Topic: JScript Panel script discussion/help (Read 308285 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #150
All samples I find for playback order button work fine in wsh panel but in js panel they give error -
JavaScript runtime error:
Overflow
File: <main>
Line: 132, Col: 2
<source text only available at compile time>
line is   k.CheckMenuRadioItem(1, 7, fb.PlayBackOrder + 1);
removing +1/-1 stops crashing but then the menu doesn't actually do anything. Is there a way to make it JS panel friendly?
Reply #152
Perfect, thanks again.
Reply #153
Last.fm updated their website today and it broke image downloading in my thumbs/now playing (simple) scripts. This fixes it...
https://raw.githubusercontent.com/19379/js-marc2003/master/js/thumbs.js
Just save it inside js_marc2003\js.
Thank you.
Each folder is now duplicates example:
This can be fixed?
Reply #155
I'm having a problem with the on_mouse_wheel callback. (jscript panel & wsh panel)
Any help is appreciated.
Using an external mouse with my laptop , scrolling is possible and  the callback returns step of 1 or -1 .
Using the touchpad though , with Asus Smart Gesture drivers , two-finger scrolling returns multiple steps of 0  and scrolling does not work right.
Is it a crappy driver issue , or an issue with the callback ?
Native playlists views , scollbars and volume are working fine with the two-finger scroll.
Reply #156
function on_mouse_wheel(a, b, c) {
    fb.trace("a: " + a);
    fb.trace("b: " + b);
    fb.trace("c: " + c);
Can you report the value of b when you scroll up/down with your trackpad.
Reply #157
Down
b: -80
b: -82
b: -82
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -46
b: -45
b: -45
b: -45
b: -45
b: -45
b: -45
b: -45
b: -44
b: -44
b: -44
b: -44
b: -44
b: -43
b: -43
b: -43
b: -43
b: -42
b: -42
b: -42
b: -42
b: -41
b: -41
b: -41
b: -40
b: -40
b: -40
b: -39
b: -39
b: -38
b: -38
b: -38
b: -37
b: -37
b: -36
b: -36
b: -35
b: -35
b: -35
b: -34
b: -34
b: -33
b: -33
b: -32
b: -31
b: -31
b: -30
b: -30
b: -29
b: -29
b: -28
b: -27
b: -27
b: -26
b: -26
b: -25
b: -24
b: -24
b: -23
b: -22
b: -22
b: -21
b: -20
b: -19
b: -19
b: -18
b: -17
b: -16
b: -16
b: -15
b: -14
b: -13
b: -13
b: -12
b: -11
b: -10
b: -9
b: -8
b: -7
b: -7
b: -6
b: -5
b: -4
b: -3
b: -2
b: -1
Up
b: 112
b: 112
b: 40
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 64
b: 63
b: 63
b: 63
b: 63
b: 63
b: 63
b: 63
b: 62
b: 62
b: 62
b: 62
b: 62
b: 61
b: 61
b: 61
b: 61
b: 60
b: 60
b: 60
b: 60
b: 59
b: 59
b: 59
b: 58
b: 58
b: 58
b: 57
b: 57
b: 56
b: 56
b: 56
b: 55
b: 55
b: 54
b: 54
b: 53
b: 53
b: 52
b: 52
b: 52
b: 51
b: 50
b: 50
b: 49
b: 49
b: 48
b: 48
b: 47
b: 47
b: 46
b: 45
b: 45
b: 44
b: 44
b: 43
b: 42
b: 42
b: 41
b: 40
b: 40
b: 39
b: 38
b: 37
b: 37
b: 36
b: 35
b: 34
b: 34
b: 33
b: 32
b: 31
b: 30
b: 30
b: 29
b: 28
b: 27
b: 26
b: 25
b: 24
b: 24
b: 23
b: 22
b: 21
b: 20
b: 19
b: 18
b: 17
b: 16
b: 15
b: 14
b: 13
b: 12
b: 11
b: 10
b: 9
b: 8
b: 7
b: 6
b: 5
b: 4
b: 2
b: 1
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
b: 2
a = 0
c = 120
Reply #158
Can you try this updated component. It's just the dll but I'm sure you know where to put it.
edit: temporary link removed. I'll publish a proper update later.
Reply #159
Thanks for your help marc2003.
The updated component resolved the problem and works fine. :)
Reply #160
@marc2003   How can I change the Volume sample script so that it works vertically instead of horizontally?
Reply #161
Inside your panel, replace the on_paint function with this:
function on_paint(gr) {
gr.FillSolidRect(volume.x, volume.y, volume.w, volume.h, volume.c1);
gr.FillSolidRect(volume.x, volume.y + volume.h - volume.pos(), volume.w, volume.pos(), volume.c2);
Then open js_marc2003\js\volume.js and replace the this.move function with this:
		this.move = function (x, y) {
this.mx = x;
this.my = y;
if (this.trace(x, y)) {
y -= this.y;
var pos = y < 0 ? 1 : y > this.h ? 0 : 1 - (y / this.h);
this.drag_vol = 50 * Math.log(0.99 * pos + 0.01) / Math.LN10;
_.tt(this.drag_vol.toFixed(2) + " dB");
if (this.drag)
fb.Volume = this.drag_vol;
this.hover = true;
return true;
} else {
if (this.hover)
_.tt("");
this.hover = false;
this.drag = false;
return false;
and replace the this.pos function with this:
		this.pos = function () {
return _.ceil(this.h * (Math.pow(10, fb.Volume / 50) - 0.01) / 0.99);
Make sure reload the panel after editing the .js file.
Reply #162
@marc2003 I now have a vertical volume bar. Thank you!
Reply #163
marc2003, any way for different Autoplaylist panels to keep their own queries? As it is now, one will 'pick off' queries from another, and you'll end up with two panels with same queries on both.
Reply #164
Thanks for spotting that. The updated file can be downloaded using the same link:
Hello !
Help please with thumbs. Is it possible to change the aspect of double-clicking on the screen?
I tried through window.SetProperty ( "2K3.THUMBS.ASPECT", 0);
window.SetProperty ( "2K3.THUMBS.ASPECT", 1);
window.SetProperty ( "2K3.THUMBS.ASPECT", 2);
window.SetProperty ( "2K3.THUMBS.ASPECT", 3);
but window.Repaint ();  does not work here.
After window.Reload (); do not load next images from the Internet
How to refresh the screen? Thank you!
Reply #165
OoNebsoO, autoplaylists is meant to be single instance only. However, you could try hacking it like this
var list = new _.list("autoplaylists", 10, 24, 0, 0); //original line - do not touch
list.filename = folders.settings + "autoplaylists2.json"; //only add this/modify filename in extra panels. autoplaylists.json is the original filename so don't use that
list.update();
seriousstas,
thumbs.aspect++;
if (thumbs.aspect > 3)
    thumbs.aspect = 0;
window.SetProperty("2K3.THUMBS.ASPECT", thumbs.aspect);
window.Repaint();
Reply #167
Much appreciated, yet again, marc. :)
Reply #168
Yet one question :):
Delete function for a single file:
this.delete_image = function () {
_.recycleFile (this.files [this.images]);
this.update (); }
How do delete all the files in the current folder?
Reply #169
_.map(this.files, _.recycleFile);
this.update();
Reply #170
Seems like if a character tabulation (U+0009) is present in a tag and a script tries to access it the result is a crash.
https://en.wikipedia.org/wiki/Whitespace_character
Don't expect to have any in my tags, just thought I'd mention it anyway.
Reply #171
There is no problem accessing/displaying tags with these characters in. The error is caused by the script trying to create a new folder based on the tag value. I'll look at handling this better.
Reply #173
Thank you for your work marc!
Reply #174
marc, in your sample track info + seekbar + buttons is it possible to have a notch/mark on the seekbar at a certain percent? Any directions if you don't mind?
