Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1425306 times) previous topic - next topic
Re: CUETools versions 1.9.5 through 2.1.5 (current)
Reply #3000
No, it looks like it didn't even try to query the database. You might have turned it off by mistake. It's the checkbox next to the icon of a CD with a red plus on it.
CUETools 2.1.6
Reply #3001
Grrr, new install... my bad.  Thanx
Reply #3002
Greetings from a noob.  I've been using CueTools (ver 15) for awhile but lately receiving an "Exception: An Invalid Argument was supplied" error when trying to split files.  Might someone be able to point me towards a solution?  Using latest versions does not solve.
Thx
Reply #3003
A little more information would help. You didn't even give a format for the input or output files.
FLACCL can throw this type of exception. Perhaps you changed the FLAC encoder?
korth
Reply #3004
Thank you for responding korth.  Apparently it has something to do with my particular computer (running Win 10).  I've tried the same program, same cue file on a different LT (also Win 10) and it runs fine.  BTW I am using unaltered default settings and have had no problems until lately.
I will try to clean all evidence of CueTools out of my registry, restart and see if that cures the error.
Reply #3005
If you're not running as portable, the settings file is in %appdata%\CUE Tools
Delete (or rename) while CUETools isn't running.
korth
Reply #3006
Thank you again korth.  I'd tried everything with no luck, until I loaded it to a usb drive and it now works fine.  Whatever...it's good to have it working again.  :)
Reply #3007
Just a suggestion "for consideration" (I don't really know if there is a "good" way of improving this) for the settings. It concerns all the places there are tagging-related options. If I open the preferences, I see
* One tab for "Tagging".
* One tab for AccurateRip. Therein, there is a choice to write AccurateRip tags or not.
* One Advanced tab, where several sections are tagging-relevant.
At least, why not rename the AccurateRip tab into "AccurateRip&CTDB" and put the "Write CTDB tags" into there? Typically, I either want information to be updated or I don't ...
(And there is enough room in the Tagging tab to put the first two "advanced" tagging preferences to the right - could have an "Advanced" heading.)
Memento: this is Hydrogenaudio. Do not assume good faith.
Reply #3008
This thread is locked. Please use the new CUETools forum area for comments, questions about usage or otherwise request assistance. See Read First: a few posting guidelines before posting and for more information about where to make bug reports.
korth
