Topic: JScript Panel script discussion/help (Read 305433 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #125
So, with the lyrics3 panel no longer working I was wondering if it at all possible to have a script whipped up that could fetch lyrics? The ability to add our own sites for the query would be a nice option the extension was missing.
Reply #126
@OoNebsoO, use foo_facets with foo_playcount. Use a statistics column to reverse sort.
Reply #127
Is there a way to alter tag colors in properties.txt like this that doesn't involve editing the list.js color option? I dislike poking around in the scripts but in this case it was the only way I seem to be able to do it.
Reply #128
inside on_paint before calling list.paint(gr)...
panel.colours.text = _.RGB(1, 2, 3);
panel.colours.highlight = _.RGB(4, 5, 6);
Reply #129
Thanks, marc2003. Though, shame facets do not work within Column UI.
I am fooling around a bit with autoplaylists + esplaylist (elp in future most likely). Used a bit graphical browser, but for some reason, that won't display all the results. Works well with the whole library, of course, Can't figure out a query for a particular artist that is selected, or is playing though. If that's possible anyway...
Reply #130
I am getting this error with one of your sample scripts:
JScript Panel (Album Art + Allmusic Review by marc2003): JavaScript runtime error:
Unable to get property 'getElementsByTagName' of undefined or null reference
File: C:\Users\xxx\AppData\Roaming\foobar2000\js_marc2003\js\text.js
Line: 316, Col: 8
Reply #131
Is it happening with all artists/albums or just a specific one? If it's just one then let me know what it is and I'll take a look.
Reply #132
Well it's very rare and random it seems. I posted when it crashed during playing
Artist Name : Straylight Run
Track Title : Tool Sheds And Hot Tubs
Album Title : Straylight Run
Date : 2004
Genre : Alternative
but playing it a few more times just now didn't give any errors.
Also thanks a lot for your samples, I can't do anything in javascript so these are very helpful  ;)
Reply #133
Well it worked first time for me. There's not a lot I can when I can't reproduce the problem but I guess I should handle errors more gracefully.
Reply #135
you may mean this:
but......... could read Chinese? or ESLyric would be a good choice.
A rose will bloom, it then will fade.
Reply #136
marc2003, could Autoplaylists use only the currently playing playlist, and not the whole library? Or think that query could be made that uses currently playing (or selected artist) automatically? Something like %artist% (is playing/is selected) SORT DESCENDING BY %title%?
Reply #137
Using a custom source for autoplaylists would require component changes way beyond my extremely limited capabilities.
You can run a query against an existing playlist and send the results to a new (standard) playlist. This method doesn't support SORT BY but you can use regular title formatting to sort instead.
Reply #138
Dread to think how limited some of ours' capabilites are then. ;)
Thank you. Found also one older thread where you again helped a member who had quite similar questions like I had.
Reply #139
you may mean this:
Thank you but I did not have any luck with this
Reply #140
I hope this is the best place to ask this...
THe "now playing (basic)" Script... is it possible to change the location where the images are downloaded to? When selecting to download the images from last.fm it saves to the user configuration folder.. can I for example change this to my album artist folder? (drive\album artist\artowrk\?) This is something I already use for one source for my images.. ($replace(%path%,$directory(%path%)\%filename_ext%,)extrathumbs\*)
Reply #141
you may mean this:
Once @dreamawake made an English version of ESLyric and shared it with her configuration "Foobox" on deviantart, but got "SHIT" feedback... maybe that is why @ttsping(aka oyeah) has no motion to compile an english version.
Reply #142
Theoretically possible but tricky to explain so I'm just going to say no.  :))
Reply #143
Thank you. That's all I needed. Being new to foobar my head is spinning a little and wanted to make sure I wasn't overlooking anything.
Reply #145
Getting API error after I enter my last.fm password into last.fm sync sample panel, do I have to manually enter it into one of the .js files?
Reply #146
I want to add a few extra buttons to marc2003's sample "track info + seekbar + buttons", where do I find the functions syntax I need?
For example stop after queue/current.
Reply #147
docs\interfaces.txt contains most of what you need. You can get/set the state of stop after current with fb.StopAfterCurrent. You can also detect when the state changes using the on_playlist_stop_after_current_changed callback. See callbacks.txt
Assuming stop after queue is provided by some third party component, all you can do is trigger the menu command using fb.RunMainMenuCommand. You cannot query its state.
Reply #148
I opened interfaces.txt in Notepad and quickly found that was a mistake. So I opened it in the JScript Panel editor, which obviously should have been my first choice. Can you recommend a text editor that works the same way?
Reply #149
Thank you.
