Topic: Audibility of "typical" Digital Filters in a Hi-Fi Playback  (Read 331564 times) previous topic - next topic
0 Members and 17 Guests are viewing this topic.
Reply #650
The only relevant discussion relates to the CD.
It was simple science.
(1) I created a suite of recordings of music and high bandwidth natural sounds @ 24/96 using microphones with 40+ KHz bandpass.
(2) Using myself and friends as guinea pigs I ABXed them with downsampled/upsampled versions of themselves.
None of us could hear a difference.  This was > 14 years ago when my hearing was much more sensitive to subtle differences.
Hi Arny.  Perhaps we should fill out more of this story as you told it on AVS.
It went like this:
Quote from: Amir on AVS link=msg=0 date=
Fortunately, the above speculations are not true.  With complex music signals the limit of audiblity is more like 16 KHz due to masking, and that is more than plenty far enough away from 44.1 KHz with modern digital filters.
Ah yes.  I recall you saying this before:
I've done experiements with sliding brick wall filters down to lower and lower frequencies. Usually, they start being barely audible around 16 KHz.
Can you please outline those tests?  Were they double blind or sighted?  And was the person performing the tests had his hearing tested to make sure they could hear above 16 Khz?
And a reference to masking of everything above 16 KHz would also make for great bedtime reading for me .
You kindly replied with this:
I did what I said in the previous post. I made recordings of live  musicans in an exceedingly quiet and non-reverberent room @24/96 using 1/4" measurement mics that had strong content > 20 KHz, even 30 KHz.
I set up an ABX between the 24/96 files with a 16 KHz brickwall filter, and with full bandpass. I used speakers and amps with strong response > 30 KHz and put the listeners on axis of their supertweeters.
both
The training sequence was files brick walled at lower frequencies such as 9 KHz, and working up in logical steps.
Yes.
So this testing was done at 32 Khz sampling.
I'm talking about different tests that were as I said, they involved 44.1 KHz sampling.
These other 32 KHz tests were also done.
As you know I and a number of other people passed this test.  So clearly you hearing was not that sensitive even then .
I know no such thing.  Neither I nor any of  my designated representatives were present at the AVS tests  you seem to be describing, so I don't know for sure if the tests were performed properly. I was present at the tests I described so I have some confidence about them.
Reply #651
The other implication that I was referring to in the final section of M&M 2007 is that as a format becomes more popular, the mastering for it gets worse.
We *already* see 'loudness' mastering in 'high rez' releases...it's been evident for years now. *
On 'audiophile' forums I routinely see high rez releases (*and downloads* ) critiqued for the sorts of 'bad' mastering moves long the bane of CD remasters (e.g. , extreme compression, 'smiley face' EQ,  resulting in lack of 'crankability').
This sort of mastering happens because, over and over, since at least the 1960s, someone, somewhere in the production chain, decides that these mastering moves 'sound better ' -- e.g., to focus groups comparing short samples of audio that are not level-matched.  There's solid psychoacoustic foundation for *that* being a predictable outcome.
So, if the industry pushes high rez downloads, what's to prevent that mindset from proliferating more?  Won't that bring us back to where we started?  Popular music genres will be given 'modern' mastering, classical and jazz, left pretty much alone?
This is what happens when the consumer is led to believe that a 'format' necessarily gives you great sound.
The focus of the consumer (especially the 'audiophiles' to whom this shilling is primarily aimed) should not be on 'high rez' but on MASTERING CHOICES.
*Amusingly , Steely Dan's Gaucho is one of the hi rez releases on M&M's sample list.  In terms of dynamic range compression, does this look way better than CD?  Contrary to Tap Dancers who claim that their opponents have no criticisms for M&M, I'd say (and have said) that M&M were too naively accepting of the generalization that high rez releases have superior mastering. (That said, Gaucho sounds pretty 'audiophile' in any incarnation.  The tale of its production is hilarious as a fable of late-1970s coke-fueled obsessiveness)
Reply #652
Well, neither I nor any of my designated representatives were present at the tests you are describing so I don't know for sure if the tests were performed properly!  But I was present at my own tests and I have a lot of confidence about them.
You also said this on AVS:
Quote from: Arny on AVS link=msg=0 date=
When I served in the US Army (drafted) in the 1960s they had no clue about hearing protection. I qualified with 3 different firearms, worked on firing ranges, and worked routinely for about 30 months in a very noisy environment. While any damage that may have related to those experiences did not seem to hurt my hearing acuity that much when I was younger, these days things are far worse.
I now struggle to hear the effects of an 8 KHz brick wall filter at normal listening levels. So while Floyd Tooles comments may relate to Amir and you John, some of us did not have such protected lives, no fault of our own.
14 years ago would have been year 2000, some 40 years after the firearm damage to your ears.  So surely your hearing was shot by the time you performed the 44 Khz tests, pun intended .  I hope you agree that given what you have told us, your listening test results are not reliable measure of what anyone else would hear.
Amir
Retired Technology Insider
Founder, AudioScienceReview.com
Reply #653
Arny's tests may indeed not be indicative of what others may hear but by the same token, neither are yours especially since you've been so coy about disclosing what you heard.
Reply #654
Something I said to Amir a month ago:
"I share your hope for better sound, but also your fear that someone will screw it up. Apple already want higher than CD resolution as input to produce AAC files. Record labels want those tracks to stand out. How long will it be before CD-style compression/limiting of high resolution files becomes common? "
Regards,
   Don Hills
"People hear what they see." - Doris Day
Reply #655
My answer to you has been to try the same test.  But you don't.  Yet keep asking me to do more.  Here is a person who is one of detractors on AVS as you know, and kept ridiculing the idea of anyone passing these tests, including posting a number of failed ABX tests.  He listened to me and gave it a serious try and reported as such: http://www.avsforum.com/forum/91-audio-the...ml#post25871786
Quote from: imagic link=msg=0 date=
Laptop? Practice?
Well, I decided to give my laptop a try since Amir did so well using his. Lo and behold, I had little difficulty with the 16/32 key jangling test. Not quite perfect, but I suspect a bit more practice would get me up to perfect.
My laptop is a Sony Vaio PCG-41412L with the HD upgraded to a SSD. All audio enhancements are off. I used a pair of Sony MDR-1R headphones.
The results speak for themselves; I found a critical segment that revealed an audible difference. I've had some practice, which helped—just as Amir suggested. Now, I can pass an ABX test I previously failed. I'll tackle the 16/44 test next. Oh, and it was a piece of cake to pick out the differences in the 16/16 and 22/16 tests.
foo_abx 1.3.4 report
foobar2000 v1.3.3
2014/07/19 11:26:49
File A: C:\Users\mark_000\Downloads\keys jangling band resolution limited 3216 2496.wav
File B: C:\Users\mark_000\Downloads\keys jangling full band 2496.wav
11:26:49 : Test started.
11:27:29 : 00/01 100.0%
11:28:58 : 00/02 100.0%
11:29:46 : 00/03 100.0%
11:29:59 : 01/04 93.8%
11:30:06 : 01/05 96.9%
11:30:16 : 02/06 89.1%
11:30:26 : 03/07 77.3%
11:30:34 : 04/08 63.7%
11:30:45 : 05/09 50.0%
11:31:00 : 06/10 37.7%
11:31:10 : 07/11 27.4%
11:31:29 : 08/12 19.4%
11:31:41 : 09/13 13.3%
11:32:05 : 10/14 9.0%
11:32:20 : 10/15 15.1%
11:32:30 : 11/16 10.5%
11:32:41 : 12/17 7.2%
11:32:52 : 13/18 4.8%
11:33:07 : 13/19 8.4%
11:33:16 : 14/20 5.8%
11:33:28 : 15/21 3.9%
11:33:40 : 16/22 2.6%
11:33:58 : 17/23 1.7%
11:34:12 : 18/24 1.1%
11:34:25 : Test finished.
Total: 18/24 (1.1%)
Give the above test a try.  It is 32 Khz sampling so there should be no doubt whatsoever that we have truncated useful bits.  Hopefully you hear the difference and the material acts like training.  Run the higher sample rate ones and listen to the exact same segment.  If you can't hear the difference go back and re-listen to the 32 Khz.  If nothing else, you will get a first hand feel for what we are talking about.
If you recall, I also shared with you the detailed subjective remarks from Stuart's paper which is the subject of this thread. What came out of that?  Nothing, right?  So this is yet another request to be ignored or written off as cheating, etc.  This is not a constructive discussion as to have proper give and take.  It is all take and complaining because the answer is not what you want to hear.  And that will continue to be the case no matter what you ask me.  I aspire for excellence and as long as folks are not, they are not going to hear from me what they want to hear.
Amir
Reply #656
Fear is the first letter in FUD .  There is no reason to speculate negatively here.  Become a customer and advocate of better mastering and we will get in this narrow distribution channel (stupid to even talk about it for mass market releases).
I keep repeating myself: this is not 2007.  This is not the same old business.  The world has changed around us.  See this from many such examples, for one of the award winning mastering engineers, Doug Sax: http://mixonline.com/news/profiles/masteri...h.cHY5BQ9r.dpuf
When he was invited to sit on Ludwig’s Platinum Mastering Panel this year, Doug Sax suggested they discuss mastering for multiple formats. “Ten years ago, you made a CD master and you were done,” Sax says. “Now you do a CD master, a master for iTunes, a high-resolution master for HDtracks, and a cutting master for vinyl.”
See?  Separate mastering.  You think he is going to do the same thing he does for iTunes?  or CD?  He doesn't or he wouldn't have specifically named that as another branch.
You guys need to put aside negatively and learn the new world order.  Things are moving in the right direction but only if you believe in best fidelity, not good enough.
Amir
Reply #657
This could indeed result in a huge fail for the hi-res peddlers.
By suggesting to the masses that it is the format that makes the music sound better instead of the recording, mixing and mastering "choices", the people responsible for the horrible sound quality would get a free pass for what, another decade, two, until ultra-hi-res comes along?
The rationale behind this is that by making hi-res a commodity just like the CD, the uninformed average listener will just happily buy a crappy hi-res product as he/she is doing today with crappy CDs. CD audio would become obsolete, hi-res crap the norm rather than the exception.
I can already imagine amirm in 10 years, still wasting Internet traffic, but this time about ultra-hi-res, and how bigger is always better (except if it doesn't fit his momentary argument).
"I hear it when I see it."
Reply #658
When he was invited to sit on Ludwig’s Platinum Mastering Panel this year, Doug Sax suggested they discuss mastering for multiple formats. “Ten years ago, you made a CD master and you were done,” Sax says. “Now you do a CD master, a master for iTunes, a high-resolution master for HDtracks, and a cutting master for vinyl.” [/color][/i]
See?  Separate mastering...
Since it is already stablished that there is no audible difference between the hi rez formats and CD format, and vinyl is obsolete. It looks like their intention is to scam the final user (consumer).
Reply #659
You must have no understanding of mastering to say that.
Amir
Reply #660
In the most characteristic "subjective audiophile" fashion I am having a strong audio gut feeling that you purpously misquoted Meyer and Moran. They mean exactly the oposite of what you are saying since 2007.
I am not a subjectivists nor are you an objectivists if you don't even read the published literature on this topic.
You said there should be a warning that says anyone who buys a high resolution title is delusional.  I showed you evidence from prosecution's witness that high resolution releases, you know the real product, absolutely sound superior to their CD releases due to better mastering.  As such you blanket assertion that hearing better fidelity is imaginary is wrong.
...of the SACD and DVD-A recordings sounded better than most CDs...
That is a very illogical affirmation. It should have said it sounded diferent (not better). it s that from a scientific paper??!!
No, it is not a scientific paper.  It is an engineering report published in the Journal of Audio Engineering Society.
Dynamic range compression does not depend on audio format.
Technically no, but from business point of view, it absolutely does.  The labels and talent consider CD and MP3/AAC formats as mass market so impose their wants in the form of loudness compression.  There is no such business rule for high resolution releases.
It is a choice made by the recording technician. Didn't Meyer and Moran know that?! I don't think they said that. I don't think you can be trusted as a source of information. Can you show some evidence?
Who the heck is a "recording technician?"
The only myopic views are coming from your posts. If a difference can't be heard in a properly set double blind test (to get rid of bias) than that difference is irrelevant. I think you know that but you choose to believe otherwise.
You are in a thread where such a difference was heard in double blind tests and reported in award winning peer reviewed paper in Audio Engineering Society.  Please do a bit of education before randomizing the thread.
And that was not even the point of my reply to you.  It was the fact that by getting the upstream stereo master, it could be created to a different set of business rules than mass market releases.
Amir
Reply #661
Amir, I've already explained to you why I haven't done the tests and have never stated that you cheated. It may well be that due to various issues, be they time offsets or level differences, that the test can be considered cheatable but that is a far cry from accusingly you. A full disclosure, and really something more than what you posted on WBF, would be illuminating and could help to advance discussions in that area.
Reply #662
Yeah because less extra compression, less extra EQ, ... in short less messing up the sound quality deliberately, that does cost extra $$$! Audiophile logic. (I guess that's why audiophiles are the ones willing to pay for the extra cost.)
But you want to make CD obsolete, right? It will happen eventually, and depending on the success of the hi-res peddler probably faster than we think.
So where is your niche market, where people have to pay more money for less destruction, when hi-res is the "mass market"?
No, you are in a thread where in the best condition the score was very close to the worst condition, and that was being better than about 56% correct.
Oh and "randomizing the thread"? See amir credibility.
Reply #663
He's not interested in being honest (see amir credibility).
He's not even willing to listen to this 4 second short test file: imp_urhp.wav, and tell us what he hears in his system. Well I think he already did download and listen, but he's evading. Cognitive dissonance at its best.
Reply #664
amir, stop moving the goalposts. This discussion is (in part) about technical benefits of "hi-res" formats, not about de-facto benefits of "hi-res" releases due to bad mastering practices for CD releases. In any case, an easy, sensible, scientific and honest way to study the benefits of "hi-res" formats is the experiment I (and many others before me) described earlier.
I also urge you to study what "scientific" means.
If you keep posting the same nonsense over and over this discussion will close.
Reply #665
Reinventing the Audio Power Amplifier: Mark Levinson No 53
By Amir Majidimehr
But How Does it Sound?
In comparison testing I have done, switching amplifiers using the classic class D configuration always sport incredible low frequency control and power. They beat out linear class AB amplifiers almost regardless of price. What they give up though is high frequency fidelity which I find somewhat harsh. The distortion is highly non-linear and challenging to spot but it is there. The Mark Levinson No 53 is the first switching amplifier I have heard which does not have this compromise. Its bass is amazingly authoritative: tight and powerful. Yet the rest of the response is absolutely neutral and pleasant.
If you have not heard these unique amplifiers, I highly encourage you to come into our showroom for a listen. We have a pair on hand driving our Revel speakers. I am confident that they will improve the sound of your current speakers given the ease with which they can drive any load regardless of how difficult they might be (and many high-end speakers are difficult to drive). We are happy to let you evaluate them with your own system to see the benefits of this technology.  Hearing this amplifier was an eye-opener for me.  I think it will be for you too.
Would love to see you start a thread about "Audibility of Typical Filters in a Class D amp" Amir. You've mentioned TOS #8 a few times, so we know you are aware of it.
cheers,
AJ
Loudspeaker manufacturer
Reply #666
I have no power to do so.  But I absolutely believe CD needs to be shot in the head and put out of its misery.  In this day and age creating plastic waste, and spinning a motor to read 650 megabytes?  Are you kidding?
No, hi-res has no influence on CD going away.  It is the mass market that pays the bills and will cause its gradual demise.
No, there is no mass market for high res.  There will be a market much larger than today.  But still roundoff error in the grand scheme of things.  Just like the unit volume for Porsche vs Ford.
Our role in all of this is to create a meaningful market where some segment of the content producers service us.  There is already a good start so the chicken and egg problem has been solved.  We just need to let it thrive.
If that causes you, Krab, AJ, etc. angst, that much the better.
Amir
Reply #667
Since it is already established that there is no audible difference between the hi rez formats and CD format, and vinyl is obsolete. It looks like their intention is to scam the final user (consumer).
There is a format on the list that has the potential to add audible differences - iTunes, which I believe means AAC a well known perceptual encoder.
It is generally recognized that the transparency of modern perceptual coders may be less than perfect with certain musical sources.
It may be possible to produce a given musical work in such a way that it is encoded more accurately by perceptual coders.  Seems like it could be a worthy goal for recordings that are going to widely distributed as perceptually encoded files.
BTW this post is off-topic in this thread and any further discussion of it should be moved to an appropriate thread.
Reply #668
I am not doing that.  Others are doing so to randomize the topic.  Here is one of many posts like that:
1. We "improve" the wrong thing, to the detriment of other things that would introduce a real/greater audible improvement.
Bingo.  While Amirm and Stuart  and Neil Young are flogging this technology, we're still getting 'loudness wars' mastering. And we are still stuck ina 2-channel paradigm.  And listening in rooms that are often horrendous, acoustically.
What the hi rez cheerleading squad is doing is akin to trying to focus all attention on the font of a document that is too often contains gibberish.
The question is why...why would this be the focus, when *all of them* know  where the actual 'obvious and audible and known about  for years' problems lie?
I am also constantly being asked to provide  my personal opinion so I do.
Your recommendation there is very sound and one that I am 100% on board on.  And to the dismay of few here, is one that Stuart recommended in his JAES paper, Coding for high resolution.
The problem with it is one of execution.  There is no mandate, broad education or certification that anyone includes noise shaped dither.  The default in my Adobe Audition CC for sample rate is white TPDF.  Noise shaping is off by default. There are some 8 options for noise shaping.  I challenge you to find any recording engineer that can explain what all of them mean.
And then there is the "marketing of it."  We call dither noise.  Imagine the reaction of someone producing music to "noise."  They naturally have a suspicious opinion of adding dither.
Go to any pro audio forum and search for dither.  YOu will find opinions all over the place.  Here I did a quick search on Gearslutz where I hang out from time to time: https://www.gearslutz.com/board/mastering-f...n-any-type.html
Quote from: random producer on GS forum link=msg=0 date=
So, I just started using Reaper this year. It is the first time I have found myself in a situation where I can apply dither as I listen and toggle it on and off.
The dither sounds like poo.
The sound stage just gets so much smaller. So my questions are:
Is all dither obviously audible?
Does Reaper just ship with a bad dither plug?
Am I doing something wrong with a perfectly fine plug?
Is it all totally in my head and there is in fact no difference to hear because dither noise is just too low?
On a side note, this dither is going on post limiter, and then only on personal reference mixes. The final product will never see dither applied by me.
Instead of relying on all of these people understanding proper dither and its use, I say let's bypass the whole thing.  Let's get the bits prior to down conversion.  If you want to still have 16/44.1, you can convert it yourself with dither of your choice.  There is no technological reason anymore to have these guys make random selections as to stuff the bits on CD.
I have no emotional attachment to the thread or this forum.  Feel free to close the thread any time you like.
On what is science, feel free to open another thread and we can have a good discussion.  I assure you in five minutes I can show that none of you are following the first thing about that.
Amir
Reply #669
Ignores common knowledge about hearing damage:
http://www.worker-health.org/noisehearingloss.html
"It is important to recognize that noise-induced hearing loss is cumulative. This means that exposures to loud levels of noise off the job – gunfire, power tools, and loud music - can also contribute to a worker’s overall hearing loss."
I am fully aware that I'm responding to a poster who appears to be desperate to distract this discussion from its topic because the on-topic discussion  leaves him little rational to say. However technical errors such as this one need to be addressed.  Any further discussion of the topic of cumulative hearing damage should be moved to an appropriate thread.
Reply #670
I was talking about CD audio, as in the format 44.1/16. That's one of the main parts the thread is about, not physical media.
What? That doesn't even make any sense.
If hi-res gains mass market traction then CD audio will eventually go away. Hi-res won't be that market where you can scam people to pay more money for less deliberate destruction of sound quality anymore, but the new mass market.
How can you fail to even understand these simple postings?
Despicable. But nothing else to expect, see amir integrity.
imp_urhp.wav is still waiting.
Reply #671
Posts nonsense in over 27 pages, repeats fallacy after fallacy even after they are pointed out, posts multiple logical abominations ... and finally, posts a random ancedote to support another one of his off-topic journies in the same post where he finally posts this:
Q.E.D. amir has disqualified himself from any rational or honest discourse. All people can objectively understand this by googling this thread, for a summary see amir integrity.
Reply #672
Wrong. Your (subjectivist) sides role, was to subvert the idea of fidelity to original soundfields and come up with ways to sell $50k "sound" amps and justify $50 2ch recordings because they possess "more resolution" and other such excrement.
This was long ago recognized by someone who might be considered the patriarch of the whole mess, despite him distancing himself from the idiocy at the end:
JA - Do you still feel the high-end audio industry has lost its way in the manner you described 15 years ago?
JGH - Not in the same manner; there's no hope now. Audio actually used to have a goal: perfect reproduction of the sound of real music performed in a real space. That was found difficult to achieve, and it was abandoned when most music lovers, who almost never heard anything except amplified music anyway, forgot what "the real thing" had sounded like. Today, "good" sound is whatever one likes. As Art Dudley so succinctly said [in his January 2004 "Listening," see "Letters," p.9], fidelity is irrelevant to music.
Since the only measure of sound quality is that the listener likes it, that has pretty well put an end to audio advancement, because different people rarely agree about sound quality. Abandoning the acoustical-instrument standard, and the mindless acceptance of voodoo science, were not parts of my original vision.
JA - I remember you strongly feeling back in 1992 that multichannel/surround reproduction was the only chance the industry had for getting back on course.
JGH - With fidelity in stagnation, spatiality was the only area of improvement left.
That's all this horse and pony show about 2ch "Hi-Rez" and what the crap that the BS paper peddles is all about. Squeezing more $$ out of the few idiots left, who long ago ceased to want anything remotely resembling fidelity to original soundfields.
Yes, "Higher Resolution" of Neil Youngs guitar amp studio construct. Whatever the heck that might be. I'd love to see someone identify that 24bit vs the 16/44 TPDF version under any circumstances.
Except an unsupervised online ABX Windows pc "test" of course.
cheers,
AJ
Reply #673
Addressing this bit of pseudo science:
1. Where on earth do you see non-linear distortions? You don't even know what an LTI system is, but talk big about filters? What the..
Down conversion involves both filtering and quantization.  Quantization error is anything but a linear distortion.  And likewise accuracy/quantization error in the filter math also creates non-linear distortion.  Do you really think what they heard in Stuart's listening test was linear distortion?  Linear distortion garners such adjectives?  "Echoes, when audible, were identi ed as being a ected the most clearly by the ltering. It was felt that some of the louder passages of the recording were less aggressive after ltering, and that the inner voices (second violin and viola) had "a nasal quality".  I don't think so.  Not at all.
But let's suspend reality and follow your TLA buzzword.  The cognitive part of the brain does not follow the rules of signal processing.  Let's look at the impulse response again:
From math/signal processing point of view we can say all of this ringing is benign.  The theory says this is what must happen in time domain to implement the low pass function.  But that is not how the psychoacoustics works.  We hear each one of those samples as they come.  The brain doesn't collect them all and then say, "ah, that was a FIR filter."  It hears the individual samples as they get processed by the transfer function of the low pass filter.  This is why you can't use your logic of "it is a linear function."  Those sample transforms taken individually do not represent such.
To understand this topic fully, you must have broad understanding of multiple disciplines.  Assuming it just about college textbook signal processing will surely cause you to fall into a ditch thinking the results created by Stuart's research is impossible. Only to see the opposite come true.
Ditto for assuming we are all sensitive to distortions the same way which was my point.  We are not and that is amply proven in detection of lossy compression artifacts where expert listeners can hear distortions that masses cannot perceive at all.
3. I also already told you that I take the paper for what it is, and there are still unknowns. Your stereotyping of me, which you even admitted, prevents you from actually understanding my position. You don't even care about any of this. All this is for you is a "war" (your own word), that you apparently need to win at all cost, which sadly seems to include your sanity.
No, the war has been lost.  It was lost before this thread even started.  The discussion is months old.  On WBF Forum the thread is 1,500 posts long and 41,000 views.  On AVS it is on the order of 3,000 posts.  Krab, Arny, mzil, etc. have made all of their arguments elsewhere and lost them.  Specific to this discussion of my hearing ability with respect to distortions, Arny had this to say: http://www.avsforum.com/forum/91-audio-the...ml#post25344962
Amir, I reject the implication that you and I are in the same camp, audio-wise. IMO, you are a Golden Ear, pure and simple.
It is not easy to get him to volunteer such things as I am sure you know.  But volunteer he had after he saw the few of us accomplish what most could not.
Amir
Reply #674
Only a seriously self deluded individual with overactive imagination, like for example, a "subjectivist" audiophile...could read that Arny quote in anything other than a pejorative sense.
No Amir, there is no "war", except within your mind of "worry" and other subjectivist audiophile issues. This is about distributed (to be) reproduced music, purportedly for musical enjoyment (which we all know isn't on the audiophile need list).
The BS paper is not an "attack" on rational, objective folks. It's an attempt by those with pecuniary interests in "Hi-Rez" to concoct some form of counter to the M&M 2007 "Hi-Rez" myth buster. It has more holes than swiss cheese, but we understand if it's all you got.
And no, 13yrs of unsupervised, unrecorded and in at least one case fabricated, test results, don't count.
I'm sure this isn't the last we are going to hear about this BS paper. So your psychogenic "war" isn't over quite yet.
cheers,
AJ
