Topic: [crashware] foo_uie_lyrics2 (Read 484588 times) previous topic - next topic
Reply #575
first of all GREAT WORK works fine exept a little thing.
If there's a song with no lyric, and the plugin download it automatically. The functions (open with External editor, open file location) should be enabled.
this is for me not the case, i cannot open, it is greyed out (open with.. and open in..) what could be the reason?? its not the problem to open the folder otherwise but a bit anoying...
Thanks in advance
Reply #576
normally  i wanted to edit my previous post, but there is no option anymore.
i found out, that downloaded lyric.lrc files cannot be open with... and open file... during the current session of f2k but if i restart f2k the options are available..
perhaps that helps, kindly
Reply #577
Will anyone pick up the project and keep improving it?
It's really good except can't dock the windows inside Foobar2000 (or I don't know how).
Hong Kong - International Joke Center (after 1997-06-30)
Reply #579
yes you can absolutely use this plugin as a UI element in Default UI:
http://tinypic.com/r/rrt54m/4
Enable Layout Editing Mode and add as a new Default UI Element, scroll down to the Utilities section, it's labelled "Lyrics Show Panel v2"
Reply #580
and how about an ability to edit embedded lyrics in-place (by choosing from context menu)?
Reply #581
I have a problem with this plugin:
If a song has multiple artists, for example the currently popular song
David Guetta - Gettin' Over You,
wich has artists David Guetta; Chris Willis; Fergie; LMFAO,
then lyrics2 doesn't recognize the song and doesn't show any lyrics.
I will try to fumble with title formatting to extract the first artist. But I'd be glad if anyone is gonna share a ready-to-go title formatting expression.
Another Problem: The first artist is not always the "main" artist, especially if you use other (bad) programs like Windows Media Player, that sort multiple artists alphabetically and saves the changes (which is a task you didn't tell them to do). Then the order would be Chris Willis; David Guetta; Fergie; LMFAO. What to do in this case? Would be great if lyrics2 could be changed to handle this in the future (maybe search for every single artist until something is found).
Reply #582
if you look at the developer's profile page.....
Last Seen: 9th February 2010 - 22:44
edit: forgot to mention you can get the first artist using $meta(artist,0) - and don't use windows media player.
Reply #583
Thanks, I knew there would be a simple solution.
Reply #584
Allright, the next problem:
The song "Madcon - Glow" makes lyrics2 to grab the lyrics from another song, "Nelly Furtado - Glow". Is it possible to prevent this?
Reply #585
Is it possible to have the component download and save (automatically) the timestamped lyrics to LYRICS and the non-timestamped lyrics to UNSYNCHEDLYRICS?  I can get it to do the former but not both.  My situation is that I want to the time stamped lyrics when using foobar but don't want them on my iPhone...  looks bad with all of the time stamps.
Reply #586
I found out that lyrics 2 can't show any text when playback has stopped.
Please change this in the next version. I tried this:
$if(%isplaying%,$char(1)Cblah,$char(1)Cnot blah)
Didn't work for stopped playback.
Reply #587
Yes, I would like this feature as well.
Reply #588
eh, on windows 7 32/64 foobar crashed with this plugin after 30-40 (maybe less) or more songs plays
on XP works perfectly
Reply #589
Latest plugin version (.15) and foobar 1.0.3 work perfectly with win7 x64 here.
I'm still to update to foobar 1.1 so can't really say anything about it, but up to 1.0.3 works fine, as long as the latest plugin version is used.
Reply #590
Is it possible to specify different font sizes for the fallback text? Line 1 big size, line 2 smaller... ?
Reply #591
Has anyone had an issue with the plugin not finding "unsynced lyrics" for songs that have an apostrophe in the title?  I'm going through Beatles songs (which should have easy-to-find lyrics) and I can get them all except songs with apostrophes in the title.  Anyone else have/noticed this issue?
Reply #592
Is there a way to show album art in the background without shading from the background color?  I've tried turning on transparent background, but that doesn't fix this problem.  Thanks in advance!
Reply #593
This is a thread for a lyrics component.  Did you mean to post elsewhere?
terry
Reply #594
From what I understood, he wants the lyric panel background to be the plain album cover. Which in the best case scenario would make the lyrics pretty much unreadable due to the multiple colors of the cover. Background for readable text (in this case, lyrics) should be plain or a soft gradient at most, putting an image there (specially without the "shading", a.k.a. low opacity) would result in a mess. Your best shot: leave the lyrics with a "regular" background and add another panel for Album Art.
Reply #595
Sometimes the plugin doesn't save the lyrics to the tag, is it normal?
Reply #596
Unfortunately yes. Use then "save to tag" by mouse.  :-)
Reply #597
is it just me or does the text not scroll as smoothly as foo_uie_lyrics.dll
Reply #598
If the lyric is searched manually, "save the tag" sometimes will save the previous one, but not the recent one. Another issue,if search manually, the button "download" seems not work, I have to double-click the lyric, it will display.
Reply #599
The download page 403's me, any idea how to solve it?
でも、何事をぞんじるやなんて...
