@pbelkner, I appreciate your posting of the lib1770 code, and have a question about the gating constants. From my reading of bs1770_stats.c, the gating overlap is set to 50% of the of the 400 ms window. However, BS.1770-2 (03/2011) specifies a gating overlap of 75%. Shouldn't the overlap be 300 msec instead of 200 msec?
Version 0.8.5 released:
[blockquote]Home: http://r128gain.sourceforge.net/
Download: http://sourceforge.net/projects/r128gain/files/[/blockquote]What's new?
- Allow choosing the BS.1770 block overlap by the parameter partition (1, 2, 3, ...). The corresponding overlap in % is (1 - 1/partition) * 100%.
- LIB1770 is updated accordingly.
Example command line with block overlap 75% (partition 4) and gate -10.0:
$ r128gain --partition=4 --gate=-10.0 ../sounds/ebu-loudness-test-setv01/
SoX successfully loaded.
FFmpeg successfully loaded.
analyzing ...
1kHz Sine -20 LUFS-16bit.wav (1/16): -20.0 LUFS, -3.0 LU (peak: 0.100733: -19.9 dBFS)
1kHz Sine -26 LUFS-16bit.wav (2/16): -26.0 LUFS, 3.0 LU (peak: 0.050508: -25.9 dBFS)
1kHz Sine -40 LUFS-16bit.wav (3/16): -40.0 LUFS, 17.0 LU (peak: 0.010260: -39.8 dBFS)
seq-3341-1-16bit.wav (4/16): -23.0 LUFS, -0.0 LU (peak: 0.071316: -22.9 dBFS)
seq-3341-2-16bit.wav (5/16): -33.0 LUFS, 10.0 LU (peak: 0.023049: -32.7 dBFS)
seq-3341-3-16bit.wav (6/16): -23.0 LUFS, 0.0 LU (peak: 0.071468: -22.9 dBFS)
seq-3341-4-16bit.wav (7/16): -23.1 LUFS, 0.1 LU (peak: 0.070849: -23.0 dBFS)
seq-3341-5-16bit.wav (8/16): -22.9 LUFS, -0.1 LU (peak: 0.100845: -19.9 dBFS)
seq-3341-6-5channels-16bit.wav (9/16): -23.0 LUFS, 0.0 LU (peak: 0.063132: -24.0 dBFS)
seq-3341-6-6channels-WAVEEX-16bit.wav (10/16): -23.0 LUFS, 0.0 LU (peak: 0.063132: -24.0 dBFS)
seq-3341-7_seq-3342-5-24bit.wav (11/16): -23.0 LUFS, -0.0 LU (peak: 0.358340: -8.9 dBFS)
seq-3341-8_seq-3342-6-24bit.wav (12/16): -23.2 LUFS, 0.2 LU (peak: 0.718297: -2.9 dBFS)
seq-3342-1-16bit.wav (13/16): -22.6 LUFS, -0.4 LU (peak: 0.100088: -20.0 dBFS)
seq-3342-2-16bit.wav (14/16): -16.8 LUFS, -6.2 LU (peak: 0.177971: -15.0 dBFS)
seq-3342-3-16bit.wav (15/16): -20.0 LUFS, -3.0 LU (peak: 0.100088: -20.0 dBFS)
seq-3342-4-16bit.wav (16/16): -24.5 LUFS, 1.5 LU (peak: 0.100073: -20.0 dBFS)
ALBUM: -21.9 LUFS, -1.1 LU (peak: 0.718297: -2.9 dBFS)
