable and targeted for garbage collection anyway.
As I'm using AutoHotkey, I'm looking for ways to push information from AutoHotkey script to SMP script (pulling information from AutoHotkey script and pushing information to AutoHotkey script could be done with COM object methods).
AutoHotkey can send (or post) windows messages (https://hotkeyit.github.io/v2/docs/commands/PostMessage.htm) to windows and controls with given parameters. As my limited understanding of SMP component code allows me to suppose, SMP's on_main_menu() callback is invoked based on specific window message number and argument passed to on_main_menu() callback is parameter of window message. So it could be used for my purposes.
However, window message number (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/5589fb60982f066b24f44f0315b0ce8fefd1444d/foo_spider_monkey_panel/user_message.h#L64) for invoking on_main_menu() callback can change between releases of SMP, because of possible changing of related enums where this number is defined. This makes relying on concrete number a bit reckless.
Can you provide separate callback (like on_wm_user_message()), which would be called on receving windows message with stable number? Or maybe you can expose main_menu_item message number in property accessible from JS script (like window.MAIN_MENU_ITEM_WM_NUMBER), so that I can push it to AutoHotkey script?
(Concrete names of functions and properties are not important.)
Post by: Ottodix on 2019-07-24 15:47:11
HI,
Is there a way to get a playlist track metadb without retrieving the whole content of the target playlist?
I'm trying to get the focused track of a playlist (any playlist, not the active one).
So i've got that
var focus_index = plman.GetPlaylistFocusItemIndex(playlistIndex);
var metadbs = plman.GetPlaylistItems(playlistIndex);
metadb = metadbs[focus_index];
But in term of performance, it means that i will temporary create a object containing the whole playlist, isn't it an issue on very large playlist? I would prefer something like
plman.GetPlaylistItemByIndex(playlistIndex, item_index);
Or eventually, something like that, in order to get the FbMetadbHandle instead of just the index
plman.GetPlaylistFocusItem(playlistIndex);
Post by: TheQwertiest on 2019-07-24 16:45:45
Sorry, forgot to answer your post:
`xhr` in chrome/mozilla/edge is not the same as `*legacy* xhr` which is XMLHttpRequest activexobject.
It's possible to manually invoke it in JavaScript in SMP, but the problem is that it's impossible to save the file asynchronously, meaning that it will block the main thread until the operation is finished. The solution to this is to invoke the `download&save` operation in a separate process. One such example is the one @Ottodix mentioned: invoke the download with a separate VBScript via `cscript,exe`: VBScript file - `samples\complete\vbs\download.vbs`; example usage - `samples\complete\js\thumbs.js` (https://github.com/marc2k3/smp_2003/blob/98fb2425975dcd8d3e999a7f25282392403d60dd/js/thumbs.js#L525)
Actually I was thinking about it when I was tuning GC, but decided against it exactly due to the scenario when user reloads script a lot to test his changes. I should try to trigger a minimal GC though, since minimal GC has minimal impact on UX.
I can't, since it will tank the performance - crossing JS <> native boundary is not free and message loop is one of the most often called places.
Uhm, you could just call `fb.GetFocusItem()` though? =)
But yea, there is currently no way to get a single track (except for the focused track) from the playlist without fetching the array containing the whole playlist.
[EDIT]: I can't currently think of a proper scenario when you would have a track index, but wouldn't have the whole playlist or means to access the corresponding track: you are either working with the whole playlist or you need a specific track because of it's status (that is selected, focused, queued and etc) which means that you can access them via corresponding methods.
Post by: Ottodix on 2019-07-25 10:29:40
fb.GetFocusItem() works only on the active playlist. This is inside a on_item_focus_change(playlistIndex, from, to) callback.
In this callback, I would like to get the focused track handle, and this status is effectively focused, but ! Not in the active playlist unfortunately
Post by: TheQwertiest on 2019-07-25 10:44:58
Hm... Just wondering, why would you need a focused track from non-active playlist? =)
Post by: Ottodix on 2019-07-25 16:23:53
this is a little bit complex, i'm building a side panel which show infos about the focused track, it needs to interact with others panels showing tracks from a playlist which is not necessary the active one (and i can't make it the active one without triggering on_playlist_switch everywhere, and it would be a major performance drawback on my layout).
I think i will try to trigger a refresh of this "info panel" without on_item_focus_change but instead with on_notify_data() and a custom on_focus_change function, all my panels are SMP panels anyway, it will allow me a better control
EDIT: Yes, it's much easier to control with with on_notify_data(), less foobar-logic-compliant, but it doesn't matter
Post by: thisbanisnotsettoexpire on 2019-07-26 02:15:20
Something like
I (whyonearth) was banned for not really considering forum rules. I hope now I'm complying with them. Sorry for breaking the rules and for confusion with replying from new account.
Anyway, that OOM-on-repeated-script-reload error I was talking about was not an OOM error at all. Nevertheless, it's still error of resource exhaustion type.
So, I noted that there was some free memory at the time of crash. This is when I thought I might be wrong in my conclusions. Then I somehow did look more thoroughly at foobar2000 crash report and accidentally 93MB of .rar files extracted meaningful information (crash report is trimmed here):
So, code tried to access address zero, when last win32 error was error with code 1114 (ERROR_DLL_INIT_FAILED (https://docs.microsoft.com/en-us/windows/win32/debug/system-error-codes--1000-1299-): A dynamic link library (DLL) initialization routine failed).
I examined AutoHotkey_H sources, then downloaded OllyDbg and tried to trace AutoHotkey DLL execution. Starting point was in DllGetClassObject (https://github.com/HotKeyIt/ahkdll/blob/eec985c16ff284ec77bde2423bb584c3a7fb1463/source/dllmain.cpp#L1199). Here's what I found.
Relevant links:Spoiler (click to show/hide)
So, when I naively chose Win32w_MT variant of AutoHotkey.dll from release distribution, I chose statically linked library (which I didn't know at the time) and this brought some fixed limits.
Good news, in recent version of Windows 10 this limit is raised: read here (https://social.msdn.microsoft.com/Forums/windowsdesktop/en-US/3546c3c4-1b36-4552-85c5-1b3ba860ee84/how-many-dlls-can-be-loaded-in-a-process-using-loadlibrary-?forum=windowssdk#2e017194-025e-4521-bee0-aad21fd1f805) and here (https://www.gearslutz.com/board/showpost.php?p=13729254&postcount=62&s=b7f43881db1fa1a81da3cc76ceba2e51). Bad news (for me), I'm not using the recent version of Windows 10.
So, while I can instead use dynamically linked AutoHotkey.dll (from Win32w directory), which is linked with vcruntime140.dll, just as foobar2000, and this replacement seems to fix crashes, I thought, maybe if SMP component would just unload COM DLL on unloading (i.e. reloading) SMP script, this also should fix my problem?
While, looking at the SMP code, I can find CoFreeUnusedLibraries (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/9252b68ba8caca8cecc0a9a9f64b76c8bacd314a/foo_spider_monkey_panel/js_objects/active_x_object.cpp#L420), I believe, in real usage component doesn't always work as expected.
Trying to prove that normally used CoFreeUnusedLibraries certainly should free FLS indexes allocated by COM DLL (at least, by AutoHotkey.dll), I did some experiments:
So, I think this is where SMP can be improved.
Post by: TheQwertiest on 2019-07-26 15:15:44
@thisbanisnotsettoexpire : that's quite a research you did there =)
I'm not sure if this is SMP bug, since it seems that AHK reserves new FLS on every execution, but as I said I will add some GC on panel unload.
Not sure when will it happen though, since MS released a broken Visual Studio update, which made it impossible to compile SMP (and I just can't find enough motivation to go through the whole VS reinstallation process to get the working VS back).
<rant>This f***ing s***-show makes me wonder if they even go through QA before making a release...</rant>
<rant intensifies>And don't even get me started on this f***ing disgusting compact title-bar...</rant>
Post by: MordredKLB on 2019-07-26 20:44:01
Is this VS2019 - 16.2.0 you're talking about?
Post by: thisbanisnotsettoexpire on 2019-07-27 04:07:27
As far as I can understand from sources, SMP allows to pass JS function as argument to COM object method. Passed function is wrapped in IDispatch-able gateway and this function could be invoked from COM object side by using gateway's ExecuteValue() (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/8a02533ad58ced877ace97dae7d482e5da5c17de/foo_spider_monkey_panel/convert/com.cpp#L79) method.
AutoHotkey_H COM object can assign value to variable in AutoHotkey script with ahkassign (https://hotkeyit.github.io/v2/docs/commands/ahkassign.htm) method. Though documentation says that only string value can be passed to that method and assigned to variable, in fact, as AutoHotkey_H sources show, CoCOMServer::ahkassign (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/dllmain.cpp#L803) recognizes different COM types (calling AssignVariant (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/script_com.cpp#L757), then VariantToToken (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/script_com.cpp#L620)). By passing VT_DISPATCH COM value to ahkassign, it's possible to assign AutoHotkey object to AutoHotkey script variable and then invoke IDispatch methods from AutoHotkey side by using same-named object methods.
I successfully tested this functionality of AutoHotkey_H COM object with Python script:
But when I used AutoHotkey_H COM object in SMP JS script in the same way as in Python script, trying to call JS function from AutoHotkey script side, it produced access violation error on ExecuteValue() call from AutoHotkey script.
JS script code:Spoiler (click to show/hide)
In tests I used following versions: Spoiler (click to show/hide)
I tried to trace SMP code with OllyDbg, found that ExecuteValue() is really called on SMP component side and (if my understanding is right) in this line (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/8a02533ad58ced877ace97dae7d482e5da5c17de/foo_spider_monkey_panel/convert/com.cpp#L97)
JS::RootedObject jsGlobal( pJsCtx_, heapMgr.Get( globalId_ ).toObjectOrNull() );
heapMgr.Get( globalId_ ) returned 0.
If I'm right, can it be fixed? (Just asking about possibility, not pushing to do it ASAP.)
Post by: thisbanisnotsettoexpire on 2019-07-28 15:29:04
In that experiments I used CoUninitialize and it was critical for successful results, but, while it's OK to use this function in the end of execution of standalone script, now I believe (basing on CoUninitialize documentation (https://docs.microsoft.com/en-us/windows/win32/api/combaseapi/nf-combaseapi-couninitialize)), that using it in SMP is either not allowed at all, or at least would require cooperation between author of foobar2000, authors of all other components and author of SMP (i.e. it's impractical).
Turns out, just using CoFreeUnusedLibraries wasn't enough to produce noticable releasing of FLS indexes, because
CoFreeUnusedLibraries does not immediately release DLLs that have no active object. There is a 10-minute delay for multithreaded apartments (MTAs) and neutral apartments (NAs). For single-threaded apartments (STAs), there is no delay.
No, it's not a quote from CoFreeUnusedLibraries documentation (https://docs.microsoft.com/ru-ru/windows/win32/api/combaseapi/nf-combaseapi-cofreeunusedlibraries), it's a quote from CoFreeUnusedLibrariesEx documentation (https://docs.microsoft.com/en-us/windows/win32/api/combaseapi/nf-combaseapi-cofreeunusedlibrariesex). Thanks a lot, Microsoft.
CoFreeUnusedLibrariesEx is specifically provided to set explicit delay for unloading DLLs with a way to force the unloading of DLLs without any delay, though remarks in CoFreeUnusedLibrariesEx documentation warn against forcing immediate unloading of DLLs.
With using CoFreeUnusedLibrariesEx I can consistently release FLS indexes in test script without CoUninitialize:
The problem is, with any reasonable delay (even reasonably small delay), there probably would still be no useful change in my original SMP's usage scenario (in the concrete case of using statically linked AutoHotkey DLL), because in reloading script new AutoHotkey COM object would be created by reloaded script in a time smaller than that delay and then AutoHotkey DLL wouldn't be unloaded and allocated FLS indexes wouldn't be released and foobar2000 will still crash after repeated script reloading.
But anyway, it looks like this particular mysterious mystery of strange mystery is resolved and, with this information, maybe TheQwertiest will come up with some heuristic to use the possibility of setting COM DLLs unload delay.
Post by: TheQwertiest on 2019-07-29 13:17:50
Yup
This should not ever happen - it's a bug.
Can you try the nightly build (see OP for the link) and check if the bug persists?
PS: Thanks for the detailed repro steps!
Post by: thisbanisnotsettoexpire on 2019-08-08 14:58:49
I changed debugger from OllyDbg to x64dbg (https://x64dbg.com/) (it has 32-bit version and can debug 32-bit code, despite the name) and, coincidentally, place of error also changed. I didn't try to debug with OllyDbg again, so I can't say whether I was just plainly wrong in quoted bug report, or there was some misunderstanding on my side. However, after several attempts at debugging with x64dbg, I successfully found bugfix.
I patched foo_spider_monkey_panel v1.2.1 (https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.2.1) DLL at following offsets (from the beginning of file):
OffsetOriginal valuePatched value
0x3F7790xFF0x90
0x3F77A0xD70x90
Originally I used runtime patching ability of x64dbg and exported patch in .1337 format. It looks like offsets in this patch are not from the beginning of the file, so it wasn't useful for me per se, but for completeness I paste it here:Spoiler (click to show/hide)
Original values are assembled as CALL EDI instruction and patch replaces it with NOPs.
In terms of C++ sources, patch removes this line (https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/667bfffec3df96a8e8b36b70240739d728eddeac/foo_spider_monkey_panel/js_objects/active_x_object.cpp#L812) in ActiveXObject::Invoke method:
VariantClear( &args[i] );
After patching, I can execute JS script from quoted post without any errors, but with producing expected result of appending an entry to foobar2000 console. As ExecuteValue method is the default member of SMP's COM object (i.e. it is identified by DISPID_VALUE (https://docs.microsoft.com/en-us/openspecs/windows_protocols/ms-oaut/cb9d0131-c6bd-463d-9c40-7264856a10c5)), it can also be invoked from AutoHotkey side by using following syntax: Spoiler (click to show/hide)
After replacing foo_spider_monkey_panel v1.2.1 to v1.2.2-beta+8a02533a I observe Access Violation error on the ahk.ahkExec('f.ExecuteValue()'); line. Though I can't say that it's the same bug. In absence of .pdb for nightly and having working stable DLL, I didn't try to debug nightly to find the cause of error.
Post by: TheQwertiest on 2019-08-08 15:56:04
@thisbanisnotsettoexpire : that's some extensive debugging!
It's really weird though that `VariantClear` causes errors: it just cleans up arguments that were generated for function call (and it should be safe for well-formed COM types). Not doing this will cause memory leaks.
Nevertheless, I can't test nor debug this (nor continue the component development) since I still don't have a working Visual Studio installation: current version (16.2) is broken and I couldn't find a way to download the previous release...
PS: Corresponding .pdb symbols (as well as a debug build) are available on the appveyor agent - https://ci.appveyor.com/project/TheQwertiest/foo-spider-monkey-panel/builds/26070987/job/nxn00otulu6tyrl7/artifacts
Post by: thisbanisnotsettoexpire on 2019-08-09 14:06:02
Thanks for hint. I guess then it's working, but wrong solution. VariantClear (https://docs.microsoft.com/en-us/windows/win32/api/oleauto/nf-oleauto-variantclear):
clears a VARIANTARG by setting the vt field to VT_EMPTY. The current contents of the VARIANTARG are released first. [...] If the vtfield is VT_DISPATCH, the object is released.
So I've took an attempt to come up with solution from other side and patched AutoHotkey_H DLL v2.0-a100-H104:
It changes 0x6A 0x00 to 0x6A 0x01, i.e. PUSH 0 to PUSH 1.
In terms of original source, it modifies function CoCOMServer::ahkassign (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/dllmain.cpp#L803) by changing argument false in function call (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/dllmain.cpp#L812) to true:
AssignVariant(*var, value, false);
It means that AssignVariant (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/script_com.cpp#L757) is called with argument aRetainVar = true, then VariantToToken (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/script_com.cpp#L620) is called with argument aRetainVar = true, then reference count for an interface pointer to a COM object is incremented (https://github.com/HotKeyIt/ahkdll/blob/af0541bcb57240bcfbf29884cf358367be27962b/source/script_com.cpp#L718).
I'm not sure that it's correct bugfix (is AutoHotkey_H really must be responsible for incrementing reference counter?), but it also works with Spider Monkey Panel v1.2.2-beta+8a02533a.
Post by: TheQwertiest on 2019-08-09 16:22:13
After some incredible shenanigans I've managed to get myself a working VS2019 16.1 installation (no thanks to Microsoft)!
Anyways...
@thisbanisnotsettoexpire : I've managed to reproduce your crash - it seems that the COM object passed to `ahkassign` does not have it's counter incremented.
function f();
ahk.assign('f', f);
SMP wraps function `f` in a COM object and passes it to `ahk.assign`.
So, we have the following scenario:
- COM object is created from JS object. It has a usage counter equal to 1.
- COM object is passed to ahk.assign. Usage counter was not incremented in ahk.assign.
- Local (to SMP) COM object is destroyed. Usage counter is decremented to zero thus the VARIANT is destroyed as well.
- If ahk tries to use said (destroyed) COM object it will invoke UB and most likely crash.
Yes, because the caller does not how the passed object will be utilized. COM object handling is the same as shared_ptr.
Post by: TheQwertiest on 2019-08-09 17:06:29
@thisbanisnotsettoexpire : I've tested with the debug build of AHK and my guess was proven true - AHK assign does not increase ref count. This is the code which assigns my COM object to internal ASH variable: https://github.com/HotKeyIt/ahkdll/blob/7e6d355db20d6faf59d8a15fcc908b52ff7b5d80/source/script_com.cpp#L731
There is no reference increments going on unless aRetainVar was set to true (which is not the case for `ahkassign`).
[EDIT] Moreover, it seems that `ahkassign` will actually DECREASE refcount of the incoming object WITHOUT incrementing it in some cases (invoking UB if the caller didn't increase refcount) : e.g. https://github.com/HotKeyIt/ahkdll/blob/7e6d355db20d6faf59d8a15fcc908b52ff7b5d80/source/script_com.cpp#L698
This code is flawed and I can't find any sensible scenario when it would be a correct approach. Your AHK patch *is* the correct fix.
Post by: TheQwertiest on 2019-08-12 12:02:11
Well f**k... VS 2019 was updated to 16.2 on the build agent, so now SMP can't be built there... And there is still no answer from Microsoft on this issue...
Post by: cerbaire on 2019-08-19 16:24:01
Thank you Ottidix and TheQwertiest. It works great. It was finally quite simple but I did no get the idea by myself !
Another question ; I have an error 'can't access dead object' !
Any suggestion on why this error is raised ?
I will check the livecycle of my object, but if you have any clue (I reset SMP parameters in 'Advanced / Tools / SMP settings, but not sufficient)
Post by: Ottodix on 2019-08-19 16:43:30
It completely depend of your code, there is a lot of possible scenarios. One common mistake : if you send a object from another panel using window.NotifyOthers(name,info), you need to clone the object inside the corresponding callback on_notify_data(name,info) of the receiver panel, you can't just assign by reference to another variable. Because the "info" object is destructed at the end of this function.
Post by: TheQwertiest on 2019-08-20 12:09:20
@cerbaire , Ottodix's suggestion is entirely correct. You can find more info about it in the documentation of `on_notify_data` callback (you can access HTML documentation via 'Configure...'>'Help'>'View Help').
Post by: cerbaire on 2019-08-20 17:05:13
Thanks for your responses. I understand the problem, and I think I am not in the scenario of a on_notify_data call.
My object is a FbMetadbHandle stored in a list. I will check on which event I am binded, but I think I instantiate my object directly in the panel script so it is not binded to any documented SMP event. I check that tonight and let you know.
Post by: Ottodix on 2019-08-21 09:58:05
Then it's really impossible to help without the code, you can debug it yourself though. You can use a function like:
function debug_dead_item(metadb_list,index){
    console.log("desired index: "+index+", list length: "+metadb_list.length);
    console.log(metadb_list[index].RawPath);
Put checkpoints in your code with this function in order to trace when/where this object was available and when/where it's not anymore, and then you'll probably understand what's going on. This function will crash if the list or if the specified index doesn't exist, but it doesn't matter, the crash message will be as good an information than the console messages.
Post by: TheQwertiest on 2019-08-21 10:28:32
The problem might be delayed: e.g.
// Pseudo code
let arr = []
on_notify_data(data) {
  // no error
  arr.push_back(data);
on_mouse_click() {
  // error
  console.log(arr[0].Path);
On another note: what SMP version are you using?
Post by: cerbaire on 2019-08-21 12:18:14
// Pseudo code
let arr = []
  // no error
on_mouse_click() {
  // error
I am using last nightly build available.
In the panel code, I call GetPlaylistItems(-1) in a setTimeout() and store index and FbMetadbHandle returned by GetPlaylistItems. Later, in a on_mouse_lbtn_up, I use the previous stored FbMetadbHandle, and it fail.
Post by: TheQwertiest on 2019-08-21 14:22:02
That's really weird. Can you provide a minimal repro scenario? So that I could reproduce it locally.
Post by: cerbaire on 2019-08-22 00:14:50
You're right ! I was storing FbMetadbHandle in a function called from on_notify_data, and using that handle after the callback end.
I replace the handle by the RawPath property and it works better!
Thank you for putting me in the right direction.
Post by: TheQwertiest on 2019-08-22 11:16:49
No! You are using it wrong! Please, read documentation for the `on_notify_data`...
Your usage (for both FbMetadbHandle and FbMetadbHandle.RawPath) is covered explicitly in the method description.
Post by: cerbaire on 2019-08-22 13:51:56
Right! I now use JSON.parse(JSON.stringify(metadb)) to store a copy of my handle and it works lke a charm. Thanks.
Post by: TheQwertiest on 2019-08-22 15:17:06
Uhm... no...
 If you want to store the data from `info` you have to perform a deep copy:
- `String(info)` for strings.
So if you want to store `metadb.RawPath`, you store it like this:
// Pseudo code
g_storage = []
on_notify_data(metadb)
  // `String` performs a deep copy
  g_storage.push_back(String(metadb.RawPath))
You can't serialize `metadb` since it's not a serializable object (i.e. it will be restored into a simple struct instead after deserialization).
To clone metadb you'll have to clone metadbhandlelist instead (metadb does not have a copy constructor):
// Pseudo code
g_storage = []
  // FbMetadbHandleList constructor always performs a deep copy
  let tmpHandleList = new FbMetadbHandleList(metadb);
  g_storage.push_back(tmpHandleList[0]);
Post by: MordredKLB on 2019-08-29 07:24:11
Is there a way to get an arbitrary URL to open in a browser from FSM (or jscript)? I was thinking this was simple, then when I tried to implement it, I realized that all the times I'd seen it done required foo_run, along with pre-defined URLs.
Post by: thisbanisnotsettoexpire on 2019-08-29 10:11:42
Maybe Shell.ShellExecute (https://docs.microsoft.com/en-us/windows/win32/shell/shell-shellexecute) will work?
const objShell = new ActiveXObject("Shell.Application");
objShell.ShellExecute("https://hydrogenaud.io");
Post by: zeremy on 2019-08-29 12:53:42
Use Wshshell.Run with WScript.Shell
Sample function
https://github.com/marc2k3/smp_2003/blob/ed613ee3875cc914ea102a763758457431cdfc25/js/helpers.js#L516
Post by: davideleo on 2019-08-29 15:42:35
Back from my holidays, the lastfm album art downloader is not working anymore. It is an old script by marc2003 that I modified now and then. It is quite obvious that the reason is a change in the lastfm web page HTML code. It is likely a silly problem, but I'm not familiar with HTML, so maybe someone here can help me out.
The following is - as far as I understand - the relevant code which needs some change:
include(fb.ComponentPath + 'samples\\complete\\js\\lodash.min.js');
include(fb.ComponentPath + 'samples\\complete\\js\\helpers.js')
include(fb.ComponentPath + 'samples\\complete\\js\\panel.js');
var x = new ActiveXObject("Microsoft.XMLHTTP");
var ar = panel.tf("$meta_sep(artist,', ',' and ')");
var al = panel.tf("%album%");
x.open("GET", "https://www.last.fm/music/" + encodeURIComponent(ar) + "/" + encodeURIComponent(al) + "/+images", true);
x.setRequestHeader("If-Modified-Since", "Thu, 01 Jan 1970 00:00:00 GMT");
x.send();
var o = _.first(_.filter(_getElementsByTagName(x.responseText, "img"), {"className" : "image-list-image"}));
The issue is in the last line of the above code. It used to fetch the first of the album covers on the album lastfm page, such as this one (https://www.last.fm/music/Alessandro+Alessandroni/Prisma+Sonoro/+images). I've been looking at this part of the HTML code (from line 1077 in the aforementioned example page):
    <ul class="image-list">
            <li class="image-list-item-wrapper">
                <a href="/music/Alessandro+Alessandroni/Prisma+Sonoro/+images/829db16b90ed471cbbfe248ef08ada39" class="image-list-item">
                    <img
                        src="https://lastfm-img2.akamaized.net/i/u/avatar170s/829db16b90ed471cbbfe248ef08ada39.webp"
                        alt="None"
                </a>
            </li>
                <a href="/music/Alessandro+Alessandroni/Prisma+Sonoro/+images/72cd2e7b55604336b9003de58bf58d24" class="image-list-item">
                    <img
                        src="https://lastfm-img2.akamaized.net/i/u/avatar170s/72cd2e7b55604336b9003de58bf58d24.webp"
                        alt="None"
                </a>
            </li>
                <a href="/music/Alessandro+Alessandroni/Prisma+Sonoro/+images/d002704049d844f4ba5dcc647614a483" class="image-list-item">
                    <img
                        src="https://lastfm-img2.akamaized.net/i/u/avatar170s/d002704049d844f4ba5dcc647614a483.webp"
                        alt="None"
                </a>
            </li>
    </ul>
I guess the parameters in the _getElementsByTagName function do not match the page HTML code anymore, but I cannot reference it properly.
Title: Re: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: MordredKLB on 2019-08-29 17:31:23
Sample function
Thanks, guys. thisban's code worked great, but I already had Marc's helper script in my theme so I saved a line of code :)
Post by: MordredKLB on 2019-08-29 17:37:42
A few things:
1) The img's don't have "image-list-image" class attached to them anymore, so all images are being filtered out. You'd have to completely remove the _.filter section, or first get all "a" tags and filter by class="image-list-item" and then get all images from inside those. I haven't used those methods enough to know how to write that relevant code though.
2) Those are .webp images. Can SMP even handle those, presuming they can be scraped correctly?
Post by: davideleo on 2019-08-29 19:18:44
A few things:
Thanks, I'll try your suggested fixes. I don't know about the webp format yet. I wanted to fix the file download anyway, as a mean to better understand how to use the xmlhttp object. I found instructions on how to manually download the webp file as a jpg, so maybe it's possible to edit the code in order to emulate such method. Perhaps a better alternative would be to get the jpg url from the meta tag (line 65 of the HTML code in the above example page). This might be my next question.
Post by: TheQwertiest on 2019-08-30 10:25:02
@davideleo , I think it should be fixed with the latest marc2003 scripts (https://github.com/marc2k3/smp_2003). Download them and put them in samples/complete.
@MordredKLB , SMP doesn't support .webp images.
[EDIT] MSDN indicates that there's some built-in support for .webp images, but there is no information on when and where such support is available (https://docs.microsoft.com/en-us/windows/win32/gdiplus/-gdiplus-constant-image-file-format-constants)
PS: I might have found a workaround that might allow me to work around MSVS issues.
Post by: davideleo on 2019-08-31 18:01:22
Thanks for the link, but I cannot find the "Last.fm Album Art Downloader" script. As far as I know marc2003 stopped updating it since a few years, at least publicly.
However I tried fetching the jpg URL in the page metadata with this code:
let doc = new ActiveXObject('htmlfile');
doc.open();
doc.write(x.responseText);
var o = doc.querySelector("meta[property='og:image']").getAttribute("content");
doc.close();
The code correctly assigns the url, such as this one (https://lastfm-img2.akamaized.net/i/u/ar0/829db16b90ed471cbbfe248ef08ada39.jpg), to the variable "o", but the "download" visual basic script doesn't seem to like it as an argument. The code that runs the visual basic script is the following:
_runCmd("cscript //nologo " + _q(fb.ComponentPath + "samples\\complete\\vbs\\download.vbs") + " " + _q(o) + " " + _q(f), false);
where the variable "f" is the destination filename.
Post by: davideleo on 2019-09-03 17:11:18
Problem solved. The issue was a leftover line of the previous code (commented out in the script below) which I naively thought to be harmless.
                        doc.open();
                        doc.close();
// var u = o.src.replace("avatar170s", "ar0");
Post by: cerbaire on 2019-09-06 18:53:33
Hello,
When I use image in my panels, for example with gdi.Image('path.to.img'), I can't delete the file from filesystem without closing foobar2000. Is there a best practice to release image handle?
Kind regards,
Nicolas
Post by: spuuunit on 2019-09-14 09:45:27
Hi, I just noticed that when I print out the track title for example ( fb.TitleFormat('%title%'); ) the character & does not display correctly. This is what it looks like (https://imgur.com/WZFkRYk). It's not a huge deal, but it would be nice if I could fix it. And ideas?
Post by: TheQwertiest on 2019-09-14 13:44:39
What method are you calling to print the text? Which font are you using?
Post by: davideleo on 2019-09-15 17:26:00
I'm a little confused about the encodeURIComponent() function.
The lastfm album art downloader script uses the function to get the right URL of the lastfm album page, like this:
var ar = panel.tf("$meta_sep(album artist,', ',' and ')");
x.open("GET", "https://www.last.fm/music/" + encodeURIComponent(ar) + "/" + encodeURIComponent(al), true);
This usually worked fine, but with the Damned's "The MCA Singles A's + B's" I got
https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%2B%20B's (https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%2B%20B's)
whereas the URL of the lastfm album page is
https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%252B%20B's (https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%252B%20B's)
The encodeURIComponent() function properly converts the "+" character to "%2B", but the lastfm URL shows a sort of double encoding converting the "%" character to "%25" in turn, and thus the "+" character becomes "%252B".
Therefore I changed the code applying the function twce, like this:
"https://www.last.fm/music/" + encodeURIComponent(encodeURIComponent(ar)) + "/" + encodeURIComponent(encodeURIComponent(al))
getting a weird
https://www.last.fm/music/The%2520Damned/The%2520MCA%2520Singles%2520A's%2520%252B%2520B's (https://www.last.fm/music/The%2520Damned/The%2520MCA%2520Singles%2520A's%2520%252B%2520B's)
which surprisingly (at least for me) works as well.
Can anybody explain me the logic of this double encoding?
Post by: TheQwertiest on 2019-09-16 14:43:18
It seem that's just a bug in lastfm url generation.
`encodeURIComponent` seems to perform exactly as it's described in JavaScript docs: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/encodeURIComponent
Post by: TheQwertiest on 2019-09-16 14:48:13
Version: 1.2.2-preview
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.2.2-preview
Changelog:
Detailed description of API changes: https://github.com/TheQwertiest/foo_spider_monkey_panel/wiki/API-Changes#v122
PS: the version is called "preview", because it was built manually on my PC (instead of appveyor CI as before). Because of Microsoft shenanigans this is the only way right now. It will be republished as a proper non-preview version once MS fixes the bug (mind you, it's already been two months since the bug was reported). It will be the same though functionality-wise (unless there are bugs discovered, of course)
Post by: davideleo on 2019-09-16 15:32:52
Yes, sorry my question was not clear enough. How come the double encoding works? Unlike my code, lastfm's bug generates a double encoding of only one percentage character in the URL. In other words, why does
lead me to
https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%252B%20B's (https://www.last.fm/music/The%20Damned/The%20MCA%20Singles%20A's%20%252B%20B's)?
It is as if all "%25" were interpreted as "%", but one.
Mind that triple encoding doesn't work.
Post by: spuuunit on 2019-09-16 20:55:00
gr.GdiDrawText. Segoe UI, and that font has the '&' character.
Here's my code for clarity:
var time2 = fb.TitleFormat(' / %length%');
    window.Repaint();
    window.Repaint();
window.Repaint();
function on_library_items_changed() {
window.Repaint();
window.RepaintRect(213, 3, 85, 12);
function on_paint(gr) {
    var time_width = gr.CalcTextWidth(time1.Eval() + time2.Eval(), font);
    gr.GdiDrawText(play_pause.Eval() + " " + title.Eval(), font, Color(0,0,0), 5, 1, 287 - time_width, 1000);
    gr.GdiDrawText(time1.Eval() + time2.Eval(), font, Color(0,0,0), 297 - time_width, 1, 1000, 1000);
Post by: TheQwertiest on 2019-09-16 21:45:13
@spuuunit : `GdiDrawText` (which uses `::DrawText` internally) uses `&` for some formatting rules (e.g. adding underscore to the following character). In your case you can just add `DT_NOPREFIX` flag (0x00000800) to the method. For more info about flags of `GdiDrawText` see corresponding section in docs/flags.js.
Post by: spuuunit on 2019-09-17 17:39:55
Oooh, I see. That makes sense. And thanks, I added that now. :)
Post by: Madthunder on 2019-09-18 19:31:05
I had a problem moving from 1.2.1 to 1.2.2 when using the updated jsplaylist-mod.
I seems like g_font_wd2 and g_font_wd3 were undefined in WSHplaylistmanager.js and WSHtopbar.js and so I had to add the following in both files (specifically, in the functions oPlaylistManager and oTopBar):
var g_font_wd2 = {
var g_font_wd3 = {
This fixes the problem for me.
Post by: TheQwertiest on 2019-09-20 21:54:38
@Madthunder , nice catch! Will be fixed in the next release.
Post by: TheQwertiest on 2019-09-30 16:09:52
@AndreaT , most likely you are using up all the memory =)
At least I can have it running for a while
Do you mean that the script doesn't fail immediately?
I will try to whip up a debug build that has a more detailed error message.
Post by: AndreaT on 2019-10-02 16:27:44
@TheQwertiest : Yes, exactly so, the script runs for a while, even for minutes, then it crashes randomly (but quite often when making a search or browsing/scrolling through the search's results).
Regards, Andrea
Post by: TheQwertiest on 2019-10-02 17:30:47
@AndreaT, does it fail always in the same place (i.e. OrderByRelativePath)? If not, does it produce the same error message ("allocation overflow") ?
Post by: Lasternom on 2019-10-04 16:40:59
Hi all,
I've got an questions. I'm trying to make a theme selector that would changes the whole colour scheme of foobar.
I was wondering if it's possible to change the default colours in Columns UI, as shown in the attached picture, this ofcourse with the SpiderMonkeyPanel.
My apologies If I'm asking this question in the wrong place.
Post by: TheQwertiest on 2019-10-05 15:29:13
AFAIK, CUI/DUI does not provide such API, so SMP can't do much about it :\
Post by: AndreaT on 2019-10-07 17:47:56
@TheQwertiest : I am sorry, I cannot be of help about, I didn't take care of that.
As soon as a new version with improved debugging will be available, I will reinstall the component and I will take care to update you more precisely.
Many thanks.
Kind regards, Andrea
Post by: TheQwertiest on 2019-10-10 00:19:53
PS: Nightly builds are up again! (thanks to Appveyor team!) (no thanks to Microsoft...)
Post by: AndreaT on 2019-10-10 17:08:02
@TheQwertiest
SMP crash on Windows 10 Pro 32bit. But working perfectly on Windows 7 Ultimate 32bit
Hello, I don't know if this is a SMP problem or a problem of Biography 1.1.1, but this happens with FB 1.5 beta 17 and 18 on Windows 10 Pro 32bit ITA version.
To be noted that I am running exactly the same configuration also on Windows 7 Ultimate 32bit ITA without any significant problems.
Thanks and regards,
Andrea
Post by: TheQwertiest on 2019-10-11 10:36:29
@TheQwertiest
Well, you are out of memory =)
This error usually happens when there are too many images loaded (or the images are too big).
The difference between Win7 and Win10 might be caused by the difference in RAM/VRAM consumption by OS (i.e. Win10 consumes more memory than Win7).
PS: How much RAM and VRAM do you have?
Post by: AndreaT on 2019-10-11 13:01:42
@TheQwertiest
I was not out of memory, I had over 1GB available.
I have 4GB total (the max for a 32bit OS).
And also I do not agree on Windows 10 consuming more memory of Win7, it is the contrary.
Foobar (exactly the same configuration) uses 1100MB on Win7 and only 950MB on Win10.
And, question, why you point to the memory while the error is speaking about an "image/window resize error"?
Regarding the image size and the like, Biography 1.1.1 is fetching images from internet. Usually are small, a matter of kB.
Regards,
Andrea
Post by: TheQwertiest on 2019-10-11 15:59:38
Because `Resize` does not modify the current image, but creates a new resized image from the old one.
It might be something else though: it seems that GdiPlus might return `OutOfMemory` error even if the error has nothing to do with memory...
Another thing you could check is the amount of GDI handles used: open Task Manager (CTRL-SHIFT-ESC) > Details > Right-Mouse-Button on column header > Select columns > Check `GDI objects`. This will display the current number of GDI objects used by process.
Post by: AndreaT on 2019-10-13 08:20:20
@TheQwertiest
Hi, I checked the system and everything was within the normal limits.
So, I decided to remove the Biography script, delete all the sub-folders related to Biography, but not its install where the config files are.
Then I run Foobar again and reloaded the Biography script.
Doing so, it is finally working fine.
Probably there was something corrupted in the subfolders structure or in the ACL.
I think the real error was related to some disk write error / access denied in writing.
Regards, Andrea
Post by: AndreaT on 2019-10-19 08:13:18
@TheQwertiest
Hello TheQwertiest, I am just reminding you that I am still having this blocking error with Library Tree:
Error: Spider Monkey Panel v1.2.2-preview+0db3c6a4 (Library Tree v2.1.2 by WilB)
OrderByRelativePath failed:
allocation size overflow
File: <main>
Line: 542, Column: 61
Stack trace:
  Panel/this.sort@<main>:542:61
  rootNames@<main>:1205:48
  Library/this.getLibrary@<main>:1190:119
  Timers/this.lib/<@<main>:2911:115
I contacted WilB once more and he gave me this reply:
Reply #255 – 2019-10-17 18:54:23
As far as I am aware this seems to be a bug in spider monkey panel and outside of my control, but I am open to suggestions. I just tried again with a 642K test library & all was OK here. That particular error seems to be occurring on panel initialisation and is explicitly related to view by folder structure. So you could try a different view (if the error is locking you out you could open panel properties and find SYSTEM.View By [it's probably the last entry] and change it to 1 to set a different view).
I thought you were debugging the issue with @TheQwertiest? It sounds as though the issue is reproducible and so it ought to be possible to resolve the cause.
HTH
Last Edit: 2019-10-17 19:08:22 by WilB
Can you help me solving this issue?
Many thanks and kind regards, Andrea
Post by: TheQwertiest on 2019-10-24 21:02:27
@AndreaT , regretfully, I couldn't make the debug SMP build work (yet).
... The lack of free time doesn't help either ...
Post by: AndreaT on 2019-10-25 07:48:19
@TheQwertiest, no problem and thanks for having let me know.
If/when you will make it, kindly let me know and I will test it.
Many thanks and kind regards, Andrea.
Post by: TheQwertiest on 2019-10-31 15:52:39
@AndreaT , here is the debug build for diagnosing `OrderByRelativePath` issue:
https://ci.appveyor.com/api/buildjobs/4fnfte0b2r6h8906/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel.fb2k-component
https://ci.appveyor.com/api/buildjobs/4fnfte0b2r6h8906/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel_pdb.zip
To turn on diagnostics you need:
1. Install *.fb2k-component as usual.
2. Unpack *_pdb.zip into the SMP component folder (e.g. `user-components/foo_spider_monkey_panel`).
3. Launch fb2k.
4. Preferences > Advanced > Tools > Spider Monkey Panel > C++ exception stack trace > Enable (tick).
5. Load WilB's Library Tree and reproduce the error.
6. Check fb2k console output for the stack trace.
7. Post console output here.
Post by: AndreaT on 2019-10-31 15:59:05
@TheQwertiest : Many thanks! I will update you as soon as possible. Kind regards, Andrea
Post by: AndreaT on 2019-10-31 16:29:53
@TheQwertiest :
Hello TheQwerties, herein attached the log collected.
It should contains 3 or 4 "runs" in attempt to have the script running, but it always failed just at the initialization.
Looking forward
Post by: TheQwertiest on 2019-10-31 17:49:43
Welp, I was right - you were out of memory =)
Good news though, I have an idea how to reduce memory usage here, which might fix your issue.
Post by: AndreaT on 2019-10-31 17:55:03
Hi @TheQwertiest : I do not have the knowledge to question you, but I have to kindly notify you that I am having 1.5GB of physical free memory plus other 2 or 3GB of virtual memory available...
I do not understand how I can be out-of-memory...
Thanks and warm regards, Andrea
Post by: kode54 on 2019-11-01 00:26:06
Virtual memory does not let you allocate more memory to a single process than can fit in its own memory space. For 32 bit applications, this is 2GB of user address space*. Even then, allocating more memory than is available can only force so much to page out to disk, and if those background processes are actively running, they cannot really be paged out so easily, without incurring a heavy load as they continue to access their own memory.
* Even with Large Address Aware, the limit is only 3GB.
Post by: lvqcl on 2019-11-01 12:02:02
There's also such thing as memory fragmentation: https://stackoverflow.com/questions/3770457/what-is-memory-fragmentation
Post by: tuxman on 2019-11-01 12:11:59
Memory limits are exactly why I hesitate to try this. JavaScript virtual machines - like SpiderMonkey - have been proven to be not really low on resource usage. You pay a high price for having a non-native user interface.
Post by: TheQwertiest on 2019-11-01 15:04:47
@tuxman , well each programming language has it's niche. I mean, SMP itself was written in C++, because performance and memory consumption matters for it's intended usage. But making a program in a compiled language requires much more effort than making it in a scripting language (especially for a casual user).
Regarding SMP: creating a panel component for fb2k in C++ requires quite a bit of code and a machine with configured IDE, but when using SMP (or JSP/WSH) you get that panel handling code for free and you don't need any IDE nor even a Notepad. SMP/JSP/WSH can be considered a higher level API wrapper around fb2k API, i.e. it might be not as flexible and performant, but it's much easier to use and requires much less insight in fb2k and/or Windows internals.
Post by: tuxman on 2019-11-01 15:11:56
I don't think that a casual user should be able to write code. It is a profession for a good reason.
If resource usage would not matter, I'd dive deeper into Dopamine and similar players.
Post by: TheQwertiest on 2019-11-01 15:28:25
@AndreaT , I've made a test SMP version, which has a revamped `OrderByRelativePath` implementation called `OrderByRelativePathV2`. To test it, you need to replace OrderByRelativePath with OrderByRelativePathV2 in WilB LibraryTree script.
Link to test version: https://ci.appveyor.com/api/buildjobs/pegl4h5tg2ms6noh/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel.fb2k-component
Post by: TheQwertiest on 2019-11-01 15:36:44
@tuxman , I don't agree with you, but I don't think we can have a productive discussion on this topic, so I'll just drop it.
Post by: AndreaT on 2019-11-01 17:59:15
@TheQwertiest : Many Thanks! I am going to do that. I will update you asap. Kind regards, Andrea
Post by: kode54 on 2019-11-02 02:18:06
Thanks for being the gatekeeper to all things known as creative expression. Casual users should also stay away from composing music and crafting artwork as well. If it isn't a paying job, it isn't worth doing, right?
Oh, how could I be so stupid! Some kind soul has alerted me to my mistake. I have forgotten to include the fine profession of word craft. Lest we forget that you have not been paid for writing the above quoted post, so I should assume that it is not of your best quality. Do be sure to share something more akin to the writings of a professional author next time!
Post by: AndreaT on 2019-11-02 11:14:46
@TheQwertiest :
Hello TheQwerties,
I installed your new SMP ver 1.2.3-beta (kindly note that I did NOT removed the debug library from the user-component directory and did not disabled the Advanced settings I set for the debug of the ver 1.2.3-test). I was supposed to keep all this as-is not having had different instruction.
Then I edited the Library Tree ver 2.1.2 JS as instructed (replacing all the occurances). Attached is the modified JS in case you would check if I did all right.
And this is the outcome:
1) What's good is that not Library Tree can start-up with the default view, there are no crash.
2) What's bad is that as soon as I select the View by Folder Structure, Foobar UI freezes and it doesn't came back to live even waiting 1+ hour. So, I have to kill the process Foobar.
To be noted that after the kill, I can restart Foobar and the Library Tree JS results not loaded in the target SMP panel (that panel configuration is lost or deleted by the system).
I tried this 5 times and all runs went exactly the same.
Unfortunately I could not collect any console log because of Foobar freeze.
Kindly let me know if you need me to execute some other tests or collect debug info.
Thanks and regards, Andrea
Post by: TheQwertiest on 2019-11-02 16:00:36
@AndreaT, could you create a memory dump during freeze? Instructions: https://github.com/TheQwertiest/foo_spider_monkey_panel/issues/61#issuecomment-470036761
Post by: AndreaT on 2019-11-02 16:09:47
@TheQwertiest : I will try right away. I will let you know asap.
Post by: Black_Over_Bills_Mothers on 2019-11-06 10:08:04
@Qwertyiest
Tidying my script to process new tracks. In this script I get a list of handles to be processed and then I used to call
fb.RunContextCommandWithMetadb("Tagging/Remove all pictures",myHandles,8);
to delete all embedded images. I've replaced this with the RemoveAttachedImages method of the handles list and it works great.
I also want to optimise my files so I currently use a context menu command;
fb.RunContextCommandWithMetadb("Utilities/Optimize file layout + minimize file size",myHandles,8);
However this generates a popup information box that I have to close every time. Would it be possible to create another method such as myHandles.OptimizeAndMinimize on the list of handles to avoid the popup message?
Post by: Black_Over_Bills_Mothers on 2019-11-09 08:56:34
Looks like our friend marc2k3 has implemented IMetadbHandleList OptimiseFileLayout in his foo_jscript_panel to address my request. Thanks marc2k3. Hopefully this will find it's way into the next foo_spider_monkey_panel.....please.
Post by: TheQwertiest on 2019-11-09 18:01:02
@Black_Over_Bills_Mothers, sorry, I have quite a few things that I want (and need) to do in SMP, so it will have to wait for a bit. It is noted though, and I'll come back to it after I finish at least some of planned features.
Post by: TheQwertiest on 2019-11-11 10:57:17
@AndreaT , latest nightly has OrderByRelativePath with integrated fix.
Post by: AndreaT on 2019-11-11 12:05:59
Hello @TheQwertiest, many thanks for promptly notifing me.
I immediately tested the new Spider Monkey Panel v1.2.3-beta+61085bf2.
It is working well and in my case it saves approximately 75MB or RAM (compared with the special build you gave me dated 6 of November).
Great job!
Post by: TheQwertiest on 2019-11-11 12:26:50
It's probably caused by the new SpiderMonkey (JavaScript engine), which was updated in the nightly builds =)
Post by: AndreaT on 2019-11-11 13:41:04
@TheQwertiest : But I was not using V2 method. So, I think the 75MB savings is due to the new V2 method merged into the legacy V1.
Post by: davideleo on 2019-11-14 20:01:42
* double post removed *
Post by: davideleo on 2019-11-14 20:02:50
First time I ever see this kind of error:
Error: Spider Monkey Panel v1.2.2-preview+0db3c6a4 (test by davideleo)
Font failed:
WinAPI error: CreateFont failed with error (0x0): The operation completed successfully.
The code which generates the error is as simple as this:
this.font = gdi.Font("Segoe UI", 12);
The crash occurs only once every two times.
Any clue?
P.S.
As a test, I replaced the error generating line with the following:
this.font =  window.GetFontCUI(0);
The script still crashes once every two times, but for a different reason:
FillSolidRect failed:
GdiPlus error: FillRectangle failed with error (0x2): InvalidParameter
Once again, the error-generatng line is as innocent as it can get:
gr.FillSolidRect(this.x, this.y, this.width, this.height, colours.LightGray);
Post by: TheQwertiest on 2019-11-15 10:42:48
@davideleo , can you try the latest nightly version and check if it has the same error?
As for `gr.FillSolidRect(this.x, this.y, this.width, this.height, colours.LightGray);` error, this usually happens when you supply invalid dimensions. E.g. zero height or width.
Post by: davideleo on 2019-11-15 14:21:15
Hi @TheQwertiest , I tested the script with the nightly build and it behaves in the exact same way, notifying the same errors.
Switching from one version to the other, I watched the behavior on startup, though, which I did not consider previously. The original script (the one with gdi.Font()) always crashes on startup and at the first attempt to reload it. Subsequent attempts alternate success and failure.
The "control" script (the one with window.GetFontCUI()) totally freezes foobar2000 on startup. I can hear the sound of the crash notification, but all I see is a blank window preview when I move the mouse over the taskbar icon (see the attached picture). I can start foobar2000 (albeit with a crash) only with the original script and replace it with the control script only once foobar2000 is running. The control script will than work and crash every other time.
Something I did not mention before is that it is not a proper crash: the code stops working, but the last painted window is not replaced by the "Aw, crashed :(" orange window (I have to manually resize the window to trigger that).
For doubt's sake I outputted the FillSolidRect() arguments to the console and they are the same the one time it crashes and the one it works.
P.S.
Maybe it's a clue, maybe not: I tried reverting to SMP v1.2.1 and found out that with this older version both scripts freeze foobar2000 on startup.
Post by: AndreaT on 2019-11-16 12:28:26
Hello @TheQwertiest, I do not know why but yesterday I had again Out-of-memory errors (3 or 4 in a couple of hours) running Library Tree and the beta of SMP 1.2.3 dated (build 11 of November).
I do not remember to have done something different or unusual than the previous days...
The only big change in between is Windows 10 update from 1903 to 1909.
Kindly let me know if you need me collecting specific data/logs.
Regards, Andrea
Post by: AndreaT on 2019-11-16 20:21:07
Unresponsive script - Don't ask me again - Option NOT working
Hello @TheQwertiest, I noticed that even if I select the option "Don't ask me again", it doesn't work and every time I restart Foorbar I get the notifying window herein attached.
Post by: TheQwertiest on 2019-11-17 14:34:11
It's not supposed to persist between fb2k restarts, i.e. it's intentional. It only suppresses the warning in the current panel for the current fb2k instance.
Regarding OOM errors: not sure what I can do to help you. As I've said before, your library *is* huge and WilB's script is not designed for minimal memory usage (the performance of the script would have been likely worse if it was though - time-memory trade-off and all that). Maybe playing around with GC settings might help you (i.e. in preferences > advanced), but I have no specific suggestions :\
@davideleo , can you provide the script that reproduces the problem?
Post by: AndreaT on 2019-11-18 07:21:29
@TheQwertiest, many thanks for your kind reply.
All the best, Andrea
Post by: davideleo on 2019-11-19 19:18:42
I tried reverting to the error-generating version of the script, but I made too many edits since my last post. However, I was able to move on when I found out that the error was generated by too many repeated gdi.Font methods (the crash would occur after around 2000 iterations),
The following is a very simplified script with the same logic, which reproduces the same error:
include(fb.ComponentPath + "samples\\complete\\js\\lodash.min.js");
var artists = list("artist");
var grid = new Grid(artists, 12);
function Cell(fontSize){
this.font = gdi.Font("Segoe UI", fontSize);
function Grid(list, fontSize){
this.cells = list.map(() => {
return new Cell(fontSize);
function list(tag, handle_list = fb.GetLibraryItems()){
var tags = [];
var items = fb.GetQueryItems(handle_list, tag + " PRESENT");
for (var i = 0; i < items.Count; i++) {
var handle = items[i];
var values = fb.TitleFormat("$meta_num(" + tag + ")").EvalWithMetadb(handle);
for (var j = 0; j < values; j++) {
tags.push(fb.TitleFormat("$meta(" + tag + "," + j + ")").EvalWithMetadb(handle));
    return _.uniq(tags.sort(), true);
Post by: TheQwertiest on 2019-11-20 10:01:28
@davideleo , it seems that you've exhausted GDI handles. System can provide only so much GDI handles (the limit depends on the OS version and it's configuration). Since all GdiFont objects are being stored in the Grid/Cell, they can't be GC'd, thus GDI handles can't be freed. The resulting error report is weird though and I'll try to look into it.
That aside, you should reuse GdiFont objects whenever possible (instead of recreating them every time) for memory and performance sakes (and to avoid hitting GDI handle limit).
Post by: davideleo on 2019-11-25 20:31:07
I need the width of the playing playlist name on start up. According to the console log, I only have one on_paint event to exploit after the playing playlist is resumed, but I'd rather not overload the on_paint() callback if not strictly needed. So, is there another way to trigger the code when the playback state has been resumed, or alternatively a good reason not to?
Post by: TheQwertiest on 2019-11-26 10:01:26
Not sure I understand your scenario. For playback state tracking you can use `on_playback*` callbacks (e.g. `on_playback_pause`). If you want to reduce workload in `on_paint`, you can always cache results (i.e. calculate width only if the playlist name changed).
Post by: davideleo on 2019-11-26 13:37:43
The problem is only at startup. I use foobar2000 with the option to resume playback state checked and I never stop the player, I just  pause it. Therefore, foobar2000 starts with a playing playlist on. I have a drawtext function that takes the playing playlist name and the width of the playlist name, but the playing playlist name is not available until the very end of the startup process, when the only event left to use is the on_paint. So, is this the only option? I have no need to recalculate the width of the text at every on_paint, on_size would make more sense, but the last of the three on_size events at startup is before playlist initialization.
There is actually other stuff going on between the last on_size and the on_paint at startup, such as foo_enhanced_playcount being loaded, which makes me guess that I'd have the same issue if I were to retrieve scrobbling information at startup.
I kind of miss an on_startup_done() callback.
Post by: davideleo on 2019-11-26 19:57:04
Is there a way to temporary disable keyboard shortcuts?
Post by: TheQwertiest on 2019-11-29 11:08:26
Regretfully, fb2k does not provide `on_startup_done` callback and I can't implement it myself.
As I've said, you can *cache* the value. Or just use a simple boolean guard
var isInitialized = false;
function on_paint()
  if (!isInitialized )
    CalculateSmth();
    isInitialized =true;
fb2k API does not provide such functionality.
Post by: davideleo on 2019-11-29 12:56:07
function on_paint()
    CalculateSmth();
I see. Thanks, I actually needed to be reassured that a workaround is needed here. I guess I'll just save the playing playlist name to a file, Talking of workarounds, I found out that you can trigger a few playlist events before the initial on_paint by adding and removing items to a playlist on start up. It's probably the closest you can get to an on_start_up_done.
Post by: TheQwertiest on 2019-11-29 13:11:28
@davideleo , I've got some info from Peter (https://hydrogenaud.io/index.php?topic=117208.msg977811#msg977811), which clarified some things:
- It *might* be possible to create on_start_up_done callback. No promises or ETA though.
- on_paint and on_size callbacks *might* (and often will) be called before the fb2k is fully initialized.
[Edit]:
- It *is* possible to suppress shortcuts. But no promises or ETA on that either.
Post by: davideleo on 2019-11-29 13:16:45
 8)  You are my favorite foobar2000 component developer ♥
Post by: TheQwertiest on 2019-11-29 13:30:38
Haha, thanks =)
Though I don't think I deserve this title. There are far more qualified developers (e.g. musicmusic, CUI dev).
Post by: davideleo on 2019-11-29 13:51:49
What I refer to as "start up" is probably autoplaylist initialization really. The console log shows the start up time right after all autoplaylists are set, therefore I gathered that was the last stand of the start up process. This is my usual start up log:
Quote from:  console.log
components loaded
configuration read
on_size
Spider Monkey panel initialized
on_size (3 times)
UI initialized
foo_custom_database initialized
autoplaylist initialized
foo_enhanced_playcount loaded
start up done (at least start up time is written here in the console log) <-----------------
possible playlist events
on_paint
Post by: AndreaT on 2019-12-01 13:56:03
Hello @TheQwertiest, hoping to find you well, I am getting to you just to have an idea of when you would release the new SMP with the v1 and v2 methods merged together.
I am waiting for it in order to use Library Tree (I have then to remove because of the too frequent out-of-memory crashes).
Post by: TheQwertiest on 2019-12-01 14:55:08
@AndreaT, it's still quite far from release, but you can use Nightly version in the meantime (Nightly/beta doesn't mean "not stable" ), it has v2 sorting method integrated.
Post by: AndreaT on 2019-12-01 17:57:11
Hello @TheQwertiest, ... thanks ... but your last Nightly build I downloaded few hours ago cannot be installed.
I am getting an installation error. I tried 3 times.
If you need the error code, let me know and I will try to reinstall again.
Post by: TheQwertiest on 2019-12-02 10:19:52
That's really weird. Is there a error message or smth like that?
Post by: AndreaT on 2019-12-02 13:16:09
Hello @TheQwertiest, this is the error I get during the installation process:
"Could not load component "foo_spider_monkey_panel.fb2k-component": bad allocation"
I downloaded right now the Nightly buid from your GitHub project page: https://github.com/TheQwertiest/foo_spider_monkey_panel
using the link you provided for the nightly build:
link https://ci.appveyor.com/api/projects/theqwertiest/foo-spider-monkey-panel/artifacts/_result%2FWin32_Release%2Ffoo_spider_monkey_panel.fb2k-component?branch=master&job=Configuration%3A%20Release
Regards, Andrea
Post by: TheQwertiest on 2019-12-02 15:03:22
@AndreaT, Hmm... can you try installing debug version and see if it works?
Link: https://ci.appveyor.com/api/buildjobs/iyyt6dttpmkuf98y/artifacts/_result%2FWin32_Debug%2Ffoo_spider_monkey_panel.fb2k-component_debug
Post by: davideleo on 2019-12-02 16:36:08
I need some clarification about memory usage. I'm monitoring the panel and the total memory usage of a one SMP only configuration and I was expecting the two values to coincide. Instead, panel memory usage reaches 52 MB before GC kicks in, while total memory usage is more or less stuck on 2 MB. How is that? Why is total memory usage lower than panel memory usage?
Post by: AndreaT on 2019-12-02 17:51:11
Hello @TheQwertiest , I am getting the same error: Could not load component "foo_spider_monkey_panel.fb2k-component": bad allocation.
By the way, is it correct that this package is 57MB in size and that I had to rename the file removing the ending "_debug"?
Regards, Andrea
Post by: TheQwertiest on 2019-12-02 18:15:50
What smp version are you using?
Hm... That's really weird. Can you check if installation of the latest release version (v1.2.2) works? I'm not even sure if it's a SMP error anymore...
Oh and what's your fb2k version?
Yes, that's correct. Another user has informed me that I forgot to include some files though, so it wouldn't have worked even if your installation succeeded.
Post by: davideleo on 2019-12-02 18:25:32
Post by: TheQwertiest on 2019-12-02 18:31:14
Calculating total memory usage is actually not a `free` operation in terms of performance (compared to panel memory usage), so to minimize performance impact it uses cached value, which is updated every GC cycle. In some cases (e.g. yours) this might result in incorrect values. I'll see if smth can be done to make reported values more accurate.
Post by: davideleo on 2019-12-02 18:35:50
Thanks for the answer. Since it's a one-panel configuration, can I presume the total memory consumption to be that of the only panel, or does the component use more memory besides the panel shares?
Post by: TheQwertiest on 2019-12-02 18:41:26
SMP needs additional memory for JS engine and for internal usage, but it's safe to assume that panel is the one that contributes the most to memory usage (unless it contains nothing :P).
The memory impact of SMP will be close to zero (citation needed), if there are no SMP panels active.
Post by: AndreaT on 2019-12-02 20:52:31
Hello @TheQwertiest, I am sorry, I have bad news: no way for me to install ever the v1.2.2-preview.
I am getting the same error.
I would like to try to remove the current version I have running:
Spider Monkey Panel v1.2.3-beta+61085bf2 by TheQwertiest
Based on JScript Panel by marc2003
Based on WSH Panel Mod by T.P. Wang
Build: 10:49:05, Nov 11 2019
Columns UI SDK Version: 6.5
But what about if then I cannot reinstall any?
Regards, Andrea
Post by: TheQwertiest on 2019-12-09 15:04:37
Created a basic website for SMP documentation - https://theqwertiest.github.io/foo_spider_monkey_panel
Notable features:
- Built-in script documentation (the one that is currently supplied with the component): https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_documentation/javascript_api
- Script showcase (more like `script list` currently, but I will work on that): https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_showcase
Post by: davideleo on 2019-12-09 15:33:24
Post by: davideleo on 2019-12-09 17:14:04
components loaded
configuration read
on_size
on_size (3 times)       <=======
UI initialized
on_paint
One way or another, I always stumble on this multiple on_size() fire at start up. I never read other users having problems with it, so I wonder if I'm simply ignoring some document or some common good practice.
Some time ago I learnt that the full window width and height are not available until the last of the three events and consequently instructed my scripts to check the window size before making calculations on it. I relied on the assumption that the window size is either full or 0. But today I found out that the second on_size() sets the window to an intermediate measure, which my code was not expecting. Did the start up procedure change with one of the last updates? Or is it just me, finding out in dribs and drabs how things work ?
Working around such issues is quite easy, as long as I understand correctly what is going on under the hood. Clearly analyzing the console log and making guesses is not enough. Can anybody explain me once and for all how the panel initialization works and why? What is the safe way to initialize objects and variables with values relative to the window size?
Post by: seongbin on 2019-12-09 18:33:00
Maybe a stupid question (non-programmer btw)....
Is there any difference between SMP and JScript or WSH while rendering text with GdiDrawText? Feels like it is slightly different in details especially for CJK characters, actually SMP has much better effect.
Post by: davideleo on 2019-12-09 23:19:51
Here's a javascript puzzle not strictly related to SMP, I hope it is not too off topic.
I'm working on a nested objects system, where each object is an item in an array property of a container object. The methods of the container object execute the method with the same name in the nested objects. This is done by calling another method - the forward() method in the code below - so the container constructor function has the following structure:
function Container(){
this.items = [obj1, obj2, obj3...];
this.method1 = (...args) => {this.forward('method1', ...args)};
this.method2 = (...args) => {this.forward('method2', ...args)};
this.method3 = (...args) => {this.forward('method3', ...args)};
this.methodN = (...args) => {this.forward('methodN', ...args)};
this.forward = (method, ...args) => {
this.items.forEach((item) => {if (method in item) item[method](...args)});
Since the methods from 1 to N have the same pattern I thought I could make them perfectly alike and thus simply reference the forward() method for all. What I need is to ditch the "method" argument in the forward() method and retrieve it by code from the caller method's name. But it turns out it is harder than I thought. Ideally I would like to write something like:
this.method1 = this.forward;
this.method2 = this.forward;
this.method3 = this.forward;
this.methodN = this.forward;
this.forward = ( ...args) => {
let method = //...code to retrieve the caller*** method's name
//***if this kind of code did work like I mean, the container's method would not be a caller anymore, just a reference.
It looks like such a typical scenario for javascript that I'm confident there must be a way, but everything I tried failed. Do you have any suggestion?
Post by: TheQwertiest on 2019-12-10 10:28:54
Retrieving caller information was deemed a problematic feature for multiple reasons:
- Makes some optimizations impossible.
- Easy to abuse to make code unreadable.
- (Web-specific) potential security vulnerabilities.
There is `Function.caller` (https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Function/caller), which can be abused to get the name of the function. But this will not be performance friendly (constant regexp parsing) and this method is unavailable in strict mode anyway.
No intentional changes on my side =)
The only thing I can think of, is that I target Windows 7 as a minimum supported OS, while WSH and JSP target Windows XP, so that could've affected the way GdiDrawText is called, theoretically.
Nope.
Are you using SMP panel as a standalone CUI/DUI panel? Or is it a part of smth like PSS?
Post by: davideleo on 2019-12-10 16:22:37
Yes, I tried that and it actually crashed the panel, because indeed I am using strict mode. But then, why does this function I use for debugging purposes work in strict mode?
I read a bit about this topic in the last days, in search for a solution, and I understand that these caller methods are vestiges of a pre-named-functions era in javascript, but it is exactly the name of the function that I need to have, not the function itself, which is probably the only case when a caller method makes sense. I also understand how uncertain it is to rely on a "function name", which is actually not a property of the function, just one of many possible references to it. But when that reference is an object property, it is definitely more reliable.
Whatever. All in all it seems that the ECMA guys know what they are doing. The thesis that if you think you need the caller method, there is likely a better way to do what you are trying to do, turned out to be true, at least for me. As is often the case, posting the problem on the forum cleared my mind and I realized I actually don't need the method's name, I actually don't need all those methods at all, but just the forward method with an argument, from the head of the chain, so my container constructor is now something like this:
It might be a little meaningless out of context, but I got rid of several lines of code and the final result is a lot more concise than it would have been with a caller-like workaround. Sorry if this was a waste of time, but I just wanted to witness the wisdom of javascript constraints, which I was cursing until yesterday night, and blessing today for pushing me into better coding.
I was using PSS, but since I don't need it (thanks for reminding me!), I removed it and tested it again, with CUI and with DUI. The on_size() callback is always triggered three times in a row, and the window size is always 0x0 on the first, full width x full height on the third and intermediate values in the second, but these are different with DUI, CUI and PSS.
Post by: davideleo on 2019-12-11 00:40:44
For reasons I don't understand, it only works with columns ui, maybe some more advanced coder can figure out why,
I still don't understand the reason, but at least now I know that to make it work in DUI I need to set the window dialog code to 4 (DLGC_WANTALLKEYS). At first I thought the reason was the default dlgcode in CUI, but I checked and with both UI, SMP has a default dlgcode set to 0. Can anybody explain me why DUI needs a different dlg code to take key events?
Post by: zoumbro on 2019-12-13 06:14:31
dear developer(s)
I am facing the following message after installing the latest fsmp version.
I am using latest foobar 1.5 and I have attached a report of installed components.
Post by: TheQwertiest on 2019-12-16 10:35:29
I could not reproduce this behaviour, do you have a reproducible scenario?
Regarding repeated on_size calls: these are only invoked when the panel receives WM_SIZE message (except for one extra invocation which will be removed in the next version. These messages might be triggered by fb2k, by DUI, by CUI or by system itself. SMP just translates this native system message to JS callback.
You probably didn't install all the required fonts (which are listed in readme.md in samples folder).
Post by: davideleo on 2019-12-16 16:09:49
Yes, a very simple one: clean portable installation (v1.5.1 beta 2) with only two extra components: spider monkey panel and columns ui. No library, no playlists.
The columns ui layout is just one spider monkey panel, as a base, with this script:
function on_size(){
    console.log("width: " + window.Width, "height: " + window.Height);
And here's the console output on startup:
Quote from:  the console log
width: 0 height: 0
width: 0 height: 0
width: 1139 height: 593
width: 1366 height: 705
I get it. After reading your explanation I recreated the above scenario without CUI and here's the console log:
width: 0 height: 0
width: 1364 height: 653
The height is lower than CUI in the final size because of the toolbars.
So, it looks like the intermediate sizing is triggered by CUI. Problem solved. I don't need CUI actually, but for removing toolbars. BTW, replacing a whole interface only to get rid of the toolbars is kind of ridiculous, isn't it?
Post by: AndreaT on 2019-12-16 20:33:21
Hello @TheQwertiest, I have a big problem with Foobar 1.5 beta 2 crashing at start while loading SMP.
I also tried the last nightly build having the same crash on start.
Probably the case to notify also Peter. I didn't do yet.
Attached the crash report files
Post by: zoumbro on 2019-12-17 08:29:29
I have all fonts installed (Guifx v2 Transports, fontawesome-webfont,wingdings2.ttf and wingdings3.ttf).
Post by: TheQwertiest on 2019-12-17 10:17:05
@AndreaT , a known issue that I've actually fixed already, but forgot to merge into master branch >_<
Will be up shortly (in a nightly build).
Post by: AndreaT on 2019-12-17 10:39:13
Hello @TheQwertiest, thanks for the prompt reply.
Please, if you don't mind, kindly drop me a message (here or private) when the new Nightly Build is ready for testing.
Post by: TheQwertiest on 2019-12-17 11:11:01
@AndreaT, nightly build with the fix is up.
@zoumbro , I was reminded by @marc2k3 (https://github.com/marc2k3) that it's a known (and fixed) problem in the script. Regrettably, there is no release build yet which has the fix. So, you can either download the nightly build (see OP for the link), or download and replace all the scripts manually (https://github.com/TheQwertiest/foo_spider_monkey_panel/tree/master/component/samples)
Post by: AndreaT on 2019-12-17 21:45:56
Hello @TheQwertiest, well done! Now it works fine again. Many thanks. Regards, Andrea
Post by: davideleo on 2019-12-19 19:18:06
I'd like to get back to this (https://hydrogenaud.io/index.php?msg=971543) clipping procedure, which as far as I understand is the SMP translation of this (https://docs.microsoft.com/en-us/dotnet/framework/winforms/advanced/restricting-the-drawing-surface-in-gdi#see-also) windows GDI+ clipping technique. As far as clipping i concerned, it works as it should, but the text rendering sucks. I didn't realize this at first because I was working with white text on black background. In the code below, I added some text in the clipped region and changed the colours to make the problem visible.
include(fb.ComponentPath + "docs\\helpers.js");
let font = gdi.Font("segoe UI", 16);
let myRegion = new PaintRegion(100, 100, 200, 200)
function on_paint(gr){
gr.FillSolidRect(0, 0, window.Width, window.Height, colours.DarkGray);
gr.GdiDrawText("TEST", font, colours.White,110, 70, 100, 20)
    myRegion.paint(gr);
function PaintRegion(x, y, w, h){
    this.x = x;
    this.y = y;
    this.w = w;
    this.h = h;
    this.paint = (gr) => {
gr.FillSolidRect(this.x, this.y, this.w, this.h, colours.Pink);
        var clipImg = gdi.CreateImage(this.w, this.h)
        var grClip = clipImg.GetGraphics();
grClip.GdiDrawText("TEST", font, colours.White, 10, 10, 100, 20)
grClip.DrawEllipse(100, 50, 200, 200, 2, colours.White);
        clipImg.ReleaseGraphics(grClip);
        gr.DrawImage(clipImg, this.x, this.y, this.w, this.h, 0, 0, this.w, this.h)
In the attached picture you can see the outcome. The first line of text on gray background is drawn with the regular graphics object passed by the on_paint callback, the one below, in the pink clipped region is drawn with the clipped graphics object. SetTextRenderingHint and SetSmoothingMode didn't help.
How can I avoid this blurred effect?
Post by: davideleo on 2019-12-20 00:36:44
So, apparently the problem is the DrawText function. Once more posting to the forum helped me find the answer. I finally found a case where you actually need the DrawString method.
P. S.
Upon reading some window .NET docs on GDI+ and TextRender, I have the impression that the use of DrawString is strongly encouraged, whereas I get the opposite idea from the SMP docs. Are the two methods actually the same? And what are the drawbacks of replacing DrawText with DrawString, anyway?
Post by: TheQwertiest on 2019-12-20 10:01:32
DrawString is worse than DrawText in most cases. DrawText has better performance and better rendering unless used on a transparent surface (as mentioned in SMP docs).
One of the sources: https://stackoverflow.com/questions/1203087/why-is-graphics-measurestring-returning-a-higher-than-expected-number/6404811#6404811
Regarding your problem. Quote from docs (https://theqwertiest.github.io/foo_spider_monkey_panel/assets/generated_files/docs/html/GdiGraphics.html#GdiDrawText):
GdiDrawText
    Provides faster and better rendering than GdiGraphics#DrawString.
    Do not use this to draw text on transparent background or with GdiGraphics other than the one passed in on_paint callback: this will result in visual artifacts caused by ClearType hinting.
    Use GdiGraphics#DrawString instead in such cases.
Post by: davideleo on 2019-12-20 14:01:12
Thanks, this was very, very useful.
Post by: seongbin on 2019-12-28 00:51:02
Firstly, MERRY X MAS! and thx for the great component.
It looks like DrawImage() in SMP is generating left and top border by default. How can I avoid this?
Post by: TheQwertiest on 2019-12-28 10:25:44
o/
What version of SMP are you using?
Post by: seongbin on 2019-12-28 20:43:58
o/
I am using v1.2.2-preview+0db3c6a4. I tried simply comment out the relevant line in JScommon.js as below, but the borders are still there in jssb.
function drawImage(gr, img, src_x, src_y, src_w, src_h, auto_fill, border, alpha) {
if (border) {
// gr.DrawRect(src_x, src_y, src_w - 1, src_h - 1, 1, border);
-eidt-
I digged google a little bit, it looks like borders are generated during resizing images
https://mariusschulz.com/blog/preventing-ghost-borders-when-resizing-images-with-system-drawing
Post by: kowal24 on 2020-01-02 21:21:06
Hi
Today my AV shows info about virus in file foo_lastfm_img.vbs. Anyone have the same problem?
(https://i.imgur.com/KiD3xEp.jpg)
Post by: seongbin on 2020-01-05 12:12:10
-eidt-
NVM, simply resolved by setting interpolation mode as "0" in relevant functions.
Post by: TheQwertiest on 2020-01-10 15:54:50
@seongbin , glad to hear that your problem was resolved. Sorry for the lack of answers - was on a vacation and (mostly) away from the internet...
@kowal24 , false-positive (you can view the code of the script to manually verify that).
Post by: Ottodix on 2020-01-23 09:21:35
I've got an issue related to search query and multi values tags.
I'm searching in my whole library the tracks by an artist simply named "bob".
I could do
fb.GetQueryItems(fb.GetLibraryItems(), "%artist% IS bob");
but then it won't return the tracks tagged with multi values, like "bob; nirvana".
In order to include the tracks tagged with multiple artists, I could do
fb.GetQueryItems(fb.GetLibraryItems(), "%artist% HAS bob");
but then it will return all tracks with bob inside their artist name, like bob dylan, and not all tracks by the artist simply named "bob".
Does someone there have an idea? Thanks!
Post by: TheQwertiest on 2020-01-27 10:50:16
fb.GetQueryItems uses fb2k query rules. I.e. you can use and test this query in default CUI playlist_view search. So I think you are more likely to get a proper answer if you create a separate thread in General forum section.
Post by: TheQwertiest on 2020-02-04 14:56:04
Version: 1.2.3
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.2.3
Changelog:
Spoiler (click to show/hide)
Post by: TheQwertiest on 2020-02-04 14:58:51
Note: I've decided to make this Maintenance release, because a full Feature release is still far away from being ready...
Post by: TheQwertiest on 2020-02-04 18:55:19
Reuploaded v1.2.3. It shouldn't crash anymore now =)
Post by: wcs13 on 2020-02-08 00:41:35
Hi :) Some time ago with WSH Panel component, I was using the "Thumbs" script by marc2003.
It's a nice script that displays not only a main pic, but several thumbs of other pics that you can select by clicking on them, etc.. Plus it's really customizable (e.g. I could edit lines 10 & 11 to change data folder and subfolders format).
So of course my question is : is there some port or equivalent script that I could use with Spider Monkey ? Thanks !
Post by: MojoBass on 2020-02-08 04:18:42
Isn't this (https://github.com/marc2k3/smp_2003/blob/master/js/thumbs.js) Marcs smp version of his thumb.js? (not using it myself)
Post by: mjm716 on 2020-02-08 05:47:47
Yes Marc's old scripts are all ported to SMP and found in the default SMP install folder: foobar2000\user-components\foo_spider_monkey_panel\samples\complete
Post by: wcs13 on 2020-02-08 11:42:04
Got it :) Thanks MojoBass & mjm716 !
There is however one thing I can't get to work :
- With the old WSH script I could set a custom data folder, and then automatically download pics to that folder and subfolders. It worked perfectly.
- With the new SMP script I can set a custom folder structure (in my case it would be "D:\AUDIO\BIOS\artists\$meta(artist,0)"), and then the script displays the already existing pics... but there is no automatic download of new pics (e.g. when there are no pics yet, or where the number of existing pics is lower than the set limit).
If I change "Custom folder" to "Last.fm artist art" I see a "Download now" menu option, but :
- The download is manual, so I'd have to select "Download now" for every new song, which is painful for thousands of artists,
- The pics then get downloaded to %foobar folder%\js_data\artists\ , not to my custom folder.
Can I change this behaviour ? How ?
Post by: TheQwertiest on 2020-02-08 13:40:12
@wcs13 ,  marc2003 removed automatic download option (AFAIK people abused it by settings download limit too high, thus violating LastFM rules, which prompted LastFm to block marc's API key), you can probably restore it by comparing the old script with the new one and copying all the relevant changes.
Post by: wcs13 on 2020-02-12 16:20:00
I've been thinking about this. Rather than removing auto-download, maybe this would have been more useful  in marc's script ?
Idea 1 :
- Define two api_key variables : m_api_key = marc's one (somewhere in the middle of the script), and user_api_key = empty (to be filled by the user at the beginning of the script)
- "Download now" would use m_api_key, but "Auto download" would use user_api_key, so it would result in an error until user enters a valid user_api_key
Sure, an evil user could always try to tweak the script into using m_api_key for autoDL, but very few users would go through the hassle. Easier to just get a personal API Key and copy it in the very first lines of the script.
Idea 2 :
An even stricter solution : just define a single user_api_key variable (empty), so no DLs at all until user enters a valid key. But once he does, autoDL would work too.
My point being : if you're a developer, please don't break script's functionality just because of some (ab)users. Stop giving the API Key if needed, but never break functionality.
It harms the good guys, while at the same time any abuser with JS knowledge could restore function using marc's previous WSH script and keep abusing it.
Anyway, I'll wait until somehow this function can be restored : I already have a personal API Key, but I know little about JS so I can't do all those changes on my own. :(
Post by: mjm716 on 2020-02-13 02:54:24
It could be a loooong wait. WilB's absolutely amazing SMP/Biography script has better downloading capabilities and customization than Marc's script. I use them both myself.
https://hydrogenaud.io/index.php?topic=112914.0
Post by: snotlicker on 2020-02-13 08:40:43
Last update of complete samples should be attached. Includes automatic download options for Thumbs script.
Post by: TheQwertiest on 2020-02-13 10:24:37
@wcs13 , @mjm716 , actually marc2003 re-added automatic download to the `Thumbs` script yesterday (he also corrected my misinformation about LFM API key requirement: the script actually parses LFM site manually without using LFM API). But, regretfully, he deleted his GitHub account shortly afterwards =(
@mjm716, I would say that one should use WilB's Bio script if they need everything in a single panel, and use marc2003's scripts if they want to separate various functionality in multiple different panels (e.g. `thumbs` and `last.fm bio` scripts).
Post by: TheQwertiest on 2020-02-13 10:55:23
Thanks! (esp. for providing `.git` as well)
Post by: Smurth on 2020-02-13 18:42:31
Hello,
Is there a way to disable the default context menu (and NOT replacing it with another) ?
Post by: wcs13 on 2020-02-14 00:45:07
Quote from: mjm716
Quote from: snotlicker
Quote from: TheQwertiest
Wow guys, that was faster than I expected !  :))
I have indeed updated the SMP samples and now autoDL seems to work again. Thank you !  :)
One question though :
- In "last.fm artist art" mode, art is downloaded to %foobar folder%\js_data\artists
- In "custom folder" mode, art isn't downloaded to the defined custom folder (ex : "D:\AUDIO\BIOS\artists\$meta(artist,0)" ). It just doesn't seem to be downloaded anywhere.
Am I doing something wrong ?
I'd really like the art to be downloaded to my big storage D: drive, and not to my small system C: drive.
Besides, I have several portable foobar installs, and I'd like them all to share the same art folder in order not to download art multiple times.
As a last resort, maybe I could edit the script and change the the default %foobar folder%\js_data\artists. Any hints on what line(s) I should edit ?
Post by: TheQwertiest on 2020-02-14 12:17:25
Implement an empty `on_mouse_rbtn_up` callback that returns `true`. Corresponding docs: https://theqwertiest.github.io/foo_spider_monkey_panel/assets/generated_files/docs/html/module-callbacks.html#~on_mouse_rbtn_up
Post by: Smurth on 2020-02-14 16:15:56
Implement an empty `on_mouse_rbtn_up` callback that returns `true`. (...)
Thank you very, very much ;)
Title: Re: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: kutuzof on 2020-02-21 18:58:15
Greetings!
I am not good at scripting. I want to create a menu for switching DSP presets. There is a switching code for the output device, but when I replace with "fb.GetDSPPresets()" the menu remains the same.
function getDSPPresetsMenu(x, y) {
x = Buttons.top_l.left;
y = Buttons.top_l.top;
    var menu = window.CreatePopupMenu();
    var str = fb.GetDSPPresets();
    var arr = JSON.parse(str);
    var active = -1;
    for (var i = 0; i < arr.length; i++) {
        menu.AppendMenuItem(0, i + 1, arr[i].name);
        if (arr[i].active) active = i;
    if (active > -1) menu.CheckMenuRadioItem(1, arr.length + 1, active + 1);
    var idx = menu.TrackPopupMenu(x, y);
    menu;
    if (idx > 0) fb.RunMainMenuCommand("Playback/DSP settings/" + arr[idx - 1].name);
Post by: Smurth on 2020-02-26 16:26:36
Hello,
I'm having an issue with fb.IsMainMenuCommandChecked()
The code below allow me to successfuly change the settings - all the defined settings - but it fail to retrieve the state of the "Playback/order/..." stuff. II can't understand why. Foobar's bug or SMP's bug ?
Or me ?
		let menu = window.CreatePopupMenu();
let ent = ['Order/Default','Order/Repeat (playlist)','Order/Repeat (track)','Order/Random','Stop after current','Playback follows cursor','Cursor follows playback'];
for (var i = 0; i < ent.length; i++) {
menu.AppendMenuItem(MF_STRING, i+1, ent[i].replace('Order/',''));
if (fb.IsMainMenuCommandChecked('Playback/' + ent[i])) {
menu.CheckMenuItem(i+1, true);
if (i == 3){
menu.AppendMenuSeparator();
const idx = menu.TrackPopupMenu(x, y);
if (idx>0) {
fb.RunMainMenuCommand('Playback/' + ent[idx-1]);
Post by: Smurth on 2020-02-26 19:03:34
Sorry, I've missed plman.PlaybackOrder.
Post by: wcs13 on 2020-02-27 23:51:04
Could somebody please answer this past question? Thank you  :)
Post by: TheQwertiest on 2020-02-28 12:46:31
@kutuzof , regarding `GetDSPPresets()`: yep, that's a bug. Fixed in the nightly build.
@Smurth , regarding `IsMainMenuCommandChecked()`: yep, that's a bug as well - this command didn't work properly for menu items that are hidden by default. Fixed in the nightly build.
@wcs13 , in `custom folder mode` images are loaded from the folder provided by user, so it doesn't download anything.
Folders for all marc's scripts are defined in `js\helpers.js` (search for `let folders = {};`). Beware that changing these paths will affect all scripts that are using said paths.
Post by: davideleo on 2020-02-28 16:28:19
Hi @TheQwertiest , concerning this GetDSPPresets() function, I can see that it is listed in the autocomplete entries, but I cannot find any reference in the docs.  If it wasn't for @kutuzof 's post, I wouldn't know about it. Am I missing some source of information?
Post by: TheQwertiest on 2020-02-28 18:15:48
Yep, you should've read it from my mind :D
Anyways, it's indeed missing from docs. I'll add it soonish.
Post by: davideleo on 2020-02-28 19:24:28
 :)  I see, so that's @kutuzof 's secret superpower.
Post by: snotlicker on 2020-02-28 20:43:11
No super powers required.  :-X
https://github.com/kbuffington/foo_jscript_panel/blob/54fc020f09f3a9fb54bdbed8f3c1e6755e4ff8a6/component/docs/Interfaces.txt#L282
Post by: wcs13 on 2020-02-28 23:14:48
It all works perfectly now. You made my day ! :D
I'll remember that other scripts may use those paths, but so far I'm only using Marc's Thumbs and WilB's bio.
Post by: wcs13 on 2020-02-29 01:45:23
BTW I have noticed what could be a glitch on marc's Thumbs script. It's easy to reproduce.
Let's say %artist% = "Bryan Lee & The Jump Street Five"
WilB's bio nicely creates a folder called "Bryan Lee & The Jump Street Five" and downloads relevant album art.
However, marc's Thumbs creates a folder called "Bryan Lee & The Jump Street" and of course can't download any album art so the folder remains empty.
Can somebody confirm this ?
Post by: snotlicker on 2020-02-29 05:09:13
Bug reproduced. Those scripts used a 3rd party Javascript library called lodash and the way you supply arguments to one of the functions got changed when upgrading from the old version 3 used with JSP and the newer version 4 bundled with SMP
js\helpers.js line 197 replace
folder = folders.artists + _.truncate(a, 64);
with
folder = folders.artists + _.truncate(a, { length : 64 });
Post by: anamorphic on 2020-02-29 05:32:08
Also, I imagine that when we update SMP, all edited sample scripts will get overwritten to defaults? So perhaps copy the edited samples folder elsewhere for use, or make note of the changes you made, I guess.
Post by: wcs13 on 2020-02-29 09:30:02
@snotlicker : thanks, it worked indeed :)
@anamorphic : yes, I have already copied the edited samples AND made note of changes on separate txt files, just in case ;)
Post by: wcs13 on 2020-02-29 12:11:19
I think I found another glitch :
If %artist% is empty but %composer% is filled, WilB's bio creates a %composer% folder and downloads info, but marc's Thumbs does nothing.
Any hints ?
Post by: TheQwertiest on 2020-03-02 10:20:16
@snotlicker , thanks!
https://github.com/TheQwertiest/smp_2003/commit/c7d62119559fb1c46f4dcd43f74390b58f8f028e
Post by: Anakunda on 2020-03-03 13:38:32
would be SpiderMonkey able to capture metadata from online source, apply them to audio tags, and eventually transfer the cover to album folder? The similar task what Discogs plugin does, just for custom source. If that's possible, could I get a hint what functions to use for it. Also I'd appreciate an existing script previously made for the same purpose as a template, if some.
Post by: Miltiades on 2020-03-14 21:15:09
Hallo there,
I'm using (latest) foobar v.1.5.2. I have also SpiderMonkeyPanel, Biography and JScript Panel on latest version.
It was working properly, as it should since yesterday at the afternoon: I can't see either artist pictures nor pictures from covers.  I see only text (biography) but no pictures.
Any suggestions please?
Post by: wcs13 on 2020-04-01 14:14:00
I'm bumping this because it's been a month :
If %artist% is empty but %composer% is filled, WilB's bio creates a %composer% folder and downloads info, but marc's Thumbs does nothing. Any hints ?
Post by: snotlicker on 2020-04-01 18:31:41
https://github.com/TheQwertiest/smp_2003/blob/master/js/helpers.js#L628
If all your tags are single value, you could replace it with %artist% as that has automatic fallbacks built in...
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Title_Formatting_Reference#.25artist.25
If your tags are multi-value, you should use $meta to access the first value only...
$if2($meta(artist,0),$meta(composer,0))
Post by: wcs13 on 2020-04-03 03:09:45
Thank you. That worked indeed! My happiness is complete now :)
Yes, I totally get your code. I'm quite OK at Titleformat but I suck at JS. I only needed to find the right line(s) in the right file(s), so thank you for pointing this one out! I really appreciate.
Post by: wcs13 on 2020-04-03 14:10:31
New bug report, in helpers.js, line 511 :
		app.Namespace(10).MoveHere(file);
Error: Spider Monkey Panel v1.2.3 (Thumbs by marc2003)
app.Namespace is not a function
File: helpers.js
Line: 511, Column: 3
Stack trace:
  _recycleFile@helpers.js:511:3
  _thumbs/this.rbtn_up_done@thumbs.js:461:4
  _panel/this.rbtn_up@panel.js:142:5
  on_mouse_rbtn_up@<main>:49:9
Post by: snotlicker on 2020-04-04 05:32:56
That would be a component bug. For now you can replace that line of code with
_deleteFile(file)
This bypasses the recycle bin though - files get deleted for good.
Post by: mjm716 on 2020-04-04 16:37:01
I recently updated to 1.5.3 and have had a steady stream of crashes since. I can't really understand the reports, other than they seem to indicate SMP (and probably Marc's Thumb script)? (using v1.2.3)
Can anyone help me decipher these?
CRASH:
CheckMenuRadioItem failed:
Index is out of bounds
File: thumbs.js
Line: 323, Column: 4
Stack trace:
  _thumbs/this.rbtn_up@thumbs.js:323:4
  _panel/this.rbtn_up@panel.js:85:4
Different CRASH
DrawImage failed:
GdiPlus error: DrawImage failed with error (0x7): Win32Error
File: helpers.js
Line: 265, Column: 3
Stack trace:
  _drawImage@helpers.js:265:3
  _thumbs/this.paint@thumbs.js:92:23
  on_paint@<main>:58:2
different CRASH:
DrawImage failed:
File: helpers.js
Line: 280, Column: 3
Stack trace:
  _drawImage@helpers.js:280:3
  _thumbs/this.paint@thumbs.js:136:23
Post by: snotlicker on 2020-04-04 17:14:27
Pretty sure that's your fault for bypassing the available menu options and entering your own thumbnail size via the Properties dialog???
Post by: mjm716 on 2020-04-05 04:33:07
good lead - I do have one panel with custom thumb size. thank you, I'll see if that helps.
Post by: TheQwertiest on 2020-04-06 12:15:23
It might be a casing error, try replacing `Namespace` with `NameSpace`.
PS: component development is still on-going, if anyone was wondering =) The new (major) feature is just too non-trivial and it gets me frustrated all the time >_<
Post by: wcs13 on 2020-04-07 02:38:32
@TheQwertiest : casing error indeed! 'NameSpace' worked perfectly. Thanks, and please note the correction for future releases. Thanks again.
Post by: cerbaire on 2020-04-09 22:45:07
I love your PS. Take care.
Post by: SUPERCOOLMAN on 2020-04-10 07:42:33
hit a crash. I think it's having issue with some high res large png images. foo_uie_albumart allows user to pick resolution resizing quality, not sure if it's this problem or just not happy with the type of png file(s)
File: helpers.js
Line: 287, Column: 1
Stack trace:
  _drawImage@helpers.js:287:1
  _thumbs/this.size/<@thumbs.js:55:6
  r@lodash.min.js:5:356
  Xe@lodash.min.js:67:63
  _thumbs/this.size@thumbs.js:54:5
  _thumbs/this.update@thumbs.js:483:3
  _thumbs/this.metadb_changed@thumbs.js:167:3
  on_metadb_changed@<main>:33:2
  _panel/this.item_focus_change@panel.js:11:4
  on_item_focus_change@<main>:25:2
Spider Monkey Panel v1.2.3 (Thumbs by marc2003): initialized in 698 ms
Opening track for playback: "D:\ISU\OST_CD.cue" / index: 11
Out of memory: 1754042880/1073741824 bytes
overall I'm just looking for something that allows folder name with wildcard searching and allows multiple folders with cycling through all supported arts
Post by: Fabio258 on 2020-04-10 16:26:14
I'm searching a playlist viewer that can be linked to a specific playlist like EsPlaylist. Is it possible with jsplaylist? I've tried but It seems auto-linked to the active playlist  :(
Post by: Air KEN on 2020-04-11 07:51:24
Hi.
Picture cannot be displayed with Microsoft Store foobar2000 (not foobar2000 mobile).
https://www.microsoft.com/store/apps/9PDJ8X9SPF2K
Text only.Biography, thumbs ...
Spider Monkey Panel and JScript Panel.
Thanks for the help.
Post by: wcs13 on 2020-04-11 14:46:31
Hi, another question about Thumbs script :
I have noticed that downloaded images are often low-res, even when there are lots of hi-res images for the same artist on last.fm.
For some artists there are hundreds of images available, but the component just seems to pick the first ones.
Is there an option to either favor hi-res images, or the most upvoted ones, or to set a minimum res ?
If not, it would be a nice add-on. Thanks !
Post by: snotlicker on 2020-04-12 08:53:51
Look at this HTML and tell me which images are low/hi res. Thanks.
Post by: wcs13 on 2020-04-12 15:12:18
Hi @snotlicker , I just asked if there was an option that I wouldn't know about, because there are tons of things I don't know about.
If it's not possible, then it's not possible, but there's no need to be ironic.
Also, since I'm not a dev, I don't know if SMP scripts can check downloaded files.
Maybe we could download an unknown pic, then once downloaded check its dimensions, and if it's too small, just trash it and download the next one. I don't know!
https://www.tutorialrepublic.com/faq/how-to-get-current-image-size-in-javascript.php
Post by: Falstaff on 2020-04-12 17:30:12
HI,
as it is a script, you can modify jssplaylist to replace active playlist to a specific one, but it needs some changes to do that like replacing in script "plman.ActivePlaylist" with a variable that you have to set on init, by scanning existing playlists to find the index of the playlist you want to link to the playlist view (by playlist name testing imho ...)
HTH  ;)
Post by: TheQwertiest on 2020-04-13 09:44:58
@SUPERCOOLMAN, it's an out of memory error. The script preloads all images from the folder without resizing them (so as to support dynamic size, e.g. when resizing player), so if there are a lot of big images, it might eat all of the available memory. It might be possible to avoid this issue by resizing images immediately after loading them, but this way there won't be a higher resolution image for dynamic resizing.
@Air KEN , MS Store sandboxes their apps (by disabling some operations), in this case it might have disabled some internet related API used by SMP. Nothing I can do to fix that, aside from rewriting the whole networking stack (which I won't be doing any time soon).
@wcs13 , it might be possible to implement such logic in the script (ignoring low-res images that is), but I'm currently prioritizing component development over script improvement. In other words it won't be fixed anytime soon, sorry.
Post by: snotlicker on 2020-04-13 10:00:47
People getting out of memory errors with samples from the complete folder can open samples\complete\js\helpers.js and replace this function...
function _img(value) {
if (_isFile(value)) {
return gdi.Image(value);
} else {
return gdi.Image(folders.images + value);
with
let img;
img = gdi.Image(value);
} else {
img = gdi.Image(folders.images + value);
if (!img) return null;
const MAX_SIZE = 1000;
if (img.Width < MAX_SIZE && img.Height < MAX_SIZE) return img;
const s = Math.min(MAX_SIZE / img.Width, MAX_SIZE / img.Height);
const w = Math.floor(img.Width * s);
const h = Math.floor(img.Height * s);
return img.Resize(w, h);
Using the old function, I tested it with 8 large 5000px + images that take 40MB on disk but caused SMP to use nearly 900MB of ram according to window.PanelMemoryUsage
After this change, the reported value was 22MB.
edit: resizing doesn't come for free - there might be an apparent freeze for a second or 2 while it hogs the CPU!! YMMV.
Post by: TheQwertiest on 2020-04-13 10:23:11
That's because images are loaded in memory as uncompressed BMP, so it takes much more memory than it could've (or should've).
edit: resizing doesn't come for free - there is a performance penalty to be paid which might be noticeable?? YMMV.
This is caused by resize operation being performed on the main thread. I was thinking of making it async or maybe incorporating it `LoadImageAsync` (i.e. load *and* resize), but thought that such functionality was not that needed...
In long-term I'm planning to implement a new graphics back-end based on Direct2D (the support for current GDI/GDI+ back-end will remain), which should help with RAM utilization (amongst many other things).
Post by: Fabio258 on 2020-04-13 11:14:03
HI,
HTH  ;)
Hi Falstaff, nice to see you here again  :)
Yes, if I was a programmer this can help me a lot, but sadly my programmer skills are slightly above 0  :'(
And I don't want anyone to do the job for me for free.
In jsplaylist there is already a menu with a list of existing foobar playlists. I'm sure that can be modified to lock the view to the selected playlist but I've no idea on how to do this and how long it takes. So, if there is someone who wants to do it for me, please send me a PM.
Many thanks to all for this beautiful player and plugins
Fabio
Post by: SUPERCOOLMAN on 2020-04-13 11:32:53
ideally, script should generate only the small thumbnails when thumbnails is enabled. for main image, it should just keep a list of images file path found when current track's playback starts. script only need to load an image when being shown/drawn during current track's playback. there is already refresh/reload option when user want to refresh list of available images
another way to do this would be detecting screen resolution at the beginning and just down scale all images larger than that to screen resolution or smaller before loading since screen resolution is your display upper limit
In long-term I'm planning to implementing a new graphics back-end based on Direct2D (the support for current GDI/GDI+ back-end will remain), which should help with RAM utilization (amongst many other things).
that would be a great improvement
one of the problem with the old albumart is that it doesn't pre-load or cache images during current track's playback, so it causes fb2k to freeze for 1-3 seconds every time it cycles to a high resolution image
Post by: snotlicker on 2020-04-13 11:34:56
For just one script (thumbs), use JScript Panel. It has none of these issues.
Post by: SUPERCOOLMAN on 2020-04-13 11:39:20
unfortunately, for another complex script, I had to freeze JSP at pretty old version due to newer JSP causing breakage. marc2003 has also completely removed his repositories, so this is the only current repository for the thumbs
Post by: snotlicker on 2020-04-13 12:07:04
What version? Just checked and anything newer than v1.1.6.1 should have thumbs included.
Last.fm functionality will be broken in every version except the latest but since you're have issues with hi-res images, I'm assuming you're using custom folder mode which hasn't changed in years.
Post by: TheQwertiest on 2020-04-13 12:11:56
I think this is the easiest solution\workaround to your problem (coupled with the snippet @snotlicker posted above). But async resize would be needed to avoid fb2k freeze. I think I'll just add resizing to LoadAsync, coz I have a few huge album arts as well that I'm too lazy to resize, which cause fb2k to stutter every time they load...
Post by: Falstaff on 2020-04-13 17:09:53
Bug report:
in panel script editor, "Replace all" makes freezing/looping the program when searched string is a word in lowercase and the new string is the same word in uppercase
i.e: Replace "text" by "TEXT"
i've just lost 50 minutes of works :(
Post by: TheQwertiest on 2020-04-13 17:34:44
That... should not happen =)
I'll take a look tomorrow.
Post by: Falstaff on 2020-04-13 18:06:28
Post by: wcs13 on 2020-04-14 03:57:35
Sounds great for me. Nobody's in a hurry. :)
I'd love it if it can be achieved someday, so please put it in your to-do list and you'll get to it eventually.
Many thanks for your work and your expertise!
Post by: mjm716 on 2020-04-14 12:47:34
I clean my images up (over 10GB of artists alone) in minutes using Agent Ransack (https://www.mythicsoft.com/agentransack/) and Image Resizer (https://www.bricelam.net/ImageResizer/).
e.g. AR can search for image files of size> or dimensions> and the sortable results list can easily be batch resized by ctrl-click & IR
Post by: TheQwertiest on 2020-04-16 15:41:45
@Falstaff , `Replace All` is not working at all in the current version, REGEXP is borked as well. I'll fix it today\tomorrow.
Post by: wcs13 on 2020-04-16 17:22:44
XnViewMP (https://www.xnview.com/fr/xnviewmp/) can do it too on its own, no need for two pieces of software :
1. Tools > Search (Add > File Size > Is greater than or equal to > 1000 > KiB)
2. Select all results
3. Right Click > Batch Convert (Add action > Image > Resize, then set all relevant options, everything is possible)
Post by: Bollerkopp on 2020-04-23 08:44:50
Hello,
if I use some of the samples of the "complete" folder (e.g. "last.fm bio.js"), the panel crashes and I get the following error message:
Error: Spider Monkey Panel v1.2.3 (Last.fm Bio by marc2003)
include failed:
ActiveXObject_Constructor failed:
WinAPI error: GetTypeInfo failed with error (0x80029c4a): Unknown error
File: helpers.js
Line: 588, Column: 11
Stack trace:
  @helpers.js:588:11
  @<main>:5:1
I'm on Windows 10 64bit with foobar2000 v1.5.3.0.
What could be the problem? Thank you very much in advance.
Post by: hexenszene on 2020-04-26 09:24:26
Hope this is the right place to ask, but has the Spectrogram Seekbar that used to run on WSH Panel been upated for SM Panel?
This is the old one: https://pastebin.com/6n0ZmTtB
I know SoX is or would be required...
Post by: hexenszene on 2020-04-27 18:03:38
Another question...   My SM Panels seem to be missing a font, so the down arrow isn't displaying properly.
See here:  https://imgur.com/a/FHia3X7   Does anyone know how  to resolve this?
And last but not least, Marc2003 used to have a Last.fm script for WSH Panel that allowed you to see "top tracks" and "top albums" for an artist.  Has this been updated for SM Panels yet?
Thanks all.
Post by: TheQwertiest on 2020-04-28 10:12:34
@Bollerkopp , not sure, why you are getting this error. The library in question (`Mshtml.dll`) should be available on all supported Windows systems. Are you using a norrmal fb2k or a fb2k from Windows Store? There were reports about issues in Windows Store version.
@hexenszene ,
AFAIK, no.
have you installed `Font Awesome` as per `readme`?
`complete/last.fm similar artists + user charts + recent tracks.js`
@Falstaff , regretfully, the fix is still not ready. Hopefully I'll have enough free time and energy to complete the fix soon (it's 95% ready).
Post by: hexenszene on 2020-04-28 13:36:50
@hexenszene ,
AFAIK, no.
Thanks for the help.  I had looked for a readme in the folder but somehow missed it.  Issue solved.
Regarding the script "complete/last.fm similar artists + user charts + recent tracks.js" -- this doesn't seem to have "top albums" or "top tracks" in it.  The only choices seem to be "last.fm user charts", "recent tracks", and "similar artists".  Am I missing something?
Post by: MojoBass on 2020-04-28 20:00:00
The Youtube Track Manager (YTTM, see here (https://hydrogenaud.io/index.php?topic=105522.100)) is listing top albums and top tracks out of the box. Runs as well on SMP.
Post by: hexenszene on 2020-04-30 13:44:47
This is awesome!  Thank you!
Post by: Falstaff on 2020-04-30 17:15:45
*waits* ;)
Post by: TheQwertiest on 2020-05-06 15:46:21
@Falstaff , should be fixed (hopefully) in the latest nightly build. What a PITA it was...
Post by: Falstaff on 2020-05-10 11:14:19
thanks, i'll test asap
Post by: MordredKLB on 2020-05-29 04:46:45
@TheQwertiest
I was building foo_spider_monkey_panel just fine and then I upgraded to VS2019 - 16.6, and the kmeans code throws errors wherever ranges::... is used. I think this is probably fixed by bumping up the range submodule dependency, but it looked like you were purposefully using an older version. Am I out of luck here?
Post by: TheQwertiest on 2020-05-29 19:45:53
@MordredKLB , haha, well I've updated my VS as well and it indeed fails to build, but not in `range-v3` part :P
What is the commit that your range submodule is on? (`cd submodules/range` & `git status` ).
Post by: MordredKLB on 2020-05-30 18:31:42
Well, After rebasing last night to get your 16.6 changes, everything is good again, and DEBUG builds just fine. I still can't build release versions though.
I'm getting dozens of these 3 errors which shows me they're all related, but I can't figure out where the mismatch is coming from:
LNK2038	mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '2' doesn't match value '0' in abort_callback.obj
LNK2038 mismatch detected for 'RuntimeLibrary': value 'MTd_StaticDebug' doesn't match value 'MT_StaticRelease' in abort_callback.obj
LNK2001 unresolved external symbol __CrtDbgReport
Also, when I try and use the debug build I made, foobar tells me I have missing dependencies.
This is why I should stick to JavaScript :D
Edit: I'm realizing now that I can probably use your "pack_component.bat --debug" script to build the debug component, which I guess is really all I need to be able to do.
Post by: snotlicker on 2020-05-30 19:03:04
Seems like your solution has a mix of statically linked and dynamically linked projects. They all need to be the same.
edit: and debug/release mixed up too??
Post by: MordredKLB on 2020-05-30 19:17:59
Yeah, it's weird. I haven't touched any of that stuff either. Fresh pull, run setup.py, open the .sln file and attempt to build release. All the components are set to RELEASE as well. Either way, I can now build a debug component and that's what matters.
Post by: TheQwertiest on 2020-05-30 19:44:31
You have to "Rebuild" the project when you change configuration. This is caused by some *make based dependencies (scintilla, lexilla), which output binaries to the same path in Release and Debug configuration (and they do not detect automatically the change in configuration to trigger the rebuild).
Post by: snotlicker on 2020-05-30 19:53:05
The current version of Scintilla now includes a VS project file for lexilla which makes it easier.
Post by: TheQwertiest on 2020-05-30 19:57:15
Thanks! I'll look into it.
Post by: TheQwertiest on 2020-05-30 20:01:47
@snotlicker , it seems that these projects can only produce dynamic libraries, so it's not really suitable for SMP =(
Post by: snotlicker on 2020-05-30 20:22:13
I normally use dynamic but did a quick test with static and it compiles and works just fine??
Perhaps you need to update your linker settings to remove the .lib file previously generated by nmake??
edit: here's a screenshot of my own project - note the increased file size on the right!
https://i.imgur.com/5CX6MTc.png
Post by: TheQwertiest on 2020-05-30 20:34:10
`*.lib` file that is produced by `Scintilla.vcxproj` is an export library. So if you link against it, it will actually link you against corresponding `*.dll`. You can test this by removing said `*.dll` file (the program should crash or disable the component once it tries to load the component library)).
[edit]: https://i.imgur.com/JT8l35w.png
As you can see *.lib has the size of only 2KB vs 2MB of *.dll.
Post by: MordredKLB on 2020-05-30 21:05:23
Ugh, should have thought to try that since it was clearly a release/debug mismatch. It's getting close to a decade since I worked professionally in VS/C-development so I've forgotten a few tricks.
Thanks for merging that PR!
Post by: snotlicker on 2020-06-02 07:20:59
Since I was locked on version 4.3.3, I didn't understand this issue but I guess you were on latest commit when you tried. Since a new version was released yesterday, I encountered the same issue and reported it here...
https://groups.google.com/forum/#!topic/scintilla-interest/vnegGNO6nKw
 It has now been fixed in version 4.4.2.
Post by: APECR on 2020-06-06 00:35:45
image_cache = function () {
    this._cachelist = {};
    this.hit = function (metadb) {
        var img = this._cachelist[metadb.Path];
        if (list.drag_stop && typeof img == "undefined") {
            if(!cover.load_timer) {
                cover.load_timer = window.SetTimeout(function() {
                    utils.GetAlbumArtAsync(window.ID, metadb, 0, true, false, false);
                    cover.load_timer && window.ClearTimeout(cover.load_timer);
                    cover.load_timer = false;
                }, 20);
        return img;
    this.getit = function (metadb, track_type, image) {
        var img;
        var quotient = (panel.flat_mode) ? 2 : 12;
        if(cover.keepaspectratio) {
            if(!image) {
                var pw = (cover.w+cover.margin*quotient);
                var ph = (cover.h+cover.margin*quotient);
            } else {
                if(image.Height>=image.Width) {
                    var ratio = image.Width / image.Height;
                    var pw = (cover.w+cover.margin*quotient)*ratio;
                } else {
                    var ratio = image.Height / image.Width;
                    var ph = (cover.h+cover.margin*quotient)*ratio;
        } else {
        // item.cover_type : 0 = nocover, 1 = external cover, 2 = embedded cover, 3 = stream
        if(track_type!=3) {
            if(metadb) {
                img = FormatCover(image, pw, ph);
                if(!img) {
                    img = nocover_img;
                    //item.cover_type = 0;
                } else {
                    //item.cover_type = 1;
        } else {
            img = streamcover_img;
            //item.cover_type = 3;
        this._cachelist[metadb.Path] = img;
        return img;
Help convert
Post by: TheQwertiest on 2020-07-10 17:39:14
Version: 1.3.0
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.3.0
Changelog:
Detailed description of API changes: https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_documentation/api_changes/#v130
Post by: snotlicker on 2020-07-10 18:46:00
SetFont doesn't work.
tooltip.SetFont is not a function
Pre-existing methods like SetMaxWidth still work.
Post by: MordredKLB on 2020-07-12 00:05:34
I'm seeing phantom tooltips that keep coming back after a script crashes and you reload it. I maxed out at 5 visible on top of each other at the same time. No real rhyme or reason I can tell to why they show up (or what values they have), but switching to foobar from another tab causes them to show again.
Seems like on a script crash Tooltip.Deactivate() might need to be called internally?
Post by: MordredKLB on 2020-07-12 07:04:47
I discovered this evening that gdi.LoadImageAsync can return the same task ID at certain times which was a serious problem when I was attempting to load two large images somewhat simultaneously and then check then check the IDs in the callback. Was pretty simple to migrate over to LoadImageAsyncV2 (which is much cleaner as well!) but still kind of a confusing problem.
I'm also running into a memory leak when doing window.Reload(). I tried some pedantic stuff to reproduce but it seems garbage collection works fine, except in my theme.
My foobar starts at around 250MB, and adds 10-20MB (seems somewhat dependent on size of the active playlist) each time I do a window.Reload(). Eventually foobar is using 1.3TBs and I get error messages like this immediately after my theme loads and I have to restart foobar:
Error: Spider Monkey Panel v1.3.0 (Georgia v2.0.0 by Mordred)
Out of memory: 4057804/1073741824 bytes
Still trying to figure out if there's something I can do to minimize things, or not.
Edit: Seems I can mitigate things somewhat by setting playlist = null; and all of WillB's library objects to null before doing window.Reload(). Somehow it seems objects in the global namespace get orphaned references on a window.Reload... and I have a lot of stuff in the global namespace.
Post by: TheQwertiest on 2020-07-12 12:10:15
Haha, welp, that's what I get for being lazy and not testing things properly =)
Thanks for reporting.
Strange, that should not happen. I'll take a look if I can reproduce it.
Do you mean that that `LoadImageAsync()` returns the same ID when ran serially? E.g.
ids = []
for (path in paths)
  ids.push[gdi.LoadImageAsync(path)];
// ids not unique
Task ID is just an object's memory address. The only way they could have the same id (in theory) is when the memory is reused (which is possible only if the previous task was finished and handled in the callback).
Regretfully, it's nearly impossible to fix such leaks without at least somewhat minimal repro scenario.
Try downloading debug version of SMP, enable GC zeal (https://theqwertiest.github.io/foo_spider_monkey_panel/docs/for_developers/component_development_tips/#test-with-gczeal) and see if the memory leak is still there.
Note: GC zeal will tank the performance, so it might take some time for the script to load.
Post by: TheQwertiest on 2020-07-12 12:48:00
@snotlicker , fixed in the Nightly build.
@MordredKLB , I've fixed the `ghost tooltip` in the Nightly build. Can you check if it fixes your memory leak as well?
Post by: MordredKLB on 2020-07-12 17:18:53
JFC, it was the god damned tooltip! Now I can spam the Reload() button on my theme, get memory up to 500MB, and it drops back down to 225-230ish within a few seconds. Also easy to verify since if I cause an error in the theme, memory usage drops back to a flat 207MB every time.
I can't believe it. Ghost tooltip issue is also fixed. Thanks so much. :)
Post by: MordredKLB on 2020-07-12 20:41:58
Not to be one of those people, but I noticed that ESR 78.x was released a few days ago. How difficult is the jump from 68 to 78? I wouldn't have even noticed, but I was rewriting some of my stuff using the class syntax and found out that I got a "fields are not currently supported" crash when trying to use class field notation. No big deal at all, I was just surprised to discover that the ESRs only release once a year or so.
One other question I've got, I've added the foo_spider_monkey_panel.js to my VSCode project, and it picks up types correctly for everything except window which gives me the following type error for every method: "Property 'RepaintRect' does not exist on type 'Window & typeof globalThis'." Any way around that?
Post by: TheQwertiest on 2020-07-13 10:53:52
Dunno. SM devs do not care much for API stability (or MSVC compatibility), so it might be anything between a simple SM recompile or a full-blown SMP rewrite.
Anyway, I won't start migrating to ESR78 before I finish the ConfigureV2 rewrite (which will take a loooong time).
The problem is that `window` object is a built-in JS object, which causes conflicts with SMP definitions.
There *is* probably a way to work around that, but I don't have any ideas =)
PS: If you *do* find a workaround, plz message me, so I could add it to the docs.
Post by: TheQwertiest on 2020-07-13 12:13:40
@MordredKLB , try smth like this:
    "compilerOptions": {
        // this is needed to suppress built-in browser objects (`window`, various DOM objects and etc)
        "lib": ["es2019"]
    "include": [
        // project files
        "**/*.js",
        // docs
        "../../user-components/foo_spider_monkey_panel/docs/js/*.js"
Post by: MordredKLB on 2020-07-13 16:04:58
        "lib": ["es2019"]
    "include": [
        // project files
        "**/*.js",
        // docs
Yup, that's what worked for me. BTW, I've made a ton of changes to the JSDoc stuff to fix VSCode false positives. Should I submit a PR for that? Not sure if everything currently works okay in intelliJ.
Post by: TheQwertiest on 2020-07-13 16:57:11
Sure, I will take a look.
Post by: TheQwertiest on 2020-07-14 15:53:18
I've tried to load 1000 images multiple times and didn't manage to reproduce the problem. Are you sure that the task id collision happened before it was utilized in `on_load_image_done()`? I.e. reuse of task id can only happen after the task_id is consumed by `on_load_image_done()` (which makes said task_id unused and available for further usage).
[edit]: Nvm, reproduced and fixed.
Post by: TheQwertiest on 2020-07-14 22:47:11
Remade `script showcase` page. Now it has screenshots and stuff!
Link: https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_showcase
Post by: snotlicker on 2020-07-14 23:12:18
Thanks to your screenshot, just spotted a bug in the Properties script where subsong index is undefined. This is because of case sensitivity again...
https://github.com/TheQwertiest/smp_2003/blob/7fc1d75cd73081e3a83cb16e6af0ef2405342150/js/list.js#L983
panel.metadb.Subsong should be panel.metadb.SubSong
Post by: TheQwertiest on 2020-07-15 10:49:07
Haha, nice catch =)
Btw, could you help with the `Last.fm Loved Tracks Manager` script screenshot (I can crop it myself if needed) and/or description, please? I've never used Last.Fm for anything other than scrobbling...
PS: It also appears that `track info + seekbar + buttons` script is borked, both on SMP and JSP. Hopefully, I have enough JS knowledge left to fix it :D
Post by: snotlicker on 2020-07-15 11:24:22
How is the track info+seekbar+buttons borked? I'm sure you know about the font requirements for the buttons. Perhaps your panel is far too big? Ideal height is around 60-80px
The behaviour of the seekbar where if you move your mouse too far away while dragging and the grip is released... that's by design.
(https://i.imgur.com/zaarAf5.png)
edit: the last.fm lover script has this description inside it...
This script makes use of the Spider Monkey "Playback Stats" database to import
and store loved tracks from Last.fm. Each loved track will have the value of
%smp_loved% set to 1. You can access this through all other components/search -
it works in the same way as "foo_playcount" - all values are stored in a database
file and no files are tagged. Each record is bound to "%artist% - %title%" so
common tracks across different albums will share the same loved status. Right click
the heart iocn to set your Last.fm username and authorise the script through your
browser. You can then import all your loved tracks and then use the heart icon
to love/unlove tracks.
edit2: Of course the glaring error in that text is that you won't see a heart icon until AFTER you've configured your username and authorised through your browser. Until, then you'll see a little red exclamation mark.
Post by: VlaKor on 2020-07-15 14:47:40
Post by: TheQwertiest on 2020-07-16 13:53:40
Yep, that was it =)
@VlaKor , thank you as well =)
Post by: jazzthieve on 2020-07-16 18:40:53
Speaking of Last.fm Loved Tracks Manager, is there a way to indicate in playlist with a value which tracks are loved? The only way to see is to go to the lastfm website or when a track is playing.
Post by: TheQwertiest on 2020-07-16 19:05:25
@jazzthieve , if your playlist supports the display of custom tags, you can use `%smp_loved%` to get the value for the track (1 - loved, 0 - not really...).
E.g. `$ifequal(%smp_loved%,1,♥,)`.
Post by: jazzthieve on 2020-07-16 19:43:54
Great, thanks.
Post by: TheQwertiest on 2020-07-18 13:14:52
Version: 1.3.1
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.3.1
Changelog
Hotfix for v1.3.0 (see changelog above (https://hydrogenaud.io/index.php?topic=116669.msg985305#msg985305))
Post by: MordredKLB on 2020-07-21 06:32:04
Haven't noticed any issues with 1.3.1. Thanks for being so responsive.
In my playlist, I've got hyperlinks that will create/replace the current playlist with a new search based on what you clicked on. I.e. you click on the artists name and the playlist just shows all songs by that artist. It bugged me that if I was playing a song by Tool for instance, and clicked on the artist name, calling plman.ClearPlaylist(pl) would also lose the playing status of the current playing song (i.e. it wouldn't show as being played anymore even though it's metadb was in the contents of the playlist).
So I devised this workaround to remove everything from the playlist except what was being played, then add the contents of the search back in:
const pl = plman.FindOrCreatePlaylist('Search', true);
if (pl === plman.PlayingPlaylist && plman.GetPlayingItemLocation().PlaylistIndex === pl) {
plman.ClearPlaylistSelection(pl);
plman.SetPlaylistSelection(pl, [plman.GetPlayingItemLocation().PlaylistItemIndex], true);
plman.RemovePlaylistSelection(pl, true);
const playing = new FbMetadbHandleList(fb.GetNowPlaying());
handle_list.Sort();
const handle_copy = new FbMetadbHandleList(handle_list);
handle_copy.MakeIntersection(playing);
if (handle_copy.Count === 0) {
plman.ClearPlaylist(pl);
} else {
handle_list.MakeDifference(playing);
plman.InsertPlaylistItems(pl, 0, handle_list);
} else {
// nothing playing or Search playlist is not active
This works, but it seems incredibly hacky to me, and is hard to read. Is there a better/another way to remove items from a playlist than using RemovePlaylistSelection, or otherwise do this?
Post by: snotlicker on 2020-07-21 08:02:49
Not sure modifying the contents of any existing playlist is the way to go if other people are using this?? To be safe, I'd be sending the contents of the query to a new playlist every time.
But if you really want to remove the playing track from the handle list of results, use BSearch to find its index and remove it.
Post by: TheQwertiest on 2020-07-21 10:45:25
@MordredKLB , it's just the way fb2k works - played item is bound to the playlist it's playing on. If you clear a playlist then it's no longer bound to it (from fb2k point of view). So, yeah. The only way you can preserve this connection is by removing all other items like you currently do (but you can simplify it a bit via BSearch as suggested by @snotlicker ).
Post by: MordredKLB on 2020-07-21 16:34:10
It uses a specific playlist each time. Think of it like the CUI "Filter" playlist, or WillB's "Library Playlist". When you make a new selection the contents of that specific playlist are always replaced.
I want to do the opposite of removing the playing song. :) I want to see if the currently playing song is in the results of the search, and if so, remove everything else and then add the results of the search.
Post by: MordredKLB on 2020-07-21 16:35:35
I'm not sure how BSearch helps since I've already got the index from plman.GetPlayingItemLocation().PlaylistItemIndex.
Post by: snotlicker on 2020-07-21 17:00:10
I was talking about this....
handle_list.Sort();
} else {
...but maybe I have no idea what you're doing at all. If whatever it's supposed to do works, just leave it and forget I said anything. :D
Post by: MordredKLB on 2020-07-21 17:28:28
I gotcha. Sorry I misread what you were saying earlier. This is much cleaner now:
handle_list.Sort();
const index = handle_list.BSearch(fb.GetNowPlaying());
if (pl === plman.PlayingPlaylist && plman.GetPlayingItemLocation().PlaylistIndex === pl && index !== -1) {
// remove everything in playlist except currently playing song
handle_list.RemoveById(index);
} else {
Post by: MordredKLB on 2020-07-24 06:12:21
So I've noticed something kind of annoying with Georgia in FSM. When I start up foobar, everything has to spin up as my library loads and FB checks for changes. At the same time FSM is trying to parse my theme, and it's not uncommon to get a "this script is taking too long would you like to kill it" message. It appears that when the dialog is up, FSM freezes the scripts so even though they'd become responsive by the time you have a chance to click continue/kill it doesn't happen. Is there some way to increase the timeout before this warning when foobar is starting up... or not pause the scripts and clear the dialog if they do become responsive again?
Alternatively, is there something I can do in my scripts at startup to prevent this from happening?
BTW, don't know if it matters but my configuration is just a single include of a georgia-theme.js file, and that georgia-theme.js file is what actually includes all the js files for the theme. Figured that would give me more flexibility when updating the theme to add/remove files at will, but maybe the nested includes cause issues?
Post by: TheQwertiest on 2020-07-24 11:14:40
Nope, won't be changed.
That would be neat. I'll see if it's possible to do this.
The proper way to avoid holding stuff for long time would be to make initialization segmented, which would yield the control after each segment is completed (with smth like a progress bar). E.g.
// This is pseudo-code
is_initializing = true;
function on_paint() {
  if (is_initializing) {
    print_loading_in_progress();
  else {
    print_normal_stuff();
function init_short()
  // basic init that doesn't hold for long
async function init_long() {
  while (has_stuff_to_do) {
     let promise = new Promise((resolve) => {
       stuff_to_do = get_current_init_part();
       stuff_to_do.do();
       resolve(stuff_to_do.id)
     stuff_id = await promise; // this will yield the execution
     console.log(`$(stuff_id) done`);
  is_initializing = false;
init_short();
init_long();
The panel is considered a single script. I.e. it doesn't matter if it uses `include()` or just has everything inlined.
Post by: MordredKLB on 2020-07-24 17:39:49
I might try some tests with async/await wrapping includes. The warning seems to be entirely dependent on whether my hard drives need to spin up first... something I haven't been able to get to happen today. If the HDD is spinning, FSM loads my theme in <300ms at startup. Refreshing the panel after foobar has started takes about 20ms, so it's not that the script is actually slow.
BTW, I stupidly had clicked the "don't show me this again" checkbox. Is deleting the foo_spider_monkey.dll.cfg good enough to reset that? It didn't reset the panel configuration so some data is being stored elsewhere at least.
Edit: Rebooted my computer and got this to happen again. Async processing of files won't help the situation. I verified the file it had hung on last time, and it's the very second file I include, and it died at line 70, where I define the RGB helper function. Not exactly a tight loop.
Post by: Black_Over_Bills_Mothers on 2020-07-26 12:39:47
Using;
handle_list.AttachImage(img_path, 0)
If img_path contains ( or ) then image file is not found.
Post by: snotlicker on 2020-07-26 12:58:18
You sure? Just tested and it works exactly as expected with () in the filename.
Post by: Black_Over_Bills_Mothers on 2020-07-26 13:45:52
Hi snotlicker
Thanks for the quick response. You are correct and I'm guilty of such a stupid js school-boy error. Too embarrassed to tell what I'd done wrong. All working now. Thanks.
Post by: TheQwertiest on 2020-07-26 14:06:52
"don't show me this again" options is fb2k-instance-local. Meaning that it only affects the current process of fb2k and it does not persist across different fb2k launches.
@ your "hanging" problem: I'm trying to make "Slow script" dialog async, so that it would not halt the script execution. But I don't think I can do anything other than that.
Post by: MordredKLB on 2020-07-26 17:10:23
Does that mean you could also hide the dialog again, once things become responsive again, or no? Even if not it'd be a big improvement since users would be able to see the theme load behind the dialog.
Post by: TheQwertiest on 2020-07-27 09:53:00
Yes.
Post by: Black_Over_Bills_Mothers on 2020-07-27 14:15:35
I'm trying  to process selected files from a playlist. Firstly I want to convert them and I'm using:
fb.RunContextCommandWithMetadb("Convert/mp3 tablet",handle_list);
then I want to embed the album cover. My problem is the the RunContextCommand doesn't block so I need an event that is raised when all the files have been converted. Any ideas?
Post by: TheQwertiest on 2020-07-27 14:28:46
@Black_Over_Bills_Mothers , that's just the way fb2k API works. Hence can't do much if the invoked command is non-blocking :\
Post by: fbuser on 2020-07-27 16:44:51
In general you could use something like the code below. You need to replace <get handleList> and <do the processing for metaDb> with valid code and you might need to play a little bit with the timings.
const handleList= <get handleList>;
fb.RunContextCommandWithMetadb("Convert/mp3 tablet",handleList);
const processItem=() => {
  if(!handleList.Count) return false;
  const metaDb=handleList[0];
  handleList.RemoveById(0);
  return Boolean(handleList.Count);
   if(!processItem()) return;
   setTimeout(arguments.callee,20);
Post by: MordredKLB on 2020-07-27 16:48:31
That seems dangerous to me. You're essentially just guessing that each file will be written in 20ms. If HDDs need to spin back up, or a file is huge, this will fail just like B_O_B_M's original case.
Post by: fbuser on 2020-07-27 16:55:58
No, it's not dangerous. You just need to make additional tests during the processing and return false return true, if the file, which needs to be processed is not ready. Additionally a guard should be implemented to avoid endless processing.
Edit: Corrected and extended the answer.
Post by: Black_Over_Bills_Mothers on 2020-07-27 19:36:24
@All. Thanks for your replies. My best effort was to create an autoplaylist targeted at the destination for the converted files. I made a note of the file total and tested the playlist index of the autoplaylist and file count in the 'on_playlist_items_added(playlistIndex)' event. When I had all the files in the destination folder, I continued and embedded the album image in them all. Seems to work so far.
Thanks for your valuable time spent in helping me on this.
Post by: TheQwertiest on 2020-07-31 15:05:14
@MordredKLB , I've tinkered around a bit . Regretfully, it seems that it's impossible to make `slow script` dialog asynchronyous (without writing/using a new GUI stack): the problem is that GUI handling/processing is performed on the main thread, so if the main thread is stuck (e.g. in the infinite loop in JS), then no GUI messages can be processed making it impossible to interact with any dialogs (including `slow script` dialog).
While I understand your problem, I just don't know what can be done without removing the `slow script` check. I will try to extend the time limit a bit for the script on fb2k startup (in case there's some async stuff that hogging up the CPU), but it's still won't be a universal solution and it might not help much in your case.
[EDIT] Welp, no idea how to check that fb2k has loaded everything. Hence decided to make `slow script` time limit configurable (Advanced > SMP > Performance > Execution time limit).
Post by: MordredKLB on 2020-07-31 21:22:08
Thanks for investigating and I was afraid that might be the issue.
In further thinking, I might play around with async loading, just to see if maybe that can help. It all depends on what's actually happening behind the scenes with FB freezes trying to read from the HDD. i.e. do the other threads completely get locked out while that's happening, or are they just processing very slowly. If it's the first (which seems likely) then there's nothing to be done, but if it's the second, it might make this issue harder to encounter. It's weird though that SMP can still display the dialog.
Honestly this seems like a FB issue, and I'm wondering if we should report to @Peter .
Post by: TheQwertiest on 2020-07-31 21:45:14
SMP can display a modal `slow script` dialog during JS execution, because this dialog is invoked during JS interruption callback (i.e. it actually stops JS execution, thus it no longer stalls the main thread). The dialog could not have been displayed if the main thread was stalled by smth not JS related (this `not JS related` stuff might slow-down JS execution enough to trigger the `slow script` though).
If you have a debugger (e.g. visual studio), you may try to diagnose the issue by attaching to fb2k and breaking during the freeze. It will at least show the `.dll` on which fb2k is stuck.
Post by: MordredKLB on 2020-07-31 21:57:42
Well this is my confusion. Are you saying SMP executes the JS in the main thread then? In that case I would have thought that the interruption handler wouldn't have been able to work since it's also on the main thread, unless I'm misunderstanding how that even works.
I might try the debugger trick, or maybe just wait and see if I'm the only one actually running into the issue. It's a pain in the ass to get conditions right to even occur naturally (although I haven't messed with HDD spin-down times yet...)
Post by: TheQwertiest on 2020-07-31 22:14:35
Yep. Most of the JS stuff is executed on the main thread. A lot (most?) of GC is performed on worker threads though (memory deallocation is not cheap, so it gives a good performance boost).
I didn't look in the Spider Monkey internals too much, but it probably looks smth like this:
// SM internals
// Everything here is executed on the main thread
void JSMachineRunner()
  while (hasStuffToDo)
    auto currentPart = GetNewPart();
    ExecuteJSMaybe(currentPart);
void ExecuteJSMaybe(JSPart part)
  if (interruptRequested)
    InvokeInterruptCallback();
  ExecuteJS(part);
I.e. in JS engine itself the JS code is not monolithic, but split in parts that are fed in a JS runner (even an infinite loop like `while(true){}`). Thus making the interruption (and `slow script` dialog) possible.
Post by: MordredKLB on 2020-08-01 05:32:06
Got it. Well, i'll give the async script loading a shot. Wrap every file in a await promise with setTimeout(() => {}, 1) and see if that improves the situation.
Post by: Mrakobes on 2020-08-01 16:43:58
problem 1: Artist Images (thumbs.js)
help to configure the paths for displaying the covers in the "covers" folder, the problem is that sometimes I place this folder in the album, it is one level higher (in the case of a two-disc edition) - I just can't configure the second option. I want the code to look for the "covers" folder first in the lower directory, then, not finding it there, went up one level, and so on
problem 2: last.fm similar artists + user charts + recent tracks
similar unicode characters are not displayed correctly (bands in German, French)
problem 3: last.fm
I can not configure the folder for uploading photos from last.fm to the same directory as the artist
problem 4: musicbrainz
the discography is sorted by year in reverse order and I want to increase
Post by: MordredKLB on 2020-09-24 21:26:00
Wanted to follow up that loading scripts async made the issue go away. I haven't seen the slow-script warning popup in the last 2 months.
My code for anyone who has this same problem (probably nobody else):
function loadAsyncFile(filePath) {
    return new Promise(resolve => {
        setTimeout(() => {
            include(filePath);
            resolve();
        }, 1);
const basePath = fb.ProfilePath + 'georgia\\';
async function includeFiles(fileList) {
    for (let i = 0; i < fileList.length; i++) {
        await loadAsyncFile(basePath + fileList[i]);
includeFiles([
    'js\\CaTRoX_QWR\\lodash.min.js',
    . . . // all other files
Post by: TheQwertiest on 2020-09-25 21:06:51
@Mrakobes , regretfully my free time is very limited currently (even more than before, because of the new job I've landed). Because of that I won't be focusing on script development, but rather on component itself (I will steal some script fixes\improvements from @marc though :P)
@MordredKLB , glad to hear that it's working out for you =)
Post by: wcs13 on 2020-09-25 23:16:54
Hi :) This is obviously not the best moment judging from your last post. I just wanted to remind you this one from about 6 months ago, so you can keep it in mind when the moment comes. Many thanks in advance !
Post by: snotlicker on 2020-09-26 03:40:42
Quick hack, complete\js\thumbs.js, line 492, replace the existing function with this..
	this.update = () => {
this.image = 0;
this.files = [];
this.images = [];
let tmp = _getFiles(this.folder, this.exts, this.properties.sort.value == 1);
tmp.forEach((item) => {
let img = gdi.Image(item);
if (img && img.Width >= 500 && img.Height >= 500) {
this.files.push(item);
this.images.push(img);
this.size(true);
window.Repaint();
Change the dimensions as required.
Post by: snotlicker on 2020-09-26 11:27:18
^Forget I posted that. It will lead to undesirable/buggy behaviour. It could be done properly but I'm far too lazy for that.
Post by: davideleo on 2020-10-25 11:18:01
fb.GetNowPlaying() method returns the actually playing (or paused) track, and returns a null value when the player is stopped, but it seems that foobar2000 stores a reference to the track even once it is stopped, because it is resumed when pressing the "play" button subsequently. Panel Stack Splitter also seems to access that reference when titleformat mode on start up is set to "Now playing".
So, given my assumption is not wrong, is there a SMP method that returns that same reference?
Post by: snotlicker on 2020-10-25 11:36:38
That's why callbacks like on_playback_stop exist.
Post by: davideleo on 2020-10-25 14:16:11
Yes, but this does not answer my question. or does it?
Post by: MordredKLB on 2020-10-25 16:48:55
I believe Marc is saying that in the on_playback_stop you could record a reference to the track.
From what I can tell, I think you're actually confusing having a reference to the last song played with the active playlist item. If I stop a song, and then press play, it isn't that foobar is remembering what the song is, it's just playing from the current position of the active playlist. When I play an entire playlist and then playback stops, when I hit play again, it doesn't play the last song, it plays the first song in the playlist.
Post by: davideleo on 2020-10-25 18:17:08
But if I stop a song and then select another item in the active playlist, when I press play the playback does not start from the selected item, but from where the playback stopped. Furthermore, it does so even if I move the selected item above the previously playing song, so that its index is changed, which apparently means foobar is remembering the song and not the position.
Post by: davideleo on 2020-10-26 08:50:15
EDIT: Sorry, I posted in the wrong thread!
Post by: snotlicker on 2020-10-26 19:10:13
It seems I have no idea what anyone is on about. I thought the original issue was something like this.
var g_metadb = fb.GetNowPlaying() // could be a valid handle or null
function on_playback_new_track(metadb) {
    g_metadb = metadb; // always a valid handle
    if (g_metadb) {
        //code here would run even if playback has stopped so long as g_metadb was valid at some point previously
I would "fix" like this...
function on_playback_stop(reason) {
   g_metadb = null;
g_metadb would always be a valid handle when playing and null when not.
Now it seems the issue has nothing to do with scripts/components at all and is simply not having main menu->"Playback/Playback follows cursor" enabled??
Post by: davideleo on 2020-10-26 21:35:31
My issue arises from the need to make a SMP script consistent with that of a PSS panel where titleformatting mode on startup is set to "now playing". Indeed it looks as if PSS is keeping record of the last played track, but I was wondering if this is what's actually going on under the hood or if PSS is referencing some value provided by foobar2000. My question was not how to keep record of the last playing track, which is not a big deal, but whether this supposed foobar2000 internal reference exists and if I'm missing a SMP method the retrieves it.
Post by: Emerelle on 2020-10-27 17:19:42
thank you very much for this awesome panel!
I updated almost all of my very outdated WSH panels and Im very happy.
One question - and a request for coding help :/
I am using the sample script of the menu button. I would love to add an onHover image to the menu image though.
Can someone give me pointers into the right direction?
Here is the script I use:
'use strict';
window.DefinePanel('Menu Button', {author:'marc2003'});
include(fb.ComponentPath + 'samples\\complete\\js\\lodash.min.js');
include(fb.ComponentPath + 'samples\\complete\\js\\helpers.js');
include(fb.ComponentPath + 'samples\\complete\\js\\panel.js');
let panel = new _panel(true);
let buttons = new _buttons();
buttons.buttons.menu = new _button(0, 0, 36, 36, {normal : 'misc\\foobar2000.png'}, (x, y, mask) => { _menu(0, 36); }, 'Menu');
function on_focus(is_focused) {
if (is_focused) {
plman.SetActivePlaylistContext();
function on_colours_changed() {
panel.colours_changed();
window.Repaint();
function on_mouse_lbtn_up(x, y, mask) {
buttons.lbtn_up(x, y, mask);
function on_mouse_leave() {
buttons.leave();
buttons.move(x, y);
function on_mouse_rbtn_up(x, y) {
if (buttons.buttons.menu.trace(x, y)) {
_help(0, 36);
return true;
} else {
return panel.rbtn_up(x, y);
function on_paint(gr) {
panel.paint(gr);
buttons.paint(gr);
function on_size() {
panel.size();
Post by: davideleo on 2020-10-28 19:35:43
From what I gather, you can add the hover image as a property of the fifth argument of the _button() function, which is an object.
If you look at line 10, you will see the img_src argument which is
Just add another property with key "hover" and value either an image (GdiBitmap), or if you place the image in the  "samples\complete\images" directory, a string with the last part of the image path.
For example
{normal : 'misc\\foobar2000.png', hover : 'buttons\\menu_hover.png'}
The _button() function code where you can learn all this is in the "samples\complete\js\helpers.js" script.
Post by: Emerelle on 2020-10-29 05:22:37
Thank you so much, davideleo!
It is hard for me since I am not a programmer at all; I will try out your suggestion today :)
Post by: JOSHSKORN on 2020-10-30 18:06:15
Hi.  I'm I've been racking my brain, trying to create a custom list of my library and I just can't seem to figure it out.  Basically, I want to list all of my artists and then albums.  See table example:
List(Artist, Album, Genre, Total Album Length, Total Number of Tracks, Date, Front, Back, CD)
The fields Front/Back/CD are to test the immediate folder for the contents of Front.jpg, Back. jpg and CD. jpg.
Can this be accomplished using Spider Monkey Panel?  If so, is there sample coding I can work off of?
Post by: davideleo on 2020-10-31 12:18:17
I'm very sympathetic to your issue because after some months of studying javascript I was still lost applying it to foobar2000 and the answer marc2003, alias @snotlicker , gave me to a similar question was enlightening and a turning point for me (I still have to thank him for this). You can read the exchange here (https://hydrogenaud.io/index.php?topic=110516.msg941771#msg941771).
Since that was a jscript panel discussion, here is a spider monkey version of the code, which is also lodash-free.
fb.ShowPopupMessage(listByTag("artist").join("\n"));
function listByTag(tag){
    let tags = [];
    let items = fb.GetQueryItems(fb.GetLibraryItems(), tag + " PRESENT");
    for (let i = 0; i < items.Count; i++) {
        let num = fb.TitleFormat("$meta_num(" + tag + ")").EvalWithMetadb(items[i]);
        for (let j = 0; j < num; j++) {
            tags.push(fb.TitleFormat("$meta(" + tag + "," + j + ")").EvalWithMetadb(items[i]));
    return [...new Set(tags)].sort();
Title: Re: Spider Monkey Panel (foo_spider_monkey_panel)
Post by: Emerelle on 2020-11-01 10:07:08
I had been using one of the one-panel examples, the text reader script. It crashed my foobar ever so often that I had to take the panel out of my layout.
I didnt add any modifications of the code at all, so I was wondering if there is a known issue with the loading time of this script? I get a "one script on this page is not responding" message when I add it to my layout up to the point foobar2000 will not come up anymore at all.
Its a real shame since I store the contents of audiobooks in a info.txt file.
Any hint very welcome!
Post by: zeremy on 2020-11-03 17:07:37
@TheQwertiest
Regarding the callback on_script_unload()
The docs say:
Called when:
- Panel script is reloaded via context menu > Reload.
- Panel script is changed via panel menu > Configure.
- fb2k is exiting normally.
Not called when:
- Script fails with error.
- fb2k closed externally (e.g. killed with process manager).
- fb2k fails with exception.
Do the same restrictions apply as the jscript component that the callback is not guaranteed to be called during unloading.?
Post by: TheQwertiest on 2020-11-03 19:53:59
@zeremy , AFAIK, JSP has mostly the same behaviour as SMP regarding `on_script_unload`. It's just not listed explicitly.
@Emerelle , does it fail for every track? Or does it fail only on specific file? If the latler, please send me an example, so I can reproduce the problem.
Post by: snotlicker on 2020-11-04 08:06:32
I think that was inherited from WSH panel mod and I've never given it a moments thought. I guess I should test/update the docs. I'm pretty sure it's always called but the original dev was just being extra cautious.
In addition to the SMP docs you quoted, it should also be called when removing/replacing a panel in layout editing mode.
Post by: Emerelle on 2020-11-04 12:11:03
@TheQwertiest It fails on load, when I start foobar. I get a notification that a script takes too long to load and if I want to stop it or wait for it to load. Sometimes even foobar does not load at all anymore and I have to kill the process.
Post by: Mrakobes on 2020-11-05 10:12:12
Recently (after updating the player), the script started to crash, this is observed on some audio.
(https://i114.fastpic.ru/thumb/2020/1105/80/_137c398386c40388a1238df355d9cd80.jpeg) (https://i114.fastpic.ru/big/2020/1105/80/_137c398386c40388a1238df355d9cd80.png)
I understand that the code was developed in collaboration with marc2k3, can here take the files
https://github.com/marc2k3/foo_jscript_panel
only problem is that samples are there in TXT no JS
Post by: VERDAE on 2020-11-05 17:26:15
Hey, I downloaded the SMP debug and now I'm getting this error whenever I try to open Foobar. What can I do to fix this? I'm also somewhat new to foobar so I apologize if this is a stupid question lol:
Error: Spider Monkey Panel v1.3.2-beta+f0830b60 ({269F9404-C9AD-4BFA-957D-26628B44C199})
include failed:
Invalid CLSID: UIHacks
File: JStheme_common.js
Line: 863, Column: 26
Stack trace:
  oUIHacks@JStheme_common.js:863:26
  @JStheme_common.js:1023:17
  @<main>:1:1
Post by: zeremy on 2020-11-05 21:13:09
@snotlicker
I found that the culprit not letting me run the callback in a script was your helpers.js that was an include.
It has the function
function on_script_unload() {
_tt('');
in it
and the second on_script_unload() in my script didn't get executed.
Maybe some sanity checks are needed as to define the same function only once.
Post by: snotlicker on 2020-11-05 21:31:43
The normal convention in javascript is that if a function with the same name is defined more than once, the last version always takes precedence. For example...
function message(name) {
    console.log("hello", name);
    console.log("bye", name);
message("zeremy"); // always outputs "bye zeremy"
But the include function built in to SMP breaks this convention so if the first definition is inside an include file, that will take precedence instead.
Post by: wcs13 on 2020-11-18 16:07:17
Thanks for trying though  :)
I hope it can be done properly by TheQwertiest or you at some point, because low-res art tends to ruin the whole Thumbs experience.
In my case I have a nice bio on the left half of the screen... and quite often I have a low-res art on the right half, even though I know that many hi-res pics exist for the same artist/album.
Hi-res art should definitely be prioritized IMHO (when available). It's not about completely avoiding low-res, but rather about preferring hi-res when possible. Fingers crossed.  :)
Post by: snotlicker on 2020-11-19 09:16:39
This might work instead...
this.image = 0;
this.files = [];
this.images = [];
_(_getFiles(this.folder, this.exts, false))
.map((item) => {
var img = gdi.Image(item);
return {
path : item,
image : img,
area : img.Width * img.Height
.orderBy((item) => {
return item.area;
}, 'desc')
this.files.push(item.path);
this.images.push(item.image);
this.size(true);
window.Repaint();
Post by: wcs13 on 2020-11-19 19:44:12
Thanks, trying to make it work :)
EDIT - doesn't seem to work.
I have tried it on Beyoncé. It seemed like a good example, since her last.fm page has 5000+ pictures, some low-res, some hi-res.
The modified Thumbs.js just appears to download the first n pictures in her page (in my case the first 10 pictures), regardless of their size.
Post by: snotlicker on 2020-11-19 20:44:54
That code is simply for re-arranging files that are inside the folder. Don't like it? Don't use it.
Do I really need to tell you that asking about thousands of images online is ****ing insane.
Post by: wcs13 on 2020-11-20 01:06:51
I may have missed something, but I don't think I was rude at all in my message. So why are you ?  :o
Do I need to remind you what was kindly requested months ago in the first place ?
You just posted a bit of code, with no indications of what it's supposed to do.
I'm not a dev. So of course I didn't examine the code, because I thought you were answering to what was requested.
Now you say that your code was only for re-arranging images (from hi-res to low-res in foobar I guess), which has little to do with what was requested (ignoring, not re-arranging).
Now don't get me wrong : I'm grateful for your bit of code and I'm grateful for you wanting to help.
It's of course better than nothing, but it's hardly a solution, because if Thumbs.js downloaded a majority of low-res images in the first place, then sorting them will not be very useful, unless we're only interested in the first or second image.
BTW, did I ever ask about parsing thousands of images online ? No !  :o  I'm not that stupid.
Ignoring low-res images can be much simpler. I assume you know lots of ways to do it. Here's one :
If we are reasonable with the enough-res resolution (e.g. 360.000 pixels min, that's 600x600), we won't need to ignore lots of images. So for n saved images, I guess we may need to parse 1.5n images, maybe 2n images, but hardly more.
I guess that's what @TheQwertiest suggested that he'd do when he'd have some time. If somebody is willing to do it, I'm sure I won't be the only one to be grateful. If not, then I'll just keep waiting. There's nothing else I can do.
BTW here's how my 32" 1440p display looks with a low-res image (see attached file). Like I said, it ruins the whole experience a bit.
Post by: regor on 2020-12-10 19:44:43
Is it possible to rename the main menu entries? (I was expecting it would be available on the preferences panel)
XX
Why? Because adding those menu commands to standard foobar buttons give the menu name as tool-tip texts.
X
Renaming the menu entries would give a clue of what they do without having to use text buttons.
Post by: cooldude on 2020-12-12 21:02:43
I've been trying to find a convenient way to view, select and automatically cycle through all the images which are in the same folder as a song, and also a subdirectory below. The "Artist Images"/"thumbs.js" script which is included is nearly perfect.
But currently, it only shows images from the same directory as the music file - using this:
$directory_path(%path%)
How do I set it up so that it also shows images from a directory below the file (for example, if there's a folder filled with covers)?
In addition, is it possible to also have it show embedded album art? Currently it can't.
So in summary, I'd like it to show the images in the same folder, the images in any folder which is directly below, and embedded images.
The last and smallest thing that would be nice to have, is to somehow change this background color (currently black):
(https://i.imgur.com/T46BJ6F.png)
The included setting doesn't change it.
Post by: regor on 2020-12-13 21:03:09
Probably not exactly what you needed, since I'm using other script. But sure you can take the path part to suit your needs.
window.DefinePanel("LoadImageAsync", { author: "XXX" });
let sel = ""
let path = ""
if (fb.IsPlaying) {
    sel = fb.GetNowPlaying();
    path = fb.TitleFormat("$directory_path(%path%)").EvalWithMetadb(sel);
// Get a list of jpg files from a folder
var pathart = ""
if (utils.FileTest(path + '\\art', "e"))
    pathart = '\\art\\';
else if (utils.FileTest(path + '\\artwork', "e"))
    pathart = '\\artwork\\';
else if (utils.FileTest(path + '\\_artwork', "e"))
    pathart = '\\_artwork\\';
const g_image_list = utils.Glob(path + pathart + '*.jpg');
let ww = 0, wh = 0;
let g_img = null;
let g_valid_tid = 0;
// Trigger every 5 seconds.
let g_timer = setInterval(function () {
    load_random_image_async();
}, 5000);
    let g_timer = setTimeout(function () {
        window.Reload();
    }, 1000);
function on_playback_starting() {
        window.Reload();
    }, 1000);
function load_random_image_async() {
    // Load a random image from the list
    let path = g_image_list[Math.floor(Math.random() * g_image_list.length)];
    // on_load_image_done will be triggered when the image has been loaded
    g_valid_tid = gdi.LoadImageAsync(window.ID, path);
    ww = window.Width;
    wh = window.Height;
    if (!g_img) {
        return;
    let scale_w = ww / g_img.Width;
    let scale_h = wh / g_img.Height;
    let scale = Math.min(scale_w, scale_h);
    let pos_x = 0, pos_y = 0;
    if (scale_w < scale_h) {
        pos_y = (wh - g_img.Height * scale) / 2;
    else if (scale_w > scale_h) {
        pos_x = (ww - g_img.Width * scale) / 2;
    gr.DrawImage(g_img, pos_x, pos_y, g_img.Width * scale, g_img.Height * scale, 0, 0, g_img.Width, g_img.Height);
// After loading image is done in the background, this callback will be invoked
function on_load_image_done(tid, image, image_path) {
    if (g_valid_tid === tid) {
        g_img = image;
        window.Repaint();
"Pathart" is the subfolder part you want. Ex:
ACDC/Black in black/Artwork/front.jpg
ACDC/Black in black/Artwork/...
ACDC/Black in black/track1
ACDC/Black in black/cover.jpg
I only have 3 possible artwork sub-folder names, so that's the 3 "if sentences" part.
Then const g_image_list = utils.Glob(path + pathart + '*.jpg') just merges the file path (track folder) with the subfolder path and takes all jpg files. It should work with any other extension, but beware I have no idea if js displays png or other image files right. I just note you can put whatever you want on that list.
So the first part of this script should work for you in your script in some way. It just displays 1 image at a time and cycle it.
About adding the embedded artwork, I have a "cover.jpg" file present on the base folder, so that's what I would check. Adding that file to the image list too. If you talk about the cover within the track, then you can check "GetAlbumArtAsync.js" on samples folder.
EDIT: After re-reading.. btw if it's just a matter of config editing and you can put whatever tittle-formatting you want then:
$directory_path(%path%) --> $directory_path(%path%)\artwork
That should do. Or your desired subfolder name. (Note, anyway, that would restrict the images to just the subfolder).
Post by: cooldude on 2020-12-14 23:03:03
Thanks. However, I can't find any "GetAlbumArtAsync.js" file anywhere, and probably wouldn't know what to do with it.
The way I can select particular images with the "thumbs.js" script is quite slick and practical, and something similar would be a must if I'm going to bother with this. But it seems it may not be possible to simultaneously view images from folders, subfolders and embedded images while using it.
I also don't mind using other scripts if there's ones which would work for all this. It's just that without being able to view all three sources simultaneously (images in folders, subfolders, and embedded), most of the album art in my different collections would end up missing.
There's an older WSH artwork script which might work and I want to try, hopefully someone can reupload it:
https://hydrogenaud.io/index.php?topic=77883.msg991453#msg991453
Post by: dwmartin0906 on 2020-12-20 01:03:50
Hi.  I have a strange issue using the on_mouse_mbtn_up function.  When my script is in an embedded panel, I have to double click to get the desired result.  A single click is ignored.  But when the same script is in a foo_flowin pop-up panel, it works just fine.   I also use on_mouse_lbtn_up and it works fine either way.  Does any one have an idea what might be causing this?
Post by: TheQwertiest on 2020-12-25 16:19:07
    Check image 1. If enough-res, save it, or else ignore it. Go to the next image.
    Repeat until you have n enough-res saved images.
That's actually the problem. To get image dimensions you need to download it. So, if there are only low-res images, you'll have to download all those images first.
I have plans to totally rework `main menu buttons` feature (and make it possible to generate buttons dynamically), but I don't think it will be done any time soon.
What do you mean by "embedded panel"? Also can you attach an example script that has such problem?
Post by: dwmartin0906 on 2020-12-26 02:56:36
Thank you for responding.  I used the term "embedded panel" to refer to a normal Foobar panel as defined with splitters, as opposed to pop-up panels created with foo_flowin.  And I found the problem.  Another component was set up to use the middle mouse button, even though I had never used it.  I redefined the keys used by that component and on_mouse_mbtn_up now works as expected with a single click.  I've just started learning Spider Monkey scripting and am amazed at the power and flexibility it offers.  Thank you very much for this amazing component and the excellent documentation you provide.
Post by: regor on 2020-12-26 17:59:46
Quote from: TheQwertiest
That would be much appreciated.
Also, would it be possible to add a Find(handle) → {number} function with configurable order (inverted too)? Or one which outputs all coincidences?
I'm working on a remove duplicates" function (more advanced than 'same raw path'), while maintaining playlist order by duplicating handles and working on sorted lists on parallel to the original one (A).
For 17K tracks that means 1.5 seconds (A). 327 seconds working without cloned sorted list. And 369 ms if I don't care about original order at all.
The problem I got for (A) is that remove(handle) removes all coincidences (but I one to maintain one!), so I use Find(handle) to  then remove by ID at the original unsorted list. But... it obviously outputs just one match, instead of all. And it always search from the start of the list, so the removed position is not configurable.
I'm currently doing this within some loops and other code (for tags):
									let handleAidx =[];
let idx = handle_list.Find(handleA); //Needed. Or it would remove all instances of the same handle!
let idxcache = idx;
while (idxcache != -1) {
handle_list.RemoveById(idxcache);
idxcache = handle_list.Find(handleA);
handle_list.Insert(idx,handleA); //It was last copy. Revert once to first place.
break;
With oriented search it would convert to:
									let idxA = handle_list.Find(handleA);
let idxB = handle_list.Find(handleA,-1); //Inverse
while (idxA != idxB) {
handle_list.RemoveById(idxB);
break;
Or find array result:
									let findArray= handle_list.Find(handleA);
let i = findArray.length;
while (i--) {
handle_list.RemoveById(findArray[i]);
break;
Which would be so much better and faster.
Post by: sndsAU on 2021-01-08 02:25:07
Hi, I am using the Spider Monkey panel and the included sample file "js smooth browser" for a cover art browser.
My question is, is there a way to actually cache the artwork to local disk? My music is stored on a NAS and the artwork is embedded in the flac files.
There is a setting that can be selected in the popup menu "Enable Disk Image Cache" but this seems broken/has no effect. Everytime foobar is restarted, the panel has to reread the art from remote files.
Post by: MordredKLB on 2021-01-14 08:34:41
Utils.Version returns the version of SMP, but I was wondering if there a way to get the version of foobar currently running?
Post by: zeremy on 2021-01-14 09:56:43
fb.TitleFormat("%_foobar2000_version%").Eval(true);
Post by: MordredKLB on 2021-01-14 16:22:43
Brilliant. Should have known there'd be a title_format field. Thank man!
Post by: regor on 2021-01-15 10:37:07
How do I load a playlist by path?
LoadPlaylist() doesn't accept any argument according to the documentation
Post by: snotlicker on 2021-01-15 10:53:14
plman.AddLocations. It expects an existing playlistIndex as one of the args so you might want to create a new one with plman.CreatePlaylist first.
Post by: regor on 2021-01-15 11:15:13
Yep, got it working. The idea is to have a playlist manager with {names/paths} and load playlists on foobar only on demand (instead of cluttering the playlist tab with all playlist loaded at the same time). So the name (and thus new ID needed) will be already given by the object. Thanks!
Post by: MordredKLB on 2021-01-15 17:14:07
@TheQwertiest FYI, the latest nightly causes foobar to crash on startup.
Post by: TheQwertiest on 2021-01-15 17:16:52
Are you using DUI? (https://github.com/TheQwertiest/foo_spider_monkey_panel/issues/129)
