Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 366286 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #400
BTW I have noticed what could be a glitch on marc's Thumbs script. It's easy to reproduce.
Let's say %artist% = "Bryan Lee & The Jump Street Five"
WilB's bio nicely creates a folder called "Bryan Lee & The Jump Street Five" and downloads relevant album art.
However, marc's Thumbs creates a folder called "Bryan Lee & The Jump Street" and of course can't download any album art so the folder remains empty.
Can somebody confirm this ?
Reply #401
Bug reproduced. Those scripts used a 3rd party Javascript library called lodash and the way you supply arguments to one of the functions got changed when upgrading from the old version 3 used with JSP and the newer version 4 bundled with SMP
js\helpers.js line 197 replace
folder = folders.artists + _.truncate(a, 64);
with
folder = folders.artists + _.truncate(a, { length : 64 });
Reply #402
I'll remember that other scripts may use those paths, but so far I'm only using Marc's Thumbs and WilB's bio.
Also, I imagine that when we update SMP, all edited sample scripts will get overwritten to defaults? So perhaps copy the edited samples folder elsewhere for use, or make note of the changes you made, I guess.
Reply #403
@snotlicker : thanks, it worked indeed :)
@anamorphic : yes, I have already copied the edited samples AND made note of changes on separate txt files, just in case ;)
Reply #404
I think I found another glitch :
If %artist% is empty but %composer% is filled, WilB's bio creates a %composer% folder and downloads info, but marc's Thumbs does nothing.
Any hints ?
Reply #406
would be SpiderMonkey able to capture metadata from online source, apply them to audio tags, and eventually transfer the cover to album folder? The similar task what Discogs plugin does, just for custom source. If that's possible, could I get a hint what functions to use for it. Also I'd appreciate an existing script previously made for the same purpose as a template, if some.
Reply #407
Hallo there,
I'm using (latest) foobar v.1.5.2. I have also SpiderMonkeyPanel, Biography and JScript Panel on latest version.
It was working properly, as it should since yesterday at the afternoon: I can't see either artist pictures nor pictures from covers.  I see only text (biography) but no pictures.
Any suggestions please?
Reply #408
I'm bumping this because it's been a month :
If %artist% is empty but %composer% is filled, WilB's bio creates a %composer% folder and downloads info, but marc's Thumbs does nothing. Any hints ?
Reply #409
https://github.com/TheQwertiest/smp_2003/blob/master/js/helpers.js#L628
If all your tags are single value, you could replace it with %artist% as that has automatic fallbacks built in...
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Title_Formatting_Reference#.25artist.25
If your tags are multi-value, you should use $meta to access the first value only...
$if2($meta(artist,0),$meta(composer,0))
Reply #410
Thank you. That worked indeed! My happiness is complete now :)
Yes, I totally get your code. I'm quite OK at Titleformat but I suck at JS. I only needed to find the right line(s) in the right file(s), so thank you for pointing this one out! I really appreciate.
Reply #411
New bug report, in helpers.js, line 511 :
		app.Namespace(10).MoveHere(file);
Error: Spider Monkey Panel v1.2.3 (Thumbs by marc2003)
app.Namespace is not a function
File: helpers.js
Line: 511, Column: 3
Stack trace:
  _recycleFile@helpers.js:511:3
  _thumbs/this.rbtn_up_done@thumbs.js:461:4
  _panel/this.rbtn_up@panel.js:142:5
  on_mouse_rbtn_up@<main>:49:9
Reply #413
I recently updated to 1.5.3 and have had a steady stream of crashes since. I can't really understand the reports, other than they seem to indicate SMP (and probably Marc's Thumb script)? (using v1.2.3)
Can anyone help me decipher these?
CRASH:
CheckMenuRadioItem failed:
Index is out of bounds
File: thumbs.js
Line: 323, Column: 4
Stack trace:
  _thumbs/this.rbtn_up@thumbs.js:323:4
  _panel/this.rbtn_up@panel.js:85:4
Different CRASH
DrawImage failed:
GdiPlus error: DrawImage failed with error (0x7): Win32Error
File: helpers.js
Line: 265, Column: 3
Stack trace:
  _drawImage@helpers.js:265:3
  _thumbs/this.paint@thumbs.js:92:23
  on_paint@<main>:58:2
different CRASH:
DrawImage failed:
File: helpers.js
Line: 280, Column: 3
Stack trace:
  _drawImage@helpers.js:280:3
  _thumbs/this.paint@thumbs.js:136:23
Reply #414
Pretty sure that's your fault for bypassing the available menu options and entering your own thumbnail size via the Properties dialog???
Reply #415
good lead - I do have one panel with custom thumb size. thank you, I'll see if that helps.
Reply #416
It might be a casing error, try replacing `Namespace` with `NameSpace`.
PS: component development is still on-going, if anyone was wondering =) The new (major) feature is just too non-trivial and it gets me frustrated all the time >_<
Reply #417
@TheQwertiest : casing error indeed! 'NameSpace' worked perfectly. Thanks, and please note the correction for future releases. Thanks again.
Reply #418
I love your PS. Take care.
Reply #419
hit a crash. I think it's having issue with some high res large png images. foo_uie_albumart allows user to pick resolution resizing quality, not sure if it's this problem or just not happy with the type of png file(s)
File: helpers.js
Line: 287, Column: 1
Stack trace:
  _drawImage@helpers.js:287:1
  _thumbs/this.size/<@thumbs.js:55:6
  r@lodash.min.js:5:356
  Xe@lodash.min.js:67:63
  _thumbs/this.size@thumbs.js:54:5
  _thumbs/this.update@thumbs.js:483:3
  _thumbs/this.metadb_changed@thumbs.js:167:3
  on_metadb_changed@<main>:33:2
  _panel/this.item_focus_change@panel.js:11:4
  on_item_focus_change@<main>:25:2
Spider Monkey Panel v1.2.3 (Thumbs by marc2003): initialized in 698 ms
Opening track for playback: "D:\ISU\OST_CD.cue" / index: 11
Out of memory: 1754042880/1073741824 bytes
overall I'm just looking for something that allows folder name with wildcard searching and allows multiple folders with cycling through all supported arts
Reply #420
I'm searching a playlist viewer that can be linked to a specific playlist like EsPlaylist. Is it possible with jsplaylist? I've tried but It seems auto-linked to the active playlist  :(
Reply #421
Hi.
Picture cannot be displayed with Microsoft Store foobar2000 (not foobar2000 mobile).
https://www.microsoft.com/store/apps/9PDJ8X9SPF2K
Text only.Biography, thumbs ...
Spider Monkey Panel and JScript Panel.
Thanks for the help.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #422
Hi, another question about Thumbs script :
I have noticed that downloaded images are often low-res, even when there are lots of hi-res images for the same artist on last.fm.
For some artists there are hundreds of images available, but the component just seems to pick the first ones.
Is there an option to either favor hi-res images, or the most upvoted ones, or to set a minimum res ?
If not, it would be a nice add-on. Thanks !
Reply #424
Hi @snotlicker , I just asked if there was an option that I wouldn't know about, because there are tons of things I don't know about.
If it's not possible, then it's not possible, but there's no need to be ironic.
Also, since I'm not a dev, I don't know if SMP scripts can check downloaded files.
Maybe we could download an unknown pic, then once downloaded check its dimensions, and if it's too small, just trash it and download the next one. I don't know!
https://www.tutorialrepublic.com/faq/how-to-get-current-image-size-in-javascript.php
