Topic: Foobar2000 (Mobile Edition)  (Read 181286 times) previous topic - next topic
Re: Foobar2000 (Mobile Edition)
Reply #200
I upped the resolution of my cover art pictures but I can still see the artifacts on some that are not there when I open them as normal pictures in other app
If it's a scaling artifact you might want to reduce them to match the screen's resolution.
Reply #201
They look like jpeg artifacts. I don't know.
Reply #203
The resolution you see in specific locations of the program is hard coded in the program. The reason for this, is because the resized images are cached in memory for a while, and larger sizes with large libraries tends to lead to the player running out of memory.
Maybe you can convince Peter to try a mode that does no image caching whatsoever, and instead just loads images to memory as-is only when they are being displayed, then immediately disposes of them when they leave the screen. You may experience noticeable load time hitching as it reads the artwork, but you'll have your full resolution 300dpi artwork!
re
Reply #204
foobar2000 mobile resizes each image to the intended resolution and saves the resized version into its application data for future reuse, so next time the image loads near instantly. I chose to use JPEG for images with no alpha channel and PNG for images with alpha channel, which seems like a sensible tradeoff to me. Going 100% PNG will cause considerably higher CPU usage - but it may not result in a noticeable performance drop on today's high end devices. I'll provide an option to use only lossless formats (PNG) for rescaled images in a future update.
EDIT
Tested what happens if I go 100% PNG on my current low-anchor device, nothing particularly horrible, so here we go, from the next beta - 1.1.13 - no more intermediate JPEG.
EDIT 2
1.1.13 beta is available on Android.
Opt-in to receive betas here - https://foobar2000.org/test-android
Reply #205
I have foobar for android installed. I have a TP-link C2 wifi router with shared USD/UPNP plugged in to the router.
My laptop computer (Win 7), my Ipad (using Upnp app) and my android phone (using Suomi player) can access and browse the music easily
Foobar android does have an option to allow us to add server/shared drive.  However, it is frustrating to configure the shared drive on foobar. I did not success. I have tried to add the drive by below gramma
http://XX.XX.XX.XX/ with XX is my shared drive static LAN IP. this method is succeeded with Suomi player.
//XX.XX.XX.XX
//XX.XX.XX.XX:server password/
Does anyone know how to adding the shared network drive on foobar for android?
You answers are really appreciated!!!!
Reply #207
I have installed the "regular" fb2k on my convertible laptop. I would like to install fb2k mobile side-by-side in order to use it when the convertible is in tablet mode.
Will the two fb2k's have separate and independent user configurations? (I wouldn't want the mobile installation to alter the setup of the desktop one.)
Reply #208
Is there a hope to see "Convolver" DSP in foobar2000 for Android?
It's a fairly simple effect which also doesn't need a whole lot of GUI.
I mean, the direct analog of https://www.foobar2000.org/components/view/foo_convolve but in the Android version.
Reply #209
They are like 2 completely different applications.
Reply #210
They initially developed a "Windows App" version of the mobile fb2k, but I believe they stopped further development because it was the platform they had more problems on maintaining it. I really haven't followed the development, so I might be wrong in this regard, but it's your best hope. Following the link on the first page of this thread still points to a valid application.
Using an Android emulator is not really a good option, because you would have to emulate the storage, and that would complicate things too much probably.
Reply #211
Thanks. To reply somewhat belatedly: It looks like the standard desktop version is distributed via the Windows store. And yes, I agree it's probably not a good idea to run the Android version in an emulator such as Genymotion for my use case.
Reply #212
Is there a way to get *All Tracks" listed under the genres tab. Is there a file to edit anywhere that change the media library tree like with the windows program?
I have my music in genres and when I want to hear say Jazz, I want to be able to shuffle thru all the jazz on my phone, not just all the jazz under a particular artist. For some reason the All Tracks shows up under genre(Jazz)-->artist(John Coltrane)-->All Tracks but not under just the genre (Jazz)-->*missing*All Tracks.
Any ideas how to do this?
Is there a different forum where I should ask this question?
Reply #213
Yes. You'll probably have better luck at: http://forum.foobar2000.com/forum/
Reply #214
Hi
I did not find so ask.
I can add directory to a playlist on windows pc easily.
Now I wanted to do it on android, however the popup menu has not this function.
Are there any way to add directory as new playlist?
Also are there any way to import m3u playlist to playlist menu?
bye
szabi
Reply #215
Anyone know how to change preferences in which foobar2000 sorts albums?
Unlike Windows 7 and Android, Foobar 2000 mobile seems to sort albums by letters first than numbers.  I'd rather if it sorted by numbers first than letters like windows and android, as this is the way I have my library numbering sorted, and the different sorting system messes up how the library is viewed.  Only other alternative is having to retag all 580 albums. :( which I prefer not to do.
PS: Below the albums are listed in a simple list view, but in foobar, they appear in a grid view with album covers.
Folders as they appear in Windows 7 and Android Folders:
0000 - 1985 - Greatest Hits (the archies)
0002 - 2001 - Apple Blossoms and Spring Walks (various)
0004 - 2018 - Just a little old time love (various)
0006 - 2018 - A little more old time love (various)
0012 - 2018 - Battle of the Brits (Swaps Greenline) (various)
0013 - 2019 - Feel good 60s (various)
0014 - 2018 - The psychodelic flower trip (various)
0016 - 1988 - Bubblegum heaven (Various)
0017 - 2018 - Real Soul Flavour (various)
0020 - 2003 - The king (elvis presley)
0022 - 1965 - Rubber soul (the beatles)
0023 - 1966 - Revolver (the beatles)
0024 - 1967 - Sgt Pepper's Lonely heart's club (the beatles)
0026 - 1967 - The white album (limited edition single disc) (beatles)
0028 - 1968 - Magical Mystery Tour (the beatles)
0030 - 1969 - Abbey Road (beatles)
0034 - 1970 - Let it be (the beatles)
0036 - 1987 - Past Masters Volume II (the beatles)
0040 - 1981 - Greatest Hits Vol 1 part 1 (Queen)
0042 - 1981 - Greatest Hits Vol 1 part II (Queen)
0053 - 2019 - Super Memory Rewind 1968 (various)
0054 - 2019 - Super Memory Rewind 1969 (various)
0055 - 2019 - Super Memory Rewind 1970 (various)
0056 - 2019 - Super Memory Rewind 1971 (various)
0057 - 2019 - Super Memory Rewind 1972 (various)
0058 - 2019 - Super Memory Rewind 1973 (various)
0059 - 2019 - Super Memory Rewind 1974 (various)
0060 - 2019 - Super Memory Rewind 1975 (various)
0061 - 2019 - Super memory Rewind 1976 (various)
0062 - 2019 - Super memory Rewind 1977 (various)
0063 - 2019 - Super memory Rewind 1978 (various)
0064 - 2019 - Super memory Rewind 1979 (various)
0065 - 2019 - Super memory Rewind 1980 (various)
0066 - 2019 - Super memory Rewind 1981 (various)
0067 - 2019 - Super memory Rewind 1982 (various)
0068 - 2019 - Super memory Rewind 1983 (various)
0069 - 2019 - Super memory Rewind 1984 (various)
0070 - 2019 - Super Memory Rewind 1985 (various)
0071 - 2019 - Super Memory Rewind 1986 (various)
0072 - 2019 - Super Memory Rewind 1987 (various)
0073 - 2019 - Super Memory Rewind 1988 (various)
0075 - 2019 - Super Memory Rewind 1990 (various)
0076 - 2019 - Super Memory Rewind - Rockers of the Eighties (various)
0077 - 2019 - Super Memory Rewind - Australian Pop of the 80s (various)
0080 - 1974 - Fantastic (Ktel TA 248) (various)
0085 - 1974 - Bobby Daggler (Ktel TA 250) (various)
0090 - 1974 - Unreal (K tel TA 249) (various)
0100 - 1974 - Explosive hits '74 (EMI Australia) (various)
0104 - 1974 - Dynamyte 74 (various)
0110 - 1974 - Mind Stumper (Ktel TA 251) (various)
0116 - 1975 - Twister '75 (various)
0120 - 1975 - Outa Sight (Ktel TA 252) (various)
0124 - 1975 - Dynamyte '75 (various)
0130 - 1975 - Ripper 75 (fontana records) (various)
0140 - 1975 - Explosive Hits '75 (EMI) (various)
0150 - 1975 - Whopper (Polydor) (various)
0180 - 1975 - Screamer '75 (EMI Australia) (various)
0186 - 1975 - Saucer '75 (various)
0190 - 1976 - Bumper (EMI Australia) (various)
0200 - 1976 - Right on (Ktel records) (various)
snip
6502 - 1986 - The other side of life (the moody blues)
6504 - 1986 - Back in the Highlife (steve winwood)
6508 - 1986 - 51 50 (van halen)
6510 - 1986 - Dancing on the ceiling (lionel richie)
6520 - 1986 - Graceland (paul simon)
6524 - 1986 - Break every rule (tina turner)
6530 - 1986 - Leather Jackets (elton john)
6540 - 1986 - Boom baby boom (mondo rock)
6550 - 1986 - Whispering Jack (john farnham)
6554 - 1986 - Bruce Hornsby and the Range (bruce hornsby and the range)
6560 - 1986 - Tell me that you like it (taco)
6564 - 1986 - Manilow (barry manilow)
6570 - 1987 - Mad bad and dangerous (dead or alive)
6660 - 1987 - Dancing with strangers (chris rea)
6670 - 1987 - Whenever you need somebody (rick astley)
6672 - 1987 - Pearls of Passion (roxette)
6674 - 1987 - Up from Down Under (tommy emmanuel)
6678 - 1987 - Bad (deluxe edition) (michael jackson)
6680 - 1987 - The lonesome jubilee (john cougar mellencamp)
6690 - 1987 - Tales of the City (deluxe edition) (the rockmelons)
6698 - 1987 - Once upon a long ago (aussie three track cd) (paul mccartney)
6700 - 1987 - Nothing like the sun (sting)
6710 - 1987 - Love is the name of the game (patty ryan)
6720 - 1987 - I stand alone (agnetha faltskog)
6740 - 1988 - Cloud nine (george harrison)
6760 - 1988 - Tear down these walls (billy ocean)
6780 - 1988 - Scenes from the Southside (bruce hornsby and the range)
6810 - 1988 - Flashes (the best of) (irene cara)
6820 - 1988 - Age of reason (john farnham)
6830 - 1988 - Hold me in your arms (rick astley)
6832 - 1988 - Mamba (soundtrack)
6834 - 1988 - Volume one (the traveling wilburys)
6836 - 1988 - Gold (fancy)
6838 - 1988 - Temple of Low Men (crowded house)
6840 - 1988 - Une nuit ne suffit pas (frederic francois)
6842 - 1988 - Four play (blood sweat and tears)
6844 - 1988 - Four play (gary puckett and the union gap)
6848 - 1988 - Strangers by night (the best of) (cc catch)
6850 - 1988 - Cocktail (soundtrack)
6860 - 1989 - Mystery Girl (deluxe edition) (roy orbison)
6880 - 1989 - Sing (soundtrack)
6910 - 1989 - Look sharp (1997 reissue) (roxette)
6990 - 1990 - Sleeping with the past (deluxe edition) (elton john)
7010 - 1989 - Forever your girl (paula abdul)
7020 - 1990 - Cry like a rainstorm howl like the wind (linda ronstadt)
7110 - 1990 - Pretty Woman (original soundtrack)
7120 - 1990 - Armchair theatre (jeff lynne)
7140 - 1990 - Slow Motion (the best of) (modern talking)
7142 - 1990 - Diamonds and Storms (the best of) (john denver)
7143 - 1990 - The best of (john farnham)
7144 - 1990 - The very best of (cat stevens)
7145 - 1990 - America's greatest hits (america)
7146 - 1990 - Together in love (the best of) (captain and tennille)
7147 - 1990 - Greatest Hits (deluxe edition) (rod stewart)
7149 - 1990 - Elements (special edition) (mike oldfield)
7150 - 1990 - Cecilia (the best of) (limited edition) (simon and garfunkel)
7210 - 1991 - Worldwide love (little river band)
7270 - 1991 - Waking up the Neighbours (bryan adams)
7280 - 1991 - On every street (dire straits)
7430 - 1992 - The one (elton john)
7440 - 1992 - Calling you (with Andrew Pendlebury) (2 track cd single) (kate ceberano)
7442 - 1992 - In the closet (3 track promo single) (michael jackson)
7444 - 1992 - Everytime we touch (limited edition ep) (maggie reilly)
7560 - 1993 - Body and soul (rick astley)
7570 - 1993 - Then again (john farnham)
7580 - 1993 - Duets (elton john)
7610 - 1994 - Happy man (columbia house remaster) (david koz)
7675 - 1994 - The real thing (aussie 4 track promo) (2 unlimited)
7680 - 1994 - The colour of my love (celine dion)
7880 - 1995 - Head over heels (paula abdul)
7890 - 1995 - La carretera (julio iglesias)
7940 - 1996 - Falling into you (celine dion)
8000 - 1996 - Savage garden (savage garden)
8010 - 1996 - Fresh (gina g)
8014 - 1996 - Romeo's heart (john farnham)
8018 - 1996 - Where do we go from here (ep) (vanessa williams)
8020 - 1996 - Tango (julio iglesias)
8030 - 1996 - Greatest Hits (kenny g)
8180 - 1997 - Profondamente Innamorato (1997 BMG Remaster) (al bano and romina power)
8190 - 1997 - The big picture (elton john)
8380 - 1999 - Have a nice day (roxette)
8410 - 1999 - Poetic justice (jane saunders)
8470 - 1999 - Die zomernachten van san jos (Frans Bauer and Corry Konings)
8490 - 1999 - Affirmation (savage garden)
8500 - 1999 - Reload (tom jones)
8540 - 2000 - Two against nature (steely Dan)
8580 - 2001 - Room service (roxette)
8710 - 2004 - The greatest hits (chinese edition) (atomic kitten)
9130 - 1983 - Gezellig allies (various)
9140 - 1983 - Iedereen blij (various)
9675 - 2018 - So Fresh (the hits of Spring 2018) (various)
L164 - 1966 - Classics up to date Volume 1 (james last)
L194 - 1969 - Happy lehar (james last)
L198 - 1969 - Classics up to Date Volume 2 (james last)
L268 - 1976 - Classics up to Date Volume 4 (james last)
L348 - 1984 - Super best (richard clayderman)
L356 - 1985 - Strictly for Dancing (klaus wunderlich)
L404 - 1990 - Memories (richard clayderman)
L408 - 1990 - Barocco (Rondo Veneziano)
X310 - 1981 - The christmas album (original) (boney m)
X360 - 1986 - The Most Beautiful Christmas Songs of the World (boney m)
X690 - 2019 - The Best Christmas of All Time (various)
Folders as they appear in foobar mobile album viewer:
snip
Moderator Edit: Moved long lists to CODE boxes
The best place to be is where the sun never sets.
