Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1946940 times) previous topic - next topic
Re: CUETools versions 1.9.5 through 2.1.5 (current)
Reply #2975
cuetools 2.16 prerequisites lists net framework 2.0sp2 & vcrun2008.
today i created a fresh 64bit wineprefix, installed only dotnet20sp2 (x64) and to my surprise, cuetools (libflac) was working just fine.
in the changelog of cuetools you find:
I moved from Visual Studio 2005 to Visual Studio 2008, sorry folks, you might need to install yet another MS redistributable (most likely it's already installed): x86 version, x64 version. If you don't see libFLAC in the list of flac encoders, that means you need this redistributable. Although you can just use libFlake instead, which doesn't require it.
is vcrun2008 needed at all?
p.s. it even works with dotnet20sp1 alone - is wine transcendent or what?  8)
Reply #2976
a quick question: i would like to update (overwrite) the codecs from cuetools 2016 with the ones from 2017, will this work?
Reply #2977
Sorry, no. Also settings are incompatible, so it's best to either remove user_profiles_enabled file to keep settings with the program.
CUETools 2.1.6
Reply #2978
ok, i see, thanks.
i would like to stick with 2016 stable, any chance to make use of the latest flac version avaiable, then?
Reply #2979
No. But there's really no point. At this point in flac development, there aren't many improvements to be had.
CUETools 2.1.6
Reply #2980
have you ever considered making cuetools more modular by using codec.exes that can be exchanged more easily? i guess there is good reasons how things are working out right now, but i believe a modular concept has its claim.
Reply #2981
First of all, it is. You can actually configure it to use an external command line encoder if you wish to do so.
I wouldn't recommend it. As i said, flac is very stable and there's really no point in updating it.
Personally i use cuetools built in encoder, because it provides better compression than official encoder.
If i didn't have that, i'd use builtin libFLAC version, because it's stable and using a .dll is faster and safer in some ways than using an external command line encoder.
But if for some reason i fail to grasp those two options don't appeal to you, go ahead and configure an external command line encoder.
CUETools 2.1.6
Reply #2982
hey, no worries - it was more or less a kind of remembrance of the good old burrrn days :)
i loved the tool for its modularity, a very clean and simply way to update codecs (if you feel the need for).
i can live with an older flac version, but i would have upgraded if it is just a matter of copying over a file...
Reply #2983
Same here. I'm still trying out CUETools and using 2.1.6 but am looking forward to 2.1.7 with updated FLAC.
Reply #2984
hi
will there be support for musepack?
Reply #2985
i just tested cuetools 2.17 on a 64bit wineprefix (dotnet40 + vcrun2015 installed). when running libflac as encoder, i get the following warning:
exception: arithmetic operation resulted in an overflow
btw - cuetools encoder works, but it is very slow (50x) in comparison to libflac (170x on 2.16). is this the normal case (always used libflac)?
Reply #2986
It's probably possible to configure CUETools to use a command line musepack encoder.
I'm afraid i never tested cuetools with Wine. Was cuetools encoder as slow in 2.1.6? Also, what compression levels are we talking about in both cases, because cuetools -5 often compresses as good as libFLAC -7.
CUETools 2.1.6
Reply #2987
You have to realize that CUETools flake compresses as least as good as the generic flac encoder using the additional parameters e and p. The speed is great for its compression rate then. It is ~150x on a slightly OC'd 8700k at -8 btw.
Reply #2988
no prob, just wanted to let you know there is problems with wine and ct 2.17.
regarding cuetools encoder, i left all to default values (-5). in 2.16, the speed is pretty much identical.
@wombat: thanks for clarifying. which level to choose then with cuetools, if i am looking for libflac -6 (cuetools -4)?
Reply #2989
Sorry, i don't have numbers for inbetween levels. I always used and therefore compared high compression settings.
Reply #2990
well, i tried with cuetools -4 so to be on par with libflac -6, but it did not get that much better. now it is 58x (2.16 & 2.17) vs 170x (2.16).
Reply #2991
Thanks. Well, i'll blame Wine. It's a lot faster without it. Have you tried Mono?
CUETools 2.1.6
Reply #2992
no, i have not, but i'd be interrested to know as well. unfortunately, with mono, some tools refuse to work properly and you can not have both (dotnet + mono) in parallel.
in the end, it is just my wineprefix - ha! anyone on linux with the same results?
what is the speed of cuetools vs libflac on your win machine?
Reply #2993
Quick unscientific test on one small file:
Size       mode            speed
25,144,135 cuetools-8.flac 83.21x;
25,149,808 cuetools-7.flac 110.74x
25,153,336 cuetools-6.flac 122.28x
25,161,336 cuetools-5.flac 152.34x
25,172,183 cuetools-4.flac 172.86x
25,171,795 libFLAC-8.flac  161.39x
25,182,825 libFLAC-7.flac  222.90x
CUETools 2.1.6
Reply #2994
thank you.
Reply #2996
Oh right, sorry. Forgot i never got around to adding a button to register a new extension.
CUETools 2.1.6
Reply #2997
Wow, I've been running CUETools 2.1.5 in kvm (Linux VM) with XP for years. Running CUETools 2.1.6 under wine 3.0 on the same system is 7.5x faster (6 seconds vs 45 seconds) for a verify on the same album. Fortunately I did not encounter any crashes using wine, all the config screens worked fine. The font size is microscopically small on my 4K monitor though.
I'm seeing the same with Windows 10.  It appears that CUETools 2.1.6 does not follow DPI scaling I set.  Does anyone have any solutions?
Reply #2998
Is CUETools having issues querying recently added albums from ctdb?
http://db.cuetools.net/?tocid=xlmbOkBcwfHM2CvMl990tuhd5TY-
When running verify:
[CUETools log; Date: 5/5/2018 6:38:02 PM; Version: 2.1.6]
[AccurateRip ID: 001681b5-00d1bdf6-960bb00c] disk not present in database.
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --   99.8 [436F1A4D] [2933A9F6]
 01   99.8 [F4F2AA2F] [5D9DCF21]   CRC32
 02   99.8 [7044355F] [3E8D5529]   CRC32
 03   99.8 [ECF0A1A8] [907B2025]   CRC32
 04   99.8 [517F682D] [D8EBD158]   CRC32
 05   99.8 [22D45D61] [4530D008]   CRC32
 06   99.8 [3A3ED517] [0C7663F0]   CRC32
 07   99.8 [598B0B27] [CDEDA38A]   CRC32
 08   99.8 [4D7EE73F] [CA9905E1]   CRC32
 09   99.8 [BED8E745] [4E9C0D9A]   CRC32
 10   99.8 [3C97D910] [8E80C50D]   CRC32
 11   99.8 [12BC2E1E] [EAC74562]   CRC32
 12   99.8 [C1DDBF90] [D3D7D3D9]   CRC32
An older album verified just fine.
Reply #2999
No, it looks like it didn't even try to query the database. You might have turned it off by mistake. It's the checkbox next to the icon of a CD with a red plus on it.
CUETools 2.1.6
