Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 369241 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #1025
(not programmer here)
installed smp and smp-scripts,
added the line in the script:   include(fb.ProfilePath + 'smp-scripts\\smp-date\\smp-date.js');
but its showing me small font and a very detailed date format, on a white background
how do i make it show current date's hour:minutes in a large (impact) font, with the default colors of fb
Reply #1026
`smp-date` script is a user created script, hence the following disclaimer applies:
These scripts are created by SMP users and are not installed with the component.
For installation instructions (and support) see corresponding links.
Reply #1027
is it possible to convert a file from svg format (vector graphics) to png format when downloading.
There is a link for an example. I want to download this file in png
"https://cdn-gce.allmusic.com/images/logos/allmusic_wordmark.svg"
UR5EQF. Ukraine
Reply #1028
Rendering SVG is a complex process, so much that a lot of projects just import the entirety of InkScape on the command line just to render them.
Reply #1030
kode54, TheQwertiest,
thank you, I understand.
Sometimes if I want to add Spider Monkey Panel to Dockable Panels (foo_dockable_panels.dll) i have crash.
Where am I making a mistake.
UR5EQF. Ukraine
Reply #1033
Got another report about the rel. paths not working:
https://hydrogenaud.io/index.php?topic=120979.0
Btw, while writing some faq about my scripts thought it would be great to have a method to save the panel properties directly to a file (without the UI and user intervention). That would come really handy to create and manage backups or exporting config to other installations from within the script. (*)
(*) For ex. the playlist manager uses the properties for config, an additional json file for autoplaylists, fpl and other playlist's data and finally a folder with the physical playlists. Exporting the entire panel would be a matter of seconds if I simply output a zipped file with all those files/folders. Something similar happens in Bio panel, where backups require locating files from multiple places.
Reply #1035
Thank you, it works  :)
 X
YouTube Music
Reply #1036
@regor , I remember you sending me suitable screenshots for your scripts, but I can't for the life of me find them anywhere >_<
Do you recall by any chance where did you post them?
Reply #1037
Attached.
Reply #1039
Version: 1.6.0
Link: https://github.com/TheQwertiest/foo_spider_monkey_panel/releases/tag/v1.6.0
Changelog:
Spoiler (click to show/hide)
Detailed description of API changes: https://theqwertiest.github.io/foo_spider_monkey_panel/docs/script_documentation/api_changes/#v160
Reply #1040
TheQwertiest, how can I use packaging biography on two panels. Stopped working after updating.
Reply #1042
Do you mean WilB's script? And what do you mean by "stopped working"? Is there some kind of error message?
FYI new SMP panels still display 1.5.2.
Try invoking `console.log(utils.Version)`, if it returns 1.5.2, then it means that it's not 1.6.0 and that you are using an old version xD =)
Reply #1043
Error: Spider Monkey Panel v1.6.1-dev+d8d0f4bc ({04620F16-1878-47A1-8EFE-0CE0B99566CC}: Georgia-ReBORN v2.0.3 by TT)
include failed:
is_4k is not defined
File: settings.js
Line: 156, Column: 94
Stack trace:
  @settings.js:156:94
  loadAsyncFile/</<@georgia-reborn-theme.js:18:13
Solution?
Best Regards
Reply #1044
Yes, the script is from WilB. After updating the SMP, the biography panels (I use two biography panels) stopped loading pictures with text. If I delete one panel, then everything loads fine.
Reply #1045
include failed:
File: settings.js
Stack trace:
  @settings.js:156:94
Solution?
Best Regards
Hi Cardiacs,
this issue has been fixed, you can download it here.
Please post it next time in the Georgia-ReBORN thread, thanks for reporting!
-TT
Reply #1046
@kutuzof can't reproduce: both panels work fine for me. Can you share your setup? Or at least those panel's properties?
Reply #1047
You can download my entire assembly (no new SMP version) here. After opening the properties window and pressing the ok button, pictures with text begin to load. But after restarting the player, they do not load again, you need to open the properties again, etc.
Reply #1048
With update to SMP1.6.0 I am getting quite some instability and crashes, especially when changing presets within CUI. Crash location SMP,  call path entry=>app_mainloop, see attached.
Reverted back to SMP1.5.2, which is stable on my side. Any idea what could cause the issue?
Reply #1049
There is such a script. I use timers. The WSH works fine. Problems with the SMP.
If you have time, look.
UR5EQF. Ukraine
