Topic: Georgia: A dynamically generated fb2k theme (Read 97955 times) previous topic - next topic
Re: Georgia: A dynamically generated fb2k theme
Reply #250
Does anybody know why my PUBLISHER (Label) tags don't work with $meta_sep(?
Anytime I have more than one label now it doesn't show the logos in the bottom right corner, it just thinks it's one label, even though I separate them with semicolons.
{ "label": "Label", "val": "[$meta_sep(PUBLISHER, • )]" }, // The label(s) or publisher(s) that released the album.
-from my georgia-config.jsonc file
Really stumped on this
Reply #251
You're saying this stopped working recently? Are you positive that you've set PUBLISHER as a Multi-value field (check it in Preferences: Advanced =>Display => Properties dialog => Multivalue fields).
The line from the config you referenced is just for the entry in the meta grid on the left. The images are actually generated by calling $meta_sep on both LABEL and PUBLISHER fields (customizable by editing the tf.labels found in settings.js).
Reply #252
Yep, that fixed it. It's been so long since I've had to go into settings.js, I completely forgot about it. I didn't know it generated an image for the bullet point, interesting how that works.
Thank you, the theme looks especially flawless now with the ui hacks.
Reply #253
Link to Georgia.txt is broken, can't install.
Reply #254
Georgia.txt is included in the download package (only for JSP, for SMP georgia-install.js is included)
Reply #256
JScript Panel vs Spider Monkey Panel.
Reply #258
How do I know that as a first time user? Also I have no idea what JSP and SMP are.
@NateHigs: sorry for having been too short here. Are the other steps of the installation guide here from @MordredKLB clear? Please do not hesitate to ask futher questions!
Reply #259
Georgia Theme is literally gorgeous, and thanks for all your hard works.
I'm trying to change fonts since my native language isn't English, and 'HelveticaNeueLT Pro' font doesn't look good when printing other languages.
I modified all stuffs in fontList in 'georgia-theme.js' and 'georgia-main.js' which are look like this.
//georgia-theme.js
    const fontLight = 'HelveticaNeueLT Pro 45 Lt';
    const fontBold = 'HelveticaNeueLT Pro 65 Md';
//georgia-main.js
    const fontThin = 'HelveticaNeueLT Pro 35 Th';
    const fontRegular = 'HelveticaNeueLT Pro 55 Roman';
    const fontLightAlternate = 'NeueHaasGroteskDisp Pro XLt';
    const fontGuiFx = 'Guifx v2 Transports';
    var fontList = [fontThin, fontLight, fontRegular, fontBold, fontLightAlternate, fontGuiFx];
This worked with past versions, but doesn't work with v2.0.0-beta4.
It may be rude to modify your code since I'm an user, not a developer, but I will be happy using Georgia with my nice looking native language.
Can you help me with where to edit code to change theme fonts?
Thanks a lot!
Reply #260
@linuxlight You can ignore georgia-theme.js for now. The font code in georgia-main.js hasn't been touched in 8-12 months at least. What doesn't work if you change, say, fontThin to a different font? Are you positive you've got the name right? Right click the otf/ttf font in Windows and select Preview and then usually the correct font name to use will be listed as Font Name up at the top. Sometimes it's not the correct way to address it though.
Reply #261
Version 2.0 has finally been released. It's been pretty much all I've worked on for the last 8 months. Thanks to the amazing folks who helped me beta test, reported issues, and prodded me for features/improvements. It's really improved the quality of this theme.
I also spent a ton of time over the last week creating all new documentation, and writing up everything I could think of and taking tons of screenshots. I even recorded a new installation walkthrough.
Get the new version here.
Changelog is too big to post, but it can be found here.
Reply #262
@MordredKLB , you can fix the bugged search bar text colour in gh pages by changing `.search-input` variable - https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/gh-pages/_sass/custom/colours.scss (colours.scss is included via custom.css)
Reply #263
Somehow I hadn't even noticed. Thanks for the tip!
Also, thanks for showing me that gh-pages could have a decent looking documentation format besides the mostly terrible defaults!
Reply #264
Thank you very much for the new version of Georgia! However it keeps showing up an error from spider monkey panel and foobar crashes (I'm using latest version 1.6.4):
Error: Spider Monkey Panel v1.4.1 (Georgia: Georgia v2.0.0 by Mordred)
DrawString failed:
GdiPlus error: DrawString failed with error (0xb): ValueOverflow
File: georgia-main.js
Line: 408, Column: 8
Stack trace:
  draw_ui@georgia-main.js:408:8
  on_paint@georgia-main.js:949:2
Reply #265
Before line 408 can you paste this line:
console.log('>>>>', infoLeft, geo.top_bg_h - trackInfoHeight - scaleForDisplay(15), maxInfoWidth, trackInfoHeight);
Open the console, and then get it to crash again, and then paste the contents of that line to me.
Also when encountering the crash do you have cdArt?
albumArt?
Have you edited settings.extraTrackInfo at all?
In the mean time you can just comment out the gr.DrawString line on 408 to skip the crash while I try and figure out what's going wrong.
Reply #266
I have vinylArt and the crash happens when skipping songs. I didn't edit nothing on settings.extraTrackInfo.
How do I edit georgia-main.js to be able to paste that line?
Reply #267
Just replace it with the attached file.
Reply #268
Ok, I've replaced it and now it gives this error:
DrawString failed:
Line: 409, Column: 8
Stack trace:
  draw_ui@georgia-main.js:409:8
  on_paint@georgia-main.js:950:2
Reply #269
Yeah, sorry, I didn't disable the crash in that file. Can you paste the contents of the console? (I just need the line that starts with ">>>>")
Reply #270
Ok, here it is:
>>>> NaN 123.46200180053711 NaN 21.53799819946289
This line comes just before the error, when is fetching new art.
Reply #271
Well that explains it, but I still can't figure out how it's getting in that state. Can you try this one and paste the same line from the console afterwards?
Reply #272
With the new georgia-main.js the line is now:
>>>> 1918 20 516 NaN - flac | -4.38dB
One thing I noticed is that the error happens almost immediately in shuffle tracks or random mode, but if I play them in default mode, it takes many more time (several album covers changes) for it to occur.
Reply #273
Fixed! I was able to reproduce and squashed it. Seems to have been a race condition that occurred when switching from an album that had disc art to one without. Didn't happen all the time but should be good now.
Reply #274
It's working perfectly now! Thank you very much for your help.
